  3. Off Topic
  4. Proxmox
  5. Proxmox VM friert ein
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
186 Beiträge 20 Kommentatoren 45.4k Aufrufe 14 Beobachtet
  • T TronLand
    Da steht ja so gut wie nichts drin für heute. Zumindest nicht bei meiner Einstellung "WARN":
    2022-07-08 00:55:22.377  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.000E9569A24263.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 05:37:54.296  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.00265D898976EF.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 05:50:48.584  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.0009170993369E.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 06:25:41.873  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.00201D899333DE.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 07:02:08.039  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.000313C9933C4A.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 18:57:48.511  - warn: node-red.0 (453) 8 Jul 18:57:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
    2022-07-08 18:59:39.472  - warn: host.iobVM "system.host.raspberrypigas" is offline
    2022-07-08 18:59:39.491  - warn: host.iobVM "system.host.ioBroker3" is offline
    2022-07-08 19:30:46.434  - warn: host.iobVM instance system.adapter.mqtt.0 terminated due to SIGTERM
    2022-07-08 19:31:25.243  - warn: node-red.0 (461) 8 Jul 19:31:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
    2022-07-08 19:46:20.828  - warn: host.iobVM "system.host.raspberrypigas" is offline
    2022-07-08 19:46:20.845  - warn: host.iobVM "system.host.ioBroker3" is offline
    2022-07-08 19:55:07.934  - warn: influxdb.0 (494) Store data for 17 points and 0 conflicts
    2022-07-08 19:55:09.360  - warn: host.iobVM instance system.adapter.mqtt.0 terminated due to SIGTERM
    2022-07-08 19:55:15.594  - warn: host.iobVM "system.host.raspberrypigas" is offline
    2022-07-08 19:55:15.608  - warn: host.iobVM "system.host.ioBroker3" is offline
    2022-07-08 19:55:28.203  - warn: node-red.0 (1178) 8 Jul 19:55:28 - [warn] Projects disabled : editorTheme.projects.enabled=false
    Um 18:59 hatte ich ja neu gestartet.
    GlasfaserG Offline
    GlasfaserG Offline
    @tronland sagte in Proxmox VM friert ein:
    sind diese beiden auch so struppelig !?
      Manuell hab' ich nichts gemacht.
      Doch, npm reingepflügt.
      TronLand
      @thomas-braun Oh Mist. Wie komm' ich denn auf die 32bit Version? Muss wohl verrutscht sein, als ich das Image ausgewählt habe.
      Ich Idiot.
      Okay, ihr habt mir superschnell geholfen! Vielen vielen Dank!!!!!
      Ich denke, ich verbringe den Abend mit dem Aufsetzen einer neuen VM und dem Einspielen meiner Backups :-)
      Ich kann mich echt nicht erinnern, dass ich npm installiert habe. Aber ist ja so.
      Nochmals vielen vielen Dank für Eure Hilfe!!!
      Viele Grüße aus Heidelberg!
      Michael
      • GlasfaserG Glasfaser
        TronLand
        @glasfaser Eigentlich nicht. Das sind beides Raspberry Pi's. Hab' mit denen eigentlich keine Probleme.
        Aber auf denen läuft nicht nicht die 64bit Version.
        GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
        • T TronLand
          Ich Idiot.
          Michael
          GlasfaserG Offline
          GlasfaserG Offline
          Das wäre auch noch schneller gelaufen ... wenn du schon oben im Start-Thread mehr Infos gehabt hättest .
          T Thomas BraunT 2 Antworten Letzte Antwort
            TronLand
            @glasfaser Ja, weiss ich jetzt auch. Nochmals sorry dafür.
            • T TronLand
              GlasfaserG Offline
              GlasfaserG Offline
              würde es aber trotzdem mal prüfen mit der Anfrage die ich oben gestellt habe !
              • T TronLand
                Bei den arm-basierten Geräten ist das (noch) nicht weiter wild, da wird noch das allermeiste auch für 32bit gebacken. i386 wird dahingegen schon geraume Zeit nicht mehr voll bedient.
                  @glasfaser
                  Im dritten Posting stand es drin:
                  Debian VM Linux iobVM 5.10.0-14-686-pae
                  Habs aber auch überlesen.
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @TT-Tom
                    Warum bewertest du @crunchip Negativ !
                    Ist doch erstmal eine Logisch vorgehensweise , wenn wir hier was benötigen !?
                    T crunchipC 2 Antworten Letzte Antwort
                      @TT-Tom
                      TT-Tom
                      @glasfaser
                      War nicht mit Absicht, muss beim blättern passiert sein. Nehme ich gleich wieder zurück. Sorry
                      Gruß Tom
                      Public Transport
                      NSPanel Adapter Wiki
                        @TT-Tom
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @glasfaser was dir so alles auffällt😁
                          TronLand
                          schrieb am zuletzt editiert von TronLand
                          @glasfaser
                          nun ist es wieder passiert.
                          Habe eine neue (64bit) VM aufgesetzt und ioBroker restored.
                          Punkt 22:18 ging die Prozessorlast auf ca. 50% und ioBroker war nicht mehr erreichbar.
                          Linux ioBroker 5.10.0-16-amd64 #1 SMP Debian 5.10.127-1 (2022-06-30) x86_64
                          permitted by applicable law.
                          Last login: Sun Jul 10 15:45:11 2022 from 192.168.10.111
                          tech@ioBroker:~$ cd /opt/iobroker
                          tech@ioBroker:/opt/iobroker$ npm ls | grep -E 'github.com|ERR'
                          [sudo] password for tech:
                          ├── iobroker.life360@0.2.17 (git+ssh://git@github.com/migoller/iobroker.life360.git#fb48e5d206f904abaf7a464acb79eb0dfbab52ea)
                          tech@ioBroker:/opt/iobroker$ iobroker update -i
                          Used repository: stable
                          Adapter    "admin"        : 5.3.8    , installed 5.3.8
                          Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                          Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                          Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
                          Adapter    "info"         : 1.9.19   , installed 1.9.19
                          Adapter    "iot"          : 1.11.4   , installed 1.11.4
                          Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                          Controller "js-controller": 4.0.23   , installed 4.0.23
                          Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
                          Adapter    "node-red"     : 3.3.1    , installed 3.3.1
                          Adapter    "nut"          : 1.5.1    , installed 1.5.1
                          Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
                          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                          Adapter    "wireguard"    : 1.3.1    , installed 1.3.1
                          Adapter    "withings"     : 0.0.9    , installed 0.0.7  [Updatable]
                          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                          Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                          tech@ioBroker:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                          uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                          x86_64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.16.0
                          v16.16.0
                          8.11.0
                          tech
                          /opt/iobroker
                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                          Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                          Hit:3 http://ftp.tu-chemnitz.de/debian bullseye InRelease
                          Hit:4 http://ftp.tu-chemnitz.de/debian bullseye-updates InRelease
                          Reading package lists... Done
                          All packages are up to date.
                          nodejs:
                            Installed: 16.16.0-deb-1nodesource1
                            Candidate: 16.16.0-deb-1nodesource1
                            Version table:
                           *** 16.16.0-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                               12.22.12~dfsg-1~deb11u1 500
                                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                               12.22.5~dfsg-2~11u1 500
                                  500 http://ftp.tu-chemnitz.de/debian bullseye/main amd64 Packages
                          syslog.log:
                          Jul 12 21:27:21 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:27:33 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:27:44 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:27:54 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:28:05 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:28:17 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:28:28 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:28:39 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:28:52 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:29:03 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:29:13 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:29:25 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 21:29:36 ioBroker qemu-ga: info: guest-ping called
                          Jul 12 22:05:34 ioBroker dhclient[341]: DHCPREQUEST for 192.168.1.101 on ens18 to 192.168.1.200 port 67
                          Jul 12 22:05:34 ioBroker dhclient[341]: DHCPACK of 192.168.1.101 from 192.168.1.200
                          Jul 12 22:05:34 ioBroker dhclient[341]: bound to 192.168.1.101 -- renewal in 2767 seconds.
                          Jul 12 22:17:01 ioBroker CRON[4503]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] Linux version 5.10.0-16-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP Debian 5.10.127-1 (2022-06-30)
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-16-amd64 root=UUID=d362ca41-a039-4c29-a1ee-8b143035a2a2 ro quiet
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] x86/fpu: x87 FPU will use FXSAVE
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-provided physical RAM map:
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bffd9fff] usable
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-e820: [mem 0x00000000bffda000-0x00000000bfffffff] reserved
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001bfffffff] usable
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] NX (Execute Disable) protection: active
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] SMBIOS 2.8 present.
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] DMI: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.15.0-0-g2dd4b9b3f840-prebuilt.qemu.org 04/01/2014
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] Hypervisor detected: KVM
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] kvm-clock: cpu 0, msr 1bacb8001, primary cpu clock
                          Jul 12 22:36:27 ioBroker kernel: [    0.000000] kvm-clock: using sched offset of 10540014338 cycles
                          Jul 12 22:36:27 ioBroker kernel: [    0.000002] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
                          Jul 12 22:36:27 ioBroker kernel: [    0.000005] tsc: Detected 1996.800 MHz processor
                          Jul 12 22:36:27 ioBroker kernel: [    0.000745] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
                          Jul 12 22:36:27 ioBroker kernel: [    0.000748] e820: remove [mem 0x000a0000-0x000fffff] usable
                          Jul 12 22:36:27 ioBroker kernel: [    0.000752] last_pfn = 0x1c0000 max_arch_pfn = 0x400000000
                          Jul 12 22:36:27 ioBroker kernel: [    0.000784] MTRR default type: write-back
                          Jul 12 22:36:27 ioBroker kernel: [    0.000785] MTRR fixed ranges enabled:
                          kern.log:
                          Jul 11 09:04:36 ioBroker kernel: [    3.059065] audit: type=1400 audit(1657523076.524:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=301 comm="apparmor_parser"
                          Jul 11 09:04:36 ioBroker kernel: [    3.059067] audit: type=1400 audit(1657523076.524:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=301 comm="apparmor_parser"
                          Jul 11 09:04:37 ioBroker kernel: [    3.569939] random: crng init done
                          Jul 11 09:04:37 ioBroker kernel: [    3.569942] random: 167 urandom warning(s) missed due to ratelimiting
                          ioBroker Log:
                          2022-07-12 22:15:56.862  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:16:03.863  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:16:04.000  - warn: hm-rpc.0 (1333) State value to set for "hm-rpc.0.0009170993369E.0.RSSI_DEVICE" has value "128" greater than max "127"
                          2022-07-12 22:16:14.113  - info: influxdb.0 (510) Store 22 buffered influxDB history points
                          2022-07-12 22:16:24.121  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:16:34.132  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:16:43.715  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:16:51.725  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:17:00.157  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:17:10.168  - info: influxdb.0 (510) Store 22 buffered influxDB history points
                          2022-07-12 22:17:19.849  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:17:28.332  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:17:37.693  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:17:46.204  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:17:56.215  - info: influxdb.0 (510) Store 22 buffered influxDB history points
                          2022-07-12 22:18:05.754  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:18:16.018  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:18:22.833  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:18:30.412  - info: influxdb.0 (510) Store 21 buffered influxDB history points
                          2022-07-12 22:36:29.107  - info: host.iobVM iobroker.js-controller version 4.0.23 js-controller starting
                          2022-07-12 22:36:29.109  - info: host.iobVM Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                          2022-07-12 22:36:29.110  - info: host.iobVM hostname: iobVM, node: v16.16.0
                          2022-07-12 22:36:29.111  - info: host.iobVM ip addresses: 192.168.1.101 fe80::fc7b:28ff:fe6b:cc51
                          2022-07-12 22:36:29.216  - info: host.iobVM Sets unsupported
                          2022-07-12 22:36:29.217  - info: host.iobVM Sets unsupported
                          2022-07-12 22:36:29.922  - info: host.iobVM connected to Objects and States
                          2022-07-12 22:36:29.937  - info: host.iobVM added notifications configuration of host
                          2022-07-12 22:36:30.394  - info: host.iobVM 28 instances found
                          2022-07-12 22:36:30.416  - info: host.iobVM starting 11 instances
                          2022-07-12 22:36:30.569  - info: host.iobVM instance system.adapter.admin.0 started with pid 446
                          2022-07-12 22:36:31.354  - info: admin.0 (446) Sets unsupported
                          2022-07-12 22:36:31.356  - info: admin.0 (446) Sets unsupported
                          2022-07-12 22:36:31.626  - info: admin.0 (446) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
                          2022-07-12 22:36:31.650  - info: admin.0 (446) requesting all states
                          2022-07-12 22:36:31.650  - info: admin.0 (446) requesting all objects
                          2022-07-12 22:36:31.784  - info: admin.0 (446) Request actual repository...
                          2022-07-12 22:36:32.253  - info: admin.0 (446) received all objects
                          2022-07-12 22:36:32.343  - info: host.iobVM Updating repository "stable" under "http://repo.iobroker.live/sources-dist.json"
                          2022-07-12 22:36:32.375  - info: admin.0 (446) http server listening on port 8081
                          2022-07-12 22:36:32.376  - info: admin.0 (446) Use link "http://localhost:8081" to configure.
                          2022-07-12 22:36:33.239  - info: admin.0 (446) Repository received successfully.
                          2022-07-12 22:36:34.558  - info: host.iobVM instance system.adapter.javascript.0 started with pid 461
                          2022-07-12 22:36:35.959  - info: javascript.0 (461) Sets unsupported
                          2022-07-12 22:36:35.961  - info: javascript.0 (461) Sets unsupported
                          2022-07-12 22:36:36.295  - info: javascript.0 (461) starting. Version 5.7.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.16.0, js-controller: 4.0.23
                          2022-07-12 22:36:37.399  - info: javascript.0 (461) requesting all states
                          2022-07-12 22:36:37.399  - info: javascript.0 (461) requesting all objects
                          2022-07-12 22:36:38.074  - info: javascript.0 (461) received all states
                          2022-07-12 22:36:38.338  - info: javascript.0 (461) received all objects
                          2022-07-12 22:36:38.597  - info: javascript.0 (461) Start javascript script.js.common.Speedy
                          Thomas BraunT Dr. BakteriusD 2 Antworten Letzte Antwort
                          • T TronLand
                            @glasfaser
                            x86_64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.16.0
                            v16.16.0
                            8.11.0
                            tech
                            /opt/iobroker
                            nodejs:
                              Version table:
                            syslog.log:
                            kern.log:
                            ioBroker Log:
                            @tronland
                            Da würde ich mal in der Konfiguration von influxdb herumschauen.
                              @tronland
                              TronLand
                              Nach was genau? Die Datenbank ist auf einem anderen Rechner.
                              Meinst du in der Konfiguration des ioBroker Adapters?
                              Was könnte denn dort nicht stimmen? Sieht für mich so aus, als würde der Adapter genau das machen, was er soll. Nach 20 (oder mehr) neuen Daten einmal zur Datenbank schreiben.
                              Michael
                              • T TronLand
                                @glasfaser
                                x86_64
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.16.0
                                v16.16.0
                                8.11.0
                                tech
                                /opt/iobroker
                                nodejs:
                                  Version table:
                                syslog.log:
                                kern.log:
                                ioBroker Log:
                                Dr. BakteriusD Online
                                Dr. Bakterius
                                Kann es sich um ein Skript handeln das amokläuft? Also irgendeine Endlosschleife.
                                  TronLand
                                  @dr-bakterius
                                  Hatte alle Skripte deaktiviert.
                                  Das mit den 50% (+-5) ist so ein Proxmox Ding. Wenn eine VM mal z.B. einen Kernal Panic wirft und nicht mehr erreichbar ist, dann zeigt Proxmox genau die gleiche Auslastung. Warum, weiß ich nicht.
                                  A
                                    TronLand
                                    Jetzt ist es wieder passiert... ;-(
                                    In keinen Logs auch nur der geringste Hinweis. Alle Logs sehen normal aus, dann plötzlich kein Eintrag mehr bis zu meinem Reboot. Bin echt am Verzweifeln.
                                    Ich bin echt für jeden Hinweis dankbar.
                                    Michael
                                    isi07I 1 Antwort Letzte Antwort
                                    • T TronLand
                                      Michael
                                      isi07I Offline
                                      isi07I Offline
                                      isi07
                                      @tronland
                                      Hallo
                                      hast Du das Problem lösen können? Ich bin mit meinem IObroker auch auf Proxmox umgezogen und habe genau das gleiche Problem. Nach ein paar Tagen friert die IObroker-VM mit den beschriebenen Symptomen ein. Auch ich kann in den logs keine Fehler feststellen.
                                      Viele Grüße
                                      • crunchipC Abwesend
                                        crunchipC Abwesend
                                        @isi07 sagte in Proxmox VM friert ein:
                                        hast du genau die selbe Hardware, das selbe installiert?
                                        Ein paar mehr Info`s bräuchte man schon dazu
                                          isi07I Offline
                                          isi07I Offline
                                          isi07
                                          @crunchip
                                          sorry, hier mehr Details
                                          ich habe in folgender Diskussion ein ähnliches Problem gefunden und heute schon den Kernel des Host Systems aktualisiert
                                          Es scheint wohl ein Problem mit dem Celeron N5105 zu existieren
                                          https://forum.proxmox.com/threads/vm-freezes-irregularly.111494/
                                          Als Host habe ich
                                          Intel NUC 11 NUC11ATKC4
                                          mit Celeron N5105
                                          Ich habe mehrere VMs und einen LXC Container. Das Problem tritt bei mir nur in der VM mit iobroker auf.
                                          Die VM für iobroker ist jetzt so eingestellt:
                                          iobroker@iobroker:/opt/iobroker$ npm ls | grep -E 'github.com|ERR'
                                          ├── iobroker.accuweather@1.2.4 (git+ssh://git@github.com/isi07/ioBroker.accuweather.git#f161fbf1c577e752bd24c1761ce4c6c1f60549b3)
                                          iobroker@iobroker:/opt/iobroker$ iobroker update -i
                                          Used repository: Beta (latest)
                                          Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
                                          Adapter    "admin"        : 6.2.23   , installed 6.2.23
                                          Adapter    "alarm"        : 3.1.1    , installed 3.1.1
                                          Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                          Adapter    "backitup"     : 2.5.2    , installed 2.5.2
                                          Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                                          Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                          Adapter    "cul"          : 2.0.2    , installed 2.0.2
                                          Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
                                          Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                                          Adapter    "devices"      : 1.1.0    , installed 1.1.0
                                          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                                          Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                                          Adapter    "email"        : 1.1.4    , installed 1.1.4
                                          Adapter    "eusec"        : 0.9.4    , installed 0.9.4
                                          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                          Adapter    "followthesun" : 0.4.0-alpha.1, installed 0.4.0-alpha.1
                                          Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
                                          Adapter    "history"      : 2.2.4    , installed 2.2.4
                                          Adapter    "hm-rega"      : 3.0.43   , installed 3.0.43
                                          Adapter    "hm-rpc"       : 1.15.15  , installed 1.15.15
                                          Adapter    "info"         : 1.9.21   , installed 1.9.21
                                          Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
                                          Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                                          Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                                          Adapter    "mihome-vacuum": 3.6.0    , installed 3.6.0
                                          Adapter    "modbus"       : 5.0.8    , installed 5.0.8
                                          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                          Adapter    "parcel"       : 0.0.23   , installed 0.0.23
                                          Adapter    "plex"         : 0.9.1    , installed 0.9.1
                                          Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                                          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                                          Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
                                          Adapter    "scheduler"    : 0.1.2    , installed 0.1.2
                                          Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                                          Adapter    "shelly"       : 6.2.4    , installed 6.2.4
                                          Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
                                          Adapter    "smartcontrol" : 1.3.1    , installed 1.3.1
                                          Adapter    "socketio"     : 6.1.10   , installed 6.1.10
                                          Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                                          Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
                                          Adapter    "stiebel-isg"  : 1.7.5    , installed 1.7.5
                                          Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
                                          Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
                                          Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                          Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                                          Adapter    "uv-protect"   : 0.3.6    , installed 0.3.6
                                          Adapter    "web"          : 5.2.10   , installed 5.2.10
                                          Adapter    "withings"     : 0.0.13   , installed 0.0.13
                                          Adapter    "ws"           : 2.1.5    , installed 2.1.5
                                          Adapter    "yahka"        : 0.17.0   , installed 0.17.0
                                          iobroker@iobroker:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                          [sudo] Passwort für iobroker:
                                          ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                          iobroker@iobroker:/opt/iobroker$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          x86_64
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.18.0
                                          v16.18.0
                                          8.19.2
                                          iobroker
                                          /opt/iobroker
                                          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                                          OK:2 http://deb.debian.org/debian bullseye InRelease
                                          OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                                          OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          OK:5 https://repos.influxdata.com/debian bullseye InRelease
                                          Aktualisierung für 2 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                                          nodejs:
                                            Installiert:           16.18.0-deb-1nodesource1
                                            Installationskandidat: 16.18.0-deb-1nodesource1
                                            Versionstabelle:
                                           *** 16.18.0-deb-1nodesource1 500
                                                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                          Der letzte Absturz war gestern.
                                          Es äußert sich so, dass die VM nicht mehr reagiert. Der CPU Load wird bei ca 50% angezeigt.
                                          Es hilft nur ein Reset.
                                          Log vom ioBroker
                                          2022-10-29 17:43:58.854 - info: influxdb.0 (12858) Store 101 buffered influxDB history points
                                          2022-10-29 17:44:43.174 - info: influxdb.0 (12858) Store 102 buffered influxDB history points
                                          2022-10-29 17:45:00.038 - info: host.iobroker instance system.adapter.daswetter.0 started with pid 50040
                                          2022-10-29 17:45:01.067 - info: influxdb.0 (12858) Store 101 buffered influxDB history points
                                          2022-10-29 17:45:01.366 - info: daswetter.0 (50040) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.18.0, js-controller: 4.0.23
                                          2022-10-29 17:45:09.410 - info: daswetter.0 (50040) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                          2022-10-29 17:45:09.918 - info: daswetter.0 (50040) cleaned everything up...
                                          2022-10-29 17:45:09.927 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2022-10-29 17:45:31.109 - info: influxdb.0 (12858) Store 101 buffered influxDB history points
                                          2022-10-29 17:45:56.788 - info: javascript.0 (12873) script.js.control.lueften: Lüften!
                                          2022-10-29 17:46:03.596 - info: influxdb.0 (12858) Store 101 buffered influxDB history points
                                          2022-10-29 17:46:47.535 - info: influxdb.0 (12858) Store 101 buffered influxDB history points
                                          2022-10-29 17:47:23.746 - info: influxdb.0 (12858) Store 102 buffered influxDB history points
                                          2022-10-29 19:15:43.634 - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
                                          2022-10-29 19:15:43.636 - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                          2022-10-29 19:15:43.637 - info: host.iobroker hostname: iobroker, node: v16.18.0
                                          2022-10-29 19:15:43.637 - info: host.iobroker ip addresses: 192.168.1.95 fe80::42:afff:fe31:dbb1
                                          2022-10-29 19:15:45.234 - info: host.iobroker connected to Objects and States
                                          2022-10-29 19:15:45.266 - info: host.iobroker added notifications configuration of host
                                          2022-10-29 19:15:45.713 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
                                          2022-10-29 19:15:45.714 - info: host.iobroker 61 instances found
                                          2022-10-29 19:15:45.755 - info: host.iobroker starting 42 instances
                                          2022-10-29 19:15:45.846 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
                                          2022-10-29 19:15:45.904 - info: host.iobroker instance system.adapter.admin.0 started with pid 472
                                          2022-10-29 19:15:45.912 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
                                          2022-10-29 19:15:45.969 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
                                          2022-10-29 19:15:46.022 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
                                          2022-10-29 19:15:46.071 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
                                          2022-10-29 19:15:46.120 - info: host.iobroker Some obsolete host states deleted.
                                          Der kern.log ist zu dem Zeitpunkt des Absturzes irgendwie unvollständig, da ist nichts drin.
                                          Es bricht schon am Vortag ab und steigt dann erst mit dem Neustart nach dem Absturz wieder ein.
                                          Oct 28 23:17:28 iobroker kernel: [10857.468256] device-mapper: uevent: version 1.0.3
                                          Oct 28 23:17:28 iobroker kernel: [10857.468351] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
                                          Oct 28 23:17:29 iobroker kernel: [10858.826570] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
                                          Oct 28 23:17:29 iobroker kernel: [10858.841567] JFS: nTxBlock = 8192, nTxLock = 65536
                                          Oct 28 23:17:29 iobroker kernel: [10858.891689] QNX4 filesystem 0.2.3 registered.
                                          Oct 28 23:17:29 iobroker kernel: [10859.009341] raid6: sse2x4   gen() 10934 MB/s
                                          Oct 28 23:17:29 iobroker kernel: [10859.077314] raid6: sse2x4   xor()  6947 MB/s
                                          Oct 28 23:17:29 iobroker kernel: [10859.145333] raid6: sse2x2   gen() 13516 MB/s
                                          Oct 28 23:17:29 iobroker kernel: [10859.213314] raid6: sse2x2   xor()  7560 MB/s
                                          Oct 28 23:17:29 iobroker kernel: [10859.281333] raid6: sse2x1   gen() 11930 MB/s
                                          Oct 28 23:17:29 iobroker kernel: [10859.349334] raid6: sse2x1   xor()  7237 MB/s
                                          Oct 28 23:17:29 iobroker kernel: [10859.349337] raid6: using algorithm sse2x2 gen() 13516 MB/s
                                          Oct 28 23:17:29 iobroker kernel: [10859.349337] raid6: .... xor() 7560 MB/s, rmw enabled
                                          Oct 28 23:17:29 iobroker kernel: [10859.349353] raid6: using intx1 recovery algorithm
                                          Oct 28 23:17:29 iobroker kernel: [10859.352633] xor: measuring software checksum speed
                                          Oct 28 23:17:29 iobroker kernel: [10859.353189]    prefetch64-sse  : 17804 MB/sec
                                          Oct 28 23:17:29 iobroker kernel: [10859.353848]    generic_sse     : 15363 MB/sec
                                          Oct 28 23:17:29 iobroker kernel: [10859.353849] xor: using function: prefetch64-sse (17804 MB/sec)
                                          Oct 28 23:17:30 iobroker kernel: [10859.437634] Btrfs loaded, crc32c=crc32c-generic
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] Linux version 5.10.0-19-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP Debian 5.10.149-2 (2022-10-21)
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-19-amd64 root=UUID=a0f69eef-29ae-429e-b2c8-fb1cb9ac7915 ro quiet
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] x86/fpu: x87 FPU will use FXSAVE
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-provided physical RAM map:
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bffd9fff] usable
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-e820: [mem 0x00000000bffda000-0x00000000bfffffff] reserved
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000023fffffff] usable
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] NX (Execute Disable) protection: active
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] SMBIOS 2.8 present.
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] DMI: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.16.0-0-gd239552ce722-prebuilt.qemu.org 04/01/2014
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] Hypervisor detected: KVM
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
                                          Oct 29 19:15:42 iobroker kernel: [    0.000000] kvm-clock: cpu 0, msr 1cb4f3001, primary cpu clock
                                          Oct 29 19:15:42 iobroker kernel: [    0.000001] kvm-clock: using sched offset of 82759752833378 cycles
                                          Oct 29 19:15:42 iobroker kernel: [    0.000003] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
                                          Oct 29 19:15:42 iobroker kernel: [    0.000006] tsc: Detected 1996.800 MHz processor
                                          Im Syslog sehe ich auch nichts Auffälliges vor dem Absturz.
                                          Oct 29 16:46:49 iobroker qemu-ga: info: guest-ping called
                                          Oct 29 17:17:01 iobroker CRON[49159]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
                                          Oct 29 19:15:42 iobroker systemd-random-seed[214]: Kernel entropy pool is not initialized yet, waiting until it is.
                                          Oct 29 19:15:42 iobroker systemd[1]: Starting Flush Journal to Persistent Storage...
                                          Oct 29 19:15:42 iobroker systemd[1]: Started Rule-based Manager for Device Events and Files.
                                          Oct 29 19:15:42 iobroker systemd[1]: Finished Coldplug All udev Devices.
                                          Oct 29 19:15:42 iobroker systemd[1]: Starting Helper to synchronize boot up for ifupdown...
                                          Oct 29 19:15:42 iobroker systemd[1]: Finished Flush Journal to Persistent Storage.
                                          Oct 29 19:15:42 iobroker systemd[1]: Finished Helper to synchronize boot up for ifupdown.
                                          Oct 29 19:15:42 iobroker systemd-udevd[249]: Using default interface naming scheme 'v247'.
                                          Oct 29 19:15:42 iobroker systemd-udevd[249]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
                                          Schon mal vielen Dank für Eure Hilfe und weitere Ideen zur Lösung des Problems.
                                          Viele Grüße
                                          Christian
