  4. Material Design Installation und Widgets
    2.1k
    4.0k
124 Beiträge 4 Kommentatoren 14.4k Aufrufe 4 Beobachtet
  • GlasfaserG Offline
    GlasfaserG Offline
    @flohtec76
    Ich frage mich immer noch , wie du an die 0.5.80 kommst .
    Wie installiert !?
    Mache mal ein
    iobroker upload all
    F 1 Antwort Letzte Antwort
    • F Flohtec76
      code_text
      iobroker update -i
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "backitup"     : 2.4.6    , installed 2.4.6
      Adapter    "cloud"        : 4.1.1    , installed 4.1.1
      Adapter    "discovery"    : 3.0.3    , installed 3.0.3
      Adapter    "echarts"      : 1.0.3    , installed 1.0.3
      Adapter    "flot"         : 1.10.7   , installed 1.10.7
      Adapter    "history"      : 1.11.1   , installed 1.11.1
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
      Adapter    "iot"          : 1.11.4   , installed 1.11.4
      Adapter    "javascript"   : 5.2.21   , installed 5.2.21
      Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
      Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
      Adapter    "pushover"     : 2.1.0    , installed 2.1.0
      Adapter    "shelly"       : 5.3.2    , installed 5.3.2
      Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sql"          : 1.16.2   , installed 1.16.2
      Adapter    "telegram"     : 1.12.2   , installed 1.12.2
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "zigbee"       : 1.6.18   , installed 1.6.16 [Updatable]
      pi@raspberrypi:~ $ iobroker list instances
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
        system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
        system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
        system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7c2a7b1b241aec1184677fe5f01c6278-if00-port0
      + instance is alive
      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verkn▒pfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      pi@raspberrypi:~ $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.12
      v12.22.12
      6.14.16
      pi
      /home/pi
      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:2 https://repos.influxdata.com/debian stretch InRelease
      OK:3 https://deb.nodesource.com/node_12.x bullseye InRelease
      OK:4 https://packages.grafana.com/oss/deb stable InRelease
      OK:5 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Abh▒ngigkeitsbaum wird aufgebaut... Fertig
      Statusinformationen werden eingelesen... Fertig
      Aktualisierung f▒r 12 Pakete verf▒gbar. F▒hren Sie ▒apt list --upgradable▒ aus, um sie anzuzeigen.
      nodejs:
        Installiert:           12.22.12-deb-1nodesource1
        Installationskandidat: 12.22.12-deb-1nodesource1
        Versionstabelle:
       *** 12.22.12-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x bullseye/main armhf Packages
           12.22.5~dfsg-2~11u1 500
      So sieht es bei mir jetzt aus!
      Ich habe Material auch bei den "latest" gefunden und installiert!
      ich bin immer erstaunt das "jemand" daraus etwas lesen kann 👍
      @flohtec76 sagte in Material Design Installation und Widgets:
      OT: Ich lese da raus, dass du für influx den falschen Release Name in der influxdb.list drin hast. Stell das auf bullseye um.
        GlasfaserG Offline
        GlasfaserG Offline
        @thomas-braun sagte in Material Design Installation und Widgets:
        OT:
        Das nennt man Kaffeesatz lesen .... ach nee das macht immer @Homoran in den meisten Thread´s wenn keine Angaben gemacht werden .....
        • F Flohtec76
          code_text
          iobroker update -i
          + instance is alive
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.12
          v12.22.12
          6.14.16
          pi
          /home/pi
          nodejs:
            Versionstabelle:
          GlasfaserG Offline
          GlasfaserG Offline
          Zu deinem Screenshot mit der .. ..80 am ende
          .... ich habe 5.8.0 auch installiert .
          das sieht so aus
          • GlasfaserG Glasfaser
            @flohtec76
            Wie installiert !?
            Mache mal ein
            iobroker upload all
            Flohtec76
            @glasfaser said in Material Design Installation und Widgets:
            iobroker upload all
            ahhhh warte mal, ich glaube das ich Material Design per link installiert hatte da ich den bei den Adaptern erst nicht gefunden hatte.
            Ich habe nun eine halbe Ewigkeit gewartet bis alles ausgelesen wurde.
            hatte es in einen Code eingefügt jedoch beim absenden bekam ich die Nachricht : nicht mehr als 10.000 Zeichen
            iobroker upload all
            funktioniert also nicht, zu viel Text
            Den Influx Adapter beachte ich gar nicht groß weiter da der überflüssig ist und wird auch heute Abend raus geworfen :-)
            GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
            • F Flohtec76
              iobroker upload all
              iobroker upload all
              GlasfaserG Offline
              GlasfaserG Offline
              Das war nur ... "mache mal" mehr nicht ...
              das LOG brauche ich nicht .
              Zeige mal
              iobroker update -i
              iobroker list adapters
              • F Flohtec76
                iobroker upload all
                iobroker upload all
                Das ist allerdings kein Adapter, sondern ein deb-Repo. Die influxdb musst du dann deinstallieren und die influxdb.list löschen.
                  Zeige mal
                  iobroker update -i
                  Flohtec76
                  Wenn ich mit "Euch" Profis schreibe kommt man sich immer vor wie ein Schuljunge 😁
                  Ich bin immer Fasziniert von alle hier! Danke für Euren Support!
                  nun der text
                  pi@raspberrypi:~ $ iobroker update -i
                  pi@raspberrypi:~ $ iobroker list adapters
                  system.adapter.admin                   : admin          - v5.3.8
                  system.adapter.alexa2                  : alexa2         - v3.11.2
                  system.adapter.backitup                : backitup       - v2.4.6
                  system.adapter.cloud                   : cloud          - v4.1.1
                  system.adapter.discovery               : discovery      - v3.0.3
                  system.adapter.echarts                 : echarts        - v1.0.3
                  system.adapter.flot                    : flot           - v1.10.7
                  system.adapter.history                 : history        - v1.11.1
                  system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
                  system.adapter.icons-icons8            : icons-icons8   - v0.0.1
                  system.adapter.icons-material-png      : icons-material-png - v0.1.0
                  system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
                  system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
                  system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                  system.adapter.influxdb                : influxdb       - v2.6.3
                  system.adapter.iot                     : iot            - v1.11.4
                  system.adapter.javascript              : javascript     - v5.2.21
                  system.adapter.mqtt                    : mqtt           - v3.0.6
                  system.adapter.pushover                : pushover       - v2.1.0
                  system.adapter.shelly                  : shelly         - v5.3.2
                  system.adapter.sonoff                  : sonoff         - v2.5.1
                  system.adapter.sql                     : sql            - v1.16.2
                  system.adapter.telegram                : telegram       - v1.12.2
                  system.adapter.vis                     : vis            - v1.4.15
                  system.adapter.vis-bars                : vis-bars       - v0.1.4
                  system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                  system.adapter.vis-history             : vis-history    - v1.0.0
                  system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
                  system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                  system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                  system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
                  system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.80
                  system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                  system.adapter.web                     : web            - v4.3.0
                  system.adapter.zigbee                  : zigbee         - v1.6.16
                  pi@raspberrypi:~ $
                  • F Flohtec76
                    nun der text
                    pi@raspberrypi:~ $
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @flohtec76
                    Lösche den Adapter vis-materialdesign mit der Mülltonne ...
                    dann:
                    wichtig ... In Verzeichniss: /opt/iobroker ausführen
                    cd /opt/iobroker
                    npm i iobroker.vis-materialdesign@0.5.8
                    und danach beim Adapter eine Instanz erstellen mit dem +
                      @flohtec76
                      dann:
                      cd /opt/iobroker
                      Flohtec76
                      Hab ich erledigt!
                      der text beim löschen:
                      pi@raspberrypi:~ $ cd /opt/iobroker
                      pi@raspberrypi:/opt/iobroker $ npm i iobroker.vis-materialdesign@0.5.8
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                      + iobroker.vis-materialdesign@0.5.8
                      updated 1 package in 40.605s
                      128 packages are looking for funding
                        run `npm fund` for details
                      den Adapter habe ich erneut installiert jedoch immer noch nicht in Vis zu sehen
                      • F Flohtec76
                        Hab ich erledigt!
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Zeigen:
                        iobroker update -i
                          Zeigen:
                          iobroker update -i
                          Flohtec76
                          das ging schnell :
                          + instance is alive
                          pi@raspberrypi:~ $
                          • F Flohtec76
                            das ging schnell :
                            + instance is alive
                            pi@raspberrypi:~ $
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Da ist immer noch der alte drin ...
                            iob upload vis-materialdesign
                            und dann nochmal prüfen
                              Flohtec76
                              @glasfaser
                              der text den ich bekommen habe
                              pi@raspberrypi:~ $ iob upload vis-materialdesign
                              upload [20] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/admin.d.ts admin.d.ts video/mp2t
                              upload [19] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/img/info-big.png img/info-big.png image/png
                              upload [18] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/index_m.html index_m.html text/html
                              upload [17] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/index_m.js index_m.js application/javascript
                              upload [16] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/clipboard-polyfill.promise.js lib/clipboard-polyfill.promise.js application/javascript
                              upload [15] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/colors.json lib/colors.json application/json
                              upload [14] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/colorsDark.json lib/colorsDark.json application/json
                              upload [13] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultcolors.json lib/defaultcolors.json application/json
                              upload [12] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultcolorsDark.json lib/defaultcolorsDark.json application/json
                              upload [11] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultfontSizes.json lib/defaultfontSizes.json application/json
                              upload [10] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultfonts.json lib/defaultfonts.json application/json
                              upload [9] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/fontSizes.json lib/fontSizes.json application/json
                              upload [8] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/fonts.json lib/fonts.json application/json
                              upload [7] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/monolith.min.css lib/monolith.min.css text/css
                              upload [6] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/pickr.min.js lib/pickr.min.js application/javascript
                              upload [5] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/pickr.min.js.map lib/pickr.min.js.map application/json
                              upload [4] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/style.css style.css text/css
                              upload [3] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/tsconfig.json tsconfig.json application/json
                              upload [2] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign.png vis-materialdesign.png image/png
                              upload [1] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign_16_9.png vis-materialdesign_16_9.png image/png
                              upload [0] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/words.js words.js application/javascript
                              Update "system.adapter.vis-materialdesign.0"
                              INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-materialdesign/www" was not found! Nothing was uploaded or deleted.
                              funktiniert leider immer noch nicht :-(
                              • F Flohtec76
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @flohtec76
                                ist immer noch die .80 drin !?
                                  @flohtec76
                                  Flohtec76
                                  @glasfaser
                                  ja, leider.
                                  ich habe jetzt zwei drei mal den befehl zum löschen gestartet und jedes mal macht er auch etwas bzw sagt mir NICHT das es nichts mehr zum löschen gibt.
                                  Ich jetzt nicht neu installiert und man sieht in der Liste das immer noch die .80 ist obwohl ich den komplett raus haben müsste?!
                                    GlasfaserG Offline
                                    Das ist doch der richtige !! keine 80 mehr
                                    iobroker update -i
                                    dann ein ... die Ausgabe brauche ich nicht
                                    iobroker upload vis
                                    und danach schau im VIS Editor
                                      iobroker update -i
                                      iobroker upload vis
                                      Flohtec76
                                      @glasfaser
                                      aber ich habe nichts installiert.
                                      • F Flohtec76
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @flohtec76
                                        Deshalb die Anfrage oben von mir , da kann ich mehr sehen ..
                                        Hast du bei der Adapterliste auf + ( Instanz hinzufügen ) gedrückt
                                          @flohtec76
                                          Flohtec76
                                          @glasfaser
                                          ja hatte ich über + hinzugefügt!
                                          ich mache rasch die abfrage
