  4. [Aufruf] Neuer Adaper Google-Sharedlocations
    6.6k
google shared locations
512 Beiträge 52 Kommentatoren 159.3k Aufrufe 32 Beobachtet
  • J Jan1
    @garfonso
    hier mal das Log im Debug Modus beim Adapter Start:
    2022-05-11 16:59:32.540 - info: admin.0 (281919) ==> Connected system.user.admin from ::ffff:192.168.100.16
    2022-05-11 16:59:39.185 - warn: admin.0 (281919) Read-only state "google-sharedlocations.0.info.augmented_cookie" has been written without ack-flag with value ""
    2022-05-11 16:59:39.277 - info: host.Beelink stopInstance system.adapter.google-sharedlocations.0 (force=false, process=true)
    2022-05-11 16:59:39.288 - info: google-sharedlocations.0 (366242) Got terminate signal TERMINATE_YOURSELF
    2022-05-11 16:59:39.296 - info: host.Beelink stopInstance system.adapter.google-sharedlocations.0 send kill signal
    2022-05-11 16:59:39.293 - info: google-sharedlocations.0 (366242) terminating
    2022-05-11 16:59:39.295 - info: google-sharedlocations.0 (366242) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-05-11 16:59:39.560 - info: admin.0 (281919) <== Disconnect system.user.admin from ::ffff:192.168.100.16
    2022-05-11 16:59:39.957 - info: host.Beelink instance system.adapter.google-sharedlocations.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-05-11 16:59:42.418 - info: host.Beelink instance system.adapter.google-sharedlocations.0 started with pid 367009
    2022-05-11 16:59:43.548 - debug: google-sharedlocations.0 (367009) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-05-11 16:59:43.673 - debug: google-sharedlocations.0 (367009) Objects client ready ... initialize now
    2022-05-11 16:59:43.677 - debug: google-sharedlocations.0 (367009) Objects create System PubSub Client
    2022-05-11 16:59:43.678 - debug: google-sharedlocations.0 (367009) Objects create User PubSub Client
    2022-05-11 16:59:43.742 - debug: google-sharedlocations.0 (367009) Objects client initialize lua scripts
    2022-05-11 16:59:43.749 - debug: google-sharedlocations.0 (367009) Objects connected to redis: 127.0.0.1:9001
    2022-05-11 16:59:43.782 - debug: google-sharedlocations.0 (367009) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-05-11 16:59:43.812 - debug: google-sharedlocations.0 (367009) States create System PubSub Client
    2022-05-11 16:59:43.814 - debug: google-sharedlocations.0 (367009) States create User PubSub Client
    2022-05-11 16:59:43.851 - debug: google-sharedlocations.0 (367009) States connected to redis: 127.0.0.1:9000
    2022-05-11 16:59:44.300 - info: google-sharedlocations.0 (367009) starting. Version 2.1.6 (non-npm: Garfonso/ioBroker.google-sharedlocations#85d8b0a5e1c3eb10986169863c6fd9b3dd271c5d) in /opt/iobroker/node_modules/iobroker.google-sharedlocations, node: v14.19.2, js-controller: 4.0.23
    2022-05-11 16:59:44.334 - info: google-sharedlocations.0 (367009) Starting google shared locations adapter
    2022-05-11 16:59:44.387 - warn: google-sharedlocations.0 (367009) Invalid character in cookie header: … at undefined. Did you copy the full cookie correctly?
    2022-05-11 16:59:44.389 - debug: google-sharedlocations.0 (367009) Polling location every 60s.
    2022-05-11 16:59:44.391 - debug: google-sharedlocations.0 (367009) Need to augment cookie.
    2022-05-11 16:59:44.437 - debug: google-sharedlocations.0 (367009) Polling locations.
    2022-05-11 16:59:44.846 - debug: google-sharedlocations.0 (367009) Response: 200
    2022-05-11 16:59:44.848 - debug: google-sharedlocations.0 (367009) New header received.
    2022-05-11 16:59:44.851 - info: google-sharedlocations.0 (367009) Error in location data parsing: Error: No location data in response. Cookie expired or no users share their location with you.
    2022-05-11 16:59:44.852 - error: google-sharedlocations.0 (367009) Could not parse location data. Probably authentication error. Please check cookie.
    2022-05-11 16:59:45.238 - debug: google-sharedlocations.0 (367009) New header received.
    2022-05-11 16:59:45.893 - debug: google-sharedlocations.0 (367009) New header received.
    GarfonsoG Offline
    GarfonsoG Offline
    Garfonso
    #438
    @jan1
    hm... das "..." Zeichen ist aber schon verdächtig... ist der Cookie mit Rechtsklick -> Copy kopiert worden? Markieren und Strg+C geht nicht (weil zu lang und Teile werden raus genommen und durch ... ersetzt).
    Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
    Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
    • GarfonsoG Garfonso
      @jan1
      Jan1
      #439
      @garfonso
      Es ist egal, wie ich kopiere, der Cookie ist immer identisch und "..." steht auch so im Cookie unter Netzwerkanalyse mit drin.
      GarfonsoG 1 Antwort Letzte Antwort
      • J Jan1
        @garfonso
        GarfonsoG Offline
        GarfonsoG Offline
        Garfonso
        #440
        @jan1 welcher browser?
        Hab es gerade mit Firefox ausprobiert. Es ist richtig, in der Anzeige steht der Cookie mit ... (eben, weil zu lang):
        Wenn ich den "Cookie"-Eintrag einmal mit einem Klick auswähle und dann Rechtsklick -> Copy kopiere, sind die ... aber weg.
        Wenn ich Text markiere (z.B. mit der maus klicken & ziehen), dann geht das kopieren schief, tatsächlich auch über das Rechtsklick Menü.
        (oben mit Rechtsklick -> Copy, unten mit markieren und strg+c):
          Jan1
          #441
          @garfonso
          Im Firefox, weil im Edge ich das nicht gebacken bekomme.
          Wie soll ich denn nun kopieren?
          David G.D GarfonsoG 2 Antworten Letzte Antwort
          • J Jan1
            @garfonso
            David G.D Online
            David G.D Online
            David G.
            #442
            @jan1
            Ich mache es immer am Smartphone.
            Da habe ich die App "WebView Test" (Android).
            (Bediene den iobroker fast komplett am Smartphone. Leider geht das seit dem Admin 5 nicht mehr so gut....).
            Dort gehe ich auf "Coockie bearbeiten".
            Anstatt es zu bearbeiten kopiere ich es mir da komplett raus. Hat bisher immer geklappt.
            • J Jan1
              @garfonso
              GarfonsoG Offline
              GarfonsoG Offline
              Garfonso
              schrieb am zuletzt editiert von Garfonso
              #443
              @jan1
              Also mein vorgehen ist:
              Das Feld mit dem Cookie: einmal mit linksklick anklicken, dann ist es markiert. Dann Rechtklick -> Copy. Da kam bisher immer der ganze Text.
              Als Alternative habe ich gerade etwas eingebaut, es gibt Addons, die Cookies extrahieren können, z.B. für Firefox (habe ich getestet) oder Chrome(ium?) (hab ich nicht getestet, müsste aber auch gehen). Da kommt eine Textdatei raus. Deren Inhalt kannst du komplett in das Textfeld in den Einstellungen kopieren. (ab Version 2.2.0, auf meinem Github)
              Dazu gerne feedback.
              Grundsätzlich scheint bei mir der Cookie aber auch nur noch selten bis gar nicht abzulaufen.
              David G.D J 2 Antworten Letzte Antwort
                @jan1
                David G.D Online
                David G.D Online
                David G.
                #444
                @garfonso
                Dubhadt vor bestimmt 2-3-4 Monaten mal geschrien, dass du was angepasst hast beim Coockie. Seit dem läuft es bei mir durch.
                Was ich manchmal habe ist, dass ich den Adapter neustarten muss weil er den Standort nicht aktualisiert. Denke so alle 2 Wochen.
                  @jan1
                  Jan1
                  #445
                  @garfonso
                  Ich habe das Addon für Firefox getestet und den kompletten Inhalt (sehr viel Zeug) im Adapter eingetragen. Geht nicht und das steht im Log:
                  2022-05-13 15:09:00.878 - info: admin.0 (3161577) ==> Connected system.user.admin from ::ffff:192.168.100.16
                  2022-05-13 15:09:09.928 - warn: admin.0 (3161577) Read-only state "google-sharedlocations.0.info.augmented_cookie" has been written without ack-flag with value ""
                  2022-05-13 15:09:10.043 - info: host.Beelink stopInstance system.adapter.google-sharedlocations.0 (force=false, process=true)
                  2022-05-13 15:09:10.063 - info: host.Beelink stopInstance system.adapter.google-sharedlocations.0 send kill signal
                  2022-05-13 15:09:10.063 - info: google-sharedlocations.0 (1338539) Got terminate signal TERMINATE_YOURSELF
                  2022-05-13 15:09:10.065 - info: google-sharedlocations.0 (1338539) terminating
                  2022-05-13 15:09:10.066 - info: google-sharedlocations.0 (1338539) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-05-13 15:09:10.429 - info: admin.0 (3161577) <== Disconnect system.user.admin from ::ffff:192.168.100.16
                  2022-05-13 15:09:10.720 - info: host.Beelink instance system.adapter.google-sharedlocations.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-05-13 15:09:13.116 - info: host.Beelink instance system.adapter.google-sharedlocations.0 started with pid 1350990
                  2022-05-13 15:09:14.646 - info: google-sharedlocations.0 (1350990) starting. Version 2.2.1 (non-npm: Garfonso/ioBroker.google-sharedlocations#91ce6d3d470cba4011b7861103c4bfffa32dffbe) in /opt/iobroker/node_modules/iobroker.google-sharedlocations, node: v14.19.2, js-controller: 4.0.23
                  2022-05-13 15:09:14.686 - info: google-sharedlocations.0 (1350990) Starting google shared locations adapter
                  2022-05-13 15:09:15.191 - info: google-sharedlocations.0 (1350990) Error in location data parsing: SyntaxError: Unexpected token < in JSON at position 0
                  2022-05-13 15:09:15.192 - error: google-sharedlocations.0 (1350990) Could not parse location data. Probably authentication error. Please check cookie.
                  Adapter Version: 2.2.1
                  XBiTX 1 Antwort Letzte Antwort
                  • J Jan1
                    @garfonso
                    XBiTX Online
                    XBiTX Online
                    XBiT
                    #446
                    @jan1
                    also hatte auch mal Probleme damit, aber aber irgend einer Version :-) kann man alles rein Kopieren der Adapter sucht sich die Werte (So habe ich es jedenfalls verstanden).
                    Vielleicht hilft dir ein Beispiel was bei mir drin steht womit es geht.
                    So sollte der Token aussehen:
                    CONSENT=PENDING+684; NID=511=ioXATcM7sHOgEMLerwYIOvA6PYskEF-wxRbkWpHX3zp6IPZLwx6SSfYFmm4eevuRtk9qFgR4GyinLUs257jmIDilFPW5ICEEdrXy7i5BT3sVOKiChdze76DVDVUT08Co5hHyp0w74DZ6W-RA1WkgcPB7e-4pH4OZG8K0BSZO4WhwiDJAuNU0KnZPc6-4RoE_Au11RniQKYll6NPxChVR; SID=FAgGuPLHegKAhOTeselyrEBcWNOm7t-LMGdp1efeCyAJnBYxXYynZPAkqWjcHIrKlwoWag.; __Secure-1PSID=CAgGuHLHegLAhOTeselyrENcWNOm7t-LMGdp1efeCyAJnBYxoJFzO3XbvzBNsDxp89XiUA.; __Secure-3PSID=CAgGuHLHegLAhOTeselyrENcWNOm7t-LMGdp1efeCyAJnBYxhXrFIpM6-o9CIIAQiiK3hQ.; HSID=A3KPYO0F6WphlZrTX; SSID=Au09niZwvKAqWugqH; APISID=xfSJnRt9Y9AKrZ7R/Au0-exs9a0ZG7jv9k; SAPISID=eF_8dwG5GgBbznyz/AjblA5CLANKBRNv0H; __Secure-1PAPISID=eF_8dwJ5GgBuznyz/AjblA5CLANKLRGv0H; __Secure-3PAPISID=eF_8dwJ5GgBbznyz/AjblA5CLANKVRNv0H; SIDCC=AJi4UfGlIs_-no8vgqfCjYbcSRXPG_kq3-EY5lymulQ0lsdDQ8ZwjH4RzSHXWrwYgvrcy_8Ktg; __Secure-3PSIDCC=ALi4VfH-ri2ejdp8147ynD3-KAcNZTFmtUY6t2gfPZCIf3Sn1aAPtg_L30G19O6rcoE-qrlepg
                    • XBiTX XBiT
                      @jan1
                      Jan1
                      #447
                      @xbit
                      Es ist ja nicht so, dass ich das nicht schon 100 mal erfolgreich gemacht habe. Jetzt gehts einfach nicht mehr, egal was ich wie rein kopiere, er meckert.
                      Edit:
                      Es kann so einfach sein, wenn man einfach auf das ? vor dem Cookie klickt und dort "kopieren" wählt, dann nimmt er wirklich alles und schon läuft es.
                      • J Jan1
                        @xbit
                        Edit:
                        XBiTX Online
                        XBiTX Online
                        XBiT
                        #448
                        @jan1
                        Okay Sorry, dachte nur wegen,
                        es könnte ein Zeichen im String dabei sein was zum SyntaxError führt.
                        Bin kein Experte darin wollte nur ein Beispiel für den Token liefern weil es bis jetzt keiner gemacht hat :-)
                        • XBiTX XBiT
                          @jan1
                          Jan1
                          #449
                          @xbit
                          Es läuft ja wieder. Problem ist wohl, dass der Cookie eben nicht mehr komplett kopiert wird, je nach dem wie man ihn versucht zu kopieren, da er zu lang ist. Übers ? geht es :)
                          • J Jan1
                            @xbit
                            maxpd
                            #450
                            Mein Adapter ist vor ein paar Tagen ebenfalls von alleine auf rot gesprungen. Cookie abgelaufen?
                            Der Cookie sieht nun auch gänzlich anders aus:
                            cookie: AEC=xxx; CONSENT=PENDING+088; SID=xxx.; __Secure-1PSID=xxx.; __Secure-3PSID=xxx.; HSID=xxx; SSID=xxx; APISID=xxx; SAPISID=xxx; __Secure-1PAPISID=xxx; __Secure-3PAPISID=xxx; NID=511=xxx .......
                            Copy & Paste von allem funktioniert trotzdem.
                            maxpd
                              Snigga
                              #451
                              Irgendwie bekomme ich die Cookie nicht richtig gespeichert. Gibt es aktuell einen BUG?
                              • S Snigga
                                maxpd
                                #452
                                @snigga Auch bei mir ist er auf rot gesprungen und neue Cookies werden nur mit connection failed quittiert.
                                maxpd
                                David G.D B 2 Antworten Letzte Antwort
                                • M maxpd
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  #453
                                  @maxpd
                                  Bei mir läuft der Adapter noch.
                                  • M maxpd
                                    bommel_030
                                    #454
                                    @maxpd
                                    Gestern erst den Cookie erneuert. Lief problemlos. Hast du auch alles richtig kopiert? Also rechte Maustaste -> Wert kopieren? (zumindest bei Chrome).
                                    • B bommel_030
                                      @maxpd
                                      maxpd
                                      #455
                                      @bommel_030 hat nu geklappt. hab immer tripleclick gemacht, bis alles markiert war.
                                      aber warum ist er überhaupt abgelaufen? Der war exakt 1 monat alt.
                                      maxpd
                                      • M maxpd
                                        bommel_030
                                        #456
                                        @maxpd
                                        Freut mich. Ich glaube das sitzt nen Werkstudent bei Google und würfelt wann welcher Cookie abläuft ;-)
                                        Spaß beiseite, konnte bis jetzt noch keine Muster erkennen wann die Cookies bei ablaufen.
                                          bommel_030
                                          #457
                                          Läuft der Adapter bei Euch noch einwandfrei? Meine Positionsdaten werden seit Sonntag nicht mehr aktualisiert.
                                          Cookie ist aktuell und Verbindungstest ist auch erfolgreich. Irgendwas scheint er auch abzuholen. Hab die Option "Places-Adapter" aktiviert. Dort werden auch weiterhin die Standorte aktualisiert. Debug-Logs der Adapter sind leider nicht sehr ausgabekräftig.
                                          2022-06-28 15:25:28.082	debug	Response: 200
                                          2022-06-28 15:25:28.074	debug	New header received.
                                          2022-06-28 15:25:27.566	debug	Polling locations.
                                          2022-06-28 15:25:27.552	debug	Need to augment cookie.
                                          2022-06-28 15:25:27.551	debug	Polling location every 300s.
                                          2022-06-28 15:25:27.502	info	Starting google shared locations adapter
                                          2022-06-28 15:25:27.492	info	starting. Version 2.2.1 (non-npm: Garfonso/ioBroker.google-sharedlocations#91ce6d3d470cba4011b7861103c4bfffa32dffbe) in /opt/iobroker/node_modules/iobroker.google-sharedlocations, node: v16.15.1, js-controller: 4.0.23
                                          places.0
                                          2022-06-28 15:25:28.107	warn	Ignoring incomplete message!
                                          places.0
                                          2022-06-28 15:25:28.100	info	Processed message, returning result: {"user":"M","latitude":52.xxxxx,"longitude":13.xxxx,"timestamp":1656422728088,"address":"","date":"2022-06-28 15:25:28","atHome":false,"distance":13036,"name":"","elevation":0,"routeDistance":"","routeDuration":"","routeDurationWithTraffic":""}
                                          places.0
                                          2022-06-28 15:25:28.099	debug	Updating persons at home
                                          places.0
                                          2022-06-28 15:25:28.099	debug	Setting values for user M
                                          places.0
                                          2022-06-28 15:25:28.090	debug	Skipping geocoding (either deactivated by configuration or invalid API key)
                                          places.0
                                          2022-06-28 15:25:28.090	debug	Checking if position is at "K" (radius: 250m)
                                          places.0
                                          2022-06-28 15:25:28.090	debug	Checking if position is at "C" (radius: 250m)
                                          places.0
                                          2022-06-28 15:25:28.090	debug	Checking if position is at "F" (radius: 250m)
                                          places.0
                                          2022-06-28 15:25:28.090	debug	Checking if user "M Birkholz" should be replaced with "Jessica"
                                          places.0
                                          2022-06-28 15:25:28.090	debug	Checking if user "M Birkholz" should be replaced with "Martin"
                                          places.0
                                          2022-06-28 15:25:28.090	debug	Processing message: {"user":"M2","latitude":52.xxxx,"longitude":13.xxxx,"timestamp":1656422728088,"address":"Berlin, Germany","date":"2022-06-28 15:25:28"}
                                          places.0
                                          2022-06-28 15:25:28.087	info	Processed message, returning result: {"user":"M3","latitude":52.xxx,"longitude":13.2xxxx,"timestamp":1656422728082,"address":"","date":"2022-06-28 15:25:28","atHome":false,"distance":13035,"name":"","elevation":0,"routeDistance":"","routeDuration":"","routeDurationWithTraffic":""}
                                          places.0
                                          2022-06-28 15:25:28.087	debug	Updating persons at home
                                          places.0
                                          2022-06-28 15:25:28.086	debug	Setting values for user M1
                                          places.0
                                          2022-06-28 15:25:28.085	debug	Skipping geocoding (either deactivated by configuration or invalid API key)
                                          places.0
                                          2022-06-28 15:25:28.084	debug	Checking if position is at "K" (radius: 250m)
                                          places.0
                                          2022-06-28 15:25:28.084	debug	Checking if position is at "C" (radius: 250m)
                                          places.0
                                          2022-06-28 15:25:28.084	debug	Checking if position is at "F" (radius: 250m)
                                          places.0
                                          2022-06-28 15:25:28.084	debug	Checking if user "M" should be replaced with "J"
                                          places.0
                                          2022-06-28 15:25:28.084	debug	Checking if user "M" should be replaced with "M"
                                          places.0
                                          2022-06-28 15:25:28.084	debug	Processing message: {"user":"M","latitude":52.xxxx,"longitude":13.xxxx,"timestamp":1656422728082,"address":"Berlin, Germany","date":"2022-06-28 15:25:28"}
                                          David G.D M 2 Antworten Letzte Antwort
