  3. Einsteigerfragen
  4. Problem mit Adapter updates
    5.6k
22 Beiträge 7 Kommentatoren 2.9k Aufrufe 5 Beobachtet
    @marcus-hamburg sagte in Problem mit Adapter updates:
    Ich starte Java update
    was ist das?
    hier bleibt man dann stecken
    und wie sieht der Konsolen in und output wirklich aus?
    Was mache ich den falsch?
    Marcus HamburgM Offline
    Marcus Hamburg
    schrieb am zuletzt editiert von Marcus Hamburg
    @homoran nach den Start des Java updates passiert nichts mehr :-(
    Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l
    permitted by applicable law.
    Last login: Wed Aug 10 09:28:36 2022 from 192.168.178.5
    pi@raspberrypi:~ $ sudo reboot
    Connection to 192.168.178.21 closed by remote host.
    Connection to 192.168.178.21 closed.
    marcus@PC-Mac-Mini ~ % 20211019_Ruck Zuck Gas Neue Pr
    zsh: command not found: 20211019_Ruck
    marcus@PC-Mac-Mini ~ % ssh pi@192.168.178.21
    pi@192.168.178.21's password:
    Last login: Wed Aug 10 09:45:28 2022
    pi@raspberrypi:~ $ node -v
    v14.20.0
    pi@raspberrypi:~ $ iob stop
    pi@raspberrypi:~ $ iob fix
    library: loaded
    Library version=2022-06-15
        Welcome to the ioBroker installation fixer!
        Script version: 2022-06-03
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://deb.nodesource.com/node_14.x buster InRelease
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $ iob update
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.10   , installed 2.3.3  [Updatable]
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hmip"         : 1.18.0   , installed 1.15.4 [Updatable]
    Adapter    "hue"          : 3.7.0    , installed 3.6.5  [Updatable]
    Adapter    "ical"         : 1.13.1   , installed 1.11.4 [Updatable]
    Adapter    "info"         : 1.9.19   , installed 1.9.8  [Updatable]
    Adapter    "javascript"   : 5.7.0    , installed 5.2.13 [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "openweathermap": 0.2.5   , installed 0.2.5
    Adapter    "renault"      : 0.0.13   , installed 0.0.13
    Adapter    "ring"         : 3.0.4    , installed 3.0.4
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "trashschedule": 2.0.2    , installed 1.4.1  [Updatable]
    pi@raspberrypi:~ $ iob upgrade
    This upgrade of "javascript" will at least introduce the following changes:
    -> 5.7.0:
    Allow sending of messages to scripts also from adapters and CLI by sending "toScript" message (see [onMessage Documentation](https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onmessage))
    Lists returned by $-selector are now unified and do not contain double entries
    Fix subscribe multiple object ID lists in blockly
    -> 5.6.1:
    Allow to subscribe multiple object ID lists in blockly
    -> 5.6.0:
    Make state properties c(omment) and user available to scripts too
    make sure values of new or changed alias objects are initialized properly
    Enhance scheduler logic and astro events offered by wizard
    Respect expected value changes when determining if a value is changed
    Fix remembering intermediate state values when state values are subscribed
    fix setState logic when states are not subscribed
    -> 5.5.4:
    Tried to solve problem with the font
    -> 5.5.3:
    Fixed getObjectAsync function if object does not exist
    -> 5.5.2:
    Added new rules action block: sum two states (or minus)
    -> 5.5.1:
    Would you like to upgrade javascript from @5.2.13 to @5.7.0 now? [(y)es, (n)o]: y
    Update javascript from @5.2.13 to @5.7.0
    NPM version: 6.14.17
    Installing iobroker.javascript@5.7.0... (System call)
    GlasfaserG wendy2702W 2 Antworten Letzte Antwort
    • Marcus HamburgM Marcus Hamburg
      v14.20.0
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      -> 5.7.0:
      -> 5.6.1:
      -> 5.6.0:
      -> 5.5.4:
      -> 5.5.3:
      -> 5.5.2:
      -> 5.5.1:
      GlasfaserG Offline
      GlasfaserG Offline
      @marcus-hamburg
      Zeige mal die Ausgabe von :
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        v14.20.0
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        -> 5.7.0:
        -> 5.6.1:
        -> 5.6.0:
        -> 5.5.4:
        -> 5.5.3:
        -> 5.5.2:
        -> 5.5.1:
        wendy2702W Online
        wendy2702W Online
        @marcus-hamburg was für ein PI und wie lange gewartet?
        Marcus HamburgM 1 Antwort Letzte Antwort
        • wendy2702W wendy2702
          Marcus Hamburg
          Danke an alle. Ich hab nicht genug Geduld gehabt. Die Adapter sind am updaten. Danke
            Moin Moin,
            ich habe ein Problem mit den Updates meiner Adapter. Ich mache
            iob stop
            iob fix
            iob update
            iob upgrade
            .... hier bleibt man dann stecken. Ich starte Java update mit yes und dann hängt es sich auf. Wenn ich in der Adminmaske die Updates starten möchte geht es eigentlich bei keinen Adapter aufgrund der verschiedenen NodeJS Versionen.
            Ich hab Node 14.20 installiert (pi@raspberrypi:~ $ node -v
            v14.20.0)
            und die einzelnen Adapter verlangen:
            • Backup Node >=12
            • discovery Node >=14
            • hmip Node >=10
            • hue node >=10
            • java node >=10
            GlasfaserG Offline
            GlasfaserG Offline
            Deine Grundfrage war das ...
            Backup Node >=12
            discovery Node >=14
            hmip Node >=10
            hue node >=10
            java node >=10
            und jetzt :
            .... denn , das wäre dann was anderes !?
            Wie kommst du denn auf ... :
            hast du dazu Meldungen im Log gehabt oder ... !?
            • GlasfaserG Glasfaser
              Backup Node >=12
              discovery Node >=14
              hmip Node >=10
              hue node >=10
              java node >=10
              und jetzt :
              Marcus Hamburg
              @glasfaser Ja in der Admin Maske konnte ich die Aktualisierungen nicht starten, dort wurde die jeweils mit den verschiedenen Node Versionen so angezeigt. Ein update über das Terminal funktioniert jetzt, war nur nicht geduldig genug.
                @marcus-hamburg
                Gegencheck mit
                sagt?
                mickymM Marcus HamburgM 2 Antworten Letzte Antwort
                  @marcus-hamburg
                  Gegencheck mit
                  sagt?
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @thomas-braun vielleicht ohne nodejs.
                  • mickymM mickym
                    @mickym
                    Dann siehst du aber nicht die üblichen doppel- oder gar dreifach Installationen.
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @thomas-braun sagte in Problem mit Adapter updates:
                      @mickym
                      Bei mir kommt
                      nodejs
                      -bash: nodejs: Kommando nicht gefunden.
                      • mickymM mickym
                        @mickym
                        Bei mir kommt
                        nodejs
                        @mickym
                        Dann ist das nicht gelinkt:
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @thomas-braun ok - danke für Aufklärung :)
                            @marcus-hamburg
                            Gegencheck mit
                            sagt?
                            Marcus Hamburg
                            pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v14.20.0
                            v14.20.0
                            6.14.17
                            pi
                            /home/pi
                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            Aktualisierung für 110 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                            nodejs:
                              Installiert:           14.20.0-deb-1nodesource1
                              Installationskandidat: 14.20.0-deb-1nodesource1
                              Versionstabelle:
                             *** 14.20.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                                 10.24.0~dfsg-1~deb10u1 500
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v14.20.0
                              v14.20.0
                              6.14.17
                              pi
                              /home/pi
                              nodejs:
                                Versionstabelle:
                              Halt dein System aktuell! Bei 110 Paketen ist das ewig nicht mehr (bzw. noch nie) gemacht worden.
                              iobroker stop
                              sudo apt update
                              sudo apt full-upgrade
                              sudo reboot
                              Künftig regelmäßig machen!
                              Und ein Upgrade auf die empfohlene nodejs@16 würde ich auch anraten.
                                iobroker stop
                                sudo apt update
                                sudo reboot
                                Marcus Hamburg
                                @thomas-braun nodejs@16 installiert, Paket installiert, nur die Adapter lassen sich nicht updaten. Ich verzweifle schon wieder an mir.
                                Last login: Wed Aug 10 20:08:59 2022
                                library: loaded
                                OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                                Installed gcc-c++
                                Autostart enabled!
                                -> 5.7.0:
                                -> 5.6.1:
                                -> 5.6.0:
                                -> 5.5.4:
                                -> 5.5.3:
                                -> 5.5.2:
                                -> 5.5.1:
                                Would you like to upgrade javascript from @5.2.13 to @5.7.0 now? [(y)es, (n)o]: n
                                No upgrade of "javascript" desired.
                                This upgrade of "info" will at least introduce the following changes:
                                -> 1.9.19:
                                Fix audio, USB, bluetooth and printer view
                                -> 1.9.18:
                                Fix invalid object definition to prevent errors in js-controller 4
                                -> 1.9.17:
                                Design fix
                                Update dependencies
                                -> 1.9.16:
                                Update dependencies
                                Fix translations
                                -> 1.9.15:
                                Design fix for react-dark theme
                                -> 1.9.10:
                                Adjust some actions to prevent js-controller 3.3 warnings
                                -> 1.9.9:
                                update library to prevent some errors
                                Would you like to upgrade info from @1.9.8 to @1.9.19 now? [(y)es, (n)o]: y
                                Update info from @1.9.8 to @1.9.19
                                NPM version: 8.11.0
                                Installing iobroker.info@1.9.19... (System call)
                                host.raspberrypi Cannot install iobroker.info@1.9.19: 217
                                pi@raspberrypi:~ $
                                  library: loaded
                                  Installed gcc-c++
                                  Autostart enabled!
                                  -> 5.7.0:
                                  -> 5.6.1:
                                  -> 5.6.0:
                                  -> 5.5.4:
                                  -> 5.5.3:
                                  -> 5.5.2:
                                  -> 5.5.1:
                                  -> 1.9.19:
                                  -> 1.9.18:
                                  -> 1.9.17:
                                  Design fix
                                  Update dependencies
                                  -> 1.9.16:
                                  Update dependencies
                                  Fix translations
                                  -> 1.9.15:
                                  -> 1.9.10:
                                  -> 1.9.9:
                                  NPM version: 8.11.0
                                  pi@raspberrypi:~ $
                                  @marcus-hamburg mach mal ein einzelupgrade nit debug
                                  iobroker upgrade javascript --debug
                                  und wieder alles posten
                                    Marcus Hamburg
                                    pi@raspberrypi:~ $ iobroker upgrade javascript --debug
                                    -> 5.7.0:
                                    -> 5.6.1:
                                    -> 5.6.0:
                                    -> 5.5.4:
                                    -> 5.5.3:
                                    -> 5.5.2:
                                    -> 5.5.1:
                                    NPM version: 8.11.0
                                    npm ERR! code ENOTEMPTY
                                    npm ERR! syscall rename
                                    npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                                    npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-10T18_29_21_627Z-debug-0.log
                                    host.raspberrypi Cannot install iobroker.javascript@5.7.0: 217
                                    pi@raspberrypi:~ $
                                    GlasfaserG HomoranH 2 Antworten Letzte Antwort
                                      -> 5.7.0:
                                      -> 5.6.1:
                                      -> 5.6.0:
                                      -> 5.5.4:
                                      -> 5.5.3:
                                      -> 5.5.2:
                                      -> 5.5.1:
                                      NPM version: 8.11.0
                                      npm ERR! errno -39
                                      pi@raspberrypi:~ $
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      Du kannst das hier nutzen
                                      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                                      cd /opt/iobroker/node_modules
                                      for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                                      Zitat aus dem Thread :
                                      WICHTIG .
                                      (Bitte Befehl KOPIEREN, nicht eintippen, ein Vertipper kann und wird da 'tödlich' sein).
                                        -> 5.7.0:
                                        -> 5.6.1:
                                        -> 5.6.0:
                                        -> 5.5.4:
                                        -> 5.5.3:
                                        -> 5.5.2:
                                        -> 5.5.1:
                                        NPM version: 8.11.0
                                        npm ERR! errno -39
                                        pi@raspberrypi:~ $
                                        oha, dazu gibt es einige Threads
                                        lösung hier suchen
                                        https://forum.iobroker.net/post/460759
