  4. js-controller 4.0.x jetzt für alle User im STABLE!
501 Beiträge 83 Kommentatoren 200.3k Aufrufe 58 Beobachtet
  • KeksmonsterK Offline
    Keksmonster
    #480
    Hallo Leute!
    ich brauche hilfe :-(
    Irgendwie will mein js-controller nicht updaten. Hat jemand einen Plan, was das sein kann?
    pi@SmartHome:~ $ iobroker upgrade self
    Update js-controller from @3.1.6 to @4.0.23
    NPM version: 6.14.17
    npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefi                           x "/opt/iobroker" (System call)
     Objects 127.0.0.1:49952 Error from InMemDB: Error: GET-UNSUPPORTED for namespac                           e cfg.: Data=["meta.objects.features.useSets"]
     States 127.0.0.1:36718 Error from InMemDB: Error: GET-UNSUPPORTED for namespace                            meta.: Data=["meta.states.protocolVersion"]
     Objects 127.0.0.1:49952 Error from InMemDB: Error: GET-UNSUPPORTED for namespac                           e cfg.: Data=["meta.objects.protocolVersion"]
     Objects 127.0.0.1:49952 Error from InMemDB: Error: scan NOT SUPPORTED
     States 127.0.0.1:36720 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for na                           mespace meta.: Data=["meta.*"]
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    ReplyError: Error scan NOT SUPPORTED
        at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
        at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.j                           s:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at processTicksAndRejections (internal/process/task_queues.js:95:5) {
      command: {
        args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@4.0.23 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.23 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional log                           ging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2022-06-07T22_40_24_484Z-debug.log
    host.SmartHome Cannot install iobroker.js-controller@4.0.23: 1
    pi@SmartHome:~ $
    Im Log steht:
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.js-controller@4.0.23',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--unsafe-perm',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.17
    3 info using node@v14.19.3
    4 verbose npm-session 4663683b180f216c
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.js-controller 1130ms (from cache)
    8 silly pacote version manifest for iobroker.js-controller@4.0.23 fetched in 1218ms
    9 timing stage:loadCurrentTree Completed in 23244ms
    10 silly install loadIdealTree
    11 silly install cloneCurrentTreeToIdealTree
    12 timing stage:loadIdealTree:cloneCurrentTree Completed in 325ms
    13 silly install loadShrinkwrap
    14 timing stage:loadIdealTree:loadShrinkwrap Completed in 6449ms
    15 silly install loadAllDepsIntoIdealTree
    16 silly resolveWithNewModule iobroker.js-controller@4.0.23 checking installable status
    17 silly removeObsoleteDep removing iobroker.js-controller@3.1.6 from the tree as its been replaced by a newer version or is no longer required
    18 silly removeObsoleteDep removing @iobroker/plugin-sentry@1.1.4 from the tree as its been replaced by a newer version or is no longer required
    19 silly removeObsoleteDep removing @iobroker/plugin-base@1.2.0 from the tree as its been replaced by a newer version or is no longer required
    20 silly removeObsoleteDep removing @sentry/integrations@5.27.2 from the tree as its been replaced by a newer version or is no longer required
    21 silly removeObsoleteDep removing @sentry/types@5.27.2 from the tree as its been replaced by a newer version or is no longer required
    22 silly removeObsoleteDep removing @sentry/utils@5.27.2 from the tree as its been replaced by a newer version or is no longer required
    23 silly removeObsoleteDep removing localforage@1.8.1 from the tree as its been replaced by a newer version or is no longer required
    24 silly removeObsoleteDep removing lie@3.1.1 from the tree as its been replaced by a newer version or is no longer required
    25 silly removeObsoleteDep removing @sentry/node@5.27.2 from the tree as its been replaced by a newer version or is no longer required
    26 silly removeObsoleteDep removing @sentry/core@5.27.2 from the tree as its been replaced by a newer version or is no longer required
      Keksmonster
      #481
      Jetzt hats mir bei dem obrigen Versuch komplett iobroker zerschossen.
      pi@SmartHome:~ $ iobroker fix
      library: loaded
      Library version=2022-06-03
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      Habe es mit npm install iobroker.js-controller@3.3 wieder zum laufen bekommen ... Kann jede Hilfe gebrauchen :-)
        Keksmonster
        #482
        Endlich ( bin heute 4h dran gesessen) ...
        Ich hab jetzt noch mal die Anleitung mit der "manuellen Installation" durchgespielt (dachte eigentlich genau so habe ich es schon versucht) und nun ist es durchgelaufen! Juhu!
        • KeksmonsterK Keksmonster
          #483
          @jan-3 Ich denke dein Fix zuerst auf die 3.3. zu gehen hat es zum funktionieren gebracht
            matzi
            #484
            ich versuche mich seit paar Stunden erfolglos an dem JS-Controller update von 3.1.6 nach 4.0.x.
            Zu Beginn bin ich der Anleitung über den Satz gestolpert "ACHTUNG: Wer von einer kleineren js-controller Version als 3.2 kommt, sollte direkt per npm installieren und NICHT per iob uograde self!!" . Da ich absolut keine Ahnung davon habe, wie per npm installiert wird, habe ich es gemäß der Anleitung mit 'iobroker upgrade self' probiert.
            Dabei bekomme ich immer folgende Meldungen:
            matthias@iobroker:~$ iobroker upgrade self
            NPM version: 8.11.0
            npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
             Objects 127.0.0.1:33972 Error from InMemDB: Error: client NOT SUPPORTED
             Objects 127.0.0.1:33972 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
             Objects 127.0.0.1:33972 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
             Objects 127.0.0.1:33972 Error from InMemDB: Error: scan NOT SUPPORTED
             Objects 127.0.0.1:33978 Error from InMemDB: Error: client NOT SUPPORTED
             Objects 127.0.0.1:33980 Error from InMemDB: Error: client NOT SUPPORTED
             States 127.0.0.1:37326 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
             Objects 127.0.0.1:33974 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
             Objects 127.0.0.1:33974 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
             Objects 127.0.0.1:33974 Error from InMemDB: Error: scan NOT SUPPORTED
             States 127.0.0.1:37332 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
             Objects 127.0.0.1:33978 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace cfg.: Data=["meta.*"]
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! command failed
            npm ERR! command sh -c node iobroker.js setup first
            npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            npm ERR!         throw e;
            npm ERR!         ^
            npm ERR!
            npm ERR! ReplyError: Error scan NOT SUPPORTED
            npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
            npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
            npm ERR! Emitted 'error' event on ScanStream instance at:
            npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
            npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
            npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
            npm ERR!     at processTicksAndRejections (node:internal/process/task_queues:96:5) {
            npm ERR!   command: {
            npm ERR!     name: 'scan',
            npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
            npm ERR!   }
            npm ERR! }
            npm ERR!     /home/iobroker/.npm/_logs/2022-07-03T10_45_15_147Z-debug-0.log
            Starting node restart.js
            Danach habe ich es mit dem Befehl 'sudo -H -u iobroker npm install iobroker.js-controller' versucht und den iobroker gestartet.
            matthias@iobroker:~$ sudo -H -u iobroker npm install iobroker.js-controller
            [sudo] password for matthias:
            up to date, audited 284 packages in 17s
            14 packages are looking for funding
              run `npm fund` for details
            4 vulnerabilities (3 moderate, 1 high)
            To address all issues (including breaking changes), run:
              npm audit fix --force
            Run `npm audit` for details.
            Egal was ich mache, ist es nach dem Start vom iobroker immer noch die js-Controller Version 3.1.6.
            Betriebssystem: Linux Ubuntu 18.04.6 LTS (aktualisiert)
            Node-JS: 16.15.1
            NPM: 8.11.0
            Was mache ich falsch?
            Viele Grüße
            Matthias
            Mod-Edit: Code in </> Code-Tag gepackt!
            • M matzi
              NPM version: 8.11.0
              npm ERR! code 1
              npm ERR!         throw e;
              npm ERR!         ^
              npm ERR!
              npm ERR!   command: {
              npm ERR!   }
              npm ERR! }
              Node-JS: 16.15.1
              NPM: 8.11.0
              Viele Grüße
              Matthias
              #485
              @matzi sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
              Richtiger Befehl, aber im falschen Verzeichnis ausgeführt.
              Zuvor
              cd /opt/iobroker
              Und künfitg nicht so schludern mit den Updates, dann ist das alles einfacher.
                matzi
                #486
                Danke - jetzt bin ich einen Schritt weiter. Die JS-Controller Version ist jetzt 3.3.22 .
                Werde mit dem Stand erst mal die VM sichern, dann alle Adapter aktualisieren und dann das Update des JS-Controllers auf 4.0.x versuchen.
                • M Online
                  M Online
                  MCU
                  #487
                  @apollon77 Laut Doku von oben soll es in der iobroker.json für objects und states einen Eintrag für "connectionTimeouts" geben.
                  Editiere /opt/iobroker/iobroker-data/iobroker.json
                  Unter objects und states gibt es jeweils ein ' "connectTimeout": 2000,`
                  Zahl ändern auf 5000
                  Bei mir gibt es den Eintrag nur für objects. Muss man den Eintrag für states ergänzen?
                  • M MCU
                    #488
                    @mcu ja. Einfach ergänzen.
                    • R Offline
                      Rocket85
                      #489
                      Hallo zusammen, kann mir vielleicht jemand beim Update helfen?
                      Komme von Version 2.2.10 und hier sollte ich wohl nicht direkt per upgrad self starten?
                      • R Rocket85
                        #490
                        @rocket85 hehe .... nnneeeee am besten nicht.
                        Am Ende zwei Varianten:
                        1.) Backup/Restore
                        • Backup machen inkl. von iobroker-data nochmal gesondert um ggf was raussuchen zu können was doch nicht im Backup ist. Dann /opt/iobroker löschen. Dann mit Linux installer neu installieren. Beenden. Dann Backup restore ...
                        • dann direkt vor dem start (!!) Alle adapter aktualisieren. Major Versionsprünge bei Adaptern aufschreiben das Du sie danach abarbeiten kannst was sich geändert hat. Starten ... Alles nach und nach hinbiegen und ggf fehlende Dateien aus Backup rausholen
                        2.) "Sollte tun"
                        • Backup gilt immer wie oben von allem. dann beenden. node_modules Verzeichnis löschen (rest lassen). dann in /opt/iobroker ein npm install iobroker.js-controller@4.0.23 --production ausführen. Dann verifizieren das iob update" bzw iob list instances` tut.
                        • dann an aich wie oben ggf zuerst adapter aktualisieren und wie oben
                        Ein schrittweise update vom js-controller (Variante 3) macht in meinen Augen nur Aufwand aber bringt nicht so viele vorteile.
                          Snapergy
                          #491
                          Ich habe gerade das Update gemacht und habe aber bei meinem KNX-Adapter ein Problem. Es kommen immer folgende Meldungen und der Adapter (V1.31 -> ich weiß, ist nicht die aktuellste, aber für meine Zwecke die, die am besten funktioniert) startet nicht mehr :(
                          knx.0
                          	2022-08-29 11:32:37.213	error	Cannot read property 'getObjectView' of undefined
                          knx.0
                          	2022-08-29 11:32:37.212	error	TypeError: Cannot read property 'getObjectView' of undefined at Object._0x2a4410 [as ready] (/opt/iobroker/node_modules/iobroker.knx/knx.js:79:30550) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8225:68
                          knx.0
                          	2022-08-29 11:32:37.208	error	unhandled promise rejection: Cannot read property 'getObjectView' of undefined
                          knx.0
                          	2022-08-29 11:32:37.208	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          Vielleicht kann mir jemand hier direkt helfen und auf eine Lösung aufmerksam machen. Bin gerade erstmal wieder auf die JS-Controller-Version 3.3.22 zurück
                          • S Snapergy
                            knx.0
                            knx.0
                            knx.0
                            knx.0
                            #492
                            @snapergy knx Adapter issue machen. Bzw falls knx nicht aktuell ist dann bitte aktualisieren!!
                            • apollon77A apollon77
                              Snapergy
                              #493
                              @apollon77 Einen issua gibt es dazu schon von einem anderen Nutzer, dort gibt es bis heute keinen response. Aktualisieren ist halt nicht so einfach, da der adapter ab V2 kostenpflichtig wird und innerhalb von V1.X keine, für mich funktionierende, version existiert. Also alles ein wenig kompliziert :(
                              • S Snapergy
                                #494
                                @snapergy Ja welche version nutzt du denn? Meines wissens nach tut die 1.0.46 problemlos - also mindestens der hier genannte Fehler ist da nicht drin ...
                                  Snapergy
                                  #495
                                  @apollon77 wie oben schon geschrieben habe ich die V1.31 im Einsatz. Ich werde das Ganze nochmal mit der v1.46 testen
                                    Snapergy
                                    #496
                                    @apollon77 1.0.46 existiert laut console nicht, habe es mit der 1.0.45 versucht, aber da klappt es leider nicht...
                                    • S Snapergy
                                      #497
                                      @snapergy Und die freien Geräte in der 2.0 reichen Dir nicht? Dann tut es mir leid aber kann ich nicht weiter helfen.
                                      • knx 2.0 nutzen und ggf eine Lizenz erwerben oder
                                      • openknx Adapter versuchen
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        #498
                                        @apollon77
                                        @Homoran
                                        DIESES Topic könnte man m.E. unpinnen.
                                        mcm1957
                                        Support Repositoryverwaltung.
                                        LESEN - gute Forenbeitrage
                                        • mcm1957M mcm1957
                                          @apollon77
                                          @Homoran
                                          mcm1957
                                          #499
                                          @mcm57 sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
                                          warum?
                                          hab jetzt doch schon den beta-thread geschlossen.
                                          damit nicht zuviel verstreute Informationen entstehen sollte IMHO dieser Thread leicht zu finden sein.
