  4. [Frage] Xiaomi Vacuum cleaner
2.2k Beiträge 204 Kommentatoren 1.5m Aufrufe 39 Beobachtet
  • MeistertrM
    MeistertrM
    Meistertr
    #713
    @ThePhantom79:
    Danke und bitte .. ich erkenne da iwie nix …
    ` > mihome-vacuum.0 2017-06-10 15:30:13.792 debug Receive <<< Helo <<< 213100200000000003d7c93d593bf465ffffffffffffffffffffffffffffffff
    mihome-vacuum.0 2017-06-10 15:30:13.673 info Send_message >>> {"id":1003,"method":"get_clean_summary"}
    mihome-vacuum.0 2017-06-10 15:30:13.669 info lastid{"get_status":0,"get_consumable":0,"get_clean_summary":1003,"get_clean_record":0}
    mihome-vacuum.0 2017-06-10 15:29:53.734 debug Receive <<< Helo <<< 213100200000000003d7c93d593bf451ffffffffffffffffffffffffffffffff
    mihome-vacuum.0 2017-06-10 15:29:53.652 info Send_message >>> {"id":1002,"method":"get_clean_summary"}
    mihome-vacuum.0 2017-06-10 15:29:53.651 info lastid{"get_status":0,"get_consumable":0,"get_clean_summary":1002,"get_clean_record":0}
    mihome-vacuum.0 2017-06-10 15:29:33.679 debug Receive <<< Helo <<< 213100200000000003d7c93d593bf43dffffffffffffffffffffffffffffffff
    mihome-vacuum.0 2017-06-10 15:29:33.641 info Send_message >>> {"id":1001,"method":"get_clean_summary"}
    mihome-vacuum.0 2017-06-10 15:29:33.638 info lastid{"get_status":0,"get_consumable":0,"get_clean_summary":1001,"get_clean_record":0}
    mihome-vacuum.0 2017-06-10 15:29:14.239 debug inMem message mihome-vacuum.0.* mihome-vacuum.0.info.connection val=true, ack=true, ts=1497101354236, q=0, from=system.adapter.mihome-vacuum.0, lc=1497101354236
    mihome-vacuum.0 2017-06-10 15:29:14.235 info Connected
    mihome-vacuum.0 2017-06-10 15:29:14.234 debug Receive <<< Helo <<< 213100200000000003d7c93d593bf429ffffffffffffffffffffffffffffffff
    mihome-vacuum.0 2017-06-10 15:29:13.635 debug server started on 0.0.0.0:53421
    mihome-vacuum.0 2017-06-10 15:29:13.631 info Send_message >>> {"id":1000,"method":"get_clean_summary"}
    mihome-vacuum.0 2017-06-10 15:29:13.628 info lastid{"get_status":0,"get_consumable":0,"get_clean_summary":1000,"get_clean_record":0}
    mihome-vacuum.0 2017-06-10 15:29:13.623 info starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v4.8.3
    mihome-vacuum.0 2017-06-10 15:29:13.551 debug statesDB connected
    die mihomepacket hast du nciht verändert oder? Das Verhalten des Adapters ist vollkommen korrekt auch die Antwortzeiten vom Roboter sind vollkommen im grünen bereich. Von daher kann es nur noch token sein oder irgendeine Firewall Hast du eine am Laufen? falls ja stelle mal alles ab.. das problem hatten wir auch schon gelegentlich, Du kannst auch noch versuchen den eigenen prot zu änder in der config, vll könnte das auch helfen.
    • T
      T
      ThePhantom79
      #714
      Ich kenne mich mit Linux nicht so super aus (unter Windows lief iobroker nicht wirklich)
      Ich habe eine Standard Debian Installation genommen, und sehe nicht, dass irgendeine FW aktiv ist…
      • M
        M
        markus- 0
        #715
        Das HELO Packet wird beantwortet, es kann also wenn Timestamps und IDs passen nur am Token liegen.
        <size size="85">https://forum.fhem.de/index.php?topic=73052</size>
        • MeistertrM
          MeistertrM
          Meistertr
          #716
          Und das passt [emoji1]
          Gesendet von meinem SM-G930F mit Tapatalk
          • T
            T
            ThePhantom79
            #717
            Kann es sein, dass ich eine zu neue HW Version habe, die den Token anders / verschlüsselt überträgt?
            Ich habe ja genau gezeigt, wie ich den Token mir rausgeschrieben habe :-(
            Der Roboter antwortet ja auch wie gewünscht auf das Paket …
            • MeistertrM
              MeistertrM
              Meistertr
              #718
              Versuch mal bitte die App hier zu installieren, da muss der Roboter auch aus dem WLAN geschmissen werden
              https://xiaomi.flole.de
              Die Funktion ist ähnlich zum Adapter. Wenn die läuft kannst du den token aus der App nehmen. Dann haben wir alles ausgeschlossen was im Weg sein könnte
              • T
                T
                ThePhantom79
                #719
                Leider funktioniert sogar diese App nicht:
                Nach dem Resetten vom WLAN, kommt "Suche Roboter", und danach "Verbinde Roboter", und dann "Kein Roboter gefunden".
                Auffällig ist, dass der Roboter danach weiterhin nicht im WLAN ist (wie auch, wenn keine WLAN Daten durch die APP abgefragt werden)
                Sehr sehr seltsam das alles.
                Edit: Kann jemand bestätigen, dass er eine funktionierende iobroker Installation mit Roboter FW 3.3.9_<u><size size="150">003074</size></u> hat?
                • S
                  S
                  skorpil
                  #720
                  Nein, kann ich leider nicht! Wie schon oben gesagt: ich traue mich nicht.
                  • T
                    T
                    ThePhantom79
                    #721
                    So, jetzt habe ich ihn mit der Flole App doch geschafft, mich zu verbinden.
                    Trotzdem schafft auch diese App es nicht, NACH der Einrichtung mit dem Roboter zu kommunizieren.
                    Die angezeigte ID des Roboters in der APP ist komischerweise nur 8-stellig … ob das normal ist?
                    • MeistertrM
                      MeistertrM
                      Meistertr
                      #722
                      Das hat nichts zu sagen die id ist nicht der token. Nur weil deiner neuer ist, müsste es trotzdem funktionieren. Im Roboter Forum sind viele die auch neue über die App betreiben. Also müsste dies bei dir auch gehen. Ich würde mal einen werksreset machen vieleicht hilft das. Weiß aber gerade nicht wie man das Macht. Versuche mal mit der Originalen App den Roboter zu steuern also mit der Fernbedienung fahren lassen. Das ist dann wahrscheinlich auch nicht möglich.
                      • T
                        T
                        ThePhantom79
                        #723
                        Doch, das manuelle steuern mit der Original App geht - habe ich gestern mal spaßeshalber ausprobiert ;-)
                        Woher würde man den Token aus dem der Flole App herbekommen?
                        • MeistertrM
                          MeistertrM
                          Meistertr
                          #724
                          Der steht in ein Datei Config.cfg und befindet sich irgendwo in einem Ordner auf dem Handy. Die kannst du mit nen Text Editor öffnen. Habe die App selber noch nicht getestet.
                          • L
                            L
                            looxer01
                            #725
                            @ThePhantom79:
                            Edit: Kann jemand bestätigen, dass er eine funktionierende iobroker Installation mit Roboter FW 3.3.9_<u><size size="150">003074</size></u> hat? `
                            Ich habe das Update durchgefuehrt. Bisher keine Auffaelligkeiten.
                            vG Looxer
                            • MeistertrM
                              MeistertrM
                              Meistertr
                              #726
                              Habe auch die neuste Roboter Version mit dem adapterupdate auf 3 Installationen am laufen
                              • T
                                T
                                ThePhantom79
                                #727
                                Ich denke ich gebe auf - trotzem vielen Dank für die viele Hilfe … Es ist scheinbar der Wurm drin.
                                Schade deswegen, da ich mich bewusst wegen dieser Möglichkeit für den Xiaomi entschieden habe.
                                • M
                                  M
                                  markus- 0
                                  #728
                                  Keine Probleme mit der neuen Firmware in meinem FHEM Modul.
                                  Aktuelle Timestamps und fortlaufende Massage IDs haben geholfen.
                                  Wer sich mit dem Air Purifier beschäftigt bzw. das Python Script verwendet:
                                  Dort wird der Timestamp anders berechnet und zählt die Sekunden seit der Einrichtung. Der Code vom Vacuum kann an dieser Stelle nicht verwendet werden. Die Differenz bekommt man aber aus der HELO Antwort.
                                  • S
                                    S
                                    skorpil
                                    #729
                                    Ich war mutig[emoji23]!
                                    Ergebnis: auch hier hat sowohl das Update der Firmware auf die 003074 als auch die Iobroker Adapter Version 0.3.2 funktioniert! Alles läuft. Danke, Meistertr!
                                    • G
                                      G
                                      gst666
                                      #730
                                      @markus-:
                                      Dort wird der Timestamp anders berechnet und zählt die Sekunden seit der Einrichtung. Der Code vom Vacuum kann an dieser Stelle nicht verwendet werden. Die Differenz bekommt man aber aus der HELO Antwort. `
                                      Ich bastele (es ist mehr noch ein planen) an einem neuen Treiber für mihome-Familie.
                                      Das Problem timestamp lässt sich für beide relativ einfach lösen:
                                      Per helo die timestamp aus Gerät holen und gleichzeitig mit der Zeit des Systems speichern. Bei nächstem Kontakt den gespeicherten Timestamp nehmen und die Zeit die seit dem speichern des Timestamps vergangen ist aufaddieren.
                                      Dann geht der Packettreiber wieder für beide.
                                      • M
                                        M
                                        markus- 0
                                        #731
                                        @Meistertr:
                                        Das hat nichts zu sagen die id ist nicht der token. Nur weil deiner neuer ist, müsste es trotzdem funktionieren. Im Roboter Forum sind viele die auch neue über die App betreiben. Also müsste dies bei dir auch gehen. Ich würde mal einen werksreset machen vieleicht hilft das. `
                                        Hab gerade auch so einen Fall gesehen und eine böse Befürchtung:
                                        Wenn der Token in neueren FW Versionen während des Einrichtungsprozesses neu gesetzt wird, wäre das ziemlich uncool von Xiaomi.
                                        Hat denn schon jemand einen Sauger mit der allerneusten Firmware erfolgreich neu aufgesetzt?
                                        • MeistertrM
                                          MeistertrM
                                          Meistertr
                                          #732
                                          Das wäre übel. Hab es noch nicht getestet..
                                          33.2k
                                          84.3k
