  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    6.0k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
    mmemme
    #543
    ich bekomme eine neuen Fehler beim Anmelden, kennt das bereits jemand?
    2022-04-24 11:13:58.302 - info: host.raspberrypi stopInstance system.adapter.bluelink.0 (force=false, process=true)
    2022-04-24 11:13:58.309 - info: bluelink.0 (28048) Got terminate signal TERMINATE_YOURSELF
    2022-04-24 11:13:58.309 - info: host.raspberrypi stopInstance system.adapter.bluelink.0 send kill signal
    2022-04-24 11:13:58.310 - info: bluelink.0 (28048) Adapter bluelink cleaned up everything...
    2022-04-24 11:13:58.311 - info: bluelink.0 (28048) terminating
    2022-04-24 11:13:58.313 - info: bluelink.0 (28048) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-04-24 11:13:58.962 - info: host.raspberrypi instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-04-24 11:14:01.396 - info: host.raspberrypi instance system.adapter.bluelink.0 started with pid 32534
    2022-04-24 11:14:03.195 - info: bluelink.0 (32534) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.bluelink, node: v10.24.0, js-controller: 3.2.16
    2022-04-24 11:14:03.230 - info: bluelink.0 (32534) Login to api
    2022-04-24 11:14:10.513 - info: bluelink.0 (32534) 1 Vehicles found
    2022-04-24 11:14:10.717 - info: bluelink.0 (32534) Error on API-Full-Status - Fallback GetNormalStatus
    2022-04-24 11:14:10.925 - error: bluelink.0 (32534) Error on API-Request Status
    2022-04-24 11:14:10.926 - error: bluelink.0 (32534) @EuropeController.pin: [400] Bad Request on [PUT] https://prd.eu-ccapi.kia.com:8080/api/v1/user/pin - {"errId":"5757072c-53e3-4a6b-b8f9-2fa778dc021d","errCode":"4003","errMsg":"Invalid values","errBody":{"remainCount":3,"remainTime":300}}
    Meister MopperM M 2 Antworten Letzte Antwort
    • M mmemme
      Meister MopperM Online
      Meister Mopper
      #544
      @mmemme sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
      Das würde ich aber dringend mal auf den aktuellen Stand bringen.
      Proxmox und HA ...
      Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
      • M mmemme
        Michaelnorge
        #545
        @mmemme said in Adapter Hyundai (Bluelink) oder KIA (UVO):
        So was habe ich in meinem log noch nie gesehen...
        • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
          mmemme
          #546
          @meister-mopper ist bereits erledigt, der Fehler besteht weiterhin.
          NewanN 1 Antwort Letzte Antwort
          • M mmemme
            NewanN Offline
            NewanN Offline
            Newan
            #547
            @mmemme Mal in der App ausloggen und wieder einloggen, oft wird da nach einem neuen Password etc gefragt
            • NewanN Newan
              mmemme
              #548
              @newan vielen Dank, ich habe mein Kennwort und PIN zurueckgesetzt, bekomme jetzt einen neuen Fehler beim starten:
              2022-05-08 12:09:53.343 - info: bluelink.0 (1682) Login to api
              2022-05-08 12:10:00.244 - info: bluelink.0 (1682) 1 Vehicles found
              2022-05-08 12:10:03.671 - info: bluelink.0 (1682) Error on API-Full-Status - Fallback GetNormalStatus
              2022-05-08 12:10:04.013 - error: bluelink.0 (1682) Error on API-Request Status
              2022-05-08 12:10:04.014 - error: bluelink.0 (1682) @EuropeVehicle.status: [400] Bad Request on [GET] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/2497512d-a0cb-4e8f-a07c-3c9a9d171e70/status - {"retCode":"F","resCode":"4004","resMsg":"Duplicate request - Duplicate request","msgId":"a16c2adb-38b8-4809-916c-f37e85ff2f0c"}
              • M mmemme
                Aiouh
                #549
                @newan noch ne Frage...kann man den Adapter auch manuell zum Abholen der Werte anstossen?
                Ich würde die Abfragen gerne nur dann machen wenn er angesteckt ist, denn ansonsten wird jedes mal das Fahrzeug aufgeweckt, was ich eigentlich vermeiden will. Notfalls mach ich das mit Stoppen und Starten des Adapters, ist halt nicht so elegant
                • A Aiouh
                  Meister Mopper
                  schrieb am zuletzt editiert von Meister Mopper
                  #550
                  @aiouh
                  Viermal in 24 Stunden ist ja ein Muss für den Erhalt aller Daten. Für die manuelle Aktualisierung ist der control button "force_refresh" zuständig.
                  Proxmox und HA ...
                    @aiouh
                    Meister Mopper
                    #551
                    @meister-mopper
                    Hier mal ein anderes Phänomen:
                    Ich versuche auf verschiedene Weisen, den Ladevorgang abzubrechen und bekomme nur Fehlermeldungen:
                    bluelink.0
                    	2022-05-09 17:47:22.291	error	No command for Control found for: bluelink.0.KNACC81GFN5121414.control.charge_stop
                    bluelink.0
                    	2022-05-09 17:47:03.755	error	No command for Control found for: bluelink.0.KNACC81GFN5121414.control.charge_stop
                    bluelink.0
                    	2022-05-09 17:46:28.571	error	No command for Control found for: bluelink.0.KNACC81GFN5121414.control.charge_stop
                    bluelink.0
                    	2022-05-09 17:45:37.674	error	No command for Control found for: bluelink.0.KNACC81GFN5121414.control.charge_stop
                    1. zwei mal per widget =true
                    2. in den Objekten Button=true
                    3. in den Objekten Button=true (bestätigt)
                    Kann mir jemand sagen, was ich da falsch mache?
                    Proxmox und HA ...
                    A NewanN 2 Antworten Letzte Antwort
                      @meister-mopper
                      bluelink.0
                      bluelink.0
                      bluelink.0
                      bluelink.0
                      Aiouh
                      schrieb am zuletzt editiert von Aiouh
                      #552
                      .deleted
                        @meister-mopper
                        bluelink.0
                        bluelink.0
                        bluelink.0
                        bluelink.0
                        NewanN Offline
                        NewanN Offline
                        Newan
                        #553
                        @meister-mopper Steuer das doch eher über die wallbox. Welche hast den da?
                          Aiouh
                          #554
                          @Meister-Mopper Danke für den Hinweis
                          @newan Ich habe den force refresh mal auf true gesetzt, eine Aktualisierung der Daten ist nicht erfolgt.
                          Dann habe ich ins log geschaut und dort folg. Meldung gesehen
                          bluelink.0 2022-05-09 20:00:50.167	error	@EuropeController.pin: [400] Bad Request on [PUT] https://prd.eu-ccapi.kia.com:8080/api/v1/user/pin - {"errId":"8dd494b6-62b1-4d97-b9e7-e493b9f4b5ca","errCode":"4002","errMsg":"Invalid parameters"}
                          bluelink.0 2022-05-09 20:00:50.166	error	Error on API-Request Status
                          bluelink.0 2022-05-09 20:00:50.068	info	Error on API-Full-Status - Fallback GetNormalStatus
                          bluelink.0 2022-05-09 20:00:49.735	info	1 Vehicles found
                          bluelink.0 2022-05-09 20:00:44.085	info	Login to api
                          bluelink.0 2022-05-09 20:00:43.945	info	starting. Version 2.2.3 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v14.19.1, js-controller: 4.0.23
                          Dann hab ich in den settings der instanz nachgeschaut und festgestellt, dass das Passwort leer war. Ist das immer so?
                          Jedenfalls habe ich es eingetragen, dasselbe Problem. Die PIN habe ich leer gelassen, wüsste nicht wo ich eine solche hätte.
                          Bis heute morgen lief es zuverlässig :(
                          • A Aiouh
                            Michaelnorge
                            #555
                            @aiouh said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                            Die PIN ist die gleiche die Du eingibst wenn Du Bluelink bei Deinem Handy benutzt und da ne Abfrage startest.
                            • NewanN Newan
                              Meister Mopper
                              #556
                              @newan sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                              Ich habe eine EVBox und leider noch keine Möglichkeit gefunden, diese im ioBroker zu steuern.
                              Proxmox und HA ...
                              • M Michaelnorge
                                Aiouh
                                #557
                                @michaelnorge Danke ! Da ich nur mit Fingerprint arbeite nutze ich schon ewig keine PIN mehr, konnte mich aber doch erinnern wie die "damals" war. Jetzt läuft der adapter wieder.
                                Muss ich eigentlich zum refresh den force refresh auf true setzen und dann wieder auf false, z.B. mit 5 s. Verzögerung? Oder reicht es immer nur auf true zu setzen. Per script meine ich.
                                Die Fehler bekomme ich noch, ignoriere ich aber, denn ich brauch die objekte eh nicht.
                                bluelink.0 2022-05-10 20:56:55.581	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
                                bluelink.0 2022-05-10 20:56:55.504	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.doorOpen.backRight" has to be type "boolean" but received type "number"
                                bluelink.0 2022-05-10 20:56:55.452	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.doorOpen.backLeft" has to be type "boolean" but received type "number"
                                bluelink.0 2022-05-10 20:56:55.404	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.doorOpen.frontRight" has to be type "boolean" but received type "number"
                                bluelink.0 2022-05-10 20:56:55.357	info	State value to set for "bluelink.0.KNAJxxxx.vehicleStatus.doorOpen.frontLeft" has to be type "boolean" but received type "number"
                                • A Aiouh
                                  Meister Mopper
                                  #558
                                  @aiouh sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  Ist nicht erforderlich. Einfach mit true aktualisieren.
                                  Proxmox und HA ...
                                    THELOH
                                    #559
                                    @meister-mopper Per Modbus wäre doch eine Option
                                    • T THELOH
                                      Meister Mopper
                                      #560
                                      @theloh
                                      Ich habe bis jetzt leider noch keine Möglichkeit gefunden, wie ich per Modbus die EVBox steuern kann.
                                      Proxmox und HA ...
                                        @theloh
                                        shipper
                                        #561
                                        mein Bluelinkadapter funktioniert, ich kann aber nur einstellen, wie oft täglich die tripinfos aktualisiert werden. Alles andere wird nur aktualisiert, wenn ich den Adapter restarte.
                                        Gibt es für die Aktualisierung z.B. des Akkuzustands eine Einstellmöglichkeit?
                                          shipper
                                          #562
                                          Wenn ich den Adapter restarte bekomme ich bei bei den drivehistorydaten die Meldung:
                                          " has to be type "undefined" but received type "number"
                                          das kann irgendwie nicht sein, das Daten vom Type undefined sein sollen.
                                          sonst läuft der Adapter gut
