  3. Off Topic
  4. *Buster* 32bit -> *Bullseye* 64bit mit *BackItUp*
51 Beiträge 6 Kommentatoren 4.9k Aufrufe 4 Beobachtet
  • L legro
    Nun habe ich bereits den zweiten Versuch hinter mir, meine ioBroker-Installation von Buster (32Bit) zu Bullseye (64Bit) mittels BackItUp zu übertragen. Ergebnis: Alle Adapter scheinen in Ordnung zu sein, nur der VIS-Adapter will einfach nicht.
    host.raspberrypi-dev
    2022-06-11 17:08:50.013	error	Cannot download and install adapter "vis@1.4.15". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
    2022-06-11 17:08:49.012	info	iobroker npm-install: exit 25
    2022-06-11 17:08:47.978	error	iobroker npm-install: host.raspberrypi-dev Cannot install iobroker.vis@1.4.15: 6
    vis.0
    2022-06-11 17:08:45.358	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    vis.0
    2022-06-11 17:08:45.357	info	terminating
    vis.0
    2022-06-11 17:08:44.851	error	Not exists
    vis.0
    2022-06-11 17:08:44.850	error	Error: Not exists at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:2973:17) at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1043:26) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:1092:29) at processImmediate (internal/timers.js:466:21)
    vis.0
    2022-06-11 17:08:44.848	error	unhandled promise rejection: Not exists
    vis.0
    2022-06-11 17:08:44.847	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    vis.0
    2022-06-11 17:08:44.542	info	vis license is OK.
    vis.0
    2022-06-11 17:08:44.405	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.3, js-controller: 4.0.23
    2022-06-11 17:08:42.890	info	iobroker npm-install: > iobroker.vis@1.4.15 install /opt/iobroker/node_modules/iobroker.vis> node main.js --install
    2022-06-11 17:08:42.888	info	iobroker npm-install:
    2022-06-11 17:08:24.206	info	iobroker npm-install: Installing iobroker.vis@1.4.15... (System call)
    2022-06-11 17:08:24.204	info	iobroker npm-install: NPM version: 6.14.17
    2022-06-11 17:08:21.717	info	iobroker install vis@1.4.15 using installedVersion
    2022-06-11 17:08:21.716	warn	startInstance cannot find adapter "vis@1.4.15". Try to install it... 4 attempt
    Mal wieder bin ich ratlos.😞
    @legro
    Versuch mal eine der Vorversionen zu installieren. Wenn ich das richtig mitbekommen habe klemmt es u.U. bei der aktuellen Vis-Version.
    L 1 Antwort Letzte Antwort
      @legro
      legro
      schrieb am zuletzt editiert von legro
      Versuch mal eine der Vorversionen ..
      Aber wie kann ich das erreichen? Die Version ist doch durch das verwendete Backup festgelegt.
      Da fällt mir noch etwas ein ..
      Es gibt ja zwei Versionen: Ich habe jene erworben, die sich beim Start nicht über das Internet authentifizieren muss. Könnte es auch daran liegen?
      Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
      • L legro
        @legro
        Ich hab keine Vis laufen, daher weiß ich auch nicht wie das mit den Lizenzen da genau geregelt ist.
          @legro
          legro
          Da sitze ich wohl in der Falle: Entfernen lässt sich vis.0 nicht und eine weitere Instanz lässt sich ebenfalls nicht installieren.
          • L legro
            @legro
            iobroker upgrade vis@GEWÜNSCHTE.VERSION.NUMMER
            • L legro
              vis.0
              vis.0
              vis.0
              vis.0
              vis.0
              vis.0
              vis.0
              vis.0
              Einstein67
              schrieb am zuletzt editiert von Einstein67
              @legro said in *Buster* 32bit -> *Bullseye* 64bit mit *BackItUp*:
              Du musst nur einfach vor dem Restore mit BackitUp, den Vis-Adapter (Version ist egal) manuell installieren. Dann läuft er auch nach dem Restore.
              • E Einstein67
                legro
                @einstein67
                Verstehe ich das richtig ..
                • Im alten System (Buster 32Bit) ein Downgrade auf eine ältere Version machen.
                • Neues Backup erstellen
                • Das neue Backup erneut per Restore auf das neue System (Bullseye 64Bit) bringen
                E 1 Antwort Letzte Antwort
                • L legro
                  @einstein67
                  Einstein67
                  @legro Nein, am "neuem" System einfach vor dem Restore, den VIS-Adapter installieren. Lizenzfenster wegklicken und Restore starten.
                  L 2 Antworten Letzte Antwort
                  • E Einstein67
                    legro
                    @einstein67
                    Das neue System ist ja durch das gescheiterte Wiederherstellen vergurkt. Ich muss also zurück auf den Stand vor dem gescheiterten Restore und hierin die VIS installieren.
                    Zum Glück habe ich beim Aufbau des neuen Bullseye-Systems nach jeder Phase ein Backup mit ApplePiBaker erstellt.
                    • E Einstein67
                      legro
                      @einstein67
                      Leider ohne Erfolg. Wenn ich versuche, die zugehörige Website zu öffnen, erscheint dies:
                      URIError: Failed to decode param '%web_protocol%://192.168.4.99:%web_port%/vis/edit.html'
                          at decodeURIComponent (<anonymous>)
                          at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
                          at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
                          at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18)
                          at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15)
                          at compression (/opt/iobroker/node_modules/compression/index.js:220:5)
                          at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                          at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
                          at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
                          at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
                      So kann der Aufruf natürlich auch nicht funktionieren: Statt der Portnummer steht in der Browser-Adresszeile %web_port%. Die Installation des VIS-Adapter ist offenbar total vergurkt.
