  4. Material Design Installation und Widgets
    2.1k
    4.0k
124 Beiträge 4 Kommentatoren 14.4k Aufrufe 4 Beobachtet
  • F Flohtec76
    @glasfaser
    Nochmal ganz langsam:
    also ich habe den erneut über die Mülltonne gelöscht.
    dann habe ich mehrmals
    npm i iobroker.vis-materialdesign@0.5.8
    laufen lassen.
    ich habe noch nichts über das Plus installiert und bekomme folgendes:
     iobroker update -i
    Used repository: stable
    Adapter    "admin"        : 5.4.9    , installed 5.3.8  [Updatable]
    Adapter    "alexa2"       : 3.12.0   , installed 3.11.2 [Updatable]
    Adapter    "backitup"     : 2.4.9    , installed 2.4.6  [Updatable]
    Adapter    "cloud"        : 4.1.1    , installed 4.1.1
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
    Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
    Adapter    "history"      : 2.1.0    , installed 1.11.1 [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 3.1.0    , installed 2.6.3  [Updatable]
    Adapter    "iot"          : 1.11.4   , installed 1.11.4
    Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
    Adapter    "mqtt"         : 4.0.3    , installed 3.0.6  [Updatable]
    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
    Adapter    "shelly"       : 5.3.2    , installed 5.3.2
    Adapter    "simple-api"   : 2.6.5    , installed 2.6.5
    Adapter    "socketio"     : 6.1.3    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sql"          : 2.1.0    , installed 1.16.2 [Updatable]
    Adapter    "telegram"     : 1.12.6   , installed 1.12.2 [Updatable]
    Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
    Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.8 [Updatable]
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "web"          : 5.2.0    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.1.0    , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.6.18   , installed 1.6.16 [Updatable]
    pi@raspberrypi:~ $ iobroker list instances
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7c2a7b1b241aec1184677fe5f01c6278-if00-port0
    + instance is alive
    pi@raspberrypi:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v5.3.8
    system.adapter.alexa2                  : alexa2         - v3.11.2
    system.adapter.backitup                : backitup       - v2.4.6
    system.adapter.cloud                   : cloud          - v4.1.1
    system.adapter.discovery               : discovery      - v3.0.3
    system.adapter.echarts                 : echarts        - v1.0.3
    system.adapter.flot                    : flot           - v1.10.7
    system.adapter.history                 : history        - v1.11.1
    system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
    system.adapter.icons-icons8            : icons-icons8   - v0.0.1
    system.adapter.icons-material-png      : icons-material-png - v0.1.0
    system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
    system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
    system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
    system.adapter.influxdb                : influxdb       - v2.6.3
    system.adapter.iot                     : iot            - v1.11.4
    system.adapter.javascript              : javascript     - v5.2.21
    system.adapter.mqtt                    : mqtt           - v3.0.6
    system.adapter.pushover                : pushover       - v2.1.0
    system.adapter.shelly                  : shelly         - v5.3.2
    system.adapter.sonoff                  : sonoff         - v2.5.1
    system.adapter.sql                     : sql            - v1.16.2
    system.adapter.telegram                : telegram       - v1.12.2
    system.adapter.vis                     : vis            - v1.4.15
    system.adapter.vis-bars                : vis-bars       - v0.1.4
    system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
    system.adapter.vis-history             : vis-history    - v1.0.0
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
    system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
    system.adapter.vis-justgage            : vis-justgage   - v1.0.2
    system.adapter.vis-material-webfont    : vis-material-webfont - v0.0.3
    system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.8
    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
    system.adapter.web                     : web            - v4.3.0
    system.adapter.zigbee                  : zigbee         - v1.6.16
    also wenn ich Euch Jungs folgen kann dann sehe ich den im Text immer noch obwohl er nicht installiert ist, richtig?
    @flohtec76 sagte in Material Design Installation und Widgets:
    vis-materialdesign
    github:	0.5.86
    latest:	0.5.9 for 11 months
    stable:	-.-.-
    Die 0.5.8 ist ja jetzt drin. Ich würde jetzt den ganzen Sums auf Stand bringen.
    • F Flohtec76
      @glasfaser
      laufen lassen.
       iobroker update -i
      + instance is alive
      GlasfaserG Offline
      GlasfaserG Offline
      ???? habe dich doch oben gefragt und du hast geschrieben du hast ihn über + die INSTANZ installiert
      Zeige ... bzw. installiere die INSTANZ
        vis-materialdesign
        github:	0.5.86
        stable:	-.-.-
        GlasfaserG Offline
        GlasfaserG Offline
        @thomas-braun sagte in Material Design Installation und Widgets:
        Warte .... ich habe noch die 0.5.8 aus bestimmten Gründen noch , da ich weiß das Sie 100% funktioniert.
        Ist halt nur Traurig , das der Adapter noch nicht in STABLE ist !
        Thomas BraunT F 2 Antworten Letzte Antwort
        • GlasfaserG Glasfaser
          @glasfaser
          Primär geht es mir auch um den Rest.
          Aber eine 0.5.9, die seit 11 Monaten im Repo schlummert dürfte verwendbar sein.
            Flohtec76
            @glasfaser
            wow jetzt wird es schwer jemanden zu folgen.
            Also ja ich hatte den Adapter gelöscht
            dann die befehle laufen lassen
            dann stand im text das er immer noch zu sehen ist
            und habe ihn wieder über die Mülltonne gelöscht.
            Alle Texte die ich in den letzten zwei drei Posts geschickt habe waren ohne über das + installierten Adapter
            Also werde ich ihn nun erneut über das + hinzufügen
            Thomas kann ich mit seinen Befehlen leider nicht helfen, wenn ich die Kommandos ausführen will sagt er das es diese nicht gibt.
            GlasfaserG Thomas BraunT 3 Antworten Letzte Antwort
            • F Flohtec76
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              Das war kein Befehl , das war nur eine Info zum Adapter Stand
              F 1 Antwort Letzte Antwort
              • F Flohtec76
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                und danach erstmal sagen was jetzt ist
                und nichts löschen oder sonst was quer machen !!!!
                • F Flohtec76
                  @glasfaser
                  @flohtec76
                  iob update
                  iob list adapters | grep vis-materialdesign
                  iob list instances | grep vis-materialdesign
                    Flohtec76
                    schrieb am zuletzt editiert von Flohtec76
                    @glasfaser
                    also ich habe nun nochmal geschaut:
                    der Adapter ist immer NOCH NICHT + installiert aber taucht doch immer noch in der liste auf.
                    Auch die Vis Material webfont hatte ich über die mülltonne gelöscht und der taucht auch im text auf.
                    • F Flohtec76
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @flohtec76
                      Ausgabe von @Thomas-Braun Anfrage fehlt !?
                        @flohtec76
                        Flohtec76
                        @glasfaser
                        Ok wartet mal ich denke ich habe es gefunden.
                        Es gibt zwei Wege die zu deinstallieren?
                        Also gelöscht hatte ich zuerst unter den Instanzen
                        Dann gibt es aber noch die Möglichkeit unter den Adaptern zu löschen was ich nun getan habe und zack
                        weg
                        GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                        • F Flohtec76
                          @glasfaser
                          weg
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @flohtec76
                          Was machst du da !!??
                          So kommen wir nicht weiter .....
                          • F Flohtec76
                            @glasfaser
                            weg
                            @flohtec76
                            Du solltest das nicht deinstallieren. Der Adapter war doch jetzt drin...
                            Da fehlte vermutlich nur die Instanz.
                              @flohtec76
                              Flohtec76
                              sorry dann war ich schneller als ihr.
                              Nun ist es eh zu spät.
                              Also ich habe neun Material über das * installiert
                              anbei zwei fotos und die Adapter Liste
                              system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
                              Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                              • F Flohtec76
                                @flohtec76
                                Och Kerl...
                                Was MACHST DU DA???
                                iobroker upload all
                                • F Flohtec76
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  gezeigt wird 0.5.80
                                  zeige :
                                  iobroker update -i
                                    gezeigt wird 0.5.80
                                    zeige :
                                    iobroker update -i
                                    Flohtec76
                                    @glasfaser
                                    noch läuft
                                    iobroker upload all
                                    • F Flohtec76
                                      @glasfaser
                                      noch läuft
                                      iobroker upload all
                                      Flohtec76
                                      @flohtec76
                                      beide updates sind gelaufen
                                       iobroker update -i
                                      • F Flohtec76
                                        @flohtec76
                                         iobroker update -i
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @flohtec76
                                        Sieht erstmal gut aus .
                                        Was sagt der VIS Editor !?
                                        • F Flohtec76
                                          @flohtec76
                                           iobroker update -i
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Hast du da was am Verwahrungsort rumgeschraubt !?????
