<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[worx2: File index.html not found :{}:]]></title><description><![CDATA[<p dir="auto">Hallo</p>
<p dir="auto">heute hatte ich auf einmal das Problem mit dem Adapter worx:<br />
<img src="/assets/uploads/files/1654943056817-3ffedd53-9a6c-4841-93d6-3533357b1493-image.png" alt="3ffedd53-9a6c-4841-93d6-3533357b1493-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Im Log:</p>
<pre><code>
worx.2
2022-06-11 12:14:12.463	error	ERROR: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}
worx.2
2022-06-11 12:14:12.462	error	Could not Connect to Worx Server: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}
</code></pre>
<p dir="auto">Hier scheint er zu existieren:</p>
<pre><code>pi@Homee:~ $ iobroker list instances
+ system.adapter.admin.0                  : admin                 : Homee                                    -  enabled, port: 7770, bind: 0.0.0.0, run as: admin
  system.adapter.admin.1                  : admin                 : Homee                                    - disabled, port: 7777, bind: 0.0.0.0, run as: admin
+ system.adapter.backitup.0               : backitup              : Homee                                    -  enabled
  system.adapter.binance.0                : binance               : Homee                                    - disabled
  system.adapter.coronavirus-statistics.0 : coronavirus-statistics: Homee                                    -  enabled
  system.adapter.daswetter.0              : daswetter             : Homee                                    -  enabled
  system.adapter.devices.0                : devices               : Homee                                    -  enabled
+ system.adapter.discovery.0              : discovery             : Homee                                    -  enabled
+ system.adapter.ds18b20.1                : ds18b20               : kellerkind4GB                            -  enabled
+ system.adapter.ds18b20.3                : ds18b20               : PapaHuette                               -  enabled
  system.adapter.dwd.0                    : dwd                   : Homee                                    -  enabled
+ system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : Homee                                    -  enabled
+ system.adapter.email.0                  : email                 : Homee                                    -  enabled
+ system.adapter.growatt.0                : growatt               : Homee                                    -  enabled
  system.adapter.ical.0                   : ical                  : Homee                                    -  enabled
  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : Homee                                    -  enabled
+ system.adapter.influxdb.0               : influxdb              : Homee                                    -  enabled, port: 8086
+ system.adapter.javascript.0             : javascript            : Homee                                    -  enabled
  system.adapter.modbus.1                 : modbus                : kellerkind4GB                            - disabled
  system.adapter.modbus.2                 : modbus                : kellerkind4GB                            - disabled
+ system.adapter.mqtt.0                   : mqtt                  : Homee                                    -  enabled, port: 1886, bind: 0.0.0.0
  system.adapter.nina.0                   : nina                  : Homee                                    - disabled
  system.adapter.parser.0                 : parser                : Homee                                    - disabled
  system.adapter.pegelalarm.0             : pegelalarm            : Homee                                    -  enabled
  system.adapter.pegelalarm.1             : pegelalarm            : Homee                                    -  enabled
+ system.adapter.pollenflug.0             : pollenflug            : Homee                                    -  enabled
+ system.adapter.rpi2.0                   : rpi2                  : Homee                                    -  enabled
+ system.adapter.rpi2.1                   : rpi2                  : kellerkind4GB                            -  enabled
+ system.adapter.rpi2.3                   : rpi2                  : PapaHuette                               -  enabled
+ system.adapter.rpi2.4                   : rpi2                  : Gartenklo                                -  enabled
+ system.adapter.smartmeter.0             : smartmeter            : Homee                                    -  enabled
+ system.adapter.sonoff.0                 : sonoff                : Homee                                    -  enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.systeminfo.0             : systeminfo            : Homee                                    -  enabled
+ system.adapter.systeminfo.1             : systeminfo            : kellerkind4GB                            -  enabled
+ system.adapter.systeminfo.3             : systeminfo            : PapaHuette                               -  enabled
+ system.adapter.systeminfo.4             : systeminfo            : Gartenklo                                -  enabled
+ system.adapter.tankerkoenig.0           : tankerkoenig          : Homee                                    -  enabled
  system.adapter.vis-bars.0               : vis-bars              : Homee                                    -  enabled
  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : Homee                                    -  enabled
  system.adapter.vis-history.0            : vis-history           : Homee                                    -  enabled
  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : Homee                                    -  enabled
  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : Homee                                    -  enabled
  system.adapter.vis-justgage.0           : vis-justgage          : Homee                                    -  enabled
  system.adapter.vis-metro.0              : vis-metro             : Homee                                    -  enabled
  system.adapter.vis-plumb.0              : vis-plumb             : Homee                                    -  enabled
  system.adapter.vis-rgraph.0             : vis-rgraph            : Homee                                    -  enabled
  system.adapter.vis-timeandweather.0     : vis-timeandweather    : Homee                                    -  enabled
  system.adapter.vis.0                    : vis                   : Homee                                    -  enabled
+ system.adapter.web.0                    : web                   : Homee                                    -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
  system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : Gartenklo                                - disabled
+ system.adapter.worx.2                   : worx                  : PapaHuette                               -  enabled
+ instance is alive
</code></pre>
<pre><code>pi@Homee:~ $ iobroker list adapters
system.adapter.admin                   : admin          - v5.3.8
system.adapter.backitup                : backitup       - v2.4.6
system.adapter.binance                 : binance        - v1.1.3
system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.7
system.adapter.daswetter               : daswetter      - v3.1.2
system.adapter.devices                 : devices        - v1.0.10
system.adapter.discovery               : discovery      - v3.0.3
system.adapter.ds18b20                 : ds18b20        - v1.5.4
system.adapter.dwd                     : dwd            - v2.8.3
system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.3.3
system.adapter.email                   : email          - v1.0.10
system.adapter.flot                    : flot           - v1.10.6
system.adapter.fritzbox                : fritzbox       - v0.2.1
system.adapter.growatt                 : growatt        - v1.1.15
system.adapter.history                 : history        - v1.9.13
system.adapter.ical                    : ical           - v1.12.1
system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.1.0
system.adapter.influxdb                : influxdb       - v2.6.3
system.adapter.info                    : info           - v1.9.18
system.adapter.javascript              : javascript     - v5.7.0
system.adapter.modbus                  : modbus         - v3.4.11
system.adapter.mqtt                    : mqtt           - v3.0.6
system.adapter.nina                    : nina           - v0.0.25
system.adapter.node-red                : node-red       - v2.0.1
system.adapter.onvif                   : onvif          - v0.4.4
system.adapter.parser                  : parser         - v1.1.4
system.adapter.pegelalarm              : pegelalarm     - v1.2.5
system.adapter.pollenflug              : pollenflug     - v1.0.6
system.adapter.roomba                  : roomba         - v1.1.4
system.adapter.rpi2                    : rpi2           - v1.3.2
system.adapter.simple-api              : simple-api     - v2.6.5
system.adapter.smartmeter              : smartmeter     - v3.3.4
system.adapter.sonoff                  : sonoff         - v2.5.1
system.adapter.systeminfo              : systeminfo     - v0.3.1
system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
system.adapter.tr-064                  : tr-064         - v4.2.14
system.adapter.upnp                    : upnp           - v1.0.19
system.adapter.vis                     : vis            - v1.4.15
system.adapter.vis-bars                : vis-bars       - v0.1.4
system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
system.adapter.vis-history             : vis-history    - v1.0.0
system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
system.adapter.vis-justgage            : vis-justgage   - v1.0.2
system.adapter.vis-metro               : vis-metro      - v1.2.0
system.adapter.vis-plumb               : vis-plumb      - v1.0.2
system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
system.adapter.web                     : web            - v4.2.3
system.adapter.whatsapp-cmb            : whatsapp-cmb   - v0.2.2
system.adapter.worx                    : worx           - v1.5.5
</code></pre>
<pre><code>pi@Homee:~ $ iobroker update -i
Adapter    "admin"        : 5.3.8    , installed 5.3.8
Adapter    "backitup"     : 2.4.6    , installed 2.4.6
Adapter    "binance"      : 1.1.3    , installed 1.1.3
Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
Adapter    "daswetter"    : 3.1.2    , installed 3.1.2
Adapter    "devices"      : 1.0.10   , installed 1.0.10
Adapter    "discovery"    : 3.0.3    , installed 3.0.3
Adapter    "dwd"          : 2.8.3    , installed 2.8.3
Adapter    "ecovacs-deebot": 1.4.4   , installed 1.3.3  [Updatable]
Adapter    "email"        : 1.0.10   , installed 1.0.10
Adapter    "growatt"      : 1.1.15   , installed 1.1.15
Adapter    "ical"         : 1.12.1   , installed 1.12.1
Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
Adapter    "javascript"   : 5.7.0    , installed 5.7.0
Controller "js-controller": 4.0.23   , installed 4.0.23
Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
Adapter    "nina"         : 0.0.25   , installed 0.0.25
Adapter    "parser"       : 1.1.5    , installed 1.1.4  [Updatable]
Adapter    "pegelalarm"   : 1.2.5    , installed 1.2.5
Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
Adapter    "socketio"     : 4.2.0    , installed 4.2.0
Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
Adapter    "web"          : 4.3.0    , installed 4.2.3  [Updatable]
Adapter    "ws"           : 1.3.0    , installed 1.3.0
</code></pre>
<pre><code>pi@Homee:~ $ uname -m &amp;&amp; which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; whoami &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
armv7l
/usr/bin/node
/usr/bin/npm
</code></pre>
<p dir="auto">Was kann das nun wieder sein? Adapter habe ich auch schon neu installiert.</p>
]]></description><link>https://forum.iobroker.net/topic/55570/worx2-file-index-html-not-found</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 16:31:24 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/55570.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Jun 2022 10:28:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Wed, 15 Jun 2022 19:12:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> Also hier steht der Adapter drin:</p>
system.adapter.backitup                : backitup       - v2.4.9
system.adapter.ecovacs-deebot          : ecovacs-deebot - v1.4.4
system.adapter.landroid                : landroid       - v1.0.3
system.adapter.parser                  : parser         - v1.1.5
system.adapter.web                     : web            - v4.3.0
</code></pre>
<p dir="auto">hier als disable (vermutlich weil ich den Adapter gestoppt habe):</p>
+ system.adapter.landroid.2               : landroid              : PapaHuette                               -  enabled
  system.adapter.worx.2                   : worx                  : PapaHuette                               - disabled
</code></pre>
<p dir="auto">deinstalliert und dann neu installiert habe ich den auch schon</p>
<p dir="auto">Update: erneut deinstalliert und wieder installiert. Jetzt läuft's wieder.</p>
]]></description><link>https://forum.iobroker.net/post/814863</link><guid isPermaLink="true">https://forum.iobroker.net/post/814863</guid><dc:creator><![CDATA[SMS]]></dc:creator><pubDate>Wed, 15 Jun 2022 19:12:00 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Wed, 15 Jun 2022 18:28:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sms" aria-label="Profile: sms">@<bdi>sms</bdi></a> laut deinem iobroker update -i gibt es den Adapter auch nicht, ebenso fehlt der whatsapp-cmb und noch ein paar andere</p>
]]></description><link>https://forum.iobroker.net/post/814846</link><guid isPermaLink="true">https://forum.iobroker.net/post/814846</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Wed, 15 Jun 2022 18:28:07 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Wed, 15 Jun 2022 12:52:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Ich komm ja gar nicht soweit das ich was ändern könnte:</p>
<p dir="auto"><img src="/assets/uploads/files/1654954287436-b3d93aa4-d96b-4d74-aee0-e9fd51e538dc-image.png" alt="b3d93aa4-d96b-4d74-aee0-e9fd51e538dc-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/814741</link><guid isPermaLink="true">https://forum.iobroker.net/post/814741</guid><dc:creator><![CDATA[SMS]]></dc:creator><pubDate>Wed, 15 Jun 2022 12:52:13 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Wed, 15 Jun 2022 12:27:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sms" aria-label="Profile: sms">@<bdi>sms</bdi></a> sagte in <a href="/post/814724">worx2: File index.html not found :{}:</a>:</p>
<blockquote>
<p dir="auto">Check the <code>username</code></p>
</blockquote>
<p dir="auto">Username korrekt? Sonderzeichen drin?</p>
]]></description><link>https://forum.iobroker.net/post/814734</link><guid isPermaLink="true">https://forum.iobroker.net/post/814734</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 15 Jun 2022 12:27:26 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Wed, 15 Jun 2022 11:55:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> Hallo</p>
<p dir="auto">nachdem noch ein anderer Adapter ausgestiegen ist, habe ich das oben genannte auf dem Master durchgeführt. Leider ohne Erfolg. Beim starten steht folgende Meldung im LOG:</p>
<pre><code>worx.2
2022-06-15 13:53:39.383	error	ERROR: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}
worx.2
2022-06-15 13:53:39.381	error	Could not Connect to Worx Server: StatusCodeError: 400 - {"error":"invalid_request","error_description":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.","hint":"Check the `username` parameter","message":"The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed."}
worx.2
2022-06-15 13:53:39.034	info	worx is selected
worx.2
2022-06-15 13:53:38.996	info	starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.worx, node: v14.19.3, js-controller: 4.0.23
worx.2
2022-06-15 13:53:33.428	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
worx.2
2022-06-15 13:53:33.424	info	terminating
worx.2
2022-06-15 13:53:33.422	info	cleaned everything up...
worx.2
2022-06-15 13:53:33.413	info	Got terminate signal TERMINATE_YOURSELF
</code></pre>
]]></description><link>https://forum.iobroker.net/post/814724</link><guid isPermaLink="true">https://forum.iobroker.net/post/814724</guid><dc:creator><![CDATA[SMS]]></dc:creator><pubDate>Wed, 15 Jun 2022 11:55:37 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Sat, 11 Jun 2022 13:39:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sms" aria-label="Profile: sms">@<bdi>sms</bdi></a> sagte in <a href="/post/813224">worx2: File index.html not found :{}:</a>:</p>
<blockquote>
<p dir="auto">Ich habe das jetzt auf dem Slave gemacht, auf dem der Adapter läuft.</p>
</blockquote>
<p dir="auto">aber nur die Instanz!<br />
die Adapterdateien liegen auf dem Master</p>
]]></description><link>https://forum.iobroker.net/post/813229</link><guid isPermaLink="true">https://forum.iobroker.net/post/813229</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 11 Jun 2022 13:39:54 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Sat, 11 Jun 2022 13:31:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/813200">worx2: File index.html not found :{}:</a>:</p>
<p dir="auto">Ich habe das jetzt auf dem Slave gemacht, auf dem der Adapter läuft. Hat leider nichts gebracht:</p>
<p dir="auto"><img src="/assets/uploads/files/1654954111601-9359d490-27be-4c36-8b71-b909d5347311-image.png" alt="9359d490-27be-4c36-8b71-b909d5347311-image.png" class=" img-fluid img-markdown" /><br />
<p dir="auto">Soll ich das auf dem Master auch machen?</p>
]]></description><link>https://forum.iobroker.net/post/813224</link><guid isPermaLink="true">https://forum.iobroker.net/post/813224</guid><dc:creator><![CDATA[SMS]]></dc:creator><pubDate>Sat, 11 Jun 2022 13:31:30 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Sat, 11 Jun 2022 12:37:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sms" aria-label="Profile: sms">@<bdi>sms</bdi></a></p>
<pre><code>sudo apt update
sudo apt full-upgrade
sudo reboot
</code></pre>
<p dir="auto">Dann</p>
<pre><code>iobroker update
iobroker upgrade
</code></pre>
]]></description><link>https://forum.iobroker.net/post/813200</link><guid isPermaLink="true">https://forum.iobroker.net/post/813200</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 11 Jun 2022 12:37:21 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Sat, 11 Jun 2022 10:39:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> OK! Danke!</p>
]]></description><link>https://forum.iobroker.net/post/813137</link><guid isPermaLink="true">https://forum.iobroker.net/post/813137</guid><dc:creator><![CDATA[SMS]]></dc:creator><pubDate>Sat, 11 Jun 2022 10:39:50 GMT</pubDate></item><item><title><![CDATA[Reply to worx2: File index.html not found :{}: on Sat, 11 Jun 2022 10:35:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sms" aria-label="Profile: sms">@<bdi>sms</bdi></a> soll ich das Thema nicht besser teilen?<br />
Hat doch mit vis nichts zu tun, oder?</p>
]]></description><link>https://forum.iobroker.net/post/813135</link><guid isPermaLink="true">https://forum.iobroker.net/post/813135</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 11 Jun 2022 10:35:56 GMT</pubDate></item></channel></rss>
