  4. Keine Verbindung zu Shelly
    5.7k
36 Beiträge 7 Kommentatoren 4.8k Aufrufe 6 Beobachtet
  • P Offline
    Phinix
    schrieb am zuletzt editiert von Phinix
    ich habe seit ein paar Tagen ein Problem mit meinem Shelly 1.
    Der Shelly Adapter verbindet sich nicht mit dem Shelly, laut Debug Infos kommen die CoAP Anfragen an, aber das Shelly antwortet nicht:
    2022-08-12 10:18:19.177 - debug: shelly.0 (1627) CoAP status package received: {"3332":"SHSW-1#E8DB84D253EC#2","3412":38400,"3420":1280,"Uri-Path":"cit/s"} / {"G":[[0,9103,3],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    2022-08-12 10:18:19.177 - debug: shelly.0 (1627) [CoAP Server] Status update received for SHSW-1#E8DB84D253EC#2: {"G":[[0,9103,3],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    2022-08-12 10:18:19.177 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(0)
    2022-08-12 10:18:21.178 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(1)
    2022-08-12 10:18:23.179 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(2)
    2022-08-12 10:18:24.309 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    2022-08-12 10:18:26.309 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    2022-08-12 10:18:28.310 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    2022-08-12 10:18:34.221 - debug: shelly.0 (1627) CoAP status package received: {"3332":"SHSW-1#E8DB84D253EC#2","3412":38400,"3420":1280,"Uri-Path":"cit/s"} / {"G":[[0,9103,3],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    2022-08-12 10:18:34.221 - debug: shelly.0 (1627) [CoAP Server] Status update received for SHSW-1#E8DB84D253EC#2: {"G":[[0,9103,3],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    2022-08-12 10:18:34.221 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(0)
    2022-08-12 10:18:36.222 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(1)
    2022-08-12 10:18:38.223 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(2)
    2022-08-12 10:18:39.344 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    2022-08-12 10:18:41.346 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    2022-08-12 10:18:43.346 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    2022-08-12 10:18:49.422 - debug: shelly.0 (1627) CoAP status package received: {"3332":"SHSW-1#E8DB84D253EC#2","3412":38400,"3420":1280,"Uri-Path":"cit/s"} / {"G":[[0,9103,3],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    2022-08-12 10:18:49.422 - debug: shelly.0 (1627) [CoAP Server] Status update received for SHSW-1#E8DB84D253EC#2: {"G":[[0,9103,3],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
    2022-08-12 10:18:49.423 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(0)
    2022-08-12 10:18:51.423 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(1)
    2022-08-12 10:18:53.423 - debug: shelly.0 (1627) CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(2)
    2022-08-12 10:18:54.554 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    2022-08-12 10:18:56.556 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    2022-08-12 10:18:58.564 - debug: shelly.0 (1627) [CoAP Server] Error - handling data: Error: No reply in 247 seconds.
    Ich habe den Adapter bereits neu installiert und auch die aktuellere Vers. 6.0 getestet.
    Der Shelly ist auf dem neuesten Stand:
    Current version: 20220209-092750/v1.11.8-g8c7bb8d
    You have latest version on your device!
    Davor lief alles ohne Probleme und von heute auf morgen hat sich das Gerät nicht mehr verbunden.
    ioBroker läuft in einer Ubuntu VM, welche aktuell ist.
    Node.js v16.16.0
    NPM 8.11.0
    JS-Controller 4.0.23
    Ich hoffe ihr könnt mir helfen :)
    • P Phinix
      Node.js v16.16.0
      NPM 8.11.0
      arteckA Offline
      arteckA Offline
      arteck
      @phinix kommst du mit der app drauf ?
      P 1 Antwort Letzte Antwort
      • arteckA arteck
        Phinix
        @arteck said in Keine Verbindung zu Shelly:
        Ja das funktioniert, App- und Browserzugriff ohne Probleme.
        • P Phinix
          da_WoodyD Online
          da_WoodyD Online
          @phinix adapter version?
          sorry, überlesen...
          • da_WoodyD da_Woody
            sorry, überlesen...
            Phinix
            @da_woody said in Keine Verbindung zu Shelly:
            sorry, überlesen...
            Ich hatte die letzte Version von Stable im Einsatz und hab dann gestern abend auf die Beta 6.0 gewechselt, hat aber mit keinen der beiden Versionen geklappt.
            • P Phinix
              sorry, überlesen...
              Phinix
              Ich habe gerade eben noch ein neues Shelly1 ausgepackt und angeschlossen, genau das gleiche Problem. Es meldet sich, der Adapter versucht eine Verbindung aufzubauen und das Shelly antwortet nicht...
              crunchipC da_WoodyD DJMarc75D 3 Antworten Letzte Antwort
              • P Phinix
                crunchipC Abwesend
                crunchipC Abwesend
                @phinix was wenn du hier mal umstellst
                • P Phinix
                  da_WoodyD Online
                  da_WoodyD Online
                  @phinix entweder wie @crunchip geschrieben hat, mit MQTT versuchen, oder eben auch unicast ColoT mit deiner IP vom ioB eintragen. der port wird beim speichern automatisch angehängt.
                    Phinix
                    @da_woody @crunchip
                    Ich habe die Shellys auf MQTT umgestellt, da funktionieren sie ohne Probleme.
                    Komisch das es über CoAP nicht mehr klappt, zumal sich im Netzwerk Hard- als auch Software nicht geändert hat...
                    • P Phinix
                      @da_woody @crunchip
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @phinix aber die Adapterversion, oder du hast vllt etwas in deinem Netzwerk verändert?
                        Phinix
                        @crunchip
                        Nein, die Adapterversion hatte ich erst geändert nachdem es nicht mehr funktioniert hatte. Ich war dauerhaft auf V5.x und bin erst mit den Problemen auf V6 gewechselt, in der Hoffnung das es danach wieder funktioniert.
                        Am Netzwerk hat sich eigentlich nicht geändert, Softwarestände von Fritzbox und Switch sind die gleichen. Das einzige was ich nicht sagen kann ist eventuell ein Windows Server 2016 Update (ioBroker läuft unter Hyper-V) ... aber ich denke dann würden hier ebenfalls auch einige andere die gleichen Probleme haben.
                        • P Phinix
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @phinix sagte in Keine Verbindung zu Shelly:
                          Shelly1
                          oder ist das ein Shelly 1 PLUS ?
                          Lehrling seit 1975 !!!
                          • DJMarc75D DJMarc75
                            Shelly1
                            da_WoodyD Online
                            da_WoodyD Online
                            @djmarc75 glaub ich nicht, im log steht SHSW-1. das ist der echte.
                            aber da von @Phinix keine infos über seine COaP einstellungen kommen, wirds schwierig.
                            nirgends was gelesen, ob er vom mcast auf unicast umgestellt hat. aber wenn er mit MQTT glücklich ist...
                            • P Phinix
                              @crunchip
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @phinix laut Doku
                              https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-coap.md
                                @phinix laut Doku
                                da_WoodyD Online
                                da_WoodyD Online
                                @crunchip wäre auch eine erklärung...
                                wobei der port beim speichern automatisch eingetragen wird. IP genügt.
                                  Phinix
                                  @DJMarc75 es handelt sich um das ganz normale Shelly1
                                  @da_Woody @crunchip die Shellys liefen ursprünglich direkt mit unicast, IP habe ich eingetragen, der Port wird automatisch ergänzt; dann kommen die Meldungen im Log aus meinem ersten Post.
                                  Ich habe gerade eben noch mcast getestet, funktioniert zwar auch nicht, aber es kommen auch überhaupt keine Meldungen mehr im Log über einen Verbindungsaufbau... somit eventuell doch ein Netzwerkproblem?
                                  • P Phinix
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    @phinix ob Du uns nicht mal die Einstellungen im Adapter und direkt am Shelly (advanced developer settings) per Screenshot zeigen magst ?
                                      Phinix
                                      @djmarc75 Klar.
                                      • P Phinix
                                        @djmarc75 Klar.
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @phinix
                                        dann halt nochmal auf mcast umstellen und das Device natürlich neu starten.
                                        Ebenso das http-passwort im Adapter rausnehmen.
                                        EDIT: da fällt mir grad auf dass der Adapter shelly.1 lautet.
                                        Sind da mehrere Instanzen am laufen ??
                                          @phinix
                                          Phinix
                                          @djmarc75 Ja, ich habe zum Testen gerade eine zweite Instanz installiert. Die Shelly.0 habe ich auf MQTT umgestellt damit die anderen Shellys im Netzwerk funktionieren.
                                          Shelly.1-Instanz läuft auf COaP.
                                          mcast und http-Kennwort habe ich geändert, klappt aber leider noch immer nicht.
                                          shelly.1
                                          2022-08-15 21:04:57.506	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(1)
                                          shelly.1
                                          2022-08-15 21:04:55.505	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(0)
                                          shelly.1
                                          2022-08-15 21:04:55.505	debug	[CoAP Server] Status update received for SHSW-1#E8DB84D253EC#2: {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                          shelly.1
                                          2022-08-15 21:04:55.504	debug	CoAP status package received: {"3332":"SHSW-1#E8DB84D253EC#2","3412":38400,"3420":256,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                          shelly.1
                                          2022-08-15 21:04:49.549	debug	[CoAP Server] Error - handling data: Error: No reply in 247 seconds.
                                          shelly.1
                                          2022-08-15 21:04:47.548	debug	[CoAP Server] Error - handling data: Error: No reply in 247 seconds.
                                          shelly.1
                                          2022-08-15 21:04:45.547	debug	[CoAP Server] Error - handling data: Error: No reply in 247 seconds.
                                          shelly.1
                                          2022-08-15 21:04:44.327	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(2)
                                          shelly.1
                                          2022-08-15 21:04:42.326	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(1)
                                          shelly.1
                                          2022-08-15 21:04:40.324	debug	CoAP device description request for SHSW-1#E8DB84D253EC#2 to 192.168.1.200(0)
                                          shelly.1
                                          2022-08-15 21:04:40.324	debug	[CoAP Server] Status update received for SHSW-1#E8DB84D253EC#2: {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                          shelly.1
                                          2022-08-15 21:04:40.323	debug	CoAP status package received: {"3332":"SHSW-1#E8DB84D253EC#2","3412":38400,"3420":256,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                                          DJMarc75D crunchipC 2 Antworten Letzte Antwort
