  4. [gelöst] ioB 120% Auslastung und no connection to database
    5.9k
53 Beiträge 5 Kommentatoren 5.9k Aufrufe 5 Beobachtet
  • apollon77A apollon77
    Also die jsonl. Files sind jetzt nicht riesig ...
    Bitte poste mal den Inhalt deiner /opt/iobroker/iobroker-data/iobroker.json
    Kueppert
    schrieb am zuletzt editiert von Kueppert
    @apollon77
      "system": {
        "memoryLimitMB": 0,
        "hostname": "",
        "statisticsInterval": 15000,
        "checkDiskInterval": 300000
      "multihostService": {
        "enabled": false,
        "secure": true,
        "password": "xxxxxxxxxxxxxxxxxx",
        "persist": false
      "network": {
        "IPv4": true,
        "IPv6": true,
        "bindAddress": null,
        "useSystemNpm": true
      "objects": {
        "type": "jsonl",
        "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379],
        "host": "127.0.0.1",
        "port": 9001,
        "user": "",
        "pass": "",
        "noFileCache": false,
        "connectTimeout": 2000,
        "options": {
          "auth_pass": null,
          "enableReadyCheck": true,
          "host": "0.0.0.0",
          "port": 9001,
          "db": 0,
          "family": 0,
          "password": null,
          "autoResubscribe": false,
          "connectionName": "host.ioBroker2",
          "retry_max_delay": 5000
        "maxQueue": 1000,
        "dataDir": "../../iobroker-data/"
      "states": {
        "type": "jsonl",
        "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379]
        "port": 9000,
        "maxQueue": 1000,
        "writeFileInterval": 300000,
        "options": {
          "auth_pass": null,
          "host": "0.0.0.0",
          "port": 9000,
          "db": 0,
          "family": 0,
          "password": null,
      "log": {
        "level": "warn",
        "maxDays": 7,
        "noStdout": true,
        "transport": {
          "file1": {
            "type": "file",
            "enabled": true,
            "filename": "log/iobroker",
            "fileext": ".log",
            "maxsize": null,
            "maxFiles": null,
            "maxSize": null,
            "level": ""
          "syslog1": {
            "type": "syslog",
            "enabled": true,
            "host": "192.168.10.10",
            "host_comment": "The host running syslogd, defaults to localhost.",
            "port": "520",
            "port_comment": "The port on the host that syslog is running on, default
            "pid_comment": "PID of the process that log messages are coming from (De
            "protocol": "udp4",
            "protocol_comment": "The network protocol to log over (e.g. tcp4, udp4,
            "path_comment": "The path to the syslog dgram socket (i.e. /dev/log or /
            "facility_comment": "Syslog facility to use (Default: local0).",
            "localhost": "iobroker",
            "localhost_comment": "Host to indicate that log messages are coming from
            "sysLogType": "5424",
            "sysLogType_comment": "The type of the syslog protocol to use (Default:
            "app_name_comment": "The name of the application (Default: process.title
            "eol_comment": "The end of line character to be added to the end of the
            "level": "warn",
            "facility": "",
            "app_name": "process.title"
      "dataDir": "../../iobroker-data/",
      "plugins": null
      "system": {
        "memoryLimitMB": 0,
        "hostname": "",
        "enabled": false,
        "secure": true,
        "password": "xxxxxxxxxxxxxxxxxxxx",
        "persist": false
      "network": {
        "IPv4": true,
        "IPv6": true,
      "objects": {
        "type": "jsonl",
        "port": 9001,
        "user": "",
        "pass": "",
        "options": {
          "auth_pass": null,
          "host": "0.0.0.0",
          "port": 9001,
          "db": 0,
          "family": 0,
          "password": null,
        "maxQueue": 1000,
      "states": {
        "type": "jsonl",
        "port": 9000,
        "maxQueue": 1000,
        "options": {
          "auth_pass": null,
          "host": "0.0.0.0",
          "port": 9000,
          "db": 0,
          "family": 0,
          "password": null,
      "log": {
        "level": "warn",
        "maxDays": 7,
        "noStdout": true,
        "transport": {
          "file1": {
            "type": "file",
            "enabled": true,
            "fileext": ".log",
            "maxsize": null,
            "maxFiles": null,
            "maxSize": null,
            "level": ""
          "syslog1": {
            "type": "syslog",
            "enabled": true,
            "port": "520",
            "protocol": "udp4",
            "level": "warn",
            "facility": "",
      "plugins": null
    • K Kueppert
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 5GB
      Festplattenart: SSD
      Betriebssystem: Ubuntu
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Installationsart: Manuell
      Image genutzt: Nein
      Hallo @apollon77
      weiterführung meines Problems von hier: https://forum.iobroker.net/topic/52208/js-controller-4-0-jetzt-im-beta-latest/726?_=1650617962136
      INFOS inkl. Fehlermeldungen nach frischem Backup-Restore:
      thorsten@ioBroker2:~$ which nodejs node npm && nodejs -v && node -v && npm -v
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.19.1
      v14.19.1
      6.14.16
      thorsten@ioBroker2:~$ iob status
       Cannot load "variables": Connection is closed.
       Cannot initialize database scripts: Cannot load "variables" into objects database: Connection is closed.
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      thorsten@ioBroker2:~$ iob -v
      4.0.21
      thorsten@ioBroker2:~$ df -h
      Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
      udev            2,5G       0  2,5G    0% /dev
      tmpfs           496M    6,7M  489M    2% /run
      /dev/sda1        29G     15G   13G   54% /
      tmpfs           2,5G       0  2,5G    0% /dev/shm
      tmpfs           5,0M       0  5,0M    0% /run/lock
      tmpfs           2,5G       0  2,5G    0% /sys/fs/cgroup
      tmpfs           496M       0  496M    0% /run/user/1000
      root@ioBroker2:~# iobroker stop
      root@ioBroker2:~# iobroker fix
      library: loaded
      Library version=2022-02-10
          Welcome to the ioBroker installation fixer!
          Script version: 2022-02-13
          Installing prerequisites (1/3)
      Holen:1 http://security.debian.org/debian-security buster/updates InRelease [65,4 kB]
      Holen:2 http://ftp.de.debian.org/debian buster InRelease [122 kB]
      Holen:3 http://ftp.de.debian.org/debian buster-updates InRelease [51,9 kB]
      Holen:4 https://repos.influxdata.com/ubuntu bionic InRelease [4.737 B]
      Holen:5 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
      OK:6 https://deb.nodesource.com/node_14.x buster InRelease
      Holen:7 http://security.debian.org/debian-security buster/updates/main Sources [232 kB]
      Holen:8 http://security.debian.org/debian-security buster/updates/main amd64 Packages [318 kB]
      Holen:9 http://security.debian.org/debian-security buster/updates/main Translation-en [173 kB]
      Holen:10 http://ftp.de.debian.org/debian buster/main Sources [7.843 kB]
      Holen:11 http://ftp.de.debian.org/debian buster/main amd64 Packages [7.911 kB]
      Holen:12 http://ftp.de.debian.org/debian buster/main Translation-en [5.969 kB]
      Holen:13 https://repos.influxdata.com/ubuntu bionic/stable amd64 Packages [1.266 B]
      Holen:14 http://ftp.de.debian.org/debian buster-updates/main Sources.diff/Index [10,6 kB]
      Holen:15 http://ftp.de.debian.org/debian buster-updates/main amd64 Packages.diff/Index [10,6 kB]
      Holen:16 http://ftp.de.debian.org/debian buster-updates/main Sources 2022-03-26-2012.00.pdiff [186 B]
      Holen:17 http://ftp.de.debian.org/debian buster-updates/main amd64 Packages 2022-03-26-2012.00.pdiff [168 B]
      Holen:18 https://deb.nodesource.com/node_12.x buster/main amd64 Packages [774 B]
      Es wurden 22,7 MB in 1 min 47 s geholt (213 kB/s).
      N: Für das Depot »http://ftp.de.debian.org/debian buster InRelease« wurde der »Version«-Wert von »10.11« in »10.12« geändert.
      Installed gcc-c++
      Installed cmake
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      @kueppert
      wo ist hier ein BUG von ioBroker?
        @kueppert sagte in ioBroker mit 120% Auslastung und no connection to database:
        lsof /opt/iobroker/iobroker-data/objects.jsonl
        Kueppert
        @thomas-braun da passiert nix:
        thorsten@ioBroker2:~$ lsof /opt/iobroker/iobroker-data/objects.jsonl
        • K Kueppert
          Mit
          sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
          sollte was kommen.
          • K Kueppert
            @thomas-braun arbeite wieder mit dem User, nicht mehr mit root. Werd ich ab sofort so handhaben 👍
            Reboot tut gut...hab ich auch gerade gemacht. Mal schauen was passiert...
            login as: thorsten
            thorsten@192.168.10.13's password:
            Linux ioBroker2 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64
            permitted by applicable law.
            Last login: Fri Apr 22 12:28:43 2022 from 192.168.1.42
            Ausgabe TOP:
            @kueppert Frage zum Top: Da läuft auch ein Redis server??? Wird scheinbar nicht genutzt
            Ansonsten bitte mal iobroker stoppen und wirklich sicherstellen das er aus ist und ggf rozesse killen und dann bitte mal neu "iob status"
              Mit
              sollte was kommen.
              Kueppert
              thorsten@ioBroker2:~$ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
              [sudo] Passwort für thorsten:
              COMMAND   PID     USER   FD   TYPE DEVICE SIZE/OFF    NODE NAME
              iobroker. 874 iobroker   19u   REG    8,1 51272289 1451506 /opt/iobroker/iobroker-data/objects.jsonl
                Kueppert
                @apollon77 für meine Begriffe (command spuckt nix aus) läuft da nix sonst?
                thorsten@ioBroker2:~$ iobroker stop
                thorsten@ioBroker2:~$ ps auxww|grep io
                root        12  0.0  0.0      0     0 ?        S    12:30   0:00 [migration/0]
                root        16  0.6  0.0      0     0 ?        S    12:30   0:05 [migration/1]
                message+   377  0.1  0.0   8980  4168 ?        Ss   12:31   0:01 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                thorsten   914  0.0  0.0   6084   892 pts/0    S+   12:45   0:00 grep io
                den Redis-Server hab ich bewusst nie selbst installiert manuell...
                • K Kueppert
                  @kueppert Und was sagt "iob status" jetzt?
                    Kueppert
                    @apollon77
                    No connection to databases possible ...
                    • K Kueppert
                      @kueppert
                      Der Hinweis von @apollon77 ist richtig. Wenn redis nicht (mehr) genutzt wird, weg damit.
                      apt policy redis
                      Ggf. deinstallieren.
                      sudo apt remove redis
                      • K Kueppert
                        @apollon77
                        @kueppert Ok, dann ändere bitte mal im iobroker.json die beiden
                        zu 30000
                        dann?
                          @kueppert
                          apt policy redis
                          Kueppert
                          thorsten@ioBroker2:~$ apt policy redis
                          redis:
                            Installiert:           (keine)
                            Installationskandidat: 5:5.0.14-1+deb10u2
                            Versionstabelle:
                               5:5.0.14-1+deb10u2 500
                                  500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                                  500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                          hab noch nicht deinstalliert - steht aber auch da wär nix installiert?
                          • K Kueppert
                            redis:
                              Versionstabelle:
                            In deinem top sieht man mit PID 422 einen redis-server Prozess.
                            systemctl status redis-server
                              zu 30000
                              dann?
                              Kueppert
                              @apollon77 hab nur ein connection-timeout gefunden?
                              iobroker is not running on this host.
                              Objects type: jsonl
                              States  type: jsonl
                                Kueppert
                                @thomas-braun sagte in ioBroker mit 120% Auslastung und no connection to database:
                                thorsten@ioBroker2:~$ systemctl status redis-server
                                ● redis-server.service - Advanced key-value store
                                   Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor pre
                                   Active: active (running) since Fri 2022-04-22 12:31:07 CEST; 23min ago
                                     Docs: http://redis.io/documentation,
                                           man:redis-server(1)
                                  Process: 383 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exite
                                 Main PID: 422 (redis-server)
                                    Tasks: 4 (limit: 4915)
                                   Memory: 15.3M
                                   CGroup: /system.slice/redis-server.service
                                           └─422 /usr/bin/redis-server 127.0.0.1:6379
                                lines 1-11/11 (END)
                                soll ich den Befehl zum deinstallieren nun ausführen? Redis nutze ich nicht
                                • K Kueppert
                                  Objects type: jsonl
                                  States  type: jsonl
                                  @kueppert Ok, heisst das die Standard 5s nicht reichen das er die Files lesen kann ... da sist komisch ...
                                  Aber ok ...
                                  iob list instances ?
                                  • K Kueppert
                                               man:redis-server(1)
                                       Memory: 15.3M
                                    lines 1-11/11 (END)
                                    @kueppert
                                    Bitte das Fenster des Terminals mal größer machen. Da fehlt rechts Text.
                                    sudo systemctl stop redis-server
                                    sudo systemctl disable redis-server
                                    • K Kueppert
                                                 man:redis-server(1)
                                         Memory: 15.3M
                                      lines 1-11/11 (END)
                                      @kueppert
                                      apt policy redis*
                                      Da ist vermutlich das Paket redis-server installiert.
                                        Aber ok ...
                                        Kueppert
                                        @apollon77 sagte in ioBroker mit 120% Auslastung und no connection to database:
                                        iob list instances
                                        thorsten@ioBroker2:~$ iob list instances
                                          system.adapter.admin.0                  : admin                 : ioBroker2                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          system.adapter.alarm.0                  : alarm                 : ioBroker2                                -  enabled
                                          system.adapter.alexa2.0                 : alexa2                : ioBroker2                                -  enabled
                                          system.adapter.alias-manager.0          : alias-manager         : ioBroker2                                -  enabled
                                          system.adapter.backitup.0               : backitup              : ioBroker2                                -  enabled
                                          system.adapter.daswetter.0              : daswetter             : ioBroker2                                -  enabled
                                          system.adapter.denon.0                  : denon                 : ioBroker2                                -  enabled
                                          system.adapter.discovery.0              : discovery             : ioBroker2                                -  enabled
                                          system.adapter.echarts.0                : echarts               : ioBroker2                                -  enabled
                                          system.adapter.email.0                  : email                 : ioBroker2                                -  enabled
                                          system.adapter.flot.0                   : flot                  : ioBroker2                                -  enabled
                                          system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBroker2                                -  enabled
                                          system.adapter.harmony.0                : harmony               : ioBroker2                                -  enabled
                                          system.adapter.history.0                : history               : ioBroker2                                -  enabled
                                          system.adapter.hm-rega.0                : hm-rega               : ioBroker2                                -  enabled
                                          system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker2                                -  enabled, port: 0
                                          system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker2                                -  enabled, port: 0
                                          system.adapter.hue.0                    : hue                   : ioBroker2                                -  enabled, port: 80
                                          system.adapter.ical.0                   : ical                  : ioBroker2                                -  enabled
                                          system.adapter.ical.1                   : ical                  : ioBroker2                                -  enabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker2                                -  enabled
                                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker2                                -  enabled
                                          system.adapter.influxdb.0               : influxdb              : ioBroker2                                -  enabled, port: 8086
                                          system.adapter.info.0                   : info                  : ioBroker2                                -  enabled
                                          system.adapter.iot.0                    : iot                   : ioBroker2                                -  enabled
                                          system.adapter.iqontrol.0               : iqontrol              : ioBroker2                                -  enabled
                                          system.adapter.javascript.0             : javascript            : ioBroker2                                -  enabled
                                          system.adapter.logparser.0              : logparser             : ioBroker2                                -  enabled
                                          system.adapter.nut.0                    : nut                   : ioBroker2                                -  enabled
                                          system.adapter.pi-hole.0                : pi-hole               : ioBroker2                                -  enabled
                                          system.adapter.ping.0                   : ping                  : ioBroker2                                - disabled
                                          system.adapter.pollenflug.0             : pollenflug            : ioBroker2                                -  enabled
                                          system.adapter.proxmox.0                : proxmox               : ioBroker2                                -  enabled, port: 8006
                                          system.adapter.scenes.0                 : scenes                : ioBroker2                                -  enabled
                                          system.adapter.shelly.0                 : shelly                : ioBroker2                                -  enabled, port: 1882, bind: 0.0.0.0
                                          system.adapter.simple-api.0             : simple-api            : ioBroker2                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          system.adapter.smartcontrol.0           : smartcontrol          : ioBroker2                                -  enabled
                                          system.adapter.snmp.0                   : snmp                  : ioBroker2                                -  enabled
                                          system.adapter.socketio.0               : socketio              : ioBroker2                                -  enabled, port: 8084, bind: 192.168.10.13, run as: admin
                                          system.adapter.sonoff.0                 : sonoff                : ioBroker2                                -  enabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.synology.0               : synology              : ioBroker2                                -  enabled, port: 5001
                                          system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker2                                -  enabled
                                          system.adapter.telegram.0               : telegram              : ioBroker2                                -  enabled, port: 8443, bind: 0.0.0.0
                                          system.adapter.text2command.0           : text2command          : ioBroker2                                -  enabled
                                          system.adapter.tr-064.0                 : tr-064                : ioBroker2                                -  enabled
                                          system.adapter.trashschedule.0          : trashschedule         : ioBroker2                                -  enabled
                                          system.adapter.unifi.0                  : unifi                 : ioBroker2                                -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : ioBroker2                                -  enabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker2                                -  enabled
                                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker2                                -  enabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker2                                -  enabled
                                          system.adapter.vis-history.0            : vis-history           : ioBroker2                                -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker2                                -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker2                                -  enabled
                                          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker2                                -  enabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker2                                -  enabled
                                          system.adapter.vis-players.0            : vis-players           : ioBroker2                                -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker2                                -  enabled
                                          system.adapter.vis-weather.0            : vis-weather           : ioBroker2                                -  enabled
                                          system.adapter.vis.0                    : vis                   : ioBroker2                                -  enabled
                                          system.adapter.web-speedy.0             : web-speedy            : ioBroker2                                -  enabled
                                          system.adapter.web.0                    : web                   : ioBroker2                                -  enabled, port: 8082, bind: 192.168.10.13, run as: admin
                                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker2                                -  enabled
                                          system.adapter.wled.0                   : wled                  : ioBroker2                                -  enabled
                                          system.adapter.yeelight-2.0             : yeelight-2            : ioBroker2                                -  enabled
                                          system.adapter.zigbee.0                 : zigbee                : ioBroker2                                -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_9271b043fa93eb11969ca85b3d98b6d1-if00-port0
                                        + instance is alive
                                          @kueppert
                                          Kueppert
                                             Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                                             Active: active (running) since Fri 2022-04-22 12:31:07 CEST; 30min ago
                                                     man:redis-server(1)
                                            Process: 383 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=0/SUCCESS)
                                             Memory: 15.3M
                                          services deaktiviert:
                                          thorsten@ioBroker2:~$ sudo systemctl stop redis-server
                                          thorsten@ioBroker2:~$ sudo systemctl disable redis-server
                                          Synchronizing state of redis-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
                                          Executing: /lib/systemd/systemd-sysv-install disable redis-server
                                          Removed /etc/systemd/system/redis.service.
                                          Removed /etc/systemd/system/multi-user.target.wants/redis-server.service.
                                          thorsten@ioBroker2:~$ apt policy redis*
                                          redis-redisearch-doc:
                                            Installationskandidat: 1:1.2.1-4
                                            Versionstabelle:
                                               1:1.2.1-4 500
                                          redis-redisearch:
                                            Versionstabelle:
                                               1:1.2.1-4 500
                                          redis:
                                            Versionstabelle:
                                          redis-sentinel:
                                            Versionstabelle:
                                          redis-tools:
                                            Installiert:           5:5.0.14-1+deb10u2
                                            Versionstabelle:
                                           *** 5:5.0.14-1+deb10u2 500
                                          redis-server:
                                            Versionstabelle:
