  3. Off Topic
  4. Proxmox
  5. Proxmox Fehler nach rebuild
    3.2k
Geplant Angeheftet Gesperrt Verschoben Proxmox
proxmoxnodezigbee
20 Beiträge 4 Kommentatoren 1.1k Aufrufe 2 Beobachtet
  • T toki1973
    @crunchip Danke. Es schient so als ob ich das gleiche Problem mit der Speicherbelegung habe. Aber so ganz genau kann ich im verlinkten Thread nicht nachvollziehen wir ich vorgehen kann.
    Hier mal ein paar infos zu meiner Konfiguration.
    root@proxmox:~# lvm
    lvm>
    root@proxmox:~# lvs
      LV                                              VG  Attr       LSize    Pool Origin                       Data%  Meta%  Move Log Cpy%Sync Convert
      data                                            pve twi-aotzD- <152.61g                                   100.00 5.85
      root                                            pve -wi-ao----   59.25g
      snap_vm-100-disk-0_Grundinstallation_aus_Backup pve Vri---tz-k   32.00g data vm-100-disk-0
      snap_vm-100-disk-0_MitGrafanaInfluxDBundZigbee  pve Vri---tz-k   32.00g data vm-100-disk-0
      snap_vm-100-disk-0_YearlySnap                   pve Vri---tz-k   32.00g data vm-100-disk-0
      snap_vm-101-disk-0_Working                      pve Vri---tz-k   32.00g data vm-101-disk-0
      snap_vm-102-disk-0_vorUpdate                    pve Vri---tz-k   32.00g data
      snap_vm-200-disk-0_GrafanaInitial               pve Vri---tz-k   20.00g data vm-200-disk-0
      snap_vm-200-disk-0_Initial                      pve Vri---tz-k   20.00g data vm-200-disk-0
      snap_vm-200-disk-0_YearlySnap                   pve Vri---tz-k   20.00g data vm-200-disk-0
      snap_vm-200-disk-0_working                      pve Vri---tz-k   20.00g data vm-200-disk-0
      swap                                            pve -wi-ao----    7.00g
      vm-100-disk-0                                   pve Vwi-a-tz--   32.00g data                              99.87
      vm-100-state-Grundinstallation_aus_Backup       pve Vwi-a-tz--    8.44g data                              12.37
      vm-100-state-MitGrafanaInfluxDBundZigbee        pve Vwi-a-tz--    8.44g data                              35.17
      vm-100-state-YearlySnap                         pve Vwi-a-tz--    8.44g data                              51.92
      vm-101-disk-0                                   pve Vwi-aotz--   32.00g data                              34.32
      vm-102-disk-0                                   pve Vwi-aotz--   32.00g data snap_vm-102-disk-0_vorUpdate 99.51
      vm-102-state-vorUpdate                          pve Vwi-a-tz--    8.30g data                              51.88
      vm-200-disk-0                                   pve Vwi-aotz--   20.00g data                              85.86
      vm-200-state-GrafanaInitial                     pve Vwi-a-tz--   <4.49g data                              14.21
      vm-200-state-Initial                            pve Vwi-a-tz--   <4.49g data                              37.55
      vm-200-state-YearlySnap                         pve Vwi-a-tz--   <4.49g data                              43.57
      vm-200-state-working                            pve Vwi-a-tz--   <4.49g data                              23.40
    root@proxmox:~#
    Die 100er lvm war meine alte Konfiguration. diese läßt sich aber nicht löschen:
    crunchipC Offline
    crunchipC Offline
    @toki1973 https://forum.iobroker.net/post/801905
    Und warum so viele snaps?
      toki1973
      @crunchip Ich würde ja gerne etwas entfernen kann das aber nicht - siehe letzte Screen Shot. Auch die 100 würde ich gerne löschen ist aber nicht möglich.
      Was kann ich denn tun? Geht das über die Konsole?
      NUC, PROXMOX, Grafana, Influx, Unify
      • T toki1973
        crunchipC Offline
        crunchipC Offline
        @toki1973 sagte in Proxmox Fehler nach rebuild:
        Hast du dir den link durchgelesen, da wird die Meldung behandelt
          toki1973
          @crunchip Ja habe ich - aber irgendwie komme ich da nicht ganz zurecht damit. Ich hatte gehofft durch das posten von Screen kann mir jemand konkret das vorgehen beschreiben
          • T toki1973
            crunchipC Offline
            crunchipC Offline
            Es steh doch genau ab hier (die vmid natürlich an deine Vm Nummer anpassen)
            https://forum.iobroker.net/post/803090
            Oder schau da https://forum.proxmox.com/threads/solved-nicht-mehr-benutztes-disk-image-von-vm-kann-nicht-gelöscht-werden.75131/
            pct rescan...für LXC
            qm rescan...für VM
            Und deinen Threadtitel solltest du anpassen
              qm rescan...für VM
              toki1973
              @crunchip
              Danke für deine Geduld:
              Ich hatte das hier probiert: 'qm rescan --vmid 100 von https://forum.proxmox.com/threads/solved-nicht-mehr-benutztes-disk-image-von-vm-kann-nicht-gelöscht-werden.75131/
              Das ging nicht mit der Fehlermeldung Volume not online
              root@proxmox:~# qm rescan --vmid 100
              rescan volumes...
              storage 'SynologyNAS' is not online
              root@proxmox:~# qm rescan --vmid 102
              rescan volumes...
              root@proxmox:~# qm rescan --vmid 200
              rescan volumes...
              root@proxmox:~# qm rescan --vmid 101
              rescan volumes...
              root@proxmox:~#
              Dieser Fehler kommt dann natürlich auch wenn ich über die GUI auf entfernen gehe
              • T toki1973
                @crunchip
                rescan volumes...
                rescan volumes...
                rescan volumes...
                rescan volumes...
                root@proxmox:~#
                crunchipC Offline
                crunchipC Offline
                @toki1973 und warum sind beide Nas nicht verbunden?
                Wenn du den laufenden Lxc bzw Vm anklickst, kannst du doch in der Gui auf snapshot wechseln, zeig mal
                  toki1973
                  schrieb am zuletzt editiert von toki1973
                  @crunchip
                  Dann beim Entfernen:
                  Liegt vlt. daran das die Storage nicht online sind?
                  • crunchipC Offline
                    crunchipC Offline
                    @toki1973 ja, aber irgendwas hast du doch gelöscht, dein local-lvm ist doch laut deinem screen, jetzt nicht mehr voll
                      toki1973
                      @crunchip
                      Hat den Snaphot wohl doch gelöscht trotz Fehlermeldung. War dann gelocked aber dazu habe ich auch etwas gefunden.
                      Aber bevor ich richtige Backups der VMs mache sollte ich noch irgendwie aufräumen. Ich schaue mir nochmal deinen Thread an in dem du @GOETSCHHOFER geholfen hast. Vlt. verstehe ich das Konstrukt dann besser...
