  4. Material Design Installation und Widgets
    2.1k
    4.0k
124 Beiträge 4 Kommentatoren 14.4k Aufrufe 4 Beobachtet
  • F Flohtec76
    code_text
    iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.6    , installed 2.4.6
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "echarts"      : 1.0.3    , installed 1.0.3
    Adapter    "flot"         : 1.10.7   , installed 1.10.7
    Adapter    "history"      : 1.11.1   , installed 1.11.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.2.21   , installed 5.2.21
    Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
    Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sql"          : 1.16.2   , installed 1.16.2
    Adapter    "telegram"     : 1.12.2   , installed 1.12.2
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "zigbee"       : 1.6.18   , installed 1.6.16 [Updatable]
    pi@raspberrypi:~ $ iobroker list instances
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7c2a7b1b241aec1184677fe5f01c6278-if00-port0
    + instance is alive
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: die symbolische Verkn▒pfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
    pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v12.22.12
    v12.22.12
    6.14.16
    pi
    /home/pi
    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:2 https://repos.influxdata.com/debian stretch InRelease
    OK:3 https://deb.nodesource.com/node_12.x bullseye InRelease
    OK:4 https://packages.grafana.com/oss/deb stable InRelease
    OK:5 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Abh▒ngigkeitsbaum wird aufgebaut... Fertig
    Statusinformationen werden eingelesen... Fertig
    Aktualisierung f▒r 12 Pakete verf▒gbar. F▒hren Sie ▒apt list --upgradable▒ aus, um sie anzuzeigen.
    nodejs:
      Installiert:           12.22.12-deb-1nodesource1
      Installationskandidat: 12.22.12-deb-1nodesource1
      Versionstabelle:
     *** 12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
         12.22.5~dfsg-2~11u1 500
    So sieht es bei mir jetzt aus!
    Ich habe Material auch bei den "latest" gefunden und installiert!
    ich bin immer erstaunt das "jemand" daraus etwas lesen kann 👍
    GlasfaserG Offline
    GlasfaserG Offline
    @flohtec76 sagte in Material Design Installation und Widgets:
    Zu deinem Screenshot mit der .. ..80 am ende
    .... ich habe 5.8.0 auch installiert .
    das sieht so aus
    • GlasfaserG Glasfaser
      @flohtec76
      Ich frage mich immer noch , wie du an die 0.5.80 kommst .
      Wie installiert !?
      Mache mal ein
      iobroker upload all
      Flohtec76
      @glasfaser said in Material Design Installation und Widgets:
      iobroker upload all
      ahhhh warte mal, ich glaube das ich Material Design per link installiert hatte da ich den bei den Adaptern erst nicht gefunden hatte.
      Ich habe nun eine halbe Ewigkeit gewartet bis alles ausgelesen wurde.
      hatte es in einen Code eingefügt jedoch beim absenden bekam ich die Nachricht : nicht mehr als 10.000 Zeichen
      iobroker upload all
      funktioniert also nicht, zu viel Text
      Den Influx Adapter beachte ich gar nicht groß weiter da der überflüssig ist und wird auch heute Abend raus geworfen :-)
      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
      • F Flohtec76
        iobroker upload all
        iobroker upload all
        GlasfaserG Offline
        GlasfaserG Offline
        Das war nur ... "mache mal" mehr nicht ...
        das LOG brauche ich nicht .
        Zeige mal
        iobroker update -i
        iobroker list adapters
        F 1 Antwort Letzte Antwort
        • F Flohtec76
          iobroker upload all
          iobroker upload all
          Das ist allerdings kein Adapter, sondern ein deb-Repo. Die influxdb musst du dann deinstallieren und die influxdb.list löschen.
            Zeige mal
            iobroker update -i
            Flohtec76
            Wenn ich mit "Euch" Profis schreibe kommt man sich immer vor wie ein Schuljunge 😁
            Ich bin immer Fasziniert von alle hier! Danke für Euren Support!
            nun der text
            pi@raspberrypi:~ $ iobroker update -i
            pi@raspberrypi:~ $ iobroker list adapters
            system.adapter.admin                   : admin          - v5.3.8
            system.adapter.alexa2                  : alexa2         - v3.11.2
            system.adapter.backitup                : backitup       - v2.4.6
            system.adapter.cloud                   : cloud          - v4.1.1
            system.adapter.discovery               : discovery      - v3.0.3
            system.adapter.echarts                 : echarts        - v1.0.3
            system.adapter.flot                    : flot           - v1.10.7
            system.adapter.history                 : history        - v1.11.1
            system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
            system.adapter.icons-icons8            : icons-icons8   - v0.0.1
            system.adapter.icons-material-png      : icons-material-png - v0.1.0
            system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
            system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
            system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
            system.adapter.influxdb                : influxdb       - v2.6.3
            system.adapter.iot                     : iot            - v1.11.4
            system.adapter.javascript              : javascript     - v5.2.21
            system.adapter.mqtt                    : mqtt           - v3.0.6
            system.adapter.pushover                : pushover       - v2.1.0
            system.adapter.shelly                  : shelly         - v5.3.2
            system.adapter.sonoff                  : sonoff         - v2.5.1
            system.adapter.sql                     : sql            - v1.16.2
            system.adapter.telegram                : telegram       - v1.12.2
            system.adapter.vis                     : vis            - v1.4.15
            system.adapter.vis-bars                : vis-bars       - v0.1.4
            system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
            system.adapter.vis-history             : vis-history    - v1.0.0
            system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
            system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
            system.adapter.vis-justgage            : vis-justgage   - v1.0.2
            system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
            system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.80
            system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
            system.adapter.web                     : web            - v4.3.0
            system.adapter.zigbee                  : zigbee         - v1.6.16
            pi@raspberrypi:~ $
            • F Flohtec76
              nun der text
              pi@raspberrypi:~ $
              GlasfaserG Offline
              GlasfaserG Offline
              @flohtec76
              Lösche den Adapter vis-materialdesign mit der Mülltonne ...
              dann:
              wichtig ... In Verzeichniss: /opt/iobroker ausführen
              cd /opt/iobroker
              npm i iobroker.vis-materialdesign@0.5.8
              und danach beim Adapter eine Instanz erstellen mit dem +
                @flohtec76
                dann:
                cd /opt/iobroker
                Flohtec76
                Hab ich erledigt!
                der text beim löschen:
                pi@raspberrypi:~ $ cd /opt/iobroker
                pi@raspberrypi:/opt/iobroker $ npm i iobroker.vis-materialdesign@0.5.8
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                + iobroker.vis-materialdesign@0.5.8
                updated 1 package in 40.605s
                128 packages are looking for funding
                  run `npm fund` for details
                den Adapter habe ich erneut installiert jedoch immer noch nicht in Vis zu sehen
                • F Flohtec76
                  Hab ich erledigt!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Zeigen:
                  iobroker update -i
                    Zeigen:
                    iobroker update -i
                    Flohtec76
                    das ging schnell :
                    + instance is alive
                    pi@raspberrypi:~ $
                    • F Flohtec76
                      das ging schnell :
                      + instance is alive
                      pi@raspberrypi:~ $
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Da ist immer noch der alte drin ...
                      iob upload vis-materialdesign
                      und dann nochmal prüfen
                        Flohtec76
                        @glasfaser
                        der text den ich bekommen habe
                        pi@raspberrypi:~ $ iob upload vis-materialdesign
                        upload [20] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/admin.d.ts admin.d.ts video/mp2t
                        upload [19] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/img/info-big.png img/info-big.png image/png
                        upload [18] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/index_m.html index_m.html text/html
                        upload [17] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/index_m.js index_m.js application/javascript
                        upload [16] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/clipboard-polyfill.promise.js lib/clipboard-polyfill.promise.js application/javascript
                        upload [15] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/colors.json lib/colors.json application/json
                        upload [14] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/colorsDark.json lib/colorsDark.json application/json
                        upload [13] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultcolors.json lib/defaultcolors.json application/json
                        upload [12] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultcolorsDark.json lib/defaultcolorsDark.json application/json
                        upload [11] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultfontSizes.json lib/defaultfontSizes.json application/json
                        upload [10] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultfonts.json lib/defaultfonts.json application/json
                        upload [9] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/fontSizes.json lib/fontSizes.json application/json
                        upload [8] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/fonts.json lib/fonts.json application/json
                        upload [7] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/monolith.min.css lib/monolith.min.css text/css
                        upload [6] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/pickr.min.js lib/pickr.min.js application/javascript
                        upload [5] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/pickr.min.js.map lib/pickr.min.js.map application/json
                        upload [4] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/style.css style.css text/css
                        upload [3] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/tsconfig.json tsconfig.json application/json
                        upload [2] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign.png vis-materialdesign.png image/png
                        upload [1] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign_16_9.png vis-materialdesign_16_9.png image/png
                        upload [0] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/words.js words.js application/javascript
                        Update "system.adapter.vis-materialdesign.0"
                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-materialdesign/www" was not found! Nothing was uploaded or deleted.
                        funktiniert leider immer noch nicht :-(
                        • F Flohtec76
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @flohtec76
                          ist immer noch die .80 drin !?
                            @flohtec76
                            Flohtec76
                            @glasfaser
                            ja, leider.
                            ich habe jetzt zwei drei mal den befehl zum löschen gestartet und jedes mal macht er auch etwas bzw sagt mir NICHT das es nichts mehr zum löschen gibt.
                            Ich jetzt nicht neu installiert und man sieht in der Liste das immer noch die .80 ist obwohl ich den komplett raus haben müsste?!
                            • GlasfaserG Offline
                              GlasfaserG Offline
                              Das ist doch der richtige !! keine 80 mehr
                              iobroker update -i
                              dann ein ... die Ausgabe brauche ich nicht
                              iobroker upload vis
                              und danach schau im VIS Editor
                                iobroker update -i
                                iobroker upload vis
                                Flohtec76
                                @glasfaser
                                aber ich habe nichts installiert.
                                • F Flohtec76
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @flohtec76
                                  Deshalb die Anfrage oben von mir , da kann ich mehr sehen ..
                                  Hast du bei der Adapterliste auf + ( Instanz hinzufügen ) gedrückt
                                    @flohtec76
                                    Flohtec76
                                    @glasfaser
                                    ja hatte ich über + hinzugefügt!
                                    ich mache rasch die abfrage
                                    • F Flohtec76
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @flohtec76
                                      Zeige nochmal dein Screenshot hiervon
                                        @flohtec76
                                        Flohtec76
                                        @glasfaser
                                        Nochmal ganz langsam:
                                        also ich habe den erneut über die Mülltonne gelöscht.
                                        dann habe ich mehrmals
                                        laufen lassen.
                                        ich habe noch nichts über das Plus installiert und bekomme folgendes:
                                         iobroker update -i
                                        Adapter    "admin"        : 5.4.9    , installed 5.3.8  [Updatable]
                                        Adapter    "alexa2"       : 3.12.0   , installed 3.11.2 [Updatable]
                                        Adapter    "backitup"     : 2.4.9    , installed 2.4.6  [Updatable]
                                        Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
                                        Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
                                        Adapter    "history"      : 2.1.0    , installed 1.11.1 [Updatable]
                                        Adapter    "influxdb"     : 3.1.0    , installed 2.6.3  [Updatable]
                                        Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
                                        Adapter    "mqtt"         : 4.0.3    , installed 3.0.6  [Updatable]
                                        Adapter    "socketio"     : 6.1.3    , installed 4.2.0  [Updatable]
                                        Adapter    "sql"          : 2.1.0    , installed 1.16.2 [Updatable]
                                        Adapter    "telegram"     : 1.12.6   , installed 1.12.2 [Updatable]
                                        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.8 [Updatable]
                                        Adapter    "web"          : 5.2.0    , installed 4.3.0  [Updatable]
                                        Adapter    "ws"           : 2.1.0    , installed 1.3.0  [Updatable]
                                        + instance is alive
                                        also wenn ich Euch Jungs folgen kann dann sehe ich den im Text immer noch obwohl er nicht installiert ist, richtig?
                                        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                        • F Flohtec76
                                          @glasfaser
                                          laufen lassen.
                                           iobroker update -i
                                          + instance is alive
                                          vis-materialdesign
                                          github:	0.5.86
                                          latest:	0.5.9 for 11 months
                                          stable:	-.-.-
                                          Die 0.5.8 ist ja jetzt drin. Ich würde jetzt den ganzen Sums auf Stand bringen.
