  4. Test Adapter Gartenbewässerung v0.0.x
    apollon77A
beregnungssteuerungbewässerunggartengartenbewässerungmagnetventilventilventile
567 Beiträge 66 Kommentatoren 215.1k Aufrufe 77 Beobachtet
  • S Snapergy
    jetzt kriege ich zahlreiche von diesen Meldungen:
    gartenbewaesserung.1
    	2021-08-16 15:15:16.271	info	State value to set for "gartenbewaesserung.1.config.updateinterval" has to be type "number" but received type "string"
    	2021-08-16 15:15:16.228	info	State value to set for "gartenbewaesserung.1.config.pauseTime" has to be type "number" but received type "string"
    gartenbewaesserung.10
    	2021-08-16 15:15:16.160	info	State value to set for "gartenbewaesserung.10.config.raintresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:16.064	info	State value to set for "gartenbewaesserung.10.config.temptresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:16.002	info	State value to set for "gartenbewaesserung.10.config.ventil10.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:16.002	info	State value to set for "gartenbewaesserung.10.config.ventil9.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:16.001	info	State value to set for "gartenbewaesserung.10.config.ventil8.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:16.000	info	State value to set for "gartenbewaesserung.10.config.ventil7.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:15.999	info	State value to set for "gartenbewaesserung.10.config.ventil6.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:15.998	info	State value to set for "gartenbewaesserung.10.config.ventil5.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:15.997	info	State value to set for "gartenbewaesserung.10.config.ventil4.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:15.988	info	State value to set for "gartenbewaesserung.10.config.ventil3.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:15.987	info	State value to set for "gartenbewaesserung.10.config.ventil2.feuchtigkeit_tresh" has to be type "number" but received type "string"
    	2021-08-16 15:15:15.986	info	State value to set for "gartenbewaesserung.10.config.ventil1.feuchtigkeit_tresh" has to be type "number" but received type "string"
    T
    T
    tombox
    #551
    @snapergy Ja sollte nur beim start passieren
    • BanditFGB
      BanditFGB
      BanditFG
      #552
      @tombox
      hallo ich benutze schon länger deinen Adapter und bin damit sehr zufrieden.
      Seit paar Tagen bekomme ich immer mal diese Warnung, hast du ne Ahnung was das ist?
      gartenbewaesserung.0
      17543	2022-01-10 15:10:21.356	warn	Read-only state "gartenbewaesserung.0.status.startAbend" has been written without ack-flag with value "Mon Jan 10 2022 16:22:28 GMT+0100"
      17543	2022-01-10 15:10:21.356	warn	Read-only state "gartenbewaesserung.0.status.startMorgen" has been written without ack-flag with value "Mon Jan 10 2022 08:07:33 GMT+0100"
      17543	2022-01-10 15:10:21.356	warn	Read-only state "gartenbewaesserung.0.status.sonnenuntergang" has been written without ack-flag with value "16:22:28 GMT+0100 (Mitteleuropäische Normalzeit)"
      17543	2022-01-10 15:10:21.356	warn	Read-only state "gartenbewaesserung.0.status.sonnenaufgang" has been written without ack-flag with value "08:07:33 GMT+0100 (Mitteleuropäische Normalzeit)"
      • BanditFGB BanditFG
        @tombox
        T
        T
        tombox
        #553
        @banditfg auch mit der aktuellen github version?
        BanditFGB 1 Antwort Letzte Antwort
        • T tombox
          BanditFGB
          BanditFGB
          BanditFG
          #554
          @tombox
          ich nutze noch Version 0.0.7 , welche ist den die aktuelle Version?
            @tombox
            T
            T
            tombox
            #555
            @banditfg 0.0.8
            BanditFGB T 2 Antworten Letzte Antwort
            • T tombox
              @banditfg 0.0.8
              BanditFGB
              BanditFGB
              BanditFG
              #556
              @tombox
              auf Github steht gar nichts von v.0.0.8 ?!
              • T tombox
                @banditfg 0.0.8
                T
                T
                Tschaeens
                #557
                @tombox
                Hallo tombox könntest du vielleicht noch eine Option in den Adapter einbauen, dass dieser bevor er die Pumpe zum ersten Mal aktiviert erst alle Feuchtigkeitssensoren überprüft und dann erst die Pumpe startet? Wenn bei mir die Feuchtigkeitsmesser übern Schwellwert sind, dann läuft meine Pumpe oft 2 Minuten bis alle Ventile durchgelaufen sind, weil ich 30 Sekunden Verzögerung zwischen den Sprenger benötige. Vielen Dank.
                Viele Grüße
                • JB_SullivanJ
                  JB_SullivanJ
                  JB_Sullivan
                  #558
                  @tombox
                  Ich weiß das du den Adapter nicht weiter entwickeln wolltest. Trotzdem habe ich eine Frage.
                  Im Vergleich zum Vorjahr, hat es ja viele Updates von anderen Adapter (z.B. Admin) gegeben, die ggf. als Abhängigkeit in deinen Adapter rein spielen.
                  So habe ich in diesen Jahr festgestellt, das man über die VIS nicht mehr sehen kann, wann die Instanz neu gestartet wird. Jede Änderung der Einstellung führt ja zu einem Instanz Neustart.
                  Wie gesagt, letztes Jahr konnte ich in meiner VIS (mit dem Material Design Adapter), sehen das die Instanz gerade neu startet (DP wurde rot) . Danach war dann in der VIS die gemachte Änderung auch sofort sichtbar.
                  Seit diesem Jahr ist der Instanz Neustart nicht mehr sichtbar und man muss eine Browser Tab Aktualisierung (F5) vornehmen wenn wann die Änderungen sehen will. Ich habe bis jetzt auch keinen DP gefunden, den ich verwenden könnte, um den Instanz Neustart im VIS zu "überwachen".
                  Hier z.B. beim ändern der Kalendertag
                  Könntest du ggf. doch noch einen DP unter "info" einbauen, der einen "connection" true/false DP enthält?
                  • T Tschaeens
                    @tombox
                    Viele Grüße
                    T
                    T
                    tombox
                    #559
                    @tschaeens feuchtigkeit vor pumpe is schwer was geht ist ein feuchtigkeit state für die pumpe
                    @JB_Sullivan es gibt ja schon info.connection und beim start ist der auf false und wenn verbindung ist wird er auf true habe jetzt noch eingebaut das er false wird wenn der adaper beendet wird
                    • T tombox
                      JB_SullivanJ
                      JB_SullivanJ
                      JB_Sullivan
                      schrieb am zuletzt editiert von JB_Sullivan
                      #560
                      @tombox sagte in Test Adapter Gartenbewässerung v0.0.x:
                      Ist jetzt erst aber neu - oder? Ab welcher Adapter Version? Ich habe die Version 0.0.8 und den DP Testweise verknüpft, aber in der Version steuerte bislang der DP nicht um.
                      Vielleicht liegt es aber auch am Material Design Adapter ?!?
                      EDIT: Habe es eben gesehen, das du die main.js vor 2 Stunden geändert hast. BtW aus dem Admin 5.x.x heraus läßt sich die Adapter Version 0.0.8 aber nicht installieren. Da muss man den Umweg über den direkten Benutzerdefinierten URL Aufruf gehen. https://github.com/TA2k/ioBroker.gartenbewaesserung
                      Wolltest du den Adapter nicht der Community Prüfung unterziehen, damit er überhaupt offiziell installiert werden kann?
                      JB_SullivanJ T 2 Antworten Letzte Antwort
                      • JB_SullivanJ JB_Sullivan
                        JB_SullivanJ
                        JB_SullivanJ
                        JB_Sullivan
                        #561
                        Funktioniert leider nicht so wie angedacht - auch mit der neuen Version von vor 2 Stunden. Die Instanz stopp und startet zwar, aber der DP gartenbewaesserung.0.info.connection steuert unter Admin 5.4.9 auch auf false, aber relativ schnell wieder auf true - ich glaube das ist zu schnell für die VIS, das bekommt das widget gar nicht so schnell mit.
                        13140	2022-05-17 18:17:52.794	info	Stop ventil4
                        13140	2022-05-17 18:17:52.794	info	Stop ventil2
                        13140	2022-05-17 18:17:52.793	info	Stop ventil1
                        13140	2022-05-17 18:17:52.793	info	Bewässerung stop
                        13140	2022-05-17 18:17:52.792	info	Stop ventil4
                        13140	2022-05-17 18:17:52.791	info	Stop ventil2
                        13140	2022-05-17 18:17:52.789	info	Stop ventil1
                        13140	2022-05-17 18:17:51.999	info	starting. Version 0.0.8 (non-npm: TA2k/ioBroker.gartenbewaesserung#9ec12d2f39898351be9ff6105043a408251e6174) in C:/iobroker/GLT/node_modules/iobroker.gartenbewaesserung, node: v14.16.0, js-controller: 4.0.23
                        13140	2022-05-17 18:17:51.553	debug	States connected to redis: 127.0.0.1:9000
                        13140	2022-05-17 18:17:51.505	debug	States create User PubSub Client
                        13140	2022-05-17 18:17:51.505	debug	States create System PubSub Client
                        13140	2022-05-17 18:17:51.473	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                        13140	2022-05-17 18:17:51.435	debug	Objects connected to redis: 127.0.0.1:9001
                        13140	2022-05-17 18:17:51.430	debug	Objects client initialize lua scripts
                        13140	2022-05-17 18:17:51.342	debug	Objects create User PubSub Client
                        13140	2022-05-17 18:17:51.341	debug	Objects create System PubSub Client
                        13140	2022-05-17 18:17:51.338	debug	Objects client ready ... initialize now
                        13140	2022-05-17 18:17:51.260	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                          T
                          T
                          tombox
                          #562
                          @jb_sullivan Der adapter is nur so installierbar da es nich geplant ist ihn zu veröffenlichen
                          • JB_SullivanJ
                            JB_SullivanJ
                            JB_Sullivan
                            #563
                            @tombox
                            Ich weiß das der Adapter nicht weiter entwickelt wird. Trotzdem eine Frage - ich bin bislang immer sehr gut mit deinem Adapter zurecht gekommen. Seit Sonntag funktioniert aber die Zeitplanung, ab wann bewässert werden soll, nicht mehr. Mit anderen Worten er startet nicht mehr zu den eingestellten Zeit.
                            Am Sonntag habe ich auch das neue JasvaSkript Update 7.1.0 installiert, was in der Versionshistory unter 7.0.5 (2023-06-06 etwas von (klein0r) reset timeouts in blockly geändert hat. Kann das etwas mit deinem Adapter zu tun haben? Mehr Änderungen habe ich an meinem ioB System nicht vorgenommen.
                            Magst du kurz gucken ob diese JS Änderung irgend welche Auswirkungen auf deinen Adapter hat? Wenn JA, hast du Zeit und Lust das ggf. zu korrigieren, damit man den tollen Adapter weiter nutzen kann?
                            Vielen Dank
                              @tombox
                              Vielen Dank
                              T
                              T
                              tombox
                              #564
                              @jb_sullivan Also der Adapter hat kein Einfluss von Javascript Adapter
                              • Z
                                Z
                                ZeroQool
                                #565
                                Ich habe das gleiche Problem, dass seit kurzem der Adapter nicht mehr zu den angegebenen Zeiten funktioniert. Glaube das ist seitdem ich das Update für iobroker Admin installiert habe. Im Log gibt es auch keine Fehlermeldung und ähnliches. Aus dem Changelog konnte ich beim Update erkennen, dass alte NodeJS Versionen nicht mehr verwendet werden können.
                                Ein Update des Adapter wäre echt klasse. Danke
                                • T tombox
                                  Hi ich habe ein Gartenbewässerungs Adapter erstellt.
                                  Er basiert auf dem Skript von Kuddel. Er wurde komplett neugeschrieben nur die Optionen wurden übernommen.
                                  Zum Installieren:
                                  Unter Adapter das Github Icon klicken:6596acc0-e8e2-4c75-9456-86dde5403787-image.png
                                  Beliebig auswählen und die Url einfügen.
                                  Dann unter Adapter den Gartenbewaesserung Adapter suchen und ganz rechts auf das 0b3e4109-9101-4e4f-a81a-24c1a493dca0-image.png klicken.
                                  In den Instanzoptionen die jeweiligen Optionen einstellen.
                                  Mit den states in "control.*" können die Bewässerung oder die einzigen Ventile gestartet und gestoppt werden.
                                  Die bessere alternative die auch weiterentwickelt wird ist:
                                  https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol
                                  https://forum.iobroker.net/topic/44493/test-adapter-sprinkle-control-0-1-4-latest
                                  Z
                                  Z
                                  ZeroQool
                                  #566
                                  @tombox said in Test Adapter Gartenbewässerung v0.0.x:
                                  Kann ich dato nicht weiter empfehlen.
                                  • Z ZeroQool
                                    T
                                    T
                                    tombox
                                    #567
                                    @zeroqool Ohne Fehler kann ich nichts anpassen.. ich habe mal alles aktualisiert aber sehe kein Fehler
                                    83.9k
