  4. Shelly plugs keine Daten aktuell (closed)
    5.8k
adapter problemerror logshellys
21 Beiträge 5 Kommentatoren 2.4k Aufrufe 4 Beobachtet
  • F Offline
    Fridolin01
    schrieb am zuletzt editiert von Fridolin01
    Moin seit gestern funktioniert meine Shelly Plugs nicht mehr.
    Bedeutet das die States Energy und Power nicht mehr aktuallisiert werden.
    Folgendes steht im Log.
    Damit kann ich aber so garnichts anfangen
    shelly.0
    	2022-06-21 20:06:54.861	error	DB closed
    shelly.0
    	2022-06-21 20:06:54.861	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:421:26) at Socket.emit (events.js:314:20) at Socket.EventEmitter.emit (domain.js:483:12) at TCP.<anonymous> (net.js:675:12)
    shelly.0
    	2022-06-21 20:06:54.852	error	unhandled promise rejection: DB closed
    shelly.0
    	2022-06-21 20:06:54.851	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    shelly.0
    	2022-06-21 20:04:20.315	error	DB closed
    shelly.0
    	2022-06-21 20:04:20.314	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:421:26) at Socket.emit (events.js:314:20) at Socket.EventEmitter.emit (domain.js:483:12) at TCP.<anonymous> (net.js:675:12)
    shelly.0
    	2022-06-21 20:04:20.305	error	unhandled promise rejection: DB closed
    shelly.0
    	2022-06-21 20:04:20.304	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    shelly.0
    	2022-06-21 20:04:20.298	warn	get state error: Connection is closed.
    shelly.0
    	2022-06-21 19:59:22.085	error	DB closed
    shelly.0
    	2022-06-21 19:59:22.083	error	Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40) at Shelly.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
    shelly.0
    	2022-06-21 19:59:21.543	error	unhandled promise rejection: DB closed
    shelly.0
    	2022-06-21 19:59:21.542	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    shelly.0
    	2022-06-21 19:59:21.536	warn	get state error: Connection is closed.
    shelly.0
    	2022-06-21 19:59:21.313	warn	setTimeout called, but adapter is shutting down
    shelly.0
    	2022-06-21 19:55:09.010	error	DB closed
    shelly.0
    	2022-06-21 19:55:09.005	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:421:26) at Socket.emit (events.js:314:20) at Socket.EventEmitter.emit (domain.js:483:12) at TCP.<anonymous> (net.js:675:12)
    shelly.0
    	2022-06-21 19:55:08.995	error	unhandled promise rejection: DB closed
    shelly.0
    	2022-06-21 19:55:08.992	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    shelly.0
    	2022-06-21 19:55:08.987	warn	get state error: Connection is closed.
    DJMarc75D HomoranH 2 Antworten Letzte Antwort
    • F Fridolin01
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      shelly.0
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @fridolin01 sagte in Shelly plugs keine Daten aktuell:
      Ja, das stimmt (bedingt) weil Du hier keine sonstigen Infos preis gibst - ABER:
      https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/549
      Das könnte vielleicht schon helfen.
      Lehrling seit 1975 !!!
      F 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        Fridolin01
        @djmarc75 Wenn du mir sagst was für Infos fehlen bemühe ich mich sofort darum
        Adapterversion Shelly 5.3.2
        Shellys alle neu gestartet
        Shellys stromlos gemacht
        Adapter neu gestartet
        Adapter downgrade auf 5.2.0 und diverse andere versucht
        Fehlt sonst noch was ?
        Danke schon mal
        • F Fridolin01
          Danke schon mal
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          Zeig mal bitte
          uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          die Ausgaben in Codetags
          Auf welchem System läuft iob?
            Zeig mal bitte
            Fridolin01
            @djmarc75 said in Shelly plugs keine Daten aktuell:
            gertz@gertz:~$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            x86_64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.12
            v12.22.12
            6.14.16
            gertz
            /home/gertz
            Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
            Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
            Hit:3 https://deb.nodesource.com/node_12.x focal InRelease
            Get:4 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
            Get:5 http://de.archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
            Fetched 222 kB in 2s (133 kB/s)
            Reading package lists... Done
            Building dependency tree
            1 package can be upgraded. Run 'apt list --upgradable' to see it.
            nodejs:
              Installed: 12.22.12-deb-1nodesource1
              Candidate: 12.22.12-deb-1nodesource1
              Version table:
             *** 12.22.12-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x focal/main amd64 Packages
                 10.19.0~dfsg-3ubuntu1 500
                    500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
            gertz@gertz:~$ gertz@gertz:~$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            gertz@gertz:~$: command not found
            gertz@gertz:~$ x86_64
            $ Welcome to Node.js v12.22.12.
            Type ".help" for more information.
            • F Fridolin01
              x86_64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.12
              v12.22.12
              6.14.16
              gertz
              /home/gertz
              nodejs:
                Version table:
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @fridolin01 ok, Ubuntu.
              Da bin ich leider raus, sorry.
              Aber vll liest es ja jemand mit mehr Ahnung damit Dir geholfen wird.
              Was auch helfen kann: welche Admin Version läuft bei Dir ?
                Fridolin01
                @djmarc75 trotzdem danke
                Admin Version 5.3.8
                • F Fridolin01
                  Admin Version 5.3.8
                  HomoranH Offline
                  HomoranH Offline
                  Admin Version 5.3.8
                  und iobroker update -i?
                    TT-Tom
                    @Homoran Node steht auf 12, passt das mit npm 6?
                    Gruß Tom
                    Public Transport
                    NSPanel Adapter Wiki
                    crunchipC HomoranH 2 Antworten Letzte Antwort
                    • T TT-Tom
                      crunchipC Offline
                      crunchipC Offline
                      @tt-tom hatte gepasst, v12 ist out and over, min v14 und mit der aktuellen Version des shelly sollte es auch wieder laufen. Das Issue von oben, war von mir
                      hatte allerdings gestern beim stoppen von iobroker mal wieder
                      2022-06-20 17:04:38.201 - warn: host.IoBroker instance system.adapter.unifi.0 terminated due to SIGTERM
                      2022-06-20 17:04:38.202 - info: host.IoBroker instance system.adapter.unifi.0 terminated with code null ()
                      2022-06-20 17:04:38.202 - info: host.IoBroker All instances are stopped.
                      2022-06-20 17:04:38.263 - warn: host.IoBroker instance system.adapter.chromecast.0 terminated due to SIGTERM
                      2022-06-20 17:04:38.264 - info: host.IoBroker instance system.adapter.chromecast.0 terminated with code null ()
                      2022-06-20 17:04:38.265 - info: host.IoBroker All instances are stopped.
                      2022-06-20 17:04:38.369 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                      2022-06-20 17:04:38.369 - error: host.IoBroker Caught by controller[0]: Error: DB closed
                      2022-06-20 17:04:38.370 - error: host.IoBroker Caught by controller[0]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                      2022-06-20 17:04:38.370 - error: host.IoBroker Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                      2022-06-20 17:04:38.371 - error: host.IoBroker Caught by controller[0]: at Object.onceWrapper (events.js:520:26)
                      2022-06-20 17:04:38.371 - error: host.IoBroker Caught by controller[0]: at Socket.emit (events.js:400:28)
                      2022-06-20 17:04:38.371 - error: host.IoBroker Caught by controller[0]: at Socket.emit (domain.js:475:12)
                      2022-06-20 17:04:38.372 - error: host.IoBroker Caught by controller[0]: at TCP. (net.js:686:12)
                      2022-06-20 17:04:38.372 - warn: host.IoBroker instance system.adapter.shelly.0 terminated due to SIGTERM
                      2022-06-20 17:04:38.373 - info: host.IoBroker instance system.adapter.shelly.0 terminated with code null ()
                      2022-06-20 17:04:38.373 - info: host.IoBroker All instances are stopped.
                      2022-06-20 17:04:38.471 - warn: host.IoBroker instance system.adapter.linux-control.0 terminated due to SIGTERM
                      2022-06-20 17:04:38.472 - info: host.IoBroker instance system.adapter.linux-control.0 terminated with code null ()
                      2022-06-20 17:04:38.472 - info: host.IoBroker All instances are stopped.
                      ich öffne mal das issue wieder
                      • T TT-Tom
                        HomoranH Offline
                        HomoranH Offline
                        @tt-tom sagte in Shelly plugs keine Daten aktuell:
                        ich wollte eigentlich alles sehen
                        DJMarc75D F 2 Antworten Letzte Antwort
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @homoran sagte in Shelly plugs keine Daten aktuell:
                          Das muss @Fridolin01 liefern (TE) scheint aber schon zu Bett gegangen zu sein 🤕
                            Fridolin01
                            @homoran ```
                            Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.4.0-120-generic x86_64)
                             * Documentation:  https://help.ubuntu.com
                             * Management:     https://landscape.canonical.com
                             * Support:        https://ubuntu.com/advantage
                              System information as of Wed Jun 22 05:42:45 CEST 2022
                              System load:            1.81
                              Usage of /:             65.0% of 15.19GB
                              Memory usage:           46%
                              Swap usage:             0%
                              Processes:              137
                              Users logged in:        1
                              IPv4 address for ens18: 192.168.2.60
                              IPv6 address for ens18: 2003:f2:172f:cc93:f095:80ff:feec:ebbb
                             * Super-optimized for small spaces - read how we shrank the memory
                               footprint of MicroK8s to make it the smallest full K8s around.
                               https://ubuntu.com/blog/microk8s-memory-optimisation
                            10 updates can be applied immediately.
                            To see these additional updates run: apt list --upgradable
                            Last login: Wed Jun 22 05:40:52 2022 from 192.168.2.113
                            gertz@gertz:~$ Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.4.0-120-generic x86_64)
                            Last login: Tue Jun 21 21:46:02 2022 from 192.168.2.113
                            gertz@gertz:~$ iobroker update -i
                            Used repository: stable
                            Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/../node_modules/iobroker.accuweather/io-package.json: /opt/iobroker/node_modules/iobroker.accuweather/io-package.json: Unexpected end of JSON input
                            Adapter    "admin"        : 5.3.8    , installed 5.3.8
                            Adapter    "backitup"     : 2.4.9    , installed 2.2.3  [Updatable]
                            Adapter    "daswetter"    : 3.1.2    , installed 3.0.9  [Updatable]
                            Adapter    "devices"      : 1.0.10   , installed 1.0.10
                            Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                            Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
                            Adapter    "history"      : 1.11.1   , installed 1.9.14 [Updatable]
                            Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
                            Adapter    "iot"          : 1.11.4   , installed 1.11.4
                            Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
                            Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
                            Controller "js-controller": 4.0.23   , installed 4.0.23
                            Adapter    "material"     : 1.1.2    , installed 1.0.4  [Updatable]
                            Adapter    "meross"       : 1.10.5   , installed 1.10.5
                            -bash: syntax error near unexpected token `('
                            gertz@gertz:~$
                            gertz@gertz:~$  * Documentation:  https://help.ubuntu.com
                            Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.5  [Updatable]
                            Adapter    "wolf"         : 1.4.0    , installed 1.2.0  [Updatable]
                            Adapter    "zigbee"       : 1.7.5    , installed 1.6.6  [Updatable]
                            sudo restart: command not found
                            gertz@gertz:~$  * Management:     https://landscape.canonical.com
                            gertz@gertz:~$  * Support:        https://ubuntu.com/advantage
                            gertz@gertz:~$
                            gertz@gertz:~$   System information as of Wed Jun 22 05:40:49 CEST 2022
                            System: command not found
                            gertz@gertz:~$
                            gertz@gertz:~$   System load:            0.95
                            gertz@gertz:~$   Usage of /:             65.0% of 15.19GB
                            Command 'Usage' not found, did you mean:
                              command 'osage' from deb graphviz (2.42.2-3build2)
                              command 'sage' from deb sagemath-common (9.0-1ubuntu4)
                            Try: sudo apt install <deb name>
                            gertz@gertz:~$   Memory usage:           43%
                            Memory: command not found
                            gertz@gertz:~$   Swap usage:             0%
                            Swap: command not found
                            gertz@gertz:~$   Processes:              138
                            Processes:: command not found
                            gertz@gertz:~$   Users logged in:        1
                            Command 'Users' not found, did you mean:
                              command 'users' from deb coreutils (8.30-3ubuntu2)
                            gertz@gertz:~$   IPv4 address for ens18: 192.168.2.60
                            IPv4: command not found
                            gertz@gertz:~$   IPv6 address for ens18: 2003:f2:172f:cc93:f095:80ff:feec:ebbb
                            IPv6: command not found
                            gertz@gertz:~$
                            gertz@gertz:~$  * Super-optimized for small spaces - read how we shrank the memory
                            gertz@gertz:~$    footprint of MicroK8s to make it the smallest full K8s around.
                            Command 'footprint' not found, did you mean:
                              command 'rootprint' from snap root-framework (v6-26-04)
                            See 'snap info <snapname>' for additional versions.
                            gertz@gertz:~$
                            gertz@gertz:~$    https://ubuntu.com/blog/microk8s-memory-optimisation
                            -bash: https://ubuntu.com/blog/microk8s-memory-optimisation: No such file or directory
                            gertz@gertz:~$
                            gertz@gertz:~$ 10 updates can be applied immediately.
                            10: command not found
                            gertz@gertz:~$ To see these additional updates run: apt list --upgradable
                            To: command not found
                            gertz@gertz:~$
                            gertz@gertz:~$
                            gertz@gertz:~$ Last login: Tue Jun 21 21:46:02 2022 from 192.168.2.113
                            Command 'Last' not found, did you mean:
                              command 'fast' from snap fast (0.0.4)
                              command 'ast' from deb jruby (9.1.17.0-3build6)
                              command 'nast' from deb nast (0.2.0-7build1)
                              command 'last' from deb util-linux (2.34-0.1ubuntu9.3)
                            gertz@gertz:~$ gertz@gertz:~$ iobroker update -i
                            gertz@gertz:~$ Used repository: stable
                            Command 'Used' not found, did you mean:
                              command 'sed' from deb sed (4.7-1)
                              command 'msed' from deb mblaze (0.6-1)
                              command 'ssed' from deb ssed (3.62-7build1)
                            gertz@gertz:~$ Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/../node_modules/iobroker.accuweather/io-package.json: /opt/iobroker/node_modules/iobroker.accuweather/io-package.json: Unexpected end of JSON input
                            Cannot: command not found
                            gertz@gertz:~$ Adapter    "admin"        : 5.3.8    , installed 5.3.8
                            Adapter: command not found
                            gertz@gertz:~$ Adapter    "backitup"     : 2.4.9    , installed 2.2.3  [Updatable]
                            gertz@gertz:~$ Adapter    "daswetter"    : 3.1.2    , installed 3.0.9  [Updatable]
                            gertz@gertz:~$ Adapter    "devices"      : 1.0.10   , installed 1.0.10
                            gertz@gertz:~$ Adapter    "discovery"    : 3.0.3    , installed 3.0.3
                            gertz@gertz:~$ Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
                            gertz@gertz:~$ Adapter    "history"      : 1.11.1   , installed 1.9.14 [Updatable]
                            gertz@gertz:~$ Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
                            gertz@gertz:~$ Adapter    "iot"          : 1.11.4   , installed 1.11.4
                            gertz@gertz:~$ Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
                            gertz@gertz:~$ Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
                            gertz@gertz:~$ Controller "js-controller": 4.0.23   , installed 4.0.23
                            Controller: command not found
                            gertz@gertz:~$ Adapter    "material"     : 1.1.2    , installed 1.0.4  [Updatable]
                            gertz@gertz:~$ Adapter    "meross"       : 1.10.5   , installed 1.10.5
                            gertz@gertz:~$ Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.1  [Updatable]
                            gertz@gertz:~$ Adapter    "ping"         : 1.5.3    , installed 1.5.3
                            gertz@gertz:~$ Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                            gertz@gertz:~$ Adapter    "shelly"       : 5.3.2    , installed 5.3.2
                            gertz@gertz:~$ Adapter    "simple-api"   : 2.6.5    , installed 2.7.0
                            gertz@gertz:~$ Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                            gertz@gertz:~$ Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
                            gertz@gertz:~$ Adapter    "vis-bars"     : 0.1.4    , installed 0.1.4
                            gertz@gertz:~$ Adapter    "vis-inventwo" : 3.3.1    , installed 3.2.5  [Updatable]
                            gertz@gertz:~$ Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.12
                            gertz@gertz:~$ Adapter    "web"          : 4.3.0    , installed 4.3.0
                            gertz@gertz:~$ Adapter    "wolf"         : 1.4.0    , installed 1.2.0  [Updatable]
                            gertz@gertz:~$ Adapter    "ws"           : 1.3.0    , installed 1.3.0
                            gertz@gertz:~$ Adapter    "zigbee"       : 1.7.5    , installed 1.6.6  [Updatable]
                            • F Fridolin01
                              @homoran ```
                                System load:            1.81
                                Memory usage:           46%
                                Swap usage:             0%
                                Processes:              137
                                Users logged in:        1
                              gertz@gertz:~$
                              gertz@gertz:~$
                              gertz@gertz:~$
                              gertz@gertz:~$
                              gertz@gertz:~$
                              gertz@gertz:~$
                              gertz@gertz:~$
                              gertz@gertz:~$
                              crunchipC Offline
                              crunchipC Offline
                              @fridolin01 was ist das denn für wirres Zeug? Was du da rein kopierst.
                              Ich sehe da kein shelly Adapter.
                                Fridolin01
                                @crunchip said in Shelly plugs keine Daten aktuell:
                                War wohl doch zu früh heute Morgen vor der Arbeit.
                                Werde heute Nachmittag nochmal in Ruhe schauen.
                                Sollte ich dennoch schonmal Node updaten?
                                Wenn ja wie stelle ich das an ? Gibts dazu eine Anleitung ?
                                • F Fridolin01
                                  crunchipC Offline
                                  crunchipC Offline
                                  Ja, zum einen in der offiziellen Doku und zum anderen im Forum.
                                  Z.b.
                                  https://forum.iobroker.net/post/621254
                                    Z.b.
                                    Fridolin01
                                    @crunchip
                                    Node.js: v14.19.3 erfolgreich geupdatet
                                    Nach dem Neustart des IOB besteht weiterhin der oben genannte Fehler
                                    Oder siehe hier aus dem Shelly adapter:
                                    shelly.0
                                    	2022-06-22 15:58:53.931	info	[CoAP] Listening for packets in the network
                                    shelly.0
                                    	2022-06-22 15:58:53.801	info	Starting in CoAP mode.
                                    shelly.0
                                    	2022-06-22 15:58:52.975	info	starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.3, js-controller: 4.0.23
                                    shelly.0
                                    	2022-06-22 15:58:46.219	error	DB closed
                                    shelly.0
                                    	2022-06-22 15:58:46.218	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (events.js:520:26) at Socket.emit (events.js:400:28) at Socket.emit (domain.js:475:12) at TCP.<anonymous> (net.js:686:12)
                                    shelly.0
                                    	2022-06-22 15:58:46.209	error	unhandled promise rejection: DB closed
                                    shelly.0
                                    	2022-06-22 15:58:46.208	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    shelly.0
                                    	2022-06-22 15:58:45.690	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    shelly.0
                                    	2022-06-22 15:58:45.687	info	terminating
                                    shelly.0
                                    	2022-06-22 15:58:45.685	info	Closing Adapter
                                    shelly.0
                                    	2022-06-22 15:58:45.673	info	Got terminate signal TERMINATE_YOURSELF
                                    • F Fridolin01
                                      @crunchip
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      shelly.0
                                      HomoranH Offline
                                      HomoranH Offline
                                      und wie sieht iobroker update -i wirklich aus?
                                        Fridolin01
                                        @homoran said in Shelly plugs keine Daten aktuell:
                                        iobroker update -i
                                        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
                                        Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
                                        Adapter    "echarts"      : 1.0.7    , installed 1.0.7
                                        Adapter    "history"      : 1.11.1   , installed 1.11.1
                                        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                                        Adapter    "material"     : 1.1.2    , installed 1.1.2
                                        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                                        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                                        • F Fridolin01
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          shelly.0
                                          HomoranH Offline
                                          HomoranH Offline
                                          hast du mal hier gelesen?
                                          https://forum.iobroker.net/topic/55765/shelly-zeigt-keine-verbrauchswerte-an/15
                                          was ist denn mit deinem accuweather los?
                                          und due komplezte Eingabezeile fehlt auch
