  4. Smartmeter: Instanz stürzt nach einer Zeit ab
    6.3k
52 Beiträge 6 Kommentatoren 2.9k Aufrufe 5 Beobachtet
  • M MatzeEscher
    @glasfaser
    Klaro :)
    iobroker list instances
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 7086
    + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
    + system.adapter.sma-em.0                 : sma-em                : raspberrypi                              -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
    + instance is alive
    iobroker list adapters
    system.adapter.admin                   : admin          - v5.3.8
    system.adapter.backitup                : backitup       - v2.4.6
    system.adapter.discovery               : discovery      - v3.0.3
    system.adapter.influxdb                : influxdb       - v2.6.3
    system.adapter.javascript              : javascript     - v5.2.21
    system.adapter.modbus                  : modbus         - v4.0.4
    system.adapter.node-red                : node-red       - v3.2.0
    system.adapter.pushover                : pushover       - v2.1.0
    system.adapter.sma-em                  : sma-em         - v0.6.5
    system.adapter.smartmeter              : smartmeter     - v3.3.4
    iobroker update -i
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "backitup"     : 2.4.6    , installed 2.4.6
    Adapter    "discovery"    : 3.0.3    , installed 3.0.3
    Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
    Adapter    "javascript"   : 5.2.21   , installed 5.2.21
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "modbus"       : 4.0.4    , installed 4.0.4
    Adapter    "node-red"     : 3.2.0    , installed 3.2.0
    Adapter    "pushover"     : 2.1.0    , installed 2.1.0
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
     ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
    uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
     armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v12.22.5
    v12.22.5
    7.5.2
    root
    /home/pi
    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://repos.influxdata.com/debian bullseye InRelease
    OK:4 https://download.docker.com/linux/raspbian bullseye InRelease
    OK:5 https://archive.raspbian.org/raspbian buster InRelease
    Alle Pakete sind aktuell.
    nodejs:
      Installiert:           12.22.5~dfsg-2~11u1
      Installationskandidat: 12.22.5~dfsg-2~11u1
      Versionstabelle:
     *** 12.22.5~dfsg-2~11u1 500
         10.24.0~dfsg-1~deb10u1 500
            500 https://archive.raspbian.org/raspbian buster/main armhf Packages
    dmesg -T
    [Fr Mai 13 10:48:51 2022] xhci_hcd 0000:01:00.0: Ring expansion failed
    [Fr Mai 13 10:48:51 2022] cp210x ttyUSB0: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -12
    [Fr Mai 13 10:48:52 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:48:54 2022] raspberrypi_fw_set_rate: 6 callbacks suppressed
    [Fr Mai 13 10:48:54 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:48:55 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:48:56 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:48:57 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:00 2022] raspberrypi_fw_set_rate: 8 callbacks suppressed
    [Fr Mai 13 10:49:00 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:01 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:02 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:05 2022] raspberrypi_fw_set_rate: 9 callbacks suppressed
    [Fr Mai 13 10:49:05 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:06 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:06 2022] xhci_hcd 0000:01:00.0: Ring expansion failed
    [Fr Mai 13 10:49:06 2022] cp210x ttyUSB0: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -12
    [Fr Mai 13 10:49:07 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:08 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:10 2022] raspberrypi_fw_set_rate: 8 callbacks suppressed
    [Fr Mai 13 10:49:10 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:11 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:21 2022] xhci_hcd 0000:01:00.0: Ring expansion failed
    [Fr Mai 13 10:49:21 2022] cp210x ttyUSB0: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -12
    [Fr Mai 13 10:49:29 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-v3d frequency: -12
    [Fr Mai 13 10:49:30 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-v3d frequency: -12
    [Fr Mai 13 10:49:35 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:36 2022] xhci_hcd 0000:01:00.0: Ring expansion failed
    [Fr Mai 13 10:49:36 2022] cp210x ttyUSB0: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -12
    [Fr Mai 13 10:49:51 2022] xhci_hcd 0000:01:00.0: Ring expansion failed
    [Fr Mai 13 10:49:51 2022] cp210x ttyUSB0: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -12
    [Fr Mai 13 10:49:53 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:54 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:55 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:56 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:58 2022] raspberrypi_fw_set_rate: 5 callbacks suppressed
    [Fr Mai 13 10:49:58 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:49:59 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:00 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:04 2022] raspberrypi_fw_set_rate: 10 callbacks suppressed
    [Fr Mai 13 10:50:04 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:05 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:06 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:06 2022] xhci_hcd 0000:01:00.0: Ring expansion failed
    [Fr Mai 13 10:50:06 2022] cp210x ttyUSB0: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -12
    [Fr Mai 13 10:50:09 2022] raspberrypi_fw_set_rate: 8 callbacks suppressed
    [Fr Mai 13 10:50:09 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:10 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:11 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:12 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:14 2022] raspberrypi_fw_set_rate: 8 callbacks suppressed
    [Fr Mai 13 10:50:14 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:15 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:16 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:17 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:19 2022] raspberrypi_fw_set_rate: 8 callbacks suppressed
    [Fr Mai 13 10:50:19 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:20 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:21 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:21 2022] xhci_hcd 0000:01:00.0: Ring expansion failed
    [Fr Mai 13 10:50:21 2022] cp210x ttyUSB0: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -12
    [Fr Mai 13 10:50:22 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:25 2022] raspberrypi_fw_set_rate: 8 callbacks suppressed
    [Fr Mai 13 10:50:25 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    [Fr Mai 13 10:50:26 2022] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
    top
     top - 10:52:38 up 1 day, 54 min,  3 users,  load average: 1,81, 1,60, 1,27
    Tasks: 208 total,   2 running, 206 sleeping,   0 stopped,   0 zombie
    %CPU(s): 15,8 us,  3,2 sy,  0,0 ni, 80,0 id,  0,2 wa,  0,0 hi,  0,7 si,  0,0 st
    MiB Spch:   3882,5 total,    351,8 free,   1488,6 used,   2042,1 buff/cache
    MiB Swap:    500,0 total,    498,0 free,      2,0 used.   2444,0 avail Spch
      PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
      620 influxdb  20   0  993936 182872  28416 S  22,0   4,6  87:13.60 influxd
      966 iobroker  20   0  276136 152352  29360 S  22,0   3,8 254:17.37 node
     2066 iobroker  20   0  246956 120796  33984 S   8,6   3,0  88:06.56 node
     2046 iobroker  20   0  213932  84044  29300 S   8,2   2,1 118:02.15 node
     2248 iobroker  20   0  209376  77600  29232 S   7,6   2,0 107:01.21 node
     2178 iobroker  20   0  213508  80692  30040 S   3,0   2,0  24:36.70 node
    12791 508       20   0 1442504 341036  19976 S   3,0   8,6   4:36.26 java
      136 root      20   0  210256 134592 133728 S   1,3   3,4   7:36.16 systemd-journal
     2078 iobroker  20   0  191568  55336  29472 S   0,7   1,4   1:41.66 node
     2151 iobroker  20   0  198120  63944  29352 R   0,7   1,6   5:29.30 node
    13413 508       20   0  947512  48588  21960 S   0,7   1,2   0:12.99 mongod
    16151 root      20   0   11460   3276   2700 R   0,7   0,1   0:00.17 top
       18 root      20   0       0      0      0 S   0,3   0,0   0:10.49 ksoftirqd/1
    15064 root      20   0       0      0      0 I   0,3   0,0   0:00.98 kworker/u8:0-writeback
        1 root      20   0   34864   9068   6964 S   0,0   0,2   0:47.51 systemd
        2 root      20   0       0      0      0 S   0,0   0,0   0:00.21 kthreadd
        3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
        4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
        5 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
        9 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
       10 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_rude_
       11 root      20   0       0      0      0 S   0,0   0,0   0:00.00 rcu_tasks_trace
       12 root      20   0       0      0      0 S   0,0   0,0   0:24.52 ksoftirqd/0
       13 root      20   0       0      0      0 I   0,0   0,0   1:01.38 rcu_sched
       14 root      rt   0       0      0      0 S   0,0   0,0   0:00.04 migration/0
       15 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
       16 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
       17 root      rt   0       0      0      0 S   0,0   0,0   0:00.03 migration/1
       21 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
       22 root      rt   0       0      0      0 S   0,0   0,0   0:00.04 migration/2
       23 root      20   0       0      0      0 S   0,0   0,0   0:10.78 ksoftirqd/2
       26 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
       27 root      rt   0       0      0      0 S   0,0   0,0   0:00.03 migration/3
       28 root      20   0       0      0      0 S   0,0   0,0   0:09.95 ksoftirqd/3
       31 root      20   0       0      0      0 S   0,0   0,0   0:00.01 kdevtmpfs
       32 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 inet_frag_wq
       37 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
       38 root      20   0       0      0      0 S   0,0   0,0   0:00.12 khungtaskd
       39 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
       40 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
       41 root      20   0       0      0      0 S   0,0   0,0   0:05.48 kcompactd0
       61 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
       62 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
       63 root     -51   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
       66 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rpciod
    free -ht --mega
                   gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
    Speicher:       3,9G        1,5G        350M         13M        2,0G        2,4G
    Swap:           499M        2,0M        497M
    Gesamt:         4,4G        1,5G        848M
    Die Meldung, die bei dmesg -T kommt, könnte wohl etwas mit meinem Problem zu tun haben.
    Hat die schon einmal jemand gesehen?
    MatzeEscher
    Das ist außerdem ein Raspberry PI 4B mit 4GB RAM.
    USB-Ports habe ich natürlich auch schon einmal umgesteckt.
    • M MatzeEscher
      @glasfaser
      Klaro :)
      + instance is alive
      iobroker update -i
       armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.5
      v12.22.5
      7.5.2
      root
      /home/pi
      nodejs:
        Versionstabelle:
      dmesg -T
      top
      free -ht --mega
      @matzeescher sagte in Smartmeter: Instanz stürzt nach einer Zeit ab:
      Ich denke dmesg ist interessant zu dem "Zeitpunkt wo es kaputt geht reinzuschauen ... also wenn du das mnoch weisst bzw rebooten und laufenlassen und ddann schauen
      • M MatzeEscher
        GlasfaserG Offline
        GlasfaserG Offline
        @matzeescher
        Bitte die Ein-Ausgaben nicht kürzen / bearbeiten .... die ganze Ausgabe davon .
        und das ganze wenn du schon netterweise es im Spoiler setzt in Code-Tags </> einbetten.
        Kann man dann besser lesen !
        • M MatzeEscher
          @glasfaser
          Klaro :)
          + instance is alive
          iobroker update -i
           armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v12.22.5
          v12.22.5
          7.5.2
          root
          /home/pi
          nodejs:
            Versionstabelle:
          dmesg -T
          top
          free -ht --mega
          GlasfaserG Offline
          GlasfaserG Offline
          v12.22.5
          v12.22.5
          7.5.2
          root
          /home/pi
          Das passt schonmal nicht !
          • GlasfaserG Glasfaser
            @matzeescher
            MatzeEscher
            @glasfaser
            Habe es quasi nicht gekürzt. Aber da die Meldung im 5 Sekunden Takt kommt und da jeweils dann ca. 8 Einträge generiert werden, gibt es bei dmesg -T keine anderen Einträge.
            Code-Tag kommt natürlich nächste mal mit rein.
            • M MatzeEscher
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              Doch ... da sieht man das du mit root unterwegs bist ...
              Was ich mir schon gedacht habe ;)
                MatzeEscher
                @glasfaser
                Kannst du mir sagen, was ich noch einmal senden soll ohne root?
                • M MatzeEscher
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Die angefragenen Ausgaben verändern sich nicht dadurch .
                  Du sollst nur nicht mit dem root arbeiten !
                  • apollon77A apollon77
                    MatzeEscher
                    @apollon77
                    Habe versucht die Meldungen von heute Morgen zu finden, als der Adapter ausgestiegen ist. Komme hier aber nur 15 Minuten zurück. Einer eine Idee, wie ich ältere Meldungen bekommen?
                    arteckA apollon77A 2 Antworten Letzte Antwort
                    • M MatzeEscher
                      @apollon77
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @matzeescher
                      npm -v
                      hast du das sauber gezogen .... version 7 ist verkehrt
                      • arteckA arteck
                        @matzeescher
                        npm -v
                        MatzeEscher
                        @arteck
                        Jop. npm habe ich auf die latest Version aktualisiert.
                        npm -v
                        8.10.0
                        • M MatzeEscher
                          @arteck
                          npm -v
                          8.10.0
                          Du solltest nodejs sauber auf Version 14 bringen, die richtige npm-Version dafür wäre dann 6. Kommt aber eh richtig mit, wenn gescheit installiert wird.
                          Dann würdest du auch mit dem nodesource-Paket unterwegs sein und nicht mit der dfsg-Variante.
                          Du fährst einen gefährlichen Mix aus 'Bullseye' und 'Buster'.
                          Ändern!
                          • M MatzeEscher
                            @apollon77
                            @matzeescher Ich glaube das ist auch alles in /var/log/syslog drin?
                            • M MatzeEscher
                              @arteck
                              npm -v
                              8.10.0
                              npm8 bei node 12 ist auch nicht besser
                              spätestens mit der package-lock.json bekommst du bei korrektem downgrade auf v6 Probleme.
                                MatzeEscher
                                Danke @Homoran für den Hinweis.
                                Das Upgrade von NodeJS und das Downgraden von NPM auf 6 hat jetzt dafür gesorgt, dass einige Adapter gar nicht mehr funktionieren.
                                Ich werde nun wohl erstmal einen neuen PI aufsetzen.
                                Melde mich wieder.
                                • M MatzeEscher
                                  Melde mich wieder.
                                  das wird möglicherweise an der package-lock.json liegen.
                                  die musst du jetzt löschen, weil npmv6 die nicht lesen kann und die Adapter nicht neu für npm v6 bauen kann.
                                  Sollte aber auch entsprechend im log stehen.
                                    MatzeEscher
                                    so ich habe den PI komplett neu aufgesetzt.
                                    iobrober neu installiert usw.
                                    Nun liefen die Smartmeter Instanzen (2 Stück) ca. einen Tag und haben beide den gleichen Fehler.
                                    Ich könnte jetzt natürlich neu starten, leider hält die Instanz dann wieder nur einen Tag.
                                    Ich hoffe, dass von der Installation jetzt alles passt.
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v14.19.2
                                    v14.19.2
                                    6.14.17
                                    pi
                                    /home/pi
                                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:3 https://repos.influxdata.com/debian bullseye InRelease
                                    Hit:4 https://download.docker.com/linux/raspbian bullseye InRelease
                                    Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
                                    Hit:6 https://archive.raspbian.org/raspbian bullseye InRelease
                                    Reading package lists... Done
                                    2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    nodejs:
                                     Installed: 14.19.2-deb-1nodesource1
                                     Candidate: 14.19.2-deb-1nodesource1
                                     Version table:
                                    *** 14.19.2-deb-1nodesource1 500
                                           500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                                           500 https://archive.raspbian.org/raspbian bullseye/main armhf Packages
                                    Zum Zeitpunkt des Ausfalls finde ich nur Folgendes im Log ( /var/log/syslog):
                                    May 15 10:10:54 raspberrypi kernel: [154518.756603] xhci_hcd 0000:01:00.0: Ring expansion failed
                                    May 15 10:10:54 raspberrypi kernel: [154518.756615] cp210x ttyUSB0: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -12
                                    May 15 10:10:54 raspberrypi kernel: [154518.904557] raspberrypi-clk soc:firmware:clocks: Failed to change fw-clk-arm frequency: -12
                                    Hat noch jemand eine Idee?
                                    HomoranH GlasfaserG 2 Antworten Letzte Antwort
                                    • M MatzeEscher
                                      armv7l
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v14.19.2
                                      v14.19.2
                                      6.14.17
                                      pi
                                      /home/pi
                                      nodejs:
                                       Version table:
                                      und zwar welchen?
                                      • M MatzeEscher
                                        armv7l
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v14.19.2
                                        v14.19.2
                                        6.14.17
                                        pi
                                        /home/pi
                                        nodejs:
                                         Version table:
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @apollon77 sagte in Smartmeter: Instanz stürzt nach einer Zeit ab:
                                        • Thomas BraunT Online
                                          @matzeescher
                                          Ich habe 2 USB Leseköpfe an einem Raspberry PI und lese diese mit dem iobroker aus.
                                          Werden beide über den Raspberry mit Strom versorgt? Könnte sein, dass die zu viel Saft ziehen.
