  4. Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta)
391 Beiträge 39 Kommentatoren 86.9k Aufrufe 38 Beobachtet
  • N neolight
    Linux iobroker 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l
    permitted by applicable law.
    Last login: Thu Jul 14 19:01:51 2022 from 192.168.178.21
    pi@iobroker:~ $ iobroker update
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.17.4
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "devices"      : 1.0.12   , installed 1.0.12
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "ham"          : 4.0.2    , installed 4.0.2
    Adapter    "history"      : 1.11.1   , installed 1.11.1
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "worx"         : 1.6.6    , installed 1.6.6
    Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
    pi@iobroker:~ $ iobroker update -i
    pi@iobroker:~ $ iobroker upgrade alexa2 --debug
    Adapter "alexa2"         is up to date.
    pi@iobroker:~ $ Linux iobroker 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l
    Adapter    "mihome"       : 1.4.0    , installed 1-bash: Linux: command not found
    .4.0
    pi@iobroker:~ $
    Dr. BakteriusD Offline
    Dr. Bakterius
    #234
    @neolight Klar, du bist im stable-Zweig und nicht in beta. Lass es einfach so und warte bis der Adapter als stabil eingestuft und freigegeben wird. Dann siehst du auch wenn er zum Updaten bereit ist.
    N 1 Antwort Letzte Antwort
      N Offline
      N Offline
      neolight
      #235
      @dr-bakterius
      Ah, okay. Hab ich jetzt auch gesehen.
      Macht es Sinn, auf Beta zu gehen? Wenn ja, wie?
      Dr. BakteriusD 1 Antwort Letzte Antwort
      • NegaleinN Offline
        NegaleinN Offline
        Negalein
        #236
        @apollon77
        bin gerade auf 3.17.5 gegangen.
        Trotz Intervalle von >60, bekomm ich Meldungen, dass die zu klein sind.
        alexa2.0
        2022-07-14 19:26:24.670	info	Alexa-Push-Connection (macDms = true) established. Disable Polling
        alexa2.0
        2022-07-14 19:26:21.109	info	Update SmartHome Devices Interval is too low, set to 322s
        alexa2.0
        2022-07-14 19:26:20.871	info	starting. Version 3.17.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.15.1, js-controller: 4.0.23
        alexa2.0
        2022-07-14 19:26:16.620	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        alexa2.0
        2022-07-14 19:26:16.619	info	terminating
        alexa2.0
        2022-07-14 19:26:16.618	info	Got terminate signal TERMINATE_YOURSELF
        alexa2.0
        2022-07-14 19:26:02.354	info	Subscribing to states...
        alexa2.0
        2022-07-14 19:25:29.227	info	Alexa-Push-Connection (macDms = true) established. Disable Polling
        alexa2.0
        2022-07-14 19:25:25.601	info	Update SmartHome Devices Interval is too low, set to 356s
        alexa2.0
        2022-07-14 19:25:25.381	info	starting. Version 3.17.5 in /opt/iobroker/node_modules/iobroker.alexa2, node: v16.15.1, js-controller: 4.0.23
        ° Fixer ---> iob fix
        ESP8266E 1 Antwort Letzte Antwort
        • NegaleinN Negalein
          @apollon77
          alexa2.0
          alexa2.0
          alexa2.0
          alexa2.0
          alexa2.0
          alexa2.0
          alexa2.0
          alexa2.0
          alexa2.0
          alexa2.0
          ESP8266E Offline
          ESP8266E Offline
          ESP8266
          schrieb am zuletzt editiert von ESP8266
          #237
          @negalein , 300 sec oder > sollten es sein.
          • ESP8266E ESP8266
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #238
            @esp8266 sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
            Danke, dann ist es hier etwas missverständlich beschrieben.
            ESP8266E apollon77A 2 Antworten Letzte Antwort
              ESP8266E Offline
              ESP8266E Offline
              ESP8266
              #239
              @negalein sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
              @apollon77 sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
              Eine 3.17.5 wird bald kommen. Diese setzt das minimum für das Smart-Home-Query-Interval auf 5 Minuten und optimiert noch eine Weitere Sache, um weiter zu unterstützen das die Requests weniger werden. Wer Smart Home Devices synchronisiert und ein Intervall != 0 nutzt bitte installieren
                #240
                @negalein ja da hab ich wohl vergessen den Text anzupassen ;-( kommt in nächste Version. 5 min ist das aktuelle - wenn man Smart devices braucht!! Sonst aus lasse
                YodaY padrinoP 2 Antworten Letzte Antwort
                • apollon77A apollon77
                  YodaY Offline
                  YodaY Offline
                  Yoda
                  #241
                  @apollon77
                  seit Heute habe ich in meiner Adapterversion 3.11.2 ebenfalls keine Hardware mehr unter Smart Home Device.
                  Da scheint Amazon ja wieder was dolles gemacht zu haben :-(
                  Ich Nutze 15 Alexa Steckdosen die ich so Aktuell nicht mehr steuern kann.
                  Der Alexa Skill wurde von mir einmal Deaktiviert und neu mit Iobroker verbunden.
                  Adapter Neustart und Geräte suche, alles vergebens.
                  Ich habe grade von neuen Adapter Versionen gelesen,
                  so wie ich verstehe gibt es aber noch keine Lösung oder?
                  Gruß Yoda
                  Stand 05.2025
                  Raspberry5,linux,arm64,CPUs:4,Geschwindigkeit:2400 MHz,Modell:Cortex-A76,RAM:15.8 GB,Node.js:v20.19.2
                  Dr. BakteriusD apollon77A 2 Antworten Letzte Antwort
                  • N neolight
                    @dr-bakterius
                    Dr. Bakterius
                    #242
                    @neolight sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
                    Wenn du nicht weißt wie das geht, lass es lieber bleiben. Beta-Versionen können noch Fehler enthalten (wie man aktuell gesehen hat) und wenn du dir dann nicht zu helfen weißt, hast du ein Problem.
                    • YodaY Yoda
                      @apollon77
                      Dr. Bakterius
                      schrieb am zuletzt editiert von Dr. Bakterius
                      #243
                      @yoda sagte in Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta):
                      Geht mir auch so. Da kann man wohl nur abwarten und hoffen das Amazon die Sperre bald wieder aufhebt... (siehe auch https://forum.iobroker.net/topic/56347/alexa2-smarthome-geräte-aktuell-pot-ohne-funktion)
                      • YodaY Yoda
                        @apollon77
                        #244
                        naja der Ehrlichkeit halber habe ICH was tolles gemacht ... Amazon hat erst einmal nur reagiert um Ihre Systeme und Kunden (und Skill Betreiber) zu schützen ... Der Ehrlichkeit halber ... ich hätte nichts anderes getan wenn es mein System gewesen wäre.
                        Also der geht leider voll auf meine Kappe und kann nicht genug Sorry dafür sagen ... Und ja jetzt hoffen das die User die noch auf einer der Kaputten Versionen sind schnellstmöglich updaten damit es wieder besser wird für alle.
                        YodaY 1 Antwort Letzte Antwort
                          YodaY Offline
                          YodaY Offline
                          Yoda
                          #245
                          @apollon77 Danke für die Info!
                          Schon mal gut zu wissen das es kein User / Lokales Problem ist.
                          Ich stehe aber grade auf der Leitung, was meinst du mit:
                          "Und ja jetzt hoffen das die User die noch auf einer der Kaputten Versionen sind schnellstmöglich updaten damit es wieder besser wird für alle"
                          Sollten die betroffenen User doch ein Adapterupdate auf Version .... machen?
                          Gruß Yoda
                          Stand 05.2025
                          • YodaY Yoda
                            #246
                            @yoda die User die eine beta Version aus dem Versionsbereich 3.14.0 bis einschließlich 3.17.3 haben müssen schnellstens auf 3.17.4 oder höher oder zurück auf eine Version kleiner 3.14 … darum geht es. Nur der genannte Versionsbereich ist „böse“ und verursacht die zu vielen calls an die Amazon Systeme. Je weniger User mit diesen buggy Versionen „spammen“ umso mehr sollte es für alle anderen wieder gehen.
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #247
                              @apollon77 kurze Zwischenfrage: empfiehlt es sich die SHD-Abfrage in der 3.17.5 zu aktivieren bevor Amazon da wieder "besänftigt" ist oder lieber paar Tage warten ?
                              Lehrling seit 1975 !!!
                              • DJMarc75D DJMarc75
                                #248
                                @djmarc75 die 5 Minuten in der 3.17.5 sind mit Amazon so abgesprochen und wird Vorauss alles gehen … wenn mal die „Spammer“ weg sind.
                                Edit: die User die da beim interval etwas >0 stehen haben sind nicht das Problem. Der Bug passiert wenn man als interval 0 (= deaktiviert .. was default ist) stehen hat … dann macht er leider doch requests und sehr viele :-(
                                  ESP8266E Offline
                                  ESP8266E Offline
                                  ESP8266
                                  #249
                                  @apollon77 , jetzt bin ich ein wenig confused. Ich habe die 3.17.4 drauf und den Interval auf 0.
                                  Also macht er jetzt requests oder nicht? Ich brauche das normal nicht....
                                  apollon77A D 2 Antworten Letzte Antwort
                                  • ESP8266E ESP8266
                                    #250
                                    @esp8266 3.17.4 ist ok wenn du 0 hast ... alles gut. Wenn Du es nicht brauchst dann einfach noch weiter unten den Haken raus nehmen - dann musst Du es ja gar nicht syncen oder?
                                    ESP8266E DJMarc75D 2 Antworten Letzte Antwort
                                    • ESP8266E ESP8266
                                      dirkhe
                                      schrieb am zuletzt editiert von dirkhe
                                      #251
                                      @esp8266 dann setze den Wert hoch oder installiere die 3.17.5
                                      • D dirkhe
                                        #252
                                        @dirkhe NEIN!!! Wenn er es nicht braucht dann weiter unten den Haken bei "Sync smart home devices" rausnehmen und/oder Interval auf 0 lassen. Nciht hochsetzen. 0= deaktiviert tut ab der 3.17.4 wie es soll ... nur bei Versionen KLEINER ALS 3.17.4 ist das Problematisch
                                          ESP8266E Offline
                                          ESP8266E Offline
                                          ESP8266
                                          #253
                                          Nein ich brauche nicht syncen....es sind nur smartNames von diversen devices hinterlegt....
