  4. [Anleitung] WireGuard mit WireGuard-UI auf Proxmox
    5.9k
portforwardingportfreigabeportfreischaltungproxmoxvpnwireguardwireguard ios app
603 Beiträge 64 Kommentatoren 230.5k Aufrufe 47 Beobachtet
    @einstein2002 sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
    Hab ein komplett neues iob aufgesetzt
    Was aufgesetzt?
    Halte dich doch an die Anleitung der Reihe nach, da wo Unklarheiten sind, nachfragen
    Vieles kann man allerdings auch aus dem Thread herauslesen
    Einstein2002
    #395
    @crunchip könnte darin mein Fehler liegen?
    Das ist aus der Anleitung.
    I highly recommend the use of sudoers under Linux!
    These security hints rely mainly on linux since it's security system is more complex than the windows one. On a Windows server you'll simply need to use an administrative user. Since the wg command (which is executed to grab the state of WireGuard) requires administrative permissions, think well of what you are doing here and how you configure the user you place in config. To protect these credentials as well as possible both - username and password - are encrypted.
    Basically there are three ways to execute the command:
    use an administrative user (root or similar). This will work but expose your entire server in case the credentials get lost/stolen.
    use of SetUID-Bit: By setting this bit (as far as I understood) each and every user is allowed to execute the flagged file with administrative privileges without needing any password. This includes hackers. So setting this bit on the wg command exposes the entire wg-command with all it's power. If you like to do so execute chmod u+s /usr/bin/wg as an administrator.
    use of sudoers: From my perspective, the most secure way is to set up a new simple user with basic privileges and add a simple line to the sudoers file which allows this user to execute the needed command without entering a password - and ONLY THIS command. Please refer to the documentation of your distribution for proper information on editing the sudoers file and using visudo. The screenshot below shows what needs to be added to the file. wireguard-monitoring-user is the user of your choice. The rest needs to be exactly like you see.
    #iobroker.wireguard adapter
    wireguard-monitoring-user ALL=NOPASSWD:/usr/bin/wg show all dump
    This setting allows the <wireguard-monitoring-user> on ALL hosts to execute the wg show all dump command from the directory /usr/bin/ (may need to be changed on your distribution) without needing a password
    Muss da noch etwas umgestellt werden??
    Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
    Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
    • E Einstein2002
      @crunchip ich habe mir zum Test eben gerade ein neuen LXC mit DEBIAN 11 erstellt. Updates gemacht einen neuen User michael mit sudo rechten eingerichtet, die Zeitzone umgestellt.
      Dann iobroker neu installiert
      Und dann wireguard adapter installiert.
      Gleicher Fehler.
      crunchipC Offline
      crunchipC Offline
      #396
      @einstein2002 warum iobroker neu, du musst doch wireguard auf nem lxc installieren und dieser muss funktionieren.
      In iobroker selbst, stellst du die Verbindung mittels dem Adapter her um die Daten auszulesen. Dies tut aber nichts zur Sache zwecks Funktion von wireguard selbst.
      E 1 Antwort Letzte Antwort
        Einstein2002
        #397
        @crunchip ja, das habe ich auch schon mehrfach gemacht, wollte mir mein Aktives System aber nicht weiter verdrehen.
        Somit habe ich es gestoppt und teste jetzt auf einem system welches ich wieder einfach löschen kann.
        Und jetzt versuche ich gerade diese sudoers datei zu bearbeiten. Da ist noch was mit den rechten? Ich weis es nicht aber ich versuche es halt nach dieser Anleitung.
        https://github.com/Grizzelbee/ioBroker.wireguard#security-hints
        • E Einstein2002
          #398
          Da muss dem user noch über visudo das Recht erteilt werden mit der Schnittstelle wg0 zu agieren.
          E 2 Antworten Letzte Antwort
            Einstein2002
            #399
            @thomas-braun ja soweit habe ich es mir auch zusammengereimt.
            Aber ich brauche halt einfach etwas länger.
            • E Einstein2002
              crunchipC Offline
              crunchipC Offline
              #400
              @einstein2002 gibt auch ein "fertiges Paket"
              https://tteck.github.io/Proxmox/
                Einstein2002
                #401
                @thomas-braun Das war der Fehler
                mit
                visudo
                diese zwei zeilen hinzugefügt
                gespeichert und es läuft.
                Den Haken sudo habe ich nicht gesetzt.
                Und damit bekomme ich die Daten wie gewünscht.
                Auch auf meinem Aktiv System.
                Für den Fall es interessiert noch jemand.
                Grüße und schönes Wochenende
                  Einstein2002
                  #402
                  @crunchip Das schau ich mir später an, sieht sehr vielversprechend aus. Danke für den link
                  Stephan SchleichS 1 Antwort Letzte Antwort
                  • E Einstein2002
                    Stephan SchleichS Offline
                    Stephan Schleich
                    #403
                    Also bei mir dauert es bis zu 5 Sekunden bis ein Handshake ausgehandelt ist, weiß jemand woran das liegen kann? Dies verursacht bei mir auch diese Timeouts
                    • NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #404
                      Hallo
                      Ich versuchs mal hier, mit der Hoffnung auf Hilfe! :)
                      Frage an die Netzwerkfreaks 😉
                      Wireguard läuft.
                      Ich kann auch auf alles im Netzwerk zugreifen.
                      Nur auf die Netzwerkfreigaben komm ich nicht.
                      Warum funktioniert das nicht?
                      Gibt es noch Einstellungen dafür?
                      Host: Windows 10 pro
                      Freigabe: Synology NAS
                      ° Fixer ---> iob fix
                      • NegaleinN Negalein
                        Hallo
                        Wireguard läuft.
                        Einstein67
                        schrieb am zuletzt editiert von Einstein67
                        #405
                        @negalein said in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                        Hast du im WG-Clienten diese Checkbox deaktiviert?
                        So geht bei mir auch der Zugriff auf alle LAN-Freigaben/Geräte.
                        NegaleinN 2 Antworten Letzte Antwort
                        • E Einstein67
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #406
                          @einstein67 sagte in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                          Danke, das wars! :)
                          • CrunkFXC CrunkFX
                            Hallöchen,
                            nachdem hier immer wieder Fragen bezüglich VPN etc. kommen, habe ich mich entschlossen eine kleine Anleitung zum Thema WireGuard zu erstellen. Ich habe versucht die Anleitung so einfach und kurz wie möglich zu halten.
                            Installationszeit ca. 15 Minuten je nach Internetverbindung
                            Stand V1.2.2 18.01.2022
                            Github Link https://github.com/KleSecGmbH/ioBroker/tree/main/wireguard
                            Voraussetzungen:
                            • Proxmox als Grundgerüst mit Kernel Version min.: 5.11 Ältere Version?
                            • Einen Dual-Stack Internetanschluss (also kein DS-Lite, hierzu kommt bei Bedarf eine gesonderte Anleitung)
                            • Portfreigabe im Router (Protokoll: UDP, Port: 51820 , auf die IP Adresse des neuen Linux Containers)
                              !!! Keine Portfreigabe auf den im späteren Verlauf erstellten Port 5000 setzen !!!
                            • Falls keine feste IP vorhanden ist benötigt ihr einen Hostnamen. Das kann z.b. MyFritz sein oder DynDns, Hauptsache ein Dienst mit dem ihr auf eure aktuelle IP verweisen könnt.
                            Anleitung:
                            Zunächst müssen wir das LXC Template für Ubuntu 21.04 oder 21.10 installieren.
                            Anschließend basierend auf diesem Image einen neuen Container anlegen
                            einen Hostnamen vergeben sowie ein Passwort
                            Danach das Image auswählen
                            Und mit den Standardwerten bis zur Netzwerkkonfiguration weitermachen.
                            Nun noch eine IP vergeben und der erste Teil wäre geschafft.
                            Ab hier wird auf dem Proxmox Host gearbeitet!
                            Zunächst passen wir die Konfiguration des neu erstellten Containers an.
                            Dazu mit dem Befehl
                            nano /etc/pve/lxc/100.conf
                            (!! 100 durch die Nummer bei eurem Container ersetzen !!)
                            die Konfigurationsdatei anpassen.
                            Und diese beiden Zeilen am Ende der Datei anhängen:
                            Proxmox Version 7.xx :
                            lxc.cgroup2.devices.allow: c 10:200 rwm
                            lxc.mount.entry: /dev/net dev/net none bind,create=dir
                            Proxmox Version 5.xx/6.xx:
                            lxc.cgroup.devices.allow: c 10:200 rwm
                            Nach dem Einfügen das Fenster mit STRG + X --> Enter speichern und verlassen.
                            Danach auf dem Proxmox Host die Zugriffsrechte für den Tunneladapter freigeben mit dem Befehl:
                            chown 100000:100000 /dev/net/tun
                            Ab hier wird auf dem neuen Container gearbeitet!
                            Danach können wir unseren LXC/CT starten und uns anmelden.
                            Ich habe alle zur Installation notwendigen Befehle und Konfigurationsdateien in einem kleinen Shell-Skript zusammengefügt.
                            Dazu also folgendes ausführen:
                            wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/installer-pve.sh -O installer-pve.sh && bash installer-pve.sh
                            Der Installer läuft bis zu diesem Punkt automatisch durch. Die abgefragten Punkte ALLE mit Enter bestätigen, da später in der Grafischen Oberfläche Konfiguriert wird.
                            Nachdem wir erfolgreich WireGuard und WireGuard-UI Installiert haben, können wir WireGuard-UI Konfigurieren.
                            Dazu rufen wir http://IP-AdresseVomLinuxContainer:5000 auf und melden uns mit Benutzer und Passwort admin an.
                            Die Anmeldedaten können mit dem Installer und dem Punkt Anmeldedaten ändern geändert werden.
                            Zunächst müssen wir den WireGuard Server Konfigurieren. Dazu muss in den Global Settings unter dem Punkt Endpoint-Address euer Hostname(MyFritz, DynDns) oder eine feste IP (falls vorhanden) Bei Fragen hierzu siehe oben!
                            Nachdem wir Hostname/IP eingegeben haben und auf Apply Config geklickt haben, müssen wir noch einen kleinen Punkt durchführen um Clients anlegen zu können.
                            Dazu im Fenster WireGuard Server unter dem Punkt Post Up Script folgendes eintragen:
                            iptables -A FORWARD -i %i -j ACCEPT; iptables -A FORWARD -o %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
                            und um Feld Post Down Script folgendes eintragen:
                            iptables -D FORWARD -i %i -j ACCEPT; iptables -D FORWARD -o %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
                            Danach speichern und Apply Config drücken.
                            Clients anlegen:
                            Ab hier dürfte alles recht selbsterklärend sein.
                            Im Menü WireGuard Clients auf New Client drücken
                            Name und Email Konfigurieren
                            und Bestätigen.
                            Nun bekommt ihr einen Client mit einem QR Code den ihr mit der WireGuard App scannen könnt oder alternativ als Datei zum Download für Desktoprechner.
                            Sollten sich doch Fehler eingeschlichen haben, bitte melden. Getestet wurde auf Proxmox V7.0-11.
                            Bei Bedarf kann ich diese Anleitung gerne für RasPi und Konsorten ebenfalls erstellen.
                            LG
                            CrunkFX
                            Johnny EnglischJ Offline
                            Johnny Englisch
                            #407
                            @crunkfx
                            ich habe es schon 1.000 mal nach dieser und anderer Anleitungen versucht.
                            Es steht immer da das es sucessfully installed wurde ist jedoch nie über die 192.168.178.150:5000 (in meinem Falle) erreichbar.
                            • CrunkFXC CrunkFX
                              @newbroker Kannst du den Installer nochmal ausführen und auf aktualisieren klicken.
                              Falls das nichts bringt, mach bitte folgendes:
                              nano /opt/wireguard-ui/db/server/global_settings.json
                              In die neue Datei :
                                      "endpoint_address": "1.1.1.1",
                                      "dns_servers": [
                                              "1.1.1.1"
                                      "mtu": "1450",
                                      "persistent_keepalive": "15",
                                      "config_file_path": "/etc/wireguard/wg0.conf",
                                      "updated_at": "2022-01-26T10:15:06.517454916Z"
                              einfügen und danach
                              cd /opt/wireguard-ui
                              ./wireguard-ui
                              Johnny Englisch
                              #408
                              @crunkfx said in [Anleitung] WireGuard mit WireGuard-UI auf Proxmox:
                              In die neue Datei :
                                      "dns_servers": [
                                              "1.1.1.1"
                                      "mtu": "1450",
                              einfügen und danach
                              ./wireguard-ui
                              Okay... schien bei mir auch daran zu liegen
                              Johnny EnglischJ 1 Antwort Letzte Antwort
                              • Johnny EnglischJ Johnny Englisch
                                In die neue Datei :
                                        "dns_servers": [
                                                "1.1.1.1"
                                        "mtu": "1450",
                                einfügen und danach
                                ./wireguard-ui
                                Johnny Englisch
                                #409
                                Nachdem ich diese Datei also per Hand beschrieben habe und den Container neu gestartet habe lief/ leuft es auch... die UI ist auch erreichbar und steuerbar.
                                Nur habe ich keinen Traffic durch die VPN. Heißt ich kann mein Home Netz nichts erreichen und auch google (zum Beispiel) nicht.
                                CrunkFXC Johnny EnglischJ 2 Antworten Letzte Antwort
                                  CrunkFXC Offline
                                  CrunkFXC Offline
                                  CrunkFX
                                  Forum Testing
                                  #410
                                  @johnny-englisch Moin,
                                  kannst du mir bitte die Ausgabe von dem Befehl
                                  wg
                                  mitteilen?
                                  • CrunkFXC CrunkFX
                                    wg
                                    mitteilen?
                                    Johnny Englisch
                                    schrieb am zuletzt editiert von Johnny Englisch
                                    #411
                                    wg
                                    mitteilen?
                                    Gerne doch...
                                    Wie gesagt verbinden geht anscheinend... wird aber nicht in der GUI angezeigt.
                                    Habe halt nur kein Internet auf "der anderen Seite"
                                      wg
                                      mitteilen?
                                      Gerne doch...
                                      Johnny Englisch
                                      #412
                                      @johnny-englisch
                                      Hie auch noch von der GUI
                                        Johnny Englisch
                                        #413
                                        Nevermind.. ich habe eine Fehlerhafte Portfreigabe gehabt
                                        Jetzt gehts
                                        • CrunkFXC CrunkFX
                                          Hallöchen,
                                          Voraussetzungen:
                                          Anleitung:
                                          Dazu mit dem Befehl
                                          Clients anlegen:
                                          und Bestätigen.
                                          LG
                                          CrunkFX
                                          #414
                                          @crunkfx Hi, ich nutze Ubuntu LTS 22.04.1
                                          Dein Skript funktioniert hier leider nicht richtig. wg0.config wird nicht angelegt. Muss man per Hand anlegen.
                                          Die GUI wird nicht korrekt installiert. wgui muss man ebenfalls nachinstallieren.
                                          VPN Verbindung klappt, nur kein Zugriff ins Netz.
                                          Da sind etliche Macken, am Besten einfach mal ausprobieren.
