  4. zigbee Adapter
    5.9k
zigbee Adapter
38 Beiträge 5 Kommentatoren 3.3k Aufrufe 7 Beobachtet
  • M michihorn
    @arteck Ja habe ich schon, COM4 ist ausgewählt. Jetzt habe ich nochmal alles gelöscht, Adapter, und Verezeichnis, den Adapter nochmal von GIT installiert aber ohne das Backup zu kopieren, also Blanko:
    zigbee.0	2022-04-05 15:51:48.141	info	(9316) Installed Version: ioBroker/ioBroker.zigbee#ffe1892c1134a7f4b39a5e364b32090296e5eef6
    zigbee.0	2022-04-05 15:51:48.127	error	(9316) Error herdsman start
    zigbee.0	2022-04-05 15:51:48.126	error	(9316) Failed to start Zigbee
    zigbee.0	2022-04-05 15:51:48.125	error	(9316) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Opening COM4: Access denied'"
    zigbee.0	2022-04-05 15:51:48.060	info	(9316) Starting Zigbee npm ...
    zigbee.0	2022-04-05 15:51:48.057	info	(9316) Try to reconnect. 1 attempts left
    zigbee.0	2022-04-05 15:51:38.052	error	(9316) Error herdsman start
    zigbee.0	2022-04-05 15:51:38.052	error	(9316) Failed to start Zigbee
    zigbee.0	2022-04-05 15:51:38.051	error	(9316) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0	2022-04-05 15:51:18.083	info	(9316) Installed Version: ioBroker/ioBroker.zigbee#ffe1892c1134a7f4b39a5e364b32090296e5eef6
    zigbee.0	2022-04-05 15:51:17.095	info	(9316) Starting Zigbee npm ...
    zigbee.0	2022-04-05 15:51:16.833	info	(9316) starting. Version 1.6.16 (non-npm: ioBroker/ioBroker.zigbee#ffe1892c1134a7f4b39a5e364b32090296e5eef6) in C:/iobroker/SmartHome/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.
    zigbee.0	2022-04-05 15:51:06.545	info	(15764) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2022-04-05 15:51:06.542	info	(15764) terminating
    zigbee.0	2022-04-05 15:51:06.541	warn	(15764) Failed to stop zigbee during startup
    zigbee.0	2022-04-05 15:51:06.511	info	(15764) Zigbee: disabling joining new devices.
    zigbee.0	2022-04-05 15:51:06.507	info	(15764) cleaned everything up...
    zigbee.0	2022-04-05 15:51:06.504	info	(15764) Got terminate signal TERMINATE_YOURSELF
    arteckA Offline
    arteckA Offline
    arteck
    @michihorn das hab ic hnicht gesagt... war doch alles ok bis dahin .. das einzige war der COM4 war belegt..eineinfaches neu starten der Kiste hätte auch gereicht.
    • arteckA arteck
      michihorn
      @arteck Die Maschine habe ich auch schon gestartet, aber ohne Veränderung, der Adapter bleibt GELB
      • M michihorn
        arteckA Offline
        arteckA Offline
        arteck
        @michihorn
        der COM4 wird von irgendeinem anderen Programm in beschlag genommen..
        deshlab kann der iobroker da nicht dran kommen.. ewtl. zieh den mal ab und steck den wieder rein
        M 2 Antworten Letzte Antwort
        • arteckA arteck
          @michihorn
          michihorn
          @arteck Das wir schwierig, da der Rechner 300 KM entfernt steht 🙄
          Kann ich evtl am Wochenende mal machen
          • arteckA arteck
            @michihorn
            michihorn
            @arteck Hallöchen, ein freundlicher Nachbar hat den Rechner einmal per Ausschaltknopf augeschaltet, ist offensichtlich was anderes als wenn ich den Rechner nur aus der Ferne per Remote neustarte. Der Adapter ist jetzt grün, die Geräte mit dem Backup vom 2.4.22 sind zu sehen, zeigen aber keinen Status an, aussderm sind viele Namen verloren gegangen.
            Was kann ich tun?
            Michael
            • M michihorn
              Was kann ich tun?
              Michael
              arteckA Offline
              arteckA Offline
              arteck
              @michihorn zumindest läuft die instanz.. die wirst du wohl neu anlernen müssen..
              und für die zukunft.. wenn was nicht läuft ist ein zurückspielen des Backups eher kontraproduktiv.. vor allem wenn man nicht weiss was man macht.
              der cc2531 ist ne zicke .. tausche den mal aus.. vor allem da du keinen Router im Netz hast..der wird dir immer wieder aussteigen..
              • arteckA arteck
                michihorn
                @arteck Welchen Stick würdest Du empfehlen?
                • M michihorn
                  @michihorn
                  Schau hier:
                  https://www.zigbee2mqtt.io/guide/adapters/#recommended
                    @michihorn
                    Schau hier:
                    michihorn
                    @thomas-braun Danke , was machst du mit Zigbee über mehrere Etagen, die Osram Steckdose als Repeater funktioniert nur suboptimal
                    • M michihorn
                      @michihorn Habe das Problem nicht, da nur eine Etage.
                      Aber ich würde andere Router einsetzen. Die Osram-Dinger sind da eher schwachbrüstig unterwegs.
                      • arteckA arteck
                        michihorn
                        schrieb am zuletzt editiert von michihorn
                        @arteck Ich nochmal 😊 Ich habe soeben ein Vollbackup über die vorhandene Installation gebügelt, jetzt sind wieder alle Geräte auf true und senden Werte. Was macht also den Unterschied aus zwischen dem Versuch vorher, die Backup Dateien von Zigbee drüber zubügeln und einem kompletten Restore eines Backups?
                        Und was passiert wenn ich einen Backup Rechner z.B einen alten Pi ebenfalls auf Kanal 11 laufen lasse?
                        Michael
                        BTW: Für meine private Immobilie über mehrere Stockwerkwerke möchte ich einen Zigbee Router anschaffen. Ist der Aquara Hub M2 Zigbee zu gebrauchen?
                        AsgothianA arteckA 2 Antworten Letzte Antwort
                        • M michihorn
                          Michael
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @michihorn sagte in zigbee Adapter:
                          Nein.
                          A.
                          • AsgothianA Asgothian
                            Nein.
                            A.
                            michihorn
                            @asgothian Hast du eine alternative Empfehlung?
                            • M michihorn
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @michihorn Nein.
                              Ein Zigbee Netzwerk wird durch eine hinreichend grosse Zahl von Geräten mit Routing Funktion Stabil
                              • Birnen
                              • Steckdosen
                              • andere immer am Strom befindliche Geräte.
                              ich bin kein Freund von extra Routern ohne weitere Funktion.
                              A.
                              • M michihorn
                                Michael
                                arteckA Offline
                                arteckA Offline
                                arteck
                                genau das...
                                du musst die richtigen Dateien an die richtige stelle bringen..
                                  Kueppert
                                  schrieb am zuletzt editiert von Kueppert
                                  ich nutze den Sonoff Zigbee-Stick. Gestern hab ich ein Update drauf gemacht gem. Anleitung von Heimautomatisierung auf die Version 19.02.2022 direkt über USB und ein Python-Skript. Hat alles super geklappt. Geräte sind auch alle noch da und erreichbar.
                                  Problem: Wenn ich ein neues Gerät anlernen möchte (Aquara Doorsensor BJ 2016) funktioniert das Interview:
                                  zigbee.0 2022-05-04 09:09:33.334	info	DeviceConfigure successful 0x00158d00033ab609 lumi.sensor_magnet.aq2
                                  zigbee.0 2022-05-04 09:09:33.326	info	Configuring 0x00158d00033ab609 lumi.sensor_magnet.aq2
                                  zigbee.0 2022-05-04 09:09:33.325	info	Device '0x00158d00033ab609' is supported, identified as: Xiaomi Aqara door & window contact sensor (MCCGQ11LM)
                                  zigbee.0 2022-05-04 09:09:33.324	info	Successfully interviewed '0x00158d00033ab609', device has succesfully been paired
                                  aber in der Zigbee-Inszanz (habe nur eine) wird das Gerät nicht korrekt angezeigt:
                                  Hab den Sensor jetzt 2mal neu angelernt (vorher gelöscht). SO ein Verhalten hatte ich in den vergangenen Jahren noch nicht ^^ Jemand eine Idee, was ich kaputt gemacht hab?
                                  Zigbee-Instanz hab ich auch schon neu gestartet...macht aktuell keinen Unterschied.
                                  Mein Stick in der Instanz:
                                  Der Stick lief vorher auf der Standard-Version (Auslieferungszustand) und das schon einige Wochen anstandslos. Vorher war eine Version von 2021-01 drauf.
                                  NACHTRAG:
                                  Hab gerade eine Osram Flex neu gepaired (war vorher nicht in Nutzung und auch nicht angelernt). Das funktioniert einwandfrei 🤔
                                  Hier noch meine Adapter-Einstellungen (nix dran verändert...ewig nicht):
                                  • K Kueppert
                                    NACHTRAG:
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @kueppert sagte in zigbee Adapter:
                                    Bitte schau ob die Datenpunkte des Sensors sauber verarbeitet werden, sprich ob es sich um ein Problem mit der Kacheldarstellung oder um ein problem mit der Funktion des Sensors handelt.
                                    bitte dazu auch den wert 00158d00033ab609 in den Datenpunkt zigbee.0.info.debugmessages eintragen und schauen ob das aktivieren des Sensors entsprechende Meldungen im iobroker auslöst.
                                    A.
                                      A.
                                      Kueppert
                                      @asgothian sagte in zigbee Adapter:
                                      00158d00033ab609
                                      Hab die ID vom Sensor eingetragen bei debug. Folgendes erscheint im Log beim neuen Anlernen (war vorher entfernt):
                                      zigbee.0 2022-05-04 09:57:16.507	info	Zigbee: stop joining
                                      zigbee.0 2022-05-04 09:57:13.312	warn	ELEVATED publishToState: value generated 'true' from device 00158d00033ab609 for 'Is open'
                                      zigbee.0 2022-05-04 09:57:13.312	warn	ELEVATED publishToState: value generated 'false' from device 00158d00033ab609 for 'Contact event'
                                      zigbee.0 2022-05-04 09:57:13.311	warn	ELEVATED publishToState: message received '{"contact":false}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:57:13.309	warn	ELEVATED publishToState: value generated '171' from device 00158d00033ab609 for 'Link quality'
                                      zigbee.0 2022-05-04 09:57:13.308	warn	ELEVATED publishToState: message received '{"linkquality":171}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:57:09.872	warn	ELEVATED publishToState: value generated 'false' from device 00158d00033ab609 for 'Is open'
                                      zigbee.0 2022-05-04 09:57:09.871	warn	ELEVATED publishToState: value generated 'true' from device 00158d00033ab609 for 'Contact event'
                                      zigbee.0 2022-05-04 09:57:09.871	warn	ELEVATED publishToState: message received '{"contact":true}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:57:09.869	warn	ELEVATED publishToState: value generated '142' from device 00158d00033ab609 for 'Link quality'
                                      zigbee.0 2022-05-04 09:57:09.868	warn	ELEVATED publishToState: message received '{"linkquality":142}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:30.056	warn	ELEVATED publishToState: value generated '10' from device 00158d00033ab609 for 'Link quality'
                                      zigbee.0 2022-05-04 09:55:30.056	warn	ELEVATED publishToState: message received '{"linkquality":10}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:30.055	warn	ELEVATED publishToState: value generated 'true' from device 00158d00033ab609 for 'Available'
                                      zigbee.0 2022-05-04 09:55:30.055	warn	ELEVATED publishToState: message received '{"available":true}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:29.057	info	DeviceConfigure successful 0x00158d00033ab609 lumi.sensor_magnet.aq2
                                      zigbee.0 2022-05-04 09:55:29.052	info	Configuring 0x00158d00033ab609 lumi.sensor_magnet.aq2
                                      zigbee.0 2022-05-04 09:55:29.050	info	Device '0x00158d00033ab609' is supported, identified as: Xiaomi Aqara door & window contact sensor (MCCGQ11LM)
                                      zigbee.0 2022-05-04 09:55:29.050	info	Successfully interviewed '0x00158d00033ab609', device has succesfully been paired
                                      zigbee.0 2022-05-04 09:55:28.761	warn	ELEVATED publishToState: value generated '100' from device 00158d00033ab609 for 'Battery percent'
                                      zigbee.0 2022-05-04 09:55:28.760	warn	ELEVATED publishToState: value generated '3.055' from device 00158d00033ab609 for 'Battery voltage'
                                      zigbee.0 2022-05-04 09:55:28.760	warn	ELEVATED publishToState: value generated 'true' from device 00158d00033ab609 for 'Is open'
                                      zigbee.0 2022-05-04 09:55:28.760	warn	ELEVATED publishToState: value generated 'false' from device 00158d00033ab609 for 'Contact event'
                                      zigbee.0 2022-05-04 09:55:28.759	warn	ELEVATED publishToState: message received '{"voltage":3055,"battery":100,"temperature":30,"contact":false}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:28.756	warn	ELEVATED publishToState: value generated '185' from device 00158d00033ab609 for 'Link quality'
                                      zigbee.0 2022-05-04 09:55:28.756	warn	ELEVATED publishToState: message received '{"linkquality":185}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:25.267	warn	ELEVATED publishToState: value generated '10' from device 00158d00033ab609 for 'Link quality'
                                      zigbee.0 2022-05-04 09:55:25.267	warn	ELEVATED publishToState: message received '{"linkquality":10}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:25.266	warn	ELEVATED publishToState: value generated 'true' from device 00158d00033ab609 for 'Available'
                                      zigbee.0 2022-05-04 09:55:25.265	warn	ELEVATED publishToState: message received '{"available":true}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:24.518	warn	ELEVATED publishToState: value generated '100' from device 00158d00033ab609 for 'Battery percent'
                                      zigbee.0 2022-05-04 09:55:24.517	warn	ELEVATED publishToState: value generated '3.055' from device 00158d00033ab609 for 'Battery voltage'
                                      zigbee.0 2022-05-04 09:55:24.517	warn	ELEVATED publishToState: value generated 'true' from device 00158d00033ab609 for 'Is open'
                                      zigbee.0 2022-05-04 09:55:24.517	warn	ELEVATED publishToState: value generated 'false' from device 00158d00033ab609 for 'Contact event'
                                      zigbee.0 2022-05-04 09:55:24.516	warn	ELEVATED publishToState: message received '{"voltage":3055,"battery":100,"temperature":30,"contact":false}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:24.513	warn	ELEVATED publishToState: value generated '185' from device 00158d00033ab609 for 'Link quality'
                                      zigbee.0 2022-05-04 09:55:24.513	warn	ELEVATED publishToState: message received '{"linkquality":185}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:24.384	warn	ELEVATED publishToState: message received '{}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:24.381	warn	ELEVATED publishToState: value generated '174' from device 00158d00033ab609 for 'Link quality'
                                      zigbee.0 2022-05-04 09:55:24.381	warn	ELEVATED publishToState: message received '{"linkquality":174}' from device 00158d00033ab609 type 'MCCGQ11LM'
                                      zigbee.0 2022-05-04 09:55:24.260	warn	Device '0x00158d00033ab609' announced itself
                                      zigbee.0 2022-05-04 09:55:24.105	info	Starting interview of '0x00158d00033ab609'
                                      zigbee.0 2022-05-04 09:55:15.084	info	Zigbee: allowing new devices to join.
                                      Sieht so aus, als wäre "nur" die Kachel kaputt??
                                      aa1a882b-686a-4eef-a656-9a81b177a872-image.png 6f957c4f-f0d2-42f4-adcf-3b4c5f049836-image.png e6a7b8e1-5d90-403f-b80e-834b92dc625c-image.png
                                      Kann ich die Kachel irgendwie selbst "reparieren"?
                                      M AsgothianA 2 Antworten Letzte Antwort
                                      • K Kueppert
                                        00158d00033ab609
                                        michihorn
                                        @kueppert Ich hatte das auch schon mal, schau mal in den Objekten, dort wird der Sensor angezeigt und liefert auch Werte. Also könntest Du die Bezichnung des Sensors auch in den Objekten ändern. Es ist auch nicht unbedingt mit deinem Sonoff Stick im direkten Zusammenhang, da ich das Problem mit einen einfachen "Wald und Wiesen" Stick gehabt habe. Am Ende habe ich eine neue Zigbee Instanz angelegt und alle Sensoren neu angelegt.
                                        • M michihorn
                                          Kueppert
                                          @michihorn Hi, danke für den Tip. Aber alle Sensoren neu anlernen...uuhhhh, das möchte ich möglichst verhindern ^^
