worx2: File index.html not found :{}:
Hallo
heute hatte ich auf einmal das Problem mit dem Adapter worx:
Im Log:
worx.2 2022-06-11 12:14:12.463 error ERROR: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."} worx.2 2022-06-11 12:14:12.462 error Could not Connect to Worx Server: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}Hier scheint er zu existieren:
pi@Homee:~ $ iobroker list instances + system.adapter.admin.0 : admin : Homee - enabled, port: 7770, bind: 0.0.0.0, run as: admin system.adapter.admin.1 : admin : Homee - disabled, port: 7777, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : Homee - enabled system.adapter.binance.0 : binance : Homee - disabled system.adapter.coronavirus-statistics.0 : coronavirus-statistics: Homee - enabled system.adapter.daswetter.0 : daswetter : Homee - enabled system.adapter.devices.0 : devices : Homee - enabled + system.adapter.discovery.0 : discovery : Homee - enabled + system.adapter.ds18b20.1 : ds18b20 : kellerkind4GB - enabled + system.adapter.ds18b20.3 : ds18b20 : PapaHuette - enabled system.adapter.dwd.0 : dwd : Homee - enabled + system.adapter.ecovacs-deebot.0 : ecovacs-deebot : Homee - enabled + system.adapter.email.0 : email : Homee - enabled + system.adapter.growatt.0 : growatt : Homee - enabled system.adapter.ical.0 : ical : Homee - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Homee - enabled + system.adapter.influxdb.0 : influxdb : Homee - enabled, port: 8086 + system.adapter.javascript.0 : javascript : Homee - enabled system.adapter.modbus.1 : modbus : kellerkind4GB - disabled system.adapter.modbus.2 : modbus : kellerkind4GB - disabled + system.adapter.mqtt.0 : mqtt : Homee - enabled, port: 1886, bind: 0.0.0.0 system.adapter.nina.0 : nina : Homee - disabled system.adapter.parser.0 : parser : Homee - disabled system.adapter.pegelalarm.0 : pegelalarm : Homee - enabled system.adapter.pegelalarm.1 : pegelalarm : Homee - enabled + system.adapter.pollenflug.0 : pollenflug : Homee - enabled + system.adapter.rpi2.0 : rpi2 : Homee - enabled + system.adapter.rpi2.1 : rpi2 : kellerkind4GB - enabled + system.adapter.rpi2.3 : rpi2 : PapaHuette - enabled + system.adapter.rpi2.4 : rpi2 : Gartenklo - enabled + system.adapter.smartmeter.0 : smartmeter : Homee - enabled + system.adapter.sonoff.0 : sonoff : Homee - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.systeminfo.0 : systeminfo : Homee - enabled + system.adapter.systeminfo.1 : systeminfo : kellerkind4GB - enabled + system.adapter.systeminfo.3 : systeminfo : PapaHuette - enabled + system.adapter.systeminfo.4 : systeminfo : Gartenklo - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : Homee - enabled system.adapter.vis-bars.0 : vis-bars : Homee - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Homee - enabled system.adapter.vis-history.0 : vis-history : Homee - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Homee - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Homee - enabled system.adapter.vis-justgage.0 : vis-justgage : Homee - enabled system.adapter.vis-metro.0 : vis-metro : Homee - enabled system.adapter.vis-plumb.0 : vis-plumb : Homee - enabled system.adapter.vis-rgraph.0 : vis-rgraph : Homee - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : Homee - enabled system.adapter.vis.0 : vis : Homee - enabled + system.adapter.web.0 : web : Homee - enabled, port: 7777, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : Gartenklo - disabled + system.adapter.worx.2 : worx : PapaHuette - enabled + instance is alivepi@Homee:~ $ iobroker list adapters system.adapter.admin : admin - v5.3.8 system.adapter.backitup : backitup - v2.4.6 system.adapter.binance : binance - v1.1.3 system.adapter.coronavirus-statistics : coronavirus-statistics - v0.8.7 system.adapter.daswetter : daswetter - v3.1.2 system.adapter.devices : devices - v1.0.10 system.adapter.discovery : discovery - v3.0.3 system.adapter.ds18b20 : ds18b20 - v1.5.4 system.adapter.dwd : dwd - v2.8.3 system.adapter.ecovacs-deebot : ecovacs-deebot - v1.3.3 system.adapter.email : email - v1.0.10 system.adapter.flot : flot - v1.10.6 system.adapter.fritzbox : fritzbox - v0.2.1 system.adapter.growatt : growatt - v1.1.15 system.adapter.history : history - v1.9.13 system.adapter.ical : ical - v1.12.1 system.adapter.icons-mfd-svg : icons-mfd-svg - v1.1.0 system.adapter.influxdb : influxdb - v2.6.3 system.adapter.info : info - v1.9.18 system.adapter.javascript : javascript - v5.7.0 system.adapter.modbus : modbus - v3.4.11 system.adapter.mqtt : mqtt - v3.0.6 system.adapter.nina : nina - v0.0.25 system.adapter.node-red : node-red - v2.0.1 system.adapter.onvif : onvif - v0.4.4 system.adapter.parser : parser - v1.1.4 system.adapter.pegelalarm : pegelalarm - v1.2.5 system.adapter.pollenflug : pollenflug - v1.0.6 system.adapter.roomba : roomba - v1.1.4 system.adapter.rpi2 : rpi2 - v1.3.2 system.adapter.simple-api : simple-api - v2.6.5 system.adapter.smartmeter : smartmeter - v3.3.4 system.adapter.sonoff : sonoff - v2.5.1 system.adapter.systeminfo : systeminfo - v0.3.1 system.adapter.tankerkoenig : tankerkoenig - v2.1.1 system.adapter.tr-064 : tr-064 - v4.2.14 system.adapter.upnp : upnp - v1.0.19 system.adapter.vis : vis - v1.4.15 system.adapter.vis-bars : vis-bars - v0.1.4 system.adapter.vis-canvas-gauges : vis-canvas-gauges - v0.1.5 system.adapter.vis-history : vis-history - v1.0.0 system.adapter.vis-hqwidgets : vis-hqwidgets - v1.2.0 system.adapter.vis-jqui-mfd : vis-jqui-mfd - v1.0.12 system.adapter.vis-justgage : vis-justgage - v1.0.2 system.adapter.vis-metro : vis-metro - v1.2.0 system.adapter.vis-plumb : vis-plumb - v1.0.2 system.adapter.vis-rgraph : vis-rgraph - v0.0.2 system.adapter.vis-timeandweather : vis-timeandweather - v1.1.7 system.adapter.web : web - v4.2.3 system.adapter.whatsapp-cmb : whatsapp-cmb - v0.2.2 system.adapter.worx : worx - v1.5.5pi@Homee:~ $ iobroker update -i Used repository: Stable (default) Adapter "admin" : 5.3.8 , installed 5.3.8 Adapter "backitup" : 2.4.6 , installed 2.4.6 Adapter "binance" : 1.1.3 , installed 1.1.3 Adapter "coronavirus-statistics": 0.8.7, installed 0.8.7 Adapter "daswetter" : 3.1.2 , installed 3.1.2 Adapter "devices" : 1.0.10 , installed 1.0.10 Adapter "discovery" : 3.0.3 , installed 3.0.3 Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "ecovacs-deebot": 1.4.4 , installed 1.3.3 [Updatable] Adapter "email" : 1.0.10 , installed 1.0.10 Adapter "growatt" : 1.1.15 , installed 1.1.15 Adapter "ical" : 1.12.1 , installed 1.12.1 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0 Adapter "influxdb" : 2.6.3 , installed 2.6.3 Adapter "javascript" : 5.7.0 , installed 5.7.0 Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "mqtt" : 3.0.6 , installed 3.0.6 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "parser" : 1.1.5 , installed 1.1.4 [Updatable] Adapter "pegelalarm" : 1.2.5 , installed 1.2.5 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "simple-api" : 2.6.5 , installed 2.6.5 Adapter "smartmeter" : 3.3.4 , installed 3.3.4 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sonoff" : 2.5.1 , installed 2.5.1 Adapter "systeminfo" : 0.3.1 , installed 0.3.1 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 0.1.5, installed 0.1.5 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.2.0 , installed 1.2.0 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.1.7, installed 1.1.7 Adapter "web" : 4.3.0 , installed 4.2.3 [Updatable] Adapter "ws" : 1.3.0 , installed 1.3.0pi@Homee:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/node /usr/bin/npmWas kann das nun wieder sein? Adapter habe ich auch schon neu installiert.
Hallo
Im Log:
Hallo
Im Log:
@thomas-braun sagte in worx2: File index.html not found :{}::
Ich habe das jetzt auf dem Slave gemacht, auf dem der Adapter läuft. Hat leider nichts gebracht:
Soll ich das auf dem Master auch machen?
@sms sagte in worx2: File index.html not found :{}::
aber nur die Instanz!
die Adapterdateien liegen auf dem Master@homoran Hallo
nachdem noch ein anderer Adapter ausgestiegen ist, habe ich das oben genannte auf dem Master durchgeführt. Leider ohne Erfolg. Beim starten steht folgende Meldung im LOG:
worx.2 2022-06-15 13:53:39.383 error ERROR: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."} worx.2 2022-06-15 13:53:39.381 error Could not Connect to Worx Server: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."} worx.2 2022-06-15 13:53:39.034 info worx is selected worx.2 2022-06-15 13:53:38.996 info starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.worx, node: v14.19.3, js-controller: 4.0.23 worx.2 2022-06-15 13:53:33.428 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason worx.2 2022-06-15 13:53:33.424 info terminating worx.2 2022-06-15 13:53:33.422 info cleaned everything up... worx.2 2022-06-15 13:53:33.413 info Got terminate signal TERMINATE_YOURSELF -
@homoran Hallo
worx.2 2022-06-15 13:53:39.383 error ERROR: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."} worx.2 2022-06-15 13:53:39.381 error Could not Connect to Worx Server: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."} worx.2 2022-06-15 13:53:39.034 info worx is selected worx.2 2022-06-15 13:53:38.996 info starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.worx, node: v14.19.3, js-controller: 4.0.23 worx.2 2022-06-15 13:53:33.428 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason worx.2 2022-06-15 13:53:33.424 info terminating worx.2 2022-06-15 13:53:33.422 info cleaned everything up... worx.2 2022-06-15 13:53:33.413 info Got terminate signal TERMINATE_YOURSELF@sms sagte in worx2: File index.html not found :{}::
Check the
usernameUsername korrekt? Sonderzeichen drin?
Check the
@thomas-braun Ich komm ja gar nicht soweit das ich was ändern könnte:
@sms laut deinem iobroker update -i gibt es den Adapter auch nicht, ebenso fehlt der whatsapp-cmb und noch ein paar andere
@crunchip Also hier steht der Adapter drin:
pi@Homee:~ $ iobroker list adapters system.adapter.admin : admin - v5.3.8 system.adapter.backitup : backitup - v2.4.9 system.adapter.binance : binance - v1.1.3 system.adapter.coronavirus-statistics : coronavirus-statistics - v0.8.7 system.adapter.daswetter : daswetter - v3.1.2 system.adapter.devices : devices - v1.0.10 system.adapter.discovery : discovery - v3.0.3 system.adapter.ds18b20 : ds18b20 - v1.5.4 system.adapter.dwd : dwd - v2.8.3 system.adapter.ecovacs-deebot : ecovacs-deebot - v1.4.4 system.adapter.email : email - v1.0.10 system.adapter.flot : flot - v1.10.6 system.adapter.fritzbox : fritzbox - v0.2.1 system.adapter.growatt : growatt - v1.1.15 system.adapter.history : history - v1.9.13 system.adapter.ical : ical - v1.12.1 system.adapter.icons-mfd-svg : icons-mfd-svg - v1.1.0 system.adapter.influxdb : influxdb - v2.6.3 system.adapter.info : info - v1.9.18 system.adapter.javascript : javascript - v5.7.0 system.adapter.landroid : landroid - v1.0.3 system.adapter.modbus : modbus - v3.4.11 system.adapter.mqtt : mqtt - v3.0.6 system.adapter.nina : nina - v0.0.25 system.adapter.node-red : node-red - v2.0.1 system.adapter.onvif : onvif - v0.4.4 system.adapter.parser : parser - v1.1.5 system.adapter.pegelalarm : pegelalarm - v1.2.5 system.adapter.pollenflug : pollenflug - v1.0.6 system.adapter.roomba : roomba - v1.1.4 system.adapter.rpi2 : rpi2 - v1.3.2 system.adapter.simple-api : simple-api - v2.6.5 system.adapter.smartmeter : smartmeter - v3.3.4 system.adapter.sonoff : sonoff - v2.5.1 system.adapter.systeminfo : systeminfo - v0.3.1 system.adapter.tankerkoenig : tankerkoenig - v2.1.1 system.adapter.tr-064 : tr-064 - v4.2.14 system.adapter.upnp : upnp - v1.0.19 system.adapter.vis : vis - v1.4.15 system.adapter.vis-bars : vis-bars - v0.1.4 system.adapter.vis-canvas-gauges : vis-canvas-gauges - v0.1.5 system.adapter.vis-history : vis-history - v1.0.0 system.adapter.vis-hqwidgets : vis-hqwidgets - v1.2.0 system.adapter.vis-jqui-mfd : vis-jqui-mfd - v1.0.12 system.adapter.vis-justgage : vis-justgage - v1.0.2 system.adapter.vis-metro : vis-metro - v1.2.0 system.adapter.vis-plumb : vis-plumb - v1.0.2 system.adapter.vis-rgraph : vis-rgraph - v0.0.2 system.adapter.vis-timeandweather : vis-timeandweather - v1.1.7 system.adapter.web : web - v4.3.0 system.adapter.whatsapp-cmb : whatsapp-cmb - v0.2.2 system.adapter.worx : worx - v1.5.5hier als disable (vermutlich weil ich den Adapter gestoppt habe):
pi@Homee:~ $ iobroker list instances + system.adapter.admin.0 : admin : Homee - enabled, port: 7770, bind: 0.0.0.0, run as: admin system.adapter.admin.1 : admin : Homee - disabled, port: 7777, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : Homee - enabled system.adapter.binance.0 : binance : Homee - disabled system.adapter.coronavirus-statistics.0 : coronavirus-statistics: Homee - enabled system.adapter.daswetter.0 : daswetter : Homee - enabled system.adapter.devices.0 : devices : Homee - enabled + system.adapter.discovery.0 : discovery : Homee - enabled + system.adapter.ds18b20.1 : ds18b20 : kellerkind4GB - enabled + system.adapter.ds18b20.3 : ds18b20 : PapaHuette - enabled system.adapter.dwd.0 : dwd : Homee - enabled + system.adapter.ecovacs-deebot.0 : ecovacs-deebot : Homee - enabled + system.adapter.email.0 : email : Homee - enabled + system.adapter.growatt.0 : growatt : Homee - enabled system.adapter.ical.0 : ical : Homee - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : Homee - enabled + system.adapter.influxdb.0 : influxdb : Homee - enabled, port: 8086 + system.adapter.javascript.0 : javascript : Homee - enabled + system.adapter.landroid.2 : landroid : PapaHuette - enabled system.adapter.modbus.1 : modbus : kellerkind4GB - disabled system.adapter.modbus.2 : modbus : kellerkind4GB - disabled + system.adapter.mqtt.0 : mqtt : Homee - enabled, port: 1886, bind: 0.0.0.0 system.adapter.nina.0 : nina : Homee - disabled system.adapter.parser.0 : parser : Homee - disabled system.adapter.pegelalarm.0 : pegelalarm : Homee - enabled system.adapter.pegelalarm.1 : pegelalarm : Homee - enabled + system.adapter.pollenflug.0 : pollenflug : Homee - enabled + system.adapter.rpi2.0 : rpi2 : Homee - enabled + system.adapter.rpi2.1 : rpi2 : kellerkind4GB - enabled + system.adapter.rpi2.3 : rpi2 : PapaHuette - enabled + system.adapter.rpi2.4 : rpi2 : Gartenklo - enabled + system.adapter.smartmeter.0 : smartmeter : Homee - enabled + system.adapter.sonoff.0 : sonoff : Homee - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.systeminfo.0 : systeminfo : Homee - enabled + system.adapter.systeminfo.1 : systeminfo : kellerkind4GB - enabled + system.adapter.systeminfo.3 : systeminfo : PapaHuette - enabled + system.adapter.systeminfo.4 : systeminfo : Gartenklo - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : Homee - enabled system.adapter.vis-bars.0 : vis-bars : Homee - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : Homee - enabled system.adapter.vis-history.0 : vis-history : Homee - enabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : Homee - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : Homee - enabled system.adapter.vis-justgage.0 : vis-justgage : Homee - enabled system.adapter.vis-metro.0 : vis-metro : Homee - enabled system.adapter.vis-plumb.0 : vis-plumb : Homee - enabled system.adapter.vis-rgraph.0 : vis-rgraph : Homee - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : Homee - enabled system.adapter.vis.0 : vis : Homee - enabled + system.adapter.web.0 : web : Homee - enabled, port: 7777, bind: 0.0.0.0, run as: admin system.adapter.whatsapp-cmb.0 : whatsapp-cmb : Gartenklo - disabled system.adapter.worx.2 : worx : PapaHuette - disableddeinstalliert und dann neu installiert habe ich den auch schon
Update: erneut deinstalliert und wieder installiert. Jetzt läuft's wieder.
