  4. [Frage] Internetradio - wie geht das ?
    5.3k
107 Beiträge 22 Kommentatoren 39.3k Aufrufe 12 Beobachtet
  • Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    Was meinst du mit "Rechner"?
    Die Widgets müssen auf die vom Skript angelegten Objekte verweisen.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
      sveni_lee
      okay, war etwas umständlich formuliert…
      bei mir sehen die Objekte vom upnp-Adapter so aus:
      ~~![](</s><URL url=)http://i.imgur.com/KvnqTf8.jpg" />
      und mein selbst angelegtes Objekt wie folgt:
      ~~![](</s><URL url=)http://i.imgur.com/XfIH6x6.jpg" />
      und das sind ersten beiden Zeilen in meinem Skript:
      ~~![](</s><URL url=)http://i.imgur.com/huzyrOw.jpg" />
      und der play-Button (Widget)
      [{"tpl":"tplHqButton","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","oid":"javascript.0.Tablet.MediaControl.Play","min":"false","max":"true","iconName":"","btIconWidth":"56","offsetAuto":"true","leftOffset":"15","topOffset":"55","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"pushButton":true,"oid-battery":"","caption":"Play","captionOn":"Play","visibility-oid":"upnp.0.BubbleUPnP_(B3-A30).MediaRenderer.Alive","name":"Radio","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","descriptionLeft":"javascript.0.Tablet.MediaControl.Play"},"style":{"left":"958px","top":"475px","z-index":"3"},"widgetSet":"hqwidgets"}]
      ergibt dann folgenden Fehler im Log…
      ![](http://i.imgur.com/qkUbRye.jpg)~~![](</s><URL url=)http://i.imgur.com/qkUbRye.jpg" />
      Ich hoffe jetzt ist es besser nachzuvollziehen~~~~~~~~
      • Jey CeeJ Online
        Jey CeeJ Online
        Jey Cee
        Es sieht alles richtig aus.
        Aber die Fehlermeldung wird nicht ganz angezeigt. Wenn du mit der Maus drüber gehst und kurz wartet sollte sie ganz zu sehen sein.
        Eine mögliche Ursache wäre das die Remote Steuerung in den Einstellungen von Bubble Upnp deaktiviert ist.
        Und es muss ein Titel bei Play Now zu sehen sein, also einer der schon mal gespielt wurde. Falls du keinen von iobroker aus gesetzt hast bevor du play drückst.
          sveni_lee
          okay, das werde ich heute Abend mal überprüfen.
          Warum werden eigendlich unter UPnP zwei Geräte auf dem B3-A30 angezeigt?
          Ist es egal Welches ich benutze?
            sveni_lee
            so ich habe jetzt mal den kompletten Wortlaut der Fehlermeldung:
            Unexpected answer from upnp service: {'statusCode':500,'body':'s:ClientUPnPError501Current state of service prevents invoking that action.
            Target host must not be null, or set in parameters..','headers':{'ext':'','content-type':'text/xml;charset=utf-8','server':'Linux/3.18.22
            UPnP/1.0 BubbleUPnP/2.8.9','date':'Thu, 15 Jun 2017 15:59:26 GMT+00:00','content-length':'547','connection':'close'},
            'request':{'uri':{'protocol':'http:','slashes':true,'auth':null,'host':'192.168.1.216:58645','port':'58645','hostname':'192.168.1.216',
            'hash':null,'search':null,'query':null,'pathname':'/dev/9af0xxx/svc/upnp-org/AVTransport/action',
            'path':'/dev/9af0xxx/svc/upnp-org/AVTransport/action',
            'href':'http://192.168.1.216:58645/dev/9af0xxx/svc/upnp-org/AVTransport/action'},
            'method':'POST','headers':{'Content-Type':'text/xml; charset='utf-8'','SOAPAction':''urn:schemas-upnp-org:service:AVTransport:1#Play'',
            'USER-AGENT':'UPnP/1.0, ioBroker.upnp/0.3.5','content-length':266}}}
            Sent message: {'uri':'http://192.168.1.216:58645/dev/9af0xxx/svc/upnp-org/AVTransport/action',
            'USER-AGENT':'UPnP/1.0, ioBroker.upnp/0.3.5'},'method':'POST','body':'01'}
            • Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              Ein Eintrag ist der player und der andere ist die Medienbibliothek vom player in Form eines Medien Servers.
              Die Fehlermeldung deutet für mich darauf hin das die Remote Steuerung in den Einstellungen deaktiviert ist. Hast du da mal nachgeschaut?
                sveni_lee
                Ja, ich denke schon das ich die Freigabe auf dem Tablet richtig erteilt habe…
                Gesendet von meinem B3-A30 mit Tapatalk
                ![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201706 ... 2a26dd.jpg">https://uploads.tapatalk-cdn.com/20170615/272fd04ad76870b4590919197d2a26dd.jpg</link_text>" />
                • Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  So jetzt hab ich das mal nachgestellt. Der Fehler ist: Es ist einfach nichts da was er Wiedergeben kann.
                  @Jey Cee:
                  Und es muss ein Titel bei Play Now zu sehen sein, also einer der schon mal gespielt wurde. Falls du keinen von iobroker aus gesetzt hast bevor du play drückst. `
                    sveni_lee
                    aber ich habe doch die Url gesetzt… Ich sehe auch im Objektbaum kein Play Now
                    • Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      Dann gib mal direkt mit Bubble Upnp ein Lied wieder. Also direkt in der APP und stopp es wieder.
                      Danach mach play in iobroker. Wenn es jetzt geht liegt es an deinem link.
                      Poste den link mal hier.
                        sveni_lee
                        @Jey Cee:
                        Danach mach play in iobroker. Wenn es jetzt geht liegt es an deinem link. `
                        ja, das funktioniert…
                        @Jey Cee:
                        Poste den link mal hier. `
                        http://wdr-1live-diggi.icecast.wdr.de/w … stream.mp3
                        den hab ich aus deinem Widget übernommen...
                        • Jey CeeJ Online
                          Jey CeeJ Online
                          Jey Cee
                          OK der sollte schon gehen. Kannst du einen anderen probieren.
                            sveni_lee
                            super vielen Dank… jetzt funktioniert es genau so wie es soll...
                            super Arbeit.
                            jetzt kann ich mir drei vier station tasten anlegen und alles ist perfekt...
                            • Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              Super das ich helfen konnte
                                mafe68
                                Habe mir auch ein Internetradio in HTML gebastelt und hätte aber da noch eine Frage da nicht alles so geht wie ich möchte ;)
                                Hier mal das Skript das ich dazu geschrieben habe
                                <audio id="audio" preload="auto" tabindex="false" controls="controls" type="audio/mpeg">
                                    </audio>
                                *   [HitRadio-Ö3](http://mp3stream7.apasf.apa.at:8000/;stream.mp3)
                                *   [SlágerFM](http://92.61.114.159:7812/slagerfm128.mp3)
                                *   [ClassFM](http://109.199.61.243:80/4784/live.mp3)
                                *   [MusikFM](http://79.172.241.238:8000/musicfm.mp3)
                                Das ganze habe ich vis erstellt in dem ich ein HTML in eine Widget gezogen habe und dort dann den HTML Code eingefügt. So geht auch alles bis auf dass das wenn ich einen Sender anklicke wird im Browser ein neuer Tab geöffnet wo er dann das ganze abspielt. Kann ich das unterbinden das er einen neuen Tab aufmacht sondern das er den Sender einfach im Player abspielt?
                                LG. Mario
                                ioBroker LXC Container Proxmox
                                ioBroker BananaPi M1
                                • H Offline
                                  Heilu
                                  ` > So jetzt hier mal die Anleitung:
                                  1. Skript anlegen (JavaScript Adapter) und anpassen. Du musst nur die erste Zeile, das Gerät welches du steuern willst, und die zweite Zeile, wo die Hilfsobjekte erstellt werden, anpassen.
                                  Spoiler: Show hidden text `
                                  Hi, würde das gerne auch mal testen. Leider stimmt etwas mit dem Script in der Anleitung nicht. Den Fehler in der ersten Zeile habe ich schon korrigiert. Jetzt zeigt er mir allerdings noch einen Fehler in Zeile 74 und 94 an.
                                          if(oldMute == 0){
                                              setState(device + '.MediaRenderer.RenderingControl.SetMute.InstanceID', 0);
                                              setState(device + '.MediaRenderer.RenderingControl.SetMute.Channel', 'Master');
                                              setState(device + '.MediaRenderer.RenderingControl.SetMute.DesiredMute', 1);
                                              setState(device + '.MediaRenderer.RenderingControl.SetMute', 'send');
                                              //oldVol = getState(device + '.MediaRenderer.RenderingControl.Volume').val;
                                          }else{
                                              setState(device + '.MediaRenderer.RenderingControl.SetMute.DesiredMute', 0);
                                          setTimeout(function(){setState(obj.id, false);}, 150);
                                  on({id: control + '.MediaControl.MediaURL'
                                      }, function(obj){
                                      setState(device + '.MediaRenderer.AVTransport.SetAVTransportURI.CurrentURI', obj.newState.val);
                                      setState(device + '.MediaRenderer.AVTransport.SetAVTransportURI.InstanceID', 0);
                                      setState(device + '.MediaRenderer.AVTransport.SetAVTransportURI', 'send');
                                  Oder sehe ich da etwas falsch? Hab leider nicht so den Plan davon.
                                  • Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    @Heilu:
                                    Den Fehler in der ersten Zeile habe ich schon korrigiert. `
                                    Welchen Fehler? Die Zeile muss man immer anpassen.
                                    @Heilu:
                                    Jetzt zeigt er mir allerdings noch einen Fehler in Zeile 74 und 94 an. `
                                    Was für Fehler werden angezeigt? Im Editor oder im Log?
                                    • H Offline
                                      Heilu
                                      var device = "upnp.0.BubbleUPnP_Media_Server_(Tab2A7-10F); //Hier das upnp Gerät eintragen das gesteuert werden soll.
                                      Fehler mit dem Anführungszeichen!
                                      Und in Zeile 74
                                              if(oldMute == 0){
                                      Da wird bei mir das Ausrufezeichen angezeigt: 3 Gleichheitszeichen statt 2 ?!
                                      Und 94 Ausrufezeichen
                                      unrecoverable syntax error (98% scanned) wird da angezeigt.
                                      Im Log:
                                      > script.js.common.Homematic.BubbleUPnP compile failed: SyntaxError: Unexpected token }
                                      • Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        In Zeile 74 dürfen nur 2 == sein, sonst geht das nicht.
                                        Aber die anderen beiden Fehler kann ich nicht Nachvollziehen. Bei mir läuft das Skript 1:1 so.
                                        Möglicherweise ist irgendwo ein ( oder { verloren gegangen beim Kopieren. Was anders kann ich mir jetzt gerade nicht vorstellen.
                                        • H Offline
                                          Heilu
                                          Habe das mehrmals aus deinem Post kopiert.
                                          Könntest du mir evtl. das Script von dir nochmal zukommen lassen?
                                          Das wäre super.
