  4. Material Design Installation und Widgets
    2.1k
    4.0k
124 Beiträge 4 Kommentatoren 14.4k Aufrufe 4 Beobachtet
  • F Flohtec76
    @glasfaser said in Material Design Installation und Widgets:
    iobroker list adapters
    das ging schnell :
    pi@raspberrypi:~ $ iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.6    , installed 2.4.6
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "echarts"      : 1.0.3    , installed 1.0.3
    Adapter    "flot"         : 1.10.7   , installed 1.10.7
    Adapter    "history"      : 1.11.1   , installed 1.11.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.2.21   , installed 5.2.21
    Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
    Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sql"          : 1.16.2   , installed 1.16.2
    Adapter    "telegram"     : 1.12.2   , installed 1.12.2
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "zigbee"       : 1.6.18   , installed 1.6.16 [Updatable]
    pi@raspberrypi:~ $ iobroker list instances
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7c2a7b1b241aec1184677fe5f01c6278-if00-port0
    + instance is alive
    pi@raspberrypi:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v5.3.8
    system.adapter.alexa2                  : alexa2         - v3.11.2
    system.adapter.backitup                : backitup       - v2.4.6
    system.adapter.cloud                   : cloud          - v4.1.1
    system.adapter.discovery               : discovery      - v3.0.3
    system.adapter.echarts                 : echarts        - v1.0.3
    system.adapter.flot                    : flot           - v1.10.7
    system.adapter.history                 : history        - v1.11.1
    system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
    system.adapter.icons-icons8            : icons-icons8   - v0.0.1
    system.adapter.icons-material-png      : icons-material-png - v0.1.0
    system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
    system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
    system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
    system.adapter.influxdb                : influxdb       - v2.6.3
    system.adapter.iot                     : iot            - v1.11.4
    system.adapter.javascript              : javascript     - v5.2.21
    system.adapter.mqtt                    : mqtt           - v3.0.6
    system.adapter.pushover                : pushover       - v2.1.0
    system.adapter.shelly                  : shelly         - v5.3.2
    system.adapter.sonoff                  : sonoff         - v2.5.1
    system.adapter.sql                     : sql            - v1.16.2
    system.adapter.telegram                : telegram       - v1.12.2
    system.adapter.vis                     : vis            - v1.4.15
    system.adapter.vis-bars                : vis-bars       - v0.1.4
    system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
    system.adapter.vis-history             : vis-history    - v1.0.0
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
    system.adapter.vis-justgage            : vis-justgage   - v1.0.2
    system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
    system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.80
    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
    system.adapter.web                     : web            - v4.3.0
    system.adapter.zigbee                  : zigbee         - v1.6.16
    pi@raspberrypi:~ $
    GlasfaserG Offline
    GlasfaserG Offline
    @flohtec76 sagte in Material Design Installation und Widgets:
    Da ist immer noch der alte drin ...
    iob upload vis-materialdesign
    und dann nochmal prüfen
    F 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      Flohtec76
      @glasfaser
      der text den ich bekommen habe
      pi@raspberrypi:~ $ iob upload vis-materialdesign
      upload [20] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/admin.d.ts admin.d.ts video/mp2t
      upload [19] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/img/info-big.png img/info-big.png image/png
      upload [18] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/index_m.html index_m.html text/html
      upload [17] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/index_m.js index_m.js application/javascript
      upload [16] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/clipboard-polyfill.promise.js lib/clipboard-polyfill.promise.js application/javascript
      upload [15] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/colors.json lib/colors.json application/json
      upload [14] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/colorsDark.json lib/colorsDark.json application/json
      upload [13] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultcolors.json lib/defaultcolors.json application/json
      upload [12] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultcolorsDark.json lib/defaultcolorsDark.json application/json
      upload [11] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultfontSizes.json lib/defaultfontSizes.json application/json
      upload [10] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultfonts.json lib/defaultfonts.json application/json
      upload [9] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/fontSizes.json lib/fontSizes.json application/json
      upload [8] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/fonts.json lib/fonts.json application/json
      upload [7] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/monolith.min.css lib/monolith.min.css text/css
      upload [6] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/pickr.min.js lib/pickr.min.js application/javascript
      upload [5] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/pickr.min.js.map lib/pickr.min.js.map application/json
      upload [4] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/style.css style.css text/css
      upload [3] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/tsconfig.json tsconfig.json application/json
      upload [2] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign.png vis-materialdesign.png image/png
      upload [1] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign_16_9.png vis-materialdesign_16_9.png image/png
      upload [0] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/words.js words.js application/javascript
      Update "system.adapter.vis-materialdesign.0"
      INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-materialdesign/www" was not found! Nothing was uploaded or deleted.
      funktiniert leider immer noch nicht :-(
      • F Flohtec76
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        @flohtec76
        ist immer noch die .80 drin !?
          @flohtec76
          Flohtec76
          @glasfaser
          ja, leider.
          ich habe jetzt zwei drei mal den befehl zum löschen gestartet und jedes mal macht er auch etwas bzw sagt mir NICHT das es nichts mehr zum löschen gibt.
          Ich jetzt nicht neu installiert und man sieht in der Liste das immer noch die .80 ist obwohl ich den komplett raus haben müsste?!
          • GlasfaserG Offline
            GlasfaserG Offline
            Das ist doch der richtige !! keine 80 mehr
            iobroker update -i
            dann ein ... die Ausgabe brauche ich nicht
            iobroker upload vis
            und danach schau im VIS Editor
              iobroker update -i
              iobroker upload vis
              Flohtec76
              @glasfaser
              aber ich habe nichts installiert.
              • F Flohtec76
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                @flohtec76
                Deshalb die Anfrage oben von mir , da kann ich mehr sehen ..
                Hast du bei der Adapterliste auf + ( Instanz hinzufügen ) gedrückt
                  @flohtec76
                  Flohtec76
                  @glasfaser
                  ja hatte ich über + hinzugefügt!
                  ich mache rasch die abfrage
                  • F Flohtec76
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @flohtec76
                    Zeige nochmal dein Screenshot hiervon
                      @flohtec76
                      Flohtec76
                      @glasfaser
                      Nochmal ganz langsam:
                      also ich habe den erneut über die Mülltonne gelöscht.
                      dann habe ich mehrmals
                      npm i iobroker.vis-materialdesign@0.5.8
                      laufen lassen.
                      ich habe noch nichts über das Plus installiert und bekomme folgendes:
                       iobroker update -i
                      Adapter    "admin"        : 5.4.9    , installed 5.3.8  [Updatable]
                      Adapter    "alexa2"       : 3.12.0   , installed 3.11.2 [Updatable]
                      Adapter    "backitup"     : 2.4.9    , installed 2.4.6  [Updatable]
                      Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
                      Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
                      Adapter    "history"      : 2.1.0    , installed 1.11.1 [Updatable]
                      Adapter    "influxdb"     : 3.1.0    , installed 2.6.3  [Updatable]
                      Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
                      Adapter    "mqtt"         : 4.0.3    , installed 3.0.6  [Updatable]
                      Adapter    "socketio"     : 6.1.3    , installed 4.2.0  [Updatable]
                      Adapter    "sql"          : 2.1.0    , installed 1.16.2 [Updatable]
                      Adapter    "telegram"     : 1.12.6   , installed 1.12.2 [Updatable]
                      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.8 [Updatable]
                      Adapter    "web"          : 5.2.0    , installed 4.3.0  [Updatable]
                      Adapter    "ws"           : 2.1.0    , installed 1.3.0  [Updatable]
                      + instance is alive
                      also wenn ich Euch Jungs folgen kann dann sehe ich den im Text immer noch obwohl er nicht installiert ist, richtig?
                      Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                      • F Flohtec76
                        @glasfaser
                        laufen lassen.
                         iobroker update -i
                        + instance is alive
                        vis-materialdesign
                        github:	0.5.86
                        latest:	0.5.9 for 11 months
                        stable:	-.-.-
                        Die 0.5.8 ist ja jetzt drin. Ich würde jetzt den ganzen Sums auf Stand bringen.
                        • F Flohtec76
                          @glasfaser
                          laufen lassen.
                           iobroker update -i
                          + instance is alive
                          GlasfaserG Offline
                          GlasfaserG Offline
                          ???? habe dich doch oben gefragt und du hast geschrieben du hast ihn über + die INSTANZ installiert
                          Zeige ... bzw. installiere die INSTANZ
                            vis-materialdesign
                            github:	0.5.86
                            stable:	-.-.-
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @thomas-braun sagte in Material Design Installation und Widgets:
                            Warte .... ich habe noch die 0.5.8 aus bestimmten Gründen noch , da ich weiß das Sie 100% funktioniert.
                            Ist halt nur Traurig , das der Adapter noch nicht in STABLE ist !
                            Thomas BraunT F 2 Antworten Letzte Antwort
                              @glasfaser
                              Primär geht es mir auch um den Rest.
                              Aber eine 0.5.9, die seit 11 Monaten im Repo schlummert dürfte verwendbar sein.
                                Flohtec76
                                @glasfaser
                                wow jetzt wird es schwer jemanden zu folgen.
                                Also ja ich hatte den Adapter gelöscht
                                dann die befehle laufen lassen
                                dann stand im text das er immer noch zu sehen ist
                                und habe ihn wieder über die Mülltonne gelöscht.
                                Alle Texte die ich in den letzten zwei drei Posts geschickt habe waren ohne über das + installierten Adapter
                                Also werde ich ihn nun erneut über das + hinzufügen
                                Thomas kann ich mit seinen Befehlen leider nicht helfen, wenn ich die Kommandos ausführen will sagt er das es diese nicht gibt.
                                GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
                                • F Flohtec76
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Das war kein Befehl , das war nur eine Info zum Adapter Stand
                                  • F Flohtec76
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    und danach erstmal sagen was jetzt ist
                                    und nichts löschen oder sonst was quer machen !!!!
                                    • F Flohtec76
                                      @glasfaser
                                      @flohtec76
                                      iob update
                                      iob list adapters | grep vis-materialdesign
                                      iob list instances | grep vis-materialdesign
                                        Flohtec76
                                        schrieb am zuletzt editiert von Flohtec76
                                        @glasfaser
                                        also ich habe nun nochmal geschaut:
                                        der Adapter ist immer NOCH NICHT + installiert aber taucht doch immer noch in der liste auf.
                                        Auch die Vis Material webfont hatte ich über die mülltonne gelöscht und der taucht auch im text auf.
                                        • F Flohtec76
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @flohtec76
                                          Ausgabe von @Thomas-Braun Anfrage fehlt !?
