  4. [Problem] SayIt an Pi 3 spricht nicht?
    6.4k
31 Beiträge 5 Kommentatoren 6.4k Aufrufe
  • VardaaranV Offline
    VardaaranV Offline
    Vardaaran
    und wieder vielen Dank!
    Zu hören ist noch immer nichts - auch nach upload nicht - aber immerhin ist jetzt eine Fehlermeldung im Log!
    javascript.0 2017-06-18 21:00:35.070 info Stop script script.js.TEST.sayit-test2-blockly
    sayit.0 2017-06-18 21:00:08.174 error Cannot get file: received file is too short
    sayit.0 2017-06-18 21:00:08.081 info saying: let's testing
    javascript.0 2017-06-18 21:00:08.071 info script.js.TEST.sayit-test2-blockly: registered 0 subscriptions and 0 schedules
    javascript.0 2017-06-18 21:00:08.059 info Start javascript script.js.TEST.sayit-test2-blockly
    javascript.0 2017-06-18 20:59:18.998 info Stop script script.js.TEST.sayit-test
    sayit.0 2017-06-18 20:59:14.612 error Cannot get file: received file is too short
    sayit.0 2017-06-18 20:59:14.358 info saying: a auf ein Neues!
    javascript.0 2017-06-18 20:59:14.345 info script.js.TEST.sayit-test: registered 0 subscriptions and 0 schedules
    javascript.0 2017-06-18 20:59:14.289 info Start javascript script.js.TEST.sayit-test
    sayit.0 2017-06-18 20:56:55.549 info All files uploaded
    sayit.0 2017-06-18 20:56:55.471 info Upload announce mp3 files
    sayit.0 2017-06-18 20:56:55.455 info starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.sayit, node: v4.8.3
    host.raspberrypi 2017-06-18 20:56:54.118 info instance system.adapter.sayit.0 started with pid 7265
    host.raspberrypi 2017-06-18 20:56:54.088 info object change system.adapter.sayit.0
    sayit.0 2017-06-18 20:56:39.169 info stopping...
    sayit.0 2017-06-18 20:56:39.161 info stopping...
    sayit.0 2017-06-18 20:56:39.158 info All files uploaded
    sayit.0 2017-06-18 20:56:39.066 info Upload announce mp3 files
    sayit.0 2017-06-18 20:56:39.064 info Install process. Upload files and stop.
    sayit.0 2017-06-18 20:56:39.047 info starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.sayit, node: v4.8.3
    host.raspberrypi 2017-06-18 20:54:52.830 info Do not restart adapter system.adapter.sayit.0 because disabled or deleted
    host.raspberrypi 2017-06-18 20:54:52.829 error instance system.adapter.sayit.0 terminated with code 0 (OK)
    host.raspberrypi 2017-06-18 20:54:52.799 info stopInstance system.adapter.sayit.0 killing pid 5804
    sayit.0 2017-06-18 20:54:52.785 info stopping...
    host.raspberrypi 2017-06-18 20:54:52.537 error Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/sayit.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/sayit.admin/_data.json'
    sayit.0 2017-06-18 20:54:51.780 info stopping...
    • DutchmanD Offline
      DutchmanD Offline
      Dutchman
      Komische Meldung… Probier Mal nen längeren text wir kommen der Sache näher
      Send from mobile device
        VardaaranV Offline
        Vardaaran
        also noch länger???
        javascript.0	2017-06-18 21:16:41.782	info	Stop script script.js.TEST.sayit-test2-blockly
        sayit.0	2017-06-18 21:16:37.382	error	Cannot get file: received file is too short
        sayit.0	2017-06-18 21:16:37.297	info	saying: let's testing ist offenbar zu kurz. Geht es etwas länger? Also wirklich länger. Aber wie viel länger? Wir werden sehen
        javascript.0	2017-06-18 21:16:37.263	info	script.js.TEST.sayit-test2-blockly: registered 0 subscriptions and 0 schedules
        javascript.0	2017-06-18 21:16:37.261	info	Start javascript script.js.TEST.sayit-test2-blockly
        • DutchmanD Offline
          DutchmanD Offline
          Dutchman
          Man eh harte nuss!
          Könnte es sein das die rechte nicht stimmen wodurch ioBroker/sayit die Datei nicht sehen ?
          Mach Mal
          sudo chmod -R 777 /opt/iobroker
          Ist ein sicherer Befehl, rechte müssen im kompletten Verzeichnis ab root 777 sein
            VardaaranV Offline
            Vardaaran
            @Dutchman:
            Mach Mal
            Ist ein sicherer Befehl, rechte müssen im kompletten Verzeichnis ab root 777 sein `
            Gemacht. Jetzt gibt es keinen Fehler mehr, aber immer noch nichts zu hören:
            javascript.0	2017-06-18 22:02:54.615	info	Stop script script.js.TEST.sayit-test
            sayit.0	2017-06-18 22:02:48.073	info	Copied file '/opt/iobroker/node_modules/iobroker.sayit/say.mp3' to '/opt/iobroker/cache/981d1d8def7b8543dc17b9d3385ff07f.mp3'
            sayit.0	2017-06-18 22:02:46.755	info	saying: Ist wirklich eine harte Nuss! Vielen Dank für die ausdauernde Hilfe!
            sayit.0	2017-06-18 22:02:45.743	info	saying: /opt/iobroker/node_modules/iobroker.sayit/gong.mp3
            javascript.0	2017-06-18 22:02:45.713	info	script.js.TEST.sayit-test: registered 0 subscriptions and 0 schedules
            javascript.0	2017-06-18 22:02:45.712	info	Start javascript script.js.TEST.sayit-test
            javascript.0	2017-06-18 22:02:41.946	info	Stop script script.js.TEST.sayit-test
            Könnte es an den Rechten von Pulseaudio oder mpg321 liegen?
            mpg321 /opt/iobroker/node_modules/iobroker.sayit/say.mp3
            Geht und gibt das erstellte MP3-File wieder…
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              Hmm…
              Vielleicht Mal im Tesmspesk/Teamviewer kwatschen und Installationen vergleichen?
                VardaaranV Offline
                Vardaaran
                habe mich eigentlich strikt an dieses Tut gehalten.
                http://youness.net/raspberry-pi/bluetoo … -ad2p-only
                Mehr habe ich nicht gemacht.
                  VardaaranV Offline
                  Vardaaran
                  Habe jetzt ein altes Image geladen und nochmals ganz von Vorne angefangen.
                  Dann erst mal mpg321 installiert und den Lautsprecher mit einem Klinkenstecker direkt am Pi angeschlossen: SayIt spricht ohne Probleme!
                  Dann nach dieser Anleitung den Lautsprecher über Bluetooth verbunden und SayIt bleibt stumm! :(
                  Das Problem liegt glaube ich bei Pulseaudio.
                  Bei dieser Anleitung wird ja gesagt:
                  http://forum.iobroker.net/viewtopic.php … 114#p52068
                  @Zeebo:
                  Die Dienste müssen im root-Kontext gestartet werden, da ioBroker als root ausgeführt wird. Werden die nachfolgenden Dienste nur als normaler Benutzer, z.B. pi ausgeführt, funktioniert es zwar von der Console aus im Benutzerkontext, jedoch nicht aus ioBroker heraus. `
                  Was ja genau mein Problem ist.
                  Wenn ich aber nach dieser Anleitung vorgehe, kann ich folgende Schritte nicht ausführen:
                  @Zeebo:
                  Das könnt ihr mit den folgenden Befehlen fixen, indem wir das Profil wählen, welches die Senke enthält. und die default-sink setzen. In diesem Fall 'a2dp':
                  sudo pactl set-card-profile bluez_card.XX_XX_XX_XX_XX_XX a2dp
                  sudo pactl set-default-sink bluez_sink.XX_XX_XX_XX_XX_XX
                  da die Befehle einfach nicht angenommen werde (ja, ich habe natürlich die richtige MAC-Adresse eingetragen :D )…
                  Und beim Ausführen von Pulseaudio über root meckert Pulseaudio ebenfalls rum.
                  Und SayIt sagt:
                  sayit.0 2017-06-21 15:02:17.491 error Can't open libao driver with device default (is device in use?)
                  sayit.0 2017-06-21 15:02:17.491 error ALSA lib dlmisc.c:252:(snd1_dlobj_cache_get) Cannot open shared library /usr/lib/arm-linux-gnueabihf/alsa-lib/libasound_module_pcm_bluetooth.so
                  sayit.0 2017-06-21 15:02:17.491 error MPEG 2.0 layer III, 32 kbit/s, 24000 Hz mono
                  sayit.0 2017-06-21 15:02:17.491 error Playing MPEG stream from say.mp3 ...
                  sayit.0 2017-06-21 15:02:17.491 error Directory: /opt/iobroker/node_modules/iobroker.sayit
                  sayit.0 2017-06-21 15:02:17.491 error tcgetattr(): Inappropriate ioctl for device
                  sayit.0 2017-06-21 15:02:17.491 error THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
                  sayit.0 2017-06-21 15:02:17.491 error Uses code from various people. See 'README' for more!
                  sayit.0 2017-06-21 15:02:17.491 error now maintained by Nanakos Chrysostomos and others.
                  sayit.0 2017-06-21 15:02:17.491 error Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,
                  sayit.0 2017-06-21 15:02:17.491 error High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.
                  sayit.0 2017-06-21 15:02:17.491 error Cannot play:Error: Command failed: mpg321 '/opt/iobroker/node_modules/iobroker.sayit/say.mp3' -a default
                  sayit.0 2017-06-21 15:02:17.468 info Copied file '/opt/iobroker/node_modules/iobroker.sayit/say.mp3' to '/opt/iobroker/cache/790814bc3890533bdfd13659432d12d0.mp3'
                  sayit.0 2017-06-21 15:02:17.196 info saying: irgendwie muss es doch gehen
                  sayit.0 2017-06-21 15:02:16.241 error Can't open libao driver with device default (is device in use?)
                  sayit.0 2017-06-21 15:02:16.241 error ALSA lib dlmisc.c:252:(snd1_dlobj_cache_get) Cannot open shared library /usr/lib/arm-linux-gnueabihf/alsa-lib/libasound_module_pcm_bluetooth.so
                  sayit.0 2017-06-21 15:02:16.241 error MPEG 1.0 layer III, 128 kbit/s, 44100 Hz joint-stereo
                  sayit.0 2017-06-21 15:02:16.241 error Playing MPEG stream from gong.mp3 ...
                  sayit.0 2017-06-21 15:02:16.241 error Directory: /opt/iobroker/node_modules/iobroker.sayit
                  sayit.0 2017-06-21 15:02:16.241 error tcgetattr(): Inappropriate ioctl for device
                  sayit.0 2017-06-21 15:02:16.241 error THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY! USE AT YOUR OWN RISK!
                  sayit.0 2017-06-21 15:02:16.241 error Uses code from various people. See 'README' for more!
                  sayit.0 2017-06-21 15:02:16.241 error now maintained by Nanakos Chrysostomos and others.
                  sayit.0 2017-06-21 15:02:16.241 error Version 0.3.2-1 (2012/03/25). Written and copyrights by Joe Drew,
                  sayit.0 2017-06-21 15:02:16.241 error High Performance MPEG 1.0/2.0/2.5 Audio Player for Layer 1, 2, and 3.
                  sayit.0 2017-06-21 15:02:16.241 error Cannot play:Error: Command failed: mpg321 '/opt/iobroker/node_modules/iobroker.sayit/gong.mp3' -a default
                  sayit.0 2017-06-21 15:02:16.177 info saying: /opt/iobroker/node_modules/iobroker.sayit/gong.mp3
                  javascript.0 2017-06-21 15:02:16.162 info script.js.TEST.sayit-test: registered 0 subscriptions and 0 schedules
                  javascript.0 2017-06-21 15:02:16.156 info Start javascript script.js.TEST.sayit-test
                  javascript.0 2017-06-21 15:02:13.781 info Stop script script.js.TEST.sayit-test
                  Jemand noch eine Idee? :|
                    Desa
                    Ja, Da ich ein ähnliches Problem hatte befor ich zu OMX Player gegangen bin und dann doch wieder zurück ^^
                    Ich hoffe das ich nicht gesteinigt werde, aber im Fhem Forum bin ich letztes mal fündig geworden.
                    Ich kopier einfach mal das wichtigste raus
                    da ich nicht weiss ob Ich den link Posten darf
                    ` > Ich habe festgellt, dass beim Aufruf in der Commandozeile vom rpi trotz, dass er den mp3 abspielt, eine Fehlermeldung mit ausspuckt (snd_pcm_open_noupdate) Unknown PCM cards.pcm.front).
                    Dies habe ich behoben indem ich in der /usr/share/alsa/alsa.conf die Zeile pcm.front cards.pcm.front” in pcm.front cards.pcm.default“ geändert habe.
                    Also das gesamte Doing:
                    sudo apt-get install alsa-utils
                    sudo apt-get install mpg321
                    sudo apt-get install lame
                    In der /usr/share/alsa/alsa.conf die Zeile pcm.front cards.pcm.front” in pcm.front cards.pcm.default“ ändern. und > root@banana-pi:/opt/fhem# ls -l /dev/snd/
                    total 0
                    drwxr-xr-x 2 root root 60 Jan 1 2010 by-path
                    crw-rw–-- 1 root audio 116, 4 Jan 1 2010 controlC0
                    crw-rw---- 1 root audio 116, 3 Jan 1 2010 pcmC0D0c
                    crw-rw---- 1 root audio 116, 2 Jan 1 2010 pcmC0D0p
                    crw-rw---- 1 root audio 116, 33 Jan 1 2010 timer `
                    Benutze jedoch auch Fhem mit,
                    Und bitte kontrolliere ob du unter beiden Usern root wie auch deinem User abspielen kannst.
                    Hoffe das Hilft dir ein bisschen weiter, bei mir fehlte damals die hälfte von alsa
                    Lg
                    5x Rpi3, 2xRpi4 4gb, 4x HMThermostat, 4x MaxThermostat, 12x HMFensterkontakt, 2x MaxFensterkontakt, 2x RauchmelderZwave, 3x SteckdoseZwave, 14x Steckdose Elro433MHz, 2x HM 4FachSchaltaktor, 3x FS20Bewegungsmelder, 1xCul433, 1xCul862, 1xCulMAX, 1xZwave und HMO, MI Home Gateway 2x, 7x Mi Smoke, 1x MiGas, 3x Temp, 3x Sens
                      VardaaranV Offline
                      Vardaaran
                      Vielen Dank für den Tipp!
                      Werde es baldmöglichst ausprobieren. Bis dahin habe ich wieder das alte Image geladen und lasse den Lautsprecher mit Klinke verbunden. Manchmal ist die alte Methode doch die Beste… ;) :D
                        Snatch
                        ich habe exakt das gleiche Problem. Per Console 1a, per SayIt direkt aus IBroker nix.
                        Gibt es hier eine Lösung mittlerweile?
                          VardaaranV Offline
                          Vardaaran
                          @Snatch:
                          Grüße `
                          Leider nicht. 😢
                          Habe mich mit der "Kabellösung" abgefunden…
                            Snatch
                            @Vardaaran:
                            @Snatch:
                            Grüße `
                            Leider nicht. 😢
                            Habe mich mit der "Kabellösung" abgefunden… `
                            Sehr schade, dann teste ich mal weiter.
                              Snatch
                              So, ich habe etwas gefunden was das Problem sein könnte aber kann es nicht deute.
                              Im Objekt "MP3" steht folgendes "Can be accessed from web server under http://ip:8082/state/sayit.0.tts.mp3".
                              Der Link führt aber ins leere (Ja, IP wurde angepasst).
                              Dieses Objekt wird immer dann aufgerufen, wenn ein Text ausgegeben werden soll. Liegt vielleicht daran. Verstehe aber nicht, wie ich das fixen könnte.
                                Snatch
                                So, bei mir geht es jetzt.
                                Habe SayIt komplett deinstalliert:
                                iobroker stop
                                npm remove iobroker.sayit
                                iobroker start
                                Dann das Verzeichnis war aber SayIt unter "Instanzen" immer noch da, also auch dort nochmal deinstalliert.
                                Anschließend SayIt wieder installiert:
                                iobroker stop
                                npm install iobroker.sayit
                                iobroker upload
                                iobroker start
                                Dann eben im IOBroker die Instanz "SayIt" wieder angelegt.
                                Nun funktioniert es wunderbar mit meinem Blocky-Skript
                                • V Offline
                                  V Offline
                                  vondefenn
                                  Gleiches Problem bei mir seit STRETCH; liegt an den Zugriffsrechten von root auf das pulse audio, bzw. für root wird keine pulse-audio Instanz geladen; (weil iobroker als root läuft). Normale User laden den pulse audio mit login, daher funktioniert das auch über die Shell, aber nicht in der sayit Instanz)
                                  Lösung siehe:
                                  https://askubuntu.com/questions/751750/ … t-usermode
                                  solved it by running,
                                  pulseaudio -D as root on each start up.
