  4. Admin 6.0 - neu als Beta
352 Beiträge 54 Kommentatoren 92.7k Aufrufe 45 Beobachtet
  • NegaleinN Negalein
    @apollon77
    Hallo
    Ich hab gerade die neue Xbox 1.0.0-beta.0 von @foxriver76 installiert.
    Folgendes passiert bei Aufruf der Instanz (Konfig).
    instrument.ts:124 TypeError: Cannot read properties of undefined (reading 'value')
        at vn.renderItem (ConfigText.jsx:36:34)
        at vn.render (ConfigGeneric.jsx:514:39)
        at Wi (react-dom.production.min.js:204:189)
        at Rs (react-dom.production.min.js:203:149)
        at oa (react-dom.production.min.js:292:172)
        at ra (react-dom.production.min.js:280:389)
        at Jc (react-dom.production.min.js:280:320)
        at ml (react-dom.production.min.js:280:180)
        at iu (react-dom.production.min.js:271:88)
        at bs (react-dom.production.min.js:268:429)
        at Ln (scheduler.production.min.js:13:203)
        at MessagePort.Gn (scheduler.production.min.js:14:128)
    (anonym) @ instrument.ts:124
    instrument.ts:124 timeout
    sentry.iobroker.net/api/58/envelope/?sentry_key=43643152dab3481db69950ba866ee9d6&sentry_version=7:1          Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
    ich bekomm nur das obige als Error.
    Und unter dem Bild steht in Rot
    TypeError: Cannot read properties of undefined (reading 'value')($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at vn.renderItem (https://10.0.1.202:8081/static/js/5710.7d75fb68.chunk.js:74:150640)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at vn.render (https://10.0.1.202:8081/static/js/5710.7d75fb68.chunk.js:74:40920)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Wi (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:6209)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Rs (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:6006)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at oa (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:44992)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at ra (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39832)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Jc (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39763)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at ml (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39622)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at iu (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:36004)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at bs (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:34957)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Ln (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:24:1614)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at MessagePort.Gn (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:24:2007)
    Bei @foxriver76 klappt es mit Admin stable.
    Upload brachte keine Besserung
    Node.js: v16.15.1
    NPM: 8.11.0
    JS-Contr: 4.0.23
    Admin: 6.2.6
    GlasfaserG Offline
    GlasfaserG Offline
    #266
    @negalein sagte in Admin 6.0 - neu als Beta:
    Node.js: v16.15.1
    NPM: 8.11.0
    Ich denke mal das hat nicht mit dem Error zu tun , aber es sollte die NodeJS 16.16.0 sein
    iobroker stop
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    • GlasfaserG Glasfaser
      Node.js: v16.15.1
      NPM: 8.11.0
      iobroker stop
      sudo apt update
      sudo reboot
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #267
      @glasfaser sagte in Admin 6.0 - neu als Beta:
      NodeJS 16.16.0
      Ah, merci. Hab ich noch nicht mitbekommen, dass die 16.16.0 heraussen ist.
      ° Fixer ---> iob fix
      • GlasfaserG Offline
        GlasfaserG Offline
        #268
        @negalein
        Nee ... 15 ist ungerade .. Dev Versionen
        Es sollte
        Node.js: v16.16.0
        mit
        NPM: 8.11.0
        kommen
          @negalein
          Es sollte
          Node.js: v16.16.0
          mit
          NPM: 8.11.0
          kommen
          #269
          Bezieht sich aber auf die Major-Version. @Negalein hat ja 16.15.1 laufen.
          Mit bekommen kann man das übrigens recht einfach, indem man sich angewöhnt bei jedem einloggen in die Konsole erstmal beim Paketmanager vorbeizuschauen, ob da was bereit liegt.
          • apollon77A Offline
            #270
            Welche Admin Version? Mal dort issues geprüft ?
            • apollon77A apollon77
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #271
              @apollon77 sagte in Admin 6.0 - neu als Beta:
              Admin: 6.2.6
              hab mich gerade diesem Issue angeschlossen
                Admin: 6.2.6
                FeuersturmF Offline
                FeuersturmF Offline
                Feuersturm
                #272
                @negalein Aktualisiere mal auf die 6.2.10
                Mit der Version tritt das Problem bei mir mit dem xbox Adapter nicht mehr auf.
                • FeuersturmF Feuersturm
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #273
                  @feuersturm sagte in Admin 6.0 - neu als Beta:
                  Merci
                  funktioniert wieder :)
                    Merci
                    #274
                    Keep your systems updated... :-)
                      #275
                      @thomas-braun lol ;-)) glaube heute war Admin versionstag ;-))
                      Thomas BraunT SBorgS 2 Antworten Letzte Antwort
                        #276
                        @apollon77
                        Naja, gerade im Beta-Zweig sollte man halt schon schauen, ob das was man da gerade betatestet auch dem aktuellen Stand der Entwicklung widerspiegelt, finde ich.
                        NegaleinN ? 2 Antworten Letzte Antwort
                          @apollon77
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #277
                          @thomas-braun sagte in Admin 6.0 - neu als Beta:
                          du meinst in Bezug auf NPM, Node, JS-Contr. und generell das System aktuell?
                          Dr. BakteriusD 1 Antwort Letzte Antwort
                            @apollon77
                            #278
                            Vielleicht sollte man sich auch mal überlegen ob man das umstellen auf Beta etwas schwieriger macht. Beim Experten Modus kommt ja auch eine Warnung...
                              #279
                              @brainbug
                              Bei Verwendung des Beta-Repos steht permanent eine Warnung im Admin...
                                SBorgS Offline
                                SBorgS Offline
                                SBorg
                                #280
                                ...aber so was von am 29.07. 😂
                                LG SBorg ( SBorg auf GitHub)
                                  Dr. BakteriusD Offline
                                  Dr. Bakterius
                                  #281
                                  Ja, aber natürlich auch im Beta-Zweig die aktuellen Stände der Adapter. Schließlich ist Beta eine Testversion die noch Fehler enthalten kann. Diese Fehler werden in der Beta-Phase möglichst alle behoben. Deshalb gibt es mehrere Beta-Versionen bis sie in stable kommen.
                                  Wenn dir das alles unbekannt ist, wäre es besser in stable zu bleiben...
                                    @brainbug
                                    #282
                                    @thomas-braun wo ist das denn? Ich hab das noch nie gesehen. Hast du mal ein Screenshot?
                                      #283
                                      @brainbug
                                        @brainbug
                                        #284
                                        @thomas-braun ok, für mich ist das ein Hinweis und keine Warnung. Das meinte ich ja, beim umstellen auf Beta sollte eine Hinweismeldung erscheinen wie beim Expertenmodus. Wie oft liest man hier: "Warum bist du mit Beta unterwegs."
                                        Thomas BraunT ChaotC M 3 Antworten Letzte Antwort
                                          #285
                                          @brainbug
                                          Die Bedeutung von 'Diese Software ist eine BETA-Version mit allen Haken und Ösen' setze ich jetzt mal einfach voraus.
