  3. Off Topic
  4. Grafana
  5. Grafana Installation - Fehler grafana-rpi:armhf
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 5 Kommentatoren 12.2k Aufrufe 4 Beobachtet
  • H heli-wolf
    @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
    apt policy grafana*
    iobroker@iobroker:~ $ sudo apt purge grafana-rpi
    Reading package lists... Done
    The following packages were automatically installed and are no longer required:
      libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
      libpng16-16:armhf libuuid1:armhf zlib1g:armhf
    Use 'sudo apt autoremove' to remove them.
    The following packages will be REMOVED:
      grafana-rpi:armhf*
    0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
    After this operation, 258 MB disk space will be freed.
    Do you want to continue? [Y/n] y
    (Reading database ... 54954 files and directories currently installed.)
    Removing grafana-rpi:armhf (9.1.4) ...
    (Reading database ... 47955 files and directories currently installed.)
    Purging configuration files for grafana-rpi:armhf (9.1.4) ...
    dpkg: warning: while removing grafana-rpi:armhf, directory '/etc/grafana' not empty so not removed
    dpkg: warning: while removing grafana-rpi:armhf, directory '/usr/lib/systemd/system' not empty so not removed
    iobroker@iobroker:~ $ sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://packages.grafana.com/oss/deb stable InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:7 https://repos.influxdata.com/debian bullseye InRelease
    All packages are up to date.
    W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
    W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
    W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
    W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
    W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
    W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
    iobroker@iobroker:~ $ apt policy grafana*
    N: Unable to locate package grafana_9.1.4_armhf.deb
    N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
    N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
    sollten die Fehler jetzt behoben sein?
    kann ich die Installation mit
    sudo apt install grafana
    jetzt wieder starten?
    heli-wolf
    @heli-wolf
    Die mehrfach vorhandenen Einträge/Zeilen in der
    löschen.
    Wie lösche ich diese Dateien.
    Über Filezilla habe ich keine Berechtigung Dateien zu löschen.
    • H heli-wolf
      apt policy grafana*
        grafana-rpi:armhf*
      @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
      Nein, da hast du ganz schon rumgeaast...
      Da ist einiges schief.
      löschen.
      Da sollte nur
      deb [signed-by=/usr/share/keyrings/grafana.gpg] https://packages.grafana.com/oss/deb stable main
      drin stehen.
      • H heli-wolf
        @heli-wolf
        löschen.
        Nicht die Datei löschen, die doppelten Zeilen darin.
        Geht mit einem Editor, nano z. B.
        sudo nano /etc/apt/sources.list.d/grafana.list
        H 1 Antwort Letzte Antwort
          heli-wolf
          Die Grafana.list habe ich mit einem Editor angesehen und sieht folgend aus:
          deb https://packages.grafana.com/oss/deb stable main
          2 davon habe ich gelöscht.
          • H heli-wolf
            @heli-wolf
            sudo apt update
              @heli-wolf
              sudo apt update
              heli-wolf
              sudo apt update
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:6 https://packages.grafana.com/oss/deb stable InRelease
              • H heli-wolf
                sudo apt update
                @heli-wolf
                apt policy grafana*
                  @heli-wolf
                  apt policy grafana*
                  heli-wolf
                  apt policy grafana*
                  • H heli-wolf
                    apt policy grafana*
                    @heli-wolf
                    Die drei hast du mal versucht manuell zu installieren? Per dpgk oder wie?
                      @heli-wolf
                      heli-wolf
                      kann sein, ich habe vieles versucht.
                      • H heli-wolf
                        @heli-wolf
                        apt install grafana-rpi --dry-run
                          @heli-wolf
                          heli-wolf
                          iobroker@iobroker:~ $ apt install grafana-rpi --dry-run
                          NOTE: This is only a simulation!
                                apt needs root privileges for real execution.
                                Keep also in mind that locking is deactivated,
                                so don't depend on the relevance to the real current situation!
                          The following NEW packages will be installed:
                            grafana-rpi:armhf
                          0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                          Inst grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
                          Conf grafana-rpi:armhf (9.1.0 grafana stable:stable [armhf])
                          • H heli-wolf
                              grafana-rpi:armhf
                            @heli-wolf
                            .k
                            apt install grafana --dry-run
                              @heli-wolf
                              .k
                              heli-wolf
                              iobroker@iobroker:~ $ apt install grafana --dry-run
                              Use 'apt autoremove' to remove them.
                                grafana
                              Inst grafana (9.1.4 grafana stable:stable [arm64])
                              Conf grafana (9.1.4 grafana stable:stable [arm64])
                              • H heli-wolf
                                  grafana
                                sudo apt autoremove
                                  sudo apt autoremove
                                  heli-wolf
                                  sudo apt autoremove
                                  iobroker@iobroker:~ $ sudo apt install grafana
                                    grafana
                                  Need to get 0 B/76.8 MB of archives.
                                  After this operation, 271 MB of additional disk space will be used.
                                  (Reading database ... 47950 files and directories currently installed.)
                                  Preparing to unpack .../grafana_9.1.4_arm64.deb ...
                                  Unpacking grafana (9.1.4) ...
                                  Setting up grafana (9.1.4) ...
                                  ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                                   sudo /bin/systemctl daemon-reload
                                   sudo /bin/systemctl enable grafana-server
                                  ### You can start grafana-server by executing
                                   sudo /bin/systemctl start grafana-server
                                  iobroker@iobroker:~ $ sudo apt autoremove
                                  0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
                                  After this operation, 2,598 kB disk space will be freed.
                                  Removing libfontconfig1:armhf (2.13.1-4.2) ...
                                  Removing libfreetype6:armhf (2.10.4+dfsg-1+deb11u1) ...
                                  Removing libbrotli1:armhf (1.0.9-2+b2) ...
                                  Removing libexpat1:armhf (2.2.10-2+deb11u3) ...
                                  Removing libpng16-16:armhf (1.6.37-3) ...
                                  Removing libuuid1:armhf (2.36.1-8+deb11u1) ...
                                  Removing zlib1g:armhf (1:1.2.11.dfsg-2+deb11u2) ...
                                  Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
                                  • H heli-wolf
                                    sudo apt autoremove
                                      grafana
                                    systemctl status grafana-server.service
                                    sudo systemctl daemon-reload
                                    sudo systemctl enable grafana-server
                                      heli-wolf
                                      nach dem ersten Befehl
                                      kam folgendes:
                                      Warning: The unit file, source configuration file or drop-ins of grafana-server>
                                      ● grafana-server.service - Grafana instance
                                           Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
                                           Active: failed (Result: signal) since Mon 2022-09-12 19:52:17 CEST; 1h 27m>
                                             Docs: http://docs.grafana.org
                                          Process: 15830 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
                                         Main PID: 15830 (code=killed, signal=SYS)
                                              CPU: 68ms
                                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Scheduled restart >
                                      Sep 12 19:52:17 iobroker systemd[1]: Stopped Grafana instance.
                                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Start request repe>
                                      Sep 12 19:52:17 iobroker systemd[1]: grafana-server.service: Failed with result>
                                      Sep 12 19:52:17 iobroker systemd[1]: Failed to start Grafana instance.
                                      H Thomas BraunT 2 Antworten Letzte Antwort
                                      • H heli-wolf
                                        kam folgendes:
                                                CPU: 68ms
                                        heli-wolf
                                        @heli-wolf
                                        rest lief ohne Probleme:
                                        iobroker@iobroker:~ $ sudo systemctl daemon-reload
                                        [sudo] password for iobroker:
                                        iobroker@iobroker:~ $ sudo systemctl enable grafana-server
                                        Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                                        Executing: /lib/systemd/systemd-sysv-install enable grafana-server
                                        • H heli-wolf
                                          kam folgendes:
                                                  CPU: 68ms
                                          @heli-wolf
                                          Mach das Mäusekinofenster von puTTY mal breiter. Da fehlt die rechte Hälfte.
                                          Dann
