  4. Lufdaten.info spammt log voll
    5.9k
31 Beiträge 6 Kommentatoren 4.1k Aufrufe 4 Beobachtet
    mpl1338
    ich benutze zum Auslesen meiner feinerstaubsensoren den Luftdaten.info Adapter.
    Dieser Adapter hat jedoch eine blöde Eigenschaft. Er wird per Cron gestartet, und das im 2 Minuten Takt.
    host.iobroker
    2022-04-30 13:44:01.395	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    host.iobroker
    2022-04-30 13:44:00.017	info	instance system.adapter.luftdaten.0 started with pid 533143
    host.iobroker
    2022-04-30 13:42:01.461	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    host.iobroker
    2022-04-30 13:42:00.040	info	instance system.adapter.luftdaten.0 started with pid 533045
    host.iobroker
    2022-04-30 13:40:01.425	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    host.iobroker
    2022-04-30 13:40:00.019	info	instance system.adapter.luftdaten.0 started with pid 532951
    host.iobroker
    2022-04-30 13:38:01.513	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    host.iobroker
    2022-04-30 13:38:00.032	info	instance system.adapter.luftdaten.0 started with pid 532828
    host.iobroker
    2022-04-30 13:36:01.520	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    host.iobroker
    2022-04-30 13:36:00.049	info	instance system.adapter.luftdaten.0 started with pid 532726
    host.iobroker
    2022-04-30 13:34:01.434	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    host.iobroker
    2022-04-30 13:34:00.036	info	instance system.adapter.luftdaten.0 started with pid 532638
    host.iobroker
    2022-04-30 13:32:01.524	info	instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    host.iobroker
    2022-04-30 13:32:00.026	info	instance system.adapter.luftdaten.0 started with pid 532514
    host.iobroker
    2022-04-30 13:30:11.132	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    lassen sich die Meldungen irgendwie unterdrücken?
    SBorgS FredFF 2 Antworten Letzte Antwort
    • M mpl1338
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      SBorgS Offline
      SBorgS Offline
      SBorg
      @mpl1338 Stelle doch den Adapter von "info" auf bspw. "warn" oder "error" um ;)
      LG SBorg ( SBorg auf GitHub)
        mpl1338
        Steht auf error bereits
        • M mpl1338
          @mpl1338 sagte in Lufdaten.info spammt log voll:
          die Meldung kommt ja auch nicht vom Adapter, sondern vom host
          • M mpl1338
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            FredFF Online
            FredFF Online
            FredF
            Most Active Forum Testing
            Warum das? So oft ändern sich die Werte doch nicht. Standard ist eine halbe Stunde...
            Da lässt sich das ändern:
              mpl1338
              Ich hab meine Frischluft Ansaugung Hinterm Haus. Unser Gelände ist durch eine Stützmauer ca 3m höher wie das darunter liegenden. Der Nachbar unten heizt das ganze Jahr über mit Abfall und benutzt Holz nur zum einheizen.
              Ich Messe die Luft Qualität anhand von Feinstaub und VOC Sensor und schalte die Belüftung aus. Daher ist für mich der kurze Messinterval wichtig.
              • M mpl1338
                und warum der Umweg über luftdaten.info?
                  klassisch
                  Luftdaten.info ist ein Reizwort für mich.
                  Warum? Meine aktuellen Ergebnisse der letzten Tage:
                  Alle gelb hinterlegten Sensorwerte sind ungültig, weil die Luftfeuchte zu hoch und der Sensor out of Spec ist und dann in der Regel zu hohe Meßwerte ausgibt..
                  Luftdaten.info kennzeichnet diese Daten aber nicht als ungültig, sondern verarbeitet auch diese Daten weiter.
                  Wenn man schon eine map-Lösung sucht, dann würde ich https://opensensemap.org/ vorziehen. Die zeigen die Daten wie sie sind - ohne zu werten und alarmieren - und wo verhanden werden auch ergänzende Werte wie Luftfeuchte mit angezeigt.
                  • K klassisch
                    @klassisch sagte in Lufdaten.info spammt log voll:
                    es gab auch mal einen ausführlichen Test eines Landesumweltamtes (???) des Luftdatensensors im Vergleich zu einem geeichten professionellen Sensors.
                    Leider ist der nicht mehr online.
                    Demnach misst der Luftdaten Sensor PM 2.5 so leidlich, PM10 aber deutlich zu hoch.
                    Das passt zu meinen Messwerten. Einmal Homematic (grün) und rinmal Luftdatrn eine Straße weiter.
                    Natürlich verfälschen Kaminfeuer in der unmittelbaren Nachbarschaft die Werte.
                    Aber PM 2.5 passt weitestgehend, während PM10 bei HomeMatic nur ganz selten deutlich Höher als PM 2.5 ist
                    in den Momentanwerten ist HM der untere Block
                      klassisch
                      Man braucht auch die Luftdaten.info SW nicht. Es geht z.B. auch mit ESPHome und dem ioBroker ESPHome Adapter.
                      • K klassisch
                        Aber wenn @mpl1338 seine eigenen Daten in das Luftdaten-Portal einspeist muss er sie doch irgendwie schon zur Verfügung haben
                          klassisch
                          @homoran Da bin ich nicht so sicher. die Luftdaten Community hat ein Programm für den ESP, welches die Daten auf ihren Server
                          übermittelt. Ob die mittlerweile auch noch zusätzlich MQTT oder sowas machen, weiß ich nicht.
                          • K klassisch
                            Burg_Io
                            @klassisch
                            MQTT ist möglich.
                            Hier die Datenpunkte im IoB:
                            • B Burg_Io
                              @klassisch
                              MQTT ist möglich.
                              @burg_io sagte in Lufdaten.info spammt log voll:
                              mach das mal ein wenig größer, damit man sieht wo du dich da befindest und was ankommt
                                Burg_Io
                                Meinst du so?
                                • B Burg_Io
                                  Meinst du so?
                                  Meinst du so?
                                  jepp
                                  Da hast du doch alles!
                                  Warum noch Luftdaten quälen
                                    Meinst du so?
                                    jepp
                                    Burg_Io
                                    Man kann auch die Werte direkt an Influx weitergeben:
                                    HomoranH M 2 Antworten Letzte Antwort
                                      klassisch
                                      schrieb am zuletzt editiert von klassisch
                                      Sieht doch gut aus. Dann kann man das Programm drauf lasse und muß nur den Broker eintragen und schon fertig.
                                      Können die auch SHT31 / SHT35 als T/H Sensor? Für den Ausseneinsatz scheinen die mir haltbarer.
                                      Und auch ein Sintermetall-Schalldämpfer als Gehäuse scheint denen gut zu tun.
                                      • B Burg_Io
                                        das nutzt dir aber nur etwas für Flot, nicht zur Anzeige des Momentanwertes
                                        • K klassisch
                                          Burg_Io
                                          @klassisch
                                          Folgende Sensoren sind angegeben:
