  4. Test Adapter Device-Watcher v2.x.x GitHub/Latest
1.6k Beiträge 101 Kommentatoren 757.0k Aufrufe 95 Beobachtet
  • Stephan SchleichS Stephan Schleich
    @ciddi89 Bekomme mit der 1er Version folgende Fehler, sobald ich sonoff mit anhake:
    device-watcher.0
    2022-09-06 07:44:39.129	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    device-watcher.0
    2022-09-06 07:44:39.128	info	terminating
    device-watcher.0
    2022-09-06 07:44:39.128	info	cleaned everything up...
    device-watcher.0
    2022-09-06 07:44:39.127	error	Cannot read properties of undefined (reading 'captureException')
    device-watcher.0
    2022-09-06 07:44:39.127	error	TypeError: Cannot read properties of undefined (reading 'captureException') at DeviceWatcher.errorReporting (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:1898:38) at DeviceWatcher.onReady (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:290:9)
    device-watcher.0
    2022-09-06 07:44:39.126	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
    device-watcher.0
    2022-09-06 07:44:39.126	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    device-watcher.0
    2022-09-06 07:44:39.126	warn	Error catched and sent to Sentry, error: [[onReady]] error: Cannot read properties of undefined (reading 'captureException')
    device-watcher.0
    2022-09-06 07:44:39.125	warn	Error catched and sent to Sentry, error: [[main]] error: Cannot read properties of undefined (reading 'captureException')
    device-watcher.0
    2022-09-06 07:44:39.125	warn	Error catched and sent to Sentry, error: [[main - create and fill datapoints for each adapter]] error: Cannot read properties of undefined (reading 'captureException')
    device-watcher.0
    2022-09-06 07:44:39.125	warn	Error catched and sent to Sentry, error: [[createDataForEachAdapter]] error: Cannot read properties of undefined (reading 'captureException')
    device-watcher.0
    2022-09-06 07:44:39.125	warn	Error catched and sent to Sentry, error: [[writeDatapoints]] error: Cannot read properties of undefined (reading 'localeCompare')
    device-watcher.0
    2022-09-06 07:44:38.960	info	Found items on the blacklist:
    device-watcher.0
    2022-09-06 07:44:38.960	info	Number of selected adapters: 4. Loading data from: Alexa2, Fritzdect, Sonoff, Zigbee ...
    device-watcher.0
    2022-09-06 07:44:38.952	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v16.17.0, js-controller: 4.0.23
    device-watcher.0
    2022-09-06 07:44:38.890	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    host.ioBroker
    2022-09-06 07:44:38.412	info	instance system.adapter.device-watcher.0 started with pid 2256613
    host.ioBroker
    2022-09-06 07:44:38.304	info	"system.adapter.device-watcher.0" enabled
    host.ioBroker
    2022-09-06 07:44:34.968	info	"system.adapter.device-watcher.0" disabled
    host.ioBroker
    2022-09-06 07:44:32.602	info	Restart adapter system.adapter.device-watcher.0 because enabled
    host.ioBroker
    2022-09-06 07:44:32.602	error	instance system.adapter.device-watcher.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    device-watcher.0
    2022-09-06 07:44:32.056	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    device-watcher.0
    2022-09-06 07:44:32.056	info	terminating
    Des Weiteren wäre es noch gut wenn du für sonoff den alive state abfragen würdest sonst sind diese immer mit "-1" offline (Baumstruktur aktiv)
    #363
    @stephan-schleich hallo, tut mir leid das es nicht auf anhieb läuft. Kannst du mal die instance auf debug stellen und dann die log ausgabe posten? Kann dann evtl eher sehen wo es hakt.
    Bei sonoff sollte er eigentlich den datenpunkt .alive nutzen wenn er auf -1
    //Edit: habe den Selektor geändert da es wohl nicht bei allen devices die uptime states gibt. Kannst bitte mal neu installieren und nochmal ausprobieren?
    Stephan SchleichS 1 Antwort Letzte Antwort
    • JB_SullivanJ Offline
      JB_Sullivan
      #364
      Hallo zusammen - durch Zufall bin ich auf diesen sehr genialen Adapter gestoßen.
      Installation und Einrichtung lief Problemlos. Was mich nur wundert, ist der Unterschied zwischen den Listen im "VIS Modus" und dem was als E-mail übermittelt wird.
      Das hier bekomme ich als Mail für Niedrige Batteriezustände geschickt.
      In der json Liste hingegen tauchen da ein paar Mehr Geräte auf.
      @ciddi89 Ist das für dich ein Großer Aufwand noch weitere Batterie betriebene Geräte zum Adapter hinzu zu fügen? Wenn Nein, was würdest du für Informationen zu so einem Gerät benötigen?
      ? 2 Antworten Letzte Antwort
      • JB_SullivanJ JB_Sullivan
        #365
        @jb_sullivan hmm das ist komisch. Ist das schon länger so oder war es heute die erste Nachricht? Dann vielleicht morgen noch mal gucken und sonst muss ich mal auf Fehler suche gehen.
        Sollte man eigentlich so hinbekommen, um welche Geräte / Adapter handelt es sich denn?
          Stephan SchleichS Offline
          Stephan Schleich
          #366
          @ciddi89 Debuglog:
          host.ioBroker
          2022-09-07 18:57:22.128	info	Restart adapter system.adapter.device-watcher.0 because enabled
          host.ioBroker
          2022-09-07 18:57:22.128	error	instance system.adapter.device-watcher.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          device-watcher.0
          2022-09-07 18:57:21.582	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          device-watcher.0
          2022-09-07 18:57:21.582	info	terminating
          device-watcher.0
          2022-09-07 18:57:21.581	info	cleaned everything up...
          device-watcher.0
          2022-09-07 18:57:21.580	error	Cannot read properties of undefined (reading 'captureException')
          device-watcher.0
          2022-09-07 18:57:21.580	error	TypeError: Cannot read properties of undefined (reading 'captureException') at DeviceWatcher.errorReporting (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:1898:38) at DeviceWatcher.onReady (/opt/iobroker/node_modules/iobroker.device-watcher/main.js:290:9)
          device-watcher.0
          2022-09-07 18:57:21.580	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
          device-watcher.0
          2022-09-07 18:57:21.580	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          device-watcher.0
          2022-09-07 18:57:21.579	warn	Error catched and sent to Sentry, error: [[onReady]] error: Cannot read properties of undefined (reading 'captureException')
          device-watcher.0
          2022-09-07 18:57:21.579	warn	Error catched and sent to Sentry, error: [[main]] error: Cannot read properties of undefined (reading 'captureException')
          device-watcher.0
          2022-09-07 18:57:21.579	warn	Error catched and sent to Sentry, error: [[main - create and fill datapoints for each adapter]] error: Cannot read properties of undefined (reading 'captureException')
          device-watcher.0
          2022-09-07 18:57:21.579	warn	Error catched and sent to Sentry, error: [[createDataForEachAdapter]] error: Cannot read properties of undefined (reading 'captureException')
          device-watcher.0
          2022-09-07 18:57:21.579	warn	Error catched and sent to Sentry, error: [[writeDatapoints]] error: Cannot read properties of undefined (reading 'localeCompare')
          device-watcher.0
          2022-09-07 18:57:21.275	info	Found items on the blacklist:
          device-watcher.0
          2022-09-07 18:57:21.275	info	Number of selected adapters: 4. Loading data from: Alexa2, Fritzdect, Sonoff, Zigbee ...
          device-watcher.0
          2022-09-07 18:57:21.266	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v16.17.0, js-controller: 4.0.23
          device-watcher.0
          2022-09-07 18:57:21.162	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
            @ciddi89 Debuglog:
            host.ioBroker
            host.ioBroker
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            device-watcher.0
            #367
            @stephan-schleich der Adapter steht nicht auf debug log :) bitte wie unten im Bild erst auf Expertenmodus gehen und dann bei Instanzen unter devicewatcher den log Mode von Info auf debug stellen. Sorry schon mal für die handyscreenshots :)
              JB_Sullivan
              #368
              @ciddi89 sagte in Test Adapter Device-Watcher v1.x.x GitHub/Latest:
              Ich habe den Adapter erst vorgestern installiert. In den drei Mails die ich bislang bekommen habe, sah es immer so aus wie in dem Beispiel oben. In der Mail nur ein Gerät, in der Liste alle die kleiner als der definierte Schwellwert (35%) sind.
              Einen Roomba Saugroboter (Roomba Adapter) und einen Rasenmähroboter (Innogy Adapter) . In diesen Adaptern gibt es jeweils Datenpunkte die die Akku Werte in % ausgeben
                #369
                @jb_sullivan Oki danke für die Info, ich werde das morgen Mittag mal testen.
                  #370
                  @jb_sullivan mir hat das heut Abend doch keine ruhe mehr gelassen und habe den Fehler gefunden und gefixed. Nach einem Update sollten alle Geräte in der Nachricht mit niedriger Batterie auftauchen. :)
                  Wegen den anderen Geräten/Adaptern gucke ich die Tage wenn ich Zeit habe das ich diese implementiert bekomme.
                    JB_Sullivan
                    schrieb am zuletzt editiert von JB_Sullivan
                    #371
                    Was auch immer du gefunden hast, es hat bei mir zu einen neuen Effekt geführt. Die Anzahl der gefundenen Devices hat sich von 92 auf 102 erhöht.
                    Diese Erhöhung resultiert vermutlich aus einem Fehler des Sonoff Adapter. Bei mir werden im Sonoff Adapter seit Jahren immer wieder "Kryptische" Geräte angelegt, deren Inhalt lediglich ein "alive=true oder false" ist.
                    Diese Geräte werden nun auch von deinem Adapter gefunden und in die Listen mit aufgenommen.
                    Von Zeit zu Zeit lösche ich dann diese kryptischen Geräte, ohne das es irgend einen Effekt für mein System hat. Keine Ahnung was der Sonoff Adapter da macht.
                    Ob das mit den Mails funktioniert kann ich dir erst heute Mittag sagen, da hier ja scheinbar ein fixer Sendezeitpunkt hinterlegt ist. Vielleicht eine Idee für die Zukunft, auch diesen Sendezeitpunkt als frei editierbaren Parameter in die Instanz Einstellungen mit aufzunehmen.
                    PS: Ich weiß nicht was du für eine zusätzliche Device Erkennung brauchst, aber hier wären die Datenpunkt Namen der beiden oben genannten Geräte
                    ROOMBA
                    roomba.0.states.battery
                    Mähroboter
                    innogy-smarthome.0.Garten.Wall-E.BatteryLevel - wobei hier "Garten/Wall-E" individuelle Begriffe sind, die jeder Nutzer selber vergeben kann.
                      Stephan Schleich
                      #372
                      @ciddi89 doch der war so eingestellt ;)
                        ROOMBA
                        Mähroboter
                        #373
                        @jb_sullivan ja ich hatte vor paar Tagen den Selektor für Sonoff Geräte auf den Datenpunkt alive geändert… weil er bei einigen nicht alle Geräte gefunden hat. Daher findet er nun deine kriptischen Geräte. Irgendwie kommen die meisten Fehler auch nur wegen dem sonoff Adapter. Muss ich mir wohl nochmal genauer angucken.
                        Das die Benutzer in Zukunft selbst die Zeit einstellen können kommt bald noch. Zusätzlich kommt dann noch das man eine Benachrichtigung kommt wenn zb lowbat states auf True wechseln.
                        Haben die Geräte noch rssi datenpunkte oder Erreichbarkeit? Am besten hilft mir immer ein Screenshot mit dem objektbaum eines Gerätes
                          JB_Sullivan
                          #374
                          Der Mähroboter leider nicht
                          Der Saugroboter auch nicht so wirklich, obwohl er einen DP für die Signal Qualität hat, was aber wohl nicht dem RSSI entspricht - vermute ich.
                            #375
                            @jb_sullivan der Saugroboter hat aber wenigstens battery, connected und signal. Sind für mich die wichtigsten Punkte. Was steht denn bei Signal in der JSON wenn du rechts auf das stiftsymbol gehst was ist min und was ist der Max wert?
                              #376
                              @stephan-schleich das ist sehr merkwürdig. Da fehlen aber die ganzen debug reports das er die Funktionen startet und so. Zumindest die ersten hätte ich erwartet und sollten auf jedenfall anlaufen. War denn schon mal eine Instanz vorhanden und wurde dann noch mal neu installiert? Am besten Instanz löschen, Adapter löschen und noch mal neu installieren. Irgendwas ist da komisch sonst.
                                Stephan Schleich
                                #377
                                @ciddi89 Hab ich bereits gemacht als ich auf V1 bin 😧 - Aber ist für mich jetzt nicht so tragisch wollts nur reporten ;)
                                  #378
                                  @stephan-schleich ja ich habe den Fehler bereits per sentry Report bekommen. Er meckert rum weil die id von den Sonoff Geräten Geräten falsch sind. Hast du da Geräte wo vor dem Namen noch ein Punkt ist oder so? Leider bist du bis jetzt der einzige User mit dem Fehler. So sieht die Fehlermeldung aus die ich bekommen habe:
                                    JB_Sullivan
                                    #379
                                    MIN/MAX Werte kann ich dir nicht sagen. Habe den DP nie aktiv beobachtet.
                                      "common": {
                                        "name": "Signal strength",
                                        "role": "value",
                                        "type": "number",
                                        "write": false
                                      "type": "state",
                                      "native": {},
                                      "from": "system.adapter.roomba.0",
                                      "user": "system.user.admin",
                                      "ts": 1626786483274,
                                      "_id": "roomba.0.states.signal",
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                        "owner": "system.user.admin",
                                        "common": {
                                          "role": "value",
                                          "type": "number",
                                          "write": false
                                        "type": "state",
                                        "native": {},
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636,
                                      #380
                                      @jb_sullivan ok danke. Normalerweise wird sowas darin hinterlegt. Ist hier aber leider nicht der Fall. Werde den Datenpunkt erstmal so übernehmen als Prozentwert.
                                          "common": {
                                            "role": "value",
                                            "type": "number",
                                            "write": false
                                          "type": "state",
                                          "native": {},
                                          "acl": {
                                            "object": 1636,
                                            "state": 1636,
                                        #381
                                        @jb_sullivan der Saugroboter hat noch einen Ordner namens device, gibt es dort oder vll im anderen Ordner irgendwo ein Datenpunkt wie ID oder name oder ähnliches in der art wo ich den Namen/id von beziehen könnte?
                                        //Edit: hat sich erledigt. Habe schon eine Auflistung gefunden. :)
                                        //Edit2: Der Roomba Adapter ist mit drin. Innogy-Smarthome muss ich mir vorher nochmal genauer angucken.
                                          Malz1902
                                          #382
                                          Mal ne Frage, ich habe 10 Steckdosen die über den Sonoff Adapter laufen. Diese sind aber nur zur Weihnachtszeit eingesteckt. Wenn ich diese jetzt auf die Blacklist setze welche Auswirkungen hat das genau, sowie ich das sehe, werden diese dann generell nicht mehr beachtet? Ich hätte halt gerne das ich in meiner VIS / JSON Tabelle sehe ob die Steckdosen verbunden sind oder nicht aber ich möchte für diese halt keine Nachricht bekommen, nevt momentan wenn man jeden Tag die Nachruicht bekommt das dieSonoff Steckdosen alle aus sind
