  4. Test Adapter iobroker.uv-protect 0.3.x
41 Beiträge 13 Kommentatoren 5.6k Aufrufe 18 Beobachtet
  • P ps1304
    @simatec erstmal danke für den Adapter - habe ich neu installiert auf iobroker - bekomme für alle Datenpunkte Fehlermeldungen ala:
    Object uv-protect.0.sun_info.sun_position.altitude is invalid: Default value has to be type "number" but received type "string"
    System iobroker: 4.0.19node.js 16.14 / NPM 8.3.1 auf proxmox vm installiert
    Ist der Fehler bekannt?
    Komplettes Log zum Adapterstart:
    2022-03-13 15:42:50.792  - info: host.iobroker-master instance system.adapter.uv-protect.0 started with pid 50746
    2022-03-13 16:42:52.812  - warn: uv-protect.0 (50746) Object uv-protect.0.uv is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.815  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:52.835  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_max is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.835  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:52.848  - warn: uv-protect.0 (50746) Object uv-protect.0.ozone is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.849  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:52.862  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st1 is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.862  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:52.872  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st2 is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.873  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:52.883  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st3 is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.883  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:52.931  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st4 is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.932  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:52.940  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st5 is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.940  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:52.948  - warn: uv-protect.0 (50746) Object uv-protect.0.safe_exposure_time.st6 is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:52.948  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:53.036  - warn: uv-protect.0 (50746) Object uv-protect.0.sun_info.sun_position.azimuth is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:53.036  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:53.043  - warn: uv-protect.0 (50746) Object uv-protect.0.sun_info.sun_position.altitude is invalid: Default value has to be type "number" but received type "string"
    2022-03-13 16:42:53.044  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:53.102  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_alert is invalid: Default value has to be type "boolean" but received type "string"
    2022-03-13 16:42:53.102  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:53.110  - warn: uv-protect.0 (50746) Object uv-protect.0.uv_warn is invalid: Default value has to be type "boolean" but received type "string"
    2022-03-13 16:42:53.110  - warn: uv-protect.0 (50746) This object will not be created in future versions. Please report this to the developer.
    2022-03-13 16:42:53.119  - info: uv-protect.0 (50746) starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v16.14.0, js-controller: 4.0.19```
    simatecS Offline
    simatecS Offline
    simatec
    @ps1304
    Das sind nur Warnungen… Fixe ich in der nächsten Version
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    P Z 2 Antworten Letzte Antwort
    • simatecS simatec
      @ps1304
      ps1304
      @simatec danke dir für die schnelle antwort und deinen adapter
      • simatecS simatec
        @ps1304
        Z Offline
        Z Offline
        zolpetol
        schrieb am zuletzt editiert von zolpetol
        @simatec
        Bei mir leider auch nur aktuelle Daten direkt nach dem Starten des Adapter, danach folgende Meldungen und keine Aktualisierung mehr:
        APi-Key ist eingetragen
        16:43h: zur Zeit funktioniert die Aktualisierung
        19:19h. wieder vorbei Code 403 oder auch Code 500
        simatecS 2 Antworten Letzte Antwort
        • Z zolpetol
          @simatec
          simatecS Offline
          simatecS Offline
          simatec
          @zolpetol Du hast nur eine gewisse Anzahl an API Abrufen innerhalb von 24 Stunden mit der freien Version.
          Du solltest dementsprechend den Zeitintervall nicht so klein setzen
          • Z zolpetol
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            @zolpetol Zitat auf der Page von OpenUV:
            Need more than 50 daily requests? Check our Extended Plan for just $15 USD/month. Payments and billing processed by Stripe.
            Z 1 Antwort Letzte Antwort
            • simatecS simatec
              Z Offline
              Z Offline
              zolpetol
              @simatec
              Danke für die Info! Das Zeitintervall wurde gemäß dieser Info eingestellt:
              • Z zolpetol
                @simatec
                simatecS Offline
                simatecS Offline
                simatec
                @zolpetol Dann sollte es nun funktionieren ...
                • JohGreJ Offline
                  JohGreJ Offline
                  JohGre
                  @zolpetol sagte in Test Adapter iobroker.uv-protect 0.3.x:
                  @simatec
                  Hast du das Problem schon lösen können? Auch bei mir immer wieder ein 403 trotz neuem Key. Werd den Adapter wohl wieder deaktivieren
                  nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
                  • JohGreJ JohGre
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    @johgre Wie oft holst du die Daten?
                    Mit der kostenlosen Version dieser API kannst du maximal 50 Anfragen pro Tag starten.
                    Wenn du mehr abfragen hast, bekommst du diesen fehler.
                    JohGreJ 1 Antwort Letzte Antwort
                    • simatecS simatec
                      JohGreJ Offline
                      JohGreJ Offline
                      JohGre
                      @simatec Default-Einstellung des Adapters
                      • JohGreJ JohGre
                        simatecS Offline
                        simatecS Offline
                        simatec
                        @johgre Dann ist die API sicher gerade nicht erreichbar ... Was aber nicht am Adapter liegt.
                        Es ist ja auch nur eine reine Warnung und nix böses
                        • simatecS simatec
                          Aktuelle Test Version 0.3.1
                          Veröffentlichungsdatum 28.06.2021
                          Github Link https://github.com/simatec/ioBroker.uv-protect
                          Hiermit stelle ich euch den Adapter iobroker.uv-protect vor.
                          Vor 2 Jahren gab es hierzu schon einmal einen Ansatz mit dem Adapter openuv.
                          Da dieser nicht weiterentwickelt wurde, habe ich mich mal ran gesetzt und einen neuen Adapter geschrieben.
                          Was kann der Adapter?
                          Der Adapter liefert euch aktuelle UV-Daten und Ozone-Daten für euren Standort und gibt Warnungen bzw. Alarme bei zu hohen Werten aus.
                          Des Weiteren liefert euch der Adapter alle Sonnenstandsdaten wie Sonnenauf- und untergang, Goldenhour, Position etc.
                          Was benötigt Ihr?
                          Der Adapter benötigt nicht viel und ist relativ selbsterklärend.
                          Es wird lediglich ein ApiKey von https://www.openuv.io benötigt und eure Geodaten.
                          Die Geodaten werden automatisch aus euren Systemeinstellungen geholt oder können auch optional direkt eingetragen werden.
                          Viel Spaß beim testen 😊
                          Changelog
                          0.3.1 (28.06.2021)
                          • (simatec) Date / time formatted
                          0.3.0 (24.06.2021)
                          • (simatec) code cleaning
                          • (simatec) added translate to system language for states
                          • (simatec) Bugfix Timestamp
                          • (simatec) value formating
                          • (simatec) Dependencies updated
                          • (simatec) name for states updated
                          0.2.3
                          • (simatec) apiKey auto encrypted
                          0.2.2
                          • (simatec) apiKey encrypted
                          • (simatec) fix async function
                          0.2.1
                          • (simatec) Fix for latest Repo
                          0.2.0
                          • (simatec) jsonConfig for Admin5 added
                          0.1.0
                          • (simatec) First Beta
                          0.0.1
                          • (simatec) initial release
                          Albert KA Offline
                          Albert KA Offline
                          Albert K
                          @simatec
                          Vielen Dank für den Adapter!!! 👍 👍 👍
                          Hatte mit dem open-uv Adapter mehr und mehr Probleme (ständige Abstürze). Und meine Rollladen Steuerung zur Beschattung basiert auf dem berechneten lokalen UVI Wert.
                          Jetzt klappt das wieder Super!
                          viele Grüße
                          • Jörg KnechtenJ Offline
                            Jörg Knechten
                            Hi der letzte Eintrag ist schon etwas her, aber ich versuche es einfach mal.
                            Erstmal vielen Dank für die Arbeit, die in dem Adapter steckt. Für uns extrem hilfreich. da meine Frau Lupus hat und somit Sonne bzw. hohe UV-Strahlung meiden soll.
                            Leider habe ich ein Problem. Die Werte aktualisieren sich bei mir nur, wenn ich den Adapter neu starte. Aktualisierung, wie empfohlen, alle 60 Min. Das Protokoll spuckt folgendes aus.
                            host.vmiob
                            2022-08-13 07:00:12.503	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                            uv-protect.0
                            2022-08-13 07:00:11.988	info	Terminated (NO_ERROR): Without reason
                            uv-protect.0
                            2022-08-13 07:00:05.984	warn	Request error: AxiosError: timeout of 5000ms exceeded
                            uv-protect.0
                            2022-08-13 07:00:00.909	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                            host.vmiob
                            2022-08-13 07:00:00.164	info	instance system.adapter.uv-protect.0 started with pid 21308
                            host.vmiob
                            2022-08-13 06:00:12.351	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                            uv-protect.0
                            2022-08-13 06:00:11.836	info	Terminated (NO_ERROR): Without reason
                            uv-protect.0
                            2022-08-13 06:00:05.832	warn	Request error: AxiosError: timeout of 5000ms exceeded
                            uv-protect.0
                            2022-08-13 06:00:00.758	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                            host.vmiob
                            2022-08-13 06:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21185
                            host.vmiob
                            2022-08-13 05:00:12.372	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                            uv-protect.0
                            2022-08-13 05:00:11.857	info	Terminated (NO_ERROR): Without reason
                            uv-protect.0
                            2022-08-13 05:00:05.853	warn	Request error: AxiosError: timeout of 5000ms exceeded
                            uv-protect.0
                            2022-08-13 05:00:00.780	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                            host.vmiob
                            2022-08-13 05:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21159
                            mercedesme.0
                            2022-08-13 04:58:46.419	info	Lost WebSocket connection. Reconnect WebSocket
                            host.vmiob
                            2022-08-13 04:00:12.354	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                            uv-protect.0
                            2022-08-13 04:00:11.840	info	Terminated (NO_ERROR): Without reason
                            uv-protect.0
                            2022-08-13 04:00:05.836	warn	Request error: AxiosError: timeout of 5000ms exceeded
                            uv-protect.0
                            2022-08-13 04:00:00.762	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                            host.vmiob
                            2022-08-13 04:00:00.019	info	instance system.adapter.uv-protect.0 started with pid 21131
                            host.vmiob
                            2022-08-13 03:00:12.382	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                            uv-protect.0
                            2022-08-13 03:00:11.867	info	Terminated (NO_ERROR): Without reason
                            uv-protect.0
                            2022-08-13 03:00:05.862	warn	Request error: AxiosError: timeout of 5000ms exceeded
                            uv-protect.0
                            2022-08-13 03:00:00.786	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                            host.vmiob
                            2022-08-13 03:00:00.018	info	instance system.adapter.uv-protect.0 started with pid 21090
                            host.vmiob
                            2022-08-13 02:00:12.353	info	instance system.adapter.uv-protect.0 terminated with code 0 (NO_ERROR)
                            uv-protect.0
                            2022-08-13 02:00:11.840	info	Terminated (NO_ERROR): Without reason
                            uv-protect.0
                            2022-08-13 02:00:05.835	warn	Request error: AxiosError: timeout of 5000ms exceeded
                            uv-protect.0
                            2022-08-13 02:00:00.761	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                            host.vmiob
                            2022-08-13 02:00:00.021	info	instance system.adapter.uv-protect.0 started with pid 21051
                            Das Problem scheint der Timout zu sein. Bin allerdings Newb bzgl. ioBroker.
                            Vielen Dank im Voraus!
                            • Jörg KnechtenJ Jörg Knechten
                              host.vmiob
                              uv-protect.0
                              uv-protect.0
                              uv-protect.0
                              host.vmiob
                              host.vmiob
                              uv-protect.0
                              uv-protect.0
                              uv-protect.0
                              host.vmiob
                              host.vmiob
                              uv-protect.0
                              uv-protect.0
                              uv-protect.0
                              host.vmiob
                              mercedesme.0
                              host.vmiob
                              uv-protect.0
                              uv-protect.0
                              uv-protect.0
                              host.vmiob
                              host.vmiob
                              uv-protect.0
                              uv-protect.0
                              uv-protect.0
                              host.vmiob
                              host.vmiob
                              uv-protect.0
                              uv-protect.0
                              uv-protect.0
                              host.vmiob
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @jörg-knechten Hast du dir ein API-Key geholt und diesen im Adapter eingetragen?
                              Geo-Daten werden vom System geholt ... dort müsst sie aber richtig eingetragen sein.
                              Auch auf die Nachkommastellen achten, da die API von OpenUV diese so benötigt
                              Beispiel:
                              Längengrad: 13.376935
                              Breitgrad: 52.516181
                              Jörg KnechtenJ 2 Antworten Letzte Antwort
                              • simatecS simatec
                                Beispiel:
                                Jörg Knechten
                                @simatec
                                Sorry war im Urlaub.
                                Den API habe ich geholt. Habe jetzt mal die GPS Koordinaten von Hand eingetragen. Mal schauen was passiert.
                                • simatecS simatec
                                  Beispiel:
                                  Jörg Knechten
                                  @simatec
                                  Irgendwie hat er mit einer Zeitüberschreitung zu kämpfen
                                  uv-protect.0
                                  2022-09-06 12:17:30.944	info	Terminated (NO_ERROR): Without reason
                                  uv-protect.0
                                  2022-09-06 12:17:24.939	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                  uv-protect.0
                                  2022-09-06 10:17:19.866	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                  uv-protect.0
                                  2022-09-06 10:15:31.460	info	Terminated (NO_ERROR): Without reason
                                  uv-protect.0
                                  2022-09-06 10:15:25.455	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                  uv-protect.0
                                  2022-09-06 10:15:20.378	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                  uv-protect.0
                                  2022-09-06 10:00:15.848	info	Terminated (NO_ERROR): Without reason
                                  uv-protect.0
                                  2022-09-06 10:00:09.844	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                  uv-protect.0
                                  2022-09-06 10:00:04.764	info	starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v18.6.0, js-controller: 4.0.23
                                  uv-protect.0
                                  2022-09-06 09:00:15.896	info	Terminated (NO_ERROR): Without reason
                                  uv-protect.0
                                  2022-09-06 09:00:09.892	warn	Request error: AxiosError: timeout of 5000ms exceeded
                                  uv-protect.0
                                  2022-09-06 09:```
                                    @simatec
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    uv-protect.0
                                    2022-09-06 09:```
                                    @jörg-knechten
                                    node: v18.6.0
                                    Hat soweit ich das sehe im Moment eh Probleme im Netzwerkbereich.
                                    Geh auf die für den ioBroker empfohlene Version 16.
                                      Jörg Knechten
                                      Vielen Dank!
                                      Muss mich erstmal einlesen wie ich das Downgrade am besten machen kann.
                                      Habe den Boker auf Proxmox mit VM Ubuntu Server laufen.
                                      Bin kein wirklicher Linux -Kenner.
                                        Vielen Dank!
                                        @jörg-knechten sagte in Test Adapter iobroker.uv-protect 0.3.x:
                                        Schau in meiner Signatur. Da steht's drin.
                                        Jörg KnechtenJ 1 Antwort Letzte Antwort
                                          Jörg Knechten
                                          Super hat erstmal geklappt.
                                          Es kommt zwar ab un zu noch der Fehler, aber es läuft.
