  5. Überwachung programmieren (Mqtt-Gerät) ?
2 Beiträge 1 Kommentatoren 280 Aufrufe 1 Beobachtet
  • HumidorH Offline
    HumidorH Offline
    Humidor
    schrieb am zuletzt editiert von Humidor
    Hi
    möchte euch bitten mir da zu helfen.
    Es soll die Verbindung zum Gerät überwacht werden.
    Smart Zähler per Mqtt Verunden, am Stromzähler der PV Anlage.
    {"1.8.0":1329412,"2.8.0":112191923,"3.8.1":1171754,"4.8.1":5825866,"1.7.0":0,"2.7.0":779,"3.7.0":0,"4.7.0":210,"1.128.0":0}
    Überwachungsskript:
    <variables>
    <variable id="BrQx4jB;k={w8|Lu7H">GridÜberwachungMerker</variable> </variables> <block type="comment" id="!O5*y@h_4{oH#[v35s7F" x="12" y="-212"> <field name="COMMENT">-------------Datenpunkte erzeugen-----------</field> <next> <block type="create" id="!HuCpXS@Er4zJUfKk7Z."> <field name="NAME">0_userdata.0.AMISFronius.11280</field> <value name="VALUE"> <block type="math_number" id="vpvqFMA%3YW}T},5Gwi/"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="S6twCn_r$MJpR,{(p[?J"> <field name="TEXT">{"name": "11.280","role": "","type": "number","desc": "Blockly erzeugt","unit": "","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field> </block> </value> <next> <block type="create" id="8j{IBw*;7JMTwD9SR49p"> <field name="NAME">0_userdata.0.AMISFronius.170</field> <value name="VALUE"> <block type="math_number" id="H3KR@Fi=O%.Tk?FL:s+F"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="G-Qm2eEOi$t6ZOk5Y.%T"> <field name="TEXT">{"name": "1.7.0","role": "","type": "number","desc": "Blockly erzeugt","unit": "W","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field> </block> </value> <next> <block type="create" id="GZD9U)C#QTPA-8.l@LBz"> <field name="NAME">0_userdata.0.AMISFronius.180</field> <value name="VALUE"> <block type="math_number" id="5m;z2}GW-5#PwUDe_lN("> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="zH(Q}J2UQ+k/cm1y{}cL"> <field name="TEXT">{"name": "1.8.0","role": "","type": "number","desc": "Blockly erzeugt","unit": "Wh","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field> </block> </value> <next> <block type="create" id="J;IaDKF*{j]J,vTY}(o">
    <field name="NAME">0_userdata.0.AMISFronius.270</field>
    <block type="math_number" id="5m9K)eK)|dzSSAQ#eAl">
    </block>
    </value>
    <block type="text" id="w}X}bl$nftPtXr7_O/w1">
    <field name="TEXT">{"name": "2.7.0","role": "","type": "number","desc": "Blockly erzeugt","unit": "W","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field>
    </block>
    </value>
    <next>
    <block type="create" id="VwIOI)sFdf+M6tuCY},"> <field name="NAME">0_userdata.0.AMISFronius.280</field> <value name="VALUE"> <block type="math_number" id="^#g)/61S5_aH]DIg/#=p"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="gUv/KYl1gS,:ACHf2}r">
    <field name="TEXT">{"name": "2.8.0","role": "","type": "number","desc": "Blockly erzeugt","unit": "Wh","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field>
    </block>
    </value>
    <next>
    <block type="create" id="-^[poh=j1~Ny46ltc$H!">
    <field name="NAME">0_userdata.0.AMISFronius.370</field>
    <block type="math_number" id="P1Jq?WUP|!)YRg;]vG#x">
    </block>
    </value>
    <block type="text" id="J0T-dp0GUw1TRLm5I5rp">
    <field name="TEXT">{"name": "3.7.0","role": "","type": "number","desc": "Blockly erzeugt","unit": "var","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field>
    </block>
    </value>
    <next>
    <block type="create" id="M$}Ohe_bPNA_7m+0OiEM">
    <field name="NAME">0_userdata.0.AMISFronius.381</field>
    <block type="math_number" id="x}dcxrl$0$wM
    HL9/j)k">
    </block>
    </value>
    <block type="text" id="Ri7)*SA=W;R+/w/hq$Pb">
    <field name="TEXT">{"name": "3.8.1","role": "","type": "number","desc": "Blockly erzeugt","unit": "varh","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field>
    </block>
    </value>
    <next>
    <block type="create" id="ZXwHR;CKqcWFw828k?F"> <field name="NAME">0_userdata.0.AMISFronius.470</field> <value name="VALUE"> <block type="math_number" id="3,i08U(eKJ!2nh9g|T"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="Ygy,?zqasm.dRxEu7{9">
    <field name="TEXT">{"name": "4.7.0","role": "","type": "number","desc": "Blockly erzeugt","unit": "var","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field>
    </block>
    </value>
    <next>
    <block type="create" id="r%KYf1.DD7O:3}UPw.{.">
    <field name="NAME">0_userdata.0.AMISFronius.481</field>
    <block type="math_number" id="k$c]1#[aTNaP!;zkge^"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="x,UtW8p%O|1+RG7xlP4!"> <field name="TEXT">{"name": "4.8.1","role": "","type": "number","desc": "Blockly erzeugt","unit": "varh","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field> </block> </value> <next> <block type="create" id="s0wKaBfJz-E-MR3v)A%{"> <field name="NAME">0_userdata.0.AMISFronius.PowerFronius</field> <value name="VALUE"> <block type="math_number" id="gLQqo,y[-y8z[h403efX"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="eItG-33IfIi+buMTx1}">
    <field name="TEXT">{"name": "PowerFronius","role": "","type": "number","desc": "Blockly erzeugt","unit": "W","min": -99999,"max": 99999,"def": 0,"read": true,"write": true}</field>
    </block>
    </value>
    <next>
    <block type="create" id="lVbn$R0O2HDk2C$2]ew"> <field name="NAME">0_userdata.0.AMISFronius.PVPowerFronius</field> <value name="VALUE"> <block type="math_number" id="|J/h]lf7:H9$BwgczL=d"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="8ep8uU8|5N1nn,d40i6">
    <field name="TEXT">{"name": "PVPowerFronius","role": "","type": "number","desc": "Blockly erzeugt","unit": "W","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field>
    </block>
    </value>
    <next>
    <block type="create" id="Wj{{HiTssj%qMxVIKy+Y">
    <field name="NAME">0_userdata.0.AMISFronius.PVÜberschussFronius</field>
    <block type="math_number" id="cY8l^Q5XPHQ9:*7$^)([">
    </block>
    </value>
    <block type="text" id="Ikbdk@,79+jU3Hxh=1Nk">
    <field name="TEXT">{"name": "PVÜberschussFronius","role": "","type": "number","desc": "Blockly erzeugt","unit": "W","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field>
    </block>
    </value>
    <next>
    <block type="create" id="SL7[,atm!W,E7S[*qVn+">
    <field name="NAME">0_userdata.0.AMISFronius.Grid_Caddy_Überwachung</field>
    <block type="text" id="W7}pNe]jKQFmHD
    -E/55">
    <field name="TEXT">false</field>
    </block>
    </value>
    <block type="text" id=",p%ys)W7P@LUw@a=i77|">
    <field name="TEXT">{"name": "Grid Caddy Überwachung","role": "","type": "boolean","read": true,"write": true,"desc": "Blockly erzeugt","def": false}</field>
    </block>
    </value>
    <next>
    <block type="create" id="~2#Bsvh+pYJYyih7jA#o">
    <field name="NAME">0_userdata.0.AMISFronius.Verbrauch</field>
    <block type="math_number" id="pLAXzV8HRg_dE~9Y0cG"> <field name="NUM">0</field> </block> </value> <value name="COMMON"> <block type="text" id="FgGE%m|C^L)BKG0;sNFZ"> <field name="TEXT">{"name": "Verbrauch","role": "","type": "number","desc": "Blockly erzeugt","unit": "W","min": 0,"max": 99999,"def": 0,"read": true,"write": true}</field> </block> </value> <next> <block type="comment" id="X8[M[9%V$RJB8=JyN/V~"> <field name="COMMENT">--------Grid Überwachung-------------</field> <next> <block type="schedule" id="/s|2-R]TRMO+;A|0%Q0l"> <field name="SCHEDULE">* * * * * *</field> <statement name="STATEMENT"> <block type="variables_set" id="Gc;x6l6+JvYgxSM}7_Q["> <field name="VAR" id="BrQx4jB;k=_{w8|Lu7H">GridÜberwachungMerker</field>
    <block type="math_arithmetic" id="P-),PpHB5odHZj7Yh$y3">
    <field name="OP">ADD</field>
    <value name="A">
    <shadow type="math_number" id="9Hszs/e/#{TtnZs!gg:Y">
    <field name="NUM">1</field>
    </shadow>
    <block type="variables_get" id="@MUI]@?x5UiPDHvydHT">
    <field name="VAR" id="BrQx4jB;k={w8|Lu7H">GridÜberwachungMerker</field> </block> </value> <value name="B"> <shadow type="math_number" id="+sm4MQrN)aPW$Tt(V3+;"> <field name="NUM">1</field> </shadow> </value> </block> </value> <next> <block type="controls_if" id="b}eu)RQ[KvK|)b$HvAby"> <value name="IF0"> <block type="logic_operation" id="HJVV8IX8SjFtCXpIjH{" inline="false">
    <field name="OP">AND</field>
    <value name="A">
    <block type="logic_compare" id="$(6a,sn{2c#1%?l$xMz?">
    <field name="OP">GTE</field>
    <value name="A">
    <block type="variables_get" id="Wp|Ssv0ZC#2:Vq48bE!I">
    {w8|Lu7H">GridÜberwachungMerker</field> </block> </value> <value name="B"> <block type="math_number" id="qXjB.(1PWq%v9)gG:-E8"> <field name="NUM">60</field> </block> </value> </block> </value> <value name="B"> <block type="logic_negate" id="o[x-lt[*Lk[AK1QQQ+np"> <value name="BOOL"> <block type="get_value" id="Q5,6D7PCFwmhXP8*2b~U"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.AMISFronius.Grid_Caddy_Überwachung</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="debug" id="cdAPMbFWbCU2zqoY=9W$"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="{j,3Y2S/!)^A|n#$:IQx"> <field name="TEXT">GRID Caddy - ÜBERWACHUNG !! Emergency Stop.</field> </shadow> </value> <next> <block type="telegram" id="]+c_j+kq#L(:q,Qn#*-X"> <field name="INSTANCE">.0</field> <field name="LOG">warn</field> <field name="SILENT">FALSE</field> <field name="PARSEMODE">default</field> <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field> <value name="MESSAGE"> <shadow type="text" id=";()qJUE#t;i6DLLD)cx5"> <field name="TEXT">GRID Caddy - ÜBERWACHUNG !! Emergency Stop.</field> </shadow> </value> <next> <block type="control" id="B(GM_zfC1*!,ZtFzJMf9"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.AMISFronius.Grid_Caddy_Überwachung</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="/05]A@;;Gl[w]:cwoc_R"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="update" id="coN%sO+T[+(u7%Pf7*0b"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.AMISFronius.PowerFronius</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="*#!#nrKkUKreu5Vnq.fG"> <field name="NUM">0</field> </block> </value> <next> <block type="update" id="X:,Y(?}6MxOF+C=n)a}o"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.AMISFronius.PVPowerFronius</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_number" id="=_T4*X_q:sypFoW7Oan">
    </block>
    </value>
    <next>
    <block type="update" id="G/Po_XaGazaEWR-w
    -Q+">
    <field name="OID">0_userdata.0.AMISFronius.PVÜberschussFronius</field>
    <block type="math_number" id="0Jf=O,3ZPY!Hu:c{eR(w">
    </block>
    </value>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </statement>
    <next>
    <block type="on_ext" id="#xeCc]psk3ASFk91E%i"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="8"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="j5Ywa#anjKSfR3Qd.n1M"> <field name="oid">0_userdata.0.AMISFronius.170</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="kW2X]M:Wdm@Pi.y=jU@T"> <field name="oid">0_userdata.0.AMISFronius.270</field> </shadow> </value> <value name="OID2"> <shadow type="field_oid" id="e)1VpdY|NlAW6I}vt(q:"> <field name="oid">0_userdata.0.AMISFronius.180</field> </shadow> </value> <value name="OID3"> <shadow type="field_oid" id="yXrXtJv!wWK%pY[xo4J#"> <field name="oid">0_userdata.0.AMISFronius.280</field> </shadow> </value> <value name="OID4"> <shadow type="field_oid" id="HK?Gz0+]^o._tT.4r70U"> <field name="oid">0_userdata.0.AMISFronius.370</field> </shadow> </value> <value name="OID5"> <shadow type="field_oid" id="{C@MmU!jgU8kk)~fj[6E"> <field name="oid">0_userdata.0.AMISFronius.381</field> </shadow> </value> <value name="OID6"> <shadow type="field_oid" id="k*iAdCGLuvmdGjNCnn)x"> <field name="oid">0_userdata.0.AMISFronius.470</field> </shadow> </value> <value name="OID7"> <shadow type="field_oid" id="D%7PZy:g-sGR^WKfyb6^"> <field name="oid">0_userdata.0.AMISFronius.481</field> </shadow> </value> <statement name="STATEMENT"> <block type="variables_set" id="AR]8m6mIzpoE$y%;jwV4"> <field name="VAR" id="BrQx4jB;k=_{w8|Lu7H">GridÜberwachungMerker</field>
    <block type="math_number" id="8sUOk{J=BMH_.Cvu6Lc+">
    </block>
    </value>
    <next>
    <block type="controls_if" id="op:K+:W+8IYDqdSfrCgD">
    <value name="IF0">
    <block type="get_value" id="uTLWdZKf6s.P6yM+io:U">
    </block>
    </value>
    <block type="control" id="^(,{sC6@pWu_ner;N#4[">
    <block type="logic_boolean" id="fc^!?Y/[7o/On2?Pq+["> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id="N{pn[|GruYgD2lOG4MI+"> <field name="Severity">log</field> <value name="TEXT"> <shadow type="text" id="v8?jb.hF0gVGz=L~N[r">
    <field name="TEXT">GRID Caddy - ÜBERWACHUNG !! Emergency Stop. -> aufgehoben</field>
    </shadow>
    </value>
    <next>
    <block type="telegram" id="n?#u#2M+8PX7w4UQSXd8">
    <field name="LOG">log</field>
    <shadow type="text" id="LMzL1g%9Z+2;b%FAyN~]">
    </shadow>
    </value>
    </block>
    </next>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </statement>
    <next>
    <block type="comment" id="){ZW^w)ZVY;%p=k;P_4q">
    <field name="COMMENT">--------Berechnungen-------------</field>
    <next>
    <block type="on_ext" id="aoFLaml@z+U_,V.H^(yN">
    <value name="OID0">
    <shadow type="field_oid" id="^J!0(9|;hu)h^TZnKr"> <field name="oid">fronius.0.powerflow.P_PV</field> </shadow> </value> <statement name="STATEMENT"> <block type="update" id="~VkAuztOkQT^am.(DtuM"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.AMISFronius.PVPowerFronius</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="get_value" id="qAj3OvkponzKam_6,N!D"> <field name="ATTR">val</field> <field name="OID">fronius.0.powerflow.P_PV</field> </block> </value> </block> </statement> <next> <block type="on_ext" id="%YLMms;v)}v6ngzEMqQ#"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="Zt-ts[8?L7z#P+%]lT:d"> <field name="oid">0_userdata.0.AMISFronius.170</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id="mP]MvPd1N]j;!hjWaM=:"> <field name="oid">0_userdata.0.AMISFronius.270</field> </shadow> </value> <statement name="STATEMENT"> <block type="update" id="N;~AdQb_gJ.n2@|.U)At"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.AMISFronius.PowerFronius</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="jpt1B?zXj:DC55DA([4:"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="5k0Ioo7QW0ya.aP(LTcH"> <field name="NUM">1</field> </shadow> <block type="get_value" id="|ew*tGO%,[i0#+Mc}^JI"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.AMISFronius.170</field> </block> </value> <value name="B"> <shadow type="math_number" id="y7z4B(h?b5yZfFV9Q|@z"> <field name="NUM">1</field> </shadow> <block type="get_value" id="e:(R]$ee![8^%4eu.5W0"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.AMISFronius.270</field> </block> </value> </block> </value> </block> </statement> <next> <block type="on_ext" id="xwjywFu75-DfW|1*1![O"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">any</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="txTG=_l=$)!hv;=pf2"> <field name="oid">0_userdata.0.AMISFronius.PowerFronius</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="K]A{u+XYM{Lm$/G(Ri">
    <value name="IF0">
    <block type="logic_compare" id="/EV6lbjYT-SVVz7%Ha$"> <field name="OP">LTE</field> <value name="A"> <block type="get_value" id="nEIL!;{#6IZ}hL(Ip3=M"> <field name="ATTR">val</field> <field name="OID">0_userdata.0.AMISFronius.PowerFronius</field> </block> </value> <value name="B"> <block type="math_number" id="6NqDo7n^^o;ZUM]]s{K5"> <field name="NUM">0</field> </block> </value> </block> </value> <statement name="DO0"> <block type="update" id="k75;YzOwn$P!7gv1nL5["> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.AMISFronius.PVÜberschussFronius</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="1X-WNmWLBq@cTO[h.2}-"> <field name="OP">MULTIPLY</field> <value name="A"> <shadow type="math_number" id="fBC_6(gR{F)p|d:Odq2]"> <field name="NUM">1</field> </shadow> <block type="get_value" id="7tPiCf(psJeYj6xDB="> <field name="ATTR">val</field> <field name="OID">0_userdata.0.AMISFronius.PowerFronius</field> </block> </value> <value name="B"> <shadow type="math_number" id="Jhsjve)QRT5zINSDAUlR"> <field name="NUM">-1</field> </shadow> </value> </block> </value> </block> </statement> <statement name="ELSE"> <block type="update" id="yCDUFo~VvLekT~CHb7$">
    <block type="math_number" id=":m#arKmuoBrj1cJnK~N"> <field name="NUM">0</field> </block> </value> </block> </statement> </block> </statement> <next> <block type="comment" id="r6lhO|h)kh]#v9fN0yDU"> <field name="COMMENT">------------Verbrauch----------</field> <next> <block type="schedule" id="3gx0XvE):PR3]g:Gd!/e"> <field name="SCHEDULE">* * * * * *</field> <statement name="STATEMENT"> <block type="update" id="byuzZCC{?3ig.Wss|36."> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.AMISFronius.Verbrauch</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="]Fb=_:[-c@/O$T5P$S9S" inline="false"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="m_Pumc3c%r3eSK]+oEB">
    </shadow>
    <block type="get_value" id="I}A9eM|3teDe:|0ckJn%">
    </block>
    </value>
    <value name="B">
    <shadow type="math_number" id="i~2Y8}ngdsLVrgv8PXN8">
    </shadow>
    <block type="get_value" id="hrsUtW:O[=KjoZ6K#DIG">
    </block>
    </value>
    </block>
    </value>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </next>
    </block>
    </xml>
    Auswertung bzw. Weitergabe an andere Blockly:
    <block type="comment" id="K[^T0mqr$6pJ:UzQvfL_" x="-2288" y="-1512">
    <field name="COMMENT">deaktivieren</field>
    <next>
    <block type="schedule" id="wN.Z]41]D-rZ!-FO+(a">
    <field name="SCHEDULE">* * * * </field>
    <block type="controls_if" id="}K?nmR@u~p?KFAUS$.kt">
    <value name="IF0">
    <block type="logic_operation" id="NfV)DJ(/^-1aR}W,5Y%P" inline="false">
    <value name="A">
    <block type="logic_operation" id="6Es80Hxtd
    lz}50kZnw~" inline="false">
    <value name="A">
    <block type="logic_compare" id="C[P}Yj=dOjV~h?AUIo6B">
    <field name="OP">EQ</field>
    <value name="A">
    <block type="get_value" id="{8|~|kWKzX=[#M?7M=|S">
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="zPhpo0_H.,LdMlZ=uFF">
    </block>
    </value>
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="xG$38iJs)RN}DX3VEEqz">
    <value name="A">
    <block type="get_value" id="Vc;
    #6qqvJ;Js:k||A18">
    <field name="OID">fronius.0.info.connection</field>
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="WRNg5/E74uR!swa34Wuc">
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="+2B,hoASo(4fN8fITy(l">
    <value name="A">
    <block type="get_value" id="q+(7pUe3@$p6uSJ$(t39">
    <field name="OID">javascript.0.Zoe.EmergenyStop</field>
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="g-O)0=#t#^+1
    ,GG;A(l">
    </block>
    </value>
    </block>
    </value>
    </block>
    </value>
    <block type="control" id="6O!$zJQtxALp)#K}0Ip"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.Zoe.EmergenyStop</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="zWJUi~@eH@XrWZrrU|">
    </block>
    </value>
    <next>
    <block type="telegram" id="v~]$)OcEv(IE!+55mRm7">
    <shadow type="text">
    <field name="TEXT">PV - GRID ÜBERWACHUNG !! Emergency Stop.</field>
    </shadow>
    <block type="text" id="oDX
    h5HnQ$KxNiY_%xKF">
    <field name="TEXT">PV - GRID ÜBERWACHUNG - deaktiviert</field>
    </block>
    </value>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </next>
    </block>
    <block type="comment" id="@4#Mkg$0m)-ezj=(.X8m" x="-1438" y="-1512">
    <field name="COMMENT">--->> GRID</field>
    <next>
    <block type="on_ext" id="];OPob#qb~#F32L4}^:"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="?R9]{qe~!;hueaHz]fRT"> <field name="oid">0_userdata.0.AMISFronius.Grid_Caddy_Überwachung</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id=",fBow#RKbw],/SFuS=#j"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_compare" id="e}ff6|GZ%5q}L%lh(L$+"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="ni:Ip^.16]N6ucNO{eGV"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="logic_boolean" id="OsNYFBf9nPr_=.izY?pV"> <field name="BOOL">TRUE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="*[h]RG5]Vh~uZ_J8;:IG"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.Zoe.EmergenyStop</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="F$u4heNGTznlH[W98k+">
    </block>
    </value>
    <next>
    <block type="telegram" id=";#rg|W*[{I5bhQGw48pO">
    <shadow type="text" id="Edgsta?i|-%,BT.J].c"> <field name="TEXT">PV - GRID ÜBERWACHUNG !! Emergency Stop.</field> </shadow> <block type="text" id="p,-cCP85q(O/K9gaZ3Zs"> <field name="TEXT">PV - GRID ÜBERWACHUNG !! Emergency Stop.</field> </block> </value> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> <block type="comment" id="X0!gaw:K|{VDJ|eLn4V." x="-688" y="-1513"> <field name="COMMENT">---&gt;&gt; FRONIUS</field> <next> <block type="on_ext" id="M-nFjSx]Z@Vl(F09WLxk"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="vf~HCzj@c6(dI4KRcew~"> <field name="oid">fronius.0.info.connection</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id=".7nCKdAx0NP#mU|qW*zT"> <value name="IF0"> <block type="logic_compare" id="D_EGBhh~pbl?BGG@:D=#"> <field name="OP">EQ</field> <value name="A"> <block type="on_source" id="w*3y8f[SLT^jzf)V,v2f"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="logic_boolean" id="|,BcLGp*SW-{fP1D7?r!"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO0"> <block type="controls_if" id="iFMuy+0$C@*a^iVa,o_5"> <value name="IF0"> <block type="logic_operation" id="UrtJ%{Md,3G4Dq]VOD31" inline="false"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="[{:I!dhS{o;uO|!z=HQe"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="!up/]2E)=[q/][=Y4.+A"> <field name="ATTR">val</field> <field name="OID">kecontact.0.enableUser</field> </block> </value> <value name="B"> <block type="logic_boolean" id="!hWl7:BUCsWq^:.^M]t">
    </block>
    </value>
    </block>
    </value>
    <value name="B">
    <block type="logic_compare" id="^la-mSw!~{H+S]O^tn97">
    <value name="A">
    <block type="get_value" id="KI%V(v]*7#knA2aVHO)J">
    </block>
    </value>
    <value name="B">
    <block type="logic_boolean" id="x1%}vjGz@fC,s4.NrS!"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="=eFI4?F7I6z.(0#zjwN5"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.Zoe.EmergenyStop</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="WJn7B#yq*-@3G6u}L)P">
    </block>
    </value>
    <next>
    <block type="telegram" id="Pb|QNR9ruNjvcAj.2/p_">
    <shadow type="text" id="il(_Tea}8LQF$C{S`Mmf">
    </shadow>
    <block type="text" id="$rPGhb~4[PI86S}7J(fp">
    <field name="TEXT">PV - FRONIUS ÜBERWACHUNG !! Emergency Stop.</field>
    </block>
    </value>
    </block>
    </next>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </statement>
    </block>
    </next>
    </block>
    </xml>
    Es funktioniert zu 99%, aber das 1% mit Fehlauslösungen nervt.
    Denke wenn keine Änderung vom Power kommt, löst mir das aus, aber das kann auch das Maximum vom PV-WR sein.
    Ich möchte eine einfache Lösung, die ich auch zu 100% kapiere. Kein Java!
    Danke!
    BG
    HumidorH 1 Antwort Letzte Antwort
    • HumidorH Humidor
      Hi
      Überwachungsskript:
      <variables>
      </block>
      </value>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      </block>
      </value>
      <next>
      HL9/j)k">
      </block>
      </value>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      </block>
      </value>
      <next>
      -E/55">
      </block>
      </value>
      </block>
      </value>
      <next>
      <value name="A">
      </shadow>
      <value name="A">
      <value name="A">
      </block>
      </value>
      <next>
      -Q+">
      </block>
      </value>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </statement>
      <next>
      </block>
      </value>
      <next>
      <value name="IF0">
      </block>
      </value>
      </shadow>
      </value>
      <next>
      </shadow>
      </value>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </statement>
      <next>
      <next>
      <value name="OID0">
      <value name="IF0">
      </shadow>
      </block>
      </value>
      <value name="B">
      </shadow>
      </block>
      </value>
      </block>
      </value>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </xml>
      <next>
      <value name="IF0">
      <value name="A">
      <value name="A">
      <value name="A">
      </block>
      </value>
      <value name="B">
      </block>
      </value>
      </block>
      </value>
      <value name="B">
      <value name="A">
      #6qqvJ;Js:k||A18">
      </block>
      </value>
      <value name="B">
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      <value name="B">
      <value name="A">
      </block>
      </value>
      <value name="B">
      ,GG;A(l">
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      </block>
      </value>
      <next>
      </shadow>
      h5HnQ$KxNiY_%xKF">
      </block>
      </value>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </next>
      </block>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      </block>
      </value>
      <value name="B">
      <value name="A">
      </block>
      </value>
      <value name="B">
      </block>
      </value>
      <next>
      </shadow>
      </block>
      </value>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </xml>
      Danke!
      HumidorH Offline
      HumidorH Offline
      Humidor
      Step by Step, die Überwachung:
      <variables>
      </block>
      </value>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      </block>
      </value>
      <next>
      HL9/j)k">
      </block>
      </value>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      <next>
      </block>
      </value>
      </block>
      </value>
      <next>
      -E/55">
      </block>
      </value>
      </block>
      </value>
      <next>
      <value name="A">
      </shadow>
      <value name="A">
      <value name="A">
      </block>
      </value>
      <next>
      -Q+">
      </block>
      </value>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </statement>
      <next>
      </block>
      </value>
      <next>
      <value name="IF0">
      </block>
      </value>
      </shadow>
      </value>
      <next>
      </shadow>
      </value>
      </block>
      </next>
      </block>
      </next>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </statement>
      <next>
      <next>
      <value name="OID0">
      <value name="IF0">
      </shadow>
      </block>
      </value>
      <value name="B">
      </shadow>
      </block>
      </value>
      </block>
      </value>
      </block>
      </statement>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </next>
      </block>
      </xml>
      jede Sekunde wird ein Zähler aufgezogen, nach einer bestimmten Zeit 60s (mehr als genug), wird der Fehler erzeugt
      der Zähler wird sobald sich ein Wert geändert hat wieder auf 0 gesetzt und der Überwachungsmerker ggf. gelöscht.
      Alternativ fällt mir gerade ein, der Timestamp von der Mqtt Übertragung.
      BG
