  4. Test Netatmo 2.0.0 Alpha (GitHub)
100 Beiträge 19 Kommentatoren 17.1k Aufrufe 18 Beobachtet
  • S Schimi
    @apollon77 sagte in Test Netatmo 2.0.0 Alpha (GitHub):
    @schimi Das ist ebenso in der 2.0.1 auf GitHub gefixt
    habe mit der aktuellen GitHub-Version (vor 2min installiert) folgenden Fehler:
    netatmo.0
    2022-09-12 19:42:36.408	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    netatmo.0
    2022-09-12 19:42:36.407	debug	Plugin sentry destroyed
    netatmo.0
    2022-09-12 19:42:36.392	error	adapter disabled
    netatmo.0
    2022-09-12 19:42:36.153	debug	Plugin sentry Initialize Plugin (enabled=true)
    netatmo.0
    2022-09-12 19:42:03.511	error	DB closed
    netatmo.0
    2022-09-12 19:42:03.510	error	Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40) at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
    netatmo.0
    2022-09-12 19:42:03.210	error	unhandled promise rejection: DB closed
    netatmo.0
    2022-09-12 19:42:03.209	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    netatmo.0
    2022-09-12 19:42:03.207	warn	get state error: Connection is closed.
    netatmo.0
    2022-09-12 19:42:03.191	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.TemperatureMaxDate ...
    netatmo.0
    2022-09-12 19:42:03.167	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.TemperatureMax ...
    netatmo.0
    2022-09-12 19:42:03.088	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.TemperatureMinDate ...
    netatmo.0
    2022-09-12 19:42:03.026	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.TemperatureMin ...
    netatmo.0
    2022-09-12 19:42:03.018	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.TemperatureAbsoluteMaxDate ...
    netatmo.0
    2022-09-12 19:42:03.009	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.TemperatureAbsoluteMinDate ...
    netatmo.0
    2022-09-12 19:42:03.001	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.TemperatureAbsoluteMax ...
    netatmo.0
    2022-09-12 19:42:02.958	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.TemperatureAbsoluteMin ...
    netatmo.0
    2022-09-12 19:42:02.931	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature.Temperature ...
    netatmo.0
    2022-09-12 19:42:02.918	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42.Temperature ...
    netatmo.0
    2022-09-12 19:42:02.907	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.02-00-00-13-6e-42 ...
    netatmo.0
    2022-09-12 19:42:02.848	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.LastUpdate ...
    netatmo.0
    2022-09-12 19:42:02.802	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.WifiStatus ...
    netatmo.0
    2022-09-12 19:42:02.695	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    netatmo.0
    2022-09-12 19:42:02.695	debug	Plugin sentry destroyed
    netatmo.0
    2022-09-12 19:42:02.693	info	terminating
    netatmo.0
    2022-09-12 19:42:02.692	info	cleaned everything up...
    netatmo.0
    2022-09-12 19:42:02.689	info	Websocket disconnected for events: io client disconnect
    netatmo.0
    2022-09-12 19:42:02.684	info	Doorbell: Unregistering realtime events
    netatmo.0
    2022-09-12 19:42:02.664	error	e is not defined
    netatmo.0
    2022-09-12 19:42:02.663	error	ReferenceError: e is not defined at handleDoorbell (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoDoorBell.js:502:24) at handleHome (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoDoorBell.js:330:21) at /opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoDoorBell.js:78:29
    netatmo.0
    2022-09-12 19:42:02.656	error	unhandled promise rejection: e is not defined
    netatmo.0
    2022-09-12 19:42:02.655	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    netatmo.0
    2022-09-12 19:42:02.642	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Humidity.AbsoluteHumidity ...
    netatmo.0
    2022-09-12 19:42:02.633	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.missed_call.LastEvent ...
    netatmo.0
    2022-09-12 19:42:02.623	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.DewPoint ...
    netatmo.0
    2022-09-12 19:42:02.621	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Pressure.PressureTrend {"val":"down","ack":true,"ts":1663004522616,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662988804302}
    netatmo.0
    2022-09-12 19:42:02.608	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.missed_call.LastEventId ...
    netatmo.0
    2022-09-12 19:42:02.589	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Pressure.PressureTrend ...
    netatmo.0
    2022-09-12 19:42:02.588	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.missed_call ...
    netatmo.0
    2022-09-12 19:42:02.586	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Pressure.AbsolutePressure {"val":1003,"ack":true,"ts":1663004522576,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1663004522576}
    netatmo.0
    2022-09-12 19:42:02.528	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.incoming_call.LastEvent ...
    netatmo.0
    2022-09-12 19:42:02.511	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Pressure.AbsolutePressure ...
    netatmo.0
    2022-09-12 19:42:02.510	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.incoming_call.LastEventId ...
    netatmo.0
    2022-09-12 19:42:02.508	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Pressure.Pressure {"val":1007.5,"ack":true,"ts":1663004522503,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1663004522503}
    netatmo.0
    2022-09-12 19:42:02.449	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.incoming_call ...
    netatmo.0
    2022-09-12 19:42:02.445	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.room {"val":"Draußen","ack":true,"ts":1663004522439,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662900017537}
    netatmo.0
    2022-09-12 19:42:02.440	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Pressure.Pressure ...
    netatmo.0
    2022-09-12 19:42:02.380	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Pressure ...
    netatmo.0
    2022-09-12 19:42:02.378	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Noise.Noise {"val":55,"ack":true,"ts":1663004522372,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1663004522372}
    netatmo.0
    2022-09-12 19:42:02.369	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.room ...
    netatmo.0
    2022-09-12 19:42:02.367	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.alim_status {"val":"correct power adapter","ack":true,"ts":1663004522363,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662900017507}
    netatmo.0
    2022-09-12 19:42:02.306	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Noise.Noise ...
    netatmo.0
    2022-09-12 19:42:02.295	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.alim_status ...
    netatmo.0
    2022-09-12 19:42:02.291	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.sd_status {"val":"Working SD Card","ack":true,"ts":1663004522286,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662900017482}
    netatmo.0
    2022-09-12 19:42:02.285	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Noise ...
    netatmo.0
    2022-09-12 19:42:02.283	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Humidity.Humidity {"val":67,"ack":true,"ts":1663004522277,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1663004522277}
    netatmo.0
    2022-09-12 19:42:02.261	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.sd_status ...
    netatmo.0
    2022-09-12 19:42:02.256	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.name {"val":"Klingel","ack":true,"ts":1663004522251,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662902500856}
    netatmo.0
    2022-09-12 19:42:02.252	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Humidity.Humidity ...
    netatmo.0
    2022-09-12 19:42:02.198	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Humidity ...
    netatmo.0
    2022-09-12 19:42:02.196	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.CO2.Calibrating {"val":false,"ack":true,"ts":1663004522188,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662900017078}
    netatmo.0
    2022-09-12 19:42:02.187	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.name ...
    netatmo.0
    2022-09-12 19:42:02.185	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.setup_date {"val":"Sat Nov 06 2021 12:14:33 GMT+0100 (Mitteleuropäische Normalzeit)","ack":true,"ts":1663004522179,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662900017428}
    netatmo.0
    2022-09-12 19:42:02.106	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.CO2.Calibrating ...
    netatmo.0
    2022-09-12 19:42:02.104	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.setup_date ...
    netatmo.0
    2022-09-12 19:42:02.102	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.CO2.CO2 {"val":907,"ack":true,"ts":1663004522093,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1663004522093}
    netatmo.0
    2022-09-12 19:42:02.098	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.id {"val":"70:ee:50:6e:bb:74","ack":true,"ts":1663004522093,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662900017399}
    netatmo.0
    2022-09-12 19:42:02.035	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.CO2.CO2 ...
    netatmo.0
    2022-09-12 19:42:02.025	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74.info.id ...
    netatmo.0
    2022-09-12 19:42:02.019	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.CO2 ...
    netatmo.0
    2022-09-12 19:42:02.017	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureTrend {"val":"stable","ack":true,"ts":1663004522012,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1663002905015}
    netatmo.0
    2022-09-12 19:42:02.000	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74 ...
    netatmo.0
    2022-09-12 19:42:01.987	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureTrend ...
    netatmo.0
    2022-09-12 19:42:01.984	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureMaxDate {"val":"Mon Sep 12 2022 18:43:36 GMT+0200 (Mitteleuropäische Sommerzeit)","ack":true,"ts":1663004521979,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1663001404365}
    netatmo.0
    2022-09-12 19:42:01.980	debug	Initially Check/Extend object 5eea11c3c20743509886b280.LastEventData.LastEvent ...
    netatmo.0
    2022-09-12 19:42:01.893	debug	Initially Check/Extend object 5eea11c3c20743509886b280.LastEventData.LastEventDeviceId ...
    netatmo.0
    2022-09-12 19:42:01.886	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureMaxDate ...
    netatmo.0
    2022-09-12 19:42:01.883	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureMax {"val":24.1,"ack":true,"ts":1663004521878,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1663001404354}
    netatmo.0
    2022-09-12 19:42:01.872	debug	Initially Check/Extend object 5eea11c3c20743509886b280.LastEventData.LastEventType ...
    netatmo.0
    2022-09-12 19:42:01.853	debug	Initially Check/Extend object 5eea11c3c20743509886b280.LastEventData.LastEventId ...
    netatmo.0
    2022-09-12 19:42:01.851	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureMax ...
    netatmo.0
    2022-09-12 19:42:01.844	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureMinDate {"val":"Mon Sep 12 2022 06:54:24 GMT+0200 (Mitteleuropäische Sommerzeit)","ack":true,"ts":1663004521839,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662958504072}
    netatmo.0
    2022-09-12 19:42:01.789	debug	Initially Check/Extend object 5eea11c3c20743509886b280.LastEventData.LastPushType ...
    netatmo.0
    2022-09-12 19:42:01.755	debug	Initially Check/Extend object 5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureMinDate ...
    netatmo.0
    2022-09-12 19:42:01.749	debug	Initially Check/Extend object 5eea11c3c20743509886b280.LastEventData ...
    netatmo.0
    2022-09-12 19:42:01.736	debug	stateChange netatmo.0.5eea11c3c20743509886b280.70-ee-50-13-66-18.Temperature.TemperatureMin {"val":23.1,"ack":true,"ts":1663004521722,"q":0,"from":"system.adapter.netatmo.0","user":"system.user.admin","lc":1662958504061}
    netatmo.0
    2022-09-12 19:42:01.717	debug	Update object 5eea11c3c20743509886b280 ...{"type":"folder","common":{"name":"Wallonischer Ring"},"native":{"type":"NAMain","id":"70:ee:50:13:66:18"},"from":"system.adapter.netatmo.0","user":"system.user.admin","ts":1663004521519} => {"type":"folder","common":{"name":"Wallonischer Ring"},"native":{"id":"5eea11c3c20743509886b280"}}
    @schimi Fix auf GitHub
    EDIT: 21:42 ... ok jetzt gefixt auf GitHub
    • apollon77A Offline
      Die aktuelle version geht jetzt als 2.0.2 ins Beta/Latest. Vielen Dank an alle Tester!
      • apollon77A apollon77
        S Online
        S Online
        schweiger2
        @apollon77
        Habe die 2.0.2 installiert und möchte mir ID und Secret von der angegebenen Netatmo-Site holen.
        Unter meinem Account ist keine App aufgeführt; nach Eingabe der App "ioBroker" und meinen Angaben zum Datenschützer erhalte ich die Meldung "Application already exists", obwohl - wie geschrieben - unter meinem Account nichts aufgeführt ist.
        Ich komme also nicht an ID und Secret.
        Folgende Warnmeldung finde ich noch im ioBroker-Log:
        netatmo.0 2022-09-13 08:26:20.149	warn	Invalid check interval "10", fallback to 10 minutes
        Danke vielmals für den hohen Arbeitsaufwand, der hier für die Allgemeinheit investiert wird.
        • S schweiger2
          @apollon77
          @schweiger2 Dann versuch doch mal ob Du eine App "ioBroker 2" anlegen kannst? :-) AN der stelle kann ich wenig helfen
            S Online
            S Online
            schweiger2
            @apollon77
            och menno - so einfach, dass man selbst drauf kommen müsste.
            Ich habe nicht gedacht, dass der App-Name generell nur einmal vergaben werden darf.
            Danke auf jeden Fall.
              Aktuelle Test Version 2.0.0
              Veröffentlichungsdatum 07.09.2022
              Github Link https://github.com/PArns/ioBroker.netatmo
              aufgrund von nötigen Anpassungen bei Netatmo (Abschaltung der bisherigen Authentication Logik die der Adapter genutzt hat, siehe unten) habe ich mich mal umfangreich dem Netatmo Adapter angenommen. Aus gegebenem Anlass und weiterer Überlegungen ist das Update sehr groß geworden. Daher brauche ich Eure Unterstützung beim Testing.
              ACHTUNG Admin Version vor Test prüfen!
              Diese Version des Adapters benötigt Admin 6.2.14 oder höher! Unter dieses Kann die Konfiguration nicht erfolgen! An sich sollte Admin das prüfen, bei einem GitHub Adaptertest geht das allerdings nicht, also bitte selbst vorab sicherstellen!
              ACHTUNG Objekt-Struktur ändert sich vollständig!
              Bisher wurden die bei Netatmo vergebenen Namen für das "Heim" und die Module und Geräte für die Objekt-Struktur genutzt. Bei Namensänderungen gab es daher bisher immer neue Objekte. Keine Ahnung in wieweit die Geräte Namen haben müssen oder Eindeutigkeit geprüft wird bei Netatmo. Damit konnte es ggf zu Überschneidungen kommen was zu komischen Mischeffekten führt.
              Ich habe daher entschieden die Objektstruktur, wie eigentlich üblich, in Zukunft auf den eindeutigen IDs der Entitäten aufzubauen. Daher bitte Objekte im Vorfeld prüfen und löschen und dann Skripte oder Logiken entsprechend anpassen!
              ACHTUNG API Umstellungen ändern teilweise Daten
              Der Adapter hat bisher auch noch einige als "Deprecated" gekennzeichneten APIs genutzt, welche ich in dem Zuge mit ausgetauscht habe, wo es möglich war bzw sinnvoll zusammengefasst habe. Das bringt ggf Daten-Änderungen mit sich indem sich Werte ggf ändern. Wenn hier Probleme bestehen - oder vor allem Daten fehlen die bisher da waren und wichtig waren - bitte melden!
              ACHTUNG Authentication-Änderung bei Netatmo zu Oktober 2022
              Netatmo will im Oktober 2022 die bisher vom Adapter genutzte Authentication Variante abschalten. Der neue Adapter unterstützt das künftig nötige Verfahren (daher auch die neue Admin-version welche nötig ist). In wieweit der alte Adapter ab Oktoiber noch tut ist unklar ... daher haben wir für den Test nicht so viel Zeit :-)
              Changelog
              neben den "nervigen Änderungen die alles anders machen" oben gibts aber auch ein paar neue Features :-) Hier der Changelog:
              • BREAKING: Object structure changes completely and now uses unique IDs instead of names!
              • (Apollon77) Change the Authentication method as requested by Netatmo till October 2022
              • (Apollon77) Doorbell integration
              • (Apollon77) Converted to new APIs, values of several objects might be different
              • (Apollon77) Fix crash cases reported by Sentry
              • (Apollon77) Adjust setAway to the current API
              • (Apollon77) Added setHome function (Welcome only) to mark all or specific persons as home (requires your own API key!)
              • (Apollon77) setAway and setHome now also return the result of the call as callback tzo the message
              • (Apollon77) Allow to edit floodlight and monitoring-state
              Was ist zu testen
              Das geht ganz kurz: ALLES :-)
              Da ich kein einziges Netatmo-Gerät habe und bisher nur mit einigen Geräten mit Accounts testen konnte zu denen mir netterweise Zugangsdaten zur Verfügung gestellt wurden (Vielen Dank dafür!) ist bestimmt einiges noch ungetestet und die Änderungen waren sehr umfangreich ...
              Wenn Probleme bestehen, es Crahes gibt, Daten fehlen bitte GuitHub Issues anlegen und Debug Logs anhängen oder mir mit Angabe des GitHub issues per E-Mail an iobroker@fischer-ka.de senden!
              Happy Testing!
              Ingo
              Dr. BakteriusD Online
              Dr. Bakterius
              @apollon77 Ich habe seit gestern v2.0.1 laufen. Die Authentifizierung hat ja schon bei meinen Test im August funktioniert. Diese Version läuft bei mir mit der Wetterstation plus zwei Innenmodule auch ohne Probleme.
              Jetzt galt es eben auch die Aliase und einige Skripte anzupassen. Und natürlich hatte ich ein Skript übersehen das dann entsprechende warns ausgeworfen hat. Wenn so ein Skript öfter mal läuft, bemerkt man es relativ rasch. Doch wenn es nur unter speziellen Gegebenheiten angestoßen wird und entsprechend selten ausgeführt wird, bekommt man das erst spät mit.
              Gibt es eine Möglichkeit Skripte auf fehlende Datenpunkte hin zu überprüfen? Bzw. könnte man diese Funktion in ioBroker integrieren?
                @dr-bakterius sagte in Test Netatmo 2.0.0 Alpha (GitHub):
                Ist Recht Off topic für hier ... am Ende meckert Javascript wenn Du getState auf ein nicht existierendes Skript machen willst. Auch wenn es bei Alias passiert sollte was im Log sein. Ich wüsste sonst keinen Weg es zu prüfen. Da könnte man aber ggf was schreiben als kleines JavaScript ... meld dich doch mal im Skript-Forumbereich
                  Für Netatmo kommt gerade die 2.0.3 mit noch ein paar Doorbell optimierungen und Fixes ... wenn keiner sonst mehr meckert geht die zeit nah ins Stable
                    2.0.4 mit einem Fix für Smoke-Detector events ... Denke geht aber auch bald in Stable!
                    • P Offline
                      peer69
                      Forum Testing
                      Habe gerade setHome und setAway getestet.
                      setHome funktioniert wie erwartet, setAway wirft jedoch bei gleicher Syntax folgenden Fehler:
                      netatmo.0 2022-09-19 21:32:40.702	info	API Warning: setPersonsAway error: Invalid string arg
                      Ich nutze die folgende Syntax aus den Beispielen aus dem GitHub-Repo für beide Aufrufe:
                      sendTo('netatmo.0', "setAway", {homeId: '1234567890abcdefg', personsId: ['123123123123123']});
                      apollon77A 2 Antworten Letzte Antwort
                      • P peer69
                        @peer69 Debug Log bite als GitHub issue. Danke
                        • P peer69
                          @peer69 Ok, mach mal bitte ohne das array ... ich glaube das darf nur ein String sein. Das kann nicht mehrere. Wenn DU mir das so bestätigst kann ich es umbauen das es so tut wie das andere. Ich kann es nur selbst nicht testen
                          Bitte teste mal
                          sendTo('netatmo.0', "setAway", {homeId: '1234567890abcdefg', personsId: '123123123123123'});
                          • H Offline
                            Halvar 0
                            Ich bin noch fast ganz neu bei ioBroker und in diesem Forum.
                            Der Netatmoadapter wird als „laufend“ angezeigt aber ich bekomme keine Werte. Die Authentifizierung funktioniert wohl nicht. Ich bekomme folgende Fehlermeldung:
                            Habe Version 2.0.5
                            Weiss jemand weiter?
                            Dr. BakteriusD 1 Antwort Letzte Antwort
                            • H Halvar 0
                              Habe Version 2.0.5
                              Dr. Bakterius
                              @halvar-0 sagte in Test Netatmo 2.0.0 Alpha (GitHub):
                              Schon das gemacht was in der Warnung steht?
                              H 1 Antwort Letzte Antwort
                                Halvar 0
                                @dr-bakterius said in Test Netatmo 2.0.0 Alpha (GitHub):
                                Du meinst manuel authentifizieren?
                                Das hab ich mehrfach probiert, aber es ändert nichts. Ich bekomme entweder die selbe Fehlermeldung nochmal oder es tut sich gar nichts.
                                • H Halvar 0
                                  @halvar-0 dann stell bitte mal den loglevel der Instanz auf debug (siehe meine signatur) und mache nochmal den „Login mit netatmo“ Prozess via Admin und zeige mal das log davon bitte.
                                  • F Offline
                                    Flopsi
                                    Hallo
                                    funktionieren auch die Netatmo Presence Außenkameras ?
                                    Die haben bei den letzten Versionen nie richtig funktioniert, interessant für mich sind die Erkennung von Menschen, Tieren, Fahrzeugen.
                                    Natürlich sollen man die Kameras auch über einen Datenpunkt ein und ausschalten können.
                                    Ist das schon dabei oder angedacht oder geht das nicht ?
                                    • F Flopsi
                                      Hallo
                                      @flopsi Versuch doch mal. Meines Wissens hat sich keiner beschwert bisher das es nicht geht. …
                                        Halvar 0
                                        schrieb am zuletzt editiert von Halvar 0
                                        @apollon77 said in Test Netatmo 2.0.0 Alpha (GitHub):
                                        Hallo Apollon,
                                        die Datei finde ich nicht. ioBroker läuft bei mir im Container auf ner QNAP
                                        Ich versteh das aber schon richtig? In der Instanz von netatmo Einstellungen öfffnen und Authent... klicken?
                                        Im Log finde ich das hier. Ist es das was Du meintest?
                                        2022-10-05 20:57:38.764 - info: netatmo.0 (499) Got terminate signal TERMINATE_YOURSELF
                                        2022-10-05 20:57:38.772 - info: netatmo.0 (499) cleaned everything up...
                                        2022-10-05 20:57:38.773 - info: netatmo.0 (499) terminating
                                        2022-10-05 20:57:38.775 - info: netatmo.0 (499) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2022-10-05 20:57:39.344 - info: host.iobroker instance system.adapter.netatmo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2022-10-05 20:57:41.842 - info: host.iobroker instance system.adapter.netatmo.0 started with pid 9156
                                        2022-10-05 20:57:44.596 - debug: netatmo.0 (9156) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2022-10-05 20:57:44.653 - debug: netatmo.0 (9156) Objects client ready ... initialize now
                                        2022-10-05 20:57:44.656 - debug: netatmo.0 (9156) Objects create System PubSub Client
                                        2022-10-05 20:57:44.658 - debug: netatmo.0 (9156) Objects create User PubSub Client
                                        2022-10-05 20:57:44.717 - debug: netatmo.0 (9156) Objects client initialize lua scripts
                                        2022-10-05 20:57:44.727 - debug: netatmo.0 (9156) Objects connected to redis: 127.0.0.1:9001
                                        2022-10-05 20:57:44.762 - debug: netatmo.0 (9156) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2022-10-05 20:57:44.782 - debug: netatmo.0 (9156) States create System PubSub Client
                                        2022-10-05 20:57:44.784 - debug: netatmo.0 (9156) States create User PubSub Client
                                        2022-10-05 20:57:44.809 - debug: netatmo.0 (9156) States connected to redis: 127.0.0.1:9000
                                        2022-10-05 20:57:44.896 - debug: netatmo.0 (9156) Plugin sentry Initialize Plugin (enabled=true)
                                        2022-10-05 20:57:45.297 - info: netatmo.0 (9156) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.1, js-controller: 4.0.23
                                        2022-10-05 20:57:45.339 - debug: netatmo.0 (9156) Use individual ID/Secret
                                        2022-10-05 20:57:45.351 - info: netatmo.0 (9156) Authenticating with Netatmo using individual client-ID 63277e36fa4aad82d40efabb
                                        2022-10-05 20:57:45.353 - warn: netatmo.0 (9156) API Error: Please Authenticate manually once using the Admin UI of this instance.
                                        2022-10-05 21:03:46.165 - debug: netatmo.0 (9156) Received OAuth start message: {"client_id":"63277e36fa4aad82d40efabb","client_secret":"uRnbsiu2OGJpnSPcTl3GKqLrytFOteSBZBi","redirect_uri_base":"http://192.168.178.150:8081/","scopes":{"netatmoCoach":false,"netatmoWeather":true,"netatmoWelcome":false,"netatmoSmokedetector":false,"netatmoCOSensor":false,"netatmoDoorBell":false}}
                                        2022-10-05 21:03:46.166 - debug: netatmo.0 (9156) Get OAuth start link data: {"client_id":"63277e36fa4aad82d40efabb","client_secret":"uRnbsiu2OGJpnSPcTl3GKqLrytFOteSBZBi","scopes":{"netatmoCoach":false,"netatmoWeather":true,"netatmoWelcome":false,"netatmoSmokedetector":false,"netatmoCOSensor":false,"netatmoDoorBell":false},"scope":"read_station","redirect_uri":"http://192.168.178.150:8081/oauth2_callbacks/netatmo.0/"}
                                        2022-10-05 21:03:46.167 - debug: netatmo.0 (9156) Get OAuth start link: https://api.netatmo.com/oauth2/authorize?client_id=63277e36fa4aad82d40efabb&redirect_uri=http%3A%2F%2F192.168.178.150%3A8081%2Foauth2_callbacks%2Fnetatmo.0%2F&scope=read_station&state=81pZhVdbx301XhnytWl8ni40kWAa9dauBlAFA7Yb
                                        2022-10-05 21:04:24.784 - info: web.0 (555) ==> Connected system.user.admin from ::ffff:192.168.178.62
                                        • H Halvar 0
                                          Hallo Apollon,
                                          @halvar-0 ja das meine ich. Das log sagt das du den Button geklickt hast. An sich geht dann ein neues Tab auf wo du dich bei netatmo einloggen kannst. Das log zeigt nicht das du das getan hast.
                                          Falls kein Tab aufgeht mal schauen ob ein popup Blocker vllt zu krass eingestellt ist? An sich gibts keine issues damit.
