  4. Error 25: npm ERR! code ENOTEMPTY
36 Beiträge 6 Kommentatoren 5.3k Aufrufe 3 Beobachtet
  • Palm_ManiacP Offline
    Palm_Maniac
    Leider zu früh gefreut. Das Node-Red Update hatte ich noch nicht gemacht und es will auch nicht. Ich hab mir jetzt mal das gemeldete Log angesehen. In der 2. Hälfte tauchen die ganzen Pfade auf, die wohl mit einem Move Befehl angelegt werden.
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@8.15.0
    2 info using node@v16.17.0
    3 timing npm:load:whichnode Completed in 0ms
    4 timing config:load:defaults Completed in 1ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
    6 timing config:load:builtin Completed in 0ms
    7 timing config:load:cli Completed in 2ms
    8 timing config:load:env Completed in 0ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 12ms
    10 timing config:load:project Completed in 23ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 3ms
    12 timing config:load:user Completed in 3ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
    14 timing config:load:global Completed in 0ms
    15 timing config:load:validate Completed in 1ms
    16 timing config:load:credentials Completed in 1ms
    17 timing config:load:setEnvs Completed in 2ms
    18 timing config:load Completed in 34ms
    19 timing npm:load:configload Completed in 34ms
    20 timing npm:load:mkdirpcache Completed in 1ms
    21 timing npm:load:mkdirplogs Completed in 1ms
    22 verbose title npm install iobroker.node-red@4.0.0
    23 verbose argv "install" "--save-exact" "iobroker.node-red@4.0.0" "--unsafe-perm"
    24 timing npm:load:setTitle Completed in 2ms
    25 timing config:load:flatten Completed in 2ms
    26 timing npm:load:display Completed in 3ms
    27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
    28 verbose logfile /home/iobroker/.npm/_logs/2022-08-18T15_43_19_158Z-debug-0.log
    29 timing npm:load:logFile Completed in 4ms
    30 timing npm:load:timers Completed in 0ms
    31 timing npm:load:configScope Completed in 0ms
    32 timing npm:load Completed in 45ms
    33 timing arborist:ctor Completed in 0ms
    34 silly logfile start cleaning logs, removing 2 files
    35 silly logfile done cleaning log files
    36 timing idealTree:init Completed in 1285ms
    37 timing idealTree:userRequests Completed in 19ms
    38 silly idealTree buildDeps
    39 silly fetch manifest iobroker.node-red@4.0.0
    40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    41 http fetch GET 200 https://registry.npmjs.org/iobroker.node-red 988ms (cache hit)
    42 silly placeDep ROOT iobroker.node-red@4.0.0 REPLACE for: iobroker.inst@3.0.0 want: 4.0.0
    43 silly fetch manifest node-red@^3.0.2
    44 silly fetch manifest node-red-node-email@^1.17.0
    45 silly fetch manifest node-red-node-feedparser@^0.3.0
    46 silly fetch manifest fs.notify@^0.0.4
    47 silly fetch manifest feedparser@^2.2.10
    48 silly fetch manifest mongodb@^4.8.1
    49 http fetch GET 200 https://registry.npmjs.org/node-red 439ms (cache hit)
    50 http fetch GET 200 https://registry.npmjs.org/node-red-node-email 442ms (cache hit)
    51 http fetch GET 200 https://registry.npmjs.org/node-red-node-feedparser 443ms (cache hit)
    52 http fetch GET 200 https://registry.npmjs.org/fs.notify 443ms (cache hit)
    53 http fetch GET 200 https://registry.npmjs.org/feedparser 444ms (cache hit)
    54 http fetch GET 200 https://registry.npmjs.org/mongodb 443ms (cache hit)
    55 timing idealTree:#root Completed in 1504ms
    56 silly placeDep ROOT feedparser@2.2.10 OK for: iobroker.node-red@4.0.0 want: ^2.2.10
    57 silly placeDep ROOT fs.notify@0.0.4 OK for: iobroker.node-red@4.0.0 want: ^0.0.4
    58 silly placeDep ROOT mongodb@4.8.1 OK for: iobroker.node-red@4.0.0 want: ^4.8.1
    59 silly placeDep ROOT node-red@3.0.2 OK for: iobroker.node-red@4.0.0 want: ^3.0.2
    60 silly placeDep ROOT node-red-node-email@1.17.0 OK for: iobroker.node-red@4.0.0 want: ^1.17.0
    61 silly placeDep ROOT node-red-node-feedparser@0.3.0 OK for: iobroker.node-red@4.0.0 want: ^0.3.0
    62 silly fetch manifest addressparser@^1.0.1
    63 silly fetch manifest array-indexofobject@~0.0.1
    64 silly fetch manifest lodash.assign@^4.2.0
    65 silly fetch manifest lodash.get@^4.4.2
    66 silly fetch manifest lodash.has@^4.5.2
    67 silly fetch manifest lodash.uniq@^4.5.0
    68 silly fetch manifest mri@^1.1.5
    69 silly fetch manifest async@~0.1.22
    70 silly fetch manifest retry@~0.6.0
    71 silly fetch manifest bson@^4.6.5
    72 silly fetch manifest denque@^2.0.1
    73 silly fetch manifest mongodb-connection-string-url@^2.5.2
    74 silly fetch manifest socks@^2.6.2
    75 silly fetch manifest saslprep@^1.0.3
    76 silly fetch manifest @node-red/editor-api@3.0.2
    77 silly fetch manifest @node-red/runtime@3.0.2
    78 silly fetch manifest @node-red/util@3.0.2
    79 silly fetch manifest @node-red/nodes@3.0.2
    80 silly fetch manifest basic-auth@2.0.1
    81 silly fetch manifest bcryptjs@2.4.3
    82 silly fetch manifest node-red-admin@^3.0.0
    83 silly fetch manifest semver@7.3.7
    84 silly fetch manifest bcrypt@5.0.1
    85 http fetch GET 200 https://registry.npmjs.org/addressparser 52ms (cache hit)
    86 http fetch GET 200 https://registry.npmjs.org/array-indexofobject 51ms (cache hit)
    87 http fetch GET 200 https://registry.npmjs.org/lodash.assign 52ms (cache hit)
    88 http fetch GET 200 https://registry.npmjs.org/lodash.get 52ms (cache hit)
    89 http fetch GET 200 https://registry.npmjs.org/lodash.has 52ms (cache hit)
    90 http fetch GET 200 https://registry.npmjs.org/lodash.uniq 52ms (cache hit)
    91 http fetch GET 200 https://registry.npmjs.org/mri 52ms (cache hit)
    92 http fetch GET 200 https://registry.npmjs.org/async 53ms (cache hit)
    93 http fetch GET 200 https://registry.npmjs.org/retry 54ms (cache hit)
    94 http fetch GET 200 https://registry.npmjs.org/bson 55ms (cache hit)
    95 http fetch GET 200 https://registry.npmjs.org/denque 56ms (cache hit)
    96 http fetch GET 200 https://registry.npmjs.org/mongodb-connection-string-url 56ms (cache hit)
    97 http fetch GET 200 https://registry.npmjs.org/socks 57ms (cache hit)
    98 http fetch GET 200 https://registry.npmjs.org/saslprep 57ms (cache hit)
    99 http fetch GET 200 https://registry.npmjs.org/@node-red%2feditor-api 57ms (cache hit)
    100 http fetch GET 200 https://registry.npmjs.org/@node-red%2fruntime 58ms (cache hit)
    101 http fetch GET 200 https://registry.npmjs.org/@node-red%2futil 58ms (cache hit)
    102 http fetch GET 200 https://registry.npmjs.org/@node-red%2fnodes 59ms (cache hit)
    103 http fetch GET 200 https://registry.npmjs.org/basic-auth 59ms (cache hit)
    104 http fetch GET 200 https://registry.npmjs.org/bcryptjs 58ms (cache hit)
    105 http fetch GET 200 https://registry.npmjs.org/node-red-admin 59ms (cache hit)
    106 http fetch GET 200 https://registry.npmjs.org/semver 54ms (cache hit)
    107 http fetch GET 200 https://registry.npmjs.org/bcrypt 54ms (cache hit)
    108 timing idealTree:node_modules/iobroker.node-red Completed in 81ms
    109 silly placeDep ROOT addressparser@1.0.1 OK for: feedparser@2.2.10 want: ^1.0.1
    110 silly placeDep ROOT array-indexofobject@0.0.1 OK for: feedparser@2.2.10 want: ~0.0.1
    111 silly placeDep ROOT lodash.assign@4.2.0 OK for: feedparser@2.2.10 want: ^4.2.0
    112 silly placeDep ROOT lodash.get@4.4.2 OK for: feedparser@2.2.10 want: ^4.4.2
    113 silly placeDep ROOT lodash.has@4.5.2 OK for: feedparser@2.2.10 want: ^4.5.2
    114 silly placeDep ROOT lodash.uniq@4.5.0 OK for: feedparser@2.2.10 want: ^4.5.0
    115 silly placeDep ROOT mri@1.2.0 OK for: feedparser@2.2.10 want: ^1.1.5
    116 timing idealTree:node_modules/feedparser Completed in 7ms
    117 timing idealTree:node_modules/addressparser Completed in 0ms
    118 timing idealTree:node_modules/array-indexofobject Completed in 0ms
    119 silly placeDep node_modules/fs.notify async@0.1.22 OK for: fs.notify@0.0.4 want: ~0.1.22
    120 silly placeDep ROOT retry@0.6.1 OK for: fs.notify@0.0.4 want: ~0.6.0
    121 timing idealTree:node_modules/fs.notify Completed in 2ms
    122 timing idealTree:node_modules/lodash.assign Completed in 1ms
    123 timing idealTree:node_modules/lodash.get Completed in 0ms
    124 timing idealTree:node_modules/lodash.has Completed in 0ms
    125 timing idealTree:node_modules/lodash.uniq Completed in 0ms
    126 silly placeDep ROOT bson@4.6.5 OK for: mongodb@4.8.1 want: ^4.6.5
    127 silly placeDep node_modules/mongodb denque@2.1.0 OK for: mongodb@4.8.1 want: ^2.0.1
    128 silly placeDep ROOT mongodb-connection-string-url@2.5.3 OK for: mongodb@4.8.1 want: ^2.5.2
    129 silly placeDep ROOT saslprep@1.0.3 OK for: mongodb@4.8.1 want: ^1.0.3
    130 silly placeDep ROOT socks@2.7.0 OK for: mongodb@4.8.1 want: ^2.6.2
    131 silly fetch manifest buffer@^5.6.0
    132 silly fetch manifest @types/whatwg-url@^8.2.1
    133 silly fetch manifest whatwg-url@^11.0.0
    134 silly fetch manifest sparse-bitfield@^3.0.3
    135 silly fetch manifest ip@^2.0.0
    136 silly fetch manifest smart-buffer@^4.2.0
    137 http fetch GET 200 https://registry.npmjs.org/buffer 14ms (cache hit)
    138 http fetch GET 200 https://registry.npmjs.org/@types%2fwhatwg-url 14ms (cache hit)
    139 http fetch GET 200 https://registry.npmjs.org/whatwg-url 14ms (cache hit)
    140 http fetch GET 200 https://registry.npmjs.org/sparse-bitfield 15ms (cache hit)
    141 http fetch GET 200 https://registry.npmjs.org/ip 14ms (cache hit)
    142 http fetch GET 200 https://registry.npmjs.org/smart-buffer 15ms (cache hit)
    143 timing idealTree:node_modules/mongodb Completed in 28ms
    144 silly placeDep node_modules/bson buffer@5.7.1 OK for: bson@4.6.5 want: ^5.6.0
    145 timing idealTree:node_modules/bson Completed in 1ms
    146 silly placeDep ROOT @types/whatwg-url@8.2.2 OK for: mongodb-connection-string-url@2.5.3 want: ^8.2.1
    147 silly placeDep node_modules/mongodb-connection-string-url whatwg-url@11.0.0 OK for: mongodb-connection-string-url@2.5.3 want: ^11.0.0
    148 silly fetch manifest @types/webidl-conversions@*
    149 http fetch GET 200 https://registry.npmjs.org/@types%2fwebidl-conversions 2ms (cache hit)
    150 timing idealTree:node_modules/mongodb-connection-string-url Completed in 5ms
    151 silly placeDep ROOT @types/webidl-conversions@6.1.1 OK for: @types/whatwg-url@8.2.2 want: *
    152 timing idealTree:node_modules/@types/whatwg-url Completed in 2ms
    153 timing idealTree:node_modules/@types/webidl-conversions Completed in 0ms
    154 timing idealTree:node_modules/mri Completed in 0ms
    155 silly placeDep ROOT @node-red/editor-api@3.0.2 OK for: node-red@3.0.2 want: 3.0.2
    156 silly placeDep ROOT @node-red/nodes@3.0.2 OK for: node-red@3.0.2 want: 3.0.2
    157 silly placeDep ROOT @node-red/runtime@3.0.2 OK for: node-red@3.0.2 want: 3.0.2
    158 silly placeDep ROOT @node-red/util@3.0.2 OK for: node-red@3.0.2 want: 3.0.2
    159 silly placeDep ROOT basic-auth@2.0.1 OK for: node-red@3.0.2 want: 2.0.1
    160 silly placeDep ROOT bcrypt@5.0.1 OK for: node-red@3.0.2 want: 5.0.1
    161 silly placeDep ROOT bcryptjs@2.4.3 OK for: node-red@3.0.2 want: 2.4.3
    162 silly placeDep ROOT node-red-admin@3.0.0 OK for: node-red@3.0.2 want: ^3.0.0
    163 silly placeDep ROOT semver@7.3.7 REPLACE for: node-red@3.0.2 want: 7.3.7
    164 silly fetch manifest @node-red/editor-client@3.0.2
    165 silly fetch manifest clone@2.1.2
    166 silly fetch manifest express-session@1.17.3
    167 silly fetch manifest memorystore@1.6.7
    168 silly fetch manifest mime@3.0.0
    169 silly fetch manifest multer@1.4.5-lts.1
    170 silly fetch manifest mustache@4.2.0
    171 silly fetch manifest oauth2orize@1.11.1
    172 silly fetch manifest passport-http-bearer@1.0.1
    173 silly fetch manifest passport-oauth2-client-password@0.1.2
    174 silly fetch manifest passport@0.6.0
    175 silly fetch manifest ws@7.5.6
    176 silly fetch manifest acorn-walk@8.2.0
    177 silly fetch manifest ajv@8.11.0
    178 silly fetch manifest cheerio@1.0.0-rc.10
    179 silly fetch manifest cronosjs@1.7.1
    180 silly fetch manifest denque@2.1.0
    181 silly fetch manifest form-data@4.0.0
    182 silly fetch manifest got@11.8.5
    183 silly fetch manifest hash-sum@2.0.0
    184 silly fetch manifest hpagent@1.0.0
    185 silly fetch manifest https-proxy-agent@5.0.1
    186 silly fetch manifest is-utf8@0.2.1
    187 silly fetch manifest js-yaml@4.1.0
    188 silly fetch manifest media-typer@1.1.0
    189 silly fetch manifest mqtt@4.3.7
    190 silly fetch manifest node-watch@0.7.3
    191 silly fetch manifest tough-cookie@4.0.0
    192 silly fetch manifest uuid@8.3.2
    193 silly fetch manifest iconv-lite@0.6.3
    194 silly fetch manifest @node-red/registry@3.0.2
    195 silly fetch manifest async-mutex@0.3.2
    196 silly fetch manifest i18next@21.8.16
    197 silly fetch manifest lodash.clonedeep@^4.5.0
    198 silly fetch manifest moment@2.29.4
    199 silly fetch manifest moment-timezone@0.5.34
    200 silly fetch manifest node-addon-api@^3.1.0
    201 silly fetch manifest ansi-colors@^4.1.1
    202 silly fetch manifest axios@0.27.2
    203 silly fetch manifest cli-table@^0.3.11
    204 silly fetch manifest enquirer@^2.3.6
    205 silly fetch manifest mustache@^4.2.0
    206 http fetch GET 200 https://registry.npmjs.org/@node-red%2feditor-client 110ms (cache hit)
    207 http fetch GET 200 https://registry.npmjs.org/clone 109ms (cache hit)
    208 http fetch GET 200 https://registry.npmjs.org/express-session 110ms (cache hit)
    209 http fetch GET 200 https://registry.npmjs.org/memorystore 110ms (cache hit)
    210 http fetch GET 200 https://registry.npmjs.org/multer 109ms (cache hit)
    211 http fetch GET 200 https://registry.npmjs.org/mustache 105ms (cache hit)
    212 http fetch GET 200 https://registry.npmjs.org/oauth2orize 104ms (cache hit)
    213 http fetch GET 200 https://registry.npmjs.org/passport-oauth2-client-password 104ms (cache hit)
    214 http fetch GET 200 https://registry.npmjs.org/passport 104ms (cache hit)
    215 http fetch GET 200 https://registry.npmjs.org/passport-http-bearer 105ms (cache hit)
    216 http fetch GET 200 https://registry.npmjs.org/ws 104ms (cache hit)
    217 http fetch GET 200 https://registry.npmjs.org/acorn-walk 105ms (cache hit)
    218 http fetch GET 200 https://registry.npmjs.org/ajv 105ms (cache hit)
    219 http fetch GET 200 https://registry.npmjs.org/cheerio 109ms (cache hit)
    220 http fetch GET 200 https://registry.npmjs.org/cronosjs 109ms (cache hit)
    221 http fetch GET 200 https://registry.npmjs.org/form-data 108ms (cache hit)
    222 http fetch GET 200 https://registry.npmjs.org/got 109ms (cache hit)
    223 http fetch GET 200 https://registry.npmjs.org/hash-sum 111ms (cache hit)
    224 http fetch GET 200 https://registry.npmjs.org/hpagent 110ms (cache hit)
    225 http fetch GET 200 https://registry.npmjs.org/https-proxy-agent 111ms (cache hit)
    226 http fetch GET 200 https://registry.npmjs.org/is-utf8 110ms (cache hit)
    227 http fetch GET 200 https://registry.npmjs.org/js-yaml 110ms (cache hit)
    228 http fetch GET 200 https://registry.npmjs.org/media-typer 110ms (cache hit)
    229 http fetch GET 200 https://registry.npmjs.org/mqtt 111ms (cache hit)
    230 http fetch GET 200 https://registry.npmjs.org/node-watch 112ms (cache hit)
    231 http fetch GET 200 https://registry.npmjs.org/tough-cookie 111ms (cache hit)
    232 http fetch GET 200 https://registry.npmjs.org/uuid 112ms (cache hit)
    233 http fetch GET 200 https://registry.npmjs.org/iconv-lite 112ms (cache hit)
    234 http fetch GET 200 https://registry.npmjs.org/@node-red%2fregistry 111ms (cache hit)
    235 http fetch GET 200 https://registry.npmjs.org/async-mutex 112ms (cache hit)
    236 http fetch GET 200 https://registry.npmjs.org/i18next 113ms (cache hit)
    237 http fetch GET 200 https://registry.npmjs.org/lodash.clonedeep 125ms (cache hit)
    238 http fetch GET 200 https://registry.npmjs.org/moment 126ms (cache hit)
    239 http fetch GET 200 https://registry.npmjs.org/moment-timezone 126ms (cache hit)
    240 http fetch GET 200 https://registry.npmjs.org/node-addon-api 126ms (cache hit)
    241 http fetch GET 200 https://registry.npmjs.org/ansi-colors 126ms (cache hit)
    242 http fetch GET 200 https://registry.npmjs.org/mime 149ms (cache hit)
    243 http fetch GET 200 https://registry.npmjs.org/axios 126ms (cache hit)
    244 http fetch GET 200 https://registry.npmjs.org/cli-table 127ms (cache hit)
    245 http fetch GET 200 https://registry.npmjs.org/enquirer 127ms (cache hit)
    246 http fetch GET 200 https://registry.npmjs.org/mustache 127ms (cache hit)
    247 timing idealTree:node_modules/node-red Completed in 168ms
    248 silly fetch manifest bufferutil@^4.0.1
    249 http fetch GET 200 https://registry.npmjs.org/bufferutil 8ms (cache hit)
    250 silly fetch manifest utf-8-validate@^5.0.2
    251 http fetch GET 200 https://registry.npmjs.org/utf-8-validate 2ms (cache hit)
    252 silly placeDep ROOT @node-red/editor-client@3.0.2 OK for: @node-red/editor-api@3.0.2 want: 3.0.2
    253 silly placeDep ROOT clone@2.1.2 OK for: @node-red/editor-api@3.0.2 want: 2.1.2
    254 silly placeDep ROOT express-session@1.17.3 OK for: @node-red/editor-api@3.0.2 want: 1.17.3
    255 silly placeDep ROOT memorystore@1.6.7 OK for: @node-red/editor-api@3.0.2 want: 1.6.7
    256 silly placeDep node_modules/@node-red/editor-api mime@3.0.0 OK for: @node-red/editor-api@3.0.2 want: 3.0.0
    257 silly placeDep ROOT multer@1.4.5-lts.1 OK for: @node-red/editor-api@3.0.2 want: 1.4.5-lts.1
    258 silly placeDep ROOT mustache@4.2.0 OK for: @node-red/editor-api@3.0.2 want: 4.2.0
    259 silly placeDep ROOT oauth2orize@1.11.1 OK for: @node-red/editor-api@3.0.2 want: 1.11.1
    260 silly placeDep ROOT passport@0.6.0 OK for: @node-red/editor-api@3.0.2 want: 0.6.0
    261 silly placeDep ROOT passport-http-bearer@1.0.1 OK for: @node-red/editor-api@3.0.2 want: 1.0.1
    262 silly placeDep ROOT passport-oauth2-client-password@0.1.2 OK for: @node-red/editor-api@3.0.2 want: 0.1.2
    263 silly placeDep node_modules/@node-red/editor-api ws@7.5.6 OK for: @node-red/editor-api@3.0.2 want: 7.5.6
    264 silly fetch manifest cookie@0.4.2
    265 silly fetch manifest depd@~2.0.0
    266 silly fetch manifest safe-buffer@5.2.1
    267 silly fetch manifest debug@^4.3.0
    268 silly fetch manifest lru-cache@^4.0.3
    269 silly fetch manifest append-field@^1.0.0
    270 silly fetch manifest mkdirp@^0.5.4
    271 silly fetch manifest uid2@0.0.x
    272 http fetch GET 200 https://registry.npmjs.org/cookie 35ms (cache hit)
    273 http fetch GET 200 https://registry.npmjs.org/depd 36ms (cache hit)
    274 http fetch GET 200 https://registry.npmjs.org/safe-buffer 35ms (cache hit)
    275 http fetch GET 200 https://registry.npmjs.org/debug 36ms (cache hit)
    276 http fetch GET 200 https://registry.npmjs.org/lru-cache 35ms (cache hit)
    277 http fetch GET 200 https://registry.npmjs.org/append-field 29ms (cache hit)
    278 http fetch GET 200 https://registry.npmjs.org/mkdirp 29ms (cache hit)
    279 http fetch GET 200 https://registry.npmjs.org/uid2 29ms (cache hit)
    280 timing idealTree:node_modules/@node-red/editor-api Completed in 78ms
    281 timing idealTree:node_modules/@node-red/editor-client Completed in 0ms
    282 silly placeDep node_modules/@node-red/nodes acorn-walk@8.2.0 OK for: @node-red/nodes@3.0.2 want: 8.2.0
    283 silly placeDep node_modules/@node-red/nodes ajv@8.11.0 OK for: @node-red/nodes@3.0.2 want: 8.11.0
    284 silly placeDep ROOT cheerio@1.0.0-rc.10 OK for: @node-red/nodes@3.0.2 want: 1.0.0-rc.10
    285 silly placeDep ROOT cronosjs@1.7.1 OK for: @node-red/nodes@3.0.2 want: 1.7.1
    286 silly placeDep node_modules/@node-red/nodes denque@2.1.0 OK for: @node-red/nodes@3.0.2 want: 2.1.0
    287 silly placeDep node_modules/@node-red/nodes form-data@4.0.0 OK for: @node-red/nodes@3.0.2 want: 4.0.0
    288 silly placeDep node_modules/@node-red/nodes got@11.8.5 OK for: @node-red/nodes@3.0.2 want: 11.8.5
    289 silly placeDep ROOT hash-sum@2.0.0 OK for: @node-red/nodes@3.0.2 want: 2.0.0
    290 silly placeDep ROOT hpagent@1.0.0 OK for: @node-red/nodes@3.0.2 want: 1.0.0
    291 silly placeDep ROOT https-proxy-agent@5.0.1 REPLACE for: @node-red/nodes@3.0.2 want: 5.0.1
    292 silly placeDep node_modules/@node-red/nodes iconv-lite@0.6.3 OK for: @node-red/nodes@3.0.2 want: 0.6.3
    293 silly placeDep ROOT is-utf8@0.2.1 OK for: @node-red/nodes@3.0.2 want: 0.2.1
    294 silly placeDep node_modules/@node-red/nodes js-yaml@4.1.0 OK for: @node-red/nodes@3.0.2 want: 4.1.0
    295 silly placeDep node_modules/@node-red/nodes media-typer@1.1.0 OK for: @node-red/nodes@3.0.2 want: 1.1.0
    296 silly placeDep ROOT mqtt@4.3.7 OK for: @node-red/nodes@3.0.2 want: 4.3.7
    297 silly placeDep ROOT node-watch@0.7.3 OK for: @node-red/nodes@3.0.2 want: 0.7.3
    298 silly placeDep node_modules/@node-red/nodes tough-cookie@4.0.0 OK for: @node-red/nodes@3.0.2 want: 4.0.0
    299 silly placeDep node_modules/@node-red/nodes uuid@8.3.2 OK for: @node-red/nodes@3.0.2 want: 8.3.2
    300 silly placeDep node_modules/@node-red/nodes ws@7.5.6 OK for: @node-red/nodes@3.0.2 want: 7.5.6
    301 silly fetch manifest json-schema-traverse@^1.0.0
    302 silly fetch manifest require-from-string@^2.0.2
    303 silly fetch manifest cheerio-select@^1.5.0
    304 silly fetch manifest dom-serializer@^1.3.2
    305 silly fetch manifest domhandler@^4.2.0
    306 silly fetch manifest htmlparser2@^6.1.0
    307 silly fetch manifest tslib@^2.2.0
    308 silly fetch manifest @sindresorhus/is@^4.0.0
    309 silly fetch manifest cacheable-lookup@^5.0.3
    310 silly fetch manifest decompress-response@^6.0.0
    311 silly fetch manifest argparse@^2.0.1
    312 silly fetch manifest concat-stream@^2.0.0
    313 silly fetch manifest debug@^4.1.1
    314 silly fetch manifest duplexify@^4.1.1
    315 silly fetch manifest readable-stream@^3.6.0
    316 silly fetch manifest ws@^7.5.5
    317 silly fetch manifest universalify@^0.1.2
    318 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 53ms (cache hit)
    319 http fetch GET 200 https://registry.npmjs.org/require-from-string 53ms (cache hit)
    320 http fetch GET 200 https://registry.npmjs.org/cheerio-select 53ms (cache hit)
    321 http fetch GET 200 https://registry.npmjs.org/dom-serializer 53ms (cache hit)
    322 http fetch GET 200 https://registry.npmjs.org/domhandler 50ms (cache hit)
    323 http fetch GET 200 https://registry.npmjs.org/htmlparser2 52ms (cache hit)
    324 http fetch GET 200 https://registry.npmjs.org/tslib 61ms (cache hit)
    325 http fetch GET 200 https://registry.npmjs.org/@sindresorhus%2fis 61ms (cache hit)
    326 http fetch GET 200 https://registry.npmjs.org/cacheable-lookup 62ms (cache hit)
    327 http fetch GET 200 https://registry.npmjs.org/decompress-response 56ms (cache hit)
    328 http fetch GET 200 https://registry.npmjs.org/argparse 55ms (cache hit)
    329 http fetch GET 200 https://registry.npmjs.org/concat-stream 56ms (cache hit)
    330 http fetch GET 200 https://registry.npmjs.org/duplexify 55ms (cache hit)
    331 http fetch GET 200 https://registry.npmjs.org/readable-stream 57ms (cache hit)
    332 http fetch GET 200 https://registry.npmjs.org/universalify 59ms (cache hit)
    333 timing idealTree:node_modules/@node-red/nodes Completed in 116ms
    334 silly placeDep ROOT @node-red/registry@3.0.2 OK for: @node-red/runtime@3.0.2 want: 3.0.2
    335 silly placeDep ROOT async-mutex@0.3.2 OK for: @node-red/runtime@3.0.2 want: 0.3.2
    336 silly fetch manifest uglify-js@3.16.3
    337 silly fetch manifest tslib@^2.3.1
    338 http fetch GET 200 https://registry.npmjs.org/uglify-js 3ms (cache hit)
    339 timing idealTree:node_modules/@node-red/runtime Completed in 16ms
    340 silly placeDep ROOT uglify-js@3.16.3 OK for: @node-red/registry@3.0.2 want: 3.16.3
    341 timing idealTree:node_modules/@node-red/registry Completed in 1ms
    342 silly placeDep ROOT i18next@21.8.16 OK for: @node-red/util@3.0.2 want: 21.8.16
    343 silly placeDep ROOT lodash.clonedeep@4.5.0 OK for: @node-red/util@3.0.2 want: ^4.5.0
    344 silly placeDep ROOT moment@2.29.4 REPLACE for: @node-red/util@3.0.2 want: 2.29.4
    345 silly placeDep ROOT moment-timezone@0.5.34 REPLACE for: @node-red/util@3.0.2 want: 0.5.34
    346 silly fetch manifest @babel/runtime@^7.17.2
    347 http fetch GET 200 https://registry.npmjs.org/@babel%2fruntime 2ms (cache hit)
    348 timing idealTree:node_modules/@node-red/util Completed in 11ms
    349 silly placeDep node_modules/async-mutex tslib@2.4.0 OK for: async-mutex@0.3.2 want: ^2.3.1
    350 timing idealTree:node_modules/async-mutex Completed in 1ms
    351 timing idealTree:node_modules/basic-auth Completed in 0ms
    352 silly placeDep ROOT node-addon-api@3.2.1 OK for: bcrypt@5.0.1 want: ^3.1.0
    353 timing idealTree:node_modules/bcrypt Completed in 2ms
    354 timing idealTree:node_modules/bcryptjs Completed in 0ms
    355 silly placeDep ROOT cheerio-select@1.6.0 OK for: cheerio@1.0.0-rc.10 want: ^1.5.0
    356 silly placeDep ROOT dom-serializer@1.4.1 OK for: cheerio@1.0.0-rc.10 want: ^1.3.2
    357 silly placeDep ROOT domhandler@4.3.1 OK for: cheerio@1.0.0-rc.10 want: ^4.2.0
    358 silly placeDep ROOT htmlparser2@6.1.0 OK for: cheerio@1.0.0-rc.10 want: ^6.1.0
    359 silly placeDep node_modules/cheerio tslib@2.4.0 OK for: cheerio@1.0.0-rc.10 want: ^2.2.0
    360 silly fetch manifest css-select@^4.3.0
    361 silly fetch manifest css-what@^6.0.1
    362 silly fetch manifest domelementtype@^2.2.0
    363 silly fetch manifest domutils@^2.8.0
    364 silly fetch manifest domelementtype@^2.0.1
    365 silly fetch manifest entities@^2.0.0
    366 silly fetch manifest domutils@^2.5.2
    367 http fetch GET 200 https://registry.npmjs.org/css-select 31ms (cache hit)
    368 http fetch GET 200 https://registry.npmjs.org/css-what 28ms (cache hit)
    369 http fetch GET 200 https://registry.npmjs.org/domelementtype 26ms (cache hit)
    370 http fetch GET 200 https://registry.npmjs.org/domutils 26ms (cache hit)
    371 http fetch GET 200 https://registry.npmjs.org/domelementtype 27ms (cache hit)
    372 http fetch GET 200 https://registry.npmjs.org/entities 26ms (cache hit)
    373 http fetch GET 200 https://registry.npmjs.org/domutils 26ms (cache hit)
    374 timing idealTree:node_modules/cheerio Completed in 41ms
    375 silly placeDep ROOT css-select@4.3.0 OK for: cheerio-select@1.6.0 want: ^4.3.0
    376 silly placeDep ROOT css-what@6.1.0 OK for: cheerio-select@1.6.0 want: ^6.0.1
    377 silly placeDep ROOT domelementtype@2.3.0 OK for: cheerio-select@1.6.0 want: ^2.2.0
    378 silly placeDep ROOT domutils@2.8.0 OK for: cheerio-select@1.6.0 want: ^2.8.0
    379 silly fetch manifest boolbase@^1.0.0
    380 silly fetch manifest nth-check@^2.0.1
    381 http fetch GET 200 https://registry.npmjs.org/boolbase 6ms (cache hit)
    382 http fetch GET 200 https://registry.npmjs.org/nth-check 6ms (cache hit)
    383 timing idealTree:node_modules/cheerio-select Completed in 16ms
    384 timing idealTree:node_modules/clone Completed in 0ms
    385 timing idealTree:node_modules/cronosjs Completed in 0ms
    386 silly placeDep ROOT boolbase@1.0.0 OK for: css-select@4.3.0 want: ^1.0.0
    387 silly placeDep ROOT nth-check@2.1.1 OK for: css-select@4.3.0 want: ^2.0.1
    388 timing idealTree:node_modules/css-select Completed in 5ms
    389 timing idealTree:node_modules/boolbase Completed in 1ms
    390 timing idealTree:node_modules/css-what Completed in 0ms
    391 silly placeDep ROOT entities@2.2.0 OK for: dom-serializer@1.4.1 want: ^2.0.0
    392 timing idealTree:node_modules/dom-serializer Completed in 2ms
    393 timing idealTree:node_modules/domelementtype Completed in 0ms
    394 timing idealTree:node_modules/domhandler Completed in 0ms
    395 timing idealTree:node_modules/domutils Completed in 0ms
    396 timing idealTree:node_modules/entities Completed in 0ms
    397 silly placeDep node_modules/express-session cookie@0.4.2 OK for: express-session@1.17.3 want: 0.4.2
    398 silly placeDep node_modules/express-session depd@2.0.0 OK for: express-session@1.17.3 want: ~2.0.0
    399 silly placeDep node_modules/express-session safe-buffer@5.2.1 OK for: express-session@1.17.3 want: 5.2.1
    400 timing idealTree:node_modules/express-session Completed in 2ms
    401 timing idealTree:node_modules/hash-sum Completed in 1ms
    402 timing idealTree:node_modules/hpagent Completed in 0ms
    403 timing idealTree:node_modules/htmlparser2 Completed in 0ms
    404 timing idealTree:node_modules/https-proxy-agent Completed in 0ms
    405 silly placeDep ROOT @babel/runtime@7.18.9 OK for: i18next@21.8.16 want: ^7.17.2
    406 silly fetch manifest regenerator-runtime@^0.13.4
    407 http fetch GET 200 https://registry.npmjs.org/regenerator-runtime 3ms (cache hit)
    408 timing idealTree:node_modules/i18next Completed in 8ms
    409 silly placeDep ROOT regenerator-runtime@0.13.9 OK for: @babel/runtime@7.18.9 want: ^0.13.4
    410 timing idealTree:node_modules/@babel/runtime Completed in 3ms
    411 timing idealTree:node_modules/is-utf8 Completed in 0ms
    412 timing idealTree:node_modules/lodash.clonedeep Completed in 0ms
    413 silly placeDep node_modules/memorystore debug@4.3.4 OK for: memorystore@1.6.7 want: ^4.3.0
    414 silly placeDep node_modules/memorystore lru-cache@4.1.5 OK for: memorystore@1.6.7 want: ^4.0.3
    415 silly fetch manifest ms@2.1.2
    416 silly fetch manifest pseudomap@^1.0.2
    417 silly fetch manifest yallist@^2.1.2
    418 http fetch GET 200 https://registry.npmjs.org/ms 8ms (cache hit)
    419 http fetch GET 200 https://registry.npmjs.org/pseudomap 8ms (cache hit)
    420 http fetch GET 200 https://registry.npmjs.org/yallist 8ms (cache hit)
    421 timing idealTree:node_modules/memorystore Completed in 12ms
    422 timing idealTree:node_modules/moment Completed in 0ms
    423 timing idealTree:node_modules/moment-timezone Completed in 0ms
    424 silly placeDep node_modules/mqtt concat-stream@2.0.0 OK for: mqtt@4.3.7 want: ^2.0.0
    425 silly placeDep node_modules/mqtt debug@4.3.4 OK for: mqtt@4.3.7 want: ^4.1.1
    426 silly placeDep node_modules/mqtt duplexify@4.1.2 OK for: mqtt@4.3.7 want: ^4.1.1
    427 silly placeDep node_modules/mqtt readable-stream@3.6.0 OK for: mqtt@4.3.7 want: ^3.6.0
    428 silly placeDep node_modules/mqtt ws@7.5.9 OK for: mqtt@4.3.7 want: ^7.5.5
    429 timing idealTree:node_modules/mqtt Completed in 7ms
    430 silly placeDep ROOT append-field@1.0.0 OK for: multer@1.4.5-lts.1 want: ^1.0.0
    431 silly placeDep ROOT mkdirp@0.5.6 OK for: multer@1.4.5-lts.1 want: ^0.5.4
    432 timing idealTree:node_modules/multer Completed in 3ms
    433 timing idealTree:node_modules/append-field Completed in 0ms
    434 timing idealTree:node_modules/mkdirp Completed in 0ms
    435 timing idealTree:node_modules/mustache Completed in 0ms
    436 timing idealTree:node_modules/node-addon-api Completed in 0ms
    437 silly placeDep ROOT ansi-colors@4.1.3 OK for: node-red-admin@3.0.0 want: ^4.1.1
    438 silly placeDep node_modules/node-red-admin axios@0.27.2 OK for: node-red-admin@3.0.0 want: 0.27.2
    439 silly placeDep ROOT cli-table@0.3.11 OK for: node-red-admin@3.0.0 want: ^0.3.11
    440 silly placeDep ROOT enquirer@2.3.6 OK for: node-red-admin@3.0.0 want: ^2.3.6
    441 silly fetch manifest form-data@^4.0.0
    442 silly fetch manifest colors@1.0.3
    443 http fetch GET 200 https://registry.npmjs.org/colors 9ms (cache hit)
    444 timing idealTree:node_modules/node-red-admin Completed in 23ms
    445 timing idealTree:node_modules/ansi-colors Completed in 0ms
    446 silly placeDep node_modules/cli-table colors@1.0.3 OK for: cli-table@0.3.11 want: 1.0.3
    447 timing idealTree:node_modules/cli-table Completed in 1ms
    448 timing idealTree:node_modules/enquirer Completed in 0ms
    449 timing idealTree:node_modules/node-red-node-email Completed in 0ms
    450 timing idealTree:node_modules/node-red-node-feedparser Completed in 0ms
    451 timing idealTree:node_modules/node-watch Completed in 0ms
    452 timing idealTree:node_modules/nth-check Completed in 0ms
    453 silly placeDep ROOT uid2@0.0.4 OK for: oauth2orize@1.11.1 want: 0.0.x
    454 timing idealTree:node_modules/oauth2orize Completed in 2ms
    455 timing idealTree:node_modules/passport Completed in 0ms
    456 timing idealTree:node_modules/passport-http-bearer Completed in 0ms
    457 timing idealTree:node_modules/passport-oauth2-client-password Completed in 0ms
    458 timing idealTree:node_modules/regenerator-runtime Completed in 0ms
    459 timing idealTree:node_modules/retry Completed in 0ms
    460 silly placeDep ROOT sparse-bitfield@3.0.3 OK for: saslprep@1.0.3 want: ^3.0.3
    461 silly fetch manifest memory-pager@^1.0.2
    462 http fetch GET 200 https://registry.npmjs.org/memory-pager 3ms (cache hit)
    463 timing idealTree:node_modules/saslprep Completed in 8ms
    464 timing idealTree:node_modules/semver Completed in 0ms
    465 silly placeDep node_modules/socks ip@2.0.0 OK for: socks@2.7.0 want: ^2.0.0
    466 silly placeDep ROOT smart-buffer@4.2.0 OK for: socks@2.7.0 want: ^4.2.0
    467 timing idealTree:node_modules/socks Completed in 3ms
    468 timing idealTree:node_modules/smart-buffer Completed in 0ms
    469 silly placeDep ROOT memory-pager@1.5.0 OK for: sparse-bitfield@3.0.3 want: ^1.0.2
    470 timing idealTree:node_modules/sparse-bitfield Completed in 3ms
    471 timing idealTree:node_modules/memory-pager Completed in 0ms
    472 timing idealTree:node_modules/uglify-js Completed in 0ms
    473 timing idealTree:node_modules/uid2 Completed in 0ms
    474 timing idealTree:node_modules/@node-red/editor-api/node_modules/mime Completed in 0ms
    475 timing idealTree:node_modules/@node-red/editor-api/node_modules/ws Completed in 0ms
    476 timing idealTree:node_modules/@node-red/nodes/node_modules/acorn-walk Completed in 0ms
    477 silly placeDep node_modules/@node-red/nodes json-schema-traverse@1.0.0 OK for: ajv@8.11.0 want: ^1.0.0
    478 silly placeDep ROOT require-from-string@2.0.2 OK for: ajv@8.11.0 want: ^2.0.2
    479 timing idealTree:node_modules/@node-red/nodes/node_modules/ajv Completed in 3ms
    480 timing idealTree:node_modules/require-from-string Completed in 0ms
    481 timing idealTree:node_modules/@node-red/nodes/node_modules/denque Completed in 0ms
    482 timing idealTree:node_modules/@node-red/nodes/node_modules/form-data Completed in 0ms
    483 silly placeDep node_modules/@node-red/nodes @sindresorhus/is@4.6.0 OK for: got@11.8.5 want: ^4.0.0
    484 silly placeDep node_modules/@node-red/nodes cacheable-lookup@5.0.4 OK for: got@11.8.5 want: ^5.0.3
    485 silly placeDep node_modules/@node-red/nodes decompress-response@6.0.0 OK for: got@11.8.5 want: ^6.0.0
    486 silly fetch manifest mimic-response@^3.1.0
    487 http fetch GET 200 https://registry.npmjs.org/mimic-response 3ms (cache hit)
    488 timing idealTree:node_modules/@node-red/nodes/node_modules/got Completed in 16ms
    489 timing idealTree:node_modules/@node-red/nodes/node_modules/@sindresorhus/is Completed in 0ms
    490 timing idealTree:node_modules/@node-red/nodes/node_modules/cacheable-lookup Completed in 0ms
    491 silly placeDep node_modules/@node-red/nodes mimic-response@3.1.0 OK for: decompress-response@6.0.0 want: ^3.1.0
    492 timing idealTree:node_modules/@node-red/nodes/node_modules/decompress-response Completed in 19ms
    493 timing idealTree:node_modules/@node-red/nodes/node_modules/iconv-lite Completed in 0ms
    494 silly placeDep node_modules/@node-red/nodes argparse@2.0.1 OK for: js-yaml@4.1.0 want: ^2.0.1
    495 timing idealTree:node_modules/@node-red/nodes/node_modules/js-yaml Completed in 2ms
    496 timing idealTree:node_modules/@node-red/nodes/node_modules/argparse Completed in 0ms
    497 timing idealTree:node_modules/@node-red/nodes/node_modules/json-schema-traverse Completed in 0ms
    498 timing idealTree:node_modules/@node-red/nodes/node_modules/media-typer Completed in 0ms
    499 timing idealTree:node_modules/@node-red/nodes/node_modules/mimic-response Completed in 0ms
    500 silly placeDep node_modules/@node-red/nodes universalify@0.1.2 OK for: tough-cookie@4.0.0 want: ^0.1.2
    501 timing idealTree:node_modules/@node-red/nodes/node_modules/tough-cookie Completed in 1ms
    502 timing idealTree:node_modules/@node-red/nodes/node_modules/universalify Completed in 0ms
    503 timing idealTree:node_modules/@node-red/nodes/node_modules/uuid Completed in 0ms
    504 timing idealTree:node_modules/@node-red/nodes/node_modules/ws Completed in 0ms
    505 timing idealTree:node_modules/async-mutex/node_modules/tslib Completed in 0ms
    506 timing idealTree:node_modules/bson/node_modules/buffer Completed in 0ms
    507 timing idealTree:node_modules/cheerio/node_modules/tslib Completed in 0ms
    508 timing idealTree:node_modules/cli-table/node_modules/colors Completed in 0ms
    509 timing idealTree:node_modules/express-session/node_modules/cookie Completed in 0ms
    510 timing idealTree:node_modules/express-session/node_modules/depd Completed in 0ms
    511 timing idealTree:node_modules/express-session/node_modules/safe-buffer Completed in 0ms
    512 timing idealTree:node_modules/fs.notify/node_modules/async Completed in 0ms
    513 silly placeDep node_modules/memorystore ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    514 timing idealTree:node_modules/memorystore/node_modules/debug Completed in 1ms
    515 silly placeDep ROOT pseudomap@1.0.2 OK for: lru-cache@4.1.5 want: ^1.0.2
    516 silly placeDep node_modules/memorystore yallist@2.1.2 OK for: lru-cache@4.1.5 want: ^2.1.2
    517 timing idealTree:node_modules/memorystore/node_modules/lru-cache Completed in 3ms
    518 timing idealTree:node_modules/pseudomap Completed in 0ms
    519 timing idealTree:node_modules/memorystore/node_modules/ms Completed in 0ms
    520 timing idealTree:node_modules/memorystore/node_modules/yallist Completed in 0ms
    521 timing idealTree:node_modules/mongodb-connection-string-url/node_modules/whatwg-url Completed in 0ms
    522 timing idealTree:node_modules/mongodb/node_modules/denque Completed in 0ms
    523 timing idealTree:node_modules/mqtt/node_modules/concat-stream Completed in 0ms
    524 silly placeDep node_modules/mqtt ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
    525 timing idealTree:node_modules/mqtt/node_modules/debug Completed in 1ms
    526 timing idealTree:node_modules/mqtt/node_modules/duplexify Completed in 0ms
    527 timing idealTree:node_modules/mqtt/node_modules/ms Completed in 0ms
    528 timing idealTree:node_modules/mqtt/node_modules/readable-stream Completed in 0ms
    529 timing idealTree:node_modules/mqtt/node_modules/ws Completed in 0ms
    530 silly placeDep node_modules/node-red-admin form-data@4.0.0 OK for: axios@0.27.2 want: ^4.0.0
    531 timing idealTree:node_modules/node-red-admin/node_modules/axios Completed in 1ms
    532 timing idealTree:node_modules/node-red-admin/node_modules/form-data Completed in 0ms
    533 timing idealTree:node_modules/socks/node_modules/ip Completed in 0ms
    534 timing idealTree:buildDeps Completed in 2232ms
    535 timing idealTree:fixDepFlags Completed in 14ms
    536 timing idealTree Completed in 3573ms
    537 timing reify:loadTrees Completed in 3575ms
    538 timing reify:diffTrees Completed in 42ms
    539 silly reify mark retired [ '/opt/iobroker/node_modules/addressparser' ]
    540 silly reify mark retired [ '/opt/iobroker/node_modules/ansi-colors' ]
    541 silly reify mark retired [ '/opt/iobroker/node_modules/append-field' ]
    542 silly reify mark retired [ '/opt/iobroker/node_modules/array-indexofobject' ]
    543 silly reify mark retired [ '/opt/iobroker/node_modules/async-mutex/node_modules/tslib' ]
    544 silly reify mark retired [ '/opt/iobroker/node_modules/bcryptjs' ]
    545 silly reify mark retired [ '/opt/iobroker/node_modules/boolbase' ]
    546 silly reify mark retired [ '/opt/iobroker/node_modules/bson' ]
    547 silly reify mark retired [ '/opt/iobroker/node_modules/cheerio/node_modules/cheerio-select' ]
    548 silly reify mark retired [ '/opt/iobroker/node_modules/cheerio/node_modules/tslib' ]
    549 silly reify mark retired [ '/opt/iobroker/node_modules/cheerio-select' ]
    550 silly reify mark retired [ '/opt/iobroker/node_modules/cli-table/node_modules/colors' ]
    551 silly reify mark retired [ '/opt/iobroker/node_modules/clone' ]
    552 silly reify mark retired [ '/opt/iobroker/node_modules/destroy' ]
    553 silly reify mark retired [ '/opt/iobroker/node_modules/express-session' ]
    554 silly reify mark retired [ '/opt/iobroker/node_modules/finalhandler' ]
    555 silly reify mark retired [ '/opt/iobroker/node_modules/fs.notify' ]
    556 silly reify mark retired [ '/opt/iobroker/node_modules/hpagent' ]
    557 silly reify mark retired [ '/opt/iobroker/node_modules/https-proxy-agent' ]
    558 silly reify mark retired [ '/opt/iobroker/node_modules/i18next' ]
    559 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin/node_modules/depd' ]
    560 silly reify mark retired [
    560 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/express-session'
    560 silly reify ]
    561 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin/node_modules/passport' ]
    562 silly reify mark retired [
    562 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer'
    562 silly reify ]
    563 silly reify mark retired [
    563 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/semver',
    563 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/.bin/semver'
    563 silly reify ]
    564 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.cloud/node_modules/passport' ]
    565 silly reify mark retired [
    565 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
    565 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
    565 silly reify ]
    566 silly reify mark retired [
    566 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/concat-stream'
    566 silly reify ]
    567 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/debug' ]
    568 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/duplexify' ]
    569 silly reify mark retired [
    569 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt',
    569 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt_pub',
    569 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt_sub',
    569 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt'
    569 silly reify ]
    570 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/ms' ]
    571 silly reify mark retired [
    571 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream'
    571 silly reify ]
    572 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.node-red' ]
    573 silly reify mark retired [
    573 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/cheerio'
    573 silly reify ]
    574 silly reify mark retired [
    574 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/dom-serializer'
    574 silly reify ]
    575 silly reify mark retired [
    575 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domelementtype'
    575 silly reify ]
    576 silly reify mark retired [
    576 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domhandler'
    576 silly reify ]
    577 silly reify mark retired [
    577 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domutils'
    577 silly reify ]
    578 silly reify mark retired [
    578 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/entities'
    578 silly reify ]
    579 silly reify mark retired [
    579 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/htmlparser2'
    579 silly reify ]
    580 silly reify mark retired [
    580 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/tslib'
    580 silly reify ]
    581 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.socketio/node_modules/cookie' ]
    582 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.socketio/node_modules/depd' ]
    583 silly reify mark retired [
    583 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/express-session'
    583 silly reify ]
    584 silly reify mark retired [
    584 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/safe-buffer'
    584 silly reify ]
    585 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.web/node_modules/cookie' ]
    586 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.web/node_modules/depd' ]
    587 silly reify mark retired [
    587 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/express-session'
    587 silly reify ]
    588 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.web/node_modules/passport' ]
    589 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.web/node_modules/safe-buffer' ]
    590 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ws/node_modules/cookie' ]
    591 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ws/node_modules/depd' ]
    592 silly reify mark retired [
    592 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/express-session'
    592 silly reify ]
    593 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ws/node_modules/safe-buffer' ]
    594 silly reify mark retired [ '/opt/iobroker/node_modules/is-utf8' ]
    595 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.assign' ]
    596 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.clonedeep' ]
    597 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.get' ]
    598 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.has' ]
    599 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.uniq' ]
    600 silly reify mark retired [ '/opt/iobroker/node_modules/memorystore/node_modules/yallist' ]
    601 silly reify mark retired [ '/opt/iobroker/node_modules/moment' ]
    602 silly reify mark retired [ '/opt/iobroker/node_modules/moment-timezone' ]
    603 silly reify mark retired [ '/opt/iobroker/node_modules/mongodb' ]
    604 silly reify mark retired [ '/opt/iobroker/node_modules/mongodb-connection-string-url' ]
    605 silly reify mark retired [
    605 silly reify   '/opt/iobroker/node_modules/mqtt',
    605 silly reify   '/opt/iobroker/node_modules/.bin/mqtt_pub',
    605 silly reify   '/opt/iobroker/node_modules/.bin/mqtt_sub',
    605 silly reify   '/opt/iobroker/node_modules/.bin/mqtt'
    605 silly reify ]
    606 silly reify mark retired [ '/opt/iobroker/node_modules/multer' ]
    607 silly reify mark retired [
    607 silly reify   '/opt/iobroker/node_modules/node-red',
    607 silly reify   '/opt/iobroker/node_modules/.bin/node-red',
    607 silly reify   '/opt/iobroker/node_modules/.bin/node-red-pi'
    607 silly reify ]
    608 silly reify mark retired [
    608 silly reify   '/opt/iobroker/node_modules/node-red-admin',
    608 silly reify   '/opt/iobroker/node_modules/.bin/node-red-admin'
    608 silly reify ]
    609 silly reify mark retired [ '/opt/iobroker/node_modules/node-red-node-email' ]
    610 silly reify mark retired [ '/opt/iobroker/node_modules/node-red-node-feedparser' ]
    611 silly reify mark retired [ '/opt/iobroker/node_modules/nth-check' ]
    612 silly reify mark retired [ '/opt/iobroker/node_modules/on-finished' ]
    613 silly reify mark retired [ '/opt/iobroker/node_modules/passport' ]
    614 silly reify mark retired [ '/opt/iobroker/node_modules/passport-http-bearer' ]
    615 silly reify mark retired [ '/opt/iobroker/node_modules/passport-oauth2-client-password' ]
    616 silly reify mark retired [ '/opt/iobroker/node_modules/pseudomap' ]
    617 silly reify mark retired [ '/opt/iobroker/node_modules/retry' ]
    618 silly reify mark retired [
    618 silly reify   '/opt/iobroker/node_modules/semver',
    618 silly reify   '/opt/iobroker/node_modules/.bin/semver'
    618 silly reify ]
    619 silly reify mark retired [
    619 silly reify   '/opt/iobroker/node_modules/sharp/node_modules/semver',
    619 silly reify   '/opt/iobroker/node_modules/sharp/node_modules/.bin/semver'
    619 silly reify ]
    620 silly reify mark retired [ '/opt/iobroker/node_modules/socks' ]
    621 silly reify mark retired [ '/opt/iobroker/node_modules/sparse-bitfield' ]
    622 silly reify mark retired [ '/opt/iobroker/node_modules/statuses' ]
    623 silly reify mark retired [ '/opt/iobroker/node_modules/streamsearch' ]
    624 silly reify mark retired [
    624 silly reify   '/opt/iobroker/node_modules/uglify-js',
    624 silly reify   '/opt/iobroker/node_modules/.bin/uglifyjs'
    624 silly reify ]
    625 silly reify mark retired [ '/opt/iobroker/node_modules/@babel/runtime' ]
    626 silly reify mark retired [
    626 silly reify   '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/passport'
    626 silly reify ]
    627 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/editor-api' ]
    628 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/editor-client' ]
    629 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/nodes' ]
    630 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/registry' ]
    631 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/runtime' ]
    632 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/util' ]
    633 silly reify mark retired [ '/opt/iobroker/node_modules/@types/whatwg-url' ]
    634 silly reify moves {
    634 silly reify   '/opt/iobroker/node_modules/addressparser': '/opt/iobroker/node_modules/.addressparser-qF9vtHFg',
    634 silly reify   '/opt/iobroker/node_modules/ansi-colors': '/opt/iobroker/node_modules/.ansi-colors-qAZfUuTD',
    634 silly reify   '/opt/iobroker/node_modules/append-field': '/opt/iobroker/node_modules/.append-field-e9miM7oT',
    634 silly reify   '/opt/iobroker/node_modules/array-indexofobject': '/opt/iobroker/node_modules/.array-indexofobject-CZUmKBfr',
    634 silly reify   '/opt/iobroker/node_modules/async-mutex/node_modules/tslib': '/opt/iobroker/node_modules/async-mutex/node_modules/.tslib-rMDsFAkc',
    634 silly reify   '/opt/iobroker/node_modules/bcryptjs': '/opt/iobroker/node_modules/.bcryptjs-aQgtHtN0',
    634 silly reify   '/opt/iobroker/node_modules/boolbase': '/opt/iobroker/node_modules/.boolbase-8130XECE',
    634 silly reify   '/opt/iobroker/node_modules/bson': '/opt/iobroker/node_modules/.bson-a4WfR2fa',
    634 silly reify   '/opt/iobroker/node_modules/cheerio/node_modules/cheerio-select': '/opt/iobroker/node_modules/cheerio/node_modules/.cheerio-select-27vO1B1R',
    634 silly reify   '/opt/iobroker/node_modules/cheerio/node_modules/tslib': '/opt/iobroker/node_modules/cheerio/node_modules/.tslib-EZxPbhJ8',
    634 silly reify   '/opt/iobroker/node_modules/cheerio-select': '/opt/iobroker/node_modules/.cheerio-select-Y5sIvfLc',
    634 silly reify   '/opt/iobroker/node_modules/cli-table/node_modules/colors': '/opt/iobroker/node_modules/cli-table/node_modules/.colors-cJQgsQ1G',
    634 silly reify   '/opt/iobroker/node_modules/clone': '/opt/iobroker/node_modules/.clone-p3TMAGgu',
    634 silly reify   '/opt/iobroker/node_modules/destroy': '/opt/iobroker/node_modules/.destroy-ZfJpRRrp',
    634 silly reify   '/opt/iobroker/node_modules/express-session': '/opt/iobroker/node_modules/.express-session-u0QSDs0s',
    634 silly reify   '/opt/iobroker/node_modules/finalhandler': '/opt/iobroker/node_modules/.finalhandler-YHTUOEck',
    634 silly reify   '/opt/iobroker/node_modules/fs.notify': '/opt/iobroker/node_modules/.fs.notify-C4n80h6t',
    634 silly reify   '/opt/iobroker/node_modules/hpagent': '/opt/iobroker/node_modules/.hpagent-PUXuWBzq',
    634 silly reify   '/opt/iobroker/node_modules/https-proxy-agent': '/opt/iobroker/node_modules/.https-proxy-agent-AiV4Y07N',
    634 silly reify   '/opt/iobroker/node_modules/i18next': '/opt/iobroker/node_modules/.i18next-VFNyugyK',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/depd': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.depd-JjqvbijE',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/express-session': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.express-session-esOkQMF4',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/passport': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.passport-4I2fLNnH',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.safe-buffer-zo81UdjE',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/semver': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.semver-6wMrgvKG',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.bin/.semver-sU6Kunpg',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.cloud/node_modules/passport': '/opt/iobroker/node_modules/iobroker.cloud/node_modules/.passport-SX2OiofV',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/concat-stream': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.concat-stream-49HFOYbl',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/debug': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.debug-Fk5FqXGC',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/duplexify': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.duplexify-UttNPDJG',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.mqtt-n2S36XkG',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt_pub': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/.mqtt_pub-u5aXLOTU',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt_sub': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/.mqtt_sub-3gzhcrHd',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/.mqtt-Cv5c20Vf',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/ms': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.ms-0d57qAAX',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.readable-stream-nz1Xpi3N',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.node-red': '/opt/iobroker/node_modules/.iobroker.node-red-lv0iVi6J',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/cheerio': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.cheerio-0AaonLoQ',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/dom-serializer': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.dom-serializer-5vJn51aa',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domelementtype': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.domelementtype-m5brpJtC',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domhandler': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.domhandler-afccCSOK',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domutils': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.domutils-n5Ecugzo',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/entities': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.entities-CJV5dfhy',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/htmlparser2': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.htmlparser2-Ll4M4y58',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/tslib': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.tslib-AiZajDxW',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/cookie': '/opt/iobroker/node_modules/iobroker.socketio/node_modules/.cookie-x4CgJJqB',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/depd': '/opt/iobroker/node_modules/iobroker.socketio/node_modules/.depd-fiIaPYgp',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/express-session': '/opt/iobroker/node_modules/iobroker.socketio/node_modules/.express-session-7gH1yiuQ',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.socketio/node_modules/.safe-buffer-R2f8sOn1',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/cookie': '/opt/iobroker/node_modules/iobroker.web/node_modules/.cookie-tK2ONQ1o',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/depd': '/opt/iobroker/node_modules/iobroker.web/node_modules/.depd-C51S9yJW',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/express-session': '/opt/iobroker/node_modules/iobroker.web/node_modules/.express-session-KGQpMhv6',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/passport': '/opt/iobroker/node_modules/iobroker.web/node_modules/.passport-1f6klSVy',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.web/node_modules/.safe-buffer-BypeWEGr',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/cookie': '/opt/iobroker/node_modules/iobroker.ws/node_modules/.cookie-BztL0LG3',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/depd': '/opt/iobroker/node_modules/iobroker.ws/node_modules/.depd-ed8nl6Sq',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/express-session': '/opt/iobroker/node_modules/iobroker.ws/node_modules/.express-session-dsS21CTq',
    634 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.ws/node_modules/.safe-buffer-jEbvbUSf',
    634 silly reify   '/opt/iobroker/node_modules/is-utf8': '/opt/iobroker/node_modules/.is-utf8-XzPsDN8p',
    634 silly reify   '/opt/iobroker/node_modules/lodash.assign': '/opt/iobroker/node_modules/.lodash.assign-D1kEZF4K',
    634 silly reify   '/opt/iobroker/node_modules/lodash.clonedeep': '/opt/iobroker/node_modules/.lodash.clonedeep-ZCp0kB7v',
    634 silly reify   '/opt/iobroker/node_modules/lodash.get': '/opt/iobroker/node_modules/.lodash.get-TIpVnLkf',
    634 silly reify   '/opt/iobroker/node_modules/lodash.has': '/opt/iobroker/node_modules/.lodash.has-uW6pvZYe',
    634 silly reify   '/opt/iobroker/node_modules/lodash.uniq': '/opt/iobroker/node_modules/.lodash.uniq-tQcTNHTM',
    634 silly reify   '/opt/iobroker/node_modules/memorystore/node_modules/yallist': '/opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ',
    634 silly reify   '/opt/iobroker/node_modules/moment': '/opt/iobroker/node_modules/.moment-YVTvHlwl',
    634 silly reify   '/opt/iobroker/node_modules/moment-timezone': '/opt/iobroker/node_modules/.moment-timezone-LVF6Tkme',
    634 silly reify   '/opt/iobroker/node_modules/mongodb': '/opt/iobroker/node_modules/.mongodb-9LMcV19S',
    634 silly reify   '/opt/iobroker/node_modules/mongodb-connection-string-url': '/opt/iobroker/node_modules/.mongodb-connection-string-url-iEu3f9Lf',
    634 silly reify   '/opt/iobroker/node_modules/mqtt': '/opt/iobroker/node_modules/.mqtt-uuzoX3iL',
    634 silly reify   '/opt/iobroker/node_modules/.bin/mqtt_pub': '/opt/iobroker/node_modules/.bin/.mqtt_pub-zrQkbc14',
    634 silly reify   '/opt/iobroker/node_modules/.bin/mqtt_sub': '/opt/iobroker/node_modules/.bin/.mqtt_sub-bGAW6Av6',
    634 silly reify   '/opt/iobroker/node_modules/.bin/mqtt': '/opt/iobroker/node_modules/.bin/.mqtt-QrHvOaHR',
    634 silly reify   '/opt/iobroker/node_modules/multer': '/opt/iobroker/node_modules/.multer-zsSYw8fD',
    634 silly reify   '/opt/iobroker/node_modules/node-red': '/opt/iobroker/node_modules/.node-red-Kvc6EPdV',
    634 silly reify   '/opt/iobroker/node_modules/.bin/node-red': '/opt/iobroker/node_modules/.bin/.node-red-sdXvnEer',
    634 silly reify   '/opt/iobroker/node_modules/.bin/node-red-pi': '/opt/iobroker/node_modules/.bin/.node-red-pi-ATJhhobv',
    634 silly reify   '/opt/iobroker/node_modules/node-red-admin': '/opt/iobroker/node_modules/.node-red-admin-97cICUzY',
    634 silly reify   '/opt/iobroker/node_modules/.bin/node-red-admin': '/opt/iobroker/node_modules/.bin/.node-red-admin-FCYEkrmv',
    634 silly reify   '/opt/iobroker/node_modules/node-red-node-email': '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi',
    634 silly reify   '/opt/iobroker/node_modules/node-red-node-feedparser': '/opt/iobroker/node_modules/.node-red-node-feedparser-BvY866YR',
    634 silly reify   '/opt/iobroker/node_modules/nth-check': '/opt/iobroker/node_modules/.nth-check-eGbySuuM',
    634 silly reify   '/opt/iobroker/node_modules/on-finished': '/opt/iobroker/node_modules/.on-finished-RsKM9iVb',
    634 silly reify   '/opt/iobroker/node_modules/passport': '/opt/iobroker/node_modules/.passport-7EnVXKbn',
    634 silly reify   '/opt/iobroker/node_modules/passport-http-bearer': '/opt/iobroker/node_modules/.passport-http-bearer-zcWcr11B',
    634 silly reify   '/opt/iobroker/node_modules/passport-oauth2-client-password': '/opt/iobroker/node_modules/.passport-oauth2-client-password-1oKaUbzI',
    634 silly reify   '/opt/iobroker/node_modules/pseudomap': '/opt/iobroker/node_modules/.pseudomap-whVLjSGu',
    634 silly reify   '/opt/iobroker/node_modules/retry': '/opt/iobroker/node_modules/.retry-MZDYeyTM',
    634 silly reify   '/opt/iobroker/node_modules/semver': '/opt/iobroker/node_modules/.semver-n8m5lQuN',
    634 silly reify   '/opt/iobroker/node_modules/.bin/semver': '/opt/iobroker/node_modules/.bin/.semver-LPDaIsIH',
    634 silly reify   '/opt/iobroker/node_modules/sharp/node_modules/semver': '/opt/iobroker/node_modules/sharp/node_modules/.semver-jHbwlJzq',
    634 silly reify   '/opt/iobroker/node_modules/sharp/node_modules/.bin/semver': '/opt/iobroker/node_modules/sharp/node_modules/.bin/.semver-d8arqhS7',
    634 silly reify   '/opt/iobroker/node_modules/socks': '/opt/iobroker/node_modules/.socks-Ly3eN6mV',
    634 silly reify   '/opt/iobroker/node_modules/sparse-bitfield': '/opt/iobroker/node_modules/.sparse-bitfield-vEiH9CFp',
    634 silly reify   '/opt/iobroker/node_modules/statuses': '/opt/iobroker/node_modules/.statuses-WEHZIwCf',
    634 silly reify   '/opt/iobroker/node_modules/streamsearch': '/opt/iobroker/node_modules/.streamsearch-oBszVB4V',
    634 silly reify   '/opt/iobroker/node_modules/uglify-js': '/opt/iobroker/node_modules/.uglify-js-UrZ3Klfa',
    634 silly reify   '/opt/iobroker/node_modules/.bin/uglifyjs': '/opt/iobroker/node_modules/.bin/.uglifyjs-Uwoamhq6',
    634 silly reify   '/opt/iobroker/node_modules/@babel/runtime': '/opt/iobroker/node_modules/@babel/.runtime-cSN2FFol',
    634 silly reify   '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/passport': '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/.passport-Pt2lVh52',
    634 silly reify   '/opt/iobroker/node_modules/@node-red/editor-api': '/opt/iobroker/node_modules/@node-red/.editor-api-Xk7v1FU7',
    634 silly reify   '/opt/iobroker/node_modules/@node-red/editor-client': '/opt/iobroker/node_modules/@node-red/.editor-client-FpqhSpDH',
    634 silly reify   '/opt/iobroker/node_modules/@node-red/nodes': '/opt/iobroker/node_modules/@node-red/.nodes-oC2yqxJN',
    634 silly reify   '/opt/iobroker/node_modules/@node-red/registry': '/opt/iobroker/node_modules/@node-red/.registry-ccnbcuRd',
    634 silly reify   '/opt/iobroker/node_modules/@node-red/runtime': '/opt/iobroker/node_modules/@node-red/.runtime-1jQRdxlO',
    634 silly reify   '/opt/iobroker/node_modules/@node-red/util': '/opt/iobroker/node_modules/@node-red/.util-sbKUIGKV',
    634 silly reify   '/opt/iobroker/node_modules/@types/whatwg-url': '/opt/iobroker/node_modules/@types/.whatwg-url-st9gKEiR'
    634 silly reify }
    635 timing reify:rollback:retireShallow Completed in 27ms
    636 timing command:install Completed in 3677ms
    637 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/memorystore/node_modules/yallist' -> '/opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ'
    638 verbose cwd /opt/iobroker
    639 verbose Linux 5.15.39-3-pve
    640 verbose node v16.17.0
    641 verbose npm  v8.15.0
    642 error code ENOTEMPTY
    643 error syscall rename
    644 error path /opt/iobroker/node_modules/memorystore/node_modules/yallist
    645 error dest /opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ
    646 error errno -39
    647 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/memorystore/node_modules/yallist' -> '/opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ'
    648 verbose exit -39
    649 timing npm Completed in 3846ms
    650 verbose unfinished npm timer reify 1660837399323
    651 verbose unfinished npm timer reify:retireShallow 1660837402946
    652 verbose code -39
    653 error A complete log of this run can be found in:
    653 error     /home/iobroker/.npm/_logs/2022-08-18T15_43_19_158Z-debug-0.log
    Ist das der Fehler, denn die werden in dann in jedem Durchlauf angemahnt und ich kann sie dann manuell löschen.
    JohGreJ 1 Antwort Letzte Antwort
    • Palm_ManiacP Palm_Maniac
      Leider zu früh gefreut. Das Node-Red Update hatte ich noch nicht gemacht und es will auch nicht. Ich hab mir jetzt mal das gemeldete Log angesehen. In der 2. Hälfte tauchen die ganzen Pfade auf, die wohl mit einem Move Befehl angelegt werden.
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@8.15.0
      2 info using node@v16.17.0
      3 timing npm:load:whichnode Completed in 0ms
      4 timing config:load:defaults Completed in 1ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
      6 timing config:load:builtin Completed in 0ms
      7 timing config:load:cli Completed in 2ms
      8 timing config:load:env Completed in 0ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 12ms
      10 timing config:load:project Completed in 23ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 3ms
      12 timing config:load:user Completed in 3ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 0ms
      15 timing config:load:validate Completed in 1ms
      16 timing config:load:credentials Completed in 1ms
      17 timing config:load:setEnvs Completed in 2ms
      18 timing config:load Completed in 34ms
      19 timing npm:load:configload Completed in 34ms
      20 timing npm:load:mkdirpcache Completed in 1ms
      21 timing npm:load:mkdirplogs Completed in 1ms
      22 verbose title npm install iobroker.node-red@4.0.0
      23 verbose argv "install" "--save-exact" "iobroker.node-red@4.0.0" "--unsafe-perm"
      24 timing npm:load:setTitle Completed in 2ms
      25 timing config:load:flatten Completed in 2ms
      26 timing npm:load:display Completed in 3ms
      27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
      28 verbose logfile /home/iobroker/.npm/_logs/2022-08-18T15_43_19_158Z-debug-0.log
      29 timing npm:load:logFile Completed in 4ms
      30 timing npm:load:timers Completed in 0ms
      31 timing npm:load:configScope Completed in 0ms
      32 timing npm:load Completed in 45ms
      33 timing arborist:ctor Completed in 0ms
      34 silly logfile start cleaning logs, removing 2 files
      35 silly logfile done cleaning log files
      36 timing idealTree:init Completed in 1285ms
      37 timing idealTree:userRequests Completed in 19ms
      38 silly idealTree buildDeps
      39 silly fetch manifest iobroker.node-red@4.0.0
      40 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      41 http fetch GET 200 https://registry.npmjs.org/iobroker.node-red 988ms (cache hit)
      42 silly placeDep ROOT iobroker.node-red@4.0.0 REPLACE for: iobroker.inst@3.0.0 want: 4.0.0
      43 silly fetch manifest node-red@^3.0.2
      44 silly fetch manifest node-red-node-email@^1.17.0
      45 silly fetch manifest node-red-node-feedparser@^0.3.0
      46 silly fetch manifest fs.notify@^0.0.4
      47 silly fetch manifest feedparser@^2.2.10
      48 silly fetch manifest mongodb@^4.8.1
      49 http fetch GET 200 https://registry.npmjs.org/node-red 439ms (cache hit)
      50 http fetch GET 200 https://registry.npmjs.org/node-red-node-email 442ms (cache hit)
      51 http fetch GET 200 https://registry.npmjs.org/node-red-node-feedparser 443ms (cache hit)
      52 http fetch GET 200 https://registry.npmjs.org/fs.notify 443ms (cache hit)
      53 http fetch GET 200 https://registry.npmjs.org/feedparser 444ms (cache hit)
      54 http fetch GET 200 https://registry.npmjs.org/mongodb 443ms (cache hit)
      55 timing idealTree:#root Completed in 1504ms
      56 silly placeDep ROOT feedparser@2.2.10 OK for: iobroker.node-red@4.0.0 want: ^2.2.10
      57 silly placeDep ROOT fs.notify@0.0.4 OK for: iobroker.node-red@4.0.0 want: ^0.0.4
      58 silly placeDep ROOT mongodb@4.8.1 OK for: iobroker.node-red@4.0.0 want: ^4.8.1
      59 silly placeDep ROOT node-red@3.0.2 OK for: iobroker.node-red@4.0.0 want: ^3.0.2
      60 silly placeDep ROOT node-red-node-email@1.17.0 OK for: iobroker.node-red@4.0.0 want: ^1.17.0
      61 silly placeDep ROOT node-red-node-feedparser@0.3.0 OK for: iobroker.node-red@4.0.0 want: ^0.3.0
      62 silly fetch manifest addressparser@^1.0.1
      63 silly fetch manifest array-indexofobject@~0.0.1
      64 silly fetch manifest lodash.assign@^4.2.0
      65 silly fetch manifest lodash.get@^4.4.2
      66 silly fetch manifest lodash.has@^4.5.2
      67 silly fetch manifest lodash.uniq@^4.5.0
      68 silly fetch manifest mri@^1.1.5
      69 silly fetch manifest async@~0.1.22
      70 silly fetch manifest retry@~0.6.0
      71 silly fetch manifest bson@^4.6.5
      72 silly fetch manifest denque@^2.0.1
      73 silly fetch manifest mongodb-connection-string-url@^2.5.2
      74 silly fetch manifest socks@^2.6.2
      75 silly fetch manifest saslprep@^1.0.3
      76 silly fetch manifest @node-red/editor-api@3.0.2
      77 silly fetch manifest @node-red/runtime@3.0.2
      78 silly fetch manifest @node-red/util@3.0.2
      79 silly fetch manifest @node-red/nodes@3.0.2
      80 silly fetch manifest basic-auth@2.0.1
      81 silly fetch manifest bcryptjs@2.4.3
      82 silly fetch manifest node-red-admin@^3.0.0
      83 silly fetch manifest semver@7.3.7
      84 silly fetch manifest bcrypt@5.0.1
      85 http fetch GET 200 https://registry.npmjs.org/addressparser 52ms (cache hit)
      86 http fetch GET 200 https://registry.npmjs.org/array-indexofobject 51ms (cache hit)
      87 http fetch GET 200 https://registry.npmjs.org/lodash.assign 52ms (cache hit)
      88 http fetch GET 200 https://registry.npmjs.org/lodash.get 52ms (cache hit)
      89 http fetch GET 200 https://registry.npmjs.org/lodash.has 52ms (cache hit)
      90 http fetch GET 200 https://registry.npmjs.org/lodash.uniq 52ms (cache hit)
      91 http fetch GET 200 https://registry.npmjs.org/mri 52ms (cache hit)
      92 http fetch GET 200 https://registry.npmjs.org/async 53ms (cache hit)
      93 http fetch GET 200 https://registry.npmjs.org/retry 54ms (cache hit)
      94 http fetch GET 200 https://registry.npmjs.org/bson 55ms (cache hit)
      95 http fetch GET 200 https://registry.npmjs.org/denque 56ms (cache hit)
      96 http fetch GET 200 https://registry.npmjs.org/mongodb-connection-string-url 56ms (cache hit)
      97 http fetch GET 200 https://registry.npmjs.org/socks 57ms (cache hit)
      98 http fetch GET 200 https://registry.npmjs.org/saslprep 57ms (cache hit)
      99 http fetch GET 200 https://registry.npmjs.org/@node-red%2feditor-api 57ms (cache hit)
      100 http fetch GET 200 https://registry.npmjs.org/@node-red%2fruntime 58ms (cache hit)
      101 http fetch GET 200 https://registry.npmjs.org/@node-red%2futil 58ms (cache hit)
      102 http fetch GET 200 https://registry.npmjs.org/@node-red%2fnodes 59ms (cache hit)
      103 http fetch GET 200 https://registry.npmjs.org/basic-auth 59ms (cache hit)
      104 http fetch GET 200 https://registry.npmjs.org/bcryptjs 58ms (cache hit)
      105 http fetch GET 200 https://registry.npmjs.org/node-red-admin 59ms (cache hit)
      106 http fetch GET 200 https://registry.npmjs.org/semver 54ms (cache hit)
      107 http fetch GET 200 https://registry.npmjs.org/bcrypt 54ms (cache hit)
      108 timing idealTree:node_modules/iobroker.node-red Completed in 81ms
      109 silly placeDep ROOT addressparser@1.0.1 OK for: feedparser@2.2.10 want: ^1.0.1
      110 silly placeDep ROOT array-indexofobject@0.0.1 OK for: feedparser@2.2.10 want: ~0.0.1
      111 silly placeDep ROOT lodash.assign@4.2.0 OK for: feedparser@2.2.10 want: ^4.2.0
      112 silly placeDep ROOT lodash.get@4.4.2 OK for: feedparser@2.2.10 want: ^4.4.2
      113 silly placeDep ROOT lodash.has@4.5.2 OK for: feedparser@2.2.10 want: ^4.5.2
      114 silly placeDep ROOT lodash.uniq@4.5.0 OK for: feedparser@2.2.10 want: ^4.5.0
      115 silly placeDep ROOT mri@1.2.0 OK for: feedparser@2.2.10 want: ^1.1.5
      116 timing idealTree:node_modules/feedparser Completed in 7ms
      117 timing idealTree:node_modules/addressparser Completed in 0ms
      118 timing idealTree:node_modules/array-indexofobject Completed in 0ms
      119 silly placeDep node_modules/fs.notify async@0.1.22 OK for: fs.notify@0.0.4 want: ~0.1.22
      120 silly placeDep ROOT retry@0.6.1 OK for: fs.notify@0.0.4 want: ~0.6.0
      121 timing idealTree:node_modules/fs.notify Completed in 2ms
      122 timing idealTree:node_modules/lodash.assign Completed in 1ms
      123 timing idealTree:node_modules/lodash.get Completed in 0ms
      124 timing idealTree:node_modules/lodash.has Completed in 0ms
      125 timing idealTree:node_modules/lodash.uniq Completed in 0ms
      126 silly placeDep ROOT bson@4.6.5 OK for: mongodb@4.8.1 want: ^4.6.5
      127 silly placeDep node_modules/mongodb denque@2.1.0 OK for: mongodb@4.8.1 want: ^2.0.1
      128 silly placeDep ROOT mongodb-connection-string-url@2.5.3 OK for: mongodb@4.8.1 want: ^2.5.2
      129 silly placeDep ROOT saslprep@1.0.3 OK for: mongodb@4.8.1 want: ^1.0.3
      130 silly placeDep ROOT socks@2.7.0 OK for: mongodb@4.8.1 want: ^2.6.2
      131 silly fetch manifest buffer@^5.6.0
      132 silly fetch manifest @types/whatwg-url@^8.2.1
      133 silly fetch manifest whatwg-url@^11.0.0
      134 silly fetch manifest sparse-bitfield@^3.0.3
      135 silly fetch manifest ip@^2.0.0
      136 silly fetch manifest smart-buffer@^4.2.0
      137 http fetch GET 200 https://registry.npmjs.org/buffer 14ms (cache hit)
      138 http fetch GET 200 https://registry.npmjs.org/@types%2fwhatwg-url 14ms (cache hit)
      139 http fetch GET 200 https://registry.npmjs.org/whatwg-url 14ms (cache hit)
      140 http fetch GET 200 https://registry.npmjs.org/sparse-bitfield 15ms (cache hit)
      141 http fetch GET 200 https://registry.npmjs.org/ip 14ms (cache hit)
      142 http fetch GET 200 https://registry.npmjs.org/smart-buffer 15ms (cache hit)
      143 timing idealTree:node_modules/mongodb Completed in 28ms
      144 silly placeDep node_modules/bson buffer@5.7.1 OK for: bson@4.6.5 want: ^5.6.0
      145 timing idealTree:node_modules/bson Completed in 1ms
      146 silly placeDep ROOT @types/whatwg-url@8.2.2 OK for: mongodb-connection-string-url@2.5.3 want: ^8.2.1
      147 silly placeDep node_modules/mongodb-connection-string-url whatwg-url@11.0.0 OK for: mongodb-connection-string-url@2.5.3 want: ^11.0.0
      148 silly fetch manifest @types/webidl-conversions@*
      149 http fetch GET 200 https://registry.npmjs.org/@types%2fwebidl-conversions 2ms (cache hit)
      150 timing idealTree:node_modules/mongodb-connection-string-url Completed in 5ms
      151 silly placeDep ROOT @types/webidl-conversions@6.1.1 OK for: @types/whatwg-url@8.2.2 want: *
      152 timing idealTree:node_modules/@types/whatwg-url Completed in 2ms
      153 timing idealTree:node_modules/@types/webidl-conversions Completed in 0ms
      154 timing idealTree:node_modules/mri Completed in 0ms
      155 silly placeDep ROOT @node-red/editor-api@3.0.2 OK for: node-red@3.0.2 want: 3.0.2
      156 silly placeDep ROOT @node-red/nodes@3.0.2 OK for: node-red@3.0.2 want: 3.0.2
      157 silly placeDep ROOT @node-red/runtime@3.0.2 OK for: node-red@3.0.2 want: 3.0.2
      158 silly placeDep ROOT @node-red/util@3.0.2 OK for: node-red@3.0.2 want: 3.0.2
      159 silly placeDep ROOT basic-auth@2.0.1 OK for: node-red@3.0.2 want: 2.0.1
      160 silly placeDep ROOT bcrypt@5.0.1 OK for: node-red@3.0.2 want: 5.0.1
      161 silly placeDep ROOT bcryptjs@2.4.3 OK for: node-red@3.0.2 want: 2.4.3
      162 silly placeDep ROOT node-red-admin@3.0.0 OK for: node-red@3.0.2 want: ^3.0.0
      163 silly placeDep ROOT semver@7.3.7 REPLACE for: node-red@3.0.2 want: 7.3.7
      164 silly fetch manifest @node-red/editor-client@3.0.2
      165 silly fetch manifest clone@2.1.2
      166 silly fetch manifest express-session@1.17.3
      167 silly fetch manifest memorystore@1.6.7
      168 silly fetch manifest mime@3.0.0
      169 silly fetch manifest multer@1.4.5-lts.1
      170 silly fetch manifest mustache@4.2.0
      171 silly fetch manifest oauth2orize@1.11.1
      172 silly fetch manifest passport-http-bearer@1.0.1
      173 silly fetch manifest passport-oauth2-client-password@0.1.2
      174 silly fetch manifest passport@0.6.0
      175 silly fetch manifest ws@7.5.6
      176 silly fetch manifest acorn-walk@8.2.0
      177 silly fetch manifest ajv@8.11.0
      178 silly fetch manifest cheerio@1.0.0-rc.10
      179 silly fetch manifest cronosjs@1.7.1
      180 silly fetch manifest denque@2.1.0
      181 silly fetch manifest form-data@4.0.0
      182 silly fetch manifest got@11.8.5
      183 silly fetch manifest hash-sum@2.0.0
      184 silly fetch manifest hpagent@1.0.0
      185 silly fetch manifest https-proxy-agent@5.0.1
      186 silly fetch manifest is-utf8@0.2.1
      187 silly fetch manifest js-yaml@4.1.0
      188 silly fetch manifest media-typer@1.1.0
      189 silly fetch manifest mqtt@4.3.7
      190 silly fetch manifest node-watch@0.7.3
      191 silly fetch manifest tough-cookie@4.0.0
      192 silly fetch manifest uuid@8.3.2
      193 silly fetch manifest iconv-lite@0.6.3
      194 silly fetch manifest @node-red/registry@3.0.2
      195 silly fetch manifest async-mutex@0.3.2
      196 silly fetch manifest i18next@21.8.16
      197 silly fetch manifest lodash.clonedeep@^4.5.0
      198 silly fetch manifest moment@2.29.4
      199 silly fetch manifest moment-timezone@0.5.34
      200 silly fetch manifest node-addon-api@^3.1.0
      201 silly fetch manifest ansi-colors@^4.1.1
      202 silly fetch manifest axios@0.27.2
      203 silly fetch manifest cli-table@^0.3.11
      204 silly fetch manifest enquirer@^2.3.6
      205 silly fetch manifest mustache@^4.2.0
      206 http fetch GET 200 https://registry.npmjs.org/@node-red%2feditor-client 110ms (cache hit)
      207 http fetch GET 200 https://registry.npmjs.org/clone 109ms (cache hit)
      208 http fetch GET 200 https://registry.npmjs.org/express-session 110ms (cache hit)
      209 http fetch GET 200 https://registry.npmjs.org/memorystore 110ms (cache hit)
      210 http fetch GET 200 https://registry.npmjs.org/multer 109ms (cache hit)
      211 http fetch GET 200 https://registry.npmjs.org/mustache 105ms (cache hit)
      212 http fetch GET 200 https://registry.npmjs.org/oauth2orize 104ms (cache hit)
      213 http fetch GET 200 https://registry.npmjs.org/passport-oauth2-client-password 104ms (cache hit)
      214 http fetch GET 200 https://registry.npmjs.org/passport 104ms (cache hit)
      215 http fetch GET 200 https://registry.npmjs.org/passport-http-bearer 105ms (cache hit)
      216 http fetch GET 200 https://registry.npmjs.org/ws 104ms (cache hit)
      217 http fetch GET 200 https://registry.npmjs.org/acorn-walk 105ms (cache hit)
      218 http fetch GET 200 https://registry.npmjs.org/ajv 105ms (cache hit)
      219 http fetch GET 200 https://registry.npmjs.org/cheerio 109ms (cache hit)
      220 http fetch GET 200 https://registry.npmjs.org/cronosjs 109ms (cache hit)
      221 http fetch GET 200 https://registry.npmjs.org/form-data 108ms (cache hit)
      222 http fetch GET 200 https://registry.npmjs.org/got 109ms (cache hit)
      223 http fetch GET 200 https://registry.npmjs.org/hash-sum 111ms (cache hit)
      224 http fetch GET 200 https://registry.npmjs.org/hpagent 110ms (cache hit)
      225 http fetch GET 200 https://registry.npmjs.org/https-proxy-agent 111ms (cache hit)
      226 http fetch GET 200 https://registry.npmjs.org/is-utf8 110ms (cache hit)
      227 http fetch GET 200 https://registry.npmjs.org/js-yaml 110ms (cache hit)
      228 http fetch GET 200 https://registry.npmjs.org/media-typer 110ms (cache hit)
      229 http fetch GET 200 https://registry.npmjs.org/mqtt 111ms (cache hit)
      230 http fetch GET 200 https://registry.npmjs.org/node-watch 112ms (cache hit)
      231 http fetch GET 200 https://registry.npmjs.org/tough-cookie 111ms (cache hit)
      232 http fetch GET 200 https://registry.npmjs.org/uuid 112ms (cache hit)
      233 http fetch GET 200 https://registry.npmjs.org/iconv-lite 112ms (cache hit)
      234 http fetch GET 200 https://registry.npmjs.org/@node-red%2fregistry 111ms (cache hit)
      235 http fetch GET 200 https://registry.npmjs.org/async-mutex 112ms (cache hit)
      236 http fetch GET 200 https://registry.npmjs.org/i18next 113ms (cache hit)
      237 http fetch GET 200 https://registry.npmjs.org/lodash.clonedeep 125ms (cache hit)
      238 http fetch GET 200 https://registry.npmjs.org/moment 126ms (cache hit)
      239 http fetch GET 200 https://registry.npmjs.org/moment-timezone 126ms (cache hit)
      240 http fetch GET 200 https://registry.npmjs.org/node-addon-api 126ms (cache hit)
      241 http fetch GET 200 https://registry.npmjs.org/ansi-colors 126ms (cache hit)
      242 http fetch GET 200 https://registry.npmjs.org/mime 149ms (cache hit)
      243 http fetch GET 200 https://registry.npmjs.org/axios 126ms (cache hit)
      244 http fetch GET 200 https://registry.npmjs.org/cli-table 127ms (cache hit)
      245 http fetch GET 200 https://registry.npmjs.org/enquirer 127ms (cache hit)
      246 http fetch GET 200 https://registry.npmjs.org/mustache 127ms (cache hit)
      247 timing idealTree:node_modules/node-red Completed in 168ms
      248 silly fetch manifest bufferutil@^4.0.1
      249 http fetch GET 200 https://registry.npmjs.org/bufferutil 8ms (cache hit)
      250 silly fetch manifest utf-8-validate@^5.0.2
      251 http fetch GET 200 https://registry.npmjs.org/utf-8-validate 2ms (cache hit)
      252 silly placeDep ROOT @node-red/editor-client@3.0.2 OK for: @node-red/editor-api@3.0.2 want: 3.0.2
      253 silly placeDep ROOT clone@2.1.2 OK for: @node-red/editor-api@3.0.2 want: 2.1.2
      254 silly placeDep ROOT express-session@1.17.3 OK for: @node-red/editor-api@3.0.2 want: 1.17.3
      255 silly placeDep ROOT memorystore@1.6.7 OK for: @node-red/editor-api@3.0.2 want: 1.6.7
      256 silly placeDep node_modules/@node-red/editor-api mime@3.0.0 OK for: @node-red/editor-api@3.0.2 want: 3.0.0
      257 silly placeDep ROOT multer@1.4.5-lts.1 OK for: @node-red/editor-api@3.0.2 want: 1.4.5-lts.1
      258 silly placeDep ROOT mustache@4.2.0 OK for: @node-red/editor-api@3.0.2 want: 4.2.0
      259 silly placeDep ROOT oauth2orize@1.11.1 OK for: @node-red/editor-api@3.0.2 want: 1.11.1
      260 silly placeDep ROOT passport@0.6.0 OK for: @node-red/editor-api@3.0.2 want: 0.6.0
      261 silly placeDep ROOT passport-http-bearer@1.0.1 OK for: @node-red/editor-api@3.0.2 want: 1.0.1
      262 silly placeDep ROOT passport-oauth2-client-password@0.1.2 OK for: @node-red/editor-api@3.0.2 want: 0.1.2
      263 silly placeDep node_modules/@node-red/editor-api ws@7.5.6 OK for: @node-red/editor-api@3.0.2 want: 7.5.6
      264 silly fetch manifest cookie@0.4.2
      265 silly fetch manifest depd@~2.0.0
      266 silly fetch manifest safe-buffer@5.2.1
      267 silly fetch manifest debug@^4.3.0
      268 silly fetch manifest lru-cache@^4.0.3
      269 silly fetch manifest append-field@^1.0.0
      270 silly fetch manifest mkdirp@^0.5.4
      271 silly fetch manifest uid2@0.0.x
      272 http fetch GET 200 https://registry.npmjs.org/cookie 35ms (cache hit)
      273 http fetch GET 200 https://registry.npmjs.org/depd 36ms (cache hit)
      274 http fetch GET 200 https://registry.npmjs.org/safe-buffer 35ms (cache hit)
      275 http fetch GET 200 https://registry.npmjs.org/debug 36ms (cache hit)
      276 http fetch GET 200 https://registry.npmjs.org/lru-cache 35ms (cache hit)
      277 http fetch GET 200 https://registry.npmjs.org/append-field 29ms (cache hit)
      278 http fetch GET 200 https://registry.npmjs.org/mkdirp 29ms (cache hit)
      279 http fetch GET 200 https://registry.npmjs.org/uid2 29ms (cache hit)
      280 timing idealTree:node_modules/@node-red/editor-api Completed in 78ms
      281 timing idealTree:node_modules/@node-red/editor-client Completed in 0ms
      282 silly placeDep node_modules/@node-red/nodes acorn-walk@8.2.0 OK for: @node-red/nodes@3.0.2 want: 8.2.0
      283 silly placeDep node_modules/@node-red/nodes ajv@8.11.0 OK for: @node-red/nodes@3.0.2 want: 8.11.0
      284 silly placeDep ROOT cheerio@1.0.0-rc.10 OK for: @node-red/nodes@3.0.2 want: 1.0.0-rc.10
      285 silly placeDep ROOT cronosjs@1.7.1 OK for: @node-red/nodes@3.0.2 want: 1.7.1
      286 silly placeDep node_modules/@node-red/nodes denque@2.1.0 OK for: @node-red/nodes@3.0.2 want: 2.1.0
      287 silly placeDep node_modules/@node-red/nodes form-data@4.0.0 OK for: @node-red/nodes@3.0.2 want: 4.0.0
      288 silly placeDep node_modules/@node-red/nodes got@11.8.5 OK for: @node-red/nodes@3.0.2 want: 11.8.5
      289 silly placeDep ROOT hash-sum@2.0.0 OK for: @node-red/nodes@3.0.2 want: 2.0.0
      290 silly placeDep ROOT hpagent@1.0.0 OK for: @node-red/nodes@3.0.2 want: 1.0.0
      291 silly placeDep ROOT https-proxy-agent@5.0.1 REPLACE for: @node-red/nodes@3.0.2 want: 5.0.1
      292 silly placeDep node_modules/@node-red/nodes iconv-lite@0.6.3 OK for: @node-red/nodes@3.0.2 want: 0.6.3
      293 silly placeDep ROOT is-utf8@0.2.1 OK for: @node-red/nodes@3.0.2 want: 0.2.1
      294 silly placeDep node_modules/@node-red/nodes js-yaml@4.1.0 OK for: @node-red/nodes@3.0.2 want: 4.1.0
      295 silly placeDep node_modules/@node-red/nodes media-typer@1.1.0 OK for: @node-red/nodes@3.0.2 want: 1.1.0
      296 silly placeDep ROOT mqtt@4.3.7 OK for: @node-red/nodes@3.0.2 want: 4.3.7
      297 silly placeDep ROOT node-watch@0.7.3 OK for: @node-red/nodes@3.0.2 want: 0.7.3
      298 silly placeDep node_modules/@node-red/nodes tough-cookie@4.0.0 OK for: @node-red/nodes@3.0.2 want: 4.0.0
      299 silly placeDep node_modules/@node-red/nodes uuid@8.3.2 OK for: @node-red/nodes@3.0.2 want: 8.3.2
      300 silly placeDep node_modules/@node-red/nodes ws@7.5.6 OK for: @node-red/nodes@3.0.2 want: 7.5.6
      301 silly fetch manifest json-schema-traverse@^1.0.0
      302 silly fetch manifest require-from-string@^2.0.2
      303 silly fetch manifest cheerio-select@^1.5.0
      304 silly fetch manifest dom-serializer@^1.3.2
      305 silly fetch manifest domhandler@^4.2.0
      306 silly fetch manifest htmlparser2@^6.1.0
      307 silly fetch manifest tslib@^2.2.0
      308 silly fetch manifest @sindresorhus/is@^4.0.0
      309 silly fetch manifest cacheable-lookup@^5.0.3
      310 silly fetch manifest decompress-response@^6.0.0
      311 silly fetch manifest argparse@^2.0.1
      312 silly fetch manifest concat-stream@^2.0.0
      313 silly fetch manifest debug@^4.1.1
      314 silly fetch manifest duplexify@^4.1.1
      315 silly fetch manifest readable-stream@^3.6.0
      316 silly fetch manifest ws@^7.5.5
      317 silly fetch manifest universalify@^0.1.2
      318 http fetch GET 200 https://registry.npmjs.org/json-schema-traverse 53ms (cache hit)
      319 http fetch GET 200 https://registry.npmjs.org/require-from-string 53ms (cache hit)
      320 http fetch GET 200 https://registry.npmjs.org/cheerio-select 53ms (cache hit)
      321 http fetch GET 200 https://registry.npmjs.org/dom-serializer 53ms (cache hit)
      322 http fetch GET 200 https://registry.npmjs.org/domhandler 50ms (cache hit)
      323 http fetch GET 200 https://registry.npmjs.org/htmlparser2 52ms (cache hit)
      324 http fetch GET 200 https://registry.npmjs.org/tslib 61ms (cache hit)
      325 http fetch GET 200 https://registry.npmjs.org/@sindresorhus%2fis 61ms (cache hit)
      326 http fetch GET 200 https://registry.npmjs.org/cacheable-lookup 62ms (cache hit)
      327 http fetch GET 200 https://registry.npmjs.org/decompress-response 56ms (cache hit)
      328 http fetch GET 200 https://registry.npmjs.org/argparse 55ms (cache hit)
      329 http fetch GET 200 https://registry.npmjs.org/concat-stream 56ms (cache hit)
      330 http fetch GET 200 https://registry.npmjs.org/duplexify 55ms (cache hit)
      331 http fetch GET 200 https://registry.npmjs.org/readable-stream 57ms (cache hit)
      332 http fetch GET 200 https://registry.npmjs.org/universalify 59ms (cache hit)
      333 timing idealTree:node_modules/@node-red/nodes Completed in 116ms
      334 silly placeDep ROOT @node-red/registry@3.0.2 OK for: @node-red/runtime@3.0.2 want: 3.0.2
      335 silly placeDep ROOT async-mutex@0.3.2 OK for: @node-red/runtime@3.0.2 want: 0.3.2
      336 silly fetch manifest uglify-js@3.16.3
      337 silly fetch manifest tslib@^2.3.1
      338 http fetch GET 200 https://registry.npmjs.org/uglify-js 3ms (cache hit)
      339 timing idealTree:node_modules/@node-red/runtime Completed in 16ms
      340 silly placeDep ROOT uglify-js@3.16.3 OK for: @node-red/registry@3.0.2 want: 3.16.3
      341 timing idealTree:node_modules/@node-red/registry Completed in 1ms
      342 silly placeDep ROOT i18next@21.8.16 OK for: @node-red/util@3.0.2 want: 21.8.16
      343 silly placeDep ROOT lodash.clonedeep@4.5.0 OK for: @node-red/util@3.0.2 want: ^4.5.0
      344 silly placeDep ROOT moment@2.29.4 REPLACE for: @node-red/util@3.0.2 want: 2.29.4
      345 silly placeDep ROOT moment-timezone@0.5.34 REPLACE for: @node-red/util@3.0.2 want: 0.5.34
      346 silly fetch manifest @babel/runtime@^7.17.2
      347 http fetch GET 200 https://registry.npmjs.org/@babel%2fruntime 2ms (cache hit)
      348 timing idealTree:node_modules/@node-red/util Completed in 11ms
      349 silly placeDep node_modules/async-mutex tslib@2.4.0 OK for: async-mutex@0.3.2 want: ^2.3.1
      350 timing idealTree:node_modules/async-mutex Completed in 1ms
      351 timing idealTree:node_modules/basic-auth Completed in 0ms
      352 silly placeDep ROOT node-addon-api@3.2.1 OK for: bcrypt@5.0.1 want: ^3.1.0
      353 timing idealTree:node_modules/bcrypt Completed in 2ms
      354 timing idealTree:node_modules/bcryptjs Completed in 0ms
      355 silly placeDep ROOT cheerio-select@1.6.0 OK for: cheerio@1.0.0-rc.10 want: ^1.5.0
      356 silly placeDep ROOT dom-serializer@1.4.1 OK for: cheerio@1.0.0-rc.10 want: ^1.3.2
      357 silly placeDep ROOT domhandler@4.3.1 OK for: cheerio@1.0.0-rc.10 want: ^4.2.0
      358 silly placeDep ROOT htmlparser2@6.1.0 OK for: cheerio@1.0.0-rc.10 want: ^6.1.0
      359 silly placeDep node_modules/cheerio tslib@2.4.0 OK for: cheerio@1.0.0-rc.10 want: ^2.2.0
      360 silly fetch manifest css-select@^4.3.0
      361 silly fetch manifest css-what@^6.0.1
      362 silly fetch manifest domelementtype@^2.2.0
      363 silly fetch manifest domutils@^2.8.0
      364 silly fetch manifest domelementtype@^2.0.1
      365 silly fetch manifest entities@^2.0.0
      366 silly fetch manifest domutils@^2.5.2
      367 http fetch GET 200 https://registry.npmjs.org/css-select 31ms (cache hit)
      368 http fetch GET 200 https://registry.npmjs.org/css-what 28ms (cache hit)
      369 http fetch GET 200 https://registry.npmjs.org/domelementtype 26ms (cache hit)
      370 http fetch GET 200 https://registry.npmjs.org/domutils 26ms (cache hit)
      371 http fetch GET 200 https://registry.npmjs.org/domelementtype 27ms (cache hit)
      372 http fetch GET 200 https://registry.npmjs.org/entities 26ms (cache hit)
      373 http fetch GET 200 https://registry.npmjs.org/domutils 26ms (cache hit)
      374 timing idealTree:node_modules/cheerio Completed in 41ms
      375 silly placeDep ROOT css-select@4.3.0 OK for: cheerio-select@1.6.0 want: ^4.3.0
      376 silly placeDep ROOT css-what@6.1.0 OK for: cheerio-select@1.6.0 want: ^6.0.1
      377 silly placeDep ROOT domelementtype@2.3.0 OK for: cheerio-select@1.6.0 want: ^2.2.0
      378 silly placeDep ROOT domutils@2.8.0 OK for: cheerio-select@1.6.0 want: ^2.8.0
      379 silly fetch manifest boolbase@^1.0.0
      380 silly fetch manifest nth-check@^2.0.1
      381 http fetch GET 200 https://registry.npmjs.org/boolbase 6ms (cache hit)
      382 http fetch GET 200 https://registry.npmjs.org/nth-check 6ms (cache hit)
      383 timing idealTree:node_modules/cheerio-select Completed in 16ms
      384 timing idealTree:node_modules/clone Completed in 0ms
      385 timing idealTree:node_modules/cronosjs Completed in 0ms
      386 silly placeDep ROOT boolbase@1.0.0 OK for: css-select@4.3.0 want: ^1.0.0
      387 silly placeDep ROOT nth-check@2.1.1 OK for: css-select@4.3.0 want: ^2.0.1
      388 timing idealTree:node_modules/css-select Completed in 5ms
      389 timing idealTree:node_modules/boolbase Completed in 1ms
      390 timing idealTree:node_modules/css-what Completed in 0ms
      391 silly placeDep ROOT entities@2.2.0 OK for: dom-serializer@1.4.1 want: ^2.0.0
      392 timing idealTree:node_modules/dom-serializer Completed in 2ms
      393 timing idealTree:node_modules/domelementtype Completed in 0ms
      394 timing idealTree:node_modules/domhandler Completed in 0ms
      395 timing idealTree:node_modules/domutils Completed in 0ms
      396 timing idealTree:node_modules/entities Completed in 0ms
      397 silly placeDep node_modules/express-session cookie@0.4.2 OK for: express-session@1.17.3 want: 0.4.2
      398 silly placeDep node_modules/express-session depd@2.0.0 OK for: express-session@1.17.3 want: ~2.0.0
      399 silly placeDep node_modules/express-session safe-buffer@5.2.1 OK for: express-session@1.17.3 want: 5.2.1
      400 timing idealTree:node_modules/express-session Completed in 2ms
      401 timing idealTree:node_modules/hash-sum Completed in 1ms
      402 timing idealTree:node_modules/hpagent Completed in 0ms
      403 timing idealTree:node_modules/htmlparser2 Completed in 0ms
      404 timing idealTree:node_modules/https-proxy-agent Completed in 0ms
      405 silly placeDep ROOT @babel/runtime@7.18.9 OK for: i18next@21.8.16 want: ^7.17.2
      406 silly fetch manifest regenerator-runtime@^0.13.4
      407 http fetch GET 200 https://registry.npmjs.org/regenerator-runtime 3ms (cache hit)
      408 timing idealTree:node_modules/i18next Completed in 8ms
      409 silly placeDep ROOT regenerator-runtime@0.13.9 OK for: @babel/runtime@7.18.9 want: ^0.13.4
      410 timing idealTree:node_modules/@babel/runtime Completed in 3ms
      411 timing idealTree:node_modules/is-utf8 Completed in 0ms
      412 timing idealTree:node_modules/lodash.clonedeep Completed in 0ms
      413 silly placeDep node_modules/memorystore debug@4.3.4 OK for: memorystore@1.6.7 want: ^4.3.0
      414 silly placeDep node_modules/memorystore lru-cache@4.1.5 OK for: memorystore@1.6.7 want: ^4.0.3
      415 silly fetch manifest ms@2.1.2
      416 silly fetch manifest pseudomap@^1.0.2
      417 silly fetch manifest yallist@^2.1.2
      418 http fetch GET 200 https://registry.npmjs.org/ms 8ms (cache hit)
      419 http fetch GET 200 https://registry.npmjs.org/pseudomap 8ms (cache hit)
      420 http fetch GET 200 https://registry.npmjs.org/yallist 8ms (cache hit)
      421 timing idealTree:node_modules/memorystore Completed in 12ms
      422 timing idealTree:node_modules/moment Completed in 0ms
      423 timing idealTree:node_modules/moment-timezone Completed in 0ms
      424 silly placeDep node_modules/mqtt concat-stream@2.0.0 OK for: mqtt@4.3.7 want: ^2.0.0
      425 silly placeDep node_modules/mqtt debug@4.3.4 OK for: mqtt@4.3.7 want: ^4.1.1
      426 silly placeDep node_modules/mqtt duplexify@4.1.2 OK for: mqtt@4.3.7 want: ^4.1.1
      427 silly placeDep node_modules/mqtt readable-stream@3.6.0 OK for: mqtt@4.3.7 want: ^3.6.0
      428 silly placeDep node_modules/mqtt ws@7.5.9 OK for: mqtt@4.3.7 want: ^7.5.5
      429 timing idealTree:node_modules/mqtt Completed in 7ms
      430 silly placeDep ROOT append-field@1.0.0 OK for: multer@1.4.5-lts.1 want: ^1.0.0
      431 silly placeDep ROOT mkdirp@0.5.6 OK for: multer@1.4.5-lts.1 want: ^0.5.4
      432 timing idealTree:node_modules/multer Completed in 3ms
      433 timing idealTree:node_modules/append-field Completed in 0ms
      434 timing idealTree:node_modules/mkdirp Completed in 0ms
      435 timing idealTree:node_modules/mustache Completed in 0ms
      436 timing idealTree:node_modules/node-addon-api Completed in 0ms
      437 silly placeDep ROOT ansi-colors@4.1.3 OK for: node-red-admin@3.0.0 want: ^4.1.1
      438 silly placeDep node_modules/node-red-admin axios@0.27.2 OK for: node-red-admin@3.0.0 want: 0.27.2
      439 silly placeDep ROOT cli-table@0.3.11 OK for: node-red-admin@3.0.0 want: ^0.3.11
      440 silly placeDep ROOT enquirer@2.3.6 OK for: node-red-admin@3.0.0 want: ^2.3.6
      441 silly fetch manifest form-data@^4.0.0
      442 silly fetch manifest colors@1.0.3
      443 http fetch GET 200 https://registry.npmjs.org/colors 9ms (cache hit)
      444 timing idealTree:node_modules/node-red-admin Completed in 23ms
      445 timing idealTree:node_modules/ansi-colors Completed in 0ms
      446 silly placeDep node_modules/cli-table colors@1.0.3 OK for: cli-table@0.3.11 want: 1.0.3
      447 timing idealTree:node_modules/cli-table Completed in 1ms
      448 timing idealTree:node_modules/enquirer Completed in 0ms
      449 timing idealTree:node_modules/node-red-node-email Completed in 0ms
      450 timing idealTree:node_modules/node-red-node-feedparser Completed in 0ms
      451 timing idealTree:node_modules/node-watch Completed in 0ms
      452 timing idealTree:node_modules/nth-check Completed in 0ms
      453 silly placeDep ROOT uid2@0.0.4 OK for: oauth2orize@1.11.1 want: 0.0.x
      454 timing idealTree:node_modules/oauth2orize Completed in 2ms
      455 timing idealTree:node_modules/passport Completed in 0ms
      456 timing idealTree:node_modules/passport-http-bearer Completed in 0ms
      457 timing idealTree:node_modules/passport-oauth2-client-password Completed in 0ms
      458 timing idealTree:node_modules/regenerator-runtime Completed in 0ms
      459 timing idealTree:node_modules/retry Completed in 0ms
      460 silly placeDep ROOT sparse-bitfield@3.0.3 OK for: saslprep@1.0.3 want: ^3.0.3
      461 silly fetch manifest memory-pager@^1.0.2
      462 http fetch GET 200 https://registry.npmjs.org/memory-pager 3ms (cache hit)
      463 timing idealTree:node_modules/saslprep Completed in 8ms
      464 timing idealTree:node_modules/semver Completed in 0ms
      465 silly placeDep node_modules/socks ip@2.0.0 OK for: socks@2.7.0 want: ^2.0.0
      466 silly placeDep ROOT smart-buffer@4.2.0 OK for: socks@2.7.0 want: ^4.2.0
      467 timing idealTree:node_modules/socks Completed in 3ms
      468 timing idealTree:node_modules/smart-buffer Completed in 0ms
      469 silly placeDep ROOT memory-pager@1.5.0 OK for: sparse-bitfield@3.0.3 want: ^1.0.2
      470 timing idealTree:node_modules/sparse-bitfield Completed in 3ms
      471 timing idealTree:node_modules/memory-pager Completed in 0ms
      472 timing idealTree:node_modules/uglify-js Completed in 0ms
      473 timing idealTree:node_modules/uid2 Completed in 0ms
      474 timing idealTree:node_modules/@node-red/editor-api/node_modules/mime Completed in 0ms
      475 timing idealTree:node_modules/@node-red/editor-api/node_modules/ws Completed in 0ms
      476 timing idealTree:node_modules/@node-red/nodes/node_modules/acorn-walk Completed in 0ms
      477 silly placeDep node_modules/@node-red/nodes json-schema-traverse@1.0.0 OK for: ajv@8.11.0 want: ^1.0.0
      478 silly placeDep ROOT require-from-string@2.0.2 OK for: ajv@8.11.0 want: ^2.0.2
      479 timing idealTree:node_modules/@node-red/nodes/node_modules/ajv Completed in 3ms
      480 timing idealTree:node_modules/require-from-string Completed in 0ms
      481 timing idealTree:node_modules/@node-red/nodes/node_modules/denque Completed in 0ms
      482 timing idealTree:node_modules/@node-red/nodes/node_modules/form-data Completed in 0ms
      483 silly placeDep node_modules/@node-red/nodes @sindresorhus/is@4.6.0 OK for: got@11.8.5 want: ^4.0.0
      484 silly placeDep node_modules/@node-red/nodes cacheable-lookup@5.0.4 OK for: got@11.8.5 want: ^5.0.3
      485 silly placeDep node_modules/@node-red/nodes decompress-response@6.0.0 OK for: got@11.8.5 want: ^6.0.0
      486 silly fetch manifest mimic-response@^3.1.0
      487 http fetch GET 200 https://registry.npmjs.org/mimic-response 3ms (cache hit)
      488 timing idealTree:node_modules/@node-red/nodes/node_modules/got Completed in 16ms
      489 timing idealTree:node_modules/@node-red/nodes/node_modules/@sindresorhus/is Completed in 0ms
      490 timing idealTree:node_modules/@node-red/nodes/node_modules/cacheable-lookup Completed in 0ms
      491 silly placeDep node_modules/@node-red/nodes mimic-response@3.1.0 OK for: decompress-response@6.0.0 want: ^3.1.0
      492 timing idealTree:node_modules/@node-red/nodes/node_modules/decompress-response Completed in 19ms
      493 timing idealTree:node_modules/@node-red/nodes/node_modules/iconv-lite Completed in 0ms
      494 silly placeDep node_modules/@node-red/nodes argparse@2.0.1 OK for: js-yaml@4.1.0 want: ^2.0.1
      495 timing idealTree:node_modules/@node-red/nodes/node_modules/js-yaml Completed in 2ms
      496 timing idealTree:node_modules/@node-red/nodes/node_modules/argparse Completed in 0ms
      497 timing idealTree:node_modules/@node-red/nodes/node_modules/json-schema-traverse Completed in 0ms
      498 timing idealTree:node_modules/@node-red/nodes/node_modules/media-typer Completed in 0ms
      499 timing idealTree:node_modules/@node-red/nodes/node_modules/mimic-response Completed in 0ms
      500 silly placeDep node_modules/@node-red/nodes universalify@0.1.2 OK for: tough-cookie@4.0.0 want: ^0.1.2
      501 timing idealTree:node_modules/@node-red/nodes/node_modules/tough-cookie Completed in 1ms
      502 timing idealTree:node_modules/@node-red/nodes/node_modules/universalify Completed in 0ms
      503 timing idealTree:node_modules/@node-red/nodes/node_modules/uuid Completed in 0ms
      504 timing idealTree:node_modules/@node-red/nodes/node_modules/ws Completed in 0ms
      505 timing idealTree:node_modules/async-mutex/node_modules/tslib Completed in 0ms
      506 timing idealTree:node_modules/bson/node_modules/buffer Completed in 0ms
      507 timing idealTree:node_modules/cheerio/node_modules/tslib Completed in 0ms
      508 timing idealTree:node_modules/cli-table/node_modules/colors Completed in 0ms
      509 timing idealTree:node_modules/express-session/node_modules/cookie Completed in 0ms
      510 timing idealTree:node_modules/express-session/node_modules/depd Completed in 0ms
      511 timing idealTree:node_modules/express-session/node_modules/safe-buffer Completed in 0ms
      512 timing idealTree:node_modules/fs.notify/node_modules/async Completed in 0ms
      513 silly placeDep node_modules/memorystore ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
      514 timing idealTree:node_modules/memorystore/node_modules/debug Completed in 1ms
      515 silly placeDep ROOT pseudomap@1.0.2 OK for: lru-cache@4.1.5 want: ^1.0.2
      516 silly placeDep node_modules/memorystore yallist@2.1.2 OK for: lru-cache@4.1.5 want: ^2.1.2
      517 timing idealTree:node_modules/memorystore/node_modules/lru-cache Completed in 3ms
      518 timing idealTree:node_modules/pseudomap Completed in 0ms
      519 timing idealTree:node_modules/memorystore/node_modules/ms Completed in 0ms
      520 timing idealTree:node_modules/memorystore/node_modules/yallist Completed in 0ms
      521 timing idealTree:node_modules/mongodb-connection-string-url/node_modules/whatwg-url Completed in 0ms
      522 timing idealTree:node_modules/mongodb/node_modules/denque Completed in 0ms
      523 timing idealTree:node_modules/mqtt/node_modules/concat-stream Completed in 0ms
      524 silly placeDep node_modules/mqtt ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
      525 timing idealTree:node_modules/mqtt/node_modules/debug Completed in 1ms
      526 timing idealTree:node_modules/mqtt/node_modules/duplexify Completed in 0ms
      527 timing idealTree:node_modules/mqtt/node_modules/ms Completed in 0ms
      528 timing idealTree:node_modules/mqtt/node_modules/readable-stream Completed in 0ms
      529 timing idealTree:node_modules/mqtt/node_modules/ws Completed in 0ms
      530 silly placeDep node_modules/node-red-admin form-data@4.0.0 OK for: axios@0.27.2 want: ^4.0.0
      531 timing idealTree:node_modules/node-red-admin/node_modules/axios Completed in 1ms
      532 timing idealTree:node_modules/node-red-admin/node_modules/form-data Completed in 0ms
      533 timing idealTree:node_modules/socks/node_modules/ip Completed in 0ms
      534 timing idealTree:buildDeps Completed in 2232ms
      535 timing idealTree:fixDepFlags Completed in 14ms
      536 timing idealTree Completed in 3573ms
      537 timing reify:loadTrees Completed in 3575ms
      538 timing reify:diffTrees Completed in 42ms
      539 silly reify mark retired [ '/opt/iobroker/node_modules/addressparser' ]
      540 silly reify mark retired [ '/opt/iobroker/node_modules/ansi-colors' ]
      541 silly reify mark retired [ '/opt/iobroker/node_modules/append-field' ]
      542 silly reify mark retired [ '/opt/iobroker/node_modules/array-indexofobject' ]
      543 silly reify mark retired [ '/opt/iobroker/node_modules/async-mutex/node_modules/tslib' ]
      544 silly reify mark retired [ '/opt/iobroker/node_modules/bcryptjs' ]
      545 silly reify mark retired [ '/opt/iobroker/node_modules/boolbase' ]
      546 silly reify mark retired [ '/opt/iobroker/node_modules/bson' ]
      547 silly reify mark retired [ '/opt/iobroker/node_modules/cheerio/node_modules/cheerio-select' ]
      548 silly reify mark retired [ '/opt/iobroker/node_modules/cheerio/node_modules/tslib' ]
      549 silly reify mark retired [ '/opt/iobroker/node_modules/cheerio-select' ]
      550 silly reify mark retired [ '/opt/iobroker/node_modules/cli-table/node_modules/colors' ]
      551 silly reify mark retired [ '/opt/iobroker/node_modules/clone' ]
      552 silly reify mark retired [ '/opt/iobroker/node_modules/destroy' ]
      553 silly reify mark retired [ '/opt/iobroker/node_modules/express-session' ]
      554 silly reify mark retired [ '/opt/iobroker/node_modules/finalhandler' ]
      555 silly reify mark retired [ '/opt/iobroker/node_modules/fs.notify' ]
      556 silly reify mark retired [ '/opt/iobroker/node_modules/hpagent' ]
      557 silly reify mark retired [ '/opt/iobroker/node_modules/https-proxy-agent' ]
      558 silly reify mark retired [ '/opt/iobroker/node_modules/i18next' ]
      559 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin/node_modules/depd' ]
      560 silly reify mark retired [
      560 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/express-session'
      560 silly reify ]
      561 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin/node_modules/passport' ]
      562 silly reify mark retired [
      562 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer'
      562 silly reify ]
      563 silly reify mark retired [
      563 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/semver',
      563 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/.bin/semver'
      563 silly reify ]
      564 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.cloud/node_modules/passport' ]
      565 silly reify mark retired [
      565 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver',
      565 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver'
      565 silly reify ]
      566 silly reify mark retired [
      566 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/concat-stream'
      566 silly reify ]
      567 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/debug' ]
      568 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/duplexify' ]
      569 silly reify mark retired [
      569 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt',
      569 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt_pub',
      569 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt_sub',
      569 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt'
      569 silly reify ]
      570 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/ms' ]
      571 silly reify mark retired [
      571 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream'
      571 silly reify ]
      572 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.node-red' ]
      573 silly reify mark retired [
      573 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/cheerio'
      573 silly reify ]
      574 silly reify mark retired [
      574 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/dom-serializer'
      574 silly reify ]
      575 silly reify mark retired [
      575 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domelementtype'
      575 silly reify ]
      576 silly reify mark retired [
      576 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domhandler'
      576 silly reify ]
      577 silly reify mark retired [
      577 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domutils'
      577 silly reify ]
      578 silly reify mark retired [
      578 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/entities'
      578 silly reify ]
      579 silly reify mark retired [
      579 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/htmlparser2'
      579 silly reify ]
      580 silly reify mark retired [
      580 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/tslib'
      580 silly reify ]
      581 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.socketio/node_modules/cookie' ]
      582 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.socketio/node_modules/depd' ]
      583 silly reify mark retired [
      583 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/express-session'
      583 silly reify ]
      584 silly reify mark retired [
      584 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/safe-buffer'
      584 silly reify ]
      585 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.web/node_modules/cookie' ]
      586 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.web/node_modules/depd' ]
      587 silly reify mark retired [
      587 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/express-session'
      587 silly reify ]
      588 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.web/node_modules/passport' ]
      589 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.web/node_modules/safe-buffer' ]
      590 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ws/node_modules/cookie' ]
      591 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ws/node_modules/depd' ]
      592 silly reify mark retired [
      592 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/express-session'
      592 silly reify ]
      593 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.ws/node_modules/safe-buffer' ]
      594 silly reify mark retired [ '/opt/iobroker/node_modules/is-utf8' ]
      595 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.assign' ]
      596 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.clonedeep' ]
      597 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.get' ]
      598 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.has' ]
      599 silly reify mark retired [ '/opt/iobroker/node_modules/lodash.uniq' ]
      600 silly reify mark retired [ '/opt/iobroker/node_modules/memorystore/node_modules/yallist' ]
      601 silly reify mark retired [ '/opt/iobroker/node_modules/moment' ]
      602 silly reify mark retired [ '/opt/iobroker/node_modules/moment-timezone' ]
      603 silly reify mark retired [ '/opt/iobroker/node_modules/mongodb' ]
      604 silly reify mark retired [ '/opt/iobroker/node_modules/mongodb-connection-string-url' ]
      605 silly reify mark retired [
      605 silly reify   '/opt/iobroker/node_modules/mqtt',
      605 silly reify   '/opt/iobroker/node_modules/.bin/mqtt_pub',
      605 silly reify   '/opt/iobroker/node_modules/.bin/mqtt_sub',
      605 silly reify   '/opt/iobroker/node_modules/.bin/mqtt'
      605 silly reify ]
      606 silly reify mark retired [ '/opt/iobroker/node_modules/multer' ]
      607 silly reify mark retired [
      607 silly reify   '/opt/iobroker/node_modules/node-red',
      607 silly reify   '/opt/iobroker/node_modules/.bin/node-red',
      607 silly reify   '/opt/iobroker/node_modules/.bin/node-red-pi'
      607 silly reify ]
      608 silly reify mark retired [
      608 silly reify   '/opt/iobroker/node_modules/node-red-admin',
      608 silly reify   '/opt/iobroker/node_modules/.bin/node-red-admin'
      608 silly reify ]
      609 silly reify mark retired [ '/opt/iobroker/node_modules/node-red-node-email' ]
      610 silly reify mark retired [ '/opt/iobroker/node_modules/node-red-node-feedparser' ]
      611 silly reify mark retired [ '/opt/iobroker/node_modules/nth-check' ]
      612 silly reify mark retired [ '/opt/iobroker/node_modules/on-finished' ]
      613 silly reify mark retired [ '/opt/iobroker/node_modules/passport' ]
      614 silly reify mark retired [ '/opt/iobroker/node_modules/passport-http-bearer' ]
      615 silly reify mark retired [ '/opt/iobroker/node_modules/passport-oauth2-client-password' ]
      616 silly reify mark retired [ '/opt/iobroker/node_modules/pseudomap' ]
      617 silly reify mark retired [ '/opt/iobroker/node_modules/retry' ]
      618 silly reify mark retired [
      618 silly reify   '/opt/iobroker/node_modules/semver',
      618 silly reify   '/opt/iobroker/node_modules/.bin/semver'
      618 silly reify ]
      619 silly reify mark retired [
      619 silly reify   '/opt/iobroker/node_modules/sharp/node_modules/semver',
      619 silly reify   '/opt/iobroker/node_modules/sharp/node_modules/.bin/semver'
      619 silly reify ]
      620 silly reify mark retired [ '/opt/iobroker/node_modules/socks' ]
      621 silly reify mark retired [ '/opt/iobroker/node_modules/sparse-bitfield' ]
      622 silly reify mark retired [ '/opt/iobroker/node_modules/statuses' ]
      623 silly reify mark retired [ '/opt/iobroker/node_modules/streamsearch' ]
      624 silly reify mark retired [
      624 silly reify   '/opt/iobroker/node_modules/uglify-js',
      624 silly reify   '/opt/iobroker/node_modules/.bin/uglifyjs'
      624 silly reify ]
      625 silly reify mark retired [ '/opt/iobroker/node_modules/@babel/runtime' ]
      626 silly reify mark retired [
      626 silly reify   '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/passport'
      626 silly reify ]
      627 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/editor-api' ]
      628 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/editor-client' ]
      629 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/nodes' ]
      630 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/registry' ]
      631 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/runtime' ]
      632 silly reify mark retired [ '/opt/iobroker/node_modules/@node-red/util' ]
      633 silly reify mark retired [ '/opt/iobroker/node_modules/@types/whatwg-url' ]
      634 silly reify moves {
      634 silly reify   '/opt/iobroker/node_modules/addressparser': '/opt/iobroker/node_modules/.addressparser-qF9vtHFg',
      634 silly reify   '/opt/iobroker/node_modules/ansi-colors': '/opt/iobroker/node_modules/.ansi-colors-qAZfUuTD',
      634 silly reify   '/opt/iobroker/node_modules/append-field': '/opt/iobroker/node_modules/.append-field-e9miM7oT',
      634 silly reify   '/opt/iobroker/node_modules/array-indexofobject': '/opt/iobroker/node_modules/.array-indexofobject-CZUmKBfr',
      634 silly reify   '/opt/iobroker/node_modules/async-mutex/node_modules/tslib': '/opt/iobroker/node_modules/async-mutex/node_modules/.tslib-rMDsFAkc',
      634 silly reify   '/opt/iobroker/node_modules/bcryptjs': '/opt/iobroker/node_modules/.bcryptjs-aQgtHtN0',
      634 silly reify   '/opt/iobroker/node_modules/boolbase': '/opt/iobroker/node_modules/.boolbase-8130XECE',
      634 silly reify   '/opt/iobroker/node_modules/bson': '/opt/iobroker/node_modules/.bson-a4WfR2fa',
      634 silly reify   '/opt/iobroker/node_modules/cheerio/node_modules/cheerio-select': '/opt/iobroker/node_modules/cheerio/node_modules/.cheerio-select-27vO1B1R',
      634 silly reify   '/opt/iobroker/node_modules/cheerio/node_modules/tslib': '/opt/iobroker/node_modules/cheerio/node_modules/.tslib-EZxPbhJ8',
      634 silly reify   '/opt/iobroker/node_modules/cheerio-select': '/opt/iobroker/node_modules/.cheerio-select-Y5sIvfLc',
      634 silly reify   '/opt/iobroker/node_modules/cli-table/node_modules/colors': '/opt/iobroker/node_modules/cli-table/node_modules/.colors-cJQgsQ1G',
      634 silly reify   '/opt/iobroker/node_modules/clone': '/opt/iobroker/node_modules/.clone-p3TMAGgu',
      634 silly reify   '/opt/iobroker/node_modules/destroy': '/opt/iobroker/node_modules/.destroy-ZfJpRRrp',
      634 silly reify   '/opt/iobroker/node_modules/express-session': '/opt/iobroker/node_modules/.express-session-u0QSDs0s',
      634 silly reify   '/opt/iobroker/node_modules/finalhandler': '/opt/iobroker/node_modules/.finalhandler-YHTUOEck',
      634 silly reify   '/opt/iobroker/node_modules/fs.notify': '/opt/iobroker/node_modules/.fs.notify-C4n80h6t',
      634 silly reify   '/opt/iobroker/node_modules/hpagent': '/opt/iobroker/node_modules/.hpagent-PUXuWBzq',
      634 silly reify   '/opt/iobroker/node_modules/https-proxy-agent': '/opt/iobroker/node_modules/.https-proxy-agent-AiV4Y07N',
      634 silly reify   '/opt/iobroker/node_modules/i18next': '/opt/iobroker/node_modules/.i18next-VFNyugyK',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/depd': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.depd-JjqvbijE',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/express-session': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.express-session-esOkQMF4',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/passport': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.passport-4I2fLNnH',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.safe-buffer-zo81UdjE',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/semver': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.semver-6wMrgvKG',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.admin/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.admin/node_modules/.bin/.semver-sU6Kunpg',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.cloud/node_modules/passport': '/opt/iobroker/node_modules/iobroker.cloud/node_modules/.passport-SX2OiofV',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.semver-nXF4HfsQ',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/semver': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin/.semver-Dy7i6zG2',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/concat-stream': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.concat-stream-49HFOYbl',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/debug': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.debug-Fk5FqXGC',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/duplexify': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.duplexify-UttNPDJG',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.mqtt-n2S36XkG',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt_pub': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/.mqtt_pub-u5aXLOTU',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt_sub': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/.mqtt_sub-3gzhcrHd',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/mqtt': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.bin/.mqtt-Cv5c20Vf',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/ms': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.ms-0d57qAAX',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/readable-stream': '/opt/iobroker/node_modules/iobroker.mqtt/node_modules/.readable-stream-nz1Xpi3N',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.node-red': '/opt/iobroker/node_modules/.iobroker.node-red-lv0iVi6J',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/cheerio': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.cheerio-0AaonLoQ',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/dom-serializer': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.dom-serializer-5vJn51aa',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domelementtype': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.domelementtype-m5brpJtC',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domhandler': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.domhandler-afccCSOK',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/domutils': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.domutils-n5Ecugzo',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/entities': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.entities-CJV5dfhy',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/htmlparser2': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.htmlparser2-Ll4M4y58',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/tslib': '/opt/iobroker/node_modules/iobroker.smartcontrol/node_modules/.tslib-AiZajDxW',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/cookie': '/opt/iobroker/node_modules/iobroker.socketio/node_modules/.cookie-x4CgJJqB',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/depd': '/opt/iobroker/node_modules/iobroker.socketio/node_modules/.depd-fiIaPYgp',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/express-session': '/opt/iobroker/node_modules/iobroker.socketio/node_modules/.express-session-7gH1yiuQ',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.socketio/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.socketio/node_modules/.safe-buffer-R2f8sOn1',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/cookie': '/opt/iobroker/node_modules/iobroker.web/node_modules/.cookie-tK2ONQ1o',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/depd': '/opt/iobroker/node_modules/iobroker.web/node_modules/.depd-C51S9yJW',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/express-session': '/opt/iobroker/node_modules/iobroker.web/node_modules/.express-session-KGQpMhv6',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/passport': '/opt/iobroker/node_modules/iobroker.web/node_modules/.passport-1f6klSVy',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.web/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.web/node_modules/.safe-buffer-BypeWEGr',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/cookie': '/opt/iobroker/node_modules/iobroker.ws/node_modules/.cookie-BztL0LG3',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/depd': '/opt/iobroker/node_modules/iobroker.ws/node_modules/.depd-ed8nl6Sq',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/express-session': '/opt/iobroker/node_modules/iobroker.ws/node_modules/.express-session-dsS21CTq',
      634 silly reify   '/opt/iobroker/node_modules/iobroker.ws/node_modules/safe-buffer': '/opt/iobroker/node_modules/iobroker.ws/node_modules/.safe-buffer-jEbvbUSf',
      634 silly reify   '/opt/iobroker/node_modules/is-utf8': '/opt/iobroker/node_modules/.is-utf8-XzPsDN8p',
      634 silly reify   '/opt/iobroker/node_modules/lodash.assign': '/opt/iobroker/node_modules/.lodash.assign-D1kEZF4K',
      634 silly reify   '/opt/iobroker/node_modules/lodash.clonedeep': '/opt/iobroker/node_modules/.lodash.clonedeep-ZCp0kB7v',
      634 silly reify   '/opt/iobroker/node_modules/lodash.get': '/opt/iobroker/node_modules/.lodash.get-TIpVnLkf',
      634 silly reify   '/opt/iobroker/node_modules/lodash.has': '/opt/iobroker/node_modules/.lodash.has-uW6pvZYe',
      634 silly reify   '/opt/iobroker/node_modules/lodash.uniq': '/opt/iobroker/node_modules/.lodash.uniq-tQcTNHTM',
      634 silly reify   '/opt/iobroker/node_modules/memorystore/node_modules/yallist': '/opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ',
      634 silly reify   '/opt/iobroker/node_modules/moment': '/opt/iobroker/node_modules/.moment-YVTvHlwl',
      634 silly reify   '/opt/iobroker/node_modules/moment-timezone': '/opt/iobroker/node_modules/.moment-timezone-LVF6Tkme',
      634 silly reify   '/opt/iobroker/node_modules/mongodb': '/opt/iobroker/node_modules/.mongodb-9LMcV19S',
      634 silly reify   '/opt/iobroker/node_modules/mongodb-connection-string-url': '/opt/iobroker/node_modules/.mongodb-connection-string-url-iEu3f9Lf',
      634 silly reify   '/opt/iobroker/node_modules/mqtt': '/opt/iobroker/node_modules/.mqtt-uuzoX3iL',
      634 silly reify   '/opt/iobroker/node_modules/.bin/mqtt_pub': '/opt/iobroker/node_modules/.bin/.mqtt_pub-zrQkbc14',
      634 silly reify   '/opt/iobroker/node_modules/.bin/mqtt_sub': '/opt/iobroker/node_modules/.bin/.mqtt_sub-bGAW6Av6',
      634 silly reify   '/opt/iobroker/node_modules/.bin/mqtt': '/opt/iobroker/node_modules/.bin/.mqtt-QrHvOaHR',
      634 silly reify   '/opt/iobroker/node_modules/multer': '/opt/iobroker/node_modules/.multer-zsSYw8fD',
      634 silly reify   '/opt/iobroker/node_modules/node-red': '/opt/iobroker/node_modules/.node-red-Kvc6EPdV',
      634 silly reify   '/opt/iobroker/node_modules/.bin/node-red': '/opt/iobroker/node_modules/.bin/.node-red-sdXvnEer',
      634 silly reify   '/opt/iobroker/node_modules/.bin/node-red-pi': '/opt/iobroker/node_modules/.bin/.node-red-pi-ATJhhobv',
      634 silly reify   '/opt/iobroker/node_modules/node-red-admin': '/opt/iobroker/node_modules/.node-red-admin-97cICUzY',
      634 silly reify   '/opt/iobroker/node_modules/.bin/node-red-admin': '/opt/iobroker/node_modules/.bin/.node-red-admin-FCYEkrmv',
      634 silly reify   '/opt/iobroker/node_modules/node-red-node-email': '/opt/iobroker/node_modules/.node-red-node-email-1lk8B7Gi',
      634 silly reify   '/opt/iobroker/node_modules/node-red-node-feedparser': '/opt/iobroker/node_modules/.node-red-node-feedparser-BvY866YR',
      634 silly reify   '/opt/iobroker/node_modules/nth-check': '/opt/iobroker/node_modules/.nth-check-eGbySuuM',
      634 silly reify   '/opt/iobroker/node_modules/on-finished': '/opt/iobroker/node_modules/.on-finished-RsKM9iVb',
      634 silly reify   '/opt/iobroker/node_modules/passport': '/opt/iobroker/node_modules/.passport-7EnVXKbn',
      634 silly reify   '/opt/iobroker/node_modules/passport-http-bearer': '/opt/iobroker/node_modules/.passport-http-bearer-zcWcr11B',
      634 silly reify   '/opt/iobroker/node_modules/passport-oauth2-client-password': '/opt/iobroker/node_modules/.passport-oauth2-client-password-1oKaUbzI',
      634 silly reify   '/opt/iobroker/node_modules/pseudomap': '/opt/iobroker/node_modules/.pseudomap-whVLjSGu',
      634 silly reify   '/opt/iobroker/node_modules/retry': '/opt/iobroker/node_modules/.retry-MZDYeyTM',
      634 silly reify   '/opt/iobroker/node_modules/semver': '/opt/iobroker/node_modules/.semver-n8m5lQuN',
      634 silly reify   '/opt/iobroker/node_modules/.bin/semver': '/opt/iobroker/node_modules/.bin/.semver-LPDaIsIH',
      634 silly reify   '/opt/iobroker/node_modules/sharp/node_modules/semver': '/opt/iobroker/node_modules/sharp/node_modules/.semver-jHbwlJzq',
      634 silly reify   '/opt/iobroker/node_modules/sharp/node_modules/.bin/semver': '/opt/iobroker/node_modules/sharp/node_modules/.bin/.semver-d8arqhS7',
      634 silly reify   '/opt/iobroker/node_modules/socks': '/opt/iobroker/node_modules/.socks-Ly3eN6mV',
      634 silly reify   '/opt/iobroker/node_modules/sparse-bitfield': '/opt/iobroker/node_modules/.sparse-bitfield-vEiH9CFp',
      634 silly reify   '/opt/iobroker/node_modules/statuses': '/opt/iobroker/node_modules/.statuses-WEHZIwCf',
      634 silly reify   '/opt/iobroker/node_modules/streamsearch': '/opt/iobroker/node_modules/.streamsearch-oBszVB4V',
      634 silly reify   '/opt/iobroker/node_modules/uglify-js': '/opt/iobroker/node_modules/.uglify-js-UrZ3Klfa',
      634 silly reify   '/opt/iobroker/node_modules/.bin/uglifyjs': '/opt/iobroker/node_modules/.bin/.uglifyjs-Uwoamhq6',
      634 silly reify   '/opt/iobroker/node_modules/@babel/runtime': '/opt/iobroker/node_modules/@babel/.runtime-cSN2FFol',
      634 silly reify   '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/passport': '/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/.passport-Pt2lVh52',
      634 silly reify   '/opt/iobroker/node_modules/@node-red/editor-api': '/opt/iobroker/node_modules/@node-red/.editor-api-Xk7v1FU7',
      634 silly reify   '/opt/iobroker/node_modules/@node-red/editor-client': '/opt/iobroker/node_modules/@node-red/.editor-client-FpqhSpDH',
      634 silly reify   '/opt/iobroker/node_modules/@node-red/nodes': '/opt/iobroker/node_modules/@node-red/.nodes-oC2yqxJN',
      634 silly reify   '/opt/iobroker/node_modules/@node-red/registry': '/opt/iobroker/node_modules/@node-red/.registry-ccnbcuRd',
      634 silly reify   '/opt/iobroker/node_modules/@node-red/runtime': '/opt/iobroker/node_modules/@node-red/.runtime-1jQRdxlO',
      634 silly reify   '/opt/iobroker/node_modules/@node-red/util': '/opt/iobroker/node_modules/@node-red/.util-sbKUIGKV',
      634 silly reify   '/opt/iobroker/node_modules/@types/whatwg-url': '/opt/iobroker/node_modules/@types/.whatwg-url-st9gKEiR'
      634 silly reify }
      635 timing reify:rollback:retireShallow Completed in 27ms
      636 timing command:install Completed in 3677ms
      637 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/memorystore/node_modules/yallist' -> '/opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ'
      638 verbose cwd /opt/iobroker
      639 verbose Linux 5.15.39-3-pve
      640 verbose node v16.17.0
      641 verbose npm  v8.15.0
      642 error code ENOTEMPTY
      643 error syscall rename
      644 error path /opt/iobroker/node_modules/memorystore/node_modules/yallist
      645 error dest /opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ
      646 error errno -39
      647 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/memorystore/node_modules/yallist' -> '/opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ'
      648 verbose exit -39
      649 timing npm Completed in 3846ms
      650 verbose unfinished npm timer reify 1660837399323
      651 verbose unfinished npm timer reify:retireShallow 1660837402946
      652 verbose code -39
      653 error A complete log of this run can be found in:
      653 error     /home/iobroker/.npm/_logs/2022-08-18T15_43_19_158Z-debug-0.log
      Ist das der Fehler, denn die werden in dann in jedem Durchlauf angemahnt und ich kann sie dann manuell löschen.
      JohGreJ Offline
      JohGreJ Offline
      JohGre
      @palm_maniac sagte in Error 25: npm ERR! code ENOTEMPTY:
      Habe das selbe Problem mit node-red 4.0.0 ebenfalls schon gefühlte 100 Verzeichnisse umbenannt, jedoch sobald ich den Ordner /opt/iobroker/node_modules/sharp/node_modules/semver umbenenne funktioniert ein
      ioBroker upgrade node-red@4.0.0 --debug
      nicht mehr und quittiert mit einer Fehlermeldung. Die hab ich jetzt leider nicht mehr bei der Hand.
      Hab dann ein Proxmox-Backup eingespielt und nun tuts wieder.
      nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
      • JohGreJ JohGre
        @johgre sagte in Error 25: npm ERR! code ENOTEMPTY:
        Der ist ja auch nicht zu löschen.
        JohGreJ 1 Antwort Letzte Antwort
          JohGreJ Offline
          JohGreJ Offline
          JohGre
          @thomas-braun sagte in Error 25: npm ERR! code ENOTEMPTY:
          wird aber als
          error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/semver ...
          angemeckert
          • JohGreJ JohGre
            wird aber als
            angemeckert
            @johgre
            Joh, die .verzeichis-asdfadsf Dinger sollen aber gelöscht werden.
              @johgre
              JohGreJ Offline
              JohGreJ Offline
              JohGre
              @johgre
              ok, dann hab ichs komplett falsch verstanden, hab alle Pfade die so ausgespuckt wurden auf diese ./Dinger renamed.
              Werd ich dann nochmal versuchen und diesmal löschen
              • JohGreJ JohGre
                @johgre
                @johgre
                Ich zitier mich mal selber.
                Etwas leichter kannst du es dir mit dem Einzeiler machen:
                for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                Jeweils in dem Verzeichnis mit den angemeckerten Unterverzeichnissen ausführen.
                  @johgre
                  sk8er-boi
                  @johgre
                  Hallo Thomas,
                  vielen Dank für den Hinweis mit dem Löschen der Verzeichnisse.
                  Allerdings verstehe ich diese Zeile nicht so richtig, beziehungsweise kann sie nicht richtig anwenden:
                  daniel@iobroker:~$ nano /home/iobroker/.npm/_logs/2022-08-18T20_18_27_186Z-debug        -0.log
                  daniel@iobroker:~$ cd /opt/iobroker/node_modules/fsevents
                  daniel@iobroker:/opt/iobroker/node_modules/fsevents$ for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                  ls: Zugriff auf '.[^.]*-*/' nicht möglich: Datei oder Verzeichnis nicht gefunden
                  daniel@iobroker:/opt/iobroker/node_modules/fsevents$ cd
                  daniel@iobroker:/opt/iobroker/node_modules$ for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                  daniel@iobroker:/opt/iobroker/node_modules$ cd
                  daniel@iobroker:~$ cd /opt/iobroker/node_modules/.fsevents-yNYMVUiI
                  -bash: cd: /opt/iobroker/node_modules/.fsevents-yNYMVUiI: Datei oder Verzeichnis nicht gefunden
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/@node-red/.editor-client-FpqhSpDH
                  daniel@iobroker:~$ nano  /home/iobroker/.npm/_logs/2022-08-18T20_25_15_202Z-debug-0.log
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/@node-red/.nodes-oC2yqxJN
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/@node-red/.registry-ccnbcuRd
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/@node-red/.runtime-1jQRdxlO
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/@node-red/.util-sbKUIGKV
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/@types/.whatwg-url-st9gKEiR
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/aws-iot-device-sdk/node_modules/.minimist-3Ko1k3C3
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/data-urls/node_modules/.tr46-qG2IDMP0
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/data-urls/node_modules/.webidl-conversions-QfmXHvso
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/feedparser/node_modules/.isarray-poFLLYOV
                  daniel@iobroker:~$ nano  /home/iobroker/.npm/_logs/2022-08-18T20_34_04_612Z-debug-0.log
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/feedparser/node_modules/.readable-stream-i4t39GG2
                  daniel@iobroker:~$ nano  /home/iobroker/.npm/_logs/2022-08-18T20_35_39_514Z-debug-0.log
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/file-stream-rotator/node_modules/.moment-GftMgLXy
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/fs.notify/node_modules/.retry-w6hQMtL4
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.admin/node_modules/.cookie-HeL9cFXP
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.admin/node_modules/.depd-JjqvbijE
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.admin/node_modules/.express-session-esOkQMF4
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.admin/node_modules/.passport-4I2fLNnH
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.admin/node_modules/.safe-buffer-zo81UdjE
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.echarts/node_modules/.moment-SzyWJfLJ
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/.xml2js-sV7dyv4t
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.iot/node_modules/.moment-Krz705Ts
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.mqtt/node_modules/.concat-stream-49HFOYbl
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.mqtt/node_modules/.debug-Fk5FqXGC
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.mqtt/node_modules/.duplexify-UttNPDJG
                  daniel@iobroker:~$ nano  /home/iobroker/.npm/_logs/2022-08-18T20_42_25_097Z-debug-0.log
                  daniel@iobroker:~$ rm -rf /opt/iobroker/node_modules/iobroker.mqtt/node_modules/.minimist-3AuogxGc
                  daniel@iobroker:~$
                  Wie wende ich den Befehl richtig an?
                  Und müssen alle Verzeichnisse mit den .-xxxxx Sachen aus dem Log gelöscht werden ?
                  Ich hab jetzt ein wenig Try &Error die gelöscht die im Los als "rename" angezeigt wurden. Dann konnte ich irgendwann einzelne Adapter aktualliseren. Allerdings dauert das ja ewig. Aber ich würde irgendwann zum Ziel kommen.
                  Vielen Dank Daniel
                  PS: Warum verbietet mir das Forum andauert das Anworten ? :-) ( Fehler Forbidden)
                  Thomas BraunT GlasfaserG HomoranH 3 Antworten Letzte Antwort
                  • S sk8er-boi
                    @johgre
                    Hallo Thomas,
                    daniel@iobroker:~$
                    Vielen Dank Daniel
                    @sk8er-boi
                    Ist das ein docker auf Synology da bei dir?
                      @sk8er-boi
                      sk8er-boi
                      @thomas-braun nein eine proxmox vm auf einem normalen Intel Rechner. Proxmox 7 läuft dabei auch auf Debian 11.
                      • S sk8er-boi
                        @johgre
                        Hallo Thomas,
                        daniel@iobroker:~$
                        Vielen Dank Daniel
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @sk8er-boi sagte in Error 25: npm ERR! code ENOTEMPTY:
                        Nicht so wild mit dem Lösch Befehl arbeiten .
                        Machmal hilft auch danach ein reboot dazu .
                        • S sk8er-boi
                          @johgre
                          Hallo Thomas,
                          daniel@iobroker:~$
                          Vielen Dank Daniel
                          HomoranH Offline
                          HomoranH Offline
                          Warum verbietet mir das Forum andauert das Anworten ? ( Fehler Forbidden)
                          einfach Seite neu laden und nochmal senden.
                          Wahrscheinlich nutzst du Firefox und der hat sich verschluckt
                          • GlasfaserG Glasfaser
                            sk8er-boi
                            @glasfaser sagte in Error 25: npm ERR! code ENOTEMPTY:
                            Ich hab bislang nur die gelöscht die im Log unten drin standen.
                            reboot hab ich probiert. Hat leider nichts geändert.
                            • Palm_ManiacP Offline
                              Palm_Maniac
                              Hmm... Das Admin Update 6.2.16 lief zum Glück einwandfrei durch, während Node-Red 4 sich weiter weigert. Liegt das Problem vielleicht an Node-Red als Verursacher?
                              Leider kann ich kein Backup zurück spielen, da es mir sämtliche Berechnungen des Strom, Gas und Wasser Verbrauchs zerschießen würde und das ist mir wichtiger. Ich hoffe mal, das es irgendwann eine Lösung geben wird.
                              • Palm_ManiacP Palm_Maniac
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Nur meine Meinung ... nicht falsch verstehen . !!!
                                Du bist im BETA-Zweig ( Beta Tester ohne Erfahrung ) !! ... da kann jederzeit etwas schief gehen .
                                warum bist du nicht in Stable und pickst dir nur die Adapter aus Beta raus die du auch brauchst
                                Palm_ManiacP 1 Antwort Letzte Antwort
                                  Palm_Maniac
                                  schrieb am zuletzt editiert von Palm_Maniac
                                  @glasfaser Mach ich ja. Ich habe nur die Adapter laufen, die ich brauche, deshalb habe ich jetzt Node Red auch deinstalliert, weil es aktuell von mir nicht mehr genutzt wird.
                                  Proxmox macht bei mir vom iobroker ständig Backups, leider hat die Fehlersuche aber so lange gedauert, dass ich wegen der Menge der neu erfassten Daten keinen Weg mehr zurück hatte. Die Zeit hat da gegen mich und das Backup gespielt. Ich weiß, das ich im Beta Zweig bin, weshalb hier die Backup-Frequenz entsprechend hoch ist, aber da bin ich aus dem Zeitfenster rausgerutscht, was ich hätte noch "reparieren" können.
                                    HomoranH Offline
                                    HomoranH Offline
                                    nicht wirklich, wenn du mrinst was du schreibst.
                                    Proxmox macht von der gesamten VM ein Backup, mit allen Fehlkonfigurationen.
                                    backitup macht ein echtes iobroker update, das bei einem Restore komplett neu gebaut wird
                                      Palm_Maniac
                                      @homoran iobroker läuft hier als LXC Container und ja, ich möchte alles sichern, eventuell inkl. einer Fehlkonfiguration, eben ein Komplett-Backup. Bemerke ich nach einem Update einen Fehler, kann ich es so eingrenzen und stelle das gesamte iobroker System auf den Stand zuvor zurück. Alles Absicht und so gewollt. Bei der Methode kann ich mir wenigstens sicher sein, das auch wirklich alle erfassten Daten mit gesichert sind und ich weiß, dass das Proxmox-Backup funktioniert. Als Ziel setze ich da einen gesonderten PBS ein, also auch alles getrennt vom Rest.
                                        sk8er-boi
                                        Als Abschluss des Topics:
                                        Mit dieser Lösung :
                                        https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8/2
                                        konnte ich den Node-red Adapter und weitere wieder installieren/ updaten.
                                        Vielen Dank an Alle.
                                        Gruß Daniel
