  4. worx2: File index.html not found :{}:
11 Beiträge 4 Kommentatoren 838 Aufrufe 3 Beobachtet
  • SMSS Offline
    SMSS Offline
    SMS
    Hallo
    heute hatte ich auf einmal das Problem mit dem Adapter worx:
    Im Log:
    worx.2
    2022-06-11 12:14:12.463	error	ERROR: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}
    worx.2
    2022-06-11 12:14:12.462	error	Could not Connect to Worx Server: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}
    Hier scheint er zu existieren:
    pi@Homee:~ $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : Homee                                    -  enabled, port: 7770, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : Homee                                    - disabled, port: 7777, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : Homee                                    -  enabled
      system.adapter.binance.0                : binance               : Homee                                    - disabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: Homee                                    -  enabled
      system.adapter.daswetter.0              : daswetter             : Homee                                    -  enabled
      system.adapter.devices.0                : devices               : Homee                                    -  enabled
    + system.adapter.discovery.0              : discovery             : Homee                                    -  enabled
    + system.adapter.ds18b20.1                : ds18b20               : kellerkind4GB                            -  enabled
    + system.adapter.ds18b20.3                : ds18b20               : PapaHuette                               -  enabled
      system.adapter.dwd.0                    : dwd                   : Homee                                    -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : Homee                                    -  enabled
    + system.adapter.email.0                  : email                 : Homee                                    -  enabled
    + system.adapter.growatt.0                : growatt               : Homee                                    -  enabled
      system.adapter.ical.0                   : ical                  : Homee                                    -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Homee                                    -  enabled
    + system.adapter.influxdb.0               : influxdb              : Homee                                    -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : Homee                                    -  enabled
      system.adapter.modbus.1                 : modbus                : kellerkind4GB                            - disabled
      system.adapter.modbus.2                 : modbus                : kellerkind4GB                            - disabled
    + system.adapter.mqtt.0                   : mqtt                  : Homee                                    -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.nina.0                   : nina                  : Homee                                    - disabled
      system.adapter.parser.0                 : parser                : Homee                                    - disabled
      system.adapter.pegelalarm.0             : pegelalarm            : Homee                                    -  enabled
      system.adapter.pegelalarm.1             : pegelalarm            : Homee                                    -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : Homee                                    -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Homee                                    -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : kellerkind4GB                            -  enabled
    + system.adapter.rpi2.3                   : rpi2                  : PapaHuette                               -  enabled
    + system.adapter.rpi2.4                   : rpi2                  : Gartenklo                                -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : Homee                                    -  enabled
    + system.adapter.sonoff.0                 : sonoff                : Homee                                    -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.systeminfo.0             : systeminfo            : Homee                                    -  enabled
    + system.adapter.systeminfo.1             : systeminfo            : kellerkind4GB                            -  enabled
    + system.adapter.systeminfo.3             : systeminfo            : PapaHuette                               -  enabled
    + system.adapter.systeminfo.4             : systeminfo            : Gartenklo                                -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : Homee                                    -  enabled
      system.adapter.vis-bars.0               : vis-bars              : Homee                                    -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Homee                                    -  enabled
      system.adapter.vis-history.0            : vis-history           : Homee                                    -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Homee                                    -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Homee                                    -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : Homee                                    -  enabled
      system.adapter.vis-metro.0              : vis-metro             : Homee                                    -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : Homee                                    -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : Homee                                    -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : Homee                                    -  enabled
      system.adapter.vis.0                    : vis                   : Homee                                    -  enabled
    + system.adapter.web.0                    : web                   : Homee                                    -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Gartenklo                                - disabled
    + system.adapter.worx.2                   : worx                  : PapaHuette                               -  enabled
    + instance is alive
    pi@Homee:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v5.3.8
    system.adapter.backitup                : backitup       - v2.4.6
    system.adapter.binance                 : binance        - v1.1.3
    system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.7
    system.adapter.daswetter               : daswetter      - v3.1.2
    system.adapter.devices                 : devices        - v1.0.10
    system.adapter.discovery               : discovery      - v3.0.3
    system.adapter.ds18b20                 : ds18b20        - v1.5.4
    system.adapter.dwd                     : dwd            - v2.8.3
    system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.3.3
    system.adapter.email                   : email          - v1.0.10
    system.adapter.flot                    : flot           - v1.10.6
    system.adapter.fritzbox                : fritzbox       - v0.2.1
    system.adapter.growatt                 : growatt        - v1.1.15
    system.adapter.history                 : history        - v1.9.13
    system.adapter.ical                    : ical           - v1.12.1
    system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
    system.adapter.influxdb                : influxdb       - v2.6.3
    system.adapter.info                    : info           - v1.9.18
    system.adapter.javascript              : javascript     - v5.7.0
    system.adapter.modbus                  : modbus         - v3.4.11
    system.adapter.mqtt                    : mqtt           - v3.0.6
    system.adapter.nina                    : nina           - v0.0.25
    system.adapter.node-red                : node-red       - v2.0.1
    system.adapter.onvif                   : onvif          - v0.4.4
    system.adapter.parser                  : parser         - v1.1.4
    system.adapter.pegelalarm              : pegelalarm     - v1.2.5
    system.adapter.pollenflug              : pollenflug     - v1.0.6
    system.adapter.roomba                  : roomba         - v1.1.4
    system.adapter.rpi2                    : rpi2           - v1.3.2
    system.adapter.simple-api              : simple-api     - v2.6.5
    system.adapter.smartmeter              : smartmeter     - v3.3.4
    system.adapter.sonoff                  : sonoff         - v2.5.1
    system.adapter.systeminfo              : systeminfo     - v0.3.1
    system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
    system.adapter.tr-064                  : tr-064         - v4.2.14
    system.adapter.upnp                    : upnp           - v1.0.19
    system.adapter.vis                     : vis            - v1.4.15
    system.adapter.vis-bars                : vis-bars       - v0.1.4
    system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
    system.adapter.vis-history             : vis-history    - v1.0.0
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
    system.adapter.vis-justgage            : vis-justgage   - v1.0.2
    system.adapter.vis-metro               : vis-metro      - v1.2.0
    system.adapter.vis-plumb               : vis-plumb      - v1.0.2
    system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
    system.adapter.web                     : web            - v4.2.3
    system.adapter.whatsapp-cmb            : whatsapp-cmb   - v0.2.2
    system.adapter.worx                    : worx           - v1.5.5
    pi@Homee:~ $ iobroker update -i
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "backitup"     : 2.4.6    , installed 2.4.6
    Adapter    "binance"      : 1.1.3    , installed 1.1.3
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
    Adapter    "devices"      : 1.0.10   , installed 1.0.10
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "ecovacs-deebot": 1.4.4   , installed 1.3.3  [Updatable]
    Adapter    "email"        : 1.0.10   , installed 1.0.10
    Adapter    "growatt"      : 1.1.15   , installed 1.1.15
    Adapter    "ical"         : 1.12.1   , installed 1.12.1
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "javascript"   : 5.7.0    , installed 5.7.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "parser"       : 1.1.5    , installed 1.1.4  [Updatable]
    Adapter    "pegelalarm"   : 1.2.5    , installed 1.2.5
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "web"          : 4.3.0    , installed 4.2.3  [Updatable]
    pi@Homee:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/node
    /usr/bin/npm
    Was kann das nun wieder sein? Adapter habe ich auch schon neu installiert.
    • SMSS SMS
      Hallo
      Im Log:
      worx.2
      worx.2
      + instance is alive
      armv7l
      /usr/bin/node
      /usr/bin/npm
      @sms soll ich das Thema nicht besser teilen?
      Hat doch mit vis nichts zu tun, oder?
      SMSS 1 Antwort Letzte Antwort
        SMSS Offline
        SMSS Offline
        SMS
        @homoran OK! Danke!
        • SMSS SMS
          Hallo
          Im Log:
          worx.2
          worx.2
          + instance is alive
          armv7l
          /usr/bin/node
          /usr/bin/npm
          @sms
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Dann
          iobroker update
          iobroker upgrade
            @sms
            sudo apt update
            sudo reboot
            Dann
            iobroker update
            iobroker upgrade
            SMSS Offline
            SMSS Offline
            SMS
            schrieb am zuletzt editiert von SMS
            @thomas-braun sagte in worx2: File index.html not found :{}::
            Ich habe das jetzt auf dem Slave gemacht, auf dem der Adapter läuft. Hat leider nichts gebracht:
            Soll ich das auf dem Master auch machen?
            • SMSS SMS
              @sms sagte in worx2: File index.html not found :{}::
              aber nur die Instanz!
              die Adapterdateien liegen auf dem Master
                SMSS Offline
                SMSS Offline
                SMS
                @homoran Hallo
                nachdem noch ein anderer Adapter ausgestiegen ist, habe ich das oben genannte auf dem Master durchgeführt. Leider ohne Erfolg. Beim starten steht folgende Meldung im LOG:
                worx.2
                2022-06-15 13:53:39.383	error	ERROR: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}
                worx.2
                2022-06-15 13:53:39.381	error	Could not Connect to Worx Server: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}
                worx.2
                2022-06-15 13:53:39.034	info	worx is selected
                worx.2
                2022-06-15 13:53:38.996	info	starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.worx, node: v14.19.3, js-controller: 4.0.23
                worx.2
                2022-06-15 13:53:33.428	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                worx.2
                2022-06-15 13:53:33.424	info	terminating
                worx.2
                2022-06-15 13:53:33.422	info	cleaned everything up...
                worx.2
                2022-06-15 13:53:33.413	info	Got terminate signal TERMINATE_YOURSELF
                • SMSS SMS
                  @homoran Hallo
                  worx.2
                  worx.2
                  worx.2
                  worx.2
                  worx.2
                  worx.2
                  worx.2
                  worx.2
                  Check the username
                  Username korrekt? Sonderzeichen drin?
                    Check the username
                    SMSS Offline
                    SMSS Offline
                    SMS
                    @thomas-braun Ich komm ja gar nicht soweit das ich was ändern könnte:
                    • SMSS SMS
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @sms laut deinem iobroker update -i gibt es den Adapter auch nicht, ebenso fehlt der whatsapp-cmb und noch ein paar andere
                        SMSS Offline
                        SMSS Offline
                        SMS
                        @crunchip Also hier steht der Adapter drin:
                        system.adapter.backitup                : backitup       - v2.4.9
                        system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.4
                        system.adapter.landroid                : landroid       - v1.0.3
                        system.adapter.parser                  : parser         - v1.1.5
                        system.adapter.web                     : web            - v4.3.0
                        hier als disable (vermutlich weil ich den Adapter gestoppt habe):
                        + system.adapter.landroid.2               : landroid              : PapaHuette                               -  enabled
                          system.adapter.worx.2                   : worx                  : PapaHuette                               - disabled
                        deinstalliert und dann neu installiert habe ich den auch schon
                        Update: erneut deinstalliert und wieder installiert. Jetzt läuft's wieder.
