  4. Material Design Installation und Widgets
    2.1k
    4.0k
124 Beiträge 4 Kommentatoren 14.4k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @flohtec76 sagte in Material Design Installation und Widgets:
    immer noch nicht in Vis zu sehen
    Zeigen:
    iobroker update -i
    iobroker list instances
    iobroker list adapters
    Flohtec76
    @glasfaser said in Material Design Installation und Widgets:
    das ging schnell :
    pi@raspberrypi:~ $ iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
    Adapter    "backitup"     : 2.4.6    , installed 2.4.6
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "echarts"      : 1.0.3    , installed 1.0.3
    Adapter    "flot"         : 1.10.7   , installed 1.10.7
    Adapter    "history"      : 1.11.1   , installed 1.11.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.2.21   , installed 5.2.21
    Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
    Adapter    "mqtt"         : 3.0.6    , installed 3.0.6
    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sql"          : 1.16.2   , installed 1.16.2
    Adapter    "telegram"     : 1.12.2   , installed 1.12.2
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "zigbee"       : 1.6.18   , installed 1.6.16 [Updatable]
    pi@raspberrypi:~ $ iobroker list instances
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7c2a7b1b241aec1184677fe5f01c6278-if00-port0
    + instance is alive
    pi@raspberrypi:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v5.3.8
    system.adapter.alexa2                  : alexa2         - v3.11.2
    system.adapter.backitup                : backitup       - v2.4.6
    system.adapter.cloud                   : cloud          - v4.1.1
    system.adapter.discovery               : discovery      - v3.0.3
    system.adapter.echarts                 : echarts        - v1.0.3
    system.adapter.flot                    : flot           - v1.10.7
    system.adapter.history                 : history        - v1.11.1
    system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
    system.adapter.icons-icons8            : icons-icons8   - v0.0.1
    system.adapter.icons-material-png      : icons-material-png - v0.1.0
    system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
    system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
    system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
    system.adapter.influxdb                : influxdb       - v2.6.3
    system.adapter.iot                     : iot            - v1.11.4
    system.adapter.javascript              : javascript     - v5.2.21
    system.adapter.mqtt                    : mqtt           - v3.0.6
    system.adapter.pushover                : pushover       - v2.1.0
    system.adapter.shelly                  : shelly         - v5.3.2
    system.adapter.sonoff                  : sonoff         - v2.5.1
    system.adapter.sql                     : sql            - v1.16.2
    system.adapter.telegram                : telegram       - v1.12.2
    system.adapter.vis                     : vis            - v1.4.15
    system.adapter.vis-bars                : vis-bars       - v0.1.4
    system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
    system.adapter.vis-history             : vis-history    - v1.0.0
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
    system.adapter.vis-justgage            : vis-justgage   - v1.0.2
    system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
    system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.80
    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
    system.adapter.web                     : web            - v4.3.0
    system.adapter.zigbee                  : zigbee         - v1.6.16
    pi@raspberrypi:~ $
    • F Flohtec76
      das ging schnell :
      + instance is alive
      pi@raspberrypi:~ $
      GlasfaserG Offline
      GlasfaserG Offline
      Da ist immer noch der alte drin ...
      iob upload vis-materialdesign
      und dann nochmal prüfen
      F 1 Antwort Letzte Antwort
        Flohtec76
        @glasfaser
        der text den ich bekommen habe
        pi@raspberrypi:~ $ iob upload vis-materialdesign
        upload [20] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/admin.d.ts admin.d.ts video/mp2t
        upload [19] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/img/info-big.png img/info-big.png image/png
        upload [18] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/index_m.html index_m.html text/html
        upload [17] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/index_m.js index_m.js application/javascript
        upload [16] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/clipboard-polyfill.promise.js lib/clipboard-polyfill.promise.js application/javascript
        upload [15] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/colors.json lib/colors.json application/json
        upload [14] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/colorsDark.json lib/colorsDark.json application/json
        upload [13] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultcolors.json lib/defaultcolors.json application/json
        upload [12] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultcolorsDark.json lib/defaultcolorsDark.json application/json
        upload [11] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultfontSizes.json lib/defaultfontSizes.json application/json
        upload [10] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/defaultfonts.json lib/defaultfonts.json application/json
        upload [9] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/fontSizes.json lib/fontSizes.json application/json
        upload [8] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/fonts.json lib/fonts.json application/json
        upload [7] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/monolith.min.css lib/monolith.min.css text/css
        upload [6] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/pickr.min.js lib/pickr.min.js application/javascript
        upload [5] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/lib/pickr.min.js.map lib/pickr.min.js.map application/json
        upload [4] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/style.css style.css text/css
        upload [3] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/tsconfig.json tsconfig.json application/json
        upload [2] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign.png vis-materialdesign.png image/png
        upload [1] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/vis-materialdesign_16_9.png vis-materialdesign_16_9.png image/png
        upload [0] vis-materialdesign.admin /opt/iobroker/node_modules/iobroker.vis-materialdesign/admin/words.js words.js application/javascript
        Update "system.adapter.vis-materialdesign.0"
        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-materialdesign/www" was not found! Nothing was uploaded or deleted.
        funktiniert leider immer noch nicht :-(
        • F Flohtec76
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          @flohtec76
          ist immer noch die .80 drin !?
            @flohtec76
            Flohtec76
            @glasfaser
            ja, leider.
            ich habe jetzt zwei drei mal den befehl zum löschen gestartet und jedes mal macht er auch etwas bzw sagt mir NICHT das es nichts mehr zum löschen gibt.
            Ich jetzt nicht neu installiert und man sieht in der Liste das immer noch die .80 ist obwohl ich den komplett raus haben müsste?!
            • GlasfaserG Offline
              GlasfaserG Offline
              Das ist doch der richtige !! keine 80 mehr
              iobroker update -i
              dann ein ... die Ausgabe brauche ich nicht
              iobroker upload vis
              und danach schau im VIS Editor
                iobroker update -i
                iobroker upload vis
                Flohtec76
                @glasfaser
                aber ich habe nichts installiert.
                • F Flohtec76
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @flohtec76
                  Deshalb die Anfrage oben von mir , da kann ich mehr sehen ..
                  Hast du bei der Adapterliste auf + ( Instanz hinzufügen ) gedrückt
                    @flohtec76
                    Flohtec76
                    @glasfaser
                    ja hatte ich über + hinzugefügt!
                    ich mache rasch die abfrage
                    • F Flohtec76
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @flohtec76
                      Zeige nochmal dein Screenshot hiervon
                        @flohtec76
                        Flohtec76
                        @glasfaser
                        Nochmal ganz langsam:
                        also ich habe den erneut über die Mülltonne gelöscht.
                        dann habe ich mehrmals
                        npm i iobroker.vis-materialdesign@0.5.8
                        laufen lassen.
                        ich habe noch nichts über das Plus installiert und bekomme folgendes:
                         iobroker update -i
                        Adapter    "admin"        : 5.4.9    , installed 5.3.8  [Updatable]
                        Adapter    "alexa2"       : 3.12.0   , installed 3.11.2 [Updatable]
                        Adapter    "backitup"     : 2.4.9    , installed 2.4.6  [Updatable]
                        Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
                        Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
                        Adapter    "history"      : 2.1.0    , installed 1.11.1 [Updatable]
                        Adapter    "influxdb"     : 3.1.0    , installed 2.6.3  [Updatable]
                        Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
                        Adapter    "mqtt"         : 4.0.3    , installed 3.0.6  [Updatable]
                        Adapter    "socketio"     : 6.1.3    , installed 4.2.0  [Updatable]
                        Adapter    "sql"          : 2.1.0    , installed 1.16.2 [Updatable]
                        Adapter    "telegram"     : 1.12.6   , installed 1.12.2 [Updatable]
                        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.8 [Updatable]
                        Adapter    "web"          : 5.2.0    , installed 4.3.0  [Updatable]
                        Adapter    "ws"           : 2.1.0    , installed 1.3.0  [Updatable]
                        + instance is alive
                        also wenn ich Euch Jungs folgen kann dann sehe ich den im Text immer noch obwohl er nicht installiert ist, richtig?
                        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                        • F Flohtec76
                          @glasfaser
                          laufen lassen.
                           iobroker update -i
                          + instance is alive
                          vis-materialdesign
                          github:	0.5.86
                          latest:	0.5.9 for 11 months
                          stable:	-.-.-
                          Die 0.5.8 ist ja jetzt drin. Ich würde jetzt den ganzen Sums auf Stand bringen.
                          • F Flohtec76
                            @glasfaser
                            laufen lassen.
                             iobroker update -i
                            + instance is alive
                            GlasfaserG Offline
                            GlasfaserG Offline
                            ???? habe dich doch oben gefragt und du hast geschrieben du hast ihn über + die INSTANZ installiert
                            Zeige ... bzw. installiere die INSTANZ
                              vis-materialdesign
                              github:	0.5.86
                              stable:	-.-.-
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @thomas-braun sagte in Material Design Installation und Widgets:
                              Warte .... ich habe noch die 0.5.8 aus bestimmten Gründen noch , da ich weiß das Sie 100% funktioniert.
                              Ist halt nur Traurig , das der Adapter noch nicht in STABLE ist !
                              Thomas BraunT F 2 Antworten Letzte Antwort
                                @glasfaser
                                Primär geht es mir auch um den Rest.
                                Aber eine 0.5.9, die seit 11 Monaten im Repo schlummert dürfte verwendbar sein.
                                  Flohtec76
                                  @glasfaser
                                  wow jetzt wird es schwer jemanden zu folgen.
                                  Also ja ich hatte den Adapter gelöscht
                                  dann die befehle laufen lassen
                                  dann stand im text das er immer noch zu sehen ist
                                  und habe ihn wieder über die Mülltonne gelöscht.
                                  Alle Texte die ich in den letzten zwei drei Posts geschickt habe waren ohne über das + installierten Adapter
                                  Also werde ich ihn nun erneut über das + hinzufügen
                                  Thomas kann ich mit seinen Befehlen leider nicht helfen, wenn ich die Kommandos ausführen will sagt er das es diese nicht gibt.
                                  GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
                                  • F Flohtec76
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Das war kein Befehl , das war nur eine Info zum Adapter Stand
                                    • F Flohtec76
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      und danach erstmal sagen was jetzt ist
                                      und nichts löschen oder sonst was quer machen !!!!
                                      • F Flohtec76
                                        @glasfaser
                                        @flohtec76
                                        iob update
                                        iob list adapters | grep vis-materialdesign
                                        iob list instances | grep vis-materialdesign
                                          Flohtec76
                                          schrieb am zuletzt editiert von Flohtec76
                                          @glasfaser
                                          also ich habe nun nochmal geschaut:
                                          der Adapter ist immer NOCH NICHT + installiert aber taucht doch immer noch in der liste auf.
                                          Auch die Vis Material webfont hatte ich über die mülltonne gelöscht und der taucht auch im text auf.
