  4. Sonoff NSPanel
Sonoff NSPanel
1.5k Beiträge 78 Kommentatoren 1.3m Aufrufe 80 Beobachtet
  • P
    P
    Peet_b
    #1127
    ersteinmal vielen Dank für das coole Projekt. Leider habe ich ein Problem bei der Umsetzung. Wenn ich die icon_mapping.ts starte, stürzt immer der JavaScript-Adpter ab. Hat jemand eine Idee?
    log:
    2022-08-29 14:18:31.285 - info: javascript.0 (1591) starting. Version 6.0.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.17.0, js-controller: 4.0.23
    2022-08-29 14:18:32.619 - info: javascript.0 (1591) requesting all states
    2022-08-29 14:18:32.621 - info: javascript.0 (1591) requesting all objects
    2022-08-29 14:18:33.752 - info: javascript.0 (1591) received all objects
    2022-08-29 14:18:33.985 - info: javascript.0 (1591) received all states
    2022-08-29 14:18:34.050 - info: javascript.0 (1591) script.js.global.icon_mapping: compiling TypeScript source...
    2022-08-29 14:18:40.228 - info: javascript.0 (1591) script.js.global.icon_mapping: TypeScript compilation successful
    2022-08-29 14:18:40.368 - error: javascript.0 (1591) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-08-29 14:18:40.369 - error: javascript.0 (1591) unhandled promise rejection: Debug Failure. Unhandled SyntaxKind: Unknown.
    2022-08-29 14:18:40.369 - error: javascript.0 (1591) Error: Debug Failure. Unhandled SyntaxKind: Unknown.
    at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:113075:22)
    at pipelineEmitWithHint (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112608:17)
    at pipelineEmitWithComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116249:13)
    at pipelineEmit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112548:13)
    at emit (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112521:13)
    at emitModuleDeclaration (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114436:13)
    at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112799:32)
    at emitListItemWithParenthesizerRule (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116742:9)
    at emitNodeListItems (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115493:17)
    at emitNodeList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115411:17)
    at emitList (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115376:13)
    at emitSourceFileWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:115062:13)
    at emitBodyWithDetachedComments (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:116369:17)
    at emitSourceFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:114981:17)
    at pipelineEmitWithHintWorker (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112623:24)
    at print (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112484:13)
    at writeFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112468:13)
    at printFile (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112329:13)
    at Object.printNode (/opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:112313:62)
    at transformGlobalDeclarations (/opt/iobroker/node_modules/iobroker.javascript/lib/typescriptTools.js:496:31)
    at Immediate. (/opt/iobroker/node_modules/iobroker.javascript/main.js:1078:64)
    at processImmediate (node:internal/timers:468:21)
    2022-08-29 14:18:40.370 - error: javascript.0 (1591) Debug Failure. Unhandled SyntaxKind: Unknown.
    2022-08-29 14:18:40.438 - info: javascript.0 (1591) terminating
    Das System läuft auf einem NUC, mit Proxmox, in einem Debian 11 LXC
    Danke und Gruß
    Peet
    T ArmilarA 2 Antworten Letzte Antwort
    • P Peet_b
      log:
      Danke und Gruß
      Peet
      T
      T
      TT-Tom
      #1128
      @peet_b sagte in Sonoff NSPanel:
      Edit: habe das selbe Problem, das der JS Adapter neu startet.
      Gruß Tom
      Public Transport
      NSPanel Adapter Dokumentation
      https://ticaki.github.io/ioBroker.nspanel-lovelace-ui/
      • P Peet_b
        log:
        Danke und Gruß
        Peet
        ArmilarA
        ArmilarA
        Armilar
        Most Active Forum Testing
        #1129
        log:
        Danke und Gruß
        Peet
        Welche Version vom JavaScript hast du laufen? Unter 6.0.1 macht meiner ebenfalls Stress. Ah sehe es ist der 6.0.0. Mal versuchen auf einen früheren Release-Stand zu wechseln?
        Eigentlich ist im icon_selector keine async Funktion (so wie in der Fehlermeldung). Sicher, dass da der richtige Inhalt drin ist?
        https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/ioBroker/icon_mapping.ts
        Der Inhalt hat sich die letzten 4 Monate nicht verändert
        T P 2 Antworten Letzte Antwort
        • ArmilarA Armilar
          log:
          Danke und Gruß
          Peet
          T
          T
          TT-Tom
          #1130
          @armilar
          bei mir lief das Script ohne Probleme. Jetzt mit der 6.0.0 habe ich das selbe Problem. Die letzte Version JS war bei mir 5.7.0, damit lief es noch.
          Nur die Fehlermeldung habe ich noch nicht gesehen, muss mal das Log durchsuchen.
          Gruß Tom
          Public Transport
          • T TT-Tom
            @armilar
            ArmilarA
            ArmilarA
            Armilar
            #1131
            @tt-tom sagte in Sonoff NSPanel:
            @armilar
            Wie schon erwähnt, das letzte Update hat bei mir auch nur Exceptions geworfen. Rebootet sich halbwegs tot.
            5.8.10 sollte aber funktionieren
            Stable sollte in der tat laut Issue noch 5.7.0 sein
            Version: stable=5.7.0 (86 days old) => latest=6.0.0 (15 days old)
            • ArmilarA Armilar
              @armilar
              T
              T
              TT-Tom
              #1132
              @armilar sagte in Sonoff NSPanel:
              5.8.10 bringt bei mir folgenden Fehler
              2022-08-29 18:49:58.826 - error: javascript.0 (4049524) npm
              2022-08-29 18:49:58.828 - error: javascript.0 (4049524) WARN config production Use `--omit=dev` instead.
              läuft aber wie es aussieht
              Edit: läuft doch nicht, fängt wieder an neu zu starten. werde auf 5.7.0 gehen und testen
              Gruß Tom
              Public Transport
              • ArmilarA Armilar
                log:
                Danke und Gruß
                Peet
                P
                P
                Peet_b
                #1133
                @armilar
                Der Inhalt ist identisch, habe auch schon das Skript mehrfach neu erstellt und habe auch schon eine andere Instanz oder ein anderen Host getestet. Keine Änderung
                Wie komme ich auf die V5.7.0 zurück? IoB bietet mir nur an auf die V5.8.3 zurück zu gehen.
                Peet
                • K
                  K
                  Kuckuckmann
                  schrieb am zuletzt editiert von Kuckuckmann
                  #1134
                  Also ich habe v6.0.1 des JS Adapter am laufen und da stürzt nix ab.
                  @TT-Tom @Peet_b
                  habt Ihr das Skript im Ordner Global?
                  Könnt Ihr mal den Inhalt Eures Skripts in einem Spoiler hier komplett posten?
                  Hattet ihr neulich ein JS Adapter Update gemacht welches hängen blieb?
                  Ggf. müsst Ihr in den Adaptern beim JS Adapter mal einen Dateiupload anstoßen.
                  @Peet_b
                  Hier findest Du eine Anleitung, wie man via Commandline eine bestimmte Adapterversion installieren kannst.
                  Aber Vorsicht: Auf Commandline Ebene ist das eigenes Risiko - quasi ohne Netz und doppelten Boden.
                  NSPanel Dokumentation im GitHub Wiki:
                  P ArmilarA 2 Antworten Letzte Antwort
                  • K Kuckuckmann
                    @TT-Tom @Peet_b
                    @Peet_b
                    P
                    P
                    Peet_b
                    #1135
                    @kuckuckmann
                    Ich habe die Vorlage Eins zu Eins übernommen und sie in "Global" angelegt.
                    Den Inhalt kann ich leider nicht posten, das sind zu viele Zeichen. Aber wenn ich bei Github "copy Raw Contents" benutze, sollte doch alles dabei sein.
                    Ich hatte vor dem Anlegen ein Update des Adapters gemacht, das lief auch problemlos durch.
                    • K Kuckuckmann
                      @TT-Tom @Peet_b
                      @Peet_b
                      ArmilarA
                      ArmilarA
                      Armilar
                      #1136
                      @kuckuckmann sagte in Sonoff NSPanel:
                      @TT-Tom @Peet_b
                      @Peet_b
                      Wie schon erwähnt. Die 6.0.1 schreibt mir mein Log komplett voll
                      Downgrade:
                      cd /opt/iobroker
                      iobroker install javascript@5.7.0
                      T 2 Antworten Letzte Antwort
                      • ArmilarA Armilar
                        @TT-Tom @Peet_b
                        @Peet_b
                        Downgrade:
                        cd /opt/iobroker
                        T
                        T
                        TT-Tom
                        #1137
                        iobroker upgrade javascript@5.7.0
                        Gruß Tom
                        Public Transport
                        • T TT-Tom
                          ArmilarA
                          ArmilarA
                          Armilar
                          #1138
                          • P Peet_b
                            @kuckuckmann
                            K
                            K
                            Kuckuckmann
                            #1139
                            @peet_b said in Sonoff NSPanel:
                            @kuckuckmann
                            Ich habe das Skript ebenfalls über CopyRaw gearde neu kopiert und eingefügt --> startet ohne Probleme.
                            Wenn ich mich recht erinnere war es noch wichtig, dass es in Global sein muss (was Du ja hast) und "IconsSelector" heißen muss (Key sensitiv). Hast Du das beachtet?
                            Zur Kontrolle: Check mal dass Dein Skript 6907 Zeilen hat und vergleich auch mal Anfang und Ende bei Dir mit dem Skript auf GitHub.
                            ArmilarA P 2 Antworten Letzte Antwort
                            • K Kuckuckmann
                              @kuckuckmann
                              ArmilarA
                              ArmilarA
                              Armilar
                              #1140
                              @kuckuckmann
                              Nee, ist nur einfacher wenn man über das gleiche spricht. Kannst die Datei auch Schneewittchen nennen.
                              Glückwunsch... mit dem letzten Raw bist du dann auf TFT 40 - v.3.3.0 😊
                              Wer das Upgrade von der 3.1.1 kommend macht, der sollte das komplette TS-Script ersetzen und dann die Variablen für Alexa, pageItems und den Config-Block wieder reinkopieren. Hat sich durch das Code-Refactoring auch etliches im oberen Teil verändert.
                              T K 2 Antworten Letzte Antwort
                              • ArmilarA Armilar
                                @TT-Tom @Peet_b
                                @Peet_b
                                Downgrade:
                                cd /opt/iobroker
                                T
                                T
                                TT-Tom
                                #1141
                                Downgrade:
                                cd /opt/iobroker
                                läuft mit 5.7.0 bei mir auch nicht.
                                Gruß Tom
                                Public Transport
                                • ArmilarA Armilar
                                  @kuckuckmann
                                  T
                                  T
                                  TT-Tom
                                  #1142
                                  im Script steht deine Alexa Nummer noch drin.
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    ArmilarA
                                    ArmilarA
                                    Armilar
                                    #1143
                                    Verstehe ich nicht. Lief doch alles bei dir. Funktioniert bei mir perfekt.
                                    Was funktioniert denn nicht? Die IconSelector oder das Skript?
                                    P.S: Alexa-Device steht wieder auf XXXX
                                    Nachtrag: Änderungen siehe https://forum.iobroker.net/post/849554
                                    Die ganzen Init's und createState's sind in der neuen Version in den unteren Teil gewandert...
                                    • K Kuckuckmann
                                      @kuckuckmann
                                      P
                                      P
                                      Peet_b
                                      #1144
                                      @kuckuckmann
                                      Das Skript ist Global und ich habe es auch mit den Namen "IconsSelector" und "icon_mapping" getestet, beides bringt das selbe Ergebnis. Auch die Version 5.7.0 hilft bei mir nicht, es passiert genau das gleiche wie mit der V6.0.0
                                      Kann vielleicht einfach ein Paket oder ein Programm fehlen? Wie gesagt, ich betreibe IoB per Proxmox auf einem Debian 11.
                                      • P Peet_b
                                        @kuckuckmann
                                        ArmilarA
                                        ArmilarA
                                        Armilar
                                        #1145
                                        @kuckuckmann
                                        Eigentlich sollte der Adapter alles mitbringen. Mit Promox kenne ich mich nicht aus. Wüsste auch nicht, was im Code so besonders anders wäre als vorher oder das es zu Problemen führen würde. Wie bereits erwähnt ist die icon_mapping.ts 4 Monate alt. Sollte also auch weiterhin laufen...
                                        H P 2 Antworten Letzte Antwort
                                        • ArmilarA Armilar
                                          @kuckuckmann
                                          K
                                          K
                                          Kuckuckmann
                                          #1146
                                          @armilar said in Sonoff NSPanel:
                                          Gibt es denn ein Changelog eine Vgl. Möglichkeit was sich zwischen den Versionen ändert?
                                          33.2k
                                          84.4k
