    6.8k
5.8k Beiträge 156 Kommentatoren 4.7m Aufrufe 137 Beobachtet
  • R Rushmed
    @sborg Hallo, habe über den Updater auf die 17 geupdated und bekomme bei Statusabfrage folgende Ausgabe.
    pi@Smartazamba:~/Wetterstation $ systemctl status wetterstation
    ● wetterstation.service - Service für ioBroker Wetterstation
         Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; vendor preset: enabled)
         Active: active (running) since Fri 2022-08-05 18:33:56 CEST; 6s ago
       Main PID: 2232017 (wetterstation.s)
          Tasks: 3 (limit: 8985)
            CPU: 6.073s
         CGroup: /system.slice/wetterstation.service
                 ├─2232017 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                 └─2234321 /bin/bash /home/pi/Wetterstation/wetterstation.sh
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234299]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234304]: (standard_in) 1: syntax error
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234305]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234306]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234311]: (standard_in) 1: syntax error
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234312]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234313]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234320]: (standard_in) 1: syntax error
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234321]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234322]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
    Aug 05 18:34:02 Smartazamba wetterstation.sh[2234327]: (standard_in) 1: syntax error
    Was hab ich falsch gemacht?
    Was hat diese Angabe beim Ausführen des Updaters zu bedeuten:
     Patche wetterstation.conf auf V2.17.0 ...
    ./ws_updater.sh: line 405: [: ==: unary operator expected
     Fertig...
    Habs jetzt mehrmals versucht. Mit Updater und ohne. Der Fehler mit den fehlenden Kommandos bleibt und Daten kommen nicht an.
    Beim Debug siehts ähnlich aus:
         Active: active (running) since Fri 2022-08-05 19:48:53 CEST; 10s ago
       Main PID: 527835 (wetterstation.s)
          Tasks: 1 (limit: 8985)
            CPU: 10.750s
                 ├─527835 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                 └─532315 date +%H
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532295]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532296]: /home/pi/Wetterstation/wetterstation.sh: line 326: debuging: command not found
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532301]: (standard_in) 1: syntax error
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532302]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532303]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532304]: /home/pi/Wetterstation/wetterstation.sh: line 326: debuging: command not found
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532310]: (standard_in) 1: syntax error
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532312]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532313]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532314]: /home/pi/Wetterstation/wetterstation.sh: line 326: debuging: command not found
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532319]: (standard_in) 1: syntax error
    Aug 05 19:49:03 Smartazamba wetterstation.sh[532320]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
    SBorgS Offline
    SBorgS Offline
    SBorg
    schrieb am zuletzt editiert von SBorg
    #4040
    @rushmed sagte in [Linux Shell-Skript] WLAN-Wetterstation:
    Hast du versucht eine Beta-Version mittels des Updaters upzugraden? Das funktioniert nicht, hier muss man per Hand die Dateien kopieren.
    So wie es aussieht fehlt oder ist deine *.sub beschädigt. Ich würde trotzdem mal beide neu installieren. Im Installationsverzeichnis (vorher den Service stoppen):
    wget -O wetterstation.sh https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/wetterstation.sh
    wget -O wetterstation.sub https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/wetterstation.sub
    LG SBorg ( SBorg auf GitHub)
    R 1 Antwort Letzte Antwort
    • SBorgS SBorg
      Rushmed
      #4041
      @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      wget -O wetterstation.sub https://github.com/SBorg2014/WLAN-Wetterstation/blob/master/wetterstation.sub
      Jetzt siehts noch schlimmer aus:
           Active: failed (Result: exit-code) since Fri 2022-08-05 20:17:03 CEST; 1s ago
          Process: 977580 ExecStart=/home/pi/Wetterstation/wetterstation.sh (code=exited, status=203/EXEC)
         Main PID: 977580 (code=exited, status=203/EXEC)
              CPU: 4ms
      Aug 05 20:17:03 Smartazamba systemd[1]: Started Service für ioBroker Wetterstation.
      Aug 05 20:17:03 Smartazamba systemd[977580]: wetterstation.service: Failed to execute /home/pi/Wetterstation/wetterstat>
      Aug 05 20:17:03 Smartazamba systemd[977580]: wetterstation.service: Failed at step EXEC spawning /home/pi/Wetterstation>
      Aug 05 20:17:03 Smartazamba systemd[1]: wetterstation.service: Main process exited, code=exited, status=203/EXEC
      Aug 05 20:17:03 Smartazamba systemd[1]: wetterstation.service: Failed with result 'exit-code'.
      Ich habe nicht versucht eine Beta mit dem Updater up zu daten.
      • R Rushmed
                CPU: 4ms
        SBorgS Offline
        SBorgS Offline
        SBorg
        #4042
        @rushmed Sieht jetzt verdächtig nach fehlenden Rechten aus.
        Was sagt denn ein ls -al wetterstattion*
        bzgl. Beta: dann weiß ich nicht was schief gelaufen ist. Pauschal scheint es zu funktionieren.
        • SBorgS SBorg
          Rushmed
          schrieb am zuletzt editiert von Rushmed
          #4043
          @sborg Hab nochmal alles gelöscht und mit dem Updater neu installiert.
               Active: active (running) since Fri 2022-08-05 20:24:00 CEST; 1s ago
             Main PID: 978048 (wetterstation.s)
                Tasks: 2 (limit: 8985)
                  CPU: 1.724s
                       ├─978048 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                       ├─978719 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                       └─978720 [bc]
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978699]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: comm>
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978704]: (standard_in) 1: syntax error
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978705]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: >
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978706]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: comm>
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978711]: (standard_in) 1: syntax error
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978712]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: >
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978713]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: comm>
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978720]: (standard_in) 1: syntax error
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978721]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: >
          Aug 05 20:24:02 Smartazamba wetterstation.sh[978722]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: comm>
          pi@Smartazamba:~/Wetterstation $ ls -al wetterstattion*
          ls: cannot access 'wetterstattion*': No such file or directory
          pi@Smartazamba:~/Wetterstation $ sudo ls -al wetterstation*
          -rw-r--r-- 1 pi pi  7561 Aug  5 20:05 wetterstation.conf
          -rw-r--r-- 1 pi pi 21596 Jul 21 08:53 wetterstation.js
          -rwxr-xr-x 1 pi pi 19368 Aug  5 15:39 wetterstation.sh
          -rw-r--r-- 1 pi pi 77119 Aug  5 14:20 wetterstation.sub
          Wenn ich Opensensemap in der Conf deaktiviere taucht zumindest diese fehlende Kommando bei der Satusabfrage nicht mehr auf.
          • R Rushmed
                    CPU: 1.724s
                         └─978720 [bc]
            SBorgS Offline
            SBorgS Offline
            SBorg
            #4044
            @rushmed Blöde Tippfehler... ;)
            Die Fehlermeldungen besagen, dass er die opensensensmap und get_data - Befehle nicht kennt. Die lädt er aus der sub nach, was fehlschlägt (wofür es keinen offensichtlichen Grund gibt).
            Hmm, das (meist) Allheilmittel: reboot?
            BoronsbruderB 1 Antwort Letzte Antwort
            • SBorgS SBorg
              BoronsbruderB Offline
              Boronsbruder
              #4045
              @sborg
              mir ist beim patchen folgendes aufgefallen:
              ./ws_updater.sh: Zeile 405: [: ==: Einstelliger (unärer) Operator erwartet.
               Fertig...
              Ich bekomme ständig:
              Aug  5 20:38:39 ZEROSERVER wetterstation.sh[18688]: (standard_in) 1: syntax error
              Aug  5 20:38:39 ZEROSERVER wetterstation.sh[18688]: /home/wetter/wetterstation.sh: Zeile 384: opensensemap: Kommando nicht gefunden.
              Aug  5 20:38:39 ZEROSERVER wetterstation.sh[18688]: /home/wetter/wetterstation.sh: Zeile 392: logging: Kommando nicht gefunden.
              Aug  5 20:38:39 ZEROSERVER wetterstation.sh[18688]: /home/wetter/wetterstation.sh: Zeile 198: get_DATA: Kommando nicht gefunden.
              R SBorgS 2 Antworten Letzte Antwort
              • BoronsbruderB Boronsbruder
                @sborg
                 Fertig...
                Rushmed
                #4046
                @boronsbruder Wo kommen denn die Meldungen bei dir und kommen Daten im ioBroker an?
                @SBorg Reboot hatte ich schon erfolglos probiert. Erneuter Reboot war auch erfolglos, selbes Ergebnis.
                @Nashra Läuft bei dir alles mit der .17?
                BoronsbruderB NashraN 2 Antworten Letzte Antwort
                • R Rushmed
                  Boronsbruder
                  #4047
                  @rushmed
                  Ist aus der logfile und Daten kommen keine an
                    @rushmed
                    SBorgS Offline
                    SBorgS Offline
                    SBorg
                    #4048
                    @boronsbruder / @Rushmed
                    Könnt ihr mal ein dos2unix wetterstation.sub machen? Ggf. mittels sudo apt install dos2unix nachinstallieren.
                      @sborg
                       Fertig...
                      SBorgS Offline
                      SBorgS Offline
                      SBorg
                      #4049
                      @boronsbruder sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                      @sborg
                      Fertig...
                      Du hast keine Rest-API installiert? Ist ein Schönheitsfehler und im kommenden Updater gefixt.
                      • SBorgS SBorg
                        @sborg
                        Fertig...
                        Boronsbruder
                        #4050
                        @sborg
                        ich hatte nur noch keine Daten in der Config eingetragen
                        nach dos2unix gibts nur noch
                        Aug  5 21:23:33 ZEROSERVER wetterstation.sh[22152]: Connection to 192.168.116.249 8087 port [tcp/*] succeeded!
                        Aug  5 21:23:34 ZEROSERVER wetterstation.sh[22152]: (standard_in) 1: syntax error
                        Debug VAR:
                        Installationsverzeichnis: /home/wetter
                        IPP: 192.168.116.249:8087       WS_PORT: 45454          WS_POLL: 30             PRE_DP: 0_userdata.0.Wetterstation
                        WEB: HTTPS              WS_PROT: Ecowitt        DP35/40/50/60/70/100/200/250/300: 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0
                        WH31: 0
                        Script-Version: V2.17.0 Config-Version: V2.17.0 Sub-Version: V2.17.0
                        Kommunikationsfehler!
                        • SBorgS SBorg
                          Rushmed
                          #4051
                          Du bist ein sehr guter Typ. Jetzt läufts.
                          Was war das Problem?
                            @sborg
                            Debug VAR:
                            WH31: 0
                            Rushmed
                            #4052
                            @boronsbruder Haste den Service neu gestartet?
                              @sborg
                              Debug VAR:
                              WH31: 0
                              SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #4053
                              @boronsbruder Lade bitte nochmal wget -O wetterstation.sub https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/wetterstation.sub
                              Da war kurzfristig eine falsche Version Online.
                              • R Rushmed
                                SBorgS Offline
                                SBorgS Offline
                                SBorg
                                #4054
                                Die "wetterstation.sub" lag auf GitHub als Windows-Version mit CR (Carrige Return), was Linux überhaupt nicht mag.
                                An der hatte ich aber zum einen schon seit Tagen nix mehr geändert, noch mache ich da irgendwas mit Windows daran. Warum sollte ich auch :)
                                • SBorgS SBorg
                                  Rushmed
                                  #4055
                                  @sborg Ah ok. Vielen Dank für die schnelle Hilfe!
                                  • SBorgS SBorg
                                    Boronsbruder
                                    schrieb am zuletzt editiert von Boronsbruder
                                    #4056
                                    @sborg
                                    Nu läufts auch bei mir wieder mit der 2.17.0
                                    Ich bin mal kurz verzweifelt, weil mit keiner Version eine Verbindung zu stande kam... ständig nur die Syntaxerror
                                    Ein Reboot war die Lösung (was ich gerne vermeide, weil ich noch andere Dienste darauf am Laufe habe...)
                                    Jetzt machst aber nicht wieder alles kaputt, gelle 🤣
                                      @sborg
                                      Rushmed
                                      #4057
                                      @boronsbruder Ich konnte auch kein Backup erfolgreich wiederherstellen.
                                      • R Rushmed
                                        NashraN Offline
                                        NashraN Offline
                                        Nashra
                                        Most Active Forum Testing
                                        #4058
                                        Ja, bis jetzt keine Probleme. Alle Daten kommen rein.
                                        Gruß Ralf
                                          Mugel80
                                          #4059
                                          ich hab mal wieder ein Problem.
                                          Seit gestern hab ich jetzt den DB60 am laufen. In der Nacht war auch ein Gewitter und es wurden schon brav Blitze gezählt.
                                          Leider erfolgt kein Datenimport zum Iobroker.
                                          Ich hab den Datenpunkt mit den JS-Script angelegt.
                                          Laut Debugausgabe vom Script soll der Iobroker-Datenpunkt nicht vorhanden sein, obwohl er angelegt ist.
                                          Ist da Fehler im Script? Oder muss ich noch was ändern?
