  3. Off Topic
  4. InfluxDB
  5. Beim Installieren von influx CLI
Geplant Angeheftet Gesperrt Verschoben InfluxDB
78 Beiträge 4 Kommentatoren 9.5k Aufrufe 3 Beobachtet
  • E Offline
    Einstein2002
    ist das normal oder mache ich da was falsch?
    Halte mich an die Anleitung und der Download hat auch ohne Fehler geklappt,
    wget https://dl.influxdata.com/influxdb/releases/influxdb2-client-2.3.0-linux-amd64.tar.gz
    beim Entpacken mit: tar xvzf path/to/influxdb2-client-2.3.0-linux-amd64.tar.gz kommt dann ein Fehler.
    root@Influxdb2:~# service influxdb status
    * influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
         Active: active (running) since Wed 2022-06-01 09:47:09 UTC; 31min ago
           Docs: https://docs.influxdata.com/influxdb/
        Process: 113 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
       Main PID: 119 (influxd)
          Tasks: 8 (limit: 76884)
         Memory: 109.2M
            CPU: 635ms
         CGroup: /system.slice/influxdb.service
                 `-119 /usr/bin/influxd
    Jun 01 09:47:08 Influxdb2 influxd-systemd-start.sh[119]: ts=2022-06-01T09:47:08.146511Z lvl=info msg="Starting retention policy enforcement service" log_id=0aofRDpl000 service=retention check_interval=30m
    Jun 01 09:47:08 Influxdb2 influxd-systemd-start.sh[119]: ts=2022-06-01T09:47:08.146520Z lvl=info msg="Starting precreation service" log_id=0aofRDpl000 service=shard-precreation check_interval=10m advance_period=30m
    Jun 01 09:47:08 Influxdb2 influxd-systemd-start.sh[119]: ts=2022-06-01T09:47:08.147275Z lvl=info msg="Starting query controller" log_id=0aofRDpl000 service=storage-reads concurrency_quota=1024 initial_memory_bytes_quota_per_query=9223372036854775807 m>
    Jun 01 09:47:08 Influxdb2 influxd-systemd-start.sh[119]: ts=2022-06-01T09:47:08.148476Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0aofRDpl000 max_select_point=0 max_select_series=0 max_select_buckets=0
    Jun 01 09:47:08 Influxdb2 influxd-systemd-start.sh[119]: ts=2022-06-01T09:47:08.162511Z lvl=info msg=Listening log_id=0aofRDpl000 service=tcp-listener transport=http addr=:8086 port=8086
    Jun 01 09:47:08 Influxdb2 influxd-systemd-start.sh[119]: ts=2022-06-01T09:47:08.162529Z lvl=info msg=Starting log_id=0aofRDpl000 service=telemetry interval=8h
    Jun 01 09:47:09 Influxdb2 influxd-systemd-start.sh[113]: InfluxDB started
    Jun 01 09:47:09 Influxdb2 systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
    Jun 01 10:17:08 Influxdb2 influxd-systemd-start.sh[119]: ts=2022-06-01T10:17:08.146836Z lvl=info msg="Retention policy deletion check (start)" log_id=0aofRDpl000 service=retention op_name=retention_delete_check op_event=start
    Jun 01 10:17:08 Influxdb2 influxd-systemd-start.sh[119]: ts=2022-06-01T10:17:08.146864Z lvl=info msg="Retention policy deletion check (end)" log_id=0aofRDpl000 service=retention op_name=retention_delete_check op_event=end op_elapsed=0.038ms
    root@Influxdb2:~# influx version
    Influx CLI 2.3.0 (git: 88ba346) build_date: 2022-04-06T19:30:53Z
    root@Influxdb2:~# ls -la
    total 5252
    drwx------  3 root root    4096 Jun  1 09:54 .
    drwxr-xr-x 18 root root    4096 Jun  1 09:47 ..
    -rw-------  1 root root     824 Jun  1 09:47 .bash_history
    -rw-r--r--  1 root root    3106 Jul 28  2020 .bashrc
    drwx------  2 root root    4096 Jun  1 09:38 .cache
    -rw-r--r--  1 root root     161 Apr 28  2021 .profile
    -rw-r--r--  1 root root 5350662 Apr  6 19:32 influxdb2-client-2.3.0-linux-amd64.tar.gz
    root@Influxdb2:~# tar xvzf path/to/influxdb2-client-2.3.0-linux-amd64.tar.gz
    tar (child): path/to/influxdb2-client-2.3.0-linux-amd64.tar.gz: Cannot open: No such file or directory
    tar (child): Error is not recoverable: exiting now
    tar: Child returned status 2
    tar: Error is not recoverable: exiting now
    root@Influxdb2:~#
    Was soll ich machen?
    Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
    Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
    • E Einstein2002
           Memory: 109.2M
              CPU: 635ms
      total 5252
      root@Influxdb2:~#
      SBorgS Offline
      SBorgS Offline
      SBorg
      @einstein2002
      Zuerst nicht als root arbeiten ;)
      Mit
      steht "path/to" für das Verzeichnis in dem die tar.gz gedownloaded wurde und muss damit ersetzt werden. Wenn sie im aktuellen Verzeichnis liegt wäre
      tar xvzf ./influxdb2-client-2.3.0-linux-amd64.tar.gz
      korrekt.
      LG SBorg ( SBorg auf GitHub)
      E crunchipC 2 Antworten Letzte Antwort
      • SBorgS SBorg
        @einstein2002
        Mit
        korrekt.
        Einstein2002
        @sborg
        Danke hab sie eben erst aufgesetzt und noch keinen User eingerichtet. Ist aber jetzt gemacht.
        Muss ich die ganzen Schritte unter dem neuen User auch noch einmal machen?
        • SBorgS SBorg
          @einstein2002
          Mit
          korrekt.
          crunchipC Abwesend
          crunchipC Abwesend
          @sborg oder man installier per apt
          E 1 Antwort Letzte Antwort
            Einstein2002
            @crunchip
            das steht leider nicht in der Doku
            aber wäre das dann apt get influx
            crunchipC E 2 Antworten Letzte Antwort
            • E Einstein2002
              @crunchip
              crunchipC Abwesend
              crunchipC Abwesend
              @einstein2002 da musst du die repo list anlegen und dann kann man per Apt installieren. Influxdb und influx cli
              • E Einstein2002
                @crunchip
                Einstein2002
                @einstein2002
                Das heißt um es jetzt endlich mal richtig zu verstehen:
                LXC erstellen und dann als erstes einen neuen User anlegen
                Mit dem einloggen und alle schritte machen.
                Ist das so richtig???
                crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                • E Einstein2002
                  @einstein2002
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @einstein2002 ja, schau in die Doku, da steht was bei einem Lxc zu tun ist bevor man etwas installiert
                  • E Einstein2002
                    @einstein2002
                    @einstein2002
                    Ja, als erstes einen user anlegen. Dem dann sudo-Rechte verpassen,
                    Und unter Linux/Debian installiert man so gut wie nie direkt Programme, man nutzt seinen Paketmanager dafür.
                    Falls aktuellere Versionen von influxdb verwendet werden sollen als 'von Haus aus' dem Debian Release beiliegen muss/sollte man eine Softwarequelle/Repository anlegen.
                    Für influxdb so:
                    https://docs.influxdata.com/influxdb/v1.8/introduction/install/
                    wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor > /etc/apt/trusted.gpg.d/influxdb.gpg
                    export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                    echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" > /etc/apt/sources.list.d/influxdb.list
                    (Wobei das nicht als user funktioniert, mach das ausnahmsweise mal als root. Ich muss das mal umbauen, dass es auch als user funktioniert.)
                    E 3 Antworten Letzte Antwort
                      @einstein2002
                      Für influxdb so:
                      Einstein2002
                      Das hab ich eben über sudo rechte erlesen,
                      Benutzer erstellen und root rechte erteilen
                      Ubuntu 18.04, Ubuntu 20.04, Debian 10 und Debian 11
                      • Loggen Sie sich als Root-Benutzer auf dem gewünschten Server ein.
                      • Um einen neuen Benutzer zu erstellen, geben Sie den folgenden Befehl ein:
                      [root@localhost ~]# adduser BENUTZERNAME
                      Beispiel:
                      [root@localhost ~]# adduser maxmustermann
                      • Geben Sie das gewünschte Passwort ein und wiederholen Sie es.
                      • Optional: Geben Sie zusätzliche Benutzerinformationen ein. Um die Eingabe dieser Informationen zu überspringen, drücken Sie die Enter-Taste.
                      Changing the user information for maxmustermann
                      Enter the new value, or press ENTER for the default
                      Full Name [ ]:
                      Room Number [ ]:
                      Work Phone [ ]:
                      Home Phone [ ]:
                      Other [ ]:
                      Is the information correct? [Y/n]
                      • Geben Sie Y ein und drücken Sie die Enter-Taste.
                      Debian und Ubuntu
                      Um einem Benutzer in Debian und Ubuntu sudo-Rechte zuzuweisen, müssen Sie diesen zur Gruppe sudo hinzufügen. Um den Benutzer dieser Gruppe hinzuzufügen, geben Sie den folgenden Befehl ein:
                      [root@localhost ~]# usermod -aG sudo BENUTZERNAME
                      Beispiel
                      [root@localhost ~]# usermod -aG sudo maxmustermann
                      Um zu kontrollieren, ob die Änderung erfolgreich war, geben Sie den folgenden Befehl ein:
                      localhost:~ # groups BENUTZERNAME
                      Beispiel:
                      localhost:~ # groups maxmustermann
                      Ist das soweit in Ordnung?
                      Ps. Sorry für die Mühe und Arbeit mit mir!! Dankeschön
                      • E Einstein2002
                        Beispiel:
                        Full Name [ ]:
                        Room Number [ ]:
                        Work Phone [ ]:
                        Home Phone [ ]:
                        Other [ ]:
                        Debian und Ubuntu
                        Beispiel
                        Beispiel:
                        @einstein2002 sagte in Beim Installieren von influx CLI:
                        Ja. Schaut soweit i. O. aus.
                          @einstein2002
                          Für influxdb so:
                          Einstein2002
                          Soweit ganz gut, aber wenn ich 1-3 ausführe dann mit apt installiere macht er ja die 1.8 drauf.
                          Ich hatte aber schon 2xx glaube ich drauf.
                          Und beim weiterleiten auf die neue Webseite komm ich wieder dahin wo ich ganz am Anfang war.
                          Um dann doch wieder von hand zu installieren.
                          https://docs.influxdata.com/influxdb/v1.8/introduction/install/ Version 1.8
                          https://docs.influxdata.com/influxdb/v2.2/install/ Version2.2
                          • E Einstein2002
                            @einstein2002
                            Nein, die Pakete heißen unterschiedlich, kommen aber aus dem gleichen Repository.
                            apt policy influxdb influxdb2
                            zeigt dir das, wenn das Repo sauber drin ist und die Quellen per
                            sudo apt update
                            aktualisiert wurden.
                            (Die Anleitung von influx selber ist aber auch zum Heulen schlecht, stimmt)
                            • E Einstein2002
                              @einstein2002
                              So schaut das mit richtigem Setup aus:
                              echad@chet:~ $ apt policy influxdb influxdb2
                              influxdb:
                                Installed: (none)
                                Candidate: 1.8.10-1
                                Version table:
                                   1.8.10-1 500
                                      500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages
                                   1.6.7~rc0-1+b5 500
                                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                              influxdb2:
                                Installed: (none)
                                Candidate: 2.2.0
                                Version table:
                                   2.2.0 500
                                   2.1.1 -1
                              echad@chet:~ $
                                @einstein2002
                                influxdb:
                                  Installed: (none)
                                  Candidate: 1.8.10-1
                                  Version table:
                                     1.8.10-1 500
                                     1.6.7~rc0-1+b5 500
                                influxdb2:
                                  Installed: (none)
                                  Candidate: 2.2.0
                                  Version table:
                                     2.2.0 500
                                     2.1.1 -1
                                echad@chet:~ $
                                Einstein2002
                                @thomas-braun sagte in Beim Installieren von influx CLI:
                                michael@Influxdb2:~$ apt policy influxdb influxdb2
                                influxdb:
                                  Installed: 1.8.10-1
                                  Candidate: 1.8.10-1
                                  Version table:
                                 *** 1.8.10-1 500
                                        500 https://repos.influxdata.com/ubuntu impish/stable amd64 Packages
                                     1.6.7~rc0-1 500
                                        500 http://archive.ubuntu.com/ubuntu impish/universe amd64 Packages
                                influxdb2:
                                  Installed: (none)
                                  Candidate: 2.2.0
                                  Version table:
                                     2.2.0 500
                                michael@Influxdb2:~$ ^C
                                So bei mir
                                Thomas BraunT E crunchipC 3 Antworten Letzte Antwort
                                • E Einstein2002
                                  influxdb:
                                    Installed: 1.8.10-1
                                    Candidate: 1.8.10-1
                                    Version table:
                                   *** 1.8.10-1 500
                                       1.6.7~rc0-1 500
                                  influxdb2:
                                    Installed: (none)
                                    Candidate: 2.2.0
                                    Version table:
                                       2.2.0 500
                                  So bei mir
                                  @einstein2002
                                  Dann passt es doch.
                                  • E Einstein2002
                                    influxdb:
                                      Installed: 1.8.10-1
                                      Candidate: 1.8.10-1
                                      Version table:
                                     *** 1.8.10-1 500
                                         1.6.7~rc0-1 500
                                    influxdb2:
                                      Installed: (none)
                                      Candidate: 2.2.0
                                      Version table:
                                         2.2.0 500
                                    So bei mir
                                    Einstein2002
                                    @einstein2002
                                    ich setzt den noch einmal neu auf.
                                    Habe gesehen du hast eine neuere Debian drauf.
                                    Hatte gedacht das geht mit der noch nicht.
                                    Noch ist es alles im grünen Bereich ohne Daten und gaaaaaanz am Anfang
                                      @einstein2002
                                      Dann passt es doch.
                                      Einstein2002
                                      Was ist denn mit der CLI?
                                      Wurde diese mitberücksichtigt?
                                      Ich glaube nein??
                                      Bin mir jetzt überhaupt nicht mehr sicher
                                      • E Einstein2002
                                        @einstein2002
                                        Auf den Punkt wollte ich gerade hinweisen. Dein Ubuntu stirbt im July eh, man nimmt entweder deren LTS-Versionen oder gleich ein Debian stable für Server.
                                        • E Einstein2002
                                          Ich glaube nein??
                                          Was meinst du?
                                          Falls du die influx clients meinst:
                                          apt policy influxdb-client influxdb2-cli
                                          82.9k
