    apollon77A
5.8k Beiträge 156 Kommentatoren 5.1m Aufrufe 138 Beobachtet
  • R Rushmed
    Ich bekomme beim Statistik Script keine Daten.
    Im Log steht zur Startzeit:
    2022-06-27 01:03:00.027 - info: javascript.0 (1073232) script.js.Wetter.Wetterstation_Statisitk: Auswertung durchgeführt...
    2022-06-27 01:03:00.045 - warn: influxdb.0 (845) Error in query "select * FROM "0_userdata.0.Wetterstation.Aussentemperatur" WHERE time >= 1656194400000000000 AND time <= 1656280799000000000": HttpError: error @1:1-1:7: undefined identifier select
    error @1:10-1:14: undefined identifier FROM
    error @1:61-1:66: undefined identifier WHERE
    error @1:67-1:71: (v: A) => time (function) is not Equatable
    error @1:67-1:71: (v: A) => time (function) is not Comparable
    error @1:95-1:98: undefined identifier AND
    error @1:99-1:103: (v: A) => time (function) is not Equatable
    error @1:99-1:103: (v: A) => time (function) is not Comparable
    2022-06-27 01:03:00.069 - warn: influxdb.0 (845) Error in query " select * FROM "0_userdata.0.Wetterstation.Wind_max" WHERE time >= 1656194400000000000 AND time <= 1656280799000000000": HttpError: error @1:2-1:8: undefined identifier select
    error @1:11-1:15: undefined identifier FROM
    error @1:54-1:59: undefined identifier WHERE
    error @1:60-1:64: (v: A) => time (function) is not Equatable
    error @1:60-1:64: (v: A) => time (function) is not Comparable
    error @1:88-1:91: undefined identifier AND
    error @1:92-1:96: (v: A) => time (function) is not Equatable
    error @1:92-1:96: (v: A) => time (function) is not Comparable
    2022-06-27 01:03:00.078 - warn: influxdb.0 (845) Error in query " select * FROM "0_userdata.0.Wetterstation.Regen_Tag" WHERE time >= 1656194472000000000 AND time <= 1656280799000000000": HttpError: error @1:2-1:8: undefined identifier select
    error @1:55-1:60: undefined identifier WHERE
    error @1:61-1:65: (v: A) => time (function) is not Equatable
    error @1:61-1:65: (v: A) => time (function) is not Comparable
    error @1:89-1:92: undefined identifier AND
    error @1:93-1:97: (v: A) => time (function) is not Equatable
    error @1:93-1:97: (v: A) => time (function) is not Comparable
    2022-06-27 01:03:00.080 - error: influxdb.0 (845) queries: Error: 3 Error happened while processing 3 queries
    2022-06-27 01:03:00.085 - error: javascript.0 (1073232) script.js.Wetter.Wetterstation_Statisitk: Fehler beim Lesen der InfluxDB: Invalid call
    2022-06-27 01:03:00.086 - warn: javascript.0 (1073232) States system pmessage io.messagebox.system.adapter.javascript.0 {"command":"query","message":{"result":[],"error":"Invalid call"},"from":"system.adapter.influxdb.0","callback":{"message":"select * FROM \"0_userdata.0.Wetterstation.Aussentemperatur\" WHERE time >= 1656194400000000000 AND time <= 1656280799000000000; select * FROM \"0_userdata.0.Wetterstation.Wind_max\" WHERE time >= 1656194400000000000 AND time <= 1656280799000000000; select * FROM \"0_userdata.0.Wetterstation.Regen_Tag\" WHERE time >= 1656194472000000000 AND time <= 1656280799000000000","id":1,"ack":true,"time":1656284580026},"_id":29058831} Reduce of empty array with no initial value
    2022-06-27 01:03:00.373 - warn: javascript.0 (1073232) TypeError: Reduce of empty array with no initial value
    at Array.reduce ()
    at Object.cb (script.js.Wetter.Wetterstation_Statisitk:175:43)
    at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5809:71)
    at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:322:37)
    at processImmediate (node:internal/timers:466:21)
    Aber prinzipiell läuft das Script.
    Was mach ich denn da wieder falsch?
    SBorgS
    SBorgS
    SBorg
    #3830
    @rushmed Hmm, der kann mit keiner Abfrage mehr was anfangen. An einem Update (zB. Influx-Adapter etc.) kann es nicht liegen, ich bin auf latest und damit läuft es aktuell problemlos.
    Deine Influx-DB ist aber noch V1?
    LG SBorg ( SBorg auf GitHub)
    R 1 Antwort Letzte Antwort
    • BoronsbruderB Boronsbruder
      @rushmed said in [Linux Shell-Skript] WLAN-Wetterstation:
      @SBorg ich würde sagen, dass das ein Tippfehler ist. Es muss SELECT anstatt select heissen, oder?
      (Zeile 157-159 und 407-409)
                  'select * FROM "' + WET_DP + '.Aussentemperatur" WHERE time >= ' + (start *1000000) + ' AND time <= ' + (end *1000000)
                   + '; select * FROM "' + WET_DP + '.Wind_max" WHERE time >= '  + (start *1000000) + ' AND time <= ' + (end *1000000)
                   + '; select * FROM "' + WET_DP + '.Regen_Tag" WHERE time >= ' + ((start+72000) *1000000) + ' AND time <= ' + (end *1000000)
      SBorgS
      SBorgS
      SBorg
      #3831
      @boronsbruder sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      Eigentlich nicht. Zum einen funktioniert(e) es bisher (zumindest aktuell bei mir noch; hat sich auch noch kein anderer beschwert ;) ), zum anderen, auch wenn es durch das WHERE, AND, FROM... so aussieht, ist das Ganze nicht case sensitiv. Reine Optik zur besseren Lesbarkeit :)
      • T tritor
        @boronsbruder
        ich glaube ich hab es hinbekommen:
        das war es zuvor:
        systemctl cat wetterstation.service | grep Group
        Group=ioobroker
        geändert auf:
        Group=iobroker
        Wie die Group auf ioobroker geändert wurde kann ich nicht nachvollziehen.
        Daten werden nurn wieder übertragen - sehe das am Temperaturlogging.
        Nur mit einigen Datenpunkten habe ich noch Probleme:
        Druck_Tendenz: -1018 ((wird in rot angezeigt)
        Wetter_Trend: Sturm mit Hagel (wird in rot angezeigt)
        Wetter_aktuell: leer
        SBorgS
        SBorgS
        SBorg
        #3832
        @tritor sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        Hat sich das mittlerweile erledigt? Da hat es wohl noch die temporären Daten etwas zerbröselt. Sollte sich aber nach ~3 Stunden Daten sammeln wieder selbst regulieren.
        • S speedy
          ich würde das Script auch gerne nutzen.
          Influxdb läuft -> Version 1.x -> Adapter 2.6.3
          Grafana läuft auch
          Probleme habe ich mit dem Script.
          • Datenpunkte wurden angelegt
          • Wetterstation Sainlogic WS3500 (ioBroker meint: WS2900_V2.01.18)
          Ausgabe bei:
          ./wetterstation.sh --debug
          Debug VAR:
          Installationsverzeichnis: /home/iobroker
          IPP: 192.168.xxx.xxx:8087   WS_PORT: 9999           WS_POLL: 20             PRE_DP: javascript.0.Wetterstation
          WEB: HTTP               WS_PROT: Wunderground   DP35/40/50/60/70/100/200/250/300: 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0
          WH31: 0
          Script-Version: V2.14.0 Config-Version: V2.14.0 Sub-Version: V2.14.0
          Kommunikationsfehler!
          Kommunikationsfehler! Stimmt die WS_ID in der Konfiguration mit der der WS View-App überein?
          In der WS View App wurden folgende Einstellungen vorgenommen:
          IP-Adresse, Station-ID sowie Key stimmen überein.
          Snifft das Script die Daten mit, oder sollte es diese von der Wetterstation aktiv abholen?
          Über eine Hilfe wäre ich dankbar.
          SBorgS
          SBorgS
          SBorg
          #3833
          @speedy sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          Moin, ja und nein. Das Skript "hört" nur auf das was das Display/Gateway sendet.
          Pauschal würde ich "Ecowitt" als Protokoll vorziehen. Hat einfach mehr Daten (zB. den Batteriestatus).
          Bei deinem aktuellen "Wunderground"-Protokoll ist der Pfad in der App falsch. Der muss /weatherstation/updateweatherstation.php? lauten.
          "Pfad" ist da etwas unglücklich seitens der App gewählt, es handelt sich hier um einen Teil einer URL ;)
          • SBorgS SBorg
            T
            T
            tritor
            schrieb am zuletzt editiert von tritor
            #3834
            @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
            leider nicht, dachte auch, daß sich die Daten über Nacht wieder finden, aber leider noch immer dasselbe Szenario.
            Gernot
            Host: i9 server Proxmox , Debian 13.4 for ioBroker
            ioBroker: 8.0.20, Node.js: 22.23.2, NPM: 10.9.8,
            Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.6
            Grafana 13.1.1 / InfluxDB 2.9.1
            SBorgS T 2 Antworten Letzte Antwort
            • T tritor
              SBorgS
              SBorgS
              SBorg
              #3835
              @tritor Das wird so auch aktuell nichts mehr werden. Dein DP "Wetterdaten" ist leer. Da müssten die letzten 15 Luftdruckwerte drin stehen. Deswegen stimmen die anderen drei Werte nicht.
              Stoppe den Service mal, warte eine Minute, dann starte ihn nochmal. Jetzt sollte eigentlich bei "Wetterdaten" 15 14 13 .... 3 2 1 stehen. Dann sollte jede 15 Minuten eine Zahl durch einen aktuellen Luftdruckwert ersetzt werden und nach ~ 3 Stunden alles wieder laufen.
              • SBorgS SBorg
                R
                R
                Rushmed
                #3836
                @sborg Nein die ist V2. Ich dachte mit V2 gehts nur nicht so richtig gut.
                Funktioniert das Statistik Script mit Influx V32 garnicht mehr?
                • SBorgS SBorg
                  T
                  T
                  tritor
                  #3837
                  @sborg
                  genauer Inhalt des DP ist: 12 11 10 9 8 7 6 5 4 3 2 1
                  Hoffe das passt so.
                  Gernot
                  • R Rushmed
                    SBorgS
                    SBorgS
                    SBorg
                    #3838
                    @rushmed Leider nicht, da haben sich die Abrufe für die Datenbank geändert und ohne Daten gibt es leider auch (so gut) wie keine Werte.
                    Die V2 hat leider noch immer einige (für mich) maßgebliche Nachteile. Ich will auch nicht jetzt pauschal alle Nutzer zwingen die V2 zu nutzen, deswegen müsste ich eigentlich beides supporten/unterstützen. Das ist aber nicht gerade trivial und zeitaufwändig. Gerade Zeit habe ich aktuell wenig, sehe aber wenigstens schon den Tunnel am Ende des Lichtes oder wie das war ^^
                    • T tritor
                      @sborg
                      Hoffe das passt so.
                      SBorgS
                      SBorgS
                      SBorg
                      #3839
                      Hoffe das passt so.
                      :) wenn man rechnen kann...
                      3h x 4 (alle 15 Minuten pro Stunde) = 12 Werte (und nicht 15)
                      Passt also alles und hat sich in rund 3 Stunden erledigt ;)
                      • SBorgS SBorg
                        Hoffe das passt so.
                        T
                        T
                        tritor
                        #3840
                        @sborg
                        leider nicht ganz bei mir.
                        hab gerade den DP geprüft und nun ist er wieder leer:
                        und Wetter_aktuell, Wetter_Trend und Luftdruck_Tendenz sehen wie im obigen Post aus.
                        Scheint mir so, als werden die Wetterdaten nur 1x übertragen.
                        Gernot
                        • T tritor
                          @sborg
                          SBorgS
                          SBorgS
                          SBorg
                          #3841
                          @tritor Ich habe eben noch mal oben deinen Debug angeschaut, da ist alles Ok. Wenn er es 1x korrekt überträgt muss es auch mehrmals funktionieren und ganz leer darf es eigentlich auch nie werden.
                          Ev. (wg. der Group etc.) läuft es doppelt. Was zeigt den ein ps -auxww|grep wetter ?
                          Da sollte es nur 2x auftauchen:
                          • SBorgS SBorg
                            T
                            T
                            tritor
                            #3842
                            gfaigel@ioBroker-prox:~$ ps -auxww|grep wetter
                            iobroker  6322  0.0  0.0   8024  2960 ?        S    12:47   0:00 /bin/bash /home/iobroker/wetterstation.sh
                            gfaigel   6332  0.0  0.0   6084   880 pts/0    S+   12:48   0:00 grep wetter
                            iobroker  7376  0.1  0.0   8024  4716 ?        Ss   10:36   0:12 /bin/bash /home/iobroker/wetterstation.sh
                            Gernot
                            • T tritor
                              SBorgS
                              SBorgS
                              SBorg
                              #3843
                              @tritor "Leider" alles gut. Ändert sich denn Solarenergie und Sonnenschein?
                              Nutzt du History? Falls ja, kannst du mal paar Stunden die "Wetterdaten" aufzeichnen wer da was schreibt?
                              ...weil ich aktuell etwas ratlos bin. Rechte & Co. können es nicht sein, dann würde fast nichts gehen...
                              "Wetter_aktuell, Wetter_Trend und Luftdruck_Tendenz" sind zwar falsch, können aber erst funktionieren wenn die "Wetterdaten" wieder korrekt vorliegen (also Haken dran machen, dass ist nicht die Ursache, sondern eine Auswirkung des Fehlers).
                              • SBorgS SBorg
                                T
                                T
                                tritor
                                #3844
                                @sborg
                                Solarenergie und Sonnenschein ändern sich.
                                Ich logge das im Moment mal mit influx um ein paar Daten zu haben.
                                So, hier nun ein paar Daten:
                                Wetterdaten:
                                timestamp;value;acknowledged;from;
                                2022-06-28T12:45:02.186Z;1020 1020 1019 1019 1019 1019 1019 1019 1019 1019 1019 1019;true;simple-api.0
                                2022-06-28T13:00:17.138Z;1020 1019 1019 1019 1019 1019 1019 1019 1019 1019 1019 1018;true;simple-api.0
                                2022-06-28T13:15:27.466Z;1019 1019 1019 1019 1019 1019 1019 1019 1019 1019 1018 1018;true;simple-api.0
                                2022-06-28T13:30:15.894Z;1019 1019 1019 1019 1019 1019 1019 1019 1019 1018 1018 1018;true;simple-api.0
                                2022-06-28T13:45:07.242Z;1019 1019 1019 1019 1019 1019 1019 1019 1018 1018 1018 1018;true;simple-api.0
                                2022-06-28T14:00:27.143Z;1019 1019 1019 1019 1019 1019 1019 1018 1018 1018 1018 1017;true;simple-api.0
                                2022-06-28T14:15:13.425Z;1019 1019 1019 1019 1019 1019 1018 1018 1018 1018 1017 1017;true;simple-api.0
                                2022-06-28T14:30:16.698Z;1019 1019 1019 1019 1019 1018 1018 1018 1018 1017 1017 1017;true;simple-api.0
                                Solarenergie:
                                2022-06-28T12:35:44.659Z;4369.355 4460.693 4460.693 4460.693;true;influxdb.0
                                2022-06-28T12:35:58.045Z;4376.216 4467.554 4467.554 4467.554;true;simple-api.0
                                2022-06-28T12:36:29.884Z;4381.589 4472.927 4472.927 4472.927;true;simple-api.0
                                2022-06-28T12:37:01.940Z;4385.993 4477.331 4477.331 4477.331;true;simple-api.0
                                2022-06-28T12:37:38.644Z;4390.530 4481.868 4481.868 4481.868;true;simple-api.0
                                2022-06-28T12:38:05.640Z;4394.070 4485.408 4485.408 4485.408;true;simple-api.0
                                2022-06-28T12:38:42.151Z;4399.517 4490.855 4490.855 4490.855;true;simple-api.0
                                Sonnenschein:
                                2022-06-28T12:36:07.885Z;25988 26174 26174 601386;true;influxdb.0
                                2022-06-28T12:36:29.738Z;26020 26206 26206 601418;true;simple-api.0
                                2022-06-28T12:37:01.798Z;26052 26238 26238 601450;true;simple-api.0
                                2022-06-28T12:37:38.507Z;26089 26275 26275 601487;true;simple-api.0
                                2022-06-28T12:38:05.495Z;26116 26302 26302 601514;true;simple-api.0
                                2022-06-28T12:38:42.003Z;26152 26338 26338 601550;true;simple-api.0
                                Jetzt scheint alles wieder im Tritt zu sein:
                                Ich werd's mal weiter beobachten.
                                Ich habe es nun über einige Stundne beobachtet. Die Daten werden zwar in den DP geschrieben, lt. influx eben alle 15 Minuten, aber die Daten
                                bleiben nicht im Datenpunkt erhalten. Aus welchem Grund auch immer, verschwinden die Daten nach einiger Zeit.
                                Anbei ein Log vom simple Adapter:
                                2022-06-28 22:00:25.029 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Innentemperatur","val":29.61}
                                2022-06-28 22:00:25.029 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Aussentemperatur","val":26.27}
                                2022-06-28 22:00:25.029 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Taupunkt","val":17.34}
                                2022-06-28 22:00:25.029 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Gefuehlte_Temperatur","val":26.27}
                                2022-06-28 22:00:25.030 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Innenfeuchtigkeit","val":49}
                                2022-06-28 22:00:25.030 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Aussenfeuchtigkeit","val":58}
                                2022-06-28 22:00:25.030 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Wind","val":0}
                                2022-06-28 22:00:25.030 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Wind_max","val":0}
                                2022-06-28 22:00:25.030 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Windrichtung","val":23}
                                2022-06-28 22:00:25.030 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Druck_absolut","val":992.92}
                                2022-06-28 22:00:25.031 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Druck_relativ","val":1016.63}
                                2022-06-28 22:00:25.031 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Regenrate","val":0}
                                2022-06-28 22:00:25.031 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Regen_Tag","val":0.7}
                                2022-06-28 22:00:25.031 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Regen_Woche","val":0.7}
                                2022-06-28 22:00:25.031 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Regen_Monat","val":151.6}
                                2022-06-28 22:00:25.032 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Regen_Jahr","val":199.6}
                                2022-06-28 22:00:25.032 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Sonnenstrahlung","val":0}
                                2022-06-28 22:00:25.032 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.UV_Index","val":0}
                                2022-06-28 22:00:25.032 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Zeitstempel","val":"28.06.2022 22:00:21"}
                                2022-06-28 22:00:25.032 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Info.FW_Version","val":"EasyWeatherV1.6.4"}
                                2022-06-28 22:00:25.032 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Info.Station_Batteriestatus","val":0}
                                2022-06-28 22:00:25.033 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Windboeen_max","val":42.16}
                                2022-06-28 22:00:25.033 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Regen_Event","val":0}
                                2022-06-28 22:00:25.033 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Regen_Stunde","val":0}
                                2022-06-28 22:00:25.033 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Info.Wetterstation_Gateway","val":"HP1000SE-PRO_Pro_V1.6.9"}
                                2022-06-28 22:00:25.033 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.1.Bodenfeuchtigkeit","val":62}
                                2022-06-28 22:00:25.033 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.2.Bodenfeuchtigkeit","val":42}
                                2022-06-28 22:00:25.034 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.3.Bodenfeuchtigkeit","val":45}
                                2022-06-28 22:00:25.034 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.4.Bodenfeuchtigkeit","val":0}
                                2022-06-28 22:00:25.036 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.5.Bodenfeuchtigkeit","val":45}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.1.Batterie","val":1.3}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.2.Batterie","val":1.3}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.3.Batterie","val":1.1}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.4.Batterie","val":1.3}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.DP100.5.Batterie","val":1.1}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Regenstatus","val":"kein Regen"}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.UV_Belastung","val":"keine"}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Windrichtung_Text","val":"NNO"}
                                2022-06-28 22:00:25.037 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Info.Hitzeindex","val":27.13}
                                2022-06-28 22:00:25.057 - debug: simple-api.0 (1332) POST-setBulk: body = javascript.0.Wetterstation.Wetter_Trend=gleichbleibend&javascript.0.Wetterstation.Druck_Tendenz=0&javascript.0.Wetterstation.Wetter_aktuell=wechselhaft&javascript.0.Wetterstation.tempData.Wetterdaten=1017 1017 1017 1017 1017 1017 1017 1017 1016 1016 1016 1017&ack=true
                                2022-06-28 22:00:25.057 - debug: simple-api.0 (1332) POST-setBulk: values = {"user":"system.user.admin","pass":"","javascript.0.Wetterstation.Wetter_Trend":"gleichbleibend","javascript.0.Wetterstation.Druck_Tendenz":"0","javascript.0.Wetterstation.Wetter_aktuell":"wechselhaft","javascript.0.Wetterstation.tempData.Wetterdaten":"1017 1017 1017 1017 1017 1017 1017 1017 1016 1016 1016 1017"}
                                2022-06-28 22:00:25.057 - debug: simple-api.0 (1332) 0: "javascript.0.Wetterstation.Wetter_Trend"
                                2022-06-28 22:00:25.057 - debug: simple-api.0 (1332) 1: "javascript.0.Wetterstation.Druck_Tendenz"
                                2022-06-28 22:00:25.057 - debug: simple-api.0 (1332) 2: "javascript.0.Wetterstation.Wetter_aktuell"
                                2022-06-28 22:00:25.058 - debug: simple-api.0 (1332) 3: "javascript.0.Wetterstation.tempData.Wetterdaten"
                                2022-06-28 22:00:25.058 - debug: simple-api.0 (1332) POST-setBulk for id=javascript.0.Wetterstation.Wetter_Trend, oid=Wettertrend, used=javascript.0.Wetterstation.Wetter_Trend, value=gleichbleibend
                                2022-06-28 22:00:25.058 - debug: simple-api.0 (1332) POST-setBulk for id=javascript.0.Wetterstation.Druck_Tendenz, oid=Luftdrucktendenz, used=javascript.0.Wetterstation.Druck_Tendenz, value=0
                                2022-06-28 22:00:25.058 - debug: simple-api.0 (1332) POST-setBulk for id=javascript.0.Wetterstation.Wetter_aktuell, oid=aktuelles Wetter, used=javascript.0.Wetterstation.Wetter_aktuell, value=wechselhaft
                                2022-06-28 22:00:25.058 - debug: simple-api.0 (1332) POST-setBulk for id=javascript.0.Wetterstation.tempData.Wetterdaten, oid=temporär gespeicherte Wetterdaten, used=javascript.0.Wetterstation.tempData.Wetterdaten, value=1017 1017 1017 1017 1017 1017 1017 1017 1016 1016 1016 1017
                                2022-06-28 22:00:25.106 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Wetter_Trend","val":"gleichbleibend"}
                                2022-06-28 22:00:25.151 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Druck_Tendenz","val":0}
                                2022-06-28 22:00:25.151 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Wetter_aktuell","val":"wechselhaft"}
                                2022-06-28 22:00:25.151 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.tempData.Wetterdaten","val":"1017 1017 1017 1017 1017 1017 1017 1017 1016 1016 1016 1017"}
                                2022-06-28 22:00:36.227 - debug: simple-api.0 (1332) POST-setBulk: body = javascript.0.Wetterstation.Wetter_Trend=Sturm mit Hagel&javascript.0.Wetterstation.Druck_Tendenz=-1018.00&javascript.0.Wetterstation.Wetter_aktuell=&javascript.0.Wetterstation.tempData.Wetterdaten=&user=&pass=
                                2022-06-28 22:00:36.228 - debug: simple-api.0 (1332) POST-setBulk: values = {"user":"","javascript.0.Wetterstation.Wetter_Trend":"Sturm mit Hagel","javascript.0.Wetterstation.Druck_Tendenz":"-1018.00","javascript.0.Wetterstation.Wetter_aktuell":"","javascript.0.Wetterstation.tempData.Wetterdaten":"","pass":""}
                                2022-06-28 22:00:36.228 - debug: simple-api.0 (1332) 0: "javascript.0.Wetterstation.Wetter_Trend"
                                2022-06-28 22:00:36.228 - debug: simple-api.0 (1332) 1: "javascript.0.Wetterstation.Druck_Tendenz"
                                2022-06-28 22:00:36.228 - debug: simple-api.0 (1332) 2: "javascript.0.Wetterstation.Wetter_aktuell"
                                2022-06-28 22:00:36.228 - debug: simple-api.0 (1332) 3: "javascript.0.Wetterstation.tempData.Wetterdaten"
                                2022-06-28 22:00:36.228 - debug: simple-api.0 (1332) POST-setBulk for id=javascript.0.Wetterstation.Wetter_Trend, oid=Wettertrend, used=javascript.0.Wetterstation.Wetter_Trend, value=Sturm mit Hagel
                                2022-06-28 22:00:36.228 - debug: simple-api.0 (1332) POST-setBulk for id=javascript.0.Wetterstation.Druck_Tendenz, oid=Luftdrucktendenz, used=javascript.0.Wetterstation.Druck_Tendenz, value=-1018.00
                                2022-06-28 22:00:36.228 - debug: simple-api.0 (1332) POST-setBulk for id=javascript.0.Wetterstation.Wetter_aktuell, oid=aktuelles Wetter, used=javascript.0.Wetterstation.Wetter_aktuell, value=
                                2022-06-28 22:00:36.229 - debug: simple-api.0 (1332) POST-setBulk for id=javascript.0.Wetterstation.tempData.Wetterdaten, oid=temporär gespeicherte Wetterdaten, used=javascript.0.Wetterstation.tempData.Wetterdaten, value=
                                2022-06-28 22:00:36.233 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Wetter_Trend","val":"Sturm mit Hagel"}
                                2022-06-28 22:00:36.234 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Druck_Tendenz","val":-1018}
                                2022-06-28 22:00:36.234 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.Wetter_aktuell","val":""}
                                2022-06-28 22:00:36.234 - debug: simple-api.0 (1332) Add to Response: {"id":"javascript.0.Wetterstation.tempData.Wetterdaten","val":""}
                                Bei 22:00:25 werden Wetterdaten geschreiben, und 22:00:36.228 wieder mit leer überschrieben, soweit ich das interpretiere.
                                Nur worher kommt dieser Befehl?
                                Gernot
                                T SBorgS 2 Antworten Letzte Antwort
                                • NegaleinN
                                  NegaleinN
                                  Negalein
                                  #3845
                                  @SBorg
                                  Servus
                                  Mit Ecowit wird ja auch der Batteriestatus übertragen (oder täuscht es mich).
                                  Ist das von Station zu Station verschieden, oder dauert es nur bis der Status abgefragt wird?
                                  Grund ist, da ich heute im Zuge vom Hardwaretausch (der RegenmengenDingsBums war tot) gleich auf Ecowit umgestellt habe, aber im Objekt nur 0 steht.
                                  ° Fixer ---> iob fix
                                  • S
                                    S
                                    speedy
                                    #3846
                                    @sborg
                                    OK, da Ecowitt mehr Daten liefern soll, habe ich nun umgestellt.
                                    Leider auch hier ein etwas unbefriedigendes Ergebnis:
                                     WLAN-Wetterstation V2.14.0 - (c)2019-2022 by SBorg
                                     Sub-Version   : V2.14.0
                                     'bc' installiert: [✓]
                                     'jq' installiert: [✓]
                                     'nc' in der Openbsd-Variante installiert:  [✓]
                                     'netcat' in Openbsd-Variante aktiv, alles korrekt [✓]
                                    Connection to 192.168.xxx.xxx 8087 port [tcp/*] succeeded!
                                    parse error: Invalid numeric literal at line 1, column 4
                                    Messwerteblock:
                                    Nicht alle Werte werden unterstützt (abhängig vom Modell der Wetterstation und dem verwendeten Protokoll)!
                                    Temperatur Innen        :  °C
                                    Temperatur Aussen       :  °C
                                    Taupunkt                :  °C
                                    Gefühlte Temperatur     :  °C
                                    Luftfeuchte Innen       :  %
                                    Luftfeuchte Aussen      :  %
                                    Windgeschwindkeit       :  km/h
                                    Windböengeschwindigkeit :  km/h
                                    max. Windböe            :  km/h
                                    Windrichtung            :  °
                                    Windrichtung            :
                                    Luftdruck absolut       :  hPa
                                    Luftdruck relativ       :  hPa
                                    Regenrate               :  mm/h
                                    Regenstatus             :
                                    Regen seit Regenbeginn  :  mm
                                    Regen Stunde            :  mm
                                    Regen Tag               :  mm
                                    Regen Woche             :  mm
                                    Regen Monat             :  mm
                                    Regen Jahr              :  mm
                                    Regen Gesamt            :  mm
                                    Sonnenstrahlung         :  W/m²
                                    UV-Index                :
                                    Zeitstempel             :
                                    Firmware                :
                                    Batteriestand:          :
                                    Gateway-Modell          :
                                    Zusatzsensoren:
                                    Datenstring für ioBroker:
                                    DATA von Wetterstation:
                                    Debug VAR:
                                    Installationsverzeichnis: /home/psw/WLAN-Wetterstation
                                    IPP: 192.168.xxx.xxx:8087   WS_PORT: 9999           WS_POLL: 60             PRE_DP: javascript.0.Wetterstation
                                    WEB: HTTP               WS_PROT: Ecowitt        DP35/40/50/60/70/100/200/250/300: 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0
                                    WH31: 0
                                    da die Fehlermeldung keine Anzeichen liefert, wo der "parse error" entsteht, kann ich nicht wirklich weitersuchen.
                                    Hat jemand noch eine Idee???
                                    ioBroker - Neuling ;)
                                    • MassiveAttackM
                                      MassiveAttackM
                                      MassiveAttack
                                      schrieb am zuletzt editiert von MassiveAttack
                                      #3847
                                      hab seit heute 3 weitere Sensoren mit der Basisstation erfolgreich verbunden. Wie kann ich die Daten jetzt im iobroker ablesen?
                                      Hab das skript mal wieder gestartet, und dann wieder gestoppt, sehe aber keine neuen DPs.
                                      Edit: Muss das wohl in der conf einstellen, ok :)
                                      Welchen muss ich auswählen, habe diese: dnt Zusatz-Thermo-/Hygrosensor für dnt RoomLogg PRO und dnt WeatherScreen PRO, 868 MHz, DNT000005
                                      Hat sich erledigt, funktioniert :)
                                      • NegaleinN Negalein
                                        @SBorg
                                        Servus
                                        SBorgS
                                        SBorgS
                                        SBorg
                                        #3848
                                        @negalein sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                        @SBorg
                                        Servus
                                        Der wird bei jedem Datenpaket mitgesendet. Du hast aber als "alter Recke" noch eine "Uralt-Datenpunktbezeichnung". Eigentlich sieht es so aus:
                                        Da wird es klarer ;)
                                        ...genügt ja den Namen in den Objekten zu ändern, dann bist du auch wieder up to date
                                        Batteriestatus [0=OK, 1=Alarm]
                                        • T tritor
                                          @sborg
                                          Wetterdaten:
                                          Solarenergie:
                                          Sonnenschein:
                                          T
                                          T
                                          tritor
                                          #3849
                                          @SBorg
                                          hattest du mal Zeit dir das Log File anzusehen?
                                          Ich bekomme zwar immer wieder Daten in den DP Wetterdaten, die werden aber immer wieder mit leer überschrieben.
                                          vielen Dank
                                          Gernot
                                          83.9k
