  4. Wie erteile ich USB-Zugriffsberechtigung?
    5.8k
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
27 Beiträge 4 Kommentatoren 4.4k Aufrufe 3 Beobachtet
  • R Reinhard 0
    Habe auch Stick einmal ab und angesteckt. Funktioniert leider immer noch nicht.
    IOBroker Log:
    host.raspberrypi	2021-02-25 12:58:46.880	info	instance system.adapter.rtl_433.0 terminated with code 2 (INVALID_ADAPTER_CONFIG)
    rtl_433.0	2021-02-25 12:58:46.501	info	(1466) cleaned everything up...
    host.raspberrypi	2021-02-25 12:58:46.500	info	stopInstance system.adapter.rtl_433.0 send kill signal
    rtl_433.0	2021-02-25 12:58:46.499	info	(1466) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi	2021-02-25 12:58:46.492	info	stopInstance system.adapter.rtl_433.0 (force=false, process=true)
    host.raspberrypi	2021-02-25 12:58:46.491	info	"system.adapter.rtl_433.0" disabled
    rtl_433.0	2021-02-25 12:58:46.335	warn	(1466) Terminated (INVALID_ADAPTER_CONFIG): Without reason
    rtl_433.0	2021-02-25 12:58:46.334	error	(1466) rtl_433 disconnected
    rtl_433.0	2021-02-25 12:58:46.329	info	Please fix the device permissions, e.g. by installing the udev rules file rtl-sdr.rules
    rtl_433.0	2021-02-25 12:58:46.329	info	(1466) rtl_433 STDERR: usb_open error -3
    rtl_433.0	2021-02-25 12:58:46.235	info	(1466) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.rtl_433, node: v12.21.0, js-controller: 3.2.16
    host.raspberrypi	2021-02-25 12:58:45.030	info	instance system.adapter.rtl_433.0 started with pid 1466
    host.raspberrypi	2021-02-25 12:58:14.990	info	Restart adapter system.adapter.rtl_433.0 because enabled
    host.raspberrypi	2021-02-25 12:58:14.989	error	instance system.adapter.rtl_433.0 terminated with code 2 (INVALID_ADAPTER_CONFIG)
    rtl_433.0	2021-02-25 12:58:14.962	info	(1447) cleaned everything up...
    rtl_433.0	2021-02-25 12:58:14.446	warn	(1447) Terminated (INVALID_ADAPTER_CONFIG): Without reason
    rtl_433.0	2021-02-25 12:58:14.445	error	(1447) rtl_433 disconnected
    rtl_433.0	2021-02-25 12:58:14.441	info	Please fix the device permissions, e.g. by installing the udev rules file rtl-sdr.rules
    rtl_433.0	2021-02-25 12:58:14.441	info	(1447) rtl_433 STDERR: usb_open error -3
    rtl_433.0	2021-02-25 12:58:14.355	info	(1447) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.rtl_433, node: v12.21.0, js-controller: 3.2.16
    host.raspberrypi	2021-02-25 12:58:13.201	info	instance system.adapter.rtl_433.0 started with pid 1447
    host.raspberrypi	2021-02-25 12:58:13.140	info	"system.adapter.rtl_433.0" enabled
    @reinhard-0 sagte in Wie erteile ich USB-Zugriffsberechtigung?:
    Gibt es das file? Und was steht drin?
    R 1 Antwort Letzte Antwort
      Reinhard 0
      das File gibt's nicht. Muss das wohl nochmal neu installieren oder das File anlegen. Was soll denn in dem File stehen?
      • R Reinhard 0
        @reinhard-0
        Da steht u. a. drin, welcher user da mit welchen Rechten zugreifen darf.
        Im Paket ist widererwarten keine 'blanko' Version der udev-Datei enthalten, dann musst du wohl selber eine schreiben.
        https://osmocom.org/projects/rtl-sdr/repository/revisions/master/entry/rtl-sdr.rules
          @reinhard-0
          Reinhard 0
          Vielen, vielen Dank!!!
          Ich war schon verzweifelt, habe das File erstellt und es geht.
          • 9 Offline
            9 Offline
            9_Mad-Max_5
            Sorry dass ich das alte Thema nochmal hochhole.
            Aber ich habe heute auch meinen rtl-sdr bekommen und an sich funktioniert er auch.
            Also ich kann direkt im Terminal meine Sensoren und ihre Werte sehen.
            Nur leider bekomme ich den Iobroker Adapter nicht ans laufen.
            Auch mit der Rules file nicht egal, ob die von dem RTL-SDR repo oder eine selbst geschnitzte es will einfach nicht.
            • 9 9_Mad-Max_5
              @9_mad-max_5 sagte in Wie erteile ich USB-Zugriffsberechtigung?:
              das dürfte das alte Hghlander Symptom sein.
              Es kann nur einen geben!
              Entweder Konsole oder Adapter.
              Also die Verbindung der Konsole zum USB-Port vor Initialisierung der Instanz vollständig beenden
              9 1 Antwort Letzte Antwort
                9 Offline
                9 Offline
                9_Mad-Max_5
                Es war mal wie immer die Benutzerrechte...
                https://github.com/aneisch/rtl_433_mqtt/issues/1#issuecomment-615933234
                Das hier hat mir geholfen dem ganzen Herr zu werden.
                Die rechte müssten eigentlich mit der Rule 666 sein. Bei mir wurde aber aus irgendeinem Grund nur 660 drauß und das hat iobroker nicht gereicht...
                Also manuell mit sudo chmod schnell angepasst.
                Mal schauen ob es den Neustart überlebt...
                • 9 9_Mad-Max_5
                  @9_mad-max_5
                  Meist sind es nur fehlende Gruppenzugehörigkeiten.
                  Hier vermutlich die Gruppe 'plugdev'
                  Bevor du da die Rechte mit chmod wasauchimmer versaubeutelst...
                    @9_mad-max_5
                    9 Offline
                    9 Offline
                    9_Mad-Max_5
                    Ja habe ich auch von gelesen war es in meinem Fall aber nicht
                    pi@iobroker:~ $ ls -la /dev/$(readlink /dev/rtl_sdr)
                    crw-rw---- 1 root plugdev 189, 3 Aug 10 17:05 /dev/bus/usb/001/004
                    pi@iobroker:~ $ sudo chmod 666 /dev/$(readlink /dev/rtl_sdr)
                    crw-rw-rw- 1 root plugdev 189, 3 Aug 10 17:05 /dev/bus/usb/001/004
                    und schon lief das ganze
                    • 9 9_Mad-Max_5
                      @9_mad-max_5
                      sudo -u iobroker groups
                        @9_mad-max_5
                        9 Offline
                        9 Offline
                        9_Mad-Max_5
                        pi@iobroker:~ $ sudo -u iobroker groups
                        iobroker tty dialout audio video bluetooth gpio i2c
                        Bin mir noch nicht ganz sicher was der output bedeutet..
                        • 9 9_Mad-Max_5
                          @9_mad-max_5
                          Der bedeutet exakt das was ich sagte:
                          Der User 'iobroker' ist nicht in der Gruppe 'plugdev' enthalten und darf deswegen nicht auf das Gerät zugreifen.
                          sudo usermod -aG plugdev iobroker
                          Und dann mach den Schwachsinn mit 666 rückgängig.
                          660 für die Gruppe 'plugdev' ist kein Fehler vom Paketbauer, der von dir korrigiert werden müsste, das hat schon seinen Grund warum das so voreingestellt wird.
                            @9_mad-max_5
                            9 Offline
                            9 Offline
                            9_Mad-Max_5
                            @thomas-braun said in Wie erteile ich USB-Zugriffsberechtigung?:
                            Ah sorry, das hatte ich nicht geschnallt.
                            Hatte nicht verstanden, dass es um den User geht, der nicht in der group ist, sondern das, das Gerät nicht plugdev zugeordnet ist.
                            Aber gut wieder etwas zugelernt ich nehme sonst immer die Brechstangenmethode und gehe auf 666 oder 777 😀
                            • 9 9_Mad-Max_5
                              @9_mad-max_5
                              Das war mir fast klar...
                              Ist nur in 99,9% der Fälle falsch. Gewöhn die den Murks ab. Und schau dir die Rechte in einem Linux-System an. Das braucht man immer wieder.
                              Denn
                              sieht man schon auf den ersten Blick in deinem Output, dass das Gerät der Gruppe 'plugdev' gehört. Und statt da rechtemäßig alles einzureißen sorgt man dafür, dass die entsprechenden User in der Gruppe sind.
                              Nebeneffekt: Das überlebt auch ein Update der udev-Rule.
                                @9_mad-max_5
                                Denn
                                9 Offline
                                9 Offline
                                9_Mad-Max_5
                                Naja helfen tut es immer die Rechte mit dem großen Hammer anzupassen ob richtig oder nicht mag eine andere frage sein.
                                Sei es drum merci für die Hilfe damit sollte nun ja alles passen.
                                • Thomas BraunT Online
                                  @9_mad-max_5
                                  Im Fall von udev-Regeln nutzt es dir gar nichts, die werden nämlich bei jeden Bootvorgang wieder gesetzt. Wenn du dort also nichts änderst ist es wieder root:plugdev 660
