  4. Shelly plugs keine Daten aktuell (closed)
    5.8k
adapter problemerror logshellys
21 Beiträge 5 Kommentatoren 2.4k Aufrufe 4 Beobachtet
    @tt-tom sagte in Shelly plugs keine Daten aktuell:
    @Homoran Node steht auf 12, passt das mit npm 6?
    ich wollte eigentlich alles sehen
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @homoran sagte in Shelly plugs keine Daten aktuell:
    Das muss @Fridolin01 liefern (TE) scheint aber schon zu Bett gegangen zu sein 🤕
    Lehrling seit 1975 !!!
      Fridolin01
      schrieb am zuletzt editiert von Fridolin01
      @homoran ```
      Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.4.0-120-generic x86_64)
       * Documentation:  https://help.ubuntu.com
       * Management:     https://landscape.canonical.com
       * Support:        https://ubuntu.com/advantage
        System information as of Wed Jun 22 05:42:45 CEST 2022
        System load:            1.81
        Usage of /:             65.0% of 15.19GB
        Memory usage:           46%
        Swap usage:             0%
        Processes:              137
        Users logged in:        1
        IPv4 address for ens18: 192.168.2.60
        IPv6 address for ens18: 2003:f2:172f:cc93:f095:80ff:feec:ebbb
       * Super-optimized for small spaces - read how we shrank the memory
         footprint of MicroK8s to make it the smallest full K8s around.
         https://ubuntu.com/blog/microk8s-memory-optimisation
      10 updates can be applied immediately.
      To see these additional updates run: apt list --upgradable
      Last login: Wed Jun 22 05:40:52 2022 from 192.168.2.113
      gertz@gertz:~$ Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.4.0-120-generic x86_64)
      Last login: Tue Jun 21 21:46:02 2022 from 192.168.2.113
      gertz@gertz:~$ iobroker update -i
      Used repository: stable
      Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/../node_modules/iobroker.accuweather/io-package.json: /opt/iobroker/node_modules/iobroker.accuweather/io-package.json: Unexpected end of JSON input
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "backitup"     : 2.4.9    , installed 2.2.3  [Updatable]
      Adapter    "daswetter"    : 3.1.2    , installed 3.0.9  [Updatable]
      Adapter    "devices"      : 1.0.10   , installed 1.0.10
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
      Adapter    "history"      : 1.11.1   , installed 1.9.14 [Updatable]
      Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
      Adapter    "iot"          : 1.11.4   , installed 1.11.4
      Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
      Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "material"     : 1.1.2    , installed 1.0.4  [Updatable]
      Adapter    "meross"       : 1.10.5   , installed 1.10.5
      -bash: syntax error near unexpected token `('
      gertz@gertz:~$
      gertz@gertz:~$  * Documentation:  https://help.ubuntu.com
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.5  [Updatable]
      Adapter    "wolf"         : 1.4.0    , installed 1.2.0  [Updatable]
      Adapter    "zigbee"       : 1.7.5    , installed 1.6.6  [Updatable]
      sudo restart: command not found
      gertz@gertz:~$  * Management:     https://landscape.canonical.com
      gertz@gertz:~$  * Support:        https://ubuntu.com/advantage
      gertz@gertz:~$
      gertz@gertz:~$   System information as of Wed Jun 22 05:40:49 CEST 2022
      System: command not found
      gertz@gertz:~$
      gertz@gertz:~$   System load:            0.95
      gertz@gertz:~$   Usage of /:             65.0% of 15.19GB
      Command 'Usage' not found, did you mean:
        command 'osage' from deb graphviz (2.42.2-3build2)
        command 'sage' from deb sagemath-common (9.0-1ubuntu4)
      Try: sudo apt install <deb name>
      gertz@gertz:~$   Memory usage:           43%
      Memory: command not found
      gertz@gertz:~$   Swap usage:             0%
      Swap: command not found
      gertz@gertz:~$   Processes:              138
      Processes:: command not found
      gertz@gertz:~$   Users logged in:        1
      Command 'Users' not found, did you mean:
        command 'users' from deb coreutils (8.30-3ubuntu2)
      gertz@gertz:~$   IPv4 address for ens18: 192.168.2.60
      IPv4: command not found
      gertz@gertz:~$   IPv6 address for ens18: 2003:f2:172f:cc93:f095:80ff:feec:ebbb
      IPv6: command not found
      gertz@gertz:~$
      gertz@gertz:~$  * Super-optimized for small spaces - read how we shrank the memory
      gertz@gertz:~$    footprint of MicroK8s to make it the smallest full K8s around.
      Command 'footprint' not found, did you mean:
        command 'rootprint' from snap root-framework (v6-26-04)
      See 'snap info <snapname>' for additional versions.
      gertz@gertz:~$
      gertz@gertz:~$    https://ubuntu.com/blog/microk8s-memory-optimisation
      -bash: https://ubuntu.com/blog/microk8s-memory-optimisation: No such file or directory
      gertz@gertz:~$
      gertz@gertz:~$ 10 updates can be applied immediately.
      10: command not found
      gertz@gertz:~$ To see these additional updates run: apt list --upgradable
      To: command not found
      gertz@gertz:~$
      gertz@gertz:~$
      gertz@gertz:~$ Last login: Tue Jun 21 21:46:02 2022 from 192.168.2.113
      Command 'Last' not found, did you mean:
        command 'fast' from snap fast (0.0.4)
        command 'ast' from deb jruby (9.1.17.0-3build6)
        command 'nast' from deb nast (0.2.0-7build1)
        command 'last' from deb util-linux (2.34-0.1ubuntu9.3)
      gertz@gertz:~$ gertz@gertz:~$ iobroker update -i
      gertz@gertz:~$: command not found
      gertz@gertz:~$ Used repository: stable
      Command 'Used' not found, did you mean:
        command 'sed' from deb sed (4.7-1)
        command 'msed' from deb mblaze (0.6-1)
        command 'ssed' from deb ssed (3.62-7build1)
      gertz@gertz:~$ Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/../node_modules/iobroker.accuweather/io-package.json: /opt/iobroker/node_modules/iobroker.accuweather/io-package.json: Unexpected end of JSON input
      Cannot: command not found
      gertz@gertz:~$ Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter: command not found
      gertz@gertz:~$ Adapter    "backitup"     : 2.4.9    , installed 2.2.3  [Updatable]
      gertz@gertz:~$ Adapter    "daswetter"    : 3.1.2    , installed 3.0.9  [Updatable]
      gertz@gertz:~$ Adapter    "devices"      : 1.0.10   , installed 1.0.10
      gertz@gertz:~$ Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      gertz@gertz:~$ Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
      gertz@gertz:~$ Adapter    "history"      : 1.11.1   , installed 1.9.14 [Updatable]
      gertz@gertz:~$ Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
      gertz@gertz:~$ Adapter    "iot"          : 1.11.4   , installed 1.11.4
      gertz@gertz:~$ Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
      gertz@gertz:~$ Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
      gertz@gertz:~$ Controller "js-controller": 4.0.23   , installed 4.0.23
      Controller: command not found
      gertz@gertz:~$ Adapter    "material"     : 1.1.2    , installed 1.0.4  [Updatable]
      gertz@gertz:~$ Adapter    "meross"       : 1.10.5   , installed 1.10.5
      gertz@gertz:~$ Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.1  [Updatable]
      gertz@gertz:~$ Adapter    "ping"         : 1.5.3    , installed 1.5.3
      gertz@gertz:~$ Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
      gertz@gertz:~$ Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      gertz@gertz:~$ Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
      gertz@gertz:~$ Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      gertz@gertz:~$ Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
      gertz@gertz:~$ Adapter    "vis-bars"     : 0.1.4    , installed 0.1.4
      gertz@gertz:~$ Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.5  [Updatable]
      gertz@gertz:~$ Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
      gertz@gertz:~$ Adapter    "web"          : 4.3.0    , installed 4.3.0
      gertz@gertz:~$ Adapter    "wolf"         : 1.4.0    , installed 1.2.0  [Updatable]
      gertz@gertz:~$ Adapter    "ws"           : 1.3.0    , installed 1.3.0
      gertz@gertz:~$ Adapter    "zigbee"       : 1.7.5    , installed 1.6.6  [Updatable]
      • F Fridolin01
        @homoran ```
          System load:            1.81
          Memory usage:           46%
          Swap usage:             0%
          Processes:              137
          Users logged in:        1
        gertz@gertz:~$
        gertz@gertz:~$
        gertz@gertz:~$
        gertz@gertz:~$
        gertz@gertz:~$
        gertz@gertz:~$
        gertz@gertz:~$
        gertz@gertz:~$
        crunchipC Offline
        crunchipC Offline
        @fridolin01 was ist das denn für wirres Zeug? Was du da rein kopierst.
        Ich sehe da kein shelly Adapter.
        F 1 Antwort Letzte Antwort
          Fridolin01
          @crunchip said in Shelly plugs keine Daten aktuell:
          War wohl doch zu früh heute Morgen vor der Arbeit.
          Werde heute Nachmittag nochmal in Ruhe schauen.
          Sollte ich dennoch schonmal Node updaten?
          Wenn ja wie stelle ich das an ? Gibts dazu eine Anleitung ?
          • F Fridolin01
            crunchipC Offline
            crunchipC Offline
            @fridolin01 sagte in Shelly plugs keine Daten aktuell:
            Ja, zum einen in der offiziellen Doku und zum anderen im Forum.
            Z.b.
            https://forum.iobroker.net/post/621254
              Z.b.
              Fridolin01
              @crunchip
              Node.js: v14.19.3 erfolgreich geupdatet
              Nach dem Neustart des IOB besteht weiterhin der oben genannte Fehler
              Oder siehe hier aus dem Shelly adapter:
              shelly.0
              	2022-06-22 15:58:53.931	info	[CoAP] Listening for packets in the network
              shelly.0
              	2022-06-22 15:58:53.801	info	Starting in CoAP mode.
              shelly.0
              	2022-06-22 15:58:52.975	info	starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.3, js-controller: 4.0.23
              shelly.0
              	2022-06-22 15:58:46.219	error	DB closed
              shelly.0
              	2022-06-22 15:58:46.218	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:520:26) at Socket.emit (events.js:400:28) at Socket.emit (domain.js:475:12) at TCP.<anonymous> (net.js:686:12)
              shelly.0
              	2022-06-22 15:58:46.209	error	unhandled promise rejection: DB closed
              shelly.0
              	2022-06-22 15:58:46.208	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              shelly.0
              	2022-06-22 15:58:45.690	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              shelly.0
              	2022-06-22 15:58:45.687	info	terminating
              shelly.0
              	2022-06-22 15:58:45.685	info	Closing Adapter
              shelly.0
              	2022-06-22 15:58:45.673	info	Got terminate signal TERMINATE_YOURSELF
              • F Fridolin01
                @crunchip
                shelly.0
                shelly.0
                shelly.0
                shelly.0
                shelly.0
                shelly.0
                shelly.0
                shelly.0
                shelly.0
                shelly.0
                shelly.0
                und wie sieht iobroker update -i wirklich aus?
                  Fridolin01
                  @homoran said in Shelly plugs keine Daten aktuell:
                  iobroker update -i
                  Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                  Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
                  Adapter    "echarts"      : 1.0.7    , installed 1.0.7
                  Adapter    "history"      : 1.11.1   , installed 1.11.1
                  Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                  Adapter    "material"     : 1.1.2    , installed 1.1.2
                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                  Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                  • F Fridolin01
                    Moin seit gestern funktioniert meine Shelly Plugs nicht mehr.
                    Bedeutet das die States Energy und Power nicht mehr aktuallisiert werden.
                    Folgendes steht im Log.
                    Damit kann ich aber so garnichts anfangen
                    shelly.0
                    	2022-06-21 20:06:54.861	error	DB closed
                    shelly.0
                    	2022-06-21 20:06:54.861	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:421:26) at Socket.emit (events.js:314:20) at Socket.EventEmitter.emit (domain.js:483:12) at TCP.<anonymous> (net.js:675:12)
                    shelly.0
                    	2022-06-21 20:06:54.852	error	unhandled promise rejection: DB closed
                    shelly.0
                    	2022-06-21 20:06:54.851	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    shelly.0
                    	2022-06-21 20:04:20.315	error	DB closed
                    shelly.0
                    	2022-06-21 20:04:20.314	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:421:26) at Socket.emit (events.js:314:20) at Socket.EventEmitter.emit (domain.js:483:12) at TCP.<anonymous> (net.js:675:12)
                    shelly.0
                    	2022-06-21 20:04:20.305	error	unhandled promise rejection: DB closed
                    shelly.0
                    	2022-06-21 20:04:20.304	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    shelly.0
                    	2022-06-21 20:04:20.298	warn	get state error: Connection is closed.
                    shelly.0
                    	2022-06-21 19:59:22.085	error	DB closed
                    shelly.0
                    	2022-06-21 19:59:22.083	error	Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40) at Shelly.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
                    shelly.0
                    	2022-06-21 19:59:21.543	error	unhandled promise rejection: DB closed
                    shelly.0
                    	2022-06-21 19:59:21.542	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    shelly.0
                    	2022-06-21 19:59:21.536	warn	get state error: Connection is closed.
                    shelly.0
                    	2022-06-21 19:59:21.313	warn	setTimeout called, but adapter is shutting down
                    shelly.0
                    	2022-06-21 19:55:09.010	error	DB closed
                    shelly.0
                    	2022-06-21 19:55:09.005	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:421:26) at Socket.emit (events.js:314:20) at Socket.EventEmitter.emit (domain.js:483:12) at TCP.<anonymous> (net.js:675:12)
                    shelly.0
                    	2022-06-21 19:55:08.995	error	unhandled promise rejection: DB closed
                    shelly.0
                    	2022-06-21 19:55:08.992	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    shelly.0
                    	2022-06-21 19:55:08.987	warn	get state error: Connection is closed.
                    hast du mal hier gelesen?
                    https://forum.iobroker.net/topic/55765/shelly-zeigt-keine-verbrauchswerte-an/15
                    was ist denn mit deinem accuweather los?
                    und due komplezte Eingabezeile fehlt auch
                      Fridolin01
                      Gerade eingelsen
                      status "updating"
                      has_update false
                      new_version "20220209-094058/v1.11.8-g8c7bb8d"
                      old_version "20220209-094058/v1.11.8-g8c7bb8d"
                      Komisch ist das alle 6 Plugs die selbe FW haben
                      2 davon laufen wie geohnt und liefern Werte aktuell an den IOB
                      4 Stk liefern keine Werte (später gekauft) liefen aber bis vor 2 Tagen auch ohne Probleme
                      Mir ist einfach nicht begreiflich wo verdammt der Unterschied liegen soll.
                      Dabei liefen die Shellys bei mir immer am stabilsten von allen Systemen
