  4. Zigbee stürzt beim schalten von Birnen über Shalter ab
22 Beiträge 9 Kommentatoren 3.7k Aufrufe 7 Beobachtet
  • E earl80
    @david-g @arteck ist bei mir ähnlich
    code_text
    host.raspberrypi
    2022-06-03 04:50:09.070 error instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.raspberrypi
    2022-06-03 04:50:09.070 error Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
    host.raspberrypi
    2022-06-03 04:50:09.070 error Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
    host.raspberrypi
    2022-06-03 04:50:09.069 error Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
    host.raspberrypi
    2022-06-03 04:50:09.069 error Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
    host.raspberrypi
    2022-06-03 04:50:09.069 error Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
    host.raspberrypi
    2022-06-03 04:50:09.069 error Caught by controller[1]: TypeError: Cannot read property 'color_options' of undefined
    host.raspberrypi
    2022-06-03 04:50:09.068 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    2022-06-03 04:50:07.894 error Cannot read property 'color_options' of undefined
    zigbee.0
    2022-06-03 04:50:07.893 error TypeError: Cannot read property 'color_options' of undefined at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
    zigbee.0
    2022-06-03 04:50:07.887 error unhandled promise rejection: Cannot read property 'color_options' of undefined
    zigbee.0
    2022-06-03 04:50:07.886 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Einstein67
    Kann ich bestätigen. Hab auch IKEA Lampen
    2022-06-03 06:00:55.929 - warn: zigbee.0 (17889) Device '0x2c1165fffee4589c' announced itself
    2022-06-03 06:00:55.933 - error: zigbee.0 (17889) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-06-03 06:00:55.933 - error: zigbee.0 (17889) unhandled promise rejection: Cannot read properties of undefined (reading 'color_options')
    2022-06-03 06:00:55.934 - error: zigbee.0 (17889) TypeError: Cannot read properties of undefined (reading 'color_options')
    2022-06-03 06:00:55.934 - error: zigbee.0 (17889) Cannot read properties of undefined (reading 'color_options')
    2022-06-03 06:00:55.948 - info: zigbee.0 (17889) cleaned everything up...
    2022-06-03 06:00:55.969 - info: zigbee.0 (17889) Zigbee: disabling joining new devices.
    2022-06-03 06:00:56.448 - info: zigbee.0 (17889) terminating
    2022-06-03 06:00:56.449 - warn: zigbee.0 (17889) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'color_options')
    2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
    2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
    2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
    2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
    2022-06-03 06:00:56.997 - error: host.iob18ig Caught by controller[0]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
    2022-06-03 06:00:56.998 - error: host.iob18ig instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-06-03 06:00:56.998 - info: host.iob18ig Restart adapter system.adapter.zigbee.0 because enabled
    • arteckA Offline
      arteckA Offline
      arteck
      color_options
      da ist ein bug im converter.und sind nur ikea lampen betroffen
      @earl80 Logs bitte in Code tag.. kann man besser lesen
      • arteckA arteck
        color_options
        M-A-X
        @arteck bei mir kommt es zum selben Fehler (soweit ich das erkenne) wie bei @earl80
        zigbee.0
        2022-06-03 08:01:18.099	error	TypeError: Cannot read property 'color_options' of undefined at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
        zigbee.0
        2022-06-03 08:01:18.095	error	unhandled promise rejection: Cannot read property 'color_options' of undefined
        zigbee.0
        2022-06-03 08:01:18.094	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.iobroker
        2022-06-03 07:51:58.562	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        2022-06-03 07:51:58.561	error	Caught by controller[5]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
        host.iobroker
        2022-06-03 07:51:58.560	error	Caught by controller[5]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
        host.iobroker
        2022-06-03 07:51:58.561	error	Caught by controller[5]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
        host.iobroker
        2022-06-03 07:51:58.560	error	Caught by controller[5]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
        host.iobroker
        2022-06-03 07:51:58.559	error	Caught by controller[5]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
        host.iobroker
        2022-06-03 07:51:58.559	error	Caught by controller[5]: TypeError: Cannot read property 'color_options' of undefined
        host.iobroker
        2022-06-03 07:51:58.559	error	Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        host.iobroker
        2022-06-03 07:51:58.558	error	Caught by controller[3]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
        host.iobroker
        2022-06-03 07:51:58.558	error	Caught by controller[3]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
        host.iobroker
        2022-06-03 07:51:58.558	error	Caught by controller[3]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
        host.iobroker
        2022-06-03 07:51:58.557	error	Caught by controller[3]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
        host.iobroker
        2022-06-03 07:51:58.552	error	Caught by controller[3]: TypeError: Cannot read property 'color_options' of undefined
        host.iobroker
        2022-06-03 07:51:58.551	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        host.iobroker
        2022-06-03 07:51:58.551	error	Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
        host.iobroker
        2022-06-03 07:51:58.552	error	Caught by controller[3]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
        host.iobroker
        2022-06-03 07:51:58.550	error	Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
        host.iobroker
        2022-06-03 07:51:58.551	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
        host.iobroker
        2022-06-03 07:51:58.550	error	Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
        host.iobroker
        2022-06-03 07:51:58.549	error	Caught by controller[1]: TypeError: Cannot read property 'color_options' of undefined
        host.iobroker
        2022-06-03 07:51:58.548	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        host.iobroker
        2022-06-03 07:51:58.549	error	Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:39:19)
        host.iobroker
        2022-06-03 07:51:58.548	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce
        Es handelt sich um Ikea Gu10 color spots.
        Das sind bei mir die einzigen zigbee Geräte, die durch einen Schalter stromlos geschaltet werden. Ansonsten müsste der Fehler ja immer kommen, wenn ich ein zigbee Gerät vom Strom nehme und wieder anschließe?
        • M M-A-X
          zigbee.0
          zigbee.0
          zigbee.0
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          arteckA Offline
          arteckA Offline
          arteck
          @m-a-x nein ES SIND NUR DIE IKEA BETROFFEN..und nur weil ihr die Spots vom Strom trennt
          das ist das wiedereinschalten Verhalten nach Stromlos
          • arteckA Offline
            arteckA Offline
            arteck
            kann einer was testen
            adapter stopen
            dann in den konsole
            nano /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js
            in zeile 39
            if (state.color_options !== undefined && state.color_options.execute_if_off === true) {
            ändern in
            if (state !== undefined && state.color_options.execute_if_off === true) {
            und zeile 42
            if (state.level_config !== undefined && state.level_config.execute_if_off === true) {
            in
            if (state!== undefined && state.level_config.execute_if_off === true) {
            adapter starten
            • arteckA arteck
              adapter stopen
              dann in den konsole
              in zeile 39
              ändern in
              und zeile 42
              in
              adapter starten
              M-A-X
              schrieb am zuletzt editiert von M-A-X
              @arteck
              Muss das von unterwegs auf dem Handy über VPN machen. Hoffe es geht nichts schief :)
              code_textst.iobroker
              2022-06-03 08:45:08.162	info	Restart adapter system.adapter.zigbee.0 because enabled
              host.iobroker
              2022-06-03 08:45:08.162	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              host.iobroker
              2022-06-03 08:45:08.162	error	Caught by controller[1]: at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
              host.iobroker
              2022-06-03 08:45:08.162	error	Caught by controller[1]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54)
              host.iobroker
              2022-06-03 08:45:08.161	error	Caught by controller[1]: at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18)
              host.iobroker
              2022-06-03 08:45:08.161	error	Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26)
              host.iobroker
              2022-06-03 08:45:08.161	error	Caught by controller[1]: at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:42:19)
              host.iobroker
              2022-06-03 08:45:08.160	error	Caught by controller[1]: TypeError: Cannot read property 'level_config' of undefined
              host.iobroker
              2022-06-03 08:45:08.159	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
              zigbee.0
              2022-06-03 08:45:07.539	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              zigbee.0
              2022-06-03 08:45:07.537	info	terminating
              zigbee.0
              2022-06-03 08:45:07.225	info	Zigbee: disabling joining new devices.
              zigbee.0
              2022-06-03 08:45:07.036	info	cleaned everything up...
              zigbee.0
              2022-06-03 08:45:07.022	error	Cannot read property 'level_config' of undefined
              zigbee.0
              2022-06-03 08:45:07.021	error	TypeError: Cannot read property 'level_config' of undefined at Object.bulbOnEvent [as onEvent] (/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/ikea.js:42:19) at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:44:26) at DeviceEvent.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:26:18) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:236:54) at ZigbeeController.handleDeviceAnnounce (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:18)
              zigbee.0
              2022-06-03 08:45:07.018	error	unhandled promise rejection: Cannot read property 'level_config' of undefined
              zigbee.0
              2022-06-03 08:45:07.017	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0
              2022-06-03 08:45:07.009	warn	Device '0x2c1165fffe9542d9' announced itself
              web.0
              2022-06-03 08:44:58.839	info	==> Connected system.user.admin from ::ffff:192.168.9.101
              zigbee.0
              2022-06-03 08:44:34.132	info	Zigbee started
              • M M-A-X
                @arteck
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                web.0
                zigbee.0
                arteckA Offline
                arteckA Offline
                arteck
                @m-a-x du musst noch eine zeile ändern
                • arteckA arteck
                  M-A-X
                  @arteck oh sorry. Hab ich überlesen... Handy Ansicht und so.
                  Scheint wieder zu funktionieren. Meine Frau sagt auch das Licht ist an und aus gegangen :)
                  zigbee.0
                  2022-06-03 09:04:48.906	warn	Device '0x2c1165fffe7d55cd' announced itself
                  zigbee.0
                  2022-06-03 09:04:48.655	warn	Device '0x2c1165fffe94ad5d' announced itself
                  zigbee.0
                  2022-06-03 09:04:48.420	warn	Device '0x2c1165fffe85b3f6' announced itself
                  zigbee.0
                  2022-06-03 09:04:48.402	warn	Device '0x2c1165fffe7d68a2' announced itself
                  zigbee.0
                  2022-06-03 09:04:48.389	warn	Device '0x2c1165fffe8a05ce' announced itself
                  zigbee.0
                  2022-06-03 09:04:48.387	warn	Device '0x2c1165fffe2cd033' announced itself
                  zigbee.0
                  2022-06-03 09:04:48.359	warn	Device '0x2c1165fffe9542d9' announced itself
                  web.0
                  2022-06-03 09:04:38.708	info	==> Connected system.user.admin from ::ffff:192.168.9.101
                  zigbee.0
                  2022-06-03 09:04:12.555	info	Zigbee started
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    ich hab ne korektur eingestellt im converter... wird bestimmt dauern..
                    aber so ist euch erstmal geholfen
                    E David G.D 2 Antworten Letzte Antwort
                    • arteckA arteck
                      Einstein67
                      @arteck Funktioniert!!
                      Vielen Dank!
                      • arteckA arteck
                        David G.D Online
                        David G.D Online
                        David G.
                        @arteck
                        Müssen wir die Zeilen jetzt bei jedem Update des Adapters ändern, bis das im Converter gefixt wurde?
                        Danke für die schnelle Hilfe.
                        • David G.D David G.
                          @arteck
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @david-g wenn du von Git installierst dann ja..
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            korrektur ist ab sofort auf GIT verfügbar
                            M E 2 Antworten Letzte Antwort
                            • arteckA arteck
                              Martin-72
                              @arteck Ich habe das Problem auch noch. Ich habe den Adapter aber über die Adapterverwaltung vom ioBroker installiert:
                              Gibt es schon Hochrechnungen, wann die Fehlerbehebung auch dort ankommt?
                              Oder soll ich den weiter oben beschriebenen Weg wählen? Muss / (Wie) Kann ich die Adapter sichern und wieder einspielen, um nicht alles neu anlernen zu müssen...?
                              Vielen Dank
                              Martin
                              • M Martin-72
                                Vielen Dank
                                Martin
                                amg_666A Offline
                                amg_666A Offline
                                amg_666
                                @martin-72 Du kannst den über github installieren. In der Adminoberfläche auf die "Katze" tippen und da dann zigbee eingeben und den Adapter installieren. Das ist dasselbe wie ein Versionsupdate über die Adapterverwaltung, nur dass es halt "Beta" ist und noch nicht "offiziell", sichern musst du da eigentlich nichts, ist nur ne neue Version.
                                • amg_666A amg_666
                                  Martin-72
                                  Vielen Dank
                                  Liebe Grüße
                                  Martin
                                  • arteckA arteck
                                    ewf04214
                                    schrieb am zuletzt editiert von ewf04214
                                    @arteck Das Problem besteht seit geraumer Zeit wieder. Was genau meinst du mit Bug im Converter, kommt der Converter von dir, oder bindest du etwas externes ein? Dann müsste man den Fehler ja dort melden.
                                    Guten Rutsch
                                    • E ewf04214
                                      Guten Rutsch
                                      dimaiv
                                      @ewf04214
                                      Aktuelle Stand: vor 3 Stunden über Git installiert, alles mögliche probiert, KENE FEHLER !
                                      Guten Rutsch!
                                      ioBroker- NUC8i3 / Proxmox / VM
                                      Node.js v22.21.0
                                      NPM v10.9.4
                                      JS controller 7.1.0
                                      Admin 7.7.20
                                      ZigBee Adapter 3.3.1alpha.0
                                      Zigbee LAN Gateway CC2652P
                                      Zigbee Firmware 20250321
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        1.9.6 ist unterwegs
                                        E 1 Antwort Letzte Antwort
                                        • arteckA arteck
                                          1.9.6 ist unterwegs
                                          ewf04214
                                          @arteck danke, auf den ersten Blick scheints zu funktionieren, Geräte Annoncen sich, und der Adapter bleibt online.
