  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
  • apollon77A apollon77
    @thekilroy kannst du bitte mal den Inhalt des Objekts system.adapter.admin.0 Porsten? )(expertenmodus unter Objekte mit dem Stift und dann das json posten)
    TheKilroyT Offline
    TheKilroyT Offline
    TheKilroy
    #231
    @apollon77
    Sorry, das war das Falsche, hier jetzt die richtigen Daten
      "_id": "system.adapter.admin.0",
      "type": "instance",
      "common": {
        "name": "admin",
        "title": "Admin",
        "version": "6.2.22",
        "desc": {
          "en": "The configuration of ioBroker via Web-Interface",
          "de": "Die Konfiguration von ioBroker über das Web-Interface",
          "ru": "Конфигурация ioBroker через веб-интерфейс",
          "pt": "A configuração do ioBroker via Web-Interface",
          "fr": "La configuration de ioBroker via Web-Interface",
          "nl": "De configuratie van ioBroker via de webinterface",
          "it": "La configurazione di ioBroker tramite interfaccia Web",
          "zh-cn": "配置ioBroker的Web界面"
        "docs": {
          "en": "docs/en/admin.md",
          "ru": "docs/ru/admin.md",
          "de": [
            "docs/de/admin.md",
            "docs/de/admin/tab-adapters.md",
            "docs/de/admin/tab-instances.md",
            "docs/de/admin/tab-objects.md",
            "docs/de/admin/tab-states.md",
            "docs/de/admin/tab-groups.md",
            "docs/de/admin/tab-users.md",
            "docs/de/admin/tab-events.md",
            "docs/de/admin/tab-hosts.md",
            "docs/de/admin/tab-enums.md",
            "docs/de/admin/tab-log.md",
            "docs/de/admin/tab-system.md"
          "pt": "docs/pt/admin.md",
          "nl": "docs/nl/admin.md",
          "es": "docs/es/admin.md",
          "fr": "docs/fr/admin.md",
          "it": "docs/it/admin.md",
          "pl": "docs/pl/admin.md",
          "zh-cn": "docs/zh-cn/admin.md"
        "materialize": true,
        "mode": "daemon",
        "platform": "Javascript/Node.js",
        "loglevel": "info",
        "icon": "admin.png",
        "messagebox": true,
        "enabled": true,
        "extIcon": "https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/admin/admin.png",
        "keywords": [
          "setup",
          "config",
          "update",
          "upgrade",
          "system",
          "konfiguration",
          "administration",
          "einrichtung",
          "wartung"
        "compact": true,
        "readme": "https://github.com/ioBroker/ioBroker.admin/blob/master/README.md",
        "authors": [
          "bluefox <bluefox@ccu.io>",
          "hobbyquaker <hq@ccu.io>"
        "dependencies": [
            "js-controller": ">=3.3.22"
        "type": "general",
        "license": "MIT",
        "logTransporter": true,
        "stopBeforeUpdate": true,
        "wwwDontUpload": true,
        "nogit": true,
        "welcomeScreenPro": {
          "link": "admin/index.html",
          "name": "Admin",
          "img": "admin/img/admin.png",
          "color": "pink",
          "order": 5,
          "localLink": true,
          "localLinks": "_default"
        "localLink": "%protocol%://%ip%:%port%",
        "plugins": {
          "sentry": {
            "dsn": "https://9d2aaf29332a4999b133c693f43203b9@sentry.iobroker.net/18"
        "installedVersion": "6.2.22",
        "host": "shsrv02.kilroy.local",
        "installedFrom": "iobroker.admin@6.2.22",
        "jsonConfig": true,
        "titleLang": {
          "en": "Admin",
          "de": "Admin",
          "ru": "Админ",
          "pt": "Admin",
          "pl": "Admin",
          "fr": "Admin",
          "nl": "Admin",
          "it": "Admin",
          "es": "Admin",
          "zh-cn": "Admin"
        "adminUI": {
          "config": "json"
        "localLinks": {
          "_default": {
            "link": "%protocol%://%bind%:%port%",
            "pro": true
        "connectionType": "local",
        "dataSource": "push",
        "news": {
          "5.0.19": {
            "en": "Admin5: Fixed many bugs",
            "de": "Admin5: Viele Fehler behoben",
            "ru": "Admin5: Исправлено множество ошибок",
            "pt": "Admin5: muitos bugs corrigidos",
            "nl": "Admin5: Veel bugs opgelost",
            "fr": "Admin5: Correction de nombreux bugs",
            "it": "Admin5: risolti molti bug",
            "es": "Admin5: se corrigieron muchos errores",
            "pl": "Admin5: Naprawiono wiele błędów",
            "zh-cn": "Admin5:修复了许多错误"
          "5.0.18": {
          "5.0.17": {
          "5.0.16": {
          "5.0.15": {
            "en": "optimized the loading process",
            "de": "optimierte den Ladevorgang",
            "ru": "оптимизировали процесс загрузки",
            "pt": "otimizou o processo de carregamento",
            "nl": "geoptimaliseerd het laadproces",
            "fr": "optimisé le processus de chargement",
            "it": "ottimizzato il processo di caricamento",
            "es": "optimizado el proceso de carga",
            "pl": "zoptymalizował proces ładowania",
            "zh-cn": "优化了加载过程"
          "5.0.14": {
          "5.0.13": {
          "5.0.12": {
          "5.0.11": {
            "en": "Admin5: users management implemented",
            "de": "Admin5: Benutzerverwaltung implementiert",
            "ru": "Admin5: реализовано управление пользователями",
            "pt": "Admin5: gerenciamento de usuários implementado",
            "nl": "Admin5: gebruikersbeheer geïmplementeerd",
            "fr": "Admin5: gestion des utilisateurs implémentée",
            "it": "Admin5: implementata la gestione degli utenti",
            "es": "Admin5: gestión de usuarios implementada",
            "pl": "Admin5: zaimplementowano zarządzanie użytkownikami",
            "zh-cn": "Admin5:已实施用户管理"
          "5.0.10": {
            "en": "Admin5: Implemented the language filter and selector for rating with comments",
            "de": "Admin5: Der Sprachfilter und die Auswahl für die Bewertung mit Kommentaren wurden implementiert",
            "ru": "Admin5: Реализован языковой фильтр и селектор для оценки с комментариями.",
            "pt": "Admin5: Implementado o filtro de idioma e seletor para classificação com comentários",
            "nl": "Admin5: Implementeerde het taalfilter en de selector voor beoordeling met opmerkingen",
            "fr": "Admin5: implémentation du filtre de langue et du sélecteur pour l'évaluation avec des commentaires",
            "it": "Admin5: implementato il filtro della lingua e il selettore per la valutazione con commenti",
            "es": "Admin5: implementó el filtro de idioma y el selector para calificar con comentarios",
            "pl": "Admin5: Zaimplementowano filtr i selektor języka do oceny z komentarzami",
            "zh-cn": "Admin5:实现了语言过滤器和选择器,以对评论进行评分"
          "5.0.9": {
          "5.0.8": {
            "en": "Admin5: Implemented rating with comments",
            "de": "Admin5: Bewertung mit Kommentaren implementiert",
            "ru": "Admin5: Реализовал рейтинг с комментариями",
            "pt": "Admin5: Avaliação implementada com comentários",
            "nl": "Admin5: Beoordeling met opmerkingen geïmplementeerd",
            "fr": "Admin5: Évaluation mise en œuvre avec commentaires",
            "it": "Admin5: valutazione implementata con commenti",
            "es": "Admin5: Calificación implementada con comentarios",
            "pl": "Admin5: Zaimplementowano ocenę z komentarzami",
            "zh-cn": "Admin5:已实施评分并带有注释"
          "5.0.7": {
          "5.0.6": {
          "5.0.5": {
          "5.0.4": {
          "5.0.3": {
            "en": "Admin5: Many new features implemented",
            "de": "Admin5: Viele neue Funktionen implementiert",
            "ru": "Admin5: реализовано много новых функций",
            "pt": "Admin5: Muitos novos recursos implementados",
            "nl": "Admin5: Veel nieuwe functies geïmplementeerd",
            "fr": "Admin5: de nombreuses nouvelles fonctionnalités implémentées",
            "it": "Admin5: molte nuove funzionalità implementate",
            "es": "Admin5: muchas funciones nuevas implementadas",
            "pl": "Admin5: Zaimplementowano wiele nowych funkcji",
            "zh-cn": "Admin5:已实现许多新功能"
          "5.0.2": {
            "en": "Merged the changes from admin4",
            "de": "Die Änderungen von admin4 wurden zusammengeführt",
            "ru": "Слил изменения от admin4",
            "pt": "Mesclou as alterações de admin4",
            "nl": "Samengevoegd de wijzigingen van admin4",
            "fr": "Fusion des modifications de admin4",
            "it": "Fuse le modifiche da admin4",
            "es": "Fusionó los cambios de admin4",
            "pl": "Scalono zmiany z admin4",
            "zh-cn": "合并来自admin4的更改"
          "5.0.0": {
            "en": "The tile view implemented for the file browser",
            "de": "Die für den Dateibrowser implementierte Kachelansicht",
            "ru": "Представление плитки реализовано для файлового браузера",
            "pt": "A visualização em bloco implementada para o navegador de arquivos",
            "nl": "De tegelweergave geïmplementeerd voor de bestandsbrowser",
            "fr": "La vue en mosaïque implémentée pour le navigateur de fichiers",
            "it": "La visualizzazione affiancata implementata per il browser di file",
            "es": "La vista de mosaico implementada para el navegador de archivos",
            "pl": "Widok kafelków zaimplementowany dla przeglądarki plików",
            "zh-cn": "为文件浏览器实现的图块视图"
          "4.1.1": {
            "en": "Started the development of GUI based on React (only for developers)",
            "de": "Startete die Entwicklung einer GUI basierend auf React (nur für Entwickler)",
            "ru": "Начата разработка графического интерфейса на основе React (только для разработчиков)",
            "pt": "Iniciou o desenvolvimento da GUI com base no React (apenas para desenvolvedores)",
            "nl": "Begonnen met de ontwikkeling van GUI op basis van React (alleen voor ontwikkelaars)",
            "fr": "A commencé le développement de GUI basé sur React (uniquement pour les développeurs)",
            "it": "Ha iniziato lo sviluppo della GUI basata su React (solo per sviluppatori)",
            "es": "Comenzó el desarrollo de GUI basado en React (solo para desarrolladores)",
            "pl": "Rozpoczął tworzenie GUI w oparciu o React (tylko dla programistów)",
            "zh-cn": "开始开发基于React的GUI(仅适用于开发人员)"
          "5.0.20": {
          "5.0.21": {
          "5.0.22": {
            "en": "Admin5: Fixed some bugs",
            "de": "Admin5: Einige Fehler wurden behoben",
            "ru": "Admin5: Исправлены некоторые ошибки",
            "pt": "Admin5: Corrigido alguns bugs",
            "nl": "Admin5: enkele bugs opgelost",
            "fr": "Admin5: Correction de quelques bugs",
            "it": "Admin5: risolti alcuni bug",
            "es": "Admin5: se corrigieron algunos errores",
            "pl": "Admin5: Naprawiono kilka błędów",
            "zh-cn": "Admin5:修复了一些错误"
          "5.0.24": {
            "en": "Admin5: GUI fixes",
            "de": "Admin5: GUI-Korrekturen",
            "ru": "Admin5: исправления графического интерфейса",
            "pt": "Admin5: Correções de GUI",
            "nl": "Admin5: GUI-fixes",
            "fr": "Admin5: correctifs de l'interface graphique",
            "it": "Admin5: correzioni della GUI",
            "es": "Admin5: correcciones de GUI",
            "pl": "Admin5: poprawki GUI",
            "zh-cn": "Admin5:GUI修复"
          "5.0.23": {
          "5.0.27": {
          "5.0.26": {
          "5.0.25": {
          "5.0.28": {
          "5.0.29": {
            "en": "Admin5: Fixed reorder of the items in menu",
            "de": "Admin5: Neuordnung der Elemente im Menü behoben",
            "ru": "Admin5: Исправлен переупорядочение пунктов в меню.",
            "pt": "Admin5: Reordenação corrigida dos itens no menu",
            "nl": "Admin5: Vaste herschikking van de items in het menu",
            "fr": "Admin5: Correction de la réorganisation des éléments dans le menu",
            "it": "Admin5: corretto riordino degli elementi nel menu",
            "es": "Admin5: reordenamiento fijo de los elementos en el menú",
            "pl": "Admin5: Naprawiono zmianę kolejności elementów w menu",
            "zh-cn": "Admin5:修复了菜单中项目的重新排序"
          "5.0.30": {
            "en": "Admin5: Fixed update of objects",
            "de": "Admin5: Aktualisierung von Objekten behoben",
            "ru": "Admin5: Исправлено обновление объектов",
            "pt": "Admin5: atualização corrigida de objetos",
            "nl": "Admin5: Vaste update van objecten",
            "fr": "Admin5: Correction de la mise à jour des objets",
            "it": "Admin5: corretto aggiornamento degli oggetti",
            "es": "Admin5: actualización fija de objetos",
            "pl": "Admin5: Naprawiono aktualizację obiektów",
            "zh-cn": "Admin5:修复了对象的更新"
          "5.0.31": {
            "en": "Admin5: Improved the enumerations",
            "de": "Admin5: Die Aufzählungen wurden verbessert",
            "ru": "Admin5: Улучшены перечисления",
            "pt": "Admin5: Melhorou as enumerações",
            "nl": "Admin5: Verbeterde opsommingen",
            "fr": "Admin5: Amélioration des énumérations",
            "it": "Admin5: migliorate le enumerazioni",
            "es": "Admin5: se mejoraron las enumeraciones",
            "pl": "Admin5: Poprawiono wyliczenia",
            "zh-cn": "Admin5:改进了枚举"
          "5.1.0": {
            "en": "Admin5: Fixed update of objects\nAdmin5: React UI is by default enabled",
            "de": "Admin5: Aktualisierung von Objekten behoben\nAdmin5: React UI ist standardmäßig aktiviert",
            "ru": "Admin5: Исправлено обновление объектов\nAdmin5: React UI по умолчанию включен",
            "pt": "Admin5: atualização corrigida de objetos\nAdmin5: React UI está habilitado por padrão",
            "nl": "Admin5: Vaste update van objecten\nAdmin5: React UI is standaard ingeschakeld",
            "fr": "Admin5: Correction de la mise à jour des objets\nAdmin5: React UI est activé par défaut",
            "it": "Admin5: corretto aggiornamento degli oggetti\nAdmin5: React UI è abilitato per impostazione predefinita",
            "es": "Admin5: actualización fija de objetos\nAdmin5: React UI está habilitado de forma predeterminada",
            "pl": "Admin5: Naprawiono aktualizację obiektów\nAdmin5: React UI jest domyślnie włączony",
            "zh-cn": "Admin5:修复了对象的更新\nAdmin5:默认情况下,React UI已启用"
          "5.0.32": {
            "en": "Admin5: Support of ANSI codes in log",
            "de": "Admin5: Unterstützung von ANSI-Codes im Protokoll",
            "ru": "Admin5: Поддержка кодов ANSI в журнале",
            "pt": "Admin5: Suporte de códigos ANSI no log",
            "nl": "Admin5: Ondersteuning van ANSI-codes in logboek",
            "fr": "Admin5: Prise en charge des codes ANSI dans le journal",
            "it": "Admin5: supporto dei codici ANSI nel registro",
            "es": "Admin5: Soporte de códigos ANSI en el registro",
            "pl": "Admin5: Obsługa kodów ANSI w dzienniku",
            "zh-cn": "Admin5:支持日志中的ANSI代码"
          "5.1.2": {
            "en": "Admin5: Fixed logs by the changing of host",
            "de": "Admin5: Protokolle durch Hostwechsel behoben",
            "ru": "Admin5: Исправлены логи при смене хоста",
            "pt": "Admin5: logs corrigidos pela mudança de host",
            "nl": "Admin5: Logboeken gerepareerd door het wisselen van host",
            "fr": "Admin5: Correction des journaux par le changement d'hôte",
            "it": "Admin5: corretti i registri cambiando host",
            "es": "Admin5: Registros fijos por el cambio de host",
            "pl": "Admin5: Naprawiono dzienniki przez zmianę hosta",
            "zh-cn": "Admin5:通过更改主机来修复日志"
          "5.1.1": {
            "en": "Admin5: Fixed teh host selector\nAdmin5: Implemented the colored logs",
            "de": "Admin5: Der Host-Selektor wurde korrigiert\nAdmin5: Die farbigen Protokolle wurden implementiert",
            "ru": "Admin5: Исправлен селектор хоста\nAdmin5: Реализованы цветные логи",
            "pt": "Admin5: Seletor de host corrigido\nAdmin5: Implementado os logs coloridos",
            "nl": "Admin5: De host-selector is opgelost\nAdmin5: Implementeerde de gekleurde logboeken",
            "fr": "Admin5: Correction du sélecteur d'hôte\nAdmin5: implémentation des journaux colorés",
            "it": "Admin5: corretto il selettore host\nAdmin5: implementati i log colorati",
            "es": "Admin5: Se corrigió el selector de host\nAdmin5: Implementó los registros de colores.",
            "pl": "Admin5: Poprawiono selektor hosta\nAdmin5: Zaimplementowano kolorowe dzienniki",
            "zh-cn": "Admin5:修复了主机选择器\nAdmin5:实施彩色日志"
          "5.1.3": {
            "en": "Improved the GUI for enumerations",
            "de": "Die GUI für Aufzählungen wurde verbessert",
            "ru": "Улучшен графический интерфейс для перечислений.",
            "pt": "Melhorou a GUI para enumerações",
            "nl": "Verbeterde GUI voor opsommingen",
            "fr": "Amélioration de l'interface graphique pour les énumérations",
            "it": "Migliorata la GUI per le enumerazioni",
            "es": "Se mejoró la GUI para enumeraciones.",
            "pl": "Poprawiono GUI dla wyliczeń",
            "zh-cn": "改进了枚举的GUI"
          "5.1.4": {
            "en": "Corrected error in log",
            "de": "Fehler im Protokoll behoben",
            "ru": "Исправленная ошибка в журнале",
            "pt": "Erro corrigido no registro",
            "nl": "Fout in logboek gecorrigeerd",
            "fr": "Erreur corrigée dans le journal",
            "it": "Errore corretto nel registro",
            "es": "Error corregido en el registro",
            "pl": "Poprawiony błąd w logu",
            "zh-cn": "更正了日志中的错误"
          "5.1.5": {
            "en": "Fix edit of enumeration",
            "de": "Korrektur der Bearbeitung der Aufzählung",
            "ru": "Исправить редактирование перечисления",
            "pt": "Corrigir a edição da enumeração",
            "nl": "Herstel bewerking van opsomming",
            "fr": "Correction de la modification de l'énumération",
            "it": "Correzione della modifica dell'enumerazione",
            "es": "Corregir edición de enumeración",
            "pl": "Napraw edycję wyliczenia",
            "zh-cn": "修复枚举的编辑"
          "5.1.6": {
            "en": "Improved the custom settings",
            "de": "Die benutzerdefinierten Einstellungen wurden verbessert",
            "ru": "Улучшены пользовательские настройки",
            "pt": "Melhorou as configurações personalizadas",
            "nl": "De aangepaste instellingen verbeterd",
            "fr": "Amélioration des paramètres personnalisés",
            "it": "Migliorate le impostazioni personalizzate",
            "es": "Mejorada la configuración personalizada.",
            "pl": "Poprawiono ustawienia niestandardowe",
            "zh-cn": "改进了自定义设置"
          "5.1.7": {
            "en": "Added the possibility to clear the schedule",
            "de": "Möglichkeit hinzugefügt, den Zeitplan zu löschen",
            "ru": "Добавлена возможность очистить расписание",
            "pt": "Adicionada a possibilidade de limpar a programação",
            "nl": "De mogelijkheid toegevoegd om het schema te wissen",
            "fr": "Ajout de la possibilité d'effacer le planning",
            "it": "Aggiunta la possibilità di cancellare il programma",
            "es": "Añadida la posibilidad de borrar el horario",
            "pl": "Dodano możliwość wyczyszczenia harmonogramu",
            "zh-cn": "添加了清除时间表的可能性"
          "5.1.9": {
            "en": "Corrected some GUI errors",
            "de": "Einige GUI-Fehler korrigiert",
            "ru": "Исправлены некоторые ошибки графического интерфейса.",
            "pt": "Corrigidos alguns erros de GUI",
            "nl": "Enkele GUI-fouten gecorrigeerd",
            "fr": "Correction de quelques erreurs d'interface graphique",
            "it": "Corretti alcuni errori della GUI",
            "es": "Se corrigieron algunos errores de GUI",
            "pl": "Poprawiono niektóre błędy GUI",
            "zh-cn": "更正了一些 GUI 错误"
          "5.1.8": {
            "en": "Improved the list of predefined icons",
            "de": "Liste der vordefinierten Symbole verbessert",
            "ru": "Улучшен список предустановленных значков.",
            "pt": "Melhorou a lista de ícones predefinidos",
            "nl": "De lijst met vooraf gedefinieerde pictogrammen verbeterd",
            "fr": "Amélioration de la liste des icônes prédéfinies",
            "it": "Migliorato l'elenco delle icone predefinite",
            "es": "Se mejoró la lista de iconos predefinidos.",
            "pl": "Poprawiono listę predefiniowanych ikon",
            "zh-cn": "改进了预定义图标列表"
          "5.1.10": {
          "5.1.11": {
            "en": "Changed the filter of objects",
            "de": "Filter von Objekten geändert",
            "ru": "Изменен фильтр объектов",
            "pt": "Mudou o filtro de objetos",
            "nl": "Het filter van objecten gewijzigd",
            "fr": "Modification du filtre des objets",
            "it": "Modificato il filtro degli oggetti",
            "es": "Cambiado el filtro de objetos.",
            "pl": "Zmieniono filtr obiektów",
            "zh-cn": "更改了对象的过滤器"
          "5.1.12": {
            "en": "The charts were improved\nCorrected the error with the jump links if more than one web instance",
            "de": "Die Charts wurden verbessert\nFehler mit den Sprunglinks bei mehr als einer Webinstanz behoben web",
            "ru": "Графики были улучшены\nИсправлена ошибка с переходом по ссылкам при наличии нескольких веб-экземпляров.",
            "pt": "Os gráficos foram melhorados\nCorrigido o erro com os links de salto se mais de uma instância da web",
            "nl": "De grafieken zijn verbeterd\nDe fout met de springlinks gecorrigeerd als er meer dan één webinstantie is",
            "fr": "Les graphiques ont été améliorés\nCorrection de l'erreur avec les liens de saut si plus d'une instance Web",
            "it": "Le classifiche sono state migliorate\nCorretto l'errore con i collegamenti di salto se più di un'istanza web",
            "es": "Se mejoraron los gráficos\nSe corrigió el error con los enlaces de salto si había más de una instancia web",
            "pl": "Wykresy zostały ulepszone\nPoprawiono błąd z linkami do skoku, jeśli więcej niż jedna instancja sieciowa",
            "zh-cn": "图表已改进\n如果有多个 Web 实例,则更正了跳转链接的错误"
          "5.1.24": {
            "en": "Corrected some errors reported via sentry and the github issues",
            "de": "Einige Fehler, die über Wache und die Github-Probleme gemeldet wurden, korrigiert",
            "ru": "Исправлены некоторые ошибки, о которых сообщалось через часовую, и проблемы с github.",
            "pt": "Corrigidos alguns erros relatados via sentry e os problemas do github",
            "nl": "Enkele fouten gecorrigeerd die zijn gemeld via sentry en de github-problemen",
            "fr": "Correction de certaines erreurs signalées via sentinelle et des problèmes de github",
            "it": "Corretti alcuni errori segnalati tramite sentry e problemi con github",
            "es": "Se corrigieron algunos errores informados a través de sentry y los problemas de github",
            "pl": "Poprawiono niektóre błędy zgłaszane przez Sentry i problemy z githubem",
            "zh-cn": "更正了通过哨兵和 github 问题报告的一些错误"
          "5.1.23": {
            "en": "Corrected some errors reported via sentry",
            "de": "Einige Fehler behoben, die über die Wache gemeldet wurden",
            "ru": "Исправлены некоторые ошибки, о которых сообщал часовой.",
            "pt": "Corrigidos alguns erros relatados via sentinela",
            "nl": "Enkele fouten gecorrigeerd die zijn gemeld via schildwacht",
            "fr": "Correction de quelques erreurs signalées via sentinelle",
            "it": "Corretti alcuni errori segnalati tramite sentinella",
            "es": "Se corrigieron algunos errores informados a través de centinela.",
            "pl": "Poprawiono niektóre błędy zgłaszane przez wartownika",
            "zh-cn": "更正了通过哨兵报告的一些错误"
          "5.1.22": {
          "5.1.21": {
          "5.1.20": {
          "5.1.19": {
          "5.1.18": {
            "en": "Corrected some GUI errors: theme switching, system settings",
            "de": "Einige GUI-Fehler korrigiert: Themenwechsel, Systemeinstellungen",
            "ru": "Исправлены некоторые ошибки графического интерфейса: переключение тем, системные настройки.",
            "pt": "Corrigidos alguns erros de GUI: mudança de tema, configurações do sistema",
            "nl": "Enkele GUI-fouten gecorrigeerd: themawisseling, systeeminstellingen",
            "fr": "Correction de quelques erreurs d'interface graphique : changement de thème, paramètres système",
            "it": "Corretti alcuni errori della GUI: cambio tema, impostazioni di sistema",
            "es": "Se corrigieron algunos errores de GUI: cambio de tema, configuración del sistema",
            "pl": "Poprawiono niektóre błędy GUI: przełączanie motywów, ustawienia systemowe",
            "zh-cn": "更正了一些 GUI 错误:主题切换、系统设置"
          "5.1.17": {
            "en": "Corrected the error on the adapter's tab",
            "de": "Fehler auf der Registerkarte des Adapters behoben",
            "ru": "Исправили ошибку на вкладке адаптера",
            "pt": "Corrigido o erro na guia do adaptador",
            "nl": "De fout op het tabblad van de adapter gecorrigeerd",
            "fr": "Correction de l'erreur sur l'onglet de l'adaptateur",
            "it": "Corretto l'errore nella scheda dell'adattatore",
            "es": "Corregido el error en la pestaña del adaptador.",
            "pl": "Poprawiono błąd na karcie adaptera",
            "zh-cn": "更正了适配器选项卡上的错误"
          "5.1.16": {
            "en": "Make the appearance of buttons configurable",
            "de": "Gestalten Sie das Aussehen von Schaltflächen konfigurierbar",
            "ru": "Сделайте внешний вид кнопок настраиваемым",
            "pt": "Faça a aparência de botões configuráveis",
            "nl": "Maak het uiterlijk van knoppen configureerbaar",
            "fr": "Rendre l'apparence des boutons paramétrable",
            "it": "Rendi configurabile l'aspetto dei pulsanti",
            "es": "Hacer que la apariencia de los botones sea configurable",
            "pl": "Spraw, aby wygląd przycisków był konfigurowalny",
            "zh-cn": "使按钮的外观可配置"
          "5.1.15": {
            "en": "Replaced the formula icon in the edit aliases dialog\nAdded the logic for checkbox in JsonConfig",
            "de": "Formelsymbol im Dialog zum Bearbeiten von Aliasen ersetzt\nLogik für Kontrollkästchen in JsonConfig hinzugefügt",
            "ru": "Заменен значок формулы в диалоговом окне редактирования псевдонимов.\nДобавлена логика для флажка в JsonConfig",
            "pt": "Substituído o ícone da fórmula na janela de edição de aliases\nAdicionada a lógica para a caixa de seleção em JsonConfig",
            "nl": "Het formulepictogram in het dialoogvenster aliassen bewerken vervangen\nDe logica toegevoegd voor het selectievakje in JsonConfig",
            "fr": "Remplacement de l'icône de formule dans la boîte de dialogue de modification des alias\nAjout de la logique pour la case à cocher dans JsonConfig",
            "it": "Sostituita l'icona della formula nella finestra di dialogo Modifica alias\nAggiunta la logica per la casella di controllo in JsonConfig",
            "es": "Reemplazó el ícono de fórmula en el cuadro de diálogo de edición de alias\nSe agregó la lógica para la casilla de verificación en JsonConfig",
            "pl": "Zamieniono ikonę formuły w oknie edycji aliasów\nDodano logikę pola wyboru w JsonConfig",
            "zh-cn": "替换了编辑别名对话框中的公式图标\n在 JsonConfig 中添加了复选框的逻辑"
          "5.1.14": {
            "en": "Corrected error with \"Intro\" page. Warning: All cards must be deactivated anew.",
            "de": "Fehler mit \"Intro\"-Seite behoben. Achtung: Alle Karten müssen neu deaktiviert werden.",
            "ru": "Исправлена ошибка со страницей \"Введение\". Предупреждение: все карты необходимо деактивировать заново.",
            "pt": "Erro corrigido com a página \"Introdução\". Aviso: Todos os cartões devem ser desativados novamente.",
            "nl": "Fout gecorrigeerd met \"Intro\"-pagina. Waarschuwing: Alle kaarten moeten opnieuw worden gedeactiveerd.",
            "fr": "Erreur corrigée avec la page \"Intro\". Attention : toutes les cartes doivent être à nouveau désactivées.",
            "it": "Corretto errore con la pagina \"Intro\". Attenzione: tutte le carte devono essere nuovamente disattivate.",
            "es": "Error corregido con la página \"Introducción\". Advertencia: Todas las tarjetas deben desactivarse nuevamente.",
            "pl": "Poprawiony błąd ze stroną „Intro”. Ostrzeżenie: Wszystkie karty muszą zostać ponownie dezaktywowane.",
            "zh-cn": "更正了“介绍”页面的错误。警告:必须重新停用所有卡。"
          "5.1.13": {
            "en": "Improved json config",
            "de": "Verbesserte Json-Konfiguration",
            "ru": "Улучшенная конфигурация json",
            "pt": "Configuração json aprimorada",
            "nl": "Verbeterde json-configuratie",
            "fr": "Configuration json améliorée",
            "it": "Configurazione json migliorata",
            "es": "Configuración json mejorada",
            "pl": "Ulepszona konfiguracja json",
            "zh-cn": "改进的 json 配置"
          "5.1.25": {
          "5.1.28": {
            "en": "Fixed discovery function\nFixed some GUI bugs",
            "de": "Feste Erkennungsfunktion\nEinige GUI-Fehler behoben",
            "ru": "Фиксированная функция обнаружения\nИсправлены некоторые ошибки графического интерфейса.",
            "pt": "Função de descoberta corrigida\nCorrigidos alguns bugs de GUI",
            "nl": "Vaste ontdekkingsfunctie\nEnkele GUI-bugs opgelost",
            "fr": "Fonction de découverte fixe\nCorrection de quelques bugs de l'interface graphique",
            "it": "Funzione di scoperta fissa\nRisolti alcuni bug della GUI",
            "es": "Función de descubrimiento fijo\nSe corrigieron algunos errores de GUI",
            "pl": "Naprawiono funkcję wykrywania\nNaprawiono kilka błędów GUI",
            "zh-cn": "固定发现功能\n修复了一些 GUI 错误"
          "5.1.29": {
            "en": "Fix crash cases reported via sentry\nAdded support for multi-repositories",
            "de": "Absturzfälle beheben, die über Wache gemeldet wurden\nUnterstützung für Multi-Repositorys hinzugefügt",
            "ru": "Исправить случаи сбоев, о которых сообщалось через часового\nДобавлена поддержка мульти-репозиториев.",
            "pt": "Corrigir casos de falha relatados via sentinela\nAdicionado suporte para multi-repositórios",
            "nl": "Herstel crashgevallen gemeld via schildwacht\nOndersteuning toegevoegd voor meerdere opslagplaatsen",
            "fr": "Correction des cas de plantage signalés via sentinelle\nAjout de la prise en charge des multi-dépôts",
            "it": "Risolti i casi di crash segnalati tramite sentinella\nAggiunto supporto per multi-repository",
            "es": "Solucionar casos de accidentes informados a través de centinelas\nSoporte agregado para repositorios múltiples",
            "pl": "Napraw przypadki awarii zgłoszone przez Sentry\nDodano obsługę wielu repozytoriów",
            "zh-cn": "修复通过哨兵报告的崩溃案例\n添加了对多存储库的支持"
          "5.2.1": {
            "en": "Allow in expert mode the creation of states and channels in mqtt branch",
            "de": "Erlaube im Expertenmodus die Erstellung von Zuständen und Kanälen im mqtt-Zweig",
            "ru": "Разрешить в экспертном режиме создание состояний и каналов в ветке mqtt",
            "pt": "Permitir no modo especialista a criação de estados e canais no ramal mqtt",
            "nl": "Sta in expertmodus het maken van staten en kanalen toe in mqtt branch",
            "fr": "Autoriser en mode expert la création d'états et de canaux dans la branche mqtt",
            "it": "Consenti in modalità esperto la creazione di stati e canali nel ramo mqtt",
            "es": "Permitir en modo experto la creación de estados y canales en rama mqtt",
            "pl": "Zezwalaj w trybie eksperta na tworzenie stanów i kanałów w gałęzi mqtt",
            "zh-cn": "允许在专家模式下在 mqtt 分支中创建状态和通道"
          "5.2.0": {
          "5.2.3": {
            "en": "Fixed error in `AutocompleteSendTo`\nFixed error in charts",
            "de": "Fehler in `AutocompleteSendTo` behoben\nFehler in Diagrammen behoben",
            "ru": "Исправлена ошибка в `AutocompleteSendTo`\nИсправлена ошибка в графиках",
            "pt": "Erro corrigido em `AutocompleteSendTo`\nErro corrigido em gráficos",
            "nl": "Fout opgelost in `AutocompleteSendTo`\nVaste fout in grafieken",
            "fr": "Correction d'une erreur dans 'AutocompleteSendTo'\nCorrection d'une erreur dans les graphiques",
            "it": "Risolto errore in `AutocompleteSendTo`\nRisolto errore nei grafici",
            "es": "Se corrigió el error en \"AutocompleteSendTo\"\nError fijo en gráficos.",
            "pl": "Naprawiono błąd w `AutocompleteSendTo`\nNaprawiono błąd w wykresach",
            "zh-cn": "修复了“AutocompleteSendTo”中的错误\n修复了图表中的错误"
          "5.2.2": {
            "en": "Changed the minimal required js-controller version to 3.3.22 \nUsed web-socket library 8 (no node 10 support anymore)",
            "de": "Die minimal erforderliche js-Controller-Version wurde auf 3.3.22 geändert\nVerwendete Web-Socket-Bibliothek 8 (keine Unterstützung von Node 10 mehr)",
            "ru": "Изменена минимально необходимая версия js-контроллера на 3.3.22\nИспользуемая библиотека веб-сокетов 8 (больше нет поддержки узла 10)",
            "pt": "Alterada a versão mínima necessária do js-controller para 3.3.22\nUtilizou a biblioteca de soquetes da web 8 (sem suporte a nó 10 mais)",
            "nl": "De minimaal vereiste js-controllerversie gewijzigd in 3.3.22\nGebruikte web-socket bibliotheek 8 (geen node 10 meer)",
            "fr": "Modification de la version minimale requise du contrôleur js en 3.3.22\nBibliothèque de sockets Web 8 utilisée (plus de support pour le nœud 10)",
            "it": "Modificata la versione minima richiesta del controller js in 3.3.22\nLibreria web socket usata 8 (nessun supporto per il nodo 10 più)",
            "es": "Se cambió la versión mínima requerida de js-controller a 3.3.22\nSe usó la biblioteca 8 de web-socket (ya no es compatible con el nodo 10)",
            "pl": "Zmieniono minimalną wymaganą wersję kontrolera js na 3.3.22\nUżywana biblioteka gniazd sieciowych 8 (brak obsługi węzła 10)",
            "zh-cn": "将最低要求的 js-controller 版本更改为 3.3.22\n使用了 web-socket 库 8(不再支持 node 10)"
          "5.3.0": {
            "en": "Enable http compression in webserver\nRemoved deprecated package \"request\"\nAdded JSONL option for base settings\nAdded small improvements\nAdded the file viewer for binary states",
            "de": "HTTP-Komprimierung im Webserver aktivieren\nVeraltetes Paket „request“ entfernt\nJSONL-Option für Basiseinstellungen hinzugefügt\nKleine Verbesserungen hinzugefügt\nDateibetrachter für Binärzustände hinzugefügt",
            "ru": "Включить сжатие http на веб-сервере\nУдален устаревший пакет «запрос».\nДобавлен параметр JSONL для базовых настроек.\nДобавлены небольшие улучшения\nДобавлен просмотрщик файлов для бинарных состояний",
            "pt": "Habilitar compressão http no servidor web\nRemoção do pacote obsoleto \"solicitação\"\nAdicionada opção JSONL para configurações básicas\nAdicionadas pequenas melhorias\nAdicionado o visualizador de arquivos para estados binários",
            "nl": "Schakel http-compressie in webserver in\nVerouderd pakket \"verzoek\" verwijderd\nJSONL-optie toegevoegd voor basisinstellingen\nKleine verbeteringen toegevoegd\nDe bestandsviewer voor binaire toestanden toegevoegd",
            "fr": "Activer la compression http sur le serveur Web\nSuppression du package obsolète \"request\"\nAjout de l'option JSONL pour les paramètres de base\nAjout de petites améliorations\nAjout de la visionneuse de fichiers pour les états binaires",
            "it": "Abilita la compressione http nel server web\nRimosso il pacchetto obsoleto \"richiesta\"\nAggiunta l'opzione JSONL per le impostazioni di base\nAggiunti piccoli miglioramenti\nAggiunto il visualizzatore di file per gli stati binari",
            "es": "Habilitar la compresión http en el servidor web\nSe eliminó el paquete obsoleto \"solicitud\"\nSe agregó la opción JSONL para la configuración básica\nPequeñas mejoras añadidas\nSe agregó el visor de archivos para estados binarios.",
            "pl": "Włącz kompresję http na serwerze WWW\nUsunięto przestarzały pakiet „request”\nDodano opcję JSONL dla ustawień podstawowych\nDodano drobne ulepszenia\nDodano przeglądarkę plików dla stanów binarnych",
            "zh-cn": "在网络服务器中启用 http 压缩\n删除了不推荐使用的包“请求”\n为基本设置添加了 JSONL 选项\n添加了小改进\n添加了二进制状态的文件查看器"
        "eraseOnUpload": true
      "native": {
        "port": 8081,
        "auth": false,
        "secure": false,
        "bind": "0.0.0.0",
        "cache": false,
        "accessLimit": false,
        "accessApplyRights": false,
        "accessAllowedConfigs": [],
        "accessAllowedTabs": [],
        "certPublic": "",
        "certPrivate": "",
        "certChained": "",
        "ttl": 3600,
        "defaultUser": "admin",
        "tmpPath": "/tmp",
        "tmpPathAllow": false,
        "thresholdValue": 200,
        "leEnabled": false,
        "leUpdate": false,
        "leCheckPort": 80,
        "loginBackgroundColor": "",
        "loginBackgroundImage": false,
        "loginHideLogo": false,
        "loginMotto": "",
        "react": false,
        "autoUpdate": 24,
        "material": true,
        "language": "",
        "reverseProxy": [],
        "loadingBackgroundColor": "",
        "loadingHideLogo": false,
        "loadingBackgroundImage": ""
      "protectedNative": [],
      "encryptedNative": [],
      "instanceObjects": [
          "_id": "info",
          "type": "channel",
          "common": {
            "name": {
              "en": "Information",
              "de": "Information",
              "ru": "Информация",
              "pt": "Em formação",
              "nl": "Informatie",
              "fr": "Information",
              "it": "Informazione",
              "es": "Información",
              "pl": "Informacja",
              "zh-cn": "信息"
          "native": {}
          "_id": "",
          "type": "meta",
          "common": {
            "name": {
              "en": "user files and images for background",
              "de": "Benutzerdateien und Bilder für den Hintergrund",
              "ru": "пользовательские файлы и изображения для фона",
              "pt": "arquivos e imagens do usuário para plano de fundo",
              "nl": "gebruikersbestanden en afbeeldingen voor achtergrond",
              "fr": "fichiers utilisateur et images pour l'arrière-plan",
              "it": "file utente e immagini per lo sfondo",
              "es": "archivos de usuario e imágenes para el fondo",
              "pl": "pliki użytkownika i obrazy w tle",
              "zh-cn": "背景的用户文件和图像"
            "type": "meta.user"
          "native": {}
          "_id": "info.connected",
          "type": "state",
          "common": {
            "role": "state",
            "name": {
              "en": "Info about connected socket clients",
              "de": "Informationen über verbundene Socket-Clients",
              "ru": "Информация о подключенных клиентах сокетов",
              "pt": "Informações sobre clientes de soquete conectados",
              "nl": "Info over aangesloten socket-clients",
              "fr": "Informations sur les clients socket connectés",
              "it": "Informazioni sui client socket connessi",
              "es": "Información sobre clientes de socket conectados",
              "pl": "Informacje o podłączonych klientach gniazd",
              "zh-cn": "有关已连接套接字客户端的信息"
            "type": "string",
            "read": true,
            "write": false,
            "def": ""
          "native": {}
          "_id": "info.connection",
          "type": "state",
          "common": {
            "role": "indicator.connected",
            "name": {
              "en": "HTTP server started",
              "de": "HTTP-Server gestartet",
              "ru": "HTTP-сервер запущен",
              "pt": "Servidor HTTP iniciado",
              "nl": "HTTP-server gestart",
              "fr": "Serveur HTTP démarré",
              "it": "Server HTTP avviato",
              "es": "Servidor HTTP iniciado",
              "pl": "Uruchomiono serwer HTTP",
              "zh-cn": "HTTP 服务器已启动"
            "type": "boolean",
            "read": true,
            "write": false,
            "def": false
          "native": {}
          "_id": "info.newsFeed",
          "type": "state",
          "common": {
            "name": {
              "en": "Last news feed as JSON",
              "de": "Letzter Newsfeed als JSON",
              "ru": "Лента последних новостей в формате JSON",
              "pt": "Último feed de notícias como JSON",
              "nl": "Laatste nieuwsfeed als JSON",
              "fr": "Dernier fil d'actualité au format JSON",
              "it": "Ultimo feed di notizie come JSON",
              "es": "Últimas noticias como JSON",
              "pl": "Ostatni kanał wiadomości jako JSON",
              "zh-cn": "最后一个新闻提要为 JSON"
            "type": "json",
            "read": true,
            "write": false
          "_id": "info.newsETag",
          "type": "state",
          "common": {
            "name": {
              "en": "Etag for news feed",
              "de": "Etag für Newsfeed",
              "ru": "Etag для новостной ленты",
              "pt": "Etag para feed de notícias",
              "nl": "Etag voor nieuwsfeed",
              "fr": "Etag pour le fil d'actualité",
              "it": "Etag per il feed di notizie",
              "es": "Etag para noticias",
              "pl": "Etag dla kanału informacyjnego",
              "zh-cn": "用于新闻提要的 Etag"
            "type": "string",
            "read": true,
            "write": false
          "_id": "info.newsLastId",
          "type": "state",
          "common": {
            "name": {
              "en": "Last news ID",
              "de": "Letzte Nachrichten-ID",
              "ru": "Идентификатор последней новости",
              "pt": "ID da última notícia",
              "nl": "Laatste nieuws-ID",
              "fr": "Identifiant des dernières nouvelles",
              "it": "Ultime notizie ID",
              "es": "ID de última noticia",
              "pl": "Identyfikator ostatnich wiadomości",
              "zh-cn": "最新消息 ID"
            "type": "string",
            "read": true,
            "write": false
          "_id": "info.updatesList",
          "type": "state",
          "common": {
            "role": "indicator.updates",
            "name": {
              "en": "List of adapters to update",
              "de": "Liste der zu aktualisierenden Adapter",
              "ru": "Список адаптеров для обновления",
              "pt": "Lista de adaptadores para atualizar",
              "nl": "Lijst met adapters die moeten worden bijgewerkt",
              "fr": "Liste des adaptateurs à mettre à jour",
              "it": "Elenco degli adattatori da aggiornare",
              "es": "Lista de adaptadores para actualizar",
              "pl": "Lista adapterów do aktualizacji",
              "zh-cn": "要更新的适配器列表"
            "type": "string",
            "read": true,
            "write": false,
            "def": ""
          "native": {}
      "objects": [],
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
      "notifications": [],
      "from": "system.host.shsrv02.kilroy.local.cli",
      "user": "system.user.admin",
      "ts": 1663519310972
    • TheKilroyT TheKilroy
      @apollon77
        "type": "instance",
        "common": {
          "name": "admin",
          "title": "Admin",
          "desc": {
          "docs": {
            "de": [
              "docs/de/admin.md",
          "mode": "daemon",
          "loglevel": "info",
          "messagebox": true,
          "enabled": true,
          "keywords": [
            "setup",
            "config",
            "update",
            "upgrade",
            "system",
            "konfiguration",
            "administration",
            "einrichtung",
            "wartung"
          "compact": true,
          "authors": [
          "dependencies": [
          "type": "general",
          "license": "MIT",
          "nogit": true,
            "name": "Admin",
            "color": "pink",
            "order": 5,
            "localLink": true,
          "plugins": {
            "sentry": {
          "jsonConfig": true,
          "titleLang": {
            "en": "Admin",
            "de": "Admin",
            "ru": "Админ",
            "pt": "Admin",
            "pl": "Admin",
            "fr": "Admin",
            "nl": "Admin",
            "it": "Admin",
            "es": "Admin",
            "zh-cn": "Admin"
          "adminUI": {
            "config": "json"
          "localLinks": {
            "_default": {
              "pro": true
          "news": {
            "5.0.19": {
            "5.0.18": {
            "5.0.17": {
            "5.0.16": {
            "5.0.15": {
              "zh-cn": "优化了加载过程"
            "5.0.14": {
            "5.0.13": {
            "5.0.12": {
            "5.0.11": {
            "5.0.10": {
            "5.0.9": {
            "5.0.8": {
            "5.0.7": {
            "5.0.6": {
            "5.0.5": {
            "5.0.4": {
            "5.0.3": {
            "5.0.2": {
            "5.0.0": {
            "4.1.1": {
            "5.0.20": {
            "5.0.21": {
            "5.0.22": {
            "5.0.24": {
            "5.0.23": {
            "5.0.27": {
            "5.0.26": {
            "5.0.25": {
            "5.0.28": {
            "5.0.29": {
            "5.0.30": {
            "5.0.31": {
            "5.1.0": {
            "5.0.32": {
            "5.1.2": {
            "5.1.1": {
            "5.1.3": {
            "5.1.4": {
            "5.1.5": {
              "zh-cn": "修复枚举的编辑"
            "5.1.6": {
              "zh-cn": "改进了自定义设置"
            "5.1.7": {
            "5.1.9": {
            "5.1.8": {
            "5.1.10": {
            "5.1.11": {
            "5.1.12": {
            "5.1.24": {
            "5.1.23": {
            "5.1.22": {
            "5.1.21": {
            "5.1.20": {
            "5.1.19": {
            "5.1.18": {
            "5.1.17": {
            "5.1.16": {
            "5.1.15": {
            "5.1.14": {
            "5.1.13": {
            "5.1.25": {
            "5.1.28": {
            "5.1.29": {
            "5.2.1": {
            "5.2.0": {
            "5.2.3": {
            "5.2.2": {
            "5.3.0": {
        "native": {
          "port": 8081,
          "auth": false,
          "secure": false,
          "bind": "0.0.0.0",
          "cache": false,
          "certPublic": "",
          "certPrivate": "",
          "certChained": "",
          "ttl": 3600,
          "tmpPath": "/tmp",
          "leEnabled": false,
          "leUpdate": false,
          "leCheckPort": 80,
          "loginMotto": "",
          "react": false,
          "autoUpdate": 24,
          "material": true,
          "language": "",
          "reverseProxy": [],
            "_id": "info",
            "type": "channel",
            "common": {
              "name": {
                "ru": "Информация",
                "nl": "Informatie",
                "pl": "Informacja",
                "zh-cn": "信息"
            "native": {}
            "_id": "",
            "type": "meta",
            "common": {
              "name": {
              "type": "meta.user"
            "native": {}
            "type": "state",
            "common": {
              "role": "state",
              "name": {
              "type": "string",
              "read": true,
              "write": false,
              "def": ""
            "native": {}
            "type": "state",
            "common": {
              "name": {
              "type": "boolean",
              "read": true,
              "write": false,
              "def": false
            "native": {}
            "type": "state",
            "common": {
              "name": {
              "type": "json",
              "read": true,
              "write": false
            "type": "state",
            "common": {
              "name": {
              "type": "string",
              "read": true,
              "write": false
            "type": "state",
            "common": {
              "name": {
                "zh-cn": "最新消息 ID"
              "type": "string",
              "read": true,
              "write": false
            "type": "state",
            "common": {
              "name": {
              "type": "string",
              "read": true,
              "write": false,
              "def": ""
            "native": {}
        "objects": [],
        "acl": {
          "object": 1636,
        "ts": 1663519310972
      apollon77A Online
      apollon77A Online
      #232
      @thekilroy danke. Da sind 24h eingestellt. Das wars also nicht.
      Auch wenn jetzt wieder läuft bitte beobachte mal die filegrösse.
      TheKilroyT 2 Antworten Letzte Antwort
        TheKilroyT Offline
        TheKilroyT Offline
        TheKilroy
        #233
        @apollon77 Werde ich tun und heute Abend berichten.
          TheKilroyT Offline
          TheKilroyT Offline
          TheKilroy
          #234
          @apollon77 Bis jetzt hat sich die Größe "objects.jsonl" nicht verändert.
          Noch als kleine Anmerkung. Der aktive Server ist ein Master-Slave-System bestehend aus einem RPI4 (wie Test-Server) und einem RPI3B. Beide Updates/Upgrades waren hier problemlos und laufen einwandfrei.
          Hier auf dem Test-Server teste ich neue Komponenten wir z.B. eigene Tasmota-Controller oder auch Skripte oder Charts bevor ich diese auf dem aktiven Server einsetze. Es kann also durchaus sein, dass sich Überreste von altem Kram darauf befinden.
            @Rene-3 Vllt auch eine option AlCalzone mal dein File zu schicken? Oder hast Du inzwischen neu aufgesetzt?
            Rene 3
            #235
            @apollon77
            ich versuche es noch mal aufzutreiben - habe das File umbenannt
            THX
              apollon77A Online
              apollon77A Online
              #236
              @thekilroy hat dein Production System auch solche Aufblähungen Oder da alles ok?
              • TheKilroyT Offline
                TheKilroyT Offline
                TheKilroy
                #237
                @apollon77 Production System sieht alles gut aus.
                Auf dem Test-Server habe ich eben, nachdem ich obigen Post verfasst habe, ein "iob update" und ein "iob upgrade -y" durchgeführt. Dazu noch den "javascript" Adapter installiert. Hier jetzt das aktuelle Listing des "iobroker-data" Verzeichnisses auf dem Test-Server mit laufendem "iobroker".
                pi@shsrv02:/opt/iobroker $ ll -h iobroker-data/
                insgesamt 1,4G
                4,0K drwxrwxr-x+ 12 iobroker iobroker 4,0K Sep 20 21:49 .
                4,0K drwxrwxr-x+  8 iobroker iobroker 4,0K Sep 19 17:31 ..
                4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Sep 20 21:59 backup-objects
                4,0K drwxrwxr-x+ 35 iobroker iobroker 4,0K Sep 20 19:19 files
                8,0K -rw-rwxr--+  1 iobroker iobroker 4,7K Sep 19 20:28 iobroker.json
                4,0K drwxrwxr-x+  3 iobroker iobroker 4,0K Jul 16  2021 jarvis
                4,0K drwxrwxr-x+  5 iobroker iobroker 4,0K Sep 20 19:29 node-red
                4,0K -rw-rwxr--+  1 iobroker iobroker    3 Sep 18 18:44 notifications.json
                5,5M -rw-rwxr--+  1 iobroker iobroker 5,5M Feb 13  2022 objects.json.bak.migrated
                 26M -rw-r--r--+  1 iobroker iobroker  26M Sep 20 19:50 objects.jsonl
                1,4G -rw-rwxr--+  1 iobroker iobroker 1,4G Sep 19 20:39 objects.jsonl.huge
                4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Sep 20 23:24 objects.jsonl.lock
                5,5M -rw-rwxr--+  1 iobroker iobroker 5,5M Feb 13  2022 objects.json.migrated
                4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Dez  5  2020 sqlite
                436K -rw-rwxr--+  1 iobroker iobroker 435K Feb 13  2022 states.json.bak.migrated
                   0 -rw-rwxr--+  1 iobroker iobroker    0 Dez 22  2021 states.json.broken
                5,3M -rw-rw-r--+  1 iobroker iobroker 5,3M Sep 20 23:23 states.jsonl
                4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Sep 20 23:24 states.jsonl.lock
                436K -rw-rwxr--+  1 iobroker iobroker 435K Feb 13  2022 states.json.migrated
                4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Mai 10 18:11 yahka.0.hapdata
                4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Mai 10 18:15 yahka.1.hapdata
                 12K drwxrwxr-x+  2 iobroker iobroker  12K Sep 20 23:01 zigbee_0
                Die Datei ist zwar jetzt 28 MB groß, liegt aber wohl an dem zusätzlichen "javascript" Adapter.
                  insgesamt 1,4G
                  apollon77A Online
                  apollon77A Online
                  #238
                  @thekilroy ja das ist alles ok.
                  TheKilroyT 1 Antwort Letzte Antwort
                    TheKilroyT Offline
                    TheKilroyT Offline
                    TheKilroy
                    #239
                    @apollon77 hier das aktuelle Listing von heute Abend.
                    insgesamt 1,4G
                    4,0K drwxrwxr-x+ 12 iobroker iobroker 4,0K Sep 21 15:38 .
                    4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Sep 21 17:31 backup-objects
                    4,0K -rw-rwxr--+  1 iobroker iobroker    3 Sep 20 23:29 notifications.json
                     34M -rw-r--r--+  1 iobroker iobroker  34M Sep 21 18:11 objects.jsonl
                    4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Sep 21 18:21 objects.jsonl.lock
                    8,5M -rw-rw-r--+  1 iobroker iobroker 8,5M Sep 21 18:21 states.jsonl
                    4,0K drwxrwxr-x+  2 iobroker iobroker 4,0K Sep 21 18:21 states.jsonl.lock
                     12K drwxrwxr-x+  2 iobroker iobroker  12K Sep 21 17:31 zigbee_0
                    Die Datei ist im 8MB auf 34MB gewachsen.
                      insgesamt 1,4G
                      apollon77A Online
                      apollon77A Online
                      #240
                      @thekilroy alles locker im Rahmen
                        TheKilroyT Offline
                        TheKilroyT Offline
                        TheKilroy
                        #241
                        @apollon77 Sehr gut. Ich werde das aber weiter beobachten und falls es sich stark ändert, melde ich das hier.
                        Danke erst einmal für die tolle Hilfe. Leider ist aber die Ursache noch nicht gefunden.
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #242
                          @thekilroy sagte in Server Cannot start inMem-objects on port 9001:
                          Doch ich denke schon. Jedes Aktualisieren der Adapter schreibt das repositories-Objekt (7 MB). Du hast weniger Objekte als die Untergrenze fürs automatische komprimieren, d.h. es wird nie komprimiert.
                          Mit diesem PR passiert das dann wenigstens täglich:
                          https://github.com/ioBroker/ioBroker.js-controller/pull/2004
                          C 1 Antwort Letzte Antwort
                          • U Offline
                            U Offline
                            ujoerk
                            #243
                            Guten Morgen zusammen…
                            So seit gestern hats mich nun auch erwischt mit dem Fehler… Dann werd ich mich mal durch den schon ziemlich langen Thread hier graben…
                            • C Offline
                              casifa29
                              #244
                              Hi, könntest du mir kurz erklären wie man den PR bei sich konfiguriert? Danke und Grüße
                              • AlCalzoneA AlCalzone
                                casifa29
                                #245
                                @alcalzone Hi, könntest du mir kurz erklären wie man den PR bei sich konfiguriert? Danke und Grüße
                                • apollon77A Online
                                  apollon77A Online
                                  #246
                                  Ok,
                                  • ioBroker beenden
                                  • Datei /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/lib/objects/objectsInMemJsonlDB.js editieren und am Ende VOR Zeile 39 eine neue Zeile einfügen mit
                                              intervalMs: 1000 * 60 * 60 * 24,
                                  Dann ioBroker neu starten.
                                  Ingo
                                    Stadtschloss
                                    #247
                                    Bei mir der gleiche Fehler...
                                    @ioBroker:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js --logs
                                    2022-10-16 00:31:53.746  - info: host.ioBroker iobroker.js-controller version 4.0.23 js-controller starting
                                    2022-10-16 00:31:53.756  - info: host.ioBroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2022-10-16 00:31:53.759  - info: host.ioBroker hostname: ioBroker, node: v16.17.0
                                    2022-10-16 00:31:53.760  - info: host.ioBroker ip addresses: 192.168.178.178 fe80::b011:c7ff:fef6:2549
                                    2022-10-16 00:31:55.886  - error: host.ioBroker-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                                    @ioBroker:/opt/iobroker# sudo ss -tulpn | grep LISTEN
                                    tcp   LISTEN 0      4096           0.0.0.0:111        0.0.0.0:*    users:(("rpcbind",pid=137,fd=4),("systemd",pid=1,fd=28))
                                    tcp   LISTEN 0      511            0.0.0.0:8400       0.0.0.0:*    users:(("io.jarvis.0",pid=1545,fd=27))
                                    tcp   LISTEN 0      511    192.168.178.178:8081       0.0.0.0:*    users:(("io.admin.0",pid=369,fd=27))
                                    tcp   LISTEN 0      100          127.0.0.1:25         0.0.0.0:*    users:(("master",pid=353,fd=13))
                                    tcp   LISTEN 0      511            0.0.0.0:1883       0.0.0.0:*    users:(("io.sonoff.0",pid=1184,fd=26))
                                    tcp   LISTEN 0      511    192.168.178.178:9093       0.0.0.0:*    users:(("io.fakeroku.0",pid=1427,fd=27))
                                    tcp   LISTEN 0      511          127.0.0.1:9000       0.0.0.0:*    users:(("iobroker.js-con",pid=173,fd=26))
                                    tcp   LISTEN 0      511          127.0.0.1:9001       0.0.0.0:*    users:(("iobroker.js-con",pid=173,fd=20))
                                    tcp   LISTEN 0      4096              [::]:111           [::]:*    users:(("rpcbind",pid=137,fd=6),("systemd",pid=1,fd=30))
                                    tcp   LISTEN 0      4096                 *:22               *:*    users:(("systemd",pid=1,fd=49))
                                    tcp   LISTEN 0      100              [::1]:25            [::]:*    users:(("master",pid=353,fd=14))
                                    tcp   LISTEN 0      511                  *:8091             *:*    users:(("io.lovelace.0",pid=1637,fd=26))
                                    tcp   LISTEN 0      511                  *:7999             *:*    users:(("io.geofency.0",pid=847,fd=26))
                                    tcp   LISTEN 0      511                  *:61991            *:*    users:(("io.harmony.0",pid=1485,fd=26))
                                    npm -v
                                    8.15.0
                                    nodejs -v
                                    v16.17.0
                                    iob -v
                                    4.0.23
                                    Was kann ich hier tun :/?
                                    • S Stadtschloss
                                      npm -v
                                      8.15.0
                                      nodejs -v
                                      v16.17.0
                                      iob -v
                                      4.0.23
                                      #248
                                      @stadtschloss sagte in Server Cannot start inMem-objects on port 9001:
                                      Nicht als root rumeimern wäre schon ein Anfang.
                                      Timeouts hochgesetzt?
                                        Stadtschloss
                                        schrieb am zuletzt editiert von Stadtschloss
                                        #249
                                        Habe ein Backup erstellt unter proxmox und eine neue Maschine mit dem aktuellen Stand eingespielt. Sollte durch root benutzen etwas kaputt gehen, besteht ein Backup. Bin quasi das erste mal mit root auf dem Rechner.
                                        Was meinst du mit timeouts? Ich habe soweit ich weis nirgends etwas angepasst. Wo kann ich das prüfen?
                                        Meinst du "connectTimeout": 1500000," in der iobroker.json?
                                        Danke!
                                        • S Stadtschloss
                                          Danke!
                                          #250
                                          @stadtschloss
                                          Als erstes legt man einen user an. Siehe Installationsanleitung.
