  4. VIS von Sigi234
    6.3k
VIS von Sigi234
ode abfragevisvis projekte
1.3k Beiträge 152 Kommentatoren 768.8k Aufrufe 202 Beobachtet
  • sigi234S sigi234
    @sushibomba sagte in VIS von Sigi234:
    @djmarc75
    Ok danke dir.
    Also ich möchte halt nicht so einen optischen Switch Schalter haben sondern nur ein Button wo ich drauf drücke und er es mir dann farblich anzeigt ob er an ist oder nicht.
    Z.B. grün der Hintergrund vom Button für an und rot oder grau bei aus.
    [{"tpl":"tplVis-materialdesign-Button-Toggle","data":{"oid":"yamaha.0.Realtime.MAIN.STRAIGHT","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"outlined","toggleType":"value","stateIfNotTrueValue":"off","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"valueOff":"Off","valueOn":"On","buttontext":"","image":"power-off","invertImageTrue":false,"iconHeight":"80","imageTrue":"power-on","labelTrue":"","labelWidth":"0","autoLockAfter":"10","lockFilterGrayscale":"30","textFontFamily":"{vis-materialdesign.0.fonts.button.text}","textFontSize":"{vis-materialdesign.0.fontSizes.button.text}","mdwButtonPrimaryColor":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.button.default.primary;dark:vis-materialdesign.0.colors.dark.button.default.primary; mode === \"true\" ? dark : light}","mdwButtonSecondaryColor":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.button.default.secondary;dark:vis-materialdesign.0.colors.dark.button.default.secondary; mode === \"true\" ? dark : light}","lockIconColor":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.button.lock_icon;dark:vis-materialdesign.0.colors.dark.button.lock_icon; mode === \"true\" ? dark : light}","imageTrueColor":"#46fd17","colorBgFalse":"#000000","colorBgTrue":"#24e203"},"style":{"left":"366px","top":"15px","width":"85px","height":"85px","z-index":"4"},"widgetSet":"materialdesign"}]
    Kannst du dir einstellen wie du willst.
    Sushibomba
    schrieb am zuletzt editiert von Sushibomba
    #1004
    @sigi234
    Vielen Dank aber ich hätte gerne es so wie deine Buttons wie für den "Input Wechsel"
    Also das soll ein View in Widget sein:
    yamaha soundmodis.txt
      Sushibomba
      #1005
      @sigi234
      Hast du eigentlich auch ne Programmzeitschrift als View?
      Habe das hier irgendwo schon mal gesehen, aber keine passende View dafür gefunden.
      Und hast du zufällig rausgefunden, warum die Ansteuerung der verschiedenen Internetradio-Sender nicht klappt aber die Tuner-Sender Auswahl funktioniert?
        Sushibomba
        #1006
        So mein kleines View in Widget ist nun auch fertig und funktioniert :)
        Jetzt klappt nur die Auswahl der Internetradio Streams noch nicht über das Dropdown-Menu.
        viw_yamaha.txt
        PS: Ich glaube ich weiß warum ich die Internet RadioSender nicht über das Dropdown anwählen kann.
        Ich haben den RX-A860 und soweit ich rausgefunden habe, habe ich zwar eine Favoritenliste aber keine Nummern die den jeweiligen Streams zugeordnet sind.
        Scheint es bei den neueren Receivern wohl nicht mehr zu geben. Warum auch immer.
        Hat jemand ne andere Idee welchen Datenpunkt ich anspielen muss dafür?
        Oder gibt es eine Möglichkeit die Möglichkeit die Befehle vom Yamaha auszulesen wenn ich es händisch auswähle?
        sigi234S bahnuhrB 2 Antworten Letzte Antwort
        • S Sushibomba
          viw_yamaha.txt
          sigi234S Online
          sigi234S Online
          #1007
          https://www.heimkino-praxis.de/yamaha-netzwerk-steuerung/
          • S Sushibomba
            viw_yamaha.txt
            bahnuhrB Offline
            bahnuhrB Offline
            bahnuhr
            #1008
            @sushibomba
            Kann deiner mussiccast.
            Wenn ja:
            mussiccast Adapter installieren.
            Favoriten im Yamaha benennen
            und dann den DP ...musiccast.0.xxxxx.netusb.presetrecallnumber den Favoriten steuern.
            Und in VIS mit dem entsprechenden mussiccast widget.
            sieht dann so aus:
            Danke.
            • bahnuhrB bahnuhr
              @sushibomba
              Wenn ja:
              sieht dann so aus:
              Sushibomba
              #1009
              @bahnuhr
              Klasse vielen Dank. Danke auch an @sigi234
              Allerdings bekomme ich es nicht hin die Favoriten Netradio Sender auf die jeweiligen Slots zu legen :(
              Kann mir da jemand noch weiterhelfen?
              @sigi234 Kurze andere Frage... Welches Widget nutzt du nochmal um Charts wie zum Beispiel bei deinem "Spritpreise" View anzuzeigen?
              -1
              • S Sushibomba
                @bahnuhr
                sigi234S Online
                sigi234S Online
                #1010
                Vis-materialdesign-Chart-Line-History
                Oder
                https://github.com/ioBroker/ioBroker.echarts
                • sigi234S sigi234
                  Oder
                  Sushibomba
                  #1011
                  @sigi234
                  Danke dir :)
                    Sushibomba
                    #1012
                    @sigi234
                    Hey Sigi ich habe mir jetzt mein View für die Spritpreise gebaut :)
                    Bin eigentlich sehr zufrieden nur wird der letzte Datensatz falsch angezeigt und ich weiß nicht wieso :(
                    Könntest du mal schauen ob due den Fehler der blauen Linie findest?
                    Es zeigt zwar die richtigen Werte an aber wird optisch zu hoch dargestellt. Heißt die Linie müsste bei den anderen unten verlaufen.
                    view_sprit_mitFehler.txt
                    • S Sushibomba
                      @sigi234
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #1013
                      @sushibomba Also wenn das ein Panel aus Grafana ist dann musst Du dort (in Grafana) mal nachsehen.
                      Glaub kaum dass @sigi234 da helfen kann weil das nix mit VIS zu tun hat. 😉
                      Lehrling seit 1975 !!!
                      • DJMarc75D DJMarc75
                        Sushibomba
                        #1014
                        @djmarc75
                        Ne ist kein Grafana Dashboard. Das ist der Adapter Echarts den er auch verwendet.
                        • S Sushibomba
                          @djmarc75
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          #1015
                          Dann eigentlich das selbe
                          @djmarc75 sagte in VIS von Sigi234:
                          EDIT: sorry @sigi234 ... bestimmt kannst Du da helfen aber wäre leicht OT
                            sigi234S Online
                            sigi234S Online
                            #1016
                            Ok, das wäre im E-Chart Beitrag besser aufgehoben.
                            • sigi234S sigi234
                              Sushibomba
                              #1017
                              @sigi234
                              OK und welchen Beitrag meinst du da genau?
                              Noch ne dumme Frage... Wenn ich auf meiner worx View eine Zeit eintragen möchte über das Tablet dann springt er immer in mein Yamaha View sobald die Tastatur auf dem Tablet aufgeht. Nutze den Filly Kiosk Browser und habe keine Ahnung warum er das macht. Ihr ne Idee?
                              • S Sushibomba
                                @sigi234
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #1018
                                Da solltest Du einen eigenen Thread aufmachen (richtige Kategorie auswählen aber vorher bitte die Suchfunktion nutzen obs da schon ne Lösung zu Deinem Problem gibt)
                                VORHER aber trotzdem in Deinem eCharts nochmal alles auf eventuelle Fehler prüfen. 😉
                                  Sushibomba
                                  #1019
                                  @djmarc75
                                  Ja habe ich gemacht. Eben bestimmt eine Stunde lang gesucht aber nichts gefunden.
                                  Bzgl. der Suchfunktion komme ich noch nicht so ganz klar hier. Habe noch nicht herausgefunden, wie ich z.b. nur in einem Thema/Threads wie diesem hier suche oder überall und dann evtl. nur in bestimmten Kategorien. Gibt's da irgendwo nen Anleitung hier fürs Forum?
                                  • S Sushibomba
                                    @djmarc75
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #1020
                                    in deinen Einstellungen " Suchen innerhalb von Themen aktivieren "
                                    siehe hier als Beispiel , wie ... :
                                    https://forum.iobroker.net/topic/4733/howto-iobroker-unter-docker-auf-synology-diskstation/2146
                                    EDIT :
                                    über den Forum Hilfe Button !
                                    • GlasfaserG Glasfaser
                                      EDIT :
                                      Sushibomba
                                      #1021
                                      @glasfaser
                                      Vielen Dank 🤗
                                        Sushibomba
                                        #1022
                                        @sigi234
                                        Versuche mir gerade meine Alexa View zusammen zu basteln.
                                        Wie hast du das mit den Playlist gemacht? Also wo lege ich die an und wie bekomme ich dann diese Logos da rein von den Sendern? Zieht er sich das automatisch?
                                        • S Sushibomba
                                          @sigi234
                                          sigi234S Online
                                          sigi234S Online
                                          #1023
                                          @sushibomba
                                          Welche View genau?
