  4. Kein Update mehr möglich mit Node.js 16
node js
335 Beiträge 16 Kommentatoren 64.7k Aufrufe 16 Beobachtet
  • K kimukao
    @thomas-braun said in Kein Update mehr möglich mit Node.js 16:
    iobroker update
    pi@raspberrypi:~ $ iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.2.20   , installed 5.3.8  [Updatable]
    Adapter    "alexa2"       : 3.11.2   , installed 3.19.7
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.4.10   , installed 2.4.10
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "heos"         : 1.10.0   , installed 1.10.0
    Adapter    "history"      : 2.2.0    , installed 1.11.1 [Updatable]
    Adapter    "ical"         : 1.13.1   , installed 1.12.1 [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 3.1.7    , installed 2.6.3  [Updatable]
    Adapter    "javascript"   : 6.0.0    , installed 5.7.0  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "lupusec"      : 1.3.6    , installed 1.3.6
    Adapter    "netatmo"      : 1.7.1    , installed 1.7.1
    Adapter    "nuki-extended": 2.3.1    , installed 2.4.0
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "parcel"       : 0.0.20   , installed 0.0.15 [Updatable]
    Adapter    "pushover"     : 3.0.2    , installed 2.1.0  [Updatable]
    Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "sonos"        : 2.2.3    , installed 2.1.7  [Updatable]
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.3  [Updatable]
    Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
    Adapter    "telegram"     : 1.14.1   , installed 1.13.0 [Updatable]
    Adapter    "text2command" : 2.2.2    , installed 2.2.1  [Updatable]
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.3    , installed 2.0.2  [Updatable]
    Adapter    "uv-protect"   : 0.3.6    , installed 0.3.5  [Updatable]
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.87.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.6
    Adapter    "vw-connect"   : 0.0.51   , installed 0.0.50 [Updatable]
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    #322
    @kimukao
    Dann zieh die Adapter jetzt auf Stand.
    iobroker upgrade all -y
    Ich will jetzt nicht hochscrollen und suchen, aber hattest du npm separat angepackt / aktualisiert?
    • mickymM mickym
      @kimukao Na dann scheint die Aktualisierung auch wieder zu klappen. ;)- Freut mich.
      Wichtig ist - wenn alles funktioniert - ein Image zu ziehen - wenn Dinge im System verkehrt sind, bekommst die über das backup nicht geregelt und musst eben wieder alles von vorne installieren. Vergiss SSD - mach ein Image auf Deinem Windowsrechner von der SD karte. ;)
      kimukao
      #323
      @mickym Nochmal tausend Dank, Du kannst Dir gar nicht vorstellen, wie ich mich freue!! Echt mega!! Hab nen Mac, aber da sollte man ja auch ein Image hinziehen können. Werde den Tipp befolgen. Für heute freue ich mich erstmal, dass es wieder läuft. Und die extraneous Hinweise kann ich ignorieren?
      Thomas BraunT mickymM 2 Antworten Letzte Antwort
      • K kimukao
        #324
        @kimukao sagte in Kein Update mehr möglich mit Node.js 16:
        Ja.
        Oder nachdem alle Adapter aktualisiert wurden nochmal
        cd /opt/iobroker
        npm prune
        K 2 Antworten Letzte Antwort
        • K kimukao
          mickymM Offline
          mickymM Offline
          mickym
          #325
          @kimukao Nun ja das kann man mit npm prune aufräumen - das kommt aber oft wieder wenn irgendwelche Adapter alte Module verwenden und die dann in einer bestimmten Version wieder installiert werden.Extraneous ist unbedenklich - sondern aus Sicht des npm Paketmanagers sind diese Pakete überflüssig - das Modul meint aber es bräuchte die.
          Deswegen ist das was Thomas sagt- wie immer natürlich - goldrichtig. Alles updaten und dann mit npm prune nochmal aufräumen - und wenn dann noch was übrig ist - hast Du halt trotzdem irgendwo noch einen Verweis auf eine veraltetes Paket drin.
            Ja.
            cd /opt/iobroker
            npm prune
            kimukao
            #326
            Ja.
            cd /opt/iobroker
            npm prune
            Ziehe grade alle Updates. Auch Dir nochmal tausend Dank! Ihr seid echt klasse. Mega Forum! Danke, danke, danke. Freu mich :)
            • K kimukao
              Ja.
              cd /opt/iobroker
              npm prune
              mickymM Offline
              mickymM Offline
              mickym
              #327
              @kimukao Wir hätten Dich ja beinahe schon aufgegeben - ich war auch kurz davor. ;) - Insofern freuen wir uns mit Dir. :)
              • mickymM mickym
                kimukao
                #328
                @mickym said in Kein Update mehr möglich mit Node.js 16:
                Zum Glück habt Ihr es nicht :)
                • K kimukao
                  #329
                  @kimukao
                  Mich würde ja immer noch interessieren, wo die komische Installation von npm herkam. Bist du sicher, dass die nie per npm -g i npm oder sowas mal angepackt wurde?
                    Ja.
                    cd /opt/iobroker
                    npm prune
                    kimukao
                    #330
                    cd /opt/iobroker
                    npm prune
                    pi@raspberrypi:/opt/iobroker $ npm list
                    iobroker.inst@3.0.0 /opt/iobroker
                    ├── iobroker.admin@6.2.20
                    ├── iobroker.alexa2@3.19.7
                    ├── iobroker.alias-manager@1.2.4
                    ├── iobroker.backitup@2.4.10
                    ├── iobroker.daswetter@3.1.2
                    ├── iobroker.deconz@1.3.21
                    ├── iobroker.device-reminder@1.2.9
                    ├── iobroker.discovery@3.0.5
                    ├── iobroker.fritzdect@2.2.3
                    ├── iobroker.heos@1.10.0
                    ├── iobroker.history@2.2.0
                    ├── iobroker.ical@1.13.1
                    ├── iobroker.icons-material-png@0.1.0
                    ├── iobroker.icons-material-svg@0.1.0
                    ├── iobroker.icons-mfd-svg@1.1.0
                    ├── iobroker.icons-open-icon-library-png@0.1.2
                    ├── iobroker.icons-ultimate-png@1.0.1
                    ├── iobroker.influxdb@3.1.7
                    ├── iobroker.javascript@6.0.0
                    ├── iobroker.js-controller@4.0.23
                    ├── iobroker.km200@2.0.3
                    ├── iobroker.lupusec@1.3.6
                    ├── iobroker.netatmo@1.7.1
                    ├── iobroker.nuki-extended@2.4.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#b303d4a823fcba09b4d3de04d1412c770f5c68b4)
                    ├── iobroker.onvif@0.4.4
                    ├── iobroker.parcel@0.0.20
                    ├── iobroker.pushover@3.0.2
                    ├── iobroker.shelly@6.0.0
                    ├── iobroker.simple-api@2.7.0
                    ├── iobroker.smartcontrol@1.2.1
                    ├── iobroker.smartgarden@2.0.0
                    ├── iobroker.socketio@4.2.0
                    ├── iobroker.sonos@2.2.3
                    ├── iobroker.sony-bravia@1.0.9
                    ├── iobroker.synology@2.1.9
                    ├── iobroker.telegram@1.14.1
                    ├── iobroker.text2command@2.2.2
                    ├── iobroker.tr-064@4.2.16
                    ├── iobroker.trashschedule@2.0.3
                    ├── iobroker.uv-protect@0.3.6
                    ├── iobroker.vis-fancyswitch@1.1.0
                    ├── iobroker.vis-hqwidgets@1.2.0
                    ├── iobroker.vis-icontwo@0.89.0
                    ├── iobroker.vis-inventwo@3.3.3
                    ├── iobroker.vis-material-advanced@1.7.2
                    ├── iobroker.vis-timeandweather@1.2.2
                    ├── iobroker.vis-weather@2.5.6
                    ├── iobroker.vis@1.4.15
                    ├── iobroker.vw-connect@0.0.51
                    ├── iobroker.web@4.3.0
                    ├── iobroker.whatsapp-cmb@0.2.2
                    └── iobroker.yahka@0.13.1
                    • K kimukao
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #331
                      @kimukao Ich kann Dir nur raten - mach trotzdem ein Image - gerade wenn Du soviel anderes Zeug noch installiert hast. Ich habe auch mal neu aufgebaut - habe nicht so viel - aber mich hat das 2 Tage gekostet. Es gibt ja meist nicht nur den iobroker auf dem System - sondern auch noch andere Dinge.
                      • K kimukao
                        cd /opt/iobroker
                        npm prune
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #332
                        cd /opt/iobroker
                        npm prune
                        Aber die Frage von @Thomas-Braun solltest vielleicht nochmal durch den Kopf gehen lassen, dass Du das halt nicht mehr wieder machst.
                          @kimukao
                          kimukao
                          #333
                          Nicht, dass ich wüsste. Aber garantieren kann ich bei meinem Kenntnisstand für nichts...
                          • mickymM mickym
                            kimukao
                            #334
                            Das mache ich auf jeden Fall. Danke! Der Schock war lehrreich...
                            • K kimukao
                              kimukao
                              schrieb am zuletzt editiert von kimukao
                              #335
                              (hat sich erledigt)
