  4. Alexa2 Adapter 3.13/3.14/3.15/3.16/3.17 (Beta)
391 Beiträge 39 Kommentatoren 86.9k Aufrufe 38 Beobachtet
  • apollon77A Offline
    So, damit Euch nicht langweilig wird hier das nächste Alexa2 Featurepack, aka 3.14.0, welches demnächst im Repo autuchen sollte.
    Changelog:
    • (Apollon77) Allow to define if Lists and Smart home devices are synced by the adapter with the Amazon Cloud at all
    • (Apollon77) Enhance Smart Home Device support by adding various controllers and states. If in your Alexa App something is configurable which is not in ioBroker please send a debug log!
    • (Apollon77) Re-Introduce the ability to poll smart home device states in intervals, but only devices are queried that report their status proactively to Amazon-Cloud to prevent Skill developer costs! ioBroker (and OpenHab) devices are NOT queried! The interval can be configured but must not be lower than 60s! Querying is disabled by default.
    • (Apollon77) Add message to send out sequences of commands to alexa devices
    • (Apollon77) Add Info states for macAddress and WifiSSID of the Alexa devices
    • (Apollon77) Add several new states for Player for allowed actions, medium quality
    • (Apollon77) Add mediaId and also allow to set it to jump to a defined entry in the playlist
    • (Apollon77) Add Commands.sound to play a sound
    • (Apollon77) Do not set the speak-volume when executing textCommand and deviceStop
    • (Apollon77) Do not set speak-volume if the volume is already as wanted when executing commands
    • (Apollon77) update Do-Not-Disturb status once on start and with device configuration updates
    • (Apollon77) Allow to specify the title in notification commands
    • (Apollon77) When a device plays music in a group then new states in "Player"will indicate this together with the group ID
    • (Apollon77) Allow to enable and disable smart home devices - this will be synced together with the smart home state updates from the cloud if changed in the app!
    • (Apollon77) Detect Rate limit exceeded response and do one automatic request retry 10s later (plus a random part)
    • (Apollon77) Slow down the update of player status to prevent rate limit exceeded errors. initial update of the player states is delayed on startup of the adapter
    • (Apollon77) Restore character replacement for Music providers (space is now again a "-")
    • (Apollon77) Add more devices
    • (Apollon77) Optimize startup and unload handling
    Wer mit der 3.13. Probleme hatte bitte die 3.14.0 nehmen wenn es darum geht Logs zu erzeugen.
    • apollon77A apollon77
      Changelog:
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @apollon77 BIsher läuft das Teil super ABER:
      irgendwie ist mir das in den Objekten unter EchoDevices, wenn man APP-Devices in der Konfig aktiviert, sehr unschlüssig weil:
      Was hat das mit den vielen, vielen Ordnern auf sich?
      Werd da no net so schlau draus. Hab auf 2 Phones die APP und an 2 PC, mehr eigentlich nicht.
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        @djmarc75 Tja, diese Frage musst Du Amazon stellen ... Das war der grund warum App Devices bisher ausgeblendet waren (und es im Default auch sind) ... Ja wenn man weiss was davon genau seine Handy App ist kann man da ggf auch Kommandos ausführen :-)
        • FlexerF Offline
          FlexerF Offline
          Flexer
          schrieb am zuletzt editiert von Flexer
          @apollon77 Idee bzw Frage. Gibt es einen Datenpunkt um Alexa zum Zuhören zubewegen.
          Fiktives Beispiel
          Alexa: Mach das Licht heller —> Trigger Alexa hört zu —> Auf wieviel Prozent soll ich das Licht einstellen?
          80% —> Licht wird auf 80% gestellt.
          Man könnte so ein Gespräch bauen.
          Grüsse
          Unterm Strich ist alles besser.
          Ja, voll geil hier!
          BananaJoeB apollon77A 2 Antworten Letzte Antwort
          • FlexerF Flexer
            Fiktives Beispiel
            Grüsse
            BananaJoeB Offline
            BananaJoeB Offline
            BananaJoe
            @flexer sagte in Alexa2 Adapter 3.13.0 (Beta):
            Fiktives Beispiel
            Grüsse
            Wenn du etwas im Forum suchst:
            • Entweder eigener Skill bei Amazon
            • du greifst das alexa2.0.History.summary Feld ab und unterdrückst die Fehlermeldungen / meckern von Alexa
            • FlexerF Flexer
              Fiktives Beispiel
              Grüsse
              @flexer leider „was bananajoe sagt“ … Bzw. Man kann an sich auch skills starten. Dann könnte etwas über custom skill von iobroker gehen. Dann kommen die Texte im
              Iot Adapter Bzw Text2command an … und man könnte Skripten.
              Wäre dann Sondas was passiert was den skill triggert und dann sagt Madame: „hallo, was möchtest du wissen oder steuern?“ und hört zu.
                Marty56
                schrieb am zuletzt editiert von Marty56
                @apollon77
                Ich bekomme eine Warnung mit der 3.13.0
                State "alexa2.0.Echo-Devices.25F271CC81A045A7B2FD9AE6C925CEF0.Preferences.ringNotificationsEnabled" has no existing object, this might lead to an error in future versions
                Es gibt aber kein Device mit der Kennung "25F271CC81A045A7B2FD9AE6C925CEF0".
                Die Warnung bekomme ich zweimal. Das zweite Mal mit einer anderen Kennung, bei der es auch kein zugehöriges Echo gibt.
                HW:NUC (16 GB Ram)
                OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                • M Marty56
                  @apollon77
                  @marty56 Das habe ich auch. Hab mal ein issue dazu aufgemacht:
                  https://github.com/Apollon77/ioBroker.alexa2/issues/911
                    @thomas-braun Fix kommt in die nächste Verison
                      Hi All,
                      heute gibt mal ein lang ersehntes Update von Alexa2 auf die 3.13.0 (und am 6.7. auf 3.14.0 und am 9.7. auf 3.15.0) im beta Repo. Sollte im laufe des Tages bei allen auftauchen.
                      Primär sollten die User die wegen komischen Family-Account-Konstellationen Probleme mit der 3.12 hatten jetzt mit der 3.13 wieder keine Probleme haben. Erstes GitHub Feedback legt dies zumindestens nahe.
                      User die viele Geräte haben und daher Kommandos an Gruppen immer nur Teileise ausgeführt wurden sollten mit der 3.13 auch weniger Issues haben weil jetzt nicht mehr ein Request pro Gerät sondern nur einer für alles gemacht wird - sollte damit keine "Rate Limit" Fehler mehr geben.
                      Weiterhin geht das aufrufen von TuneIn Station- und Topic-IDs wieder.
                      Wer GitHub Issues erstellt hatte die jetzt gelöst sind bitte schliesen bzw kommentieren (auch wenn schon geschlossen).
                      Das folgende ist der komplette Changelog der 3.13:
                      • IMPORTANT List Names are now checked for invalid characters and replaced. Might change the name of objects in ioBroker. Old ones need to be deleted manually!
                      • (Apollon77) Fix command sending in multi owner environments (e.g. Family shared devices)
                      • (Apollon77) Add some new devices
                      • (ammawel) Add the date of an alarm as state, not only time
                      • (Apollon77) Add option to also query the App Devices to allow to send commands to them
                      • (Apollon77) Rework Multiroom for commands to prevent rate limiting issues!
                      • (Apollon77) Fix Routine Naming if triggers were used
                      • (Apollon77) Support devices with "Ziggy" as wake word
                      • (Apollon77) All commands with voice output respect the defined speak-volume now
                      • (Apollon77) Allow again to directly enter TuneIn station Ids (s*) and topicIds (t*)
                      • (Apollon77) Add media states to show remaining time of media playback
                      • (simatec) Adjust link color im Admin configuration
                      • (Apollon77) Some requests are automatically retried with a slight delay if Amazon responds with error 503
                      Changelog der 3.14:
                      Changelog der 3.15:
                      • (Apollon77) IMPORTANT: Format to specify multiple Details on "New" for Alarms and Reminders changed, see documentation!
                      • (Apollon77) Add Alarm/Reminder triggered state per device which will contain the ID of the alarm that got triggered when it is triggered
                      • (Apollon77) Add several more fields for Alarms and Reminders to show better the details of the alarm
                      • (Apollon77) Allow to cancel Reminders and Alarms as in the Alexa App
                      • (Apollon77) Allow to also edit Alarm/Reminder Dates additionally to the times
                      • (Apollon77) Allow to set a custom Volume for Reminders and Alarms - it will be set 2s before the expected trigger and restored afterwards
                      • (Apollon77) Calculate the "nextTriggerDate" as Timestamp of next expected triggering
                      • (Apollon77) Add a JSON-Array with all running timers and the "next id" as state
                      • (Apollon77) Allow to stop a timer by ID
                      • (Apollon77) Add the days-list of Alarms when configured for recurrency
                      • (Apollon77) Add new Commands skill and skillYours to start Skills
                      • (Apollon77) Add Notification volume, Ascending Alarm setting and default notification sounds as preferences
                      • (Apollon77) Slow down the initialization of all data a bit, so startup could take longer
                      3.16.0 ist auf dem Weg:
                      • (Apollon77) Add (official) support for Music-Alarms - they are now listed under "Alarms" together with the other Alarms! The "sound" list will contain the device specific music targets - so you can basically zse the ones that you created at least once via voice commands.
                      • (Apollon77) For a Music Alarm the "customVolume" on the alarm is used to set the normal device volume 2s before the alarm but do not (!) reset it afterwards
                      • (Apollon77) Prevent crashes on one time Alarms that just triggered
                      3.17.1 bringt noch dazu:
                      • (Apollon77) Add support to play Audible books in Music-Providers
                      • (Apollon77) Optimize deletion of alarms and reminders
                      • (Apollon77) Optimize requesting smart home device data
                      • (Apollon77) Work around timing issues with speak-volume when using announcement
                      • (Apollon77) Correctly initialize volume/mute on startup also when player data are not available
                      • (Apollon77) Do not overwrite speak-volume (and some other fields) with null on adapter start
                      • (Apollon77) Fix crash cases reported by Sentry
                      Viel Spass beim testen und Danke für Euer Feedback!
                      Ingo
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      @apollon77 sagte in Alexa2 Adapter 3.13.0 (Beta):
                      Könnte man den Wert statt null auch leer lassen wenn gerade keine Musik über eine Gruppe läuft?
                      null macht mir gerade in javis v2 bissel Probleme bei der gewünschten Darstellung.
                      ..:: So long! Tom ::..
                      • DiginixD Diginix
                        @diginix ja generell geht das ... Was macht jarvis denn bei "null"?
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          @apollon77 Der zeigt im Frontend dann false an. Wenn ich es aber per JSON umschreiben will, funktioniert das alles nicht:
                            "null": "",
                            "false": "",
                            "default": "",
                            "12346d9a33674943a2f4baac27a0fa48": "Wohnung",
                            "1234925d014243fab4cd04b9b28f7373": "Überall"
                          Ich möchte im Frontend kein Text solange keine echte GroupID als Wert im Objekt alexa2..Echo-Devices..Player.playingInGroupId steht.
                          Edit: Konnte es zu einem "echten" false über jarvis Datenpunkt Eigenschaften (JSON Format) umschreiben:
                            "value": "val => val == null ? false : val"
                          Dadurch greift dann wiederum die Regel aus Anzeigevariante (JSON Format)
                          Also kein Anpassungsbedarf mehr von meiner Seite.
                            DiginixD Offline
                            DiginixD Offline
                            Diginix
                            Ich sehe schon immer die Smartphones mit der Alexa App als Echo Device:
                            Auch ohne die neue Einstellung aktiviert zu haben. Kann es sein, dass App Devices wie im Bild von @DJMarc75 hier noch was anderes als Smartphones mit der Alexa App sind?
                            • DiginixD Diginix
                              @diginix Ja, Nein,. Vllt ... Gibt mehrere "Device-t<pen" die man Apps zuordnen kann ... wir haben einen bestimmten Typ ausgeblendet ...
                              Ich kapiere eh net was bei Amazon manchmal was warum ist :-)
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                @apollon77 Ok, ich lass den Haken vorerst mal aus weil ich mir von den weiteren nichts erhoffe.
                                Ich hoffe du hast bald Zeit für iot v3 und vielen neuen Gerätetypen darin. ;-)
                                • DiginixD Diginix
                                  @diginix sagte in Alexa2 Adapter 3.13.0 (Beta):
                                  Ich arbeite gerade alle Themen ab die davor auf meiner Liste stehen :-) Alexa2 Update war eins davon
                                    DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    @apollon77 alexa2.*.Echo-Devices.*.Commands.doNotDisturb ist bei mir gerade schreibend bei allen meinen Echo Dot funktionslos mit v3.14.0. DND lässt sich darüber also nicht steuern. Der Wert stimmt aber wenn man DND per App oder Stimme beim Echo setzt.
                                    Im normalen Log ist nichts zu sehen.
                                    Wieso ist der Datentyp eigentlich "mixed" und nicht boolean?
                                    • DiginixD Diginix
                                      @diginix Auch wenn fast keine Details in dieser meldung waren hab ich glaube ich was gefunden. Fix kommt in nächster Version
                                        So, und damit der Samstag Nachmittag nicht so langweilig wird hier ein paar neue Spielereien ... Kommt demnächst im Repo
                                        Featurepack #3 im Moment für Alexa2 - der Fokus dieses mal sollte auch schnell klar sein :-)
                                        Changelog der 3.15: -> 3.15.1 ist aktuelle Version
                                        F R 2 Antworten Letzte Antwort
                                          Flugschüler
                                          @apollon77 Bei der neuesten version funktionieren bei mir die Commands nicht mehr.
                                          DJMarc75D apollon77A 2 Antworten Letzte Antwort
