  4. Puppeteer: Screenshots PhantomJS Alternative
    apollon77A
screenshotsheadlessbrowserpuppeteerphantomjsscreenshotwebsite
247 Beiträge 24 Kommentatoren 83.8k Aufrufe 18 Beobachtet
  • foxriver76F foxriver76
    @jojo182 Kannst du was zu deinem System sagen. Zeige mal alle Ausgaben:
    node -v
    nodejs -v
    cd /opt/iobroker
    npm ls
    J
    J
    jojo182
    #132
    @foxriver76
    Ist ein Raspberry Pi 4 mit (noch) buster.
    node -v
    v16.17.0
    nodejs -v
    v16.17.0
    cd /opt/iobroker
    npm ls
    iobroker.inst@3.0.0 /opt/iobroker
    ├── canvas@2.9.3
    ├── iobroker.admin@6.2.17
    ├── iobroker.backitup@2.4.12
    ├── iobroker.daswetter@3.1.4
    ├── iobroker.discovery@3.0.5
    ├── iobroker.echarts@1.0.12
    ├── iobroker.email@1.1.3
    ├── iobroker.energiefluss@1.0.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#0a734637f65acccbe761f460d06ecd1cb0731a96)
    ├── iobroker.flot@1.11.0
    ├── iobroker.fritzdect@2.2.3
    ├── iobroker.history@2.2.1
    ├── iobroker.homeconnect@1.0.1
    ├── iobroker.husq-automower@1.1.2 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#7a8ed7031d6e945544c0adbb05d82cc0f322f954)
    ├── iobroker.info@1.9.19
    ├── iobroker.jarvis@3.0.13
    ├── iobroker.javascript@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#9f30d43e14ff8e86d89860be50d1a4f4e15e2905)
    ├── iobroker.js-controller@4.0.23
    ├── iobroker.knx@1.0.45
    ├── iobroker.mihome-vacuum@3.6.0
    ├── iobroker.modbus@5.0.5
    ├── iobroker.mqtt@4.0.7
    ├── iobroker.node-red@3.3.1
    ├── iobroker.openknx@0.2.6
    ├── iobroker.openweathermap@0.3.0
    ├── iobroker.puppeteer@0.2.6
    ├── iobroker.pvforecast@2.3.0
    ├── iobroker.shuttercontrol@1.4.14
    ├── iobroker.simple-api@2.7.0
    ├── iobroker.smartmeter@3.3.4
    ├── iobroker.socketio@6.1.8
    ├── iobroker.sonoff@2.5.1
    ├── iobroker.sql@2.1.8
    ├── iobroker.stiebel-isg@1.7.5
    ├── iobroker.telegram@1.14.1
    ├── iobroker.text2command@2.2.2
    ├── iobroker.tr-064@4.2.16
    ├── iobroker.vis@1.4.15
    ├── iobroker.web@5.2.4
    ├── iobroker.ws@2.1.3
    ├── iobroker.yr@5.3.0
    ├── iobroker.zigbee@1.7.6
    └── puppeteer@16.2.0
    Javascript Adapter ist übrigens nur über github installiert weil ich gehofft hatte das Task Cancel Problem ist damit behoben.
    • J jojo182
      @foxriver76
      node -v
      v16.17.0
      nodejs -v
      v16.17.0
      cd /opt/iobroker
      npm ls
      ├── canvas@2.9.3
      foxriver76F
      foxriver76F
      foxriver76
      schrieb am zuletzt editiert von foxriver76
      #133
      @jojo182 Bitte noch
      Edit: sehe schon die Version all good
      Ich vermute es liegt an puppeteer@16.2.0, der Adapter installiert eigentlich ^13.7.0 und 16 ist nicht kompatibel. Lösche die Version bitte manuell und dann reinstall des Adapters. Evtl. hast du puppeteer im Javascript Adapter hinterlegt, dann dort zusätzlich entfernen.
      Videotutorials & mehr
        @negalein Ja, ist die sauberste Lösung.
        NegaleinN
        NegaleinN
        Negalein
        #134
        @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
        läuft wieder :)
        ° Fixer ---> iob fix
        • J
          J
          jojo182
          schrieb am zuletzt editiert von jojo182
          #135
          @foxriver76 Hat leider nichts geholfen. Hab puppeteer@16.2.0 deinstalliert, Im JS Adapter das zusätzliche puppeteer modul entfernt und JS neu gestartet und dann deinen Adapter einmal komplett entfernt und neu installiert. Trotzdem die gleiche Fehlermeldung wie oben gepostet.
          Edit: Was mir noch aufgefallen ist: Wenn ich im JS Adapter wieder puppeteer reinnehme und den Adapter neu starte, erscheint im Log folgendes:
          javascript.0
          	2022-08-22 12:33:04.583	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          javascript.0
          	2022-08-22 12:33:04.580	error	npm
          javascript.0
          	2022-08-22 12:33:04.496	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
          javascript.0
          	2022-08-22 12:33:04.494	error	npm
          javascript.0
          	2022-08-22 12:33:04.325	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
          javascript.0
          	2022-08-22 12:33:04.322	error	npm
          javascript.0
          	2022-08-22 12:33:04.069	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
          javascript.0
          	2022-08-22 12:33:04.067	error	npm
          javascript.0
          	2022-08-22 12:32:58.082	info	npm install puppeteer --omit=dev (System call)
          Das erscheint nur mit aktiviertem puppeteer modul. Keine Ahnung ob das was damit zu tun hat.
          • J jojo182
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            foxriver76F
            foxriver76F
            foxriver76
            #136
            @jojo182 zeig jetzt mal
            cd /opt/iobroker
            npm ls -la
              cd /opt/iobroker
              npm ls -la
              J
              J
              jojo182
              #137
              @foxriver76
              $ cd /opt/iobroker
              $ npm ls -la
              npm ERR! Cannot read properties of undefined (reading 'description')
              npm ERR!     /home/iobroker/.npm/_logs/2022-08-22T11_13_22_947Z-debug-0.log
              $ cat /home/iobroker/.npm/_logs/2022-08-22T11_13_22_947Z-debug-0.log
              0 verbose cli /usr/bin/node /usr/bin/npm
              1 info using npm@8.15.0
              2 info using node@v16.17.0
              3 timing npm:load:whichnode Completed in 1ms
              4 timing config:load:defaults Completed in 6ms
              5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
              6 timing config:load:builtin Completed in 4ms
              7 timing config:load:cli Completed in 16ms
              8 timing config:load:env Completed in 1ms
              9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
              10 timing config:load:project Completed in 6ms
              11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
              12 timing config:load:user Completed in 1ms
              13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
              14 timing config:load:global Completed in 0ms
              15 timing config:load:validate Completed in 1ms
              16 timing config:load:credentials Completed in 3ms
              17 timing config:load:setEnvs Completed in 3ms
              18 timing config:load Completed in 43ms
              19 timing npm:load:configload Completed in 44ms
              20 timing npm:load:mkdirpcache Completed in 10ms
              21 timing npm:load:mkdirplogs Completed in 2ms
              22 verbose title npm ls
              23 verbose argv "ls" "--long" "--all"
              24 timing npm:load:setTitle Completed in 4ms
              25 timing config:load:flatten Completed in 11ms
              26 timing npm:load:display Completed in 16ms
              27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
              28 verbose logfile /home/iobroker/.npm/_logs/2022-08-22T11_13_22_947Z-debug-0.log
              29 timing npm:load:logFile Completed in 17ms
              30 timing npm:load:timers Completed in 1ms
              31 timing npm:load:configScope Completed in 1ms
              32 timing npm:load Completed in 96ms
              33 timing arborist:ctor Completed in 3ms
              34 silly logfile start cleaning logs, removing 1 files
              35 silly logfile done cleaning log files
              36 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.puppeteer
              37 timing command:ls Completed in 5787ms
              38 verbose stack TypeError: Cannot read properties of undefined (reading 'description')
              38 verbose stack     at getHumanOutputItem (/usr/lib/node_modules/npm/lib/commands/ls.js:334:35)
              38 verbose stack     at visit (/usr/lib/node_modules/npm/lib/commands/ls.js:160:15)
              38 verbose stack     at visitNode (/usr/lib/node_modules/npm/node_modules/treeverse/lib/breadth.js:37:25)
              38 verbose stack     at next (/usr/lib/node_modules/npm/node_modules/treeverse/lib/breadth.js:23:19)
              38 verbose stack     at /usr/lib/node_modules/npm/node_modules/treeverse/lib/breadth.js:25:31
              38 verbose stack     at processTicksAndRejections (node:internal/process/task_queues:96:5)
              38 verbose stack     at async LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:122:20)
              38 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
              39 verbose cwd /opt/iobroker
              40 verbose Linux 5.10.103-v7l+
              41 verbose node v16.17.0
              42 verbose npm  v8.15.0
              43 error Cannot read properties of undefined (reading 'description')
              44 verbose exit 1
              45 timing npm Completed in 6097ms
              46 verbose code 1
              47 error A complete log of this run can be found in:
              47 error     /home/iobroker/.npm/_logs/2022-08-22T11_13_22_947Z-debug-0.log
              • J jojo182
                @foxriver76
                $ cd /opt/iobroker
                $ npm ls -la
                44 verbose exit 1
                46 verbose code 1
                Thomas BraunT
                Thomas BraunT
                #138
                @jojo182
                cd /opt/iobroker
                npm ls
                war vermutlich gemeint.
                  @jojo182
                  cd /opt/iobroker
                  npm ls
                  J
                  J
                  jojo182
                  #139
                  $ npm ls
                  ├── @types/caseless@0.12.2 extraneous
                  ├── @types/request@2.48.8 extraneous
                  ├── @types/tough-cookie@4.0.2 extraneous
                  ├── canvas@2.9.3
                  ├── coffeescript@1.12.7 extraneous
                  ├── node-inspect@2.0.0 extraneous
                  ├── picocolors@1.0.0 extraneous
                  ├── setimmediate@1.0.5 extraneous
                  ├── virtual-tsc@0.6.2 extraneous
                  └── wake_on_lan@1.0.0 extraneous
                  • J jojo182
                    $ npm ls
                    ├── canvas@2.9.3
                    foxriver76F
                    foxriver76F
                    foxriver76
                    #140
                    @jojo182 Komisch, dass er nur top level zeigt
                    cd /opt/iobroker
                    npm ls --depth=4
                    J Thomas BraunT 2 Antworten Letzte Antwort
                      cd /opt/iobroker
                      npm ls --depth=4
                      J
                      J
                      jojo182
                      #141
                      @foxriver76 Jetzt kommt ein haufen Zeugs:
                      $ npm ls --depth=4
                      ├─┬ @types/request@2.48.8 extraneous
                      │ ├── @types/caseless@0.12.2 deduped
                      │ ├── @types/node@18.6.3
                      │ ├── @types/tough-cookie@4.0.2 deduped
                      │ └─┬ form-data@2.5.1 extraneous
                      │   ├── asynckit@0.4.0
                      │   ├─┬ combined-stream@1.0.8
                      │   │ └── delayed-stream@1.0.0
                      │   └─┬ mime-types@2.1.30
                      │     └── mime-db@1.47.0
                      ├─┬ canvas@2.9.3
                      │ ├─┬ @mapbox/node-pre-gyp@1.0.9
                      │ │ ├── detect-libc@2.0.1
                      │ │ ├─┬ https-proxy-agent@5.0.0
                      │ │ │ ├─┬ agent-base@6.0.2
                      │ │ │ │ └── debug@4.3.1
                      │ │ │ └─┬ debug@4.3.1
                      │ │ │   └── ms@2.1.2
                      │ │ ├─┬ make-dir@3.1.0
                      │ │ │ └── semver@6.3.0
                      │ │ ├─┬ node-fetch@2.6.7
                      │ │ │ ├─┬ encoding@0.1.13
                      │ │ │ │ └── iconv-lite@0.6.3
                      │ │ │ └─┬ whatwg-url@5.0.0
                      │ │ │   ├── tr46@0.0.3
                      │ │ │   └── webidl-conversions@3.0.1
                      │ │ ├─┬ nopt@5.0.0
                      │ │ │ └── abbrev@1.1.1
                      │ │ ├─┬ npmlog@5.0.1
                      │ │ │ ├─┬ are-we-there-yet@2.0.0
                      │ │ │ │ ├── delegates@1.0.0
                      │ │ │ │ └── readable-stream@3.6.0
                      │ │ │ ├── console-control-strings@1.1.0
                      │ │ │ ├─┬ gauge@3.0.2
                      │ │ │ │ ├── aproba@1.2.0
                      │ │ │ │ ├── color-support@1.1.3
                      │ │ │ │ ├── console-control-strings@1.1.0 deduped
                      │ │ │ │ ├── has-unicode@2.0.1
                      │ │ │ │ ├── object-assign@4.1.1 deduped
                      │ │ │ │ ├── signal-exit@3.0.7
                      │ │ │ │ ├── string-width@4.2.3
                      │ │ │ │ ├── strip-ansi@6.0.1
                      │ │ │ │ └── wide-align@1.1.5
                      │ │ │ └── set-blocking@2.0.0
                      │ │ ├─┬ rimraf@3.0.2
                      │ │ │ └─┬ glob@7.1.6
                      │ │ │   ├── fs.realpath@1.0.0
                      │ │ │   ├── inflight@1.0.6
                      │ │ │   ├── inherits@2.0.3 deduped
                      │ │ │   ├── minimatch@3.0.4
                      │ │ │   ├── once@1.4.0 deduped
                      │ │ │   └── path-is-absolute@1.0.1
                      │ │ ├── semver@7.3.5 deduped
                      │ │ └── tar@6.1.11 deduped
                      │ ├── nan@2.16.0
                      │ └─┬ simple-get@3.1.0
                      │   ├─┬ decompress-response@4.2.1
                      │   │ └── mimic-response@2.1.0
                      │   ├─┬ once@1.4.0
                      │   │ └── wrappy@1.0.2
                      │   └── simple-concat@1.0.1
                      ├─┬ iobroker.admin@6.2.17
                      │ ├─┬ @iobroker/adapter-core@2.6.0
                      │ │ └─┬ @types/iobroker@4.0.2
                      │ │   └── @types/node@18.6.3 deduped
                      │ ├─┬ @iobroker/socket-classes@0.5.2
                      │ │ ├── axios@0.27.2 deduped
                      │ │ ├── cookie-parser@1.4.6 deduped
                      │ │ └── passport@0.6.0 deduped
                      │ ├─┬ @iobroker/ws-server@2.1.0
                      │ │ └── ws@8.8.1 deduped
                      │ ├─┬ axios@0.27.2
                      │ │ ├── follow-redirects@1.14.9
                      │ │ └─┬ form-data@4.0.0
                      │ │   ├── asynckit@0.4.0 deduped
                      │ │   ├── combined-stream@1.0.8 deduped
                      │ │   └── mime-types@2.1.30 deduped
                      │ ├─┬ body-parser@1.20.0
                      │ │ ├── bytes@3.1.2
                      │ │ ├── content-type@1.0.4
                      │ │ ├─┬ debug@2.6.9
                      │ │ │ └── ms@2.0.0
                      │ │ ├── depd@2.0.0
                      │ │ ├── destroy@1.2.0
                      │ │ ├─┬ http-errors@2.0.0
                      │ │ │ ├── depd@2.0.0 deduped
                      │ │ │ ├── inherits@2.0.4
                      │ │ │ ├── setprototypeof@1.2.0 deduped
                      │ │ │ ├── statuses@2.0.1 deduped
                      │ │ │ └── toidentifier@1.0.1
                      │ │ ├─┬ iconv-lite@0.4.24
                      │ │ │ └── safer-buffer@2.1.2
                      │ │ ├─┬ on-finished@2.4.1
                      │ │ │ └── ee-first@1.1.1
                      │ │ ├── qs@6.10.3 deduped
                      │ │ ├─┬ raw-body@2.5.1
                      │ │ │ ├── bytes@3.1.2 deduped
                      │ │ │ ├── http-errors@2.0.0 deduped
                      │ │ │ ├── iconv-lite@0.4.24 deduped
                      │ │ │ └── unpipe@1.0.0 deduped
                      │ │ ├─┬ type-is@1.6.18
                      │ │ │ ├── media-typer@0.3.0
                      │ │ │ └── mime-types@2.1.30 deduped
                      │ ├─┬ compression@1.7.4
                      │ │ ├─┬ accepts@1.3.7
                      │ │ │ ├── mime-types@2.1.30 deduped
                      │ │ │ └── negotiator@0.6.2
                      │ │ ├── bytes@3.0.0
                      │ │ ├─┬ compressible@2.0.18
                      │ │ │ └── mime-db@1.47.0 deduped
                      │ │ ├── debug@2.6.9 deduped
                      │ │ ├── on-headers@1.0.2
                      │ │ ├── safe-buffer@5.1.2
                      │ │ └── vary@1.1.2
                      │ ├── connect-flash@0.1.1
                      │ ├─┬ cookie-parser@1.4.6
                      │ │ ├── cookie-signature@1.0.6
                      │ │ └── cookie@0.4.1
                      │ ├─┬ express-fileupload@1.4.0
                      │ │ └─┬ busboy@1.6.0
                      │ │   └── streamsearch@1.1.0
                      │ ├─┬ express-session@1.17.3
                      │ │ ├── cookie-signature@1.0.6 deduped
                      │ │ ├── cookie@0.4.2
                      │ │ ├── on-headers@1.0.2 deduped
                      │ │ ├── parseurl@1.3.3
                      │ │ ├── safe-buffer@5.2.1
                      │ │ └─┬ uid-safe@2.1.5
                      │ │   └── random-bytes@1.0.0
                      │ ├─┬ express@4.18.1
                      │ │ ├─┬ accepts@1.3.8
                      │ │ │ ├─┬ mime-types@2.1.35
                      │ │ │ │ └── mime-db@1.52.0
                      │ │ │ └── negotiator@0.6.3
                      │ │ ├── array-flatten@1.1.1
                      │ │ ├── body-parser@1.20.0 deduped
                      │ │ ├─┬ content-disposition@0.5.4
                      │ │ │ └── safe-buffer@5.2.1
                      │ │ ├── content-type@1.0.4 deduped
                      │ │ ├── cookie@0.5.0
                      │ │ ├── encodeurl@1.0.2
                      │ │ ├── escape-html@1.0.3
                      │ │ ├── etag@1.8.1
                      │ │ ├─┬ finalhandler@1.2.0
                      │ │ │ ├── debug@2.6.9 deduped
                      │ │ │ ├── encodeurl@1.0.2 deduped
                      │ │ │ ├── escape-html@1.0.3 deduped
                      │ │ │ ├── on-finished@2.4.1 deduped
                      │ │ │ ├── parseurl@1.3.3 deduped
                      │ │ ├── fresh@0.5.2
                      │ │ ├── merge-descriptors@1.0.1
                      │ │ ├── methods@1.1.2
                      │ │ ├── path-to-regexp@0.1.7
                      │ │ ├─┬ proxy-addr@2.0.7
                      │ │ │ ├── forwarded@0.2.0
                      │ │ │ └── ipaddr.js@1.9.1
                      │ │ ├── range-parser@1.2.1
                      │ │ ├── safe-buffer@5.2.1 deduped
                      │ │ ├─┬ send@0.18.0
                      │ │ │ ├── destroy@1.2.0 deduped
                      │ │ │ ├── etag@1.8.1 deduped
                      │ │ │ ├── fresh@0.5.2 deduped
                      │ │ │ ├── mime@1.6.0
                      │ │ │ ├── ms@2.1.3
                      │ │ │ ├── range-parser@1.2.1 deduped
                      │ │ │ └── statuses@2.0.1 deduped
                      │ │ ├─┬ serve-static@1.15.0
                      │ │ │ └── send@0.18.0 deduped
                      │ │ ├── type-is@1.6.18 deduped
                      │ │ ├── utils-merge@1.0.1
                      │ │ └── vary@1.1.2 deduped
                      │ ├── mime@3.0.0
                      │ ├─┬ passport-local@1.0.0
                      │ │ └── passport-strategy@1.0.0
                      │ ├─┬ passport@0.6.0
                      │ │ ├── passport-strategy@1.0.0 deduped
                      │ │ ├── pause@0.0.1
                      │ │ └── utils-merge@1.0.1 deduped
                      │ ├─┬ semver@7.3.7
                      │ │ └─┬ lru-cache@6.0.0
                      │ │   └── yallist@4.0.0 deduped
                      │ └─┬ ws@8.8.1
                      │   ├── UNMET OPTIONAL DEPENDENCY bufferutil@^4.0.1
                      │   └── UNMET OPTIONAL DEPENDENCY utf-8-validate@^5.0.2
                      ├─┬ iobroker.backitup@2.4.12
                      │ ├─┬ @googleapis/drive@3.0.1
                      │ │ └─┬ googleapis-common@5.1.0
                      │ │   ├── extend@3.0.2 deduped
                      │ │   ├─┬ gaxios@4.3.3
                      │ │   │ ├── abort-controller@3.0.0
                      │ │   │ ├── extend@3.0.2 deduped
                      │ │   │ ├── https-proxy-agent@5.0.0 deduped
                      │ │   │ ├── is-stream@2.0.0 deduped
                      │ │   │ └── node-fetch@2.6.7 deduped
                      │ │   ├─┬ google-auth-library@7.14.1
                      │ │   │ ├── arrify@2.0.1 deduped
                      │ │   │ ├── base64-js@1.5.1 deduped
                      │ │   │ ├── ecdsa-sig-formatter@1.0.11 deduped
                      │ │   │ ├── fast-text-encoding@1.0.3 deduped
                      │ │   │ ├── gaxios@4.3.3 deduped
                      │ │   │ ├── gcp-metadata@4.3.1
                      │ │   │ ├── gtoken@5.3.2
                      │ │   │ ├── jws@4.0.0 deduped
                      │ │   │ └── lru-cache@6.0.0 deduped
                      │ │   ├── url-template@2.0.8
                      │ │   └── uuid@8.3.2
                      │ ├── @iobroker/adapter-core@2.6.0 deduped
                      │ ├─┬ axios@0.27.2
                      │ │ ├── follow-redirects@1.14.9 deduped
                      │ ├─┬ dropbox-v2-api@2.5.4
                      │ │ └── request@2.88.2 deduped
                      │ │ ├── array-flatten@1.1.1 deduped
                      │ │ ├─┬ body-parser@1.20.0
                      │ │ │ ├── content-type@1.0.4 deduped
                      │ │ │ ├── qs@6.10.3 deduped
                      │ │ │ ├─┬ raw-body@2.5.1
                      │ │ │ │ ├── bytes@3.1.2 deduped
                      │ │ │ │ ├── http-errors@2.0.0 deduped
                      │ │ │ │ ├── iconv-lite@0.4.24 deduped
                      │ │ │ │ └── unpipe@1.0.0 deduped
                      │ │ │ ├── type-is@1.6.18 deduped
                      │ │ ├── content-disposition@0.5.4 deduped
                      │ │ ├── depd@2.0.0
                      │ │ │ └── toidentifier@1.0.1 deduped
                      │ │ ├── merge-descriptors@1.0.1 deduped
                      │ │ ├── methods@1.1.2 deduped
                      │ │ │ └── ee-first@1.1.1 deduped
                      │ │ ├── path-to-regexp@0.1.7 deduped
                      │ │ ├── proxy-addr@2.0.7 deduped
                      │ │ ├─┬ send@0.18.0
                      │ │ │ ├── mime@1.6.0 deduped
                      │ │ │ ├── ms@2.1.3
                      │ │ ├── utils-merge@1.0.1 deduped
                      │ ├─┬ fs-extra@10.1.0
                      │ │ ├── graceful-fs@4.2.6
                      │ │ ├─┬ jsonfile@6.1.0
                      │ │ │ ├── graceful-fs@4.2.6 deduped
                      │ │ │ └── universalify@2.0.0 deduped
                      │ ├─┬ ftp@0.3.10
                      │ │ ├─┬ readable-stream@1.1.14
                      │ │ │ ├── core-util-is@1.0.2
                      │ │ │ ├── isarray@0.0.1
                      │ │ │ └── string_decoder@0.10.31
                      │ │ └── xregexp@2.0.0
                      │ ├─┬ google-auth-library@8.1.1
                      │ │ ├─┬ ecdsa-sig-formatter@1.0.11
                      │ │ │ └── safe-buffer@5.1.2 deduped
                      │ │ ├─┬ gaxios@5.0.1
                      │ │ ├─┬ gcp-metadata@5.0.0
                      │ │ │ ├── gaxios@5.0.1 deduped
                      │ │ │ └─┬ json-bigint@1.0.0
                      │ │ │   └── bignumber.js@9.0.2
                      │ │ ├─┬ gtoken@6.1.0
                      │ │ │ ├─┬ gaxios@4.3.3
                      │ │ │ │ ├── abort-controller@3.0.0 deduped
                      │ │ │ │ ├── extend@3.0.2 deduped
                      │ │ │ │ ├── https-proxy-agent@5.0.0 deduped
                      │ │ │ │ ├── is-stream@2.0.0 deduped
                      │ │ │ │ └── node-fetch@2.6.7 deduped
                      │ │ │ ├─┬ google-p12-pem@4.0.0
                      │ │ │ │ └── node-forge@1.3.1 deduped
                      │ │ │ └── jws@4.0.0 deduped
                      │ │ ├─┬ jws@4.0.0
                      │ │ │ ├─┬ jwa@2.0.0
                      │ │ │ │ ├── buffer-equal-constant-time@1.0.1
                      │ │ │ │ ├── ecdsa-sig-formatter@1.0.11 deduped
                      │ │ │ │ └── safe-buffer@5.1.2 deduped
                      │ ├─┬ node-schedule@2.1.0
                      │ │ ├─┬ cron-parser@3.5.0
                      │ │ │ ├─┬ is-nan@1.3.2
                      │ │ │ │ ├── call-bind@1.0.2 deduped
                      │ │ │ │ └── define-properties@1.1.3 deduped
                      │ │ │ └── luxon@1.27.0 deduped
                      │ │ ├── long-timeout@0.1.1
                      │ │ └── sorted-array-functions@1.3.0
                      │ ├── node-wol@0.1.1
                      │ ├─┬ request@2.88.2
                      │ │ ├── aws-sign2@0.7.0
                      │ │ ├── aws4@1.11.0
                      │ │ ├── caseless@0.12.0
                      │ │ ├── forever-agent@0.6.1
                      │ │ ├─┬ form-data@2.3.3
                      │ │ │ ├── asynckit@0.4.0 deduped
                      │ │ │ ├── combined-stream@1.0.8 deduped
                      │ │ ├─┬ har-validator@5.1.5
                      │ │ │ ├─┬ ajv@6.12.6
                      │ │ │ │ ├── fast-deep-equal@3.1.3 deduped
                      │ │ │ │ ├── fast-json-stable-stringify@2.1.0
                      │ │ │ │ ├── json-schema-traverse@0.4.1
                      │ │ │ │ └── uri-js@4.4.1
                      │ │ │ └── har-schema@2.0.0
                      │ │ ├─┬ http-signature@1.2.0
                      │ │ │ ├── assert-plus@1.0.0
                      │ │ │ ├─┬ jsprim@1.4.1
                      │ │ │ │ ├── assert-plus@1.0.0 deduped
                      │ │ │ │ ├── extsprintf@1.3.0
                      │ │ │ │ ├── json-schema@0.2.3
                      │ │ │ │ └── verror@1.10.0
                      │ │ │ └─┬ sshpk@1.16.1
                      │ │ │   ├── asn1@0.2.4
                      │ │ │   ├── bcrypt-pbkdf@1.0.2
                      │ │ │   ├── dashdash@1.14.1
                      │ │ │   ├── ecc-jsbn@0.1.2
                      │ │ │   ├── getpass@0.1.7
                      │ │ │   ├── jsbn@0.1.1
                      │ │ │   ├── safer-buffer@2.1.2 deduped
                      │ │ │   └── tweetnacl@0.14.5
                      │ │ ├── is-typedarray@1.0.0
                      │ │ ├── isstream@0.1.2
                      │ │ ├── json-stringify-safe@5.0.1
                      │ │ ├── oauth-sign@0.9.0
                      │ │ ├── performance-now@2.1.0
                      │ │ ├── qs@6.5.2
                      │ │ ├── safe-buffer@5.1.2 deduped
                      │ │ ├─┬ tough-cookie@2.5.0
                      │ │ │ ├── psl@1.8.0 deduped
                      │ │ │ └── punycode@2.1.1 deduped
                      │ │ ├─┬ tunnel-agent@0.6.0
                      │ │ └── uuid@3.4.0
                      │ ├─┬ tar-fs@2.1.1
                      │ │ ├── chownr@1.1.4
                      │ │ ├── mkdirp-classic@0.5.3
                      │ │ ├─┬ pump@3.0.0
                      │ │ │ ├─┬ end-of-stream@1.4.4
                      │ │ │ │ └── once@1.4.0 deduped
                      │ │ └─┬ tar-stream@2.2.0
                      │ │   ├─┬ bl@4.1.0
                      │ │   │ ├── buffer@5.7.1
                      │ │   ├── end-of-stream@1.4.4 deduped
                      │ │   ├── fs-constants@1.0.0
                      │ │   └─┬ readable-stream@3.6.0
                      │ │     ├── string_decoder@1.3.0
                      │ │     └── util-deprecate@1.0.2 deduped
                      │ └─┬ webdav@4.10.0
                      │   ├─┬ axios@0.27.2
                      │   ├── base-64@1.0.0
                      │   ├── byte-length@1.0.2
                      │   ├─┬ fast-xml-parser@3.21.1
                      │   │ └── strnum@1.0.5
                      │   ├── he@1.2.0
                      │   ├── hot-patcher@0.5.0
                      │   ├── layerr@0.1.2
                      │   ├─┬ md5@2.3.0
                      │   │ ├── charenc@0.0.2
                      │   │ ├── crypt@0.0.2
                      │   │ └── is-buffer@1.1.6
                      │   ├─┬ minimatch@5.1.0
                      │   │ └─┬ brace-expansion@2.0.1
                      │   │   └── balanced-match@1.0.2
                      │   ├── nested-property@4.0.0
                      │   ├── path-posix@1.0.0
                      │   ├── url-join@4.0.1
                      │   └─┬ url-parse@1.5.10
                      │     ├── querystringify@2.2.0
                      │     └── requires-port@1.0.0
                      ├─┬ iobroker.daswetter@3.1.4
                      │ ├─┬ axios@0.27.2
                      │ └── xml2json-light@1.0.6
                      ├─┬ iobroker.discovery@3.0.5
                      │ ├─┬ mdns-discovery@0.2.6
                      │ │ ├─┬ debug@2.2.0
                      │ │ │ └── ms@0.7.1
                      │ │ ├── dgram@1.0.1
                      │ │ └─┬ dns-packet@1.3.4
                      │ │   ├── ip@1.1.5 deduped
                      │ ├── netmask@2.0.2
                      │ ├── node-mndp@0.0.3
                      │ ├─┬ node-ssdp@4.0.1
                      │ │ ├─┬ async@2.6.4
                      │ │ │ └── lodash@4.17.21
                      │ │ ├── bluebird@3.7.2
                      │ │ ├─┬ debug@3.2.7
                      │ │ │ └── ms@2.1.3
                      │ │ └── ip@1.1.5 deduped
                      │ └─┬ serialport@10.4.0
                      │   ├─┬ @serialport/binding-mock@10.2.2
                      │   │ ├── @serialport/bindings-interface@1.2.1
                      │   │ └── debug@4.3.3 deduped
                      │   ├─┬ @serialport/bindings-cpp@10.7.0
                      │   │ ├── @serialport/bindings-interface@1.2.1 deduped
                      │   │ ├─┬ @serialport/parser-readline@10.3.0
                      │   │ │ └── @serialport/parser-delimiter@10.3.0
                      │   │ ├─┬ debug@4.3.3
                      │   │ │ └── ms@2.1.2
                      │   │ ├── node-addon-api@4.3.0 deduped
                      │   │ └── node-gyp-build@4.3.0
                      │   ├── @serialport/parser-byte-length@10.3.0
                      │   ├── @serialport/parser-cctalk@10.3.0
                      │   ├── @serialport/parser-delimiter@10.3.0
                      │   ├── @serialport/parser-inter-byte-timeout@10.3.0
                      │   ├── @serialport/parser-packet-length@10.3.0
                      │   │ └── @serialport/parser-delimiter@10.3.0 deduped
                      │   ├── @serialport/parser-ready@10.3.0
                      │   ├── @serialport/parser-regex@10.3.0
                      │   ├── @serialport/parser-slip-encoder@10.3.0
                      │   ├── @serialport/parser-spacepacket@10.3.0
                      │   ├─┬ @serialport/stream@10.3.0
                      │   └─┬ debug@4.3.3
                      │     └── ms@2.1.2
                      ├─┬ iobroker.echarts@1.0.12
                      │ ├── canvas@2.9.3 deduped
                      │ ├─┬ echarts@5.3.3
                      │ │ ├── tslib@2.3.0
                      │ │ └─┬ zrender@5.3.2
                      │ │   └── tslib@2.3.0
                      │ ├─┬ jsdom@19.0.0
                      │ │ ├── abab@2.0.6
                      │ │ ├─┬ acorn-globals@6.0.0
                      │ │ │ ├── acorn-walk@7.2.0
                      │ │ │ └── acorn@7.4.1
                      │ │ ├── acorn@8.7.1
                      │ │ ├── canvas@2.9.3 deduped
                      │ │ ├── cssom@0.5.0
                      │ │ ├─┬ cssstyle@2.3.0
                      │ │ │ └── cssom@0.3.8
                      │ │ ├─┬ data-urls@3.0.2
                      │ │ │ ├── abab@2.0.6 deduped
                      │ │ │ ├── whatwg-mimetype@3.0.0 deduped
                      │ │ │ └─┬ whatwg-url@11.0.0
                      │ │ │   ├── tr46@3.0.0 deduped
                      │ │ │   └── webidl-conversions@7.0.0 deduped
                      │ │ ├── decimal.js@10.3.1
                      │ │ ├─┬ domexception@4.0.0
                      │ │ ├─┬ escodegen@2.0.0
                      │ │ │ ├── esprima@4.0.1
                      │ │ │ ├── estraverse@5.3.0
                      │ │ │ ├── esutils@2.0.3
                      │ │ │ ├─┬ optionator@0.8.3
                      │ │ │ │ ├── deep-is@0.1.4
                      │ │ │ │ ├── fast-levenshtein@2.0.6
                      │ │ │ │ ├── levn@0.3.0
                      │ │ │ │ ├── prelude-ls@1.1.2
                      │ │ │ │ ├── type-check@0.3.2
                      │ │ │ │ └── word-wrap@1.2.3
                      │ │ │ └── source-map@0.6.1 deduped
                      │ │ ├─┬ form-data@4.0.0
                      │ │ ├─┬ html-encoding-sniffer@3.0.0
                      │ │ │ └── whatwg-encoding@2.0.0 deduped
                      │ │ ├─┬ http-proxy-agent@5.0.0
                      │ │ │ ├── @tootallnate/once@2.0.0
                      │ │ │ ├── agent-base@6.0.2 deduped
                      │ │ │ └─┬ debug@4.3.4
                      │ │ │   └── ms@2.1.2
                      │ │ ├── is-potential-custom-element-name@1.0.1
                      │ │ ├── nwsapi@2.2.0
                      │ │ ├── parse5@6.0.1
                      │ │ ├─┬ saxes@5.0.1
                      │ │ │ └── xmlchars@2.2.0
                      │ │ ├── symbol-tree@3.2.4
                      │ │ ├─┬ tough-cookie@4.0.0
                      │ │ │ ├── punycode@2.1.1 deduped
                      │ │ │ └── universalify@0.1.2
                      │ │ ├─┬ w3c-hr-time@1.0.2
                      │ │ │ └── browser-process-hrtime@1.0.0
                      │ │ ├─┬ w3c-xmlserializer@3.0.0
                      │ │ │ └── xml-name-validator@4.0.0 deduped
                      │ │ ├── webidl-conversions@7.0.0
                      │ │ ├─┬ whatwg-encoding@2.0.0
                      │ │ │ └─┬ iconv-lite@0.6.3
                      │ │ │   └── safer-buffer@2.1.2 deduped
                      │ │ ├─┬ whatwg-url@10.0.0
                      │ │ │ ├─┬ tr46@3.0.0
                      │ │ │ │ └── punycode@2.1.1 deduped
                      │ │ ├── ws@8.8.1 deduped
                      │ └── moment@2.29.3
                      ├─┬ iobroker.email@1.1.3
                      │ └── nodemailer@6.7.5
                      ├─┬ iobroker.energiefluss@1.0.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#0a734637f65acccbe761f460d06ecd1cb0731a96)
                      │ └── canvas@2.9.3 deduped
                      ├─┬ iobroker.flot@1.11.0
                      │ └── @iobroker/adapter-core@2.6.0 deduped
                      ├─┬ iobroker.fritzdect@2.2.3
                      │ ├─┬ @iobroker/adapter-core@2.5.1
                      │ │ └─┬ @types/iobroker@3.3.4
                      │ ├─┬ command-line-args@5.2.0
                      │ │ ├── array-back@3.1.0
                      │ │ ├─┬ find-replace@3.0.0
                      │ │ │ └── array-back@3.1.0 deduped
                      │ │ ├── lodash.camelcase@4.3.0
                      │ │ └── typical@4.0.0
                      │ ├─┬ command-line-usage@6.1.1
                      │ │ ├── array-back@4.0.2
                      │ │ ├─┬ chalk@2.4.2
                      │ │ │ ├─┬ ansi-styles@3.2.1
                      │ │ │ │ └── color-convert@1.9.3
                      │ │ │ ├── escape-string-regexp@1.0.5
                      │ │ │ └─┬ supports-color@5.5.0
                      │ │ │   └── has-flag@3.0.0
                      │ │ ├─┬ table-layout@1.0.2
                      │ │ │ ├── array-back@4.0.2
                      │ │ │ ├── deep-extend@0.6.0
                      │ │ │ ├── typical@5.2.0
                      │ │ │ └─┬ wordwrapjs@4.0.1
                      │ │ │   ├── reduce-flatten@2.0.0
                      │ │ │   └── typical@5.2.0
                      │ └── xml2json-light@1.0.6 deduped
                      ├─┬ iobroker.history@2.2.1
                      ├─┬ iobroker.homeconnect@1.0.1
                      │ ├─┬ axios-rate-limit@1.3.0
                      │ │ └── axios@0.24.0 deduped
                      │ ├─┬ axios@0.26.1
                      │ │ └── follow-redirects@1.14.9
                      │ ├── eventsource@2.0.0
                      │ └─┬ qs@6.10.3
                      │   └─┬ side-channel@1.0.4
                      │     ├─┬ call-bind@1.0.2
                      │     │ ├── function-bind@1.1.1
                      │     │ └── get-intrinsic@1.1.1 deduped
                      │     ├─┬ get-intrinsic@1.1.1
                      │     │ ├── function-bind@1.1.1 deduped
                      │     │ ├── has-symbols@1.0.2
                      │     │ └── has@1.0.3 deduped
                      │     └── object-inspect@1.12.0
                      ├─┬ iobroker.husq-automower@1.1.2 (git+ssh://git@github.com/truegreyhound/ioBroker.husq-automower.git#7a8ed7031d6e945544c0adbb05d82cc0f322f954)
                      │ ├─┬ node-schedule@1.3.3
                      │ │ ├─┬ cron-parser@2.18.0
                      │ │ │ ├── is-nan@1.3.2 deduped
                      │ │ │ └─┬ moment-timezone@0.5.33
                      │ │ │   └── moment@2.29.1
                      │ │ ├── long-timeout@0.1.1 deduped
                      │ │ └── sorted-array-functions@1.3.0 deduped
                      ├─┬ iobroker.info@1.9.19
                      │ │ └─┬ @types/iobroker@4.0.1
                      │ ├─┬ axios@0.26.0
                      │ ├── jshashes@1.0.8
                      │ ├── UNMET OPTIONAL DEPENDENCY osx-temperature-sensor@^1.0.7
                      │ ├─┬ semver@7.3.5
                      │ └── systeminformation@5.11.6
                      ├─┬ iobroker.jarvis@3.0.13
                      │ ├─┬ got@11.8.5
                      │ │ ├── @sindresorhus/is@4.0.1
                      │ │ ├─┬ @szmarczak/http-timer@4.0.5
                      │ │ │ └── defer-to-connect@2.0.1
                      │ │ ├─┬ @types/cacheable-request@6.0.1
                      │ │ │ ├── @types/http-cache-semantics@4.0.0
                      │ │ │ ├─┬ @types/keyv@3.1.1
                      │ │ │ │ └── @types/node@18.6.3 deduped
                      │ │ │ ├── @types/node@18.6.3 deduped
                      │ │ │ └── @types/responselike@1.0.0 deduped
                      │ │ ├─┬ @types/responselike@1.0.0
                      │ │ ├── cacheable-lookup@5.0.4
                      │ │ ├─┬ cacheable-request@7.0.2
                      │ │ │ ├─┬ clone-response@1.0.2
                      │ │ │ │ └── mimic-response@1.0.1
                      │ │ │ ├─┬ get-stream@5.2.0
                      │ │ │ │ └── pump@3.0.0 deduped
                      │ │ │ ├── http-cache-semantics@4.1.0
                      │ │ │ ├─┬ keyv@4.0.3
                      │ │ │ │ └── json-buffer@3.0.1
                      │ │ │ ├── lowercase-keys@2.0.0 deduped
                      │ │ │ ├── normalize-url@6.1.0
                      │ │ │ └── responselike@2.0.0 deduped
                      │ │ ├─┬ decompress-response@6.0.0
                      │ │ │ └── mimic-response@3.1.0
                      │ │ ├─┬ http2-wrapper@1.0.3
                      │ │ │ ├── quick-lru@5.1.1
                      │ │ │ └── resolve-alpn@1.1.2
                      │ │ ├── p-cancelable@2.1.1
                      │ │ └─┬ responselike@2.0.0
                      │ │   └── lowercase-keys@2.0.0 deduped
                      │ ├── ip@1.1.5
                      │ ├── object-hash@2.2.0
                      │ ├── platform@1.3.6
                      │ ├─┬ socket.io@4.5.1
                      │ │ ├── accepts@1.3.7 deduped
                      │ │ ├── base64id@2.0.0
                      │ │ ├─┬ debug@4.3.4
                      │ │ │ └── ms@2.1.2
                      │ │ ├─┬ engine.io@6.2.0
                      │ │ │ ├── @types/cookie@0.4.1
                      │ │ │ ├── @types/cors@2.8.12
                      │ │ │ ├── accepts@1.3.7 deduped
                      │ │ │ ├── base64id@2.0.0 deduped
                      │ │ │ ├── cookie@0.4.1 deduped
                      │ │ │ ├─┬ cors@2.8.5
                      │ │ │ │ └── vary@1.1.2 deduped
                      │ │ │ ├── debug@4.3.4 deduped
                      │ │ │ ├── engine.io-parser@5.0.4
                      │ │ │ └─┬ ws@8.2.3
                      │ │ │   ├── UNMET OPTIONAL DEPENDENCY bufferutil@^4.0.1
                      │ │ │   └── UNMET OPTIONAL DEPENDENCY utf-8-validate@^5.0.2
                      │ │ ├── socket.io-adapter@2.4.0
                      │ │ └─┬ socket.io-parser@4.0.5
                      │ │   ├── @types/component-emitter@1.2.11
                      │ │   ├── component-emitter@1.3.0
                      │ │   └── debug@4.3.4 deduped
                      │ └── uuid@8.3.2
                      ├─┬ iobroker.javascript@6.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#9f30d43e14ff8e86d89860be50d1a4f4e15e2905)
                      │ │ └─┬ @types/iobroker@4.0.4
                      │ │   └── @types/node@16.11.52 deduped
                      │ ├── @types/node@16.11.52
                      │ ├─┬ @types/request@2.48.8
                      │ │ ├── @types/caseless@0.12.2
                      │ │ ├── @types/node@16.11.52 deduped
                      │ │ ├── @types/tough-cookie@4.0.2
                      │ │ └─┬ form-data@2.5.1
                      │ │   └── mime-types@2.1.35 deduped
                      │ ├── coffeescript@1.12.7
                      │ ├── jsonata@1.8.6
                      │ ├─┬ jszip@3.10.0
                      │ │ ├─┬ lie@3.3.0
                      │ │ │ └── immediate@3.0.6
                      │ │ ├── pako@1.0.11
                      │ │ ├─┬ readable-stream@2.3.7
                      │ │ │ ├── core-util-is@1.0.3
                      │ │ │ ├── isarray@1.0.0
                      │ │ │ ├── process-nextick-args@2.0.1
                      │ │ │ ├── safe-buffer@5.1.2 deduped
                      │ │ │ ├─┬ string_decoder@1.1.1
                      │ │ │ └── util-deprecate@1.0.2
                      │ │ └── setimmediate@1.0.5
                      │ ├── node-inspect@2.0.0
                      │ │ │ │ └── define-properties@1.1.4
                      │ │ │ └── luxon@1.28.0
                      │ ├─┬ puppeteer@16.2.0
                      │ │ ├─┬ cross-fetch@3.1.5
                      │ │ │ └─┬ node-fetch@2.6.7
                      │ │ │   ├── encoding@0.1.13 deduped
                      │ │ │   └── whatwg-url@5.0.0
                      │ │ ├─┬ debug@4.3.4
                      │ │ │ └── ms@2.1.2
                      │ │ ├── devtools-protocol@0.0.1019158
                      │ │ ├─┬ extract-zip@2.0.1
                      │ │ │ ├─┬ @types/yauzl@2.10.0
                      │ │ │ │ └── @types/node@16.11.52 deduped
                      │ │ │ └─┬ yauzl@2.10.0
                      │ │ │   ├── buffer-crc32@0.2.13
                      │ │ │   └── fd-slicer@1.1.0
                      │ │ ├─┬ https-proxy-agent@5.0.1
                      │ │ │ │ └── debug@4.3.4 deduped
                      │ │ ├── progress@2.0.3
                      │ │ ├── proxy-from-env@1.1.0
                      │ │ │ └─┬ glob@7.2.0
                      │ │ │   ├── inherits@2.0.4 deduped
                      │ │ │   ├── minimatch@3.1.2
                      │ │ ├─┬ tar-fs@2.1.1
                      │ │ │ ├── chownr@1.1.4
                      │ │ │ ├── mkdirp-classic@0.5.3
                      │ │ │ ├─┬ pump@3.0.0
                      │ │ │ │ ├── end-of-stream@1.4.4
                      │ │ │ └─┬ tar-stream@2.2.0
                      │ │ │   ├── bl@4.1.0
                      │ │ │   ├── end-of-stream@1.4.4 deduped
                      │ │ │   ├── fs-constants@1.0.0
                      │ │ ├─┬ unbzip2-stream@1.4.3
                      │ │ │ ├─┬ buffer@5.7.1
                      │ │ │ │ ├── base64-js@1.5.1
                      │ │ │ │ └── ieee754@1.2.1
                      │ │ │ └── through@2.3.8
                      │ │ └─┬ ws@8.8.1
                      │ │ ├── aws4@1.11.0
                      │ │ ├─┬ combined-stream@1.0.8
                      │ │ │ └── delayed-stream@1.0.0
                      │ │ │ └── mime-types@2.1.35 deduped
                      │ │ │ ├─┬ jsprim@1.4.2
                      │ │ │ │ ├── json-schema@0.4.0
                      │ │ │ └─┬ sshpk@1.17.0
                      │ │ │   ├── asn1@0.2.6
                      │ │ ├── qs@6.5.3
                      │ │ │ ├── psl@1.9.0
                      │ │ └── uuid@3.4.0
                      │ ├─┬ semver@7.3.7
                      │ ├── suncalc2@1.8.1
                      │ ├── typescript@4.7.4
                      │ ├─┬ virtual-tsc@0.6.2
                      │ │ ├── picocolors@1.0.0
                      │ │ └── typescript@4.7.4 deduped
                      │ └─┬ wake_on_lan@1.0.0
                      │   └── minimist@1.2.6
                      ├─┬ iobroker.js-controller@4.0.23
                      │ ├─┬ @alcalzone/esbuild-register@2.5.1-1
                      │ │ ├── esbuild@0.11.23
                      │ │ └── jsonc-parser@3.0.0
                      │ ├─┬ @iobroker/db-objects-file@4.0.23
                      │ │ ├─┬ @iobroker/db-base@4.0.23
                      │ │ │ ├── @iobroker/js-controller-common@4.0.23 deduped
                      │ │ │ ├── deep-clone@3.0.3 deduped
                      │ │ │ ├── fs-extra@10.0.0 deduped
                      │ │ │ └── respjs@4.2.0
                      │ │ ├── @iobroker/db-objects-redis@4.0.23 deduped
                      │ │ └── fs-extra@10.0.0 deduped
                      │ ├─┬ @iobroker/db-objects-jsonl@4.0.23
                      │ │ ├─┬ @alcalzone/jsonl-db@2.5.1
                      │ │ │ ├─┬ alcalzone-shared@4.0.1
                      │ │ │ └─┬ proper-lockfile@4.1.2
                      │ │ │   ├── retry@0.12.0
                      │ │ │   └── signal-exit@3.0.7 deduped
                      │ │ ├── @iobroker/db-base@4.0.23 deduped
                      │ │ ├── @iobroker/db-objects-file@4.0.23 deduped
                      │ ├─┬ @iobroker/db-objects-redis@4.0.23
                      │ │ ├─┬ ioredis@4.28.5
                      │ │ │ ├── cluster-key-slot@1.1.0
                      │ │ │ ├─┬ debug@4.3.4
                      │ │ │ │ └── ms@2.1.2
                      │ │ │ ├── denque@1.5.1
                      │ │ │ ├── lodash.defaults@4.2.0
                      │ │ │ ├── lodash.flatten@4.4.0
                      │ │ │ ├── lodash.isarguments@3.1.0
                      │ │ │ ├── p-map@2.1.0
                      │ │ │ ├── redis-commands@1.7.0
                      │ │ │ ├── redis-errors@1.2.0
                      │ │ │ ├─┬ redis-parser@3.0.0
                      │ │ │ │ └── redis-errors@1.2.0 deduped
                      │ │ │ └── standard-as-callback@2.1.0
                      │ │ ├─┬ node.extend@2.0.2
                      │ │ │ ├─┬ has@1.0.3
                      │ │ │ │ └── function-bind@1.1.1 deduped
                      │ │ │ └── is@3.3.0
                      │ │ └── semver@7.3.5 deduped
                      │ ├─┬ @iobroker/db-states-file@4.0.23
                      │ │ └── @iobroker/db-states-redis@4.0.23 deduped
                      │ ├─┬ @iobroker/db-states-jsonl@4.0.23
                      │ │ ├── @alcalzone/jsonl-db@2.5.1 deduped
                      │ │ ├── @iobroker/db-states-file@4.0.23 deduped
                      │ ├─┬ @iobroker/db-states-redis@4.0.23
                      │ │ └── ioredis@4.28.5 deduped
                      │ ├─┬ @iobroker/js-controller-adapter@4.0.23
                      │ │ ├─┬ @alcalzone/pak@0.7.0
                      │ │ │ ├─┬ axios@0.21.4
                      │ │ │ │ └── follow-redirects@1.14.9 deduped
                      │ │ │ ├─┬ execa@5.1.1
                      │ │ │ │ ├── cross-spawn@7.0.3
                      │ │ │ │ ├── get-stream@6.0.1
                      │ │ │ │ ├── human-signals@2.1.0
                      │ │ │ │ ├── merge-stream@2.0.0
                      │ │ │ │ ├── npm-run-path@4.0.1
                      │ │ │ │ ├── onetime@5.1.2
                      │ │ │ │ ├── signal-exit@3.0.7 deduped
                      │ │ │ │ └── strip-final-newline@2.0.0
                      │ │ │ └─┬ fs-extra@9.1.0
                      │ │ │   ├── at-least-node@1.0.0
                      │ │ │   ├── jsonfile@6.1.0 deduped
                      │ │ ├── @iobroker/db-objects-jsonl@4.0.23 deduped
                      │ │ ├── @iobroker/db-states-jsonl@4.0.23 deduped
                      │ │ ├── @iobroker/db-states-redis@4.0.23 deduped
                      │ │ ├── @iobroker/plugin-base@1.2.1 deduped
                      │ │ ├── @iobroker/plugin-sentry@1.2.0 deduped
                      │ │ ├── jsonwebtoken@8.5.1 deduped
                      │ │ ├── node-schedule@2.1.0 deduped
                      │ │ ├── node.extend@2.0.2 deduped
                      │ │ ├── pidusage@3.0.0 deduped
                      │ │ ├── readline@1.3.0
                      │ ├─┬ @iobroker/js-controller-cli@4.0.23
                      │ │ ├── @iobroker/js-controller-common-db@4.0.23 deduped
                      │ │ ├─┬ chokidar@3.5.3
                      │ │ │ ├─┬ anymatch@3.1.2
                      │ │ │ │ ├── normalize-path@3.0.0 deduped
                      │ │ │ │ └── picomatch@2.3.1
                      │ │ │ ├─┬ braces@3.0.2
                      │ │ │ │ └── fill-range@7.0.1
                      │ │ │ ├── UNMET OPTIONAL DEPENDENCY fsevents@~2.3.2
                      │ │ │ ├─┬ glob-parent@5.1.2
                      │ │ │ │ └── is-glob@4.0.3 deduped
                      │ │ │ ├─┬ is-binary-path@2.1.0
                      │ │ │ │ └── binary-extensions@2.2.0
                      │ │ │ ├─┬ is-glob@4.0.3
                      │ │ │ │ └── is-extglob@2.1.1
                      │ │ │ └─┬ readdirp@3.6.0
                      │ │ │   └── picomatch@2.3.1 deduped
                      │ │ ├── daemonize2@0.4.2 deduped
                      │ │ ├─┬ debug@4.3.4
                      │ │ │ └── ms@2.1.2
                      │ │ ├─┬ event-stream@4.0.1
                      │ │ │ ├── duplexer@0.1.2
                      │ │ │ ├── from@0.1.7
                      │ │ │ ├── map-stream@0.0.7
                      │ │ │ ├─┬ pause-stream@0.0.11
                      │ │ │ │ └── through@2.3.8 deduped
                      │ │ │ ├─┬ split@1.0.1
                      │ │ │ ├─┬ stream-combiner@0.2.2
                      │ │ │ │ ├── duplexer@0.1.2 deduped
                      │ │ └── readline-sync@1.4.10 deduped
                      │ ├─┬ @iobroker/js-controller-common-db@4.0.23
                      │ │ ├─┬ winston-seq-updated@1.0.4
                      │ │ │ ├── seq-logging@0.4.6
                      │ │ │ └─┬ winston-transport@4.5.0
                      │ │ │   ├── logform@2.4.0 deduped
                      │ │ │   ├── readable-stream@3.6.0
                      │ │ │   └── triple-beam@1.3.0 deduped
                      │ │ └─┬ winston-syslog@2.5.0
                      │ │   ├── glossy@0.1.7
                      │ │   ├─┬ unix-dgram@2.0.4
                      │ │   │ ├── bindings@1.5.0
                      │ │   │ └── nan@2.16.0 deduped
                      │ │   └── winston@3.7.2 deduped
                      │ ├─┬ @iobroker/js-controller-common@4.0.23
                      │ │ ├── @alcalzone/pak@0.7.0 deduped
                      │ │ ├─┬ @datalust/winston-seq@1.0.2
                      │ │ │ ├── seq-logging@1.1.1
                      │ │ │ ├── winston-transport@4.5.0 deduped
                      │ │ │ └── winston@3.7.2 deduped
                      │ │ ├─┬ axios@0.26.1
                      │ │ ├── ci-info@3.3.0
                      │ │ ├── event-stream@4.0.1 deduped
                      │ │ ├── node-forge@1.3.1
                      │ │ ├── promisify-child-process@4.1.1 deduped
                      │ │ ├── readline@1.3.0 deduped
                      │ │ ├── request@2.88.2 deduped
                      │ │ ├─┬ winston-daily-rotate-file@4.6.1
                      │ │ │ ├─┬ file-stream-rotator@0.6.1
                      │ │ │ │ └── moment@2.29.1 deduped
                      │ │ │ ├── object-hash@2.2.0 deduped
                      │ │ │ ├── triple-beam@1.3.0
                      │ │ ├── winston-syslog@2.5.0 deduped
                      │ │ └─┬ winston@3.7.2
                      │ │   ├─┬ @dabh/diagnostics@2.0.3
                      │ │   │ ├── colorspace@1.1.4
                      │ │   │ ├── enabled@2.0.0
                      │ │   │ └── kuler@2.0.0
                      │ │   ├── async@3.2.3
                      │ │   ├─┬ logform@2.4.0
                      │ │   │ ├── @colors/colors@1.5.0 deduped
                      │ │   │ ├── fecha@4.2.3
                      │ │   │ ├── ms@2.1.3
                      │ │   │ ├── safe-stable-stringify@2.3.1 deduped
                      │ │   ├─┬ one-time@1.0.0
                      │ │   │ └── fn.name@1.1.0
                      │ │   ├─┬ readable-stream@3.6.0
                      │ │   │ ├── string_decoder@1.3.0
                      │ │   │ └── util-deprecate@1.0.2 deduped
                      │ │   ├── stack-trace@0.0.10
                      │ │   ├── triple-beam@1.3.0 deduped
                      │ │   └── winston-transport@4.5.0 deduped
                      │ ├─┬ @iobroker/plugin-sentry@1.2.0
                      │ │ ├─┬ @sentry/integrations@6.19.7
                      │ │ │ ├── @sentry/types@6.19.7
                      │ │ │ ├─┬ @sentry/utils@6.19.7
                      │ │ │ │ ├── @sentry/types@6.19.7 deduped
                      │ │ │ │ └── tslib@1.14.1 deduped
                      │ │ │ ├── localforage@1.10.0 deduped
                      │ │ ├─┬ @sentry/node@6.18.2
                      │ │ │ ├─┬ @sentry/core@6.18.2
                      │ │ │ │ ├── @sentry/hub@6.18.2 deduped
                      │ │ │ │ ├── @sentry/minimal@6.18.2
                      │ │ │ │ ├── @sentry/types@6.18.2 deduped
                      │ │ │ │ ├── @sentry/utils@6.18.2 deduped
                      │ │ │ ├─┬ @sentry/hub@6.18.2
                      │ │ │ ├─┬ @sentry/utils@6.18.2
                      │ │ │ ├── cookie@0.4.2
                      │ │ │ ├── lru_map@0.3.3 deduped
                      │ │ └── source-map-support@0.5.21 deduped
                      │ ├─┬ axios@0.24.0
                      │ ├─┬ debug@4.3.4
                      │ │ └── ms@2.1.2
                      │ ├─┬ decache@4.6.1
                      │ │ └── callsite@1.0.0
                      │ ├─┬ diskusage@1.1.3
                      │ │ ├── es6-promise@4.2.8
                      │ ├─┬ fs-extra@10.0.0
                      │ ├─┬ greenlock-express@4.0.3
                      │ │ ├─┬ @root/greenlock-express@4.0.4
                      │ │ │ ├── @root/greenlock@4.0.5 deduped
                      │ │ │ └── redirect-https@1.3.1 deduped
                      │ │ ├─┬ @root/greenlock@4.0.5
                      │ │ │ ├── @greenlock/manager@3.1.0 deduped
                      │ │ │ ├── @root/acme@3.1.0 deduped
                      │ │ │ ├── @root/csr@0.8.1 deduped
                      │ │ │ ├─┬ @root/keypairs@0.10.3
                      │ │ │ │ ├── @root/encoding@1.0.1 deduped
                      │ │ │ │ ├── @root/pem@1.0.4 deduped
                      │ │ │ │ └── @root/x509@0.7.2 deduped
                      │ │ │ ├── @root/mkdirp@1.0.0 deduped
                      │ │ │ ├── @root/request@1.8.1 deduped
                      │ │ │ ├── acme-http-01-standalone@3.0.5 deduped
                      │ │ │ ├── cert-info@1.5.1 deduped
                      │ │ │ ├── greenlock-store-fs@3.2.2 deduped
                      │ │ │ └── safe-replace@1.1.0 deduped
                      │ │ └─┬ redirect-https@1.3.1
                      │ │   └── escape-html@1.0.3 deduped
                        cd /opt/iobroker
                        npm ls --depth=4
                        Thomas BraunT
                        Thomas BraunT
                        #142
                        Das ist seit npm8 so.
                        • J jojo182
                          $ npm ls --depth=4
                          ├─┬ canvas@2.9.3
                          │ │ │   └── ms@2.1.2
                          │ │ ├─┬ nopt@5.0.0
                          │ ├── nan@2.16.0
                          │   ├─┬ once@1.4.0
                          │ ├─┬ axios@0.27.2
                          │ │ ├── bytes@3.1.2
                          │ │ ├─┬ debug@2.6.9
                          │ │ │ └── ms@2.0.0
                          │ │ ├── depd@2.0.0
                          │ │ ├── bytes@3.0.0
                          │ │ └── vary@1.1.2
                          │ │ ├── etag@1.8.1
                          │ │ ├── fresh@0.5.2
                          │ │ ├─┬ send@0.18.0
                          │ │ │ ├── ms@2.1.3
                          │ ├── mime@3.0.0
                          │ │ ├── pause@0.0.1
                          │ ├─┬ semver@7.3.7
                          │ └─┬ ws@8.8.1
                          │ │   └── uuid@8.3.2
                          │ ├─┬ axios@0.27.2
                          │ │ ├── depd@2.0.0
                          │ │ ├─┬ send@0.18.0
                          │ │ │ ├── ms@2.1.3
                          │ ├─┬ ftp@0.3.10
                          │ │ ├─┬ jws@4.0.0
                          │ │ │ ├─┬ jwa@2.0.0
                          │ │ ├── aws4@1.11.0
                          │ │ ├── qs@6.5.2
                          │ │ └── uuid@3.4.0
                          │ ├─┬ tar-fs@2.1.1
                          │ │ ├─┬ pump@3.0.0
                          │ │   ├─┬ bl@4.1.0
                          │ └─┬ webdav@4.10.0
                          │   ├─┬ axios@0.27.2
                          │   ├── base-64@1.0.0
                          │   ├── he@1.2.0
                          │   ├── layerr@0.1.2
                          │   ├─┬ md5@2.3.0
                          │   │ ├── crypt@0.0.2
                          │ ├─┬ axios@0.27.2
                          │ │ ├─┬ debug@2.2.0
                          │ │ │ └── ms@0.7.1
                          │ │ ├── dgram@1.0.1
                          │ ├── netmask@2.0.2
                          │ │ ├─┬ async@2.6.4
                          │ │ ├─┬ debug@3.2.7
                          │ │ │ └── ms@2.1.3
                          │   │ ├─┬ debug@4.3.3
                          │   │ │ └── ms@2.1.2
                          │   └─┬ debug@4.3.3
                          │     └── ms@2.1.2
                          │ ├─┬ echarts@5.3.3
                          │ │ ├── tslib@2.3.0
                          │ │   └── tslib@2.3.0
                          │ ├─┬ jsdom@19.0.0
                          │ │ ├── abab@2.0.6
                          │ │ ├── acorn@8.7.1
                          │ │ ├── cssom@0.5.0
                          │ │ │   └── ms@2.1.2
                          │ │ ├─┬ saxes@5.0.1
                          │ └── moment@2.29.3
                          │ │ ├─┬ chalk@2.4.2
                          │ ├─┬ axios@0.26.1
                          │ └─┬ qs@6.10.3
                          │ ├─┬ axios@0.26.0
                          │ ├─┬ semver@7.3.5
                          │ ├─┬ got@11.8.5
                          │ ├── ip@1.1.5
                          │ │ ├─┬ debug@4.3.4
                          │ │ │ └── ms@2.1.2
                          │ │ │ └─┬ ws@8.2.3
                          │ └── uuid@8.3.2
                          │ ├── jsonata@1.8.6
                          │ ├─┬ jszip@3.10.0
                          │ │ ├─┬ lie@3.3.0
                          │ │ ├── pako@1.0.11
                          │ │ ├─┬ debug@4.3.4
                          │ │ │ └── ms@2.1.2
                          │ │ │   ├── bl@4.1.0
                          │ │ └─┬ ws@8.8.1
                          │ │ ├── aws4@1.11.0
                          │ │ ├── qs@6.5.3
                          │ │ │ ├── psl@1.9.0
                          │ │ └── uuid@3.4.0
                          │ ├─┬ semver@7.3.7
                          │ │ │ ├─┬ has@1.0.3
                          │ │ │ └── is@3.3.0
                          │ │ ├─┬ debug@4.3.4
                          │ │ │ └── ms@2.1.2
                          │ │   ├── async@3.2.3
                          │ │   │ ├── ms@2.1.3
                          │ ├─┬ axios@0.24.0
                          │ ├─┬ debug@4.3.4
                          │ │ └── ms@2.1.2
                          │ ├─┬ decache@4.6.1
                          foxriver76F
                          foxriver76F
                          foxriver76
                          #143
                          @jojo182 Unter Javascript liegt nach wie vor ein Puppeteer 16.2.0. Ich vermute nach wie vor, dass sich da irgendetwas beißt.
                          Evtl. hilft
                          cd /opt/iobroker/node_modules/iobroker.javascript
                          npm uninstall puppeteer
                            Evtl. hilft
                            J
                            J
                            jojo182
                            #144
                            @foxriver76 Leider kein Erfolg, immernoch die gleiche Fehlermeldung. Da wird wohl mehr im Argen liegen 😕
                            npm ls --depth=4 | grep "pup"
                            ├─┬ iobroker.puppeteer@0.2.6
                            │ └─┬ puppeteer@13.7.0
                            • J jojo182
                              foxriver76F
                              foxriver76F
                              foxriver76
                              #145
                              @jojo182 Scheint als ist da noch was mit ARM + Puppeteer nicht out of the box kompatibel. Ich schaue es mir nochmal an.
                                J
                                J
                                jojo182
                                #146
                                @foxriver76 Von mir ein kleines Update. Ich habe von meinem Raspi Backup Image von letzter Woche das puppeteer module kopiert, jetzt geht es zumindest wieder direkt über Javascript, der Puppeteer Adapter mag wohl diese Version gar nicht. Fehlermeldung teilweise sehr cryptisch. Weiß nicht ob für dich relevant.
                                • J jojo182
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  #147
                                  @jojo182 Zeig mal gerne jetzt die Version via dem vorherigen Kommando.
                                  Und zeig mir gerne mal wie du im Skript Puppeteer startest. Wenn der mitgelieferte Browser dort funktioniert ist es komisch.
                                    J
                                    J
                                    jojo182
                                    #148
                                    @foxriver76 Gerne:
                                    │ └─┬ puppeteer@13.1.1 invalid: "^13.7.0" from node_modules/iobroker.puppeteer
                                    │   ├── devtools-protocol@0.0.981744 invalid: "0.0.948846" from node_modules/puppeteer
                                    │   ├─┬ https-proxy-agent@5.0.1 invalid: "5.0.0" from node_modules/puppeteer
                                    npm ERR! code ELSPROBLEMS
                                    npm ERR! extraneous: cross-fetch@3.1.5 /opt/iobroker/node_modules/cross-fetch
                                    npm ERR! invalid: puppeteer@13.1.1 /opt/iobroker/node_modules/puppeteer
                                    npm ERR! invalid: devtools-protocol@0.0.981744 /opt/iobroker/node_modules/devtools-protocol
                                    npm ERR! invalid: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/puppeteer/node_modules/https-proxy-agent
                                    const puppeteer = require("puppeteer");
                                    async function run () {
                                        var url = "https://....";
                                        const browser = await puppeteer.launch({executablePath: '/usr/bin/chromium-browser'});
                                        const page = await browser.newPage();
                                        await page.goto(url);
                                        await sleep(10000)
                                        await page.mouse.click(210, 210)
                                        await sleep(10000)
                                        await page.screenshot({path: '/opt/iobroker/wetter.png'});
                                        browser.close();
                                    puppeteer ist in der JS Adapter Admin Seite nicht hinzugefügt, damit es nicht wieder überschrieben wird beim nächsten Update.
                                    • foxriver76F
                                      foxriver76F
                                      foxriver76
                                      #149
                                      @jojo182 Hm ja, du gibst den executable path an, das habe ich auch gelesen für Pi's
                                      https://chsamii.medium.com/puppeteer-on-raspbian-nodejs-3425ccea470e
                                      Ich überlege mir mal wie ich das am nutzerfreundlichsten lösen kann.
                                      Thomas BraunT liv-in-skyL 2 Antworten Letzte Antwort
                                        Thomas BraunT
                                        Thomas BraunT
                                        #150
                                        @foxriver76
                                        Das schleppt halt nur eine komplette X bzw. Desktopumgebung an.
                                        • H
                                          H
                                          horphi
                                          #151
                                          gibt es eine Möglichkeit, wie ich im blocky skript den nächsten Schritt erst ausführen kann, wenn Puppeteer das Bild erstellt hat und das zurückmeldet?
                                          VIelen Dank und Gruß
                                          84.0k
