    apollon77A
4.8k Beiträge 4 Kommentatoren 3.3m Aufrufe 4 Beobachtet
  • Damrak2022D Damrak2022
    @mickym Ich habe gerade mal dieses Script eingebunden:
    [{"id":"fbbafb8d.8c3818","type":"exec","z":"ae220e4a.3c49d","command":"vcgencmd measure_temp","addpay":false,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"RPi Temperatur","x":440,"y":200,"wires":[["17fa85a3.c0a5fa"],[],[]]},{"id":"610a759f.da34ec","type":"inject","z":"ae220e4a.3c49d","name":"aktualisierung 10sek","topic":"","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"onceDelay":"","x":200,"y":200,"wires":[["fbbafb8d.8c3818","6b5302eb.fe0fbc","f8494c08.39fe8"]]},{"id":"17fa85a3.c0a5fa","type":"function","z":"ae220e4a.3c49d","name":"cutString","func":"str = msg.payload\nmsg.payload = str.substring(5,9);\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":200,"wires":[["e8f154dc.299398","71f38a1c.ca6f64"]]},{"id":"4070b9bd.5796b8","type":"exec","z":"ae220e4a.3c49d","command":"sudo reboot","addpay":false,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"Neustarten","x":430,"y":540,"wires":[[],[],[]]},{"id":"77a93271.11eabc","type":"exec","z":"ae220e4a.3c49d","command":"sudo shutdown -h now","addpay":false,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"Herunterfahren","x":440,"y":620,"wires":[[],[],[]]},{"id":"6b5302eb.fe0fbc","type":"exec","z":"ae220e4a.3c49d","command":"top -d 1 -b -n2 | grep \"Cpu(s)\"|tail -n 1 | awk '{print $2 + $4}'","addpay":false,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"CPU Last","x":420,"y":280,"wires":[["97612f41.a7f6e"],[],[]]},{"id":"f8494c08.39fe8","type":"exec","z":"ae220e4a.3c49d","command":"free | grep Mem | awk '{print 100*(($3+$5)/$2)}'","addpay":false,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"RAM","x":410,"y":360,"wires":[["6ce43c7.2c89bc4"],[],[]]},{"id":"7b744c14.050354","type":"exec","z":"ae220e4a.3c49d","command":"df -h","addpay":false,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"Speicherplatz","x":440,"y":440,"wires":[["403e1890.2fbab8"],[],[]]},{"id":"403e1890.2fbab8","type":"function","z":"ae220e4a.3c49d","name":"modifyString","func":"var re = /([0-9]{2})%/\nvar idx = msg.payload.search(re);\nvar str = msg.payload;\nif (idx >=0) {\n    str = msg.payload.substring(idx, idx + 2);\n}\nmsg.payload = str;\nreturn msg;","outputs":1,"noerr":0,"x":670,"y":440,"wires":[["f574e160.da0f1"]]},{"id":"da61973.d30f268","type":"inject","z":"ae220e4a.3c49d","name":"aktualisierung 1min","topic":"","payload":"","payloadType":"date","repeat":"60","crontab":"","once":false,"onceDelay":"","x":200,"y":440,"wires":[["7b744c14.050354"]]},{"id":"37bde909.05a676","type":"ui_button","z":"ae220e4a.3c49d","name":"","group":"5fe5a9b.a8a6158","order":3,"width":0,"height":0,"passthru":false,"label":"Neu starten","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":230,"y":540,"wires":[["4070b9bd.5796b8"]]},{"id":"12fa2be3.80e824","type":"ui_button","z":"ae220e4a.3c49d","name":"","group":"5fe5a9b.a8a6158","order":4,"width":0,"height":0,"passthru":false,"label":"Herunterfahren","color":"","bgcolor":"red","icon":"","payload":"","payloadType":"str","topic":"","x":240,"y":620,"wires":[["77a93271.11eabc"]]},{"id":"e8f154dc.299398","type":"ui_gauge","z":"ae220e4a.3c49d","name":"","group":"5fe5a9b.a8a6158","order":1,"width":0,"height":0,"gtype":"gage","title":"CPU Temperatur","label":"C","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":910,"y":180,"wires":[]},{"id":"638024a7.6ca05c","type":"ui_gauge","z":"ae220e4a.3c49d","name":"","group":"6b432a4a.06ad54","order":1,"width":0,"height":0,"gtype":"gage","title":"CPU","label":"CPU","format":"{{value}}%","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":870,"y":300,"wires":[]},{"id":"d80d6326.88202","type":"ui_gauge","z":"ae220e4a.3c49d","name":"","group":"6b432a4a.06ad54","order":1,"width":0,"height":0,"gtype":"gage","title":"Speicher","label":"RAM","format":"{{value}}%","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":880,"y":360,"wires":[]},{"id":"f574e160.da0f1","type":"ui_gauge","z":"ae220e4a.3c49d","name":"","group":"6b432a4a.06ad54","order":1,"width":0,"height":0,"gtype":"gage","title":"Disk","label":"Speicherplatz","format":"{{value}}%","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":870,"y":440,"wires":[]},{"id":"71f38a1c.ca6f64","type":"ui_chart","z":"ae220e4a.3c49d","name":"","group":"5fe5a9b.a8a6158","order":2,"width":0,"height":0,"label":"CPU Temperatur Verlauf","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":true,"x":930,"y":240,"wires":[[],[]]},{"id":"6ce43c7.2c89bc4","type":"function","z":"ae220e4a.3c49d","name":"deleteWhitespace","func":"var str = msg.payload\nstr = str.trim();\nvar nr=parseInt(str);\nmsg.payload = nr.toFixed(1);\nreturn msg;","outputs":1,"noerr":0,"x":690,"y":360,"wires":[["d80d6326.88202"]]},{"id":"97612f41.a7f6e","type":"function","z":"ae220e4a.3c49d","name":"deleteWhitespace","func":"str = msg.payload\nmsg.payload = str.trim();\nreturn msg;","outputs":1,"noerr":0,"x":690,"y":280,"wires":[["638024a7.6ca05c"]]},{"id":"75f679fd.1125a8","type":"inject","z":"ae220e4a.3c49d","name":"Herunterfahren","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":260,"y":680,"wires":[["77a93271.11eabc"]]},{"id":"5fe5a9b.a8a6158","type":"ui_group","z":"ae220e4a.3c49d","name":"2","tab":"7e8708a2.0fc408","order":2,"disp":false,"width":"6","collapse":false},{"id":"6b432a4a.06ad54","type":"ui_group","z":"ae220e4a.3c49d","name":"1","tab":"7e8708a2.0fc408","order":1,"disp":false,"width":"6","collapse":false},{"id":"7e8708a2.0fc408","type":"ui_tab","z":"ae220e4a.3c49d","name":"Raspi Daten","icon":"dashboard","order":1}]
    Da bekomme ich gerade einen Mega Schreck, vorausgesetzt die Daten stimmen.
    mickymM
    mickymM
    mickym
    #77
    Nun ja warum sollte das nicht stimmen? - Wenn Du einen Raspberry hast und Du deine Datenbank darauf laufen lässt und alles mögliche loggst, dann ist der Plattenplatz voll. du siehst ja, was für Befehle abgesetzt werden.
    Zum Beispiel für den Plattenplatz: df -h
    Im Prinzip hast Du sofort Handlungsbedarf - sonst ist Dein System im Nu gecrashed - weil der Plattenplatz voll ist.
    Wenn Du diesen Befehl eingibst - dann kannst Du auf Kommandoebene sehen, in welchen Verzeichnissen besonders viel Speicherplatz auf Deiner SD Karte verbraucht hast. Wie groß ist denn Deine Karte?
    sudo du -sh /*
    • mickymM mickym
      sudo du -sh /*
      Damrak2022D
      Damrak2022D
      Damrak2022
      #78
      @mickym Habe gerade hier gepostet.
      ioBroker ist auf einer SSD mit 128 GB installiert
      Mit besten Grüßen
      Andy
      • mickymM mickym
        sudo du -sh /*
        Damrak2022D
        Damrak2022D
        Damrak2022
        #79
        @mickym Habe mein Ergebnis in dem anderen Post gepostet
        Mit besten Grüßen
        Andy
        • mickymM
          mickymM
          mickym
          #80
          @damrak2022 sagte in Wieviel freien Speicher:
          Wie hast Du Dein Dashboard gestaltet, sodass es exakt aufs iPad passt?
          Das funktioniert beim dashboard nicht so - sondern das funktioniert reponsiv - das heiß Du kannst das Dashboard nicht für bestimmte Geräte anpassen. Wenn Du die Gruppen 6 Einheiten breit machst - dann passt es genau auf ein normales Smartphone. Auf dem iPad werden dann soviel nebeneinander angelegt - bis die Breite verbraucht ist und wird dann in der 2. Zeile weitergemacht. Das ist optisch nicht so schön - wie in einer VIS - aber dafür kannst Du das Dashboard auf vielen Geräten verwenden. Wenn Du die Gruppen 12 Einheiten breit machst dann ist es im Querformat ohne zu scrollen auf dem Smartphone sichtbar. Wie gesagt manchmal kann man durch die Reihenfolge der Gruppen etwas anpassen. - Das ist halt der Nachteil an dem responsiv Design . Die Screenshots sind alle vom iPad.
          Du kannst theoretisch aber auch eine Gruppe so breit wie das Ipad machen - dann bleibt es fix - dann kannst es halt auf dem Smartphone nur mit Wischen anschauen.
          Meine Wetterseite arbeitet mit so breiten Gruppen :
          Auf dem iPad - ich hab allerdings das große - gehen auch 2 12er Gruppen:
          schaut aber auch nicht überall schön aus:
          Aber nochmal Du solltest Dir trotzdem überlegen ob Du nicht erst mal bei VIS bleibst und Node Red für Deine Logik verwendest - Du kannst auch VIS Seiten ins NR Dashboard einbinden.
          Wenn Du statt eines Tabs eine Link verwendest kannst Du auch direkt eine VIS Seite aufrufen:
          entweder Vollbild oder auch als iFrame.
          Bei mir ist zum Beispiel die gesamte Zigbee-GUI ins NR Dashboard eingebunden:
          • mickymM mickym
            Damrak2022D
            Damrak2022D
            Damrak2022
            #81
            @mickym Das sieht gut aus und damit kann ich gut leben.
            Mal schauen, ob mein Backup nachher fertig ist, wenn ich nach Hause komme.
            Mit besten Grüßen
            Andy
            • mickymM mickym
              Damrak2022D
              Damrak2022D
              Damrak2022
              #82
              @mickym Ich habe gerade mal die Breite überall auf 7 angepasst, dann sieht es auf dem iPhone 12 perfekt aus.
              Mit besten Grüßen
              Andy
                mickymM
                mickymM
                mickym
                #83
                @damrak2022 Ja ich glaube aber das ist minimales horizontales Scrolling - musst halt mal schauen - auch sind ungerade Zahlen eher ungünstig - ich würde beim Standard 6 bleiben. ;)
                • mickymM mickym
                  Damrak2022D
                  Damrak2022D
                  Damrak2022
                  #84
                  @mickym ich schau mal wie es mit 8 ist, ansonsten gehe ich auf 6 zurück.
                  Warum sind ungerade Zahlen ungünstig?
                  Ich bin gerade meinen Hue Bewegungsmelder ein und such den DAtenpunkt der mir „LUX“ liefert. Den finde ich nämlich nicht
                  Mit besten Grüßen
                  Andy
                    mickymM
                    mickymM
                    mickym
                    #85
                    @damrak2022 Nehmen wir mal Du möchtest 2 Elemente in einer Reihe haben - dann sind die entweder immer ungleich groß oder Du nimmst ein drittes als Abstand. Das Layout Tool kann ich zwar nicht empfehlen - ausser zum Anschauen.
                    Wenn Du mal meine Elemente zur Heizungssteuerung nimmst - dann siehst Du, dass ein gewisse Symmetrie durchaus von Vorteil ist.
                    Zu HUE kann ich Dir gar nichts sagen - vielleicht haben die ja keine Helligkeitssensoren.
                    • mickymM mickym
                      Damrak2022D
                      Damrak2022D
                      Damrak2022
                      #86
                      @mickym Welche Bewegungsmelder nutzt Du. Ich brauche sowieso noch welche.
                      Mit besten Grüßen
                      Andy
                        mickymM
                        mickymM
                        mickym
                        #87
                        @damrak2022 Die hier die meisten nutzen XIAOMI - mit Zigbee halt.
                        https://www.zigbee2mqtt.io/devices/RTCGQ11LM.html#xiaomi-rtcgq11lm. Ich finde die halt super schön klein- Ich mache die nur nicht fix - wenn man sie doch mal neu pairen muss. Aber ich finde die relativ dezent.
                          mickymM
                          mickymM
                          mickym
                          #88
                          @damrak2022 Aber Du brauchst ja kein Luxmeter für Deine Bewegungsmelder - Du kannst ja auch zeitabhängig steuern.
                          • mickymM mickym
                            Damrak2022D
                            Damrak2022D
                            Damrak2022
                            #89
                            @mickym Xiaomi finde ich generell schon mal gut, da ich von denen schon meinen Ventilator, Wasserkocher uns Staubsauger habe.
                            Mit besten Grüßen
                            Andy
                              mickymM
                              mickymM
                              mickym
                              #90
                              @damrak2022 Ich denke die sind immer noch verhältnismäßig günstig -
                              wo bei ich die glaub vor 1-2 Jahren nach für ca. 15 € gekauft habe.Manchmal hakts auch - aber ich hab auch nicht den Anspruch, dass alles immer 100% funktioniert.
                              • mickymM mickym
                                Damrak2022D
                                Damrak2022D
                                Damrak2022
                                #91
                                @mickym Ich habe gerade mal nach meinem Hue Bewegungsmelder geschaut und wenn ich das richtig verstehe hat der einen Helligkeitssensor.
                                Mit besten Grüßen
                                Andy
                                  mickymM
                                  mickymM
                                  mickym
                                  #92
                                  @damrak2022 Wie gesagt - dann musst halt suchen (ich hab kein HUE und auch nicht den Adapter) - vielleicht ist der Wert in einem JSON String versteckt - zeig halt mal die Datenpunkte des Sensors
                                  • mickymM mickym
                                    Damrak2022D
                                    Damrak2022D
                                    Damrak2022
                                    #93
                                    @mickym Ich vermute das ist der:
                                    Hat sich erledigt.
                                    Mit besten Grüßen
                                    Andy
                                      Hat sich erledigt.
                                      mickymM
                                      mickymM
                                      mickym
                                      #94
                                      @damrak2022 Ja schaut doch gut aus.
                                      • mickymM mickym
                                        Damrak2022D
                                        Damrak2022D
                                        Damrak2022
                                        #95
                                        @mickym Ja, das ist es, habe das gerade mal getestet. Da kommt allerdings eine 4 stelliger Wert raus. Den müsste man wahrscheinlich durch 1000 teilen um ihn dann in Node Red darzustellen.
                                        Mit besten Grüßen
                                        Andy
                                          mickymM
                                          mickymM
                                          mickym
                                          #96
                                          @damrak2022 Nein Lux Werte können auch 4stellig werden. Das hat doch nichts mit NodeRed zu tun. Bei mir hängen die aber soweit im Zimmer, dass so gut wie nie 1000 erreicht werden. Aber es gibt in NodeRed doch keine Einschränkungen
                                          84.1k
