  3. Off Topic
  4. Proxmox
  5. Proxmox VM friert ein
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
186 Beiträge 20 Kommentatoren 45.4k Aufrufe 14 Beobachtet
  • T TronLand
    Da steht ja so gut wie nichts drin für heute. Zumindest nicht bei meiner Einstellung "WARN":
    2022-07-08 00:55:22.377  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.000E9569A24263.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 05:37:54.296  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.00265D898976EF.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 05:50:48.584  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.0009170993369E.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 06:25:41.873  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.00201D899333DE.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 07:02:08.039  - warn: hm-rpc.0 (546) State value to set for "hm-rpc.0.000313C9933C4A.0.RSSI_DEVICE" has value "128" greater than max "127"
    2022-07-08 18:57:48.511  - warn: node-red.0 (453) 8 Jul 18:57:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
    2022-07-08 18:59:39.472  - warn: host.iobVM "system.host.raspberrypigas" is offline
    2022-07-08 18:59:39.491  - warn: host.iobVM "system.host.ioBroker3" is offline
    2022-07-08 19:30:46.434  - warn: host.iobVM instance system.adapter.mqtt.0 terminated due to SIGTERM
    2022-07-08 19:31:25.243  - warn: node-red.0 (461) 8 Jul 19:31:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
    2022-07-08 19:46:20.828  - warn: host.iobVM "system.host.raspberrypigas" is offline
    2022-07-08 19:46:20.845  - warn: host.iobVM "system.host.ioBroker3" is offline
    2022-07-08 19:55:07.934  - warn: influxdb.0 (494) Store data for 17 points and 0 conflicts
    2022-07-08 19:55:09.360  - warn: host.iobVM instance system.adapter.mqtt.0 terminated due to SIGTERM
    2022-07-08 19:55:15.594  - warn: host.iobVM "system.host.raspberrypigas" is offline
    2022-07-08 19:55:15.608  - warn: host.iobVM "system.host.ioBroker3" is offline
    2022-07-08 19:55:28.203  - warn: node-red.0 (1178) 8 Jul 19:55:28 - [warn] Projects disabled : editorTheme.projects.enabled=false
    Um 18:59 hatte ich ja neu gestartet.
    GlasfaserG Offline
    GlasfaserG Offline
    @tronland
    Zeige mal was du so hast ... das hast du oben nicht erwähnt !
    Ein/ und Ausgabe davon in Code-Tags </> hier einstellen
    cd /opt/iobroker
    npm ls | grep -E 'github.com|ERR'
    iobroker update -i
    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    • GlasfaserG Glasfaser
      @tronland
      cd /opt/iobroker
      iobroker update -i
      TronLand
      @glasfaser Der Fehler mit dem ookla repo kommt noch vom Adapter Speedtest.
      admin@iobVM:/opt/iobroker$ npm ls | grep -E 'github.com|ERR'
      ├── iobroker.life360@0.2.17 (git+ssh://git@github.com/migoller/iobroker.life360.git#fb48e5d206f904abaf7a464acb79eb0dfbab52ea)
      admin@iobVM:/opt/iobroker$ iobroker update -i
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "backitup"     : 2.4.9    , installed 2.4.9
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
      Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
      Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
      Adapter    "node-red"     : 3.3.1    , installed 3.3.1
      Adapter    "nut"          : 1.5.1    , installed 1.5.1
      Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "wireguard"    : 1.2.1    , installed 1.2.1
      Adapter    "withings"     : 0.0.9    , installed 0.0.7  [Updatable]
      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
      Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
      admin@iobVM:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
      [sudo] password for admin:
      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
      admin@iobVM:/opt/iobroker$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      i686
      /usr/bin/nodejs
      /usr/bin/node
      /usr/local/bin/npm
      v12.22.5
      v12.22.5
      8.5.2
      admin
      /opt/iobroker
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
      Err:3 https://ookla.bintray.com/debian generic InRelease
        Could not handshake: The TLS connection was non-properly terminated. [IP: 18.196.239.149 443]
      Hit:4 http://ftp.uni-stuttgart.de/debian bullseye InRelease
      Hit:5 https://dl.yarnpkg.com/debian stable InRelease
      Hit:6 http://ftp.uni-stuttgart.de/debian bullseye-updates InRelease
      Hit:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Reading package lists... Done
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      W: Failed to fetch https://ookla.bintray.com/debian/dists/generic/InRelease  Could not handshake: The TLS connection was non-properly terminated. [IP: 18.196.239.149 443]
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      nodejs:
        Installed: 12.22.5~dfsg-2~11u1
        Candidate: 12.22.5~dfsg-2~11u1
        Version table:
       *** 12.22.5~dfsg-2~11u1 500
              500 http://ftp.uni-stuttgart.de/debian bullseye/main i386 Packages
              500 http://security.debian.org/debian-security bullseye-security/main i386 Packages
      Thomas BraunT arteckA 2 Antworten Letzte Antwort
      • GlasfaserG Offline
        GlasfaserG Offline
        @tronland sagte in Proxmox VM friert ein:
        /usr/bin/nodejs
        usr/bin/node
        usr/local/bin/npm
        v12.22.5
        v12.22.5
        8.5.2
        und da ist der Fehler ...
        wie hast du das denn gemacht , da ist ja alles durcheinander
          /usr/bin/nodejs
          usr/bin/node
          usr/local/bin/npm
          v12.22.5
          v12.22.5
          8.5.2
          TronLand
          @glasfaser Wie meinst du das?
          • T TronLand
            GlasfaserG Offline
            GlasfaserG Offline
            @tronland
            das gehört nicht in local nur in bin und die 12 gehört nicht zu NPM 8
            • T TronLand
              GlasfaserG Offline
              GlasfaserG Offline
              @tronland
              Schau in die Signatur von @thomas-braun , wie man das behebt .
              Ist nur wieder verwunderlich wie man zu local kommt .
              wie hast du das gemacht !?
                @tronland
                TronLand
                @glasfaser: Hmm... Ich hatte vor langer Zeit mal das Problem, dass sich nodejs nicht aktualisieren ließ. Es kam immer, dass die neueste Version schon installiert wurde. Dann ein paar mal iob stop, iob update self , usw.
                Manuell hab' ich nichts gemacht.
                GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                • T TronLand
                  i686
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/local/bin/npm
                  v12.22.5
                  v12.22.5
                  8.5.2
                  admin
                  /opt/iobroker
                  nodejs:
                    Version table:
                  i386
                  Die VM ist auf die falsche Architektur eingestellt. Das sollte eine 64-bit-Umgebung sein. Dann würde auch node16 installierbar sein.
                  Die Zeile mit dem
                  Eintrag kannst du löschen, die Quelle gibt es nicht mehr.
                  • T TronLand
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Die Befehle haben aber nichts mit Nodejs / NPM zu tun , bzw. das es im local verzeichniss kommt !
                    • T TronLand
                      Doch, npm reingepflügt.
                      • T TronLand
                        GlasfaserG Offline
                        GlasfaserG Offline
                        sind diese beiden auch so struppelig !?
                          TronLand
                          @thomas-braun Oh Mist. Wie komm' ich denn auf die 32bit Version? Muss wohl verrutscht sein, als ich das Image ausgewählt habe.
                          Ich Idiot.
                          Okay, ihr habt mir superschnell geholfen! Vielen vielen Dank!!!!!
                          Ich denke, ich verbringe den Abend mit dem Aufsetzen einer neuen VM und dem Einspielen meiner Backups :-)
                          Ich kann mich echt nicht erinnern, dass ich npm installiert habe. Aber ist ja so.
                          Nochmals vielen vielen Dank für Eure Hilfe!!!
                          Viele Grüße aus Heidelberg!
                          Michael
                            TronLand
                            @glasfaser Eigentlich nicht. Das sind beides Raspberry Pi's. Hab' mit denen eigentlich keine Probleme.
                            Aber auf denen läuft nicht nicht die 64bit Version.
                            • T TronLand
                              Ich Idiot.
                              Michael
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Das wäre auch noch schneller gelaufen ... wenn du schon oben im Start-Thread mehr Infos gehabt hättest .
                              T Thomas BraunT 2 Antworten Letzte Antwort
                                TronLand
                                @glasfaser Ja, weiss ich jetzt auch. Nochmals sorry dafür.
                                • T TronLand
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  würde es aber trotzdem mal prüfen mit der Anfrage die ich oben gestellt habe !
                                  • T TronLand
                                    Bei den arm-basierten Geräten ist das (noch) nicht weiter wild, da wird noch das allermeiste auch für 32bit gebacken. i386 wird dahingegen schon geraume Zeit nicht mehr voll bedient.
                                      @glasfaser
                                      Im dritten Posting stand es drin:
                                      Debian VM Linux iobVM 5.10.0-14-686-pae
                                      Habs aber auch überlesen.
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @TT-Tom
                                        Warum bewertest du @crunchip Negativ !
                                        Ist doch erstmal eine Logisch vorgehensweise , wenn wir hier was benötigen !?
                                        T crunchipC 2 Antworten Letzte Antwort
                                          @TT-Tom
                                          TT-Tom
                                          @glasfaser
                                          War nicht mit Absicht, muss beim blättern passiert sein. Nehme ich gleich wieder zurück. Sorry
                                          Gruß Tom
                                          Public Transport
                                          NSPanel Adapter Wiki
