    6.6k
7.6k Beiträge 296 Kommentatoren 7.8m Aufrufe 201 Beobachtet
  • M mane444
    @s-bormann
    unter ui-block-b steht bei ::after
    ui-navbar ul:after {
        clear: both;
    .ui-navbar ul:before, .ui-navbar ul:after {
        content: "";
        display: table;
    unter ui-block-a steht bei ::after
    iQontrolToolbarLink.ui-btn-active:after {
        background-color: #dd29d0 !important;
    <style>
    .iQontrolToolbarLink.ui-btn:after {
        background-color: #cd24c1 !important;
    <style>
    .iQontrolToolbarLink.ui-btn-active:after {
    <style>
    <style>
        background-color: #2935dd !important;
        background-color: transparent !important;
    .ui-nodisc-icon.ui-btn:after, .ui-nodisc-icon .ui-btn:after {
        background-color: transparent;
    .ui-btn-icon-top:after {
        top: 0.5625em;
    .ui-btn-icon-notext:after, .ui-btn-icon-top:after, .ui-btn-icon-bottom:after {
        left: 50%;
        margin-left: -11px;
    .ui-btn-icon-left:after, .ui-btn-icon-right:after, .ui-btn-icon-top:after, .ui-btn-icon-bottom:after, .ui-btn-icon-notext:after {
        content: "";
        position: absolute;
        display: block;
        width: 22px;
        height: 22px;
        background-color: #666;
        background-color: rgba(0,0,0,.3);
        background-position: center center;
        background-repeat: no-repeat;
        -webkit-border-radius: 1em;
        border-radius: 1em;
    .ui-icon-arrow-d-l:after {
        background-image: url(data:image/svg+xml;charset=US-ASCII,%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22iso-8859-1%22%3F%3E%3C!DOCTYPE%20svg%20PUBLIC%20%22-%2F%2FW3C%2F%2FDTD%20SVG%201.1%2F%2FEN%22%20%22http%3A%2F%2Fwww.w3.org%2FGraphics%2FSVG%2F1.1%2FDTD%2Fsvg11.dtd%22%3E%3Csvg%20version%3D%221.1%22%20id%3D%22Layer_1%22%20xmlns%3D%22http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg%22%20xmlns%3Axlink%3D%22http%3A%2F%2Fwww.w3.org%2F1999%2Fxlink%22%20x%3D%220px%22%20y%3D%220px%22%20%20width%3D%2214px%22%20height%3D%2214px%22%20viewBox%3D%220%200%2014%2014%22%20style%3D%22enable-background%3Anew%200%200%2014%2014%3B%22%20xml%3Aspace%3D%22preserve%22%3E%3Cpolygon%20fill%3D%22%23FFF%22%20points%3D%2214%2C3%2011%2C0%203.5%2C7.5%200%2C4%200%2C14%2010%2C14%206.5%2C10.5%20%22%2F%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3C%2Fsvg%3E);
    Die Farben hab ich geändert:
    Einstellung Toolbar:
    Anzeige:
    da_WoodyD Offline
    da_WoodyD Offline
    #7191
    @mane444 also doch, wie vermutet, ein farbproblem. nach ein bißchen hirnstöbern, glaub ich, ich hatte am anfang auch das problem. darum hab ich meine selbstgeschnitzten alle auf weiß invertiert, ohne hintergrund.
    dein Wohnz.png dürfte zu groß sein. darum wird da nur der kleine bogen angezeigt von der lehne.
    meine einstellungen für die symbolleisten pics:
    66787f96-cc45-4ad9-a3b2-3083049207f9-grafik.png d01fd109-5730-4494-8881-f8e4bf170d2d-grafik.png
    • da_WoodyD da_Woody
      mane444
      #7192
      @da_woody das scheint wirklich das Problem zu sein.
      Ich hab mal das Symbol Camera aus dem Adapter herauskopiert und in usersymbols hochgeladen. Es wird nun angezeigt, aber nicht wie das Original.
      7a86763b-40ff-4d92-a430-c215bcfa6f41-image.png 36711687-5fed-4c6d-b2fc-202281b7c7c5-image.png
      Ist schon etwas seltsam.
      • M mane444
        da_WoodyD Offline
        da_WoodyD Offline
        #7193
        @mane444 da hat sich anscheinend beim invertieren geändert. die originalen vom adapter funktionieren ja. wozu das also invertieren? ich mach das nur bei den eigenen.
        hab grad kurz reingelinst. das original ist ein anderes dateiformat! camera-black.svg wenn du das invertierst und in .png wandeslt, dann passiert sowas schon mal. noch dazu ist ein .svg skalierbar (original 14x14px). die kleinen tücken mit GFX. ;)
        musste am anfang auch probieren, aber so rund 100x100px haben sich als passende größe ergeben.
        meine komplette leiste
        1, 8-10 sind adapter eigene, die anderen Räume - 3D-Drucker selbst gebastelt.
        M 2 Antworten Letzte Antwort
          mane444
          #7194
          @da_woody ich glaub ich hab's gefunden. Es liegt scheinbar an der Einstellung der Icon Größe.
          Bei der Voreinstellung 14px werden die Symbole nicht richtig angezeig.
          Bei der Einstellung 15px werden alle Symbole angezeigt
            mane444
            #7195
            @da_woody Jetzt bin ich Happy.
            Hier das Livesystem:
            Danke für die Anregungen, ich werde trotzdem mal die Größe meiner Symbole checken.
            • da_WoodyD Offline
              da_WoodyD Offline
              #7196
              @mane444 na super! 👍 ist manchmal halt schwierig, mein iQ läuft schon von anfang an. da hat man dann nicht mehr alles im kopf. viel ändert sich bei mir nicht mehr. bis auf den neuen device-watcher hab ich schon lange nichts mehr geändert.
              da musste ich auch ne zeit rumspielen mit den automatisch erstellten widgets. :)
              • M mane444
                s.bormannS Offline
                s.bormannS Offline
                s.bormann
                #7197
                @mane444 sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
                klasse, dass es jetzt geht!
                Kannst Du mal eines der Icons hier hochladen, dann kann ich mal schauen, ob ich den Fehler finde. Welchen Browser nutzt Du?
                VG!
                M da_WoodyD 3 Antworten Letzte Antwort
                • s.bormannS s.bormann
                  VG!
                  mane444
                  schrieb am zuletzt editiert von mane444
                  #7198
                  @s-bormann
                  Hallo, ich hab hier mal die Icons zum Testen. Als Browser am PC habe ich Chrome und Edge getestet. Am Tablett und Handy Chrome.
                  Die Icons sind leider nicht sichtbar, da diese weis sind.
                  da_WoodyD s.bormannS 2 Antworten Letzte Antwort
                  • M mane444
                    @s-bormann
                    da_WoodyD Offline
                    da_WoodyD Offline
                    #7199
                    @mane444 da sind keine icons, nichtmal mit markieren. selbst wenn sie weis wären, müsste man was sehn.
                    L 1 Antwort Letzte Antwort
                      VG!
                      da_WoodyD Offline
                      da_WoodyD Offline
                      #7200
                      @s-bormann soweit ich das mitbekommen habe, nutzt du da .svg mit 14px.
                      siehe meinen beitrag weiter oben, 193
                        Labersack
                        schrieb am zuletzt editiert von Labersack
                        #7201
                        @da_woody
                        Stell mal auf dunkle Darstelllung der Seite, dann:
                        Kannst sie auch einfach speichern, indem du auf die (unsichtbaren) Icons gehst und über rechte Maustaste die Bilder speicherst.
                          VG!
                          da_WoodyD Offline
                          da_WoodyD Offline
                          #7202
                          @s-bormann ich glaub, ich hab ein kleines problem gefunden. hab ein paar online status nachgetragen.
                          bei den standarticons mein grün eingefärbtes eingetragen. das wird auch brav im editor angezeigt.
                          in der view wird aber das original orangenes angezeigt.
                          siehe rechts. wenn ich den pfad dazu eintrage, wird mein grünes verwendet. siehe links.
                          ist auch reproduzierbar. pfad löschen, wieder orange.
                          S s.bormannS 2 Antworten Letzte Antwort
                            schweiger2
                            schrieb am zuletzt editiert von schweiger2
                            #7203
                            ich habe ein neues Icon in Größe 96x96 Pixel in das Icon-Verzeichnis /opt/iobroker/iobroker-data/files/iqontrol/images/icons eingestellt und auch die Attribute an die vorhandenen angepasst. Allerdings wird mir das Icon nicht zur Auswahl im Menü angeboten.
                            Was ist mein Fehler ? Was muss ich noch beachten ?
                            Vielen Dank für eure Hilfe.
                            [Sorry, habe versehentlich über "antworten" gearbeitet]
                            • da_WoodyD Offline
                              da_WoodyD Offline
                              #7204
                              @schweiger2 kein problem. du darfst die icons nicht so übertragen. wie in vis mit dem dateimanager, musst du das in iQonrtol über
                              machen.
                                machen.
                                schweiger2
                                #7205
                                @da_woody
                                Vielen Dank, so hat es natürlich auf Anhieb funktioniert. 👍
                                • S schweiger2
                                  @da_woody
                                  da_WoodyD Offline
                                  da_WoodyD Offline
                                  #7206
                                  @schweiger2 fein, daß es geholfen hat! :)
                                    meerkat
                                    #7207
                                    @s-bormann Guten Morgen.
                                    Bei den Gerätetypen gibt es ja den Typ Info-Text. Dort kann man als Größe Volle Breite, kurz einstellen. Ist es möglich diese Einstellung für Größe auch in den anderen Gerätetypen zur Verfügung zu stellen?
                                    Es gibt das ein oder andere, was ich auf dem Tablet gerne über die ganze Breite anzeigen lassen möchte, aber nicht gleich die gesamte Höhe nutzen möchte.
                                    Gruß und sonnigen Sonntag
                                      s.bormannS Offline
                                      s.bormannS Offline
                                      s.bormann
                                      #7208
                                      @da_woody sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
                                      Stimmt, Fehler gefunden, wird in der nächsten Version gefixed. Danke!
                                      • M mane444
                                        @s-bormann
                                        s.bormannS Offline
                                        s.bormannS Offline
                                        s.bormann
                                        #7209
                                        @s-bormann
                                        Hab den Fehler gefunden, ein Semikolon im CSS-Code hat gefehlt. Wird in der nächsten Version gefixed.
                                        • s.bormannS Offline
                                          s.bormannS Offline
                                          s.bormann
                                          #7210
                                          Die beiden Fixes sind jetzt auf Github online. Hoffe es geht, hatte leider nur ein kurzes Zeitfenster zum Testen heute, bin jetzt leider auch erst mal wieder anderweitig eingebunden. LG!!
                                          M da_WoodyD 2 Antworten Letzte Antwort
