  4. IObroker Multihost Slave startet nicht mehr
    5.8k
64 Beiträge 5 Kommentatoren 8.3k Aufrufe 3 Beobachtet
  • R RS_Tobi
    @thomas-braun sagte in IObroker Multihost Slave startet nicht mehr:
    iob start iob status systemctl status iobroker
    gibt:
    pi@FroelingSlavePi2:~ $ iob start
    pi@FroelingSlavePi2:~ $ iob status
    iobroker is not running on this host.
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    pi@FroelingSlavePi2:~ $ systemctl status iobroker
    ● iobroker.service - ioBroker Server
       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset:
       Active: activating (auto-restart) (Result: exit-code) since Mon 2022-09-19 20
         Docs: http://iobroker.net
      Process: 18344 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/i
     Main PID: 18344 (code=exited, status=1/FAILURE)
    Sep 19 20:42:58 FroelingSlavePi2 systemd[1]: iobroker.service: Failed with resul
    lines 1-8/8 (END)...skipping...
       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
       Active: activating (auto-restart) (Result: exit-code) since Mon 2022-09-19 20:42:58 CEST; 1s ago
      Process: 18344 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
    Sep 19 20:42:58 FroelingSlavePi2 systemd[1]: iobroker.service: Failed with result 'exit-code'.
    lines 1-8/8 (END)
    @rs_tobi sagte in IObroker Multihost Slave startet nicht mehr:
    gibt:
    zieh mal das putty Fenster größer.
    da fehlt rechts was
    R 1 Antwort Letzte Antwort
      gibt:
      da fehlt rechts was
      RS_Tobi
      @Homoran
      "again what learned" 😂
      anbei:
      Objects type: jsonl
      States  type: jsonl
         Active: activating (auto-restart) (Result: exit-code) since Mon 2022-09-19 20:46:48 CEST; 1s ago
        Process: 18798 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
       Main PID: 18798 (code=exited, status=1/FAILURE)
      • R RS_Tobi
        @Homoran
        anbei:
        Objects type: jsonl
        States  type: jsonl
        sudo systemctl restart iobroker
          RS_Tobi
          pi@FroelingSlavePi2:~ $ sudo systemctl restart iobroker
             Active: activating (auto-restart) (Result: exit-code) since Mon 2022-09-19 20:52:29 CEST; 2s ago
            Process: 19501 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
           Main PID: 19501 (code=exited, status=1/FAILURE)
          • R RS_Tobi
            @rs_tobi
            sudo systemctl stop iobroker.service
            ps aux | grep ^io
            • R Offline
              RS_Tobi
              Was mir noch aufgefallen ist...
              wenn ich per
              top
              schaue was da so läuft taucht ab und zu mal ein USER: iobroker auf mit den COMMAND: node
              Wenn ich bei den "funktionierenden" das mache, dann taucht da sehr oft ein USER: iobroker mit dem COMMAND: iobroker.js-con und weitere auf.
              Für mich als DAU, er läuft nicht... aber irgendwas passiert trotzdem...
                @rs_tobi
                ps aux | grep ^io
                RS_Tobi
                schrieb am zuletzt editiert von RS_Tobi
                ps aux | grep ^io
                pi@FroelingSlavePi2:~ $ sudo systemctl stop iobroker.servic
                Failed to stop iobroker.servic.service: Unit iobroker.servic.service not loaded.
                pi@FroelingSlavePi2:~ $ ps aux | grep ^io
                iobroker 20561  0.0  2.7 115032 26204 ?        Rsl  21:01   0:00 /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/controller.js
                ICh glaube, da fehlte ein "e" bei service....
                HAbe es nochmal gemacht, nun kommt bei keiner Zeile eine Antwort.
                • R RS_Tobi
                  ps aux | grep ^io
                  Da fehlt ein e.
                  Die Tab-Taste ist übrigens dein bester Freund im Terminal.
                    Da fehlt ein e.
                    RS_Tobi
                    wie eben schon ergänzt, keine Antwort auf die beiden Zeilen:
                    ps aux | grep ^io
                    p.s. das mit der TAB-Taste musst mir mal noch erklären, ich habe keine Ahnung was du damit meinst. im Putty kommt beim TAB nur ein schöner "gong"
                    • R RS_Tobi
                      ps aux | grep ^io
                      @rs_tobi
                      Dann starte jetzt das System mal sauber durch.
                      TAB-Taste: Befehle und Befehlsoptionen können u. U. per TAB-Taste von der bash vervollständigt werden. Keiner tippt solche Befehle vollständig ein.
                      Ich tippe da nur
                      sudo syst [TAB] c [TAB] stat [TAB] iob [TAB] ein und das steht dann automagisch in der Konsole:
                      sudo systemctl status iobroker.service
                        @rs_tobi
                        Ich tippe da nur
                        RS_Tobi
                        das mit der TAB hab ich echt nicht gewusst! Danke
                        Ich sag ja, leider zu wenig programmieren gelernt :-(
                        Was ist deine definition für sauber durchstarten?
                        Ich weis nicht ob wir beide das selbe meinen.
                        • R RS_Tobi
                          Ich hab auch nie programmieren gelernt.
                          iobroker stop
                          sudo reboot
                            iobroker stop
                            sudo reboot
                            RS_Tobi
                            passt...
                            zumindest mache ich das schon immer richtig.
                            Also mit Autostart kam er schonmal nicht hoch...
                               Active: active (running) since Mon 2022-09-19 21:34:34 CEST; 873ms ago
                             Main PID: 1416 (node)
                                Tasks: 7 (limit: 2059)
                               CGroup: /system.slice/iobroker.service
                                       └─1416 /usr/bin/node /opt/iobroker/node_modules/iobroker.js-controller/controller.js
                            Sep 19 21:34:34 FroelingSlavePi2 systemd[1]: Started ioBroker Server.
                            Objects type: jsonl
                            States  type: jsonl
                            • R RS_Tobi
                              passt...
                              Objects type: jsonl
                              States  type: jsonl
                              @rs_tobi
                              Der service läuft.
                              Ich würde immer noch im Multihost-Setup schauen ob da die Einstellungen passen.
                                @rs_tobi
                                Der service läuft.
                                RS_Tobi
                                ich habe es auch gelesen...
                                habe jetzt zeitlich versetzt nochmal das status abgesetzt und so sieht es aus
                                   Active: activating (auto-restart) (Result: exit-code) since Mon 2022-09-19 21:37:17 CEST; 801ms ago
                                  Process: 1781 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
                                 Main PID: 1781 (code=exited, status=1/FAILURE)
                                Sep 19 21:37:17 FroelingSlavePi2 systemd[1]: iobroker.service: Failed with result 'exit-code'.
                                   Active: activating (auto-restart) (Result: exit-code) since Mon 2022-09-19 21:39:12 CEST; 526ms ago
                                  Process: 2001 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
                                 Main PID: 2001 (code=exited, status=1/FAILURE)
                                laut diesen infos läuft da nichts (mehr)
                                Oder darf man das nicht so einfach mehrfach abfragen?
                                • R RS_Tobi
                                  @rs_tobi
                                  Irgendwas räumt dir den Service wieder ab.
                                  R 2 Antworten Letzte Antwort
                                    @rs_tobi
                                    RS_Tobi
                                    JA,
                                    Wenn ich mit den Info aus
                                    top
                                    "weiterspinne" sieht es für mich aus als wolle er starten(zumindest etwas "tun")
                                    denn CPU USAGE liegt bei dem oben angegebenen
                                    USER iobroker ......... COMMAND node immer so bei 30-40% und dann ist der Prozess wieder weg....
                                      @rs_tobi
                                      RS_Tobi
                                      Weist du was Thomas,
                                      ich habe dich nun lange genug belästigt...
                                      Ich versuche gleich ne neue SD Card zu bekommen und zieh den Slave nochmal neu hoch.
                                      Ist zwar wieder ein Abend aufwand, aber zumindest stehle ich dann keinen die Zeit.
                                      Es wäre schön gewesen, aber dann klappt es halt nicht.
                                      Ich habe hier echt ein schlechtes Gewissen dich weiter zu befragen.
                                      Danke für deine Hilfe.
                                      Grüße aus Bayern
                                      Tobi
                                      • R RS_Tobi
                                        Grüße aus Bayern
                                        Tobi
                                        @rs_tobi
                                        Setz den Service mal auf Eis:
                                        sudo systemctl disable iobroker.service
                                        Und dann mal
                                        iobroker status
                                        iobroker restart
                                          @rs_tobi
                                          Und dann mal
                                          iobroker status
                                          iobroker restart
                                          RS_Tobi
                                          pi@FroelingSlavePi2:~ $ sudo systemctl stop iobroker.service
                                          pi@FroelingSlavePi2:~ $ sudo systemctl disable iobroker.service
                                          pi@FroelingSlavePi2:~ $ iobroker status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          pi@FroelingSlavePi2:~ $ iobroker restart
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Meines Erachtens kein Unterschied
